Could TPS54824 withstand 100mS8.5A current?
How do we evaluate the output current ability in our Buck devices?
Thank you
Yishan Chen
Thank you
Yishan Chen
Hi Yishan,
The TPS54824 is able to handle a continuous output current of up tp 8A, however a short burst of higher current may be ok if it doesn't go past the table below (page 5 of datasheet):
Eileen
Hi Eileen,
Thank you for your reply.
How long is the 'short burst'?
Do we have any test results for current capability?
Thank you,
Yishan Chen
Hi Yishan,
The recommended max IOUT as per table 6.3 in the datasheet is 8A. So it is not recommended to exceed 8A even if for a small burst. Please use it till 8A and if more current is required please use a higher current rated device.
Amod
