LP5861T: How to achieve Analog dimming and ..
Part Number: LP5861T
Have two queries on part LP5861T programming settings
Query1:
How to achieve Analog Dimming
We are following this Init sequence for the driver.
Register                             Value
CHIP_EN                            0x01
DEV_INITIAL                     0x58
DEV_CONFIG1                 0x00
DEV_CONFIG2                 0x00
DEV_CONFIG3                 0x57
What are the appropriate registers we have to configure to achieve Analog dimming, currently we are able to achieve using PWM dimming.
Query2:
When we set register Dev_config3 to 37.5mA(Maximum current setting). What is the expected current range at individual output CS0 - CS17.
we are not getting the maximum current as desired with maximum duty cycle.
Rahul
