Hi Francisco,
VIN1 can’t be left floating because VOUT will pull up VIN1 and RCB will never activate. Are you using a TI LDO? Typically, TI LDOs have a “P” variant with output discharge – this typically should resolve the problem/activate RCB and save Iq as the output discharge will only be active when VIN1 is disabled.
Shiven Dhir
Hi Shiven,
Hi Francisco,
Sorry if you didnt get support in past or present.
Your understanding is correct as explained in the datasheet section.
Shiven Dhir
