BQ25750: Auto Reverse Mode Timing
Part Number: BQ25750
When auto reverse mode is enabled for BQ25750, what is the typical delay time between Vac crossing the ACUV threshold and the buck-boost converter bringing back the sys voltage to VSYS_REV? Essentially the ramp up time on Vsys Fig 8.6 of the datasheet identified as the 'Reverse mode on' period.
I understand this would somewhat depend on the battery voltage, the target VSYS_REV value and the loading, but do you have some typical value to share?
Some experimental waveforms showing this transition to complement section 9.2.1.3 'application curves' of the datasheet would be nice!
Thank you for your help.
