BQ27742-G1: BQ27742-G1 Ra-table and key update abnormally
Part Number: BQ27742-G1
our customer found few batteries which use BQ27742-G1 work abnormally ,now we received one of them, the communication information on the right side picture that shown us SOH only remaining 33%,
Look into the data flash, we found that the Ra-table change abnormally and also , the unseal key and authentication key both been clean to 0 ,we confirm with customer that the terminal don't have the unseal key ,
in this way the terminal have no way to unseal the fuel gauge and change the value in the register, to sum up, we suppose the data in the Gauge was updating abnormally by itself, does it have any condition will cause the similar failure?
    I will have to talk to other members on my team and look into this.
    Adrian
  • Hi  Adrian, when do you think I can get some feedback?  now we 've sample on hand, can send out for analysis if necessary , please be free to let me know if need the IC samples, thanks!
  • Hello Yichong,
    After discussing with the firmware team, they believe that under normal operation this should not happen. They concluded that the gauge must have been accidently (or purposely) unsealed and those values got over written (a write that was not controlled by the gauge)
    Adrian
  • Hi Adrian, how about the Ra-table update abnormally?
  • Hi Yichong,
    It is believed those values got overwritten as well with garbage data just like the seal and authentication keys.
    Adrian
  • Hi Adrian, we want to know what kind of condition or use case will cause the Ra table update abnormally high, please kindly five your advise, thanks !
  • Hi Yichong,
    The most common reason we see values to change abnormally is when the srec file on the gauge becomes corrupt.
    Adrian
  • Hi  Adrian:
    you mentioned that the srec file may corrupt, how can we prove this ?
    Now we have 2 defect samples on hand, after running few cycles,  the value of table update to be lower one , so that  it seem the update logic of gauge is normal , what I want to know is if any condition (charge and discharge method) may cause the Ra-table be such high value?
  • Hi Yichong,
    Can you send me the srec file from the gauge that is reporting abnormally high Ra table values. I can verify whether the srec file is corrupted or not. I want to verify this first.
    Adrian
  • Hi Adrian:
    please refer to attached srec file
  • sorry it's difficult to upload the file so that I copy the data as below
    S00F00004657303734325F30315F303304
    S31A00004000806517F19502542605D0000000F751F6C9F414520968
    S31A0000401521326D00000000CFDC17F30000167A00003564F9A158
    S31A0000402A0015300100EF0522050100001001003C00503C0064DC
    S31A0000403F3C002012560410F2FF0EFC63000B003203E801010105
    S31A00004054F4001EC81408003C0E10000A46050F050F0320003234
    S31A00004069006446500A0EE70E9B0190006419DC5C6000C8000428
    S31A0000407E0332000100140001001403230708255A0F1E600D4832
    S31A0000409300C82801F40000000000000000000043800400C8009E
    S31A000040A80001140036000000000582000A138800C80A03002889
    S31A000040BD0F21340A01F403E8521110FC10C610971078105810AE
    S31A000040D23C101F10050FEB0FD20FBA0FA30F900F7D0F6C0F5CEC
    S31A000040E70F4B0F3A0F1E0F070EF80EEC0EE40EDC0ED60ED10E2B
    S31A000040FCCD0ECA0ECC0EC80EC20EBC0EAD0E9F0E8C0E790E78AB
    S31A000041110E620DE80BE8FBB5FD63FE4CFE77FEB6FE75FEDCFE6D
    S31A0000412679FE9CFE87FF0DFF19FED1FEC0FEB5FE56FEBDFF3B39
    S31A0000413BFE30FEDCFFEB003AFFD1FFFEFF86FF69FF69FE81FBA1
    S31A0000415096F91DF74EF58CF7DDF7A1F53CFAE4FA2AFD7BEEEDF0
    S31A00004165B70DFFD0FFD1FFD0FFC3FFBBFFD5FFD4FFD1FFD8FF44
    S31A0000417AD8FFD0FFE1000400A30099FF20FF27FF26FF20FF4A91
    S31A0000418FFF33FF40FEE0FEE1FED7FEC4FEBCFE0CFDD6FF0210A8
    S31A000041A4FEFFCE022601C20019006428FF62FF620032000A2D7A
    S31A000041B9323C0110FE10FE10CC109A32505050097F8018800B0D
    S31A000041CE07001404000AF0000F05003201C214089800003C00C4
    S31A000041E34B0028003C3C01019019861115FFFFFFFF234545676F
    S31A000041F889ABCDEFFEDCBA987654543201B300B810FB0D1E0698
    S31A0000420D40FB5E0065000A1964003C00000000000000000000D5
    S31A0000422200000000000000000000000000000000000000000081
    S31A000042370000000000000000000000000011490110E009C40153
    S31A0000424C0A28003C01F40501C2025805022610B310CC10E51001
    S31A00004261FE1117113011491162116212AB0E00000000000000D0
    S31A00004276000000000013009B7A28F70000038A000000120ED861
    S31A0000428B0031000000010058119411A84318FE7050000A7F0787
    S31A000042A001009600AF004B00640B54020BB810CC02106845351A
    S31A000042B5324E170946012A91000000000000000000000000004C
    S31A000042CA000000000000000000000000000000000000000000D9
    S31A000042DF000000000000000000000000000000000000000000C4
    S31A000042F4FFFFFFFFFFFFFFFFFFFFFFFF000004DC04DC051805D9
    S31A000043099D06A105550637099409DD0A4B09940B350E4A267F0C
    S31A0000431E6C86FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA5
    S31A00004333FFFFFFFFFFFFFFFFFFFFFFFFFF0055074A074A07A4DA
    S31A00004348086C09F2080009530E5E0ECC0F710E5E10D0156F39B8
    S31A0000435DBF7FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1A
    S31A00004372FFFFFFFFFFFFFFFFFFFFFFFFFFFF806517F195025466
    S31A000043872605D0000000F751F6C9F414520921326D00000000F6
    S31A0000439CCFDC17F30000167A00003564F9A10015300100EF0554
    S31A000043B122050100001001003C00503C00643CFFFFFFFF000153
    S31A000043C633E9FFFECC15FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1
    S31A000043DBFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDC
    S315000043F0FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC7
    S31A001000000033FFEA0033FBEB0033FC6D0033FE650033FE7D00C0
    S31A0010001515545400000742003FFFFF003FFFFF003FFFFF003FC4
    S31A0010002AFFFF003FFFFF003FFFFF003FFFFF003FFFFF003FFF7B
    S31A0010003FFF003F01030033CB58000800ED000000000000000009
    S31A00100054000EAAFF000EA7FB000EA6FF000EA1FF000EA0FF000C
    S31A001000690EA3FE000EA247003AFFD2000EA1FF000EA058000EF9
    S31A0010007EA3FF000EA257000EA5BD000EA40C003AFFCA000EA1CE
    S31A00100093FE000EA047000EA3FE000EA247003AFFCA003AFFC2AB
    S31A001000A80033FFD6000EAFFF00034F01000C113F0030FFCD00BE
    S31A001000BD35FFD4000C102F0035FFD40023FFFF0014AF010003D5
    S31A001000D24F01000C113F0030FFC50035FFCC000C102F0035FFE4
    S31A001000E7CC0023FFFF000BDFFF0033FFC400397FA90016AFFEFE
    S31A001000FC000EABC1003A7FE20001BCD5000E1C8B0036FFB60092
    S31A001001110E1C030036FFB6000E1CBA0036FFB6003A7FFB000E1A
    S31A00100126ABC1003A7FE2000CAFBC000EABFF0001BCD5003AFBB1
    S31A0010013BB90000FEDE000EAFFF0002FF000002FF01000EACFF8C
    S31A00100150000EABFF000CAFCE000CAFBD003AFDBB0000FFDE00FC
    S31A001001650EA1BE000EA0370018AB00000E2BBF000E1BFF003604
    S31A0010017AFF9B000EA08F000EA17F0018AB0D000EBBFB0033FF8F
    S31A0010018F97000EA08F000EA17F0018AB0D000E2B040002CB0D5C
    S31A001001A4000EA1BE000EA0370018AB00000E2BDF000E1BFF00DB
    S31A001001B936FF8B000EA08F000EA17F0018AB02000E2B040033BB
    S31A001001CEFF87000EA08F000EA17F0018AB02000EBBFB0002CBBF
    S31A001001E302000EA0AF000EA17F000EAFF40002CF00000EBA7F9B
    S31A001001F8000E2A40003AFF09000EACFE000EABFF0016AF0200EB
    S31A0010020D397FA80023FFFF0004AFE30004BFE20036FF7300045E
    S31A00100222A0E20004A1E30002C7000002C6010004AFE50001BFBD
    S31A00100237E30004AFE40001BFE2000EACFF00041CE10031FF2C6A
    S31A0010024C0004A0E20004A1E30018AB02000E2B7F000E1BFF00D4
    S31A0010026132FF61000EFAFC000CAFFB00182B02000E1BFF003683
    S31A00100276FF3A0018AF02000EBF7F0002CF020018A7000018A6BF
    S31A0010028B010018AB02000E2BDF000E1BFF0036FF4C0016A50105
    S31A001002A00016A4010016A9010016A8010018AB02000E2B2000DB
    S31A001002B502CB02000E2BBF000E1BFF0032FF19000EBADF00330B
    S31A001002CAFF190016A9010016A801002DFFFF0016AB010016ACC3
    S31A001002DF010016AD010016AE010016A5010016A4010016A30139
    S31A001002F40016A2010016A1010016A0010016A9010016A8010038
    S31A0010030917AF010016AF01003F1FFF0018AB02000E2BBF000E14
    S31A0010031E1BFF0032FF340018A7000018A6010004AFE2000ECF45
