TPS23881: The usage of Fuse
Part Number: TPS23881
Other Parts Discussed in Thread: TPS2384
Hi TI team
Our project use the TPS23881 as PSE controller. For the FUSE, We find two similar case about usage of TPS2384 but we still has some question as below:
1. I saw that the Fuse is relate to UL testing in that similar case. Do we must use fuse if we want to do UL testing? Do you know which UL testing item is relate to Fuse if we must use?
2. Can we use a resettable Fuse for TPS23881? Many thanks
William Tang
