LP8868Y-Q1: TPS923655EVM replace to LP8868Y to test customer's requirement
Part Number: LP8868Y-Q1
Hello expert,
I would like to use TPS923655EVM to replace with LP8868Y on this board. I will change the IC and exchange pin13/14 for CSP/CSN. But I would like to double check below points.
  • if we don't have LED board, could we use Eload to simulate LED board? I tried on CV mode but the voltage cannot regulated on set voltage.
  • do you have test waveform on Vout/Vin on EVM board to let us know which waveform is normal which is abnormal?
Ann Lien
