VOVPGDRV_On only gives a max. value. Can you give a minimun value which is relevant for FET dimensioning (UDS). Ciss will be regarded for FET selection, as you mentioned in the related thread. But we need to know the minimum output voltage of OVPGDRV, that we can guarantee the FET is completely switched on. Up to dissimilarity requirements we are not able to use the recommended FETs in the PMIC datasheet.
Regards, Peter
