How much current or watts can this regulator provide when VOUT is set to 12V on each channel. VIN will be 28V
Thank you
Thank you
Hi Ethan,
The maximum IOUT is part dependent. You can find these maximums in the datasheet in section 4. I have included the device comparison table below for your convenience:
Another note is that the EVM you linked is configured for a single output. If you would like to utilize the dual output version of the device, I would recommend looking into the dual output EVM.
Thank you,
Joshua Austria