    S31A00100333FC0001BFE200055FE30001BFE3000D1FCC00041CE11E
    S31A001003480035FF6C0000FFE30000FFE20005BBE0000E1BFE0060
    S31A0010035D30FF1F000EABF70004AFE0000E1FFE0032FF22000E58
    S31A00100372ABF5000EA0AF000EA17F0002CB00000EBADF000BDFD7
    S31A00100387FF000E2A20000EFADF0032FF1D0033FF730023FFFFF9
    S31A0010039C000E2A20000EFADF0032FF180004A0E20004A1E300A0
    S31A001003B118AB02000E2B80000EBFDF0002CF02000378FF0003A7
    S31A001003C679FF000374FF000375FF0033FF7A0023FFFF00397F22
    S31A001003DBA9003AFECD00397FA80023FFFF00397FA90016AFFDA5
    S31A001003F0000CAFC8000CAFB9000E2A20000EFADF0032FF01007A
    S31A0010040504ABDF000E2BEF000CBDFF0001BFDF0004AFE0000E0E
    S31A0010041A2F0B0001BFE0000EAFFC0002FF00000EAFF20002FF73
    S31A0010042F01000EAF5F0002FF02000EABFD000CAF9C000CAF8D2D
    S31A00100444003AFEE70000FFE30000FFE2003AFF7A0016AF030030
    S31A00100459397FA80023FFFF000374FF00397FA9000CAFD8000C81
    S31A0010046EAFC9001EAE04001EAD03001EA405000EEBFC000CAFD6
    S31A00100483FC000CAFC2000EC257000CAFB3000ED3FF000CAFE0C5
    S31A00100498000EC001000DFFD10002C9000002C801000ECE030018
    S31A001004AD02DE01000DFFDF0002DF000002D40200397FA8001629
    S31A001004C2A4010023FFFF00397FA90016AFFD000E2A20000EFAC6
    S31A001004D7DF0032FECB003AFE9D0000FFE0000EAFFF0001BFE50B
    S31A001004EC000EAF570001BFE40000FCE1000EAFFB0002FF000097
    S31A001005010EAFFF0002FF01000EAF1F0002FF02000EABFF000E6C
    S31A00100516ACCE000EAD58003AFEE7000EAFFC0002FF00000EAF97
    S31A0010052B980002FF01000EAF5E0002FF02000EABFE000EACD8A4
    S31A00100540000EAD83003AFEE7000EAFFC0002FF00000EAFF200CA
    S31A0010055502FF01000EAF5F0002FF02000EABFD000EACE8000EF4
    S31A0010056AAD3C003AFEE70000FFE30000FFE2003AFF7A0016AF23
    S31A0010057F0300397FA80023FFFF000EA2FF000EA37F000EAFFF32
    S31A001005940002DF40000EAFFF0002DF30000EA1BE000EA03700FC
    S31A001005A918AB01000E2B7F000E1BFF0036FE8F000EAFFD000204
    S31A001005BEDF31001AAB91000E2B1A0002DB91000EAF1A0002DF33
    S31A001005D390000EA04F000EA17F000EAFFF0002CF00000EAF00F8
    S31A001005E80002DF61001AAB60000E2B020002DB60000E2A43008E
    S31A001005FD0EAF070002DF930023FFFF00397FA9000E2A04000ECF
    S31A00100612FAFB000CAFFB000E1BFF0032FE76003AFF180004AF40
    S31A00100627E0000E1FFE0032FE67000EA1BE000EA02C0018AF0CEC
    S31A0010063C0036FE6D0000FFA40033FE68000EA1FF000EA01C003E
    S31A0010065118AF01000E2F200002CF010000FFE000397FA8002325
    S31A00100666FFFF00037FFF000CAFFF000B7FFF00037FFF000378AB
    S31A0010067BFF000379FF000370FF000371FF000372FF000373FF0C
    S31A00100690000374FF000375FF00037EFF00037DFF00037CFF00D5
    S31A001006A5037BFF003EBFFF000378FF000379FF000EA0EF000E11
    S31A001006BAA17F0018AB03000E2B7F000E1BFF0036FE460018AB12
    S31A001006CF04000EBB7F0002CB040018AB04000E2B800002CB0492
    S31A001006E4000EA1FF000EA0570018AF02000EBF7F0002CF020050
    S31A001006F933FF7A0023FFFF000E2A20000EFADF0032FE3F000E4D
    S31A0010070EA0CF000EA17F0018AB01000E2B040002CB01000EBA8C
    S31A00100723DF0023FFFF000EA0CF000EA17F0018AB01000E2B04FF
    S31A001007380002CB010018AB01000E2B080002CB010023FFFF00D4
    S31A0010074D397FAD0016AFFE000CAFE4000CAFD5000EAFFF00026C
    S31A00100762FF01000EAFFB0002FF00003A7FBE000CAFC8000CAFFE
    S31A00100777B9000EA1BD000EA0760018AE17000EADFF000EAC17A6
    S31A0010078C000EABFC00397FDD0002FD000002FE01000CAF9B00A2
    S31A001007A10CAF8C000CAF5D000CAF4E003A7FBE0016AF0200394E
    S31A001007B67FAC0023FFFF00397FAD0016AFFA0002FB000002FCAD
    S31A001007CB01001EA80B001EA90A0004ACCD0004ABCE00397FDCD2
    S31A001007E0000CAFDE000CAFCD000CAFBC000E6BFE000CAFE40040
    S31A001007F50CAFD5000EA1FE000EA0870018C41E0018D51D000C57
    S31A0010080AAF9C000CAF8D000EAFFE00397FD2000CAFE0000CAF95
    S31A0010081FD1000CAFC8000CAFB9000E887F0004ADCB0004ACCCD9
    S31A00100834000EAFFE00397FD200037EFF00037DFF00037CFF00D7
    S31A00100849037BFF000CAF9B000CAF8C000CAF1D000CAF0E003990
    S31A0010085E7FD50016AF04003A7FC50002FB020002FC030002FDD5
    S31A00100873040002FE05000CAF5C000CAF4D000EAFFE00397FD2ED
    S31A00100888000CAFE0000CAFD1000CAFC8000CAFB9001E140100F4
    S31A0010089D0CAFFC001EAB00000C7B5B000CAFCD000CAFBC000EC1
    S31A001008B2AFFE00397FD2001EAF0500037FFF001EAF0500037F3D
    S31A001008C7FF001EAF0500037FFF001EAF0500037FFF00397FD9D0
    S31A001008DC0016AF04000370FF000371FF000378FF000379FF004E
    S31A001008F1397FD40016AF0400397FD1000CAFDB000CAFEC0016AB
    S31A00100906AF0600397FAC0023FFFF00397FAD0016AFF80002FB6D
    S31A0010091B020002FC030002FD040002FE05003AFC82000E1CFFC5
    S31A001009300036FD220004ACE40004ABE500041BE30032FDAB0043
    S31A00100945041CE20032FDAB003AFBA4003AFBB2003AFCBC000EEB
    S31A0010095A1CFF0032FDA50000FED40033FD2A001EAB0C000E2B49
    S31A0010096FFC001EAC0D000EECF7000E6BF7000CBCFC000E2C012A
    S31A001009840002FC06001EA50D000E25C0001EAF02001EBF0300D2
    S31A0010099936FD2A000E15BF0002FF07001EAC07000EABFF001E45
    S31A001009AE1B020032FD91001E1C030034FD8E001EAF030002FF74
    S31A001009C307001EAE06000EADFF000EEEDF00037FFF000EEDDF40
    S31A001009D8000CBFED0016AE01000EBDBF0002FD0C0002FE0D00D5
    S31A001009ED0EABE3003A7FEB001EAF0C0002FF00001EAF0D0002E9
    S31A00100A02FF01000EABE3000EACFF000CAF5D003A7F9B001EAF3B
    S31A00100A170C0002FF00001EAF0D0002FF01000EABE3000EACFF76
    S31A00100A2C000CAF5D003A7F9C000E1CFF0036FDA7001EAF04005E
    S31A00100A4102FF00001EAF050002FF01000EABE3000CAF5C001EE4
    S31A00100A56AD07003A7F9B001EAF040002FF00001EAF050002FFC8
    S31A00100A6B01000EABE3000CAF5C001EAD07003A7F9C000E1CFF5C
    S31A00100A800036FDA7001EC507000CAF5C000EABFF001ECC0D00C1
    S31A00100A9502FC0D001EDB0C0002FB0C000CAF54000E44BF001EDF
    S31A00100AAAAF0C0002FF00001EAF0D0002FF01000EABE3000CAF32
    S31A00100ABF5C000CAF4D003A7F9B001EAF0C0002FF00001EAF0DA0
    S31A00100AD40002FF01000EABE3000CAF5C000CAF4D003A7F9C00E5
    S31A00100AE90E1CFF0036FDA7001EAB06003A7F99000E1CFF00365F
    S31A00100AFEFDA7003AFCBC000E1CFF0036FDA7001EAC07000EABAA
    S31A00100B13FF001E1C030002FF03001EAF02000C7FBF0002FF025B
    S31A00100B28001ECC050002FC05001EDB040002FB04001EAF0600DF
    S31A00100B3D0ECFFD0002FF06000EA5FF001EAF02001EBF03003219
    S31A00100B52FD98003AFBAB0004ACE40004ABE500041BE30032FDAA
    S31A00100B672200041CE20032FD22003AFB930016AF0800397FACF5
    S31A00100B7C0023FFFF00397FAD0016AFFC0002FB02000CAFD40079
    S31A00100B910CAFC50002FE03003AFC82000E1CFF0036FD07000299
    S31A00100BA6F5000002F401001EAB03001EAC08001EAD02003A7F14
    S31A00100BBBED0002F5000002F401001EAB03001EAC08001EAD02C9
    S31A00100BD0003A7F9C000E1CFF0032FD070000FED40016AF0400AB
    S31A00100BE5397FAC0023FFFF00397FAB000CAFB5003AFC82000EC7
    S31A00100BFA1CFF0036FCFD000CAF5B003A7FEB00397FAA0023FF48
    S31A00100C0FFF00397FA90016AFFC000EA1BD000EA0910018AF0F18
    S31A00100C240002FF000018AF100002FF010018AF110002FF0200F0
    S31A00100C3918AF120002FF03001EAF00001EBF01001EBF02001E0B
    S31A00100C4EBF030036FCBF000EA1FF000EA01C0018AB00000E2B54
    S31A00100C63DF000E1BFF0036FCD9001EAF03000ECFBC0002FF03E7
    S31A00100C78001EAF02000EDFF80002FF02001EAF01000EDF3F00A0
    S31A00100C8D02FF01001FFF000002FF00001EAF00001EBF01001E52
    S31A00100CA2BF02001EBF030036FCBF003A7FE9001EAF0300037FA1
    S31A00100CB7FF001EAF0300037FFF001EAF0300037FFF001EAF03A1
    S31A00100CCC00037FFF001E1B000032FCC1001E1C010032FCC1002A
    S31A00100CE11E1D020032FCC1001E1E030032FCC10016AF04003392
    S31A00100CF6FCBF0016AF040000FED40016AF0400397FA80023FF32
    S31A00100D0BFF00397FAD0016AFFD000EA5FE000EA03F000EA1BC8E
    S31A00100D200018A400003A7F97000E1CFF0032FCAF003A7F980045
    S31A00100D350EACFE000EABFF0033FC85000E14E00030FC87000EAC
    S31A00100D4AFADF000CAFFB0002FB02000E2A20000EFADF0032FC83
    S31A00100D5FAA000CAF4B003A7FEB000EAFBC0002FF00000EAF7F5F
    S31A00100D740002FF01000CAF4B000EACFF000EADBF003A7F9B00C5
    S31A00100D890EAFBC0002FF00000EAF7F0002FF01000CAF4B000E73
    S31A00100D9EACFF000EADBF003A7F9C000CAFC5001EAB02000CBA9F
    S31A00100DB3BA000E15FF0036FC87003A7F98000EA03F000EA1BCD7
    S31A00100DC80018AF00000E1F000032FC88000E25FE0033FC87006F
    S31A00100DDD0EA5FF000CAF5C000EABFF0016AF0300397FAC00231B
    S31A00100DF2FFFF000EA1BE000EA02C0018AE010018AD00000EAB4C
