Because of the holidays, TI E2E™ design support forum responses will be delayed from Dec. 25 through Jan. 2. Thank you for your patience.
TPS92663A-Q1: LED点灯制御について
Part Number: TPS92663A-Q1
Question about LED lighting register setting of TPS92663A-Q1
Even if data is transferred according to instructions from the customer,
It doesn't work as expected.
TPS92662A-Q1 is
It worked as expected
At the direction of the customer
TPS92663A-Q1 and
TPS92662A-Q1 has exactly the same data
This is an instruction to make it work.
Since the number of channels is different, even if you ask if it is true.
I can't get an answer.
As the delivery date is approaching, I am currently requesting a detailed day sheet from TI yesterday.
Thank you for your cooperation in resolving this issue.
