Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
BQ24600: Charging status Failure
Part Number: BQ24600
In BQ24600,where STAT and PG pin unable to change the value in software according to the Battery connected,disconnected and Charging In-progress.Where I check all the voltage measurements in the Input and output of the Battery IC it shows the correct data with the Measurement.