    S31A00100E07FF00041BD40032FC70000EA1FF000EA01C0018A209F5
    S31A00100E1C0018A308000C03DF0032FC74000C12EF0031FC7100AD
    S31A00100E31041BDE0036FC70000EABFE000CAFBC000EABFF0023EE
    S31A00100E46FFFF00037FFF000CAFFF000B7FFF00037FFF000378C3
    S31A00100E5BFF000379FF000370FF000371FF000372FF000373FF24
    S31A00100E70000374FF000375FF00037EFF00037DFF00037CFF00ED
    S31A00100E85037BFF003EBFFF000378FF000379FF000EA26F000EA7
    S31A00100E9AA37F001AAC00000E2FFB000CAFFB000E1BFF0036FCFD
    S31A00100EAF51000EAF040002DF00001AAB01000C2CBC000E2FF737
    S31A00100EC4000CAFFB000E1BFF0036FC33000EAF080002DF00001A
    S31A00100ED90EA0BF000EA17F0018AE020018AD010001BDDD000129
    S31A00100EEEBEDC0018AB00000E2BFE000E1BFF0032FC3D0001BDF4
    S31A00100F03DB0001BEDA000EA1FF000EA0540018AF02000EBF7F8A
    S31A00100F180002CF02001AAB01000E2B080002DB01000E2A1000AE
    S31A00100F2D33FF7A000E2CEF000CAFCB000E1BFF0036FBFF0000E6
    S31A00100F42FFD90000FFD80000FFD70000FFD6000EA2CF000EA3FA
    S31A00100F577F001AAF020001BFD9001AAF030001BFD8000EA0BFBB
    S31A00100F6C000EA17F0018AB00000E2BFE000E1BFF0032FC1700C5
    S31A00100F811AAB01000E2BEF000E1BFF0036FC17001AAF04000118
    S31A00100F96BF96001AAF050001BF95000EA0CF000EA17F0018AB4A
    S31A00100FAB00000E2B800002CB000004AFD30036FC0D0004AFD34A
    S31A00100FC00002CF000000FFD3000EA1FF000EA0540018AF0200EA
    S31A00100FD50EBF7F0002CF02000EA06F000EA17F0018AB01000EB5
    S31A00100FEA2B100002CB01000EAF100002CF00000E2A100033FFBB
    S31A00100FFF7A000E2A100016A9010016A801002DFFFF0016AB0199
    S31A001010140016AC010016AD010016AE010016A5010016A40100EE
    S31A0010102916A3010016A2010016A1010016A0010016A9010016E4
    S31A0010103EA8010017AF010016AF01003F1FFF0023FFFF00037F51
    S31A00101053FF000CAFFF000B7FFF00037FFF000378FF000379FFBA
    S31A00101068000370FF000371FF000372FF000373FF000374FF0019
    S31A0010107D0375FF00037EFF00037DFF00037CFF00037BFF003E99
    S31A00101092BFFF000378FF000379FF000EA06F000EA17F000EAF78
    S31A001010A7100002CF03000EA3FF000EA230000EA02F000EA17F9F
    S31A001010BC0018AB01001ABF0E0002DF0E000E2A080016A901006F
    S31A001010D116A801002DFFFF0016AB010016AC010016AD010016AB
    S31A001010E6AE010016A5010016A4010016A3010016A2010016A18F
    S31A001010FB010016A0010016A9010016A8010017AF010016AF0106
    S31A00101110003F1FFF0023FFFF00397FA9000EABFF000EAC4E0015
    S31A001011250EADFC003A7FA700397FA80023FFFF00397FA9000E98
    S31A0010113AABFF000EAC4E000EADFC003AFB8300397FA80023FFE7
    S31A0010114FFF00397FA9000EABFF000EAC4E000EADFC003AFB4F1A
    S31A0010116400397FA80023FFFF000EA06F000EA17F0018AB0100D0
    S31A001011790CAFBE000EADFF0004ABFF000E2BEF000E1BFF0036E4
    S31A0010118EFB98000E2E80000CAFEB0033FB96000E2E40000CAF46
    S31A001011A3EB0002CB01000E2A040023FFFF000EA06F000EA17FC0
    S31A001011B80018AB01000CAFBE000EADFF0004ABFF000E2BEF003F
    S31A001011CD0E1BFF0036FB87000EBE7F000CAFEB0033FB85000E65
    S31A001011E2BEBF000CAFEB0002CB010023FFFF00397FAD0016AFA6
    S31A001011F7FF000CAFC4000CAFB5000EFADF000CAFFB0002FB0045
    S31A0010120C000E2A20000EFADF0032FB7C001CAF000036FB56007D
    S31A001012210D1F40000D5F51000DBFDD0036FB5E000CAF42000E36
    S31A00101236C2FC000D5F530018AF000018BF010032FB640004AF2D
    S31A0010124BE30002CF000004AFE20002CF010004A0E20004A1E34F
    S31A001012600018AF020002DF000033FB5E000EC2FC000D5F3300C2
    S31A001012750EC0FC000D5F11000DBFDD0032FB70001EAB00000CEC
    S31A0010128ABABA0004A0E20004A1E30018AF02000E2F030002CFDD
    S31A0010129F02003AFF18000EAFFE0002EF00001EAB00000CBABADC
    S31A001012B40016AF0100397FAC0023FFFF00397FAD0016AFFF009B
    S31A001012C90CAFC8000CAFB9000EFADF000CAFFB0002FB00000E5B
    S31A001012DE2A20000EFADF0032FB48000D1F84000D5F95000CAFD3
    S31A001012F380000CAF910018AF010018BF020036FB1A0018AF0150
    S31A0010130800037FFF0018A0020016A101001CAB02000E2BFC00C9
    S31A0010131D0EBB7F0018BF020002CF02000ECD010036FB1F000C79
    S31A00101332AF82000EC2FC000D5F93000CAF80000EC0FB000D5F24
    S31A00101347910018AF000002EF000018AF010002EF010018AF02AF
    S31A0010135C0002DF00000EC0FC000D5F11000EC2FC000D5F3300D3
    S31A001013710EC4FC000D5F55000DBFDD0032FB2D000EAFFF000201
    S31A00101386EF000002EF01003AFB110033FB16000CAF82000CAFD9
    S31A0010139B93000EAFFF0002DF00001EAB00000CBABA0016AF01E8
    S31A001013B000397FAC0023FFFF0004A0E20004A1E30018AF0200B6
    S31A001013C50EBFDF0002CF02000378FF000379FF000374FF000310
    S31A001013DA75FF0033FF7A0023FFFF0016AFFF000CAFC0000CAFAD
    S31A001013EFB1000EFADF000CAFFB0002FB00000E2A20000EFADF49
    S31A001014040032FB000002CD000002CE01001EAB00000CBABA00A7
    S31A0010141916AF010023FFFF0016AFFF000EFADF000CAFFB00025E
    S31A0010142EFB00000E2A20000EFADF0032FAF3000EA1BE000EA01F
    S31A00101443370018AB00000E2BDF000E1BFF0036FAE5000EA08FF2
    S31A00101458000EA17F0018AB02000EBBFB0033FAE1000EA08F0067
    S31A0010146D0EA17F0018AB02000E2B040002CB02001EAB00000C80
    S31A00101482BABA0016AF010023FFFF0016AFFF000EFADF000CAF7E
    S31A00101497FB0002FB00000E2A20000EFADF0032FAD8000EA1BE82
    S31A001014AC000EA0370018AB00000E2BDF000E1BFF0036FACA0033
    S31A001014C10EA08F000EA17F0018AB02000E2B040033FAC6000E92
    S31A001014D6A08F000EA17F0018AB02000EBBFB0002CB02001EAB6D
    S31A001014EB00000CBABA0016AF010023FFFF000EA1FF000EA01CF7
    S31A001015000018AF01000EBF7F0002CF01000EA02F000EA17F00CF
    S31A0010151518AB00000EBBFB0002CB000023FFFF000EA02F000E4B
    S31A0010152AA17F0018AB00000E2B040002CB00000EA1FF000EA04D
    S31A0010153F1C0018AF01000E2F800002CF010023FFFF00397FA98C
    S31A001015540016AFFA000CAFC0000CAFB1001EA809001EA9080028
    S31A001015690CAFDC000E6CFE000CAFCB000CAFCB000CAFDC000C99
    S31A0010157EAFED000EAEFF0002FB000002FC010002FD020002FEEE
    S31A00101593030002F9040002F805000CAF1B000CAF0C003AFA92C9
    S31A001015A80016AF0600397FA80023FFFF00397FA90016AFFA00AC
    S31A001015BD1EAE0D001EAD0C000E1DFE0032FA8B000E1EFF003414
    S31A001015D2FA88000EAEFF000EADFE001EAF080002FF00001EAF55
    S31A001015E7090002FF01001EAF0A0002FF02001EAF0B0002FF0318
    S31A001015FC0002FD040002FE05003A7FA10016AF0600397FA80037
    S31A0010161123FFFF00397FAD0016AFFE000CAFC2000CAFB3000C6E
    S31A00101626AFE4001A3403000CAFD5001A7502001EAF07001A3F67
    S31A0010163B050002FF01001EAF06001A7F040002FF00001AA00151
    S31A00101650001AA100000CAF18000E68FE000CAF89000CAF5B0013
    S31A001016650CAF4C000CAF5D000CAF4E00397FDC00037EFF00031B
    S31A0010167A7DFF00037CFF00037BFF000370FF000371FF0003786E
    S31A0010168FFF000379FF00397FDA0016AF08001B1801001B5900AF
    S31A001016A4000CAF80000CAF91000CAF18000E68FE000CAF890009
    S31A001016B90370FF000371FF000378FF000379FF00397FD6001688
    S31A001016CEAF04001ACE090002DE09001ADD080002DD08001ADC88
    S31A001016E3070002DC07001ADB060002DB06001AA001001AA1009C
    S31A001016F8000CAF18000E68FE000CAF89001EAC01001EAB0000A8
    S31A0010170D0CAF5D000CAF4E00397FDC00037EFF00037DFF0003FA
    S31A001017227CFF00037BFF000370FF000371FF000378FF000379C9
    S31A00101737FF00397FDA0016AF08001B1801001B5900000CAF8046
    S31A0010174C000CAF91000CAF18000E68FE000CAF89000370FF0029
    S31A001017610371FF000378FF000379FF00397FD60016AF04001A84
    S31A00101776CE0D0002DE0D001ADD0C0002DD0C001ADC0B0002DCB3
    S31A0010178B0B001ADB0A0002DB0A001B1F010002DF01001B5F00AB
    S31A001017A00002DF00001AAF0100037FFF001AAF0000037FFF00A8
    S31A001017B50CAF5D000CAF4E00397FD80016AF02001ACE030002A4
    S31A001017CADE03001ADD020002DD02001AAF0100037FFF001AAF25
    S31A001017DF0000037FFF001EAE03001EAD0200397FD80016AF026B
    S31A001017F4001ACE050002DE05001ADD040002DD040016AF020053
    S31A00101809397FAC0023FFFF00397FAD000CAFC2000CAFB3000CD3
    S31A0010181EAFE4000CAFD5001AAF06001ABF07001ABF08001ABF13
    S31A00101833090032F9EE001AAC05001AAB040033F9BD001AAE0D16
    S31A00101848001AAD0C001AAC0B001AAB0A000EAFFE00397FCD00C2
    S31A0010185D0CAFE0000CAFD1000CAFC8000CAFB9000CAF4C001A21
    S31A001018723C03000CAF5B001A7B02000CAFCD000CAFBC000EAFA3
    S31A00101887FE00397FD2000370FF000371FF000378FF000379FFD4
    S31A0010189C00397FD90016AF04000CAFE0000CAFD1000CAFC8001D
    S31A001018B10CAFB9001AAE09001AAD08001AAC07001AAB06000E52
