Other Parts Discussed in Thread: TPS56837EVM, TPS56837,
Hi:
I used the TPS56837H chip to build a 24V to 12V step-down circuit, and the measured SW was more obvious than the overshoot, exceeding the SW pin withstand voltage value in the specification. Currently, the overshoot can be solved by adding RC through BOOT and SW pin, but the overshoot (up to -8V) cannot be solved, could you please provide solutions, thank you!
