BQ4050: What parameters will the FCC reduce based on?
Part Number: BQ4050
Hi TI engineer:
        As the number of cycles increases, what parameters will the FCC reduce based on? Is this parameter in the gg file?
Looking forward to your reply! thank you!
    The Full Charge Capacity will reduce based on the direct measurements taken by the gauge throughout the last full discharge cycle completed by the device, which I do not believe can be changed within the parameters of the gauge.
    Anthony