    S31A001018C6AFFE00397FCD00037EFF00037DFF00037CFF00037BCA
    S31A001018DBFF000CAF9B000CAF8C000CAF1D000CAF0E00397FD518
    S31A001018F00016AF0400397FD1000CAFEC001ACC05000CAFDB0053
    S31A001019051ADB0400397FAC0023FFFF00397FA90016AFFE000C09
    S31A0010191AAFC8000CAFB9000CAFE2000CAFD3000EA1BD000EA072
    S31A0010192F760018AE17000EADFF000EAC17000EABFC00397FDD65
    S31A001019440002FD000002FE01000CAF9B000CAF8C000CAF3D00E3
    S31A001019590CAF2E003A7FBE0016AF0200397FA80023FFFF003982
    S31A0010196E7FA9003AF98900397FA80023FFFF0000FFD3000EA069
    S31A00101983CF000EA17F000EBB7F0002CB000023FFFF00397FA9A5
    S31A00101998000E2A20000EFADF0032F999000EA06F000EA17F00D6
    S31A001019AD18AB01000EBBEF0002CB01003AFF180004AED70004E7
    S31A001019C2ADD80004ACD90004ABD9000E6BFE00397FA80023FF6B
    S31A001019D7FF00397FA9000EBB7F0001BBD3000E2A20000EFADF6F
    S31A001019EC0032F986000EA06F000EA17F0018AB01000EBBEF0058
    S31A00101A0102CB01003AFF180004AED70004ADD80004ACD90004FC
    S31A00101A16ABD9000E6BFE00397FA80023FFFF00397FAD0016AFFF
    S31A00101A2BFD000CAFC4000CAFB50002FD02000E1DFF0032F961ED
    S31A00101A40000EA1BF000EA0E7001805080032F96A001814090089
    S31A00101A5531F9660018A40B0018A50A0033F92D000EAFFB000235
    S31A00101A6AFF00000CAF1B000CAF0C0033F932000EAFEC0002FFAD
    S31A00101A7F00000EAF770002FF01000EAC9F000EABFF000CAF5DDD
    S31A00101A94000CAF4E003A7FBE000CCC44000CDB5500041499009E
    S31A00101AA90CAFFC0004AB9A000C7B5B000EA1BF000EA0FF0018FD
    S31A00101ABEAE17000E4E000018AD16000E5D800004AF99000E4F6D
    S31A00101AD3000002FF010004AF9A000E5F800002FF00003A7FBE34
    S31A00101AE8000EA1BF000EA0FF0018AE170018AD16000CC4CF0061
    S31A00101AFD02FF01000CD5BF0002FF00000CAFDB000CAFEC000CD2
    S31A00101B12AF5D000CAF4E003A7FBE000CAFC4000CAFB5000EAF70
    S31A00101B27FB0002FF00000EABBF000EACF1000CAF5D000CAF4E53
    S31A00101B3C003A7FBC000CAFC4000CAFB5000EA1BE000EA03700C8
    S31A00101B5118AB01000E2BFE001E1B020032F922000EABFE000E21
    S31A00101B66ACAD000CAF5D000CAF4E003A7FA6001EAC02000EABF6
    S31A00101B7BFF000CAFC0000EC0F4000CAFB1000ED1BF0018AC0035
    S31A00101B90000CAFCB000E6BFE000CCC44000CDB55000CAF5B00BF
    S31A00101BA50CAF4C0016AF0300397FAC0023FFFF00397FAD001646
    S31A00101BBAAFD4000CAFC4000CAFB5000E1DFF0036F9050004AF7D
    S31A00101BCFBF000E2F040001BFBF0000FFB5000EAFFF0002EF0308
    S31A00101BE40033F86F001CAF030032F864000EA1FE000EA09C00E9
    S31A00101BF918AF02001C3F050002FF2B0018AF01001C7F04000203
    S31A00101C0EFF2A000EA1BE000EA05C0018A80C000EA9FF0003780E
    S31A00101C23FF000379FF000EAEEF000EADF100397FD80016AF026E
    S31A00101C38001EAC2B001EAB2A00397FDC000CAFDE000CAFCD00E4
    S31A00101C4D0CAFBC000E6BFE000EA3FF000EA21C001AAC0900181B
    S31A00101C62CC0B001AAB080018DB0A00180B000032F8E100181C54
    S31A00101C77010035F86F00180D060032F8DD00181E070031F86F9E
    S31A00101C8C001D1F010002EF01001D5F000002EF00001CA20100D2
    S31A00101CA11CA300000C139F0032F8D3000C128F0035F864001E42
    S31A00101CB6AC2B001EAB2A00180B080032F8CD00181C090034F8AE
    S31A00101CCB6F001D1F020002EF02000E1FFD0032F86D000EAFFED2
    S31A00101CE00002EF030018AF0D000E1F000032F8C00004AFBF0088
    S31A00101CF50EBF7F0001BFBF0018AF0F000E1F000032F8BA00040E
    S31A00101D0AAFBF000EBFBF0001BFBF000EA1BF000EA0BD000EA3AB
    S31A00101D1FFF000EA21C001AAF0800037FFF001AA2090016A301FD
    S31A00101D34001813030032F8AE001812040036F8A5000EAFBF0001
    S31A00101D4902FF00000EAFBA0002FF01000EACFD000EABFF000E78
    S31A00101D5EADFF000EAE14003AFDBB000CAF6C000ECCFD000D5F82
    S31A00101D737B000EADFE003AE59B000EA1FE000EA04D000EAFFFF3
    S31A00101D880002CF040002CF05003AC2A70004AFBF000EBFFB00A8
    S31A00101D9D01BFBF000EA1FF000EA01C0018AB34000E2BBF000E27
    S31A00101DB21BFF0036F88C000CAF6C000ECCFD000D5F7B000EAD92
    S31A00101DC7FC0033F888000CAF6C000ECCFD000D5F7B000EADFEA4
    S31A00101DDC003AE3130004AFBF000EBFFB0001BFBF000EA1BE0086
    S31A00101DF10EA0370018AB01000E2BEF000E1BFF0036F86D000E25
    S31A00101E06A3FE000EA287000EA1FF000EA01C001AAC18001AABBE
    S31A00101E1B1700180B1C0032F87500181C1D0031F86D0018AF1CDD
    S31A00101E300002DF170018AF1D0002DF180033F86D000EAFFF005E
    S31A00101E4502EF02000EAFFF0002EF000002EF01000EA1FE000E25
    S31A00101E5AA09C0018AF010002EF040018AF020002EF050016AFE0
    S31A00101E6F2C00397FAC0023FFFF00397FAD0016AFF7000CAF6C4F
    S31A00101E84000ECCFD000D5F7B000EADFE003AF912000EAFFF00BB
    S31A00101E9902FF080004AF620032F845000EA1BF000EA0BD0018A0
    S31A00101EAEA40A0018A509000CAF5B000CAF4C003AC414003AE745
    S31A00101EC3E0000CAFCB0004AFD20002FF000004AFD10002FF0182
    S31A00101ED8000CAF5C000CAF4D000EAEF7003AC8B6000EA5BF00E3
    S31A00101EED0EA4AE000CAF6C000ECCFD000D5F7B000EADFF003A91
    S31A00101F02F912001FBF080002FF08000E1F000032F837000EAF6F
    S31A00101F17FB0002FF08003AC564001CAC41001CCC43001CAB40FD
    S31A00101F2C001CDB42000EA1FE000EA0D80018AF2400037FFF00B2
    S31A00101F4118A0250016A101000C01BF0032F82A000C10CF0034A1
    S31A00101F56F818001CAC68000EABFF000EA1FF000EA01C0018AF29
    S31A00101F6B2A00037FFF0018A02B0016A101000C11BF0032F81EE1
    S31A00101F80000C10CF0034F818003AEFA9000EA1FF000EA0470092
    S31A00101F950EAFFF0002CF15003AEE850004AFA3000E1FFD00361C
    S31A00101FAAF843000EA3FF000EA21C001AAB34000E2BBF000E1B3B
    S31A00101FBFFF0032F804000EA1BF000EA0AE0018AC1E0018CC6BCF
    S31A00101FD40018AB1D0018DB6A001A0B080032F805001A1C09000A
    S31A00101FE935F8010004AFBF000EBFFD0001BFBF0016AF090039DD
    S31A00101FFE7FAC0023FFFF00397FAD0016AFAA0004AFB50032F707
    S31A00102013F0000CAF6C000ECCD1000D5F7B000EADFE003AE59B86
    S31A00102028000CAF6C000ECCD1000D5F7B000EADFB003AE31300EE
    S31A0010203D3AF51A000CAF6C000ECCFD000D5F7B000EADFE003A57
    S31A00102052F6B1000CAF6C000ECCE1000D5F7B003AF05F0004AFB7
    S31A00102067620032F7D3000EA1BF000EA0BD0018A40A0018A5098B
    S31A0010207C000CAF5B000CAF4C003AC414003AE7E0000CAFCB0083
    S31A0010209104AFD20002FF000004AFD10002FF01000CAF5C000CF5
    S31A001020A6AF4D000EAEF7003AC8B6000CAF6C000ECCFD000D5F3E
    S31A001020BB7B000EADFF003AF6B1000E1CFF0036F7C5000CAF6CA2
    S31A001020D0000ECCFD000D5F7B000CAF6E000ECEE1000D5F7D0058
    S31A001020E53AF2F7000CAF6C000ECCE1000D5F7B000EADFF003AF0
    S31A001020FAF4C7003AF4AB0000FE60000EA5FF003AEFE1000C1CE5
    S31A0010210F5F0036F7B3003AF5C50000FE61000EA1FF000EA04770
    S31A00102124001815150032F7B3000EA5FE000EA3FF000EA247001A
    S31A001021391AAF160036F7AC000EA5FE000EAFFF0002DF16000E51
    S31A0010214E15FF0036F7890004AF620032F788000EA1FF000EA07A
    S31A00102163470018AC110018AB10003AC414000EA3FF000EA247A9
    S31A00102178001AAF150032F799000EA1BF000EA0AE0018AB00000F
    S31A0010218D1AAE11001AAD100033F792000EA3BF000EA2AE001AD3
    S31A001021A2AB69000EA1FF000EA0470018AE110018AD100004AFFC
    S31A001021B7D20002FF000004AFD10002FF01000CAFDC000CAFED65
    S31A001021CC000EAEFF003AC8B60033F788003AC39F003AEE85007A
    S31A001021E13AF502000EA3BF000EA2AE001AAC2E000EABFF001A0E
    S31A001021F6CC41001ADB40000EA1FF000EA01C0018AF0800037FB3
    S31A0010220BFF0018A0090016A101000C01BF0032F777000C10CFD9
    S31A001022200030F76F000EA3FF000EA21C000CAF31000CAF2000BA
    S31A0010223518AF34000EBFEF0002DF340004AFA3000E1F010036F8
    S31A0010224AF7D3003AF45A003AF756000EA1FF000EA0470018AF26
    S31A0010225F140032F760000EA1BF000EA0BD0018AB02000E2BFCE4
    S31A00102274000E1BFD0036F75B000CAF6C000ECCE1000D5F7B00C8
    S31A001022890EADFE003AF4C7000EABFA003AC5D90016AF5600399D
    S31A0010229E7FAC0023FFFF00397FAD0016AFF9000EA1FF000EA04A
    S31A001022B31C0018AB01000E2BFE000E1BFF0036F6B4000EA3BF71
    S31A001022C8000EA2BD001AAB02000E2BFC000E1BFD0032F6B40080
    S31A001022DD0EA1BE000EA0370018AB03000E2B7F000E1BFF0036A8
    S31A001022F2F6B4000EA1FE000EA0870018AF100032F6B40018ACBE
    S31A00102307090018AB08003AE1900002FB050002FC06000EA3BFB6
    S31A0010231C000EA2AE001AA43D000EA5FF000EA1FE000EA08700A9
    S31A0010233118AC070018AB06003A7FC0000CAFCE000CAFBD000C67
    S31A00102346AF5B000CAF4C003A7FB6001EA206001EA305000C1341
    S31A0010235BBF0032F726000C12CF0031F6B4000EAFFC0002FF00C7
    S31A00102370000CAF6C000ECCFD000D5F7B000EADBF000EAEBD006A
    S31A001023853A7FE0000EA1FE000EA0870018AE0B0018AD0A000E04
