TPS65987D: ADCIN1 pin configuration
Part Number: TPS65987D
Hello support team,
I would like to ask how to setup ADCIN1 pin for my application.
My application: UFP, only source, 100W. Config by spi flash. I want to use both PPHVx internal switches together for vbus power path.
Can I use the first row from this table? Will it works? Or do you recommend different boot mode configuration? In my application there is no battery.
Thank you
Martin
