Other Parts Discussed in Thread: AWR2E44, AWR2944
Hello Team,
We are using AWR2E44 Ecu . Regarding PMIC [LP8774x] we are having below queries:
* Does hardware support CRC feature in the SBC ? This is required since ECU platform is Little endian and if the hardware doesn't support CRC then SBC cannot be tested.
Our SBC Driver has a Limitation:
SPI communication without CRC is not possible on platforms with little-endian. The reason is the 24-bit transfer length. For platforms with little-endian and CRC enabled a SpiDataWidth of 32 must be used. Please kindly share your valuable understandings regarding this. I hope to hear from you soon.
Thanks & Regards,
Vicky John T