    S31A0010239AABFE000EAC4F003AC2F8000CAFC4000CAFB5000EA3D2
    S31A001023AFBF000EA2AE001AAC28000EABFF000EAEFF000EADBF0B
    S31A001023C4003A7FB9000C15BF0032F70A000C14CF0030F7030050
    S31A001023D90EA1FF000EA01C0018AB34000E2BEF000E1BFF0036E4
    S31A001023EEF6DE000EA3BF000EA2AE001AAC2D000EABFF000EA1C8
    S31A00102403FE000EA0870018AF1100037FFF0018A0120016A101A0
    S31A00102418000C11BF0032F6F6000C10CF0035F6DE000EA1BD003F
    S31A0010242D0EA076001AAC3F000EABFF0018AE0D0018AD0C0039C6
    S31A001024427FDC000CAFDE000CAFCD000CAFBC000E6BFE000EA354
    S31A00102457FE000EA287001A0D060032F6E5001A1E070030F6DEA8
    S31A0010246C000EABFE000EAC7B003A7FA0003AE12C0002FB0200BA
    S31A0010248102FC03000EA5BF000EA4BD001EAC03001EAB02001C9A
    S31A001024961B000032F6D6001C1C010036F6B4000CBCBF0036F636
    S31A001024ABB8000CAF6C000ECCFD000D5F7B003AE0A7000EA1FEFB
    S31A001024C0000EA087000EAFFE0002CF100004AF620032F6B4002F
    S31A001024D51CAF0900037FFF001CA40A0016A501000CAF5B000CDF
    S31A001024EAAF4C003AC414003AE7E0000CAFCB0004AFD20002FFAD
    S31A001024FF000004AFD10002FF01000CAF5C000CAF4D000EAEFF52
    S31A00102514003AC8B60033F6B4000EABFE000EAC7D000EADF60068
    S31A001025293A7FB20016AF0700397FAC0023FFFF00397FAD001650
    S31A0010253EAFF8000CAFC4000CAFB5000EAFFF0002FF00000E1DF4
    S31A00102553FF0036F69A000EADE3003A7FB2000EABFE000EACA975
    S31A00102568003A7FA50002EB180002EC19000EA1BF000EA0AE0014
    S31A0010257D18AE030018AD02000CAF5B000CAF4C003AF48B00339A
    S31A00102592F5CA000CAF5B000CAF4C003AF4350002FC03000EAB25
    S31A001025A7FE000EACA9003A7FA5000CAFCE000CAFBD000CAFDCB2
    S31A001025BC000E6CFE000CAFCB001CCE100002EE10001CDD0F00F4
    S31A001025D102ED0F001CDC0E0002EC0E001CDB0D0002EB0D001DC4
    S31A001025E61F110002EF11001CAC11000EABFF000CAFCE000CAFC3
    S31A001025FBBD000CAFDC000E6CFE000CAFCB00037EFF00037DFF64
    S31A0010261000037CFF00037BFF001CAE10001CAD0F001CAC0E001C
    S31A001026251CAB0D00397FD60016AF04000CAFE8000CAFD9000C1C
    S31A0010263AAFCE000CAFBD0002F9010002F802001CAF1A001CBFC8
    S31A0010264F1B0036F666001DBF1B0002EF1B001DFF1A0002EF1A6F
    S31A00102664000CAF4C000ECCF2000D5F5B000CAF9D000CAF8E0010
    S31A001026793AF482000E1CFF0032F62F000EA3BF000EA2AE001C1C
    S31A0010268EAF11001A1F070035F600000EA1BE000EA01F00199C07
    S31A001026A3010019CB00001CAE19001CAD18000C0DBF0032F65013
    S31A001026B8000C1ECF0030F64C001AAE05001AAD040033F64A0081
    S31A001026CD1AAE03001AAD02000CAF5B000CAF4C003AF48B001E5A
    S31A001026E2AF010002EF18001EAF020002EF19001CAF0D0002EF72
    S31A001026F712001CAF0E0002EF13001CAF0F0002EF14001CAF100F
    S31A0010270C0002EF15001CAF110002EF17000EAFFF0002EF1600F5
    S31A001027210EAFFF0002EF11000EAFFF0002EF0D0002EF0E000214
    S31A00102736EF0F0002EF100033F5CA001CA017001CA116000E11C2
    S31A0010274B000032F62A000E10FF0030F607001CAF15001CCF10EC
    S31A001027600002EF15001CAF14001CDF0F0002EF14001CAF13007C
    S31A001027751CDF0E0002EF13001CAF12001CDF0D0002EF12001C28
    S31A0010278AAC11000EABFF000CC0CF0002EF17000CD1BF0002EF7F
    S31A0010279F16001CAE17001CAD16000EACFF000EABFF00037EFF48
    S31A001027B400037DFF00037CFF00037BFF001CAE15001CAD1400C4
    S31A001027C91CAC13001CAB1200397FD60016AF040002ED180002D1
    S31A001027DEEE19000EAFFF0002EF11000EAFFF0002EF0D0002EF60
    S31A001027F30E0002EF0F0002EF10001CAF1A001CBF1B0032F5CAE0
    S31A00102808001EAF030036F5CA000CAF40000EC0F2000D5F510068
    S31A0010281D0EA3BF000EA2AE001AAC08000EABFF000CAFCE000CA7
    S31A00102832AFBD000CAFDC000E6CFE000CAFCB00037EFF00037D7A
    S31A00102847FF00037CFF00037BFF001CAE08001CAD07001CAC06FC
    S31A0010285C001CAB0500397FD60016AF010002FF070016AF010063
    S31A0010287102FF070016AF010002FF070016AF010002FF07000C8C
    S31A00102886AFE8000CAFD9000CAFCE000CAFBD000CAF1B000CAF6A
    S31A0010289B0C000CAF9D000CAF8E003AF482000E1CFF0036F5CA97
    S31A001028B0000EA1BF000EA0AE0018AE050018AD04000CAF5B0089
    S31A001028C50CAF4C003AF48B000EAFFE0002FF00001EAC00000E94
    S31A001028DAABFF0016AF0800397FAC0023FFFF000374FF000375E9
    S31A001028EFFF000EA1FF000EA0470018AC0F0018AB0E000EFB7FF0
    S31A001029040036F5BB000EACFF000EABFF00191F120002CF120024
    S31A0010291936F5AA00183C1100187B100018AE12000EADFF000321
    S31A0010292E7EFF00037DFF000CAFCE000CAFBD00397FD80016AF2C
    S31A00102943020018CE110002CE110018DD100002CD10000EA5BF39
    S31A00102958000EA4BD000EA3BF000EA2AE001CAC0A001ACC6300FC
    S31A0010296D1CAB09001ADB620018AE110018AD10000C0DBF003262
    S31A00102982F59D000C1ECF0030F592001CAC0A001A3C63001CAB96
    S31A0010299709001A7B620018AE110018AD10000C0DBF0032F593D7
    S31A001029AC000C1ECF0031F5900002CB100002CC11000EA1BF0027
    S31A001029C10EA0AE0018AF540018BF550036F57F000EA3FF000EE0
    S31A001029D6A247001AAC11001AAB1000180B540032F58400181CEB
    S31A001029EB550034F57F0018AF540002DF100018AF550002DF11AA
    S31A00102A00000EA1BF000EA0AE0018AF56000EFF7F0032F56E00A3
    S31A00102A150EA3FF000EA247001AAE11001AAD1000180D56003292
    S31A00102A2AF57300181E570031F56E0018AF560002DF100018AF23
    S31A00102A3F570002DF11000EACFF000EABFF000CCCCC000CDBBB6C
    S31A00102A54000CAFC0000EC047000CAFB1000ED1FF000EAFFE00C2
    S31A00102A6902CF0F000EAF7F0002CF0E0016A5010016A4010023AD
    S31A00102A7EFFFF00397FAD000CAFC4000CAFB5000EA3FF000EA27B
    S31A00102A9347001AAF08001ABF09001ABF0A001ABF0B0036F52FFD
    S31A00102AA8000E1DFF0032F5500004AFA3000E1F010032F52F0088
    S31A00102ABD1AAF0B00037FFF001AAF0A00037FFF001AAF09000370
    S31A00102AD27FFF001AAF0800037FFF001AAE07001AAD06001AACA7
    S31A00102AE705001AAB0400397FD60016AF040002ED020002EE03BB
    S31A00102AFC001AAF0B00037FFF001AAF0A00037FFF001AAF090034
    S31A00102B11037FFF001AAF0800037FFF001AAE03001AAD02001A18
    S31A00102B26AC01001AAB0000397FD60016AF040002ED000002EEDC
    S31A00102B3B010033F525000EA1BF000EA0BD0018AF050002EF008B
    S31A00102B500018AF060002EF010018AF070002EF020018AF08000B
    S31A00102B6502EF0300397FAC0023FFFF000EA1FE000EA057001901
    S31A00102B7A8C02000D9FFB000CBBCB000EEBFD000CAFBC000EAB43
    S31A00102B8FFF0023FFFF00397FA90004AFBF000E2F040001BFBF68
    S31A00102BA40000FFB5000EA1FF000EA01C0018AF34000E2F100092
    S31A00102BB902CF34000EABFF000EAC47000EADE8003A7FB2000E17
    S31A00102BCEA3FF000EA247000EA1BF000EA0BD0018AF090002DFB9
    S31A00102BE3100018AF0A0002DF1100397FA80023FFFF000374FFFD
    S31A00102BF8000375FF000EA3FF000EA247000EA5FF000EA41C0014
    S31A00102C0D1D9C15001DCB14000EA1BE000EA01F00180B0400323F
    S31A00102C22F4F500181C050035F4CD001CAE15001CAD14000CAFF8
    S31A00102C37DC000E6CFE000CAFCB001ACE030002DE03001ADD02D1
    S31A00102C4C0002DD02001ADC010002DC01001ADB000002DB0000D4
    S31A00102C611CAE41001CAD40000CAFDC000E6CFE000CAFCB001A85
    S31A00102C76CE070002DE07001ADD060002DD06001ADC050002DCBC
    S31A00102C8B05001ADB040002DB04001B1F0B0002DF0B001B5F0A8A
    S31A00102CA00002DF0A001B5F090002DF09001B5F080002DF080046
    S31A00102CB51B1F0D0002DF0D001B5F0C0002DF0C0033F4CA000E4D
    S31A00102CCAAFFF0002DF0C0002DF0D0016A5010016A4010023FFBD
    S31A00102CDFFF00397FAD0016AFFC0002FD03000EAFFF0002FF01E5
    S31A00102CF40002FF02000EA5FF000EA447001CAF13000E2F0800E4
    S31A00102D0902EF13000D1F6E000D5F7D001EAF030002FF00003A0D
    S31A00102D1EF01B000E1CFF0036F4AE001EAC02001EAB01001EAD1D
    S31A00102D3303003AF3E5001CAF13000EBFF70002EF130016AF04F1
    S31A00102D4800397FAC0023FFFF00397FAD000EA1BF000EA0AE00AC
    S31A00102D5D0EA3FF000EA247001AAF0C00037FFF001AA20D00166F
    S31A00102D72A301001813020032F49F001812030035F48D000EA10E
    S31A00102D87FE000EA0D80018A4250018A524000EABFE000EACABBF
    S31A00102D9C003A7FA5000C4C4C000C5B5B000EA1FF000EA04700A5
    S31A00102DB1180B0E0032F49000181C0F0034F48D0002CB0E00023B
    S31A00102DC6CC0F00397FAC0023FFFF000CAFC0000CAFB100181D66
    S31A00102DDB1A0032F48600181E1B0034F4830002CD1A0002CE1B37
    S31A00102DF00023FFFF00397FAD0016AFFC000CAFC4000CAFB50082
    S31A00102E051C1E0C000CAFFC001CAB0B000C7BDB003A7FC00002F6
    S31A00102E1AFB000002FC01000EA1BF000EA0AE0018AF060002FFFB
    S31A00102E2F03000EAFFF0002FF02001CAC0C001CAB0B003A7FC097
    S31A00102E44000CAFCE000CAFBD001EAC03001EAB02003A7FB6005B
