hi BU,
for the LM5175, there is 2 issue with below board, please help check what's the issue?
1. the LM5175- self is heating, about 80C,
2. the load abililty is limit, not as design target,
regards,
robin Liu3286.mosfet.pdf
hi BU,
regards,
Hi Robin,
thank you for supporting the LM5175.
Could you please attach the filled out LM5175QUICKSTART-CALC to this thread?
This will give the best overview on the application setup and requirement.
Can you also add some more details on the conditions:
- Under which condition does the controller heat up to 80Deg.
- for Point 2 the Quickstart calculator should give most of the required answers.
- the Compensation network on COMP is wrong - please check this again - here also the Quickstart calculator can help
Note: it should be R + C with an C in parallel - schematic shows R + R with C in parallel
STefan
