Equation 26 for ripple, what are the units of R and C? Is C in uf (100) or 100e-6?
If R is in ohms and C in uf (e-6), (tmax/tmin+tmin/ton) is >1 which makes the answer negative and ripple very small???
Please see section 8.2.15.4.2 of the datasheet for the output capacitor specifications.
I am not sure what calculator that is but the datasheet equations should be in SI units.
Thank you,
Joshua Austria