    S31A00102E590EAEFF000EADFF001EA001001EA100000C11BF00324D
    S31A00102E6EF462000C10CF0030F45F000EAEFE000EADFF000CAF46
    S31A00102E83DB000CAFEC0016AF0400397FAC0023FFFF00397FA9F3
    S31A00102E980016AFF4003AF523000E1CFF0036F438000CAF6C0052
    S31A00102EAD0ECCFD000D5F7B000EADFE003AF55F000EA1FF000E39
    S31A00102EC2A0470018AF100002FF060018AF110002FF070004AF8D
    S31A00102ED7CE0002FF080004AFCD0002FF090004AFCC0002FF0AE5
    S31A00102EEC0004AFCB0002FF0B000EAFBF0002FF00000EAFB8003F
    S31A00102F0102FF01000EACF5000EABFF000CAF6E000ECEFD000D2D
    S31A00102F165F7D003AFDBB0016AF0C00397FA80023FFFF00397FB8
    S31A00102F2BAD000CAFC4000CAFB5000EA1BF000EA0AE001CAF004A
    S31A00102F4000181F080032F42B000EADF2003A7FB2001D1F000082
    S31A00102F5502EF00000EABFE000EACAB003A7FA5000CAFCE000C51
    S31A00102F6AAFBD000CAFDC000E6CFE000CAFCB001CCE040002EE5D
    S31A00102F7F04001CDD030002ED03001CDC020002EC02001CDB0153
    S31A00102F940002EB01000EA1BE000EA0370018AB03000E2BFB00D8
    S31A00102FA90E1BFF0036F410000EABFE000EACA40033F40E000E43
    S31A00102FBEABFE000EACA9003A7FA5000CAFCE000CAFBD000CAFC2
    S31A00102FD3DC000E6CFE000CAFCB001CCE080002EE08001CDD070F
    S31A00102FE80002ED07001CDC060002EC06001CDB050002EB0500E8
    S31A00102FFD0EABFE000EACA7003A7FA5000CAFCE000CAFBD000C26
    S31A00103012AFDC000E6CFE000CAFCB001CCE0C0002EE0C001CDD1F
    S31A001030270B0002ED0B001CDC0A0002EC0A001CDB090002EB0989
    S31A0010303C000EACFF000EABFF000EA1BF000EA0AE001CAF000063
    S31A00103051181F080032F3E7000EACFE000EABFF00397FAC002312
    S31A00103066FFFF00397FAD0016AFD40002FB230002FC240002FD02
    S31A0010307B25003AC2B4000CAFC0000CAFB10018AF00000E1FFA80
    S31A001030900032F3D6000CAF0E000ECEBF000D5F1D0033F3D30034
    S31A001030A53AC2C1000CAFCE000CAFBD000EABDF000CAF62000E7F
    S31A001030BAC2FC000D5F73000CAFE0000CAFD10010AF0100035F05
    S31A001030CF01000DBFBB0032F3CD000EA1FE000EA0570018AC00E6
    S31A001030E4000EABFF000CCCCC000CDBBB000CCCE0000CDBD10053
    S31A001030F918AF020002FF260018AF030002FF27000EA1FF000E0E
    S31A0010310EA01C0018AB01000E2BFB000E1BFF0032F2FA000EA1ED
    S31A00103123BF000EA0BD0018AB02000E2BFC000E1BFD0032F354BE
    S31A00103138000EA5BF000EA4AE001CA215001CA314000CAF200019
    S31A0010314D0CAF31000EA8FF000EA9FF001EAE27001EAD26000C10
    S31A00103162AFDC000E6CFE000CAFCB00037EFF00037DFF00037C3B
    S31A00103177FF00037BFF000370FF000371FF000378FF000379FFD7
    S31A0010318C00397FDA0016AF08000CAFE0000CAFD1000CAFC8000F
    S31A001031A10CAFB9000E4217000E53FC0002F22B0002F32A000E7F
    S31A001031B6AFFF0002FF280002FF29001EAE24001EAD23000CAF54
    S31A001031CBDC000E6CFE000CAFCB00037EFF00037DFF00037CFF82
    S31A001031E000037BFF001EAF2F00037FFF001EAF2F00037FFF004D
    S31A001031F51EAF2F00037FFF001EAF2F00037FFF00397FDA00160D
    S31A0010320AAF08000CCE00000CDD11000CDC88000CDB99000EAF61
    S31A0010321F1700037FFF000EAFFC00037FFF000EAFFF00037FFF75
    S31A00103234000EAFFF00037FFF000CAF9B000CAF8C000CAF1D00BD
    S31A001032490CAF0E00397FD60016AF04000CAFDB000CAFEC001EDF
    S31A0010325EAE27001CCE5B001EAD26001CDD5A000C0BDF0032F3CC
    S31A0010327361000C1CEF0030F358001EAE27001C3E5B001EAD26A4
    S31A00103288001C7D5A000C0BDF0032F359000C1CEF0031F3560023
    S31A0010329D0CAFDB000CAFEC0002FB230002FC24000CAF6C000E52
    S31A001032B2CCFA000D5F7B000CAF6E000ECEDC000D5F7D001EAFAD
    S31A001032C7260002FF00001EAF270002FF01000EA3FE000EA25709
    S31A001032DC001AAF000002FF02003AC618000E1CFF0036F307008A
    S31A001032F10EA1FE000EA0570018AF02000E1F000032F32E000CAB
    S31A00103306AF02000CAF13001AAF000002CF01000CAF6C000ECC81
    S31A0010331BFA000D5F7B001EAE24001EAD23001EAF260002FF00D4
    S31A00103330001EAF270002FF01001AAF000002FF02003AC64C0064
    S31A001033450EA1FE000EA0570018AF00000E1FF10032F322001E61
    S31A0010335AAF250032F322000EA1FF000EA01C0018AF01000EBF20
    S31A0010336FFB0002CF01001EAF23000EFF7F0032F302001EAF23D3
    S31A00103384001EBF240036F302000CAF6C000ECCFC000D5F7B000E
    S31A001033993AC5BB0004AFC90036F3020004ACCF0004ABD0001E8C
    S31A001033AEAF230002FF00001EAF240002FF01001EAE27001EAD70
    S31A001033C326003A7FBE0001BBD00001BCCF003AEF6A0001BBD209
    S31A001033D80001BCD10033F302000EA1FF000EA01C0018AF0100D4
    S31A001033ED0EBFFB0002CF01000EA3FE000EA257000CAF31000C6D
    S31A00103402AF200018AF000002DF02001B1F000002CF000016AF56
    S31A001034172C00397FAC0023FFFF00397FAD0016AFD00002FB06DC
    S31A0010342C0002FC070002FD080002FE09000EA1FE000EA05700AE
    S31A0010344119BF000002FF0A000EA3BF000EA2AE001AAC08000ED3
    S31A00103456ABFF000CAFC0000CAFB1000CAF18000E68FE000CAFB8
    S31A0010346B89001EA207001EA306000370FF000371FF000378FFC0
    S31A00103480000379FF001AAE08001AAD07001AAC06001AAB050072
    S31A00103495397FD60016AF010002FF1A0016AF010002FF1A0016A6
    S31A001034AAAF010002FF1A0016AF010002FF1A0002FB130002FC3D
    S31A001034BF140002FD150002FE16001EAF150002FF0D001EAF16D1
    S31A001034D40002FF0E000370FF000371FF000378FF000379FF00E4
    S31A001034E91AAE0C001AAD0B001AAC0A001AAB0900397FD60016D0
    S31A001034FEAF010002FF220016AF010002FF220016AF010002FF20
    S31A00103513220016AF010002FF220002FB1B0002FC1C0002FD1D34
    S31A001035280002FE1E001EAF1D0002FF0F001EAF1E0002FF100064
    S31A0010353D0370FF000371FF000378FF000379FF001AAE04001AA3
    S31A00103552AD03001AAC02001AAB0100397FD60016AF040002FBBC
    S31A00103567230002FC240002FD250002FE26001EAF250002FF0BAC
    S31A0010357C001EAF260002FF0C001EAC16001EAB15003A7FC000ED
    S31A001035910CAFC8000CAFB9000EA1BD000EA076000EA3BF000E0A
    S31A001035A6A2AE001AAF2C00037FFF001AAF2B00037FFF0018AEF9
    S31A001035BB0D0018AD0C00397FD70016AF02000C19DF0032F28AFF
    S31A001035D0000C18EF0030F1D1001AAE03001AAD02000EACFF007E
    S31A001035E50EABFF000EA1FE000EA0870018AF2200037FFF00189F
    S31A001035FAAF2100037FFF0018AF2000037FFF0018AF1F00037F85
    S31A0010360FFF001E1B000032F274001E1C010032F274001E1D02B0
    S31A001036240032F274001E1E030016AF040030F1D1001EAF150007
    S31A0010363902FF00001EAF160002FF01001EAC26001EAB25001E84
    S31A0010364EAE1E001EAD1D003AC4F20002FB020002FC03000EA3FC
    S31A00103663FF000EA21C001AAB01000E2BFC000E1BFC0032F1D15D
    S31A00103678000EA1FE000EA0870018AE070018AD06000EABFE00F6
    S31A0010368D0EAC4F003AC2F8000CAFC4000CAFB5000EA3BF000EA8
    S31A001036A2A2AE001AAC27000EABFF000EAEFF000EADBF003A7F1A
    S31A001036B7B9000C15BF0032F24E000C14CF0030F243000EA1BF1B
    S31A001036CC000EA0AE0018AF290018BF2A0036F1D1001EAC26009E
    S31A001036E11EAB25003AEF8C000E1CFF0036F1D1000CAF6C000EC5
    S31A001036F6CCFD000D5F7B000EA3BF000EA2AE001AAD3B003AE00F
    S31A0010370BC8000E1CFF0036F1D1000EA1BF000EA0AE0018AC3BE1
    S31A00103720000EABFF000EA3BD000EA276001AAE0D001AAD0C008A
    S31A001037353A7FB9000EA1FE000EA0870018AF0600037FFF0018AF
    S31A0010374AA0070016A101000C01BF0032F228000C10CF0035F1CC
    S31A0010375FD1000EA3FF000EA21C001AAF14000EFF7F0036F1D191
    S31A00103774001EAC1E001EAB1D003AEF7C000E1CFF0036F1D10096
    S31A001037890EA1FE000EA0870018AC070018AB06003A7FC0000C1A
    S31A0010379EAFC4000CAFB5000EA3FE000EA257001EAC03001A3C44
    S31A001037B309001EAB02001A7B08003A7FC0000CAFC8000CAFB90A
    S31A001037C8000CAF4E000CAF5D000CAFDC000E6CFE000CAFCB0020
    S31A001037DD0EECBF000CAFFB000EEDBF000CAFFC000CBBDB000E31
    S31A001037F2EEBF000CAFFD000CBCEC000EAEFF000CAF80000CAFE2
    S31A0010380791000CAF18000E68FE000CAF89000370FF000371FF95
    S31A0010381C000378FF000379FF00397FD60016AF04000CAFE80092
    S31A001038310CAFD9000CAFCE000CAFBD000EA1FE000EA087000CE9
    S31A00103846AF02000CAF13001B1F120002CF12001B5F110002CF4D
    S31A0010385B11001AAF0D001ABF0E0032F1E20002D90D0002D80E9F
    S31A001038700033F1D7000EA1BF000EA0AE0018AF260002FF010079
    S31A001038850EAFFF0002FF00000EABFE000EAC7B000CAF9D000C0B
    S31A0010389AAF8E003AFAAB000EA1FE000EA0870018AF060002CF67
    S31A001038AF0A0018AF070002CF0B001EA207001EA306001AA008EA
    S31A001038C4001AA107001AA806001AA905000D0F9B000D4F8C00E8
    S31A001038D90D4F1D000D4F0E000E6BFB000CAFBE000E6BFD000C72
    S31A001038EEAFBC000CAFBD000EEBFD000CAFBE000EADFF000EACE9
    S31A00103903FF000EABFF000CCE00000CDD11000CDC88000CDB991E
    S31A00103918000D0F9B000D4F8C000D4F1D000D4F0E000EA0EF0065
