TPS1HTC100-Q1: Delay time from VUVLOF triggered to Vout is shut down
Part Number: TPS1HTC100-Q1
Other Parts Discussed in Thread: TPS1HB50-Q1, TPS2HB50-Q1
My customer has questions.
About the following three devices, how much time does it take from VUVLOF triggered to Vout is shut down respectively?
TPS1HTC100-Q1
TPS1HB50-Q1
TPS2HB50-Q1
K.Hirano
  • Hello Hirano-san,
    We are double checking with our backend team to get you the right information.
    Alan
  • After reaching out to the design team they said the VBB_UV response time is not a spec that is normally measured.
    When VBB_UV condition happens, gate pull-up is going to be disabled, and gate will be pulled down by passive VGS resistor. Therefore, pull-down will be relatively slower than active pull-down
     it could take about 50~100us depending on supply voltage. Since this is not specified in the datasheet, use this value only as reference when testing.
    Alan
