hi, TI experts:
described as the question title, how does TPS2372 act if a DC 54V applied to VDD and VSS directly, the UVLO threshold is the only requirement for the internal mosfet starting on?
hi, TI experts:
Hi Xiang Tao,
Thanks for reaching out!
Even without detection / classification, the TPS2372's internal hotswap (MOSFET) will be turned on if its VDD-VSS is above 36.3 - 40V as the below table.
A PSE also needs to provide higher than 36.3 - 40V to turn on the internal hotswap after the detection/classification.
Diang
Hi Xiang Tao,
Thanks for your reply.
TPH/TPL/BT mainly depends on the classification event number and width (BT has a wider 1st classification). If you uses a passive PoE injector (> 40V, without detection and classification), you will have classification event number = 0, and all your TPH/TPL/BT will be Hi-Z.
Diang