    S31A0010392D0EA1F1000EA8FF000EA9FF000370FF000371FF00037C
    S31A0010394278FF000379FF00397FD60016AF04000EA1FE000EA0B6
    S31A00103957870018CE010018DD00000EABFE000EAC51003AC2F82C
    S31A0010396C001EA209001EA3080002DB0E0002DC0F001EAC0E00EE
    S31A001039811EAB0D001EAE0C001EAD0B003AEF5A000E1CFF0036B5
    S31A00103996F062001EA009001EA1080018AC0F0018AB0E001EAEB6
    S31A001039AB10001EAD0F003AC4D0001E4C0C001E5B0B001EAE0E65
    S31A001039C0001EAD0D003AC41E0002FB110002FC12000EA3BF005A
    S31A001039D50EA2AE000CAFCF001A3F5D0002FF12000CAFBF001A82
    S31A001039EA7F5C0002FF11000EA1BE000EA0370018AB02000E2B75
    S31A001039FFFE000E1BFF0036F0DB001AAE03001AAD02000EACFF29
    S31A00103A14000EABFF000EA3FE000EA287001AAF2200037FFF007D
    S31A00103A291AAF2100037FFF001AAF2000037FFF001AAF1F0003B2
    S31A00103A3E7FFF001E1B000032F168001E1C010032F168001E1D1A
    S31A00103A53020032F168001E1E030016AF040030F0DB001EA009F1
    S31A00103A68001EA1080018AC0F0018AB0E000EAFFF0002FF00000B
    S31A00103A7D1EAE10001EAD0F003AC49E0002FB000002FC01001EB2
    S31A00103A92AC12001EAB11000EAE17000EADFC003A7FBE000CAFB5
    S31A00103AA7C4000CAFB5000EF57F0032F1500004AFCA0036F10522
    S31A00103ABC001EAF0D0002FF00001EAF0E0002FF01001EAC0C0051
    S31A00103AD11EAB0B001EAE10001EAD0F003AC4F2000CBCBF003693
    S31A00103AE6F105000EA1FE000EA05700183C0700187B06000EA16A
    S31A00103AFBBF000EA0BD0018AE010018AD0000397FDC000ECDDF9C
    S31A00103B10000D5FCC000D5FBB000EEDFB000EECFB000CBFDE0097
    S31A00103B250E6BFB000CBFCD000CAFBC000E6BFD0002FB27000256
    S31A00103B3AFC280002FD290002FE2A000EA3FE000EA287001EAF37
    S31A00103B4F290002DF00001EAF2A0002DF01000EA1BD000EA076D8
    S31A00103B640018A8010018A9000018AE17000EADFF000EAC17004C
    S31A00103B790EABFC00397FDD0002FD000002FE01001EAC2A001EC5
    S31A00103B8EAB29000CAF9D000CAF8E003A7FBE000EA1FE000EA0C5
    S31A00103BA3870002CB020002CC03000EA1FF000EA01C0018AF0190
    S31A00103BB8000EBFFB0002CF01003AEFA90000FECA000EF57F002C
    S31A00103BCD36F105000EA1FF000EA047000EAFFE0002CF16000E4E
    S31A00103BE2A417000EA5FC000EA3BF000EA2AE001AAC41001ACC93
    S31A00103BF743001AAB40001ADB42001EAE0C001EAD0B000C0DBF9E
    S31A00103C0C0032F0FA000C1ECF0035F0EF000EA1FF000EA01C00EC
    S31A00103C211AAC68000EABFF0018AE2B0018AD2A000C1DBF003298
    S31A00103C36F0F0000C1ECF0030F0DB001EA00C001EA10B001A01E0
    S31A00103C4B400032F0EA001A10410035F0DB000EA1FF000EA047F4
    S31A00103C60000EAFFE0002CF15000EAFFE0002CF160000FEC9002F
    S31A00103C750CAF5B000CAF4C003AEF6A0001BBD20001BCD1000157
    S31A00103C8AB5D00001B4CF001EAB0A003AC37B001EA209001EA331
    S31A00103C9F08001A1C0F0002FF2C001A5B0E0002FB2B000EA1BF67
    S31A00103CB4000EA0AE0018AF0F0002FF2E000EAFFF0002FF2D009A
    S31A00103CC91F1B0A003AC37B000CAFC4000CAFB5001EAB0A003A18
    S31A00103CDEC37B000C4C4E000C5B5D001EAC2E001EAB2D003A7F6C
    S31A00103CF3B9001EAE2C001EAD2B000C0DBF0032F0BD000C1ECF4F
    S31A00103D080035F062000EA1FE000EA0870018AF26000E1F00000D
    S31A00103D1D32F0B50018AF270002CF26001EA009001EA108001819
    S31A00103D32AF0E0002FF040018AF0F0002FF05000CAF6C000ECCC7
    S31A00103D47FB000D5F7B003AC22F0002FC2F000EA5FF000EA41C97
    S31A00103D5C001CAC07001CAB06003AC2B1001EAE2F000EADFF003E
    S31A00103D710CCEEE000CDDDD000CCECC000CDDBB001EAE05001E60
    S31A00103D86AD04003AC245001CA807001CA906000D9FCE000DCF34
    S31A00103D9BBD000CAF9B000CAF8C003AC431000CAFE0000CAFD14D
    S31A00103DB0000CAFC8000CAFB9001EAD12001EAC11000EAFFE007E
    S31A00103DC5397FD2000370FF000371FF000378FF000379FF003936
    S31A00103DDA7FD90016AF0400397FCF000CAFE0000CAFD1000CAF34
    S31A00103DEFC8000CAFB9000E09FF0032F07B000E18FF0032F07BF8
    S31A00103E04000E11800032F07B000E10000034F075000EAF800063
    S31A00103E1902FF11000EAF000002FF120033F06D000EF97F003650
    S31A00103E2EF06F001CAF01000EBFFB0002EF010033F0620002F10C
    S31A00103E43110002F012001EA209001EA308001AAE0F001AAD0E01
    S31A00103E58001EAF110002FF00001EAF120002FF01000CAF3B0089
    S31A00103E6D0CAF2C003AFA7A0016AF3000397FAC0023FFFF0039E2
    S31A00103E827FA9000EADF1003A7FB2000EABFE000EAC57003AF0E4
    S31A00103E9752000EA1FE000EA087000EAF000002CF260002CC2723
    S31A00103EAC00397FA80023FFFF00397FAD000CAFC4000CAFB50016
    S31A00103EC13AC161003AC3380002EC01000D1FCF0002EF00000E5C
    S31A00103ED6AF000002EF02001CAC00000EABFF00397FAC0023FF19
    S31A00103EEBFF00397FAD0016AFDE003AC2B4000CAFC4000CAFB506
    S31A00103F00001CAB00001CAF01000E1FAA0032F01E000E1BFF00C4
    S31A00103F1536F01E000E1B000036F01E000E1BFA0036F01E000E5B
    S31A00103F2AABDF000CAF62000EC2FD000D5F73000CAF40000EC050
    S31A00103F3FBF000D5F510010AF0100035F01000DBFBB0032F02EE1
    S31A00103F54000EAF000002FF02000EAFAA0002FF030002F5000020
    S31A00103F6902F401000EACDF000EABFF000CAF6E000ECEFD000DD6
    S31A00103F7E5F7D003AFDBB0016AF2200397FAC0023FFFF00397F26
    S31A00103F93AD0016AFFB0002FB000002FC010002FD020002FE0396
    S31A00103FA8001EAB09000EAFFF0002FF04000EA5FE000EA45700A1
    S31A00103FBD0E1BFF0032F00A001CAB00003AEFA3000E1CFF003693
    S31A00103FD2EFE6001EA001001EA1000018AF0000037FFF0018A071
    S31A00103FE7010016A101000E01FF0032F001000E10FE0034EFEC9A
    S31A00103FFC000EA1FF000EA01C0018AB01000E2BFA000E1BFE0004
    S31A0010401132EFEC001CAB00003AC37B000CAFCE000CAFBD001E19
    S31A00104026AC01001EAB00003AF9FB001EA003001EA1020002CB7C
    S31A0010403B000002CC01000EAFFE0002FF040033EFEA001D1F0083
    S31A001040500002EF00001EAC01001EAB00000EADF1003A7FB200A9
    S31A001040651EAC04000EABFF0016AF0500397FAC0023FFFF000358
    S31A0010407A74FF000375FF000EA5FE000EA457000EA3FE000EA218
    S31A0010408F87001CAF00001A1F270034EFBA000EA1BF000EA0AEAD
    S31A001040A40018AE030018AD02000EACFF000EABFF001AAF220005
    S31A001040B9037FFF001AAF2100037FFF001AAF2000037FFF001A6C
    S31A001040CEAF1F00037FFF001E1B000032EFC3001E1C010032EFFF
    S31A001040E3C3001E1D020032EFC3001E1E030016AF040030EFBAED
    S31A001040F8000EA1FF000EA0470018AF13000EBFFD0002CF130072
    S31A0010410D1CAF000002DF27000EA1FF000EA0470018AB13000E2D
    S31A001041222BF5000E1BFD0032EFAF0018AF13000E2F020002CF72
    S31A0010413713000EABFE0033EFAE000EABFF000CAFBC000EABFFDC
    S31A0010414C0016A5010016A4010023FFFF0000FCD2000017D100FA
    S31A0010416100FCD0000017CF0000FFC90023FFFF00397FAD00161D
    S31A00104176AFFE0002FB00000EAFFF0002FF01000E1BF10030EF7D
    S31A0010418B91003AC161000CAFC4000CAFB5001EAB00003AC37BEC
    S31A001041A0000C05BF0032EF94000C14CF0035EF91000EAFFE0010
    S31A001041B502FF01001EAC01000EABFF0016AF0200397FAC00230C
    S31A001041CAFFFF000EA1BF000EA0AE0018AE410018CE2A0018AD26
    S31A001041DF400018DD29000C0BDF0032EF83000C1CEF0035EF7F03
    S31A001041F4000EACFF000EABFF0033EF7D000EACFE000EABFF0020
    S31A0010420923FFFF000ECCAB000EDB0A000EA1BF000EA0AE00180F
    S31A0010421E0B210032EF7500181C220030EF6D00180B230032EF6A
    S31A001042337100181C240035EF6D000EACFE000EABFF0033EF6B09
    S31A00104248000EACFF000EABFF0023FFFF000EA1BF000EA0AE00EF
    S31A0010425D180B640032EF6500181C650034EF610018AC650018CB
    S31A00104272AB640033EF5B00180B660032EF5E00181C670031EFD2
    S31A001042875B0018AC670018AB660023FFFF00397FAD0016AFFD15
    S31A0010429C0002FD000002FE01000EAFFF0002FF02003A7FC000BF
    S31A001042B10CAFC8000CAFB9000EA1BD000EA076000EA5BF000EDB
    S31A001042C6A4AE001CAF0E00037FFF001CAF0D00037FFF0018AE02
    S31A001042DB0D0018AD0C00397FD80016AF02000C09DF0032EF422C
    S31A001042F0000C18EF0034EF3F000EAFFE0002FF02003AC1610014
    S31A001043050EA1FF000EA01C0018AE070018AD06003AC4D0001E91
    S31A0010431A3C01001E7B00001C0B160032EF34001C1C170034EF9E
    S31A0010432F31000EAFFE0002FF02001EAC02000EABFF0016AF0328
    S31A0010434400397FAC0023FFFF00397FA90016AFFF000EAFEB00FC
    S31A0010435902FF00000EABFF000EAC30000EADBD000EAEFB003A2D
    S31A0010436E7FE00016AF0100397FA80023FFFF00397FAD000EA566
    S31A00104383FF000EA41C001CAB01000E2BFE000E1BFF0036EEF205
    S31A00104398001CAC07000ECCAB001CAB06000EDB0A000EADFF002C
    S31A001043AD3AEEC7001CAC09001CAB08000EADFE003AEEC7001C92
    S31A001043C2AC15001CAB14000EADFD003AEEC7000EA1BE000EA072
    S31A001043D7370018AB03000E2BFD000E1BFF0036EEFE000EA1FF90
