Other Parts Discussed in Thread: TPS564247, TPS56637
previously, you confirmed that this part is DCAP3 not DCAP1.
however, i need to know what inductor value to use in order to output 7.5v from 15v input?
In datasheet it mentioned recommended 4.7u for 5v and 6.8u for 10v... can i use 4.7u for 7.5v and still get 10mv p-p or less ripple??
my output capacitors bank are: 3x22u 1206 + 7x 10u 0805 + 1x 100n 0402 ceramic caps + 10uf 3ohm esr elec cap for damping.
please check and simulate if necessary. 4.7u seems a lot better and more available\cheap than 6.8.
REGARDS
