TPS62812-Q1: VIL range matching issues
Part Number: TPS62812-Q1
Hello team,
Customer met an issue for VIL range, for example, when use 3V3 MCU to control buck enable pin, the voltage range of MCU low logic will be 0-0.66V, which is larger than 0.3V, so can you share your comments here?
Thanks.
