UCC28810: CS pin of PFC section is getting damaged
Part Number: UCC28810
I am Engr. Usman Haider from Champion Fans, Pakistan. We are deploying chinese made BLDC motor drivers in our BLDC ceiling fans. These drivers have some issues. In the SMPS (AC-DC) section, we are facing surge-related problems that are causing MOSFETs and gate driver IC-OB3636 to get damaged. The CS pin of the IC has been damaged badly and the explicit resistance at the gate, source pins also got damaged. It seems like the PFC IC- OB3631 has a slow response time that allows the surge to damage the PCB. We want you to design a circuit using your ICs and MOSFETs or if you can suggest us something that we could add to our SMPS part so that this section could be ideal for a customer. The SMPS circuit diagram and the damaged PCB photo have been attached for your reference.
FD6353 AC Side.pdf