    S31A001043EC000EA030000EA22F000EA37F001AAB010018BF0E000E
    S31A0010440102CF0E000EA3FF000EA230000EA1BD000EA0FB001AF2
    S31A00104416AF0E00181F0E0036EEF20004AFC80004BFC70032EE3E
    S31A0010442BF20000FFC80000FEC700397FAC0023FFFF00397FA902
    S31A001044400004AFC80004BFC70036EEDF000EA1BD000EA0FB0034
    S31A0010445504ACC70004ABC8000D1FCF0001BFC7000D5FBF0001A0
    S31A0010446ABFC800181B120032EEE100181C130035EEDF003AEEE9
    S31A0010447FDD00397FA80023FFFF00397FA90016AFFE0000FFC8C9
    S31A001044940000FFC7000EA1FF000EA03000191F0D0002CF0D0088
    S31A001044A9195F0C0002CF0C000EAFBD0002FF00000EAFFB000252
    S31A001044BEFF01000EACEB000EABFF000CAF1D000CAF0E003AFD9E
    S31A001044D3BB0016AF0200397FA80023FFFF00397FAD0016AFFF92
    S31A001044E8000CAFC2000CAFB3000EAFFF0002FF00000CAFDE0068
    S31A001044FD0EADFF000CAFE0000EC0FB000CAFD1000ED1BD001836
    S31A00104512A80F000EA9FF000EEEFB00037FFF000EEDFB000CBFD8
    S31A00104527ED0016AE01000CAFE0000EC030000CAFD1000ED1FFB4
    S31A0010453C000CAFE4000EC4FB000CAFD5000ED5BD00180300009D
    S31A0010455132EEA9001812010034EEA10002C3000002C201000CF2
    S31A00104566AF2C001C3C01000CAF3B001C7B000033EE9700180396
    S31A0010457B020032EE9E001812030031EE910002C3020002C203EA
    S31A00104590001C1203000CAFFC001CAB02000C7B3B000C0B9F00D7
    S31A001045A532EE94000C1C8F0034EE91000EAFFE0002FF00001EF3
    S31A001045BAAF000036EE8A0004AFC80004BFC70032EE8A0000FFCB
    S31A001045CFC80000FEC7001EAC00000EABFF0016AF0100397FAC88
    S31A001045E40023FFFF00397FAD0016AFFE003AE700000EA5FF0090
    S31A001045F90EA41C000EA1FE000EA04D001CAC0700183C03001CDF
    S31A0010460EAB0600187B02003A7FC0000EA1BE000EA05C00180B28
    S31A00104623110032EE7400181C120034EE450004AF620032EE45A0
    S31A001046380004AFA30032EE6B001CAF34000EBFFE0002EF340087
    S31A0010464D33EE450004AFA3000E1F010032EE56000EA5FF000E22
    S31A00104662A447001CAC11001CAB10003AC414000EA1BF000EA064
    S31A00104677AE0018AB00001CAE11001CAD100004AFD20002FF006D
    S31A0010468C0004AFD10002FF01000CAFDC000CAFED000EAEFF0083
    S31A001046A133EE46000EA1BF000EA0BD0018A40A0018A509000C16
    S31A001046B6AF5B000CAF4C003AC414003AE7E0000CAFCB0004AF7C
    S31A001046CBD20002FF000004AFD10002FF01000CAF5C000CAF4D4C
    S31A001046E0000EAEF7003AC8B60004AF610036EE400004AF6200B7
    S31A001046F532EE40003AC6F8000E2A20000EFADF0032EE40000E95
    S31A0010470AA3FF000EA21C001AAB34000E2BFB000E1BFF0036EE9D
    S31A0010471F2F000EA09F000EA17F0018AB00000EBBFA0002CB0072
    S31A00104734001AAF34000E2F040002DF34003AFF180000FF620055
    S31A001047490EA09F000EA17F0018AB00000EBBFA0002CB00003A3D
    S31A0010475EE699000CAFCB000E6BFE003AE6C7003AE6F9003ACCAE
    S31A00104773320016AF0200397FAC0023FFFF00397FAD000EA1FE8B
    S31A00104788000EA0870018AC180018AB17000EA5FF000EA41C009B
    S31A0010479D1CAE1D001CAD1C003AE7D7000CAFC8000CAFB9000E28
    S31A001047B2ABFE000EACFC000CAF9D000CAF8E003AFB06000EA1F2
    S31A001047C7BE000EA0370018AB01000E2BFB000E1BFF0036EE00E0
    S31A001047DC001CAC1D001C3C21001CAB1C001C7B20000EFB7F0032
    S31A001047F132EDF6000CBCBF0036EDF60018AB01000E2BFD000EE0
    S31A001048061BFF0036EDE8001CAF20000EFF7F0032EDF6001CAF0B
    S31A0010481B20001CBF210032EDE8000EA5FF000EA41C001CAE21E4
    S31A00104830001CAD20000EABFE000EACFA003AFB06001CAE1D00E7
    S31A001048451CAD1C000EABFF000EAC04003AFB060000FE930033EE
    S31A0010485AED6A0004AF900032EDDD000EA1FE000EA0AB0018AFD0
    S31A0010486F02000EFF7F0032EDDE0018AF020018BF030032ED9041
    S31A001048840033EDC90004AF920036EDD6000EA1FF000EA01C006A
    S31A0010489918A8210018A9200033EDC3000EA1FF000EA01C0018BF
    S31A001048AEAC230018AB2200180B200032EDCF00181C210034ED84
    S31A001048C3C7000CAFC8000438B9000CAFB9000479BA0033EDC3FD
    S31A001048D8000EA1FF000EA01C0018A8230004C8B90018A92200F2
    S31A001048ED04D9BA000EF97F0032EDB9000EA1FE000EA0870018B1
    S31A00104902AF17000EFF7F0032EDB90018AF170018BF180032ED74
    S31A00104917B7000EA8FF000EA9FF000EABFE000EACFA000CAF9D90
    S31A0010492C000CAF8E003AFB060004AF900036ED6A0004AF9100C8
    S31A0010494136EDA7000EA1FF000EA01C0018AE1D0018AD1C000E37
    S31A00104956ABFF000EAC04003AFB06000EA1FF000EA01C0018AC57
    S31A0010496B190018AB1800180B1C0032EDA000181C1D0034ED9B22
    S31A0010498000059FB90001BFB90005CFBA0001BFBA0018AC190051
    S31A0010499518AB1800181B1C0032ED9500181C1D0036ED6A000C2F
    S31A001049AAAFCE0004CEB9000CAFBD0004DDBA0033ED6D000EA587
    S31A001049BFFF000EA41C0018AE06000CAFED000E6DFE001CCE2306
    S31A001049D4001CDD22000EABFE000EACFA003AFB06001CA819001A
    S31A001049E91C3823001CA918001C7922000EF97F0032ED71000C76
    S31A001049FEB89F0036ED71001CAC1D001C3C21001CAB1C001C7BCB
    S31A00104A1320000EFB7F0032ED71000CBCBF0036ED71001CAE1942
    S31A00104A2800043EB9001CAD1800047DBA0033ED6D000EA1FF0011
    S31A00104A3D0EA01C0018AE230018AD22000EABFF000EAC04003A04
    S31A00104A52FB06000EA1BE000EA0370018AB03000E2BEF000E1BCF
    S31A00104A67FF0036ED5A000EA5FF000EA41C001CAE19001CAD1864
    S31A00104A7C000EABFF000EAC0A003AFB06001CA823001CA922008A
    S31A00104A9133ED51000EA5FF000EA41C001CAE1D001CAD1C000E2F
    S31A00104AA6ABFF000EAC0A003AFB06001CA821001CA920000EA3C1
    S31A00104ABBFF000EA21C001AAE13000ECE9C001B5D12000EAF9BD0
    S31A00104AD000037FFF000EAFFF00037FFF00397FD80016AF0200A6
    S31A00104AE51A4E13001A5D12000EA1BE000EA0370018AB01000E7E
    S31A00104AFA2BF7000E1BFF0036ED2C000CB89F0032ED2C001AAF81
    S31A00104B0F10000EFF7F0032ED2C001AAF10001ABF110036ED2C82
    S31A00104B24000EA1BF000EA0AE001AAC09001AAB0800180B40009D
    S31A00104B3932ED2F00181C410034ED2C000EA8FE000EA9FF000EC9
    S31A00104B4EA1BE000EA0370018AB00000E2BF7000E1BFF0036EDBA
    S31A00104B6314000C09DF0032ED23000C18EF0035ED14000EA1FFE6
    S31A00104B78000EA01C0018AC2B0018AB2A000E1BFF0032ED1B000A
    S31A00104B8D0E1C9C0030ED140004ABBF000E2BFB000E1BFF00320A
    S31A00104BA2ED14000CAFE8000CAFD9000EABFF000EAC0C000CAF77
    S31A00104BB79D000CAF8E003AFB06000EA1FF000EA01C0018AC2155
    S31A00104BCC0018CC0F0018AB200018DB0E000CAFCE00183E1D00EB
    S31A00104BE10CAFBD00187D1C000EFD7F0036ECFE000EABFF000E10
    S31A00104BF6AC10000EAEFF000EADFF0033ECFC000EABFF000EACD6
    S31A00104C0B10003AFB0600397FAC0023FFFF00397FAD0016AFFD87
    S31A00104C200004ABFF000E2BEF000E1BFF0036ECEC000EA0EF00C0
    S31A00104C350EA17F0018AB03000E2B7F000E1BFF0032ECE6003349
    S31A00104C4AECD4000EA0DF000EA17F0018AB03000E2B7F000E1B1D
    S31A00104C5FFF0036ECD40004ACC6000EABFF000ECCFD000D5FBB09
    S31A00104C74000EA1BE000EA02C0018AE04000EADFF000C0BDF0054
    S31A00104C8932ECDB000C1CEF0035ECD7000EAFFE0002FF02003307
    S31A00104C9EECD100051FC60001BFC60033ECD30000FFC6000EAF4A
    S31A00104CB3FF0002FF02000EA1FF000EA01C0018AB00000E2BF36D
    S31A00104CC8000E1BFF0036ECBA000EA0BF000EA17F0018AB00005F
    S31A00104CDD0E2BFD000E1BFF0036ECBA003AEB5A000E2CFE000CAF
    S31A00104CF2AFCB000EEBF7000CAFFB0004AFBF000E2F080001BF00
    S31A00104D07BF000CBFBF0001BFBF0033EC8C000EA5FF000EA41C8E
    S31A00104D1C001CAC15001CAB14003A7FC0000EA1BE000EA02C00F4
    S31A00104D31180B020032ECB000181C030030EC8C0004ABBF000E09
    S31A00104D462BF7000E1BFF0032EC8C001CAC07000ECCAB001CAB33
    S31A00104D5B06000EDB0A00180B070032ECA400181C080030EC8C64
    S31A00104D7000180B050032ECA000181C060035EC8C001CAF14006C
    S31A00104D851CBF150036EC8C0004AFB60032EC8C001CAF00000E79
    S31A00104D9ABFF70002EF00003AEB5A000E2CFE000CAFCB000EEB11
    S31A00104DAFF7000CAFFB0004AFBF000E2F080001BFBF000CBFBF6C
    S31A00104DC40001BFBF00005FB6001EAF020032EC870004AFBF004A
    S31A00104DD90E2F080001BFBF000EA1BF000EA0FF0004ACA100047B
    S31A00104DEEABA200181B080032EC7F00181C090036EC70000EA1F7
    S31A00104E03FF000EA01C0018AB00000E2BEF000E1BFF0032EC701A
    S31A00104E18000EAFBF0002FF00000EAFF70002FF01000EACFD0085
    S31A00104E2D0EABFF000EADFF000EAEA2003AFDBB000EACFF000ED1
    S31A00104E42ABFF0016AF0300397FAC0023FFFF00397FAD0016AF24
    S31A00104E57FA000EA1FF000EA01C0018AF100002FF010018AF110D
    S31A00104E6C0002FF020018AE130018AD12000EFD7F0032EC5D0063
    S31A00104E810CBEDF0032EC5B000EA5FF0033EC55000EAFFE000201
    S31A00104E96FF00001EAC02001EAB01003A7FB7000CAFC5000CAFB1
    S31A00104EAB5D000EABFE000EACF2000CAFDE000E6DFE003AFB06CF
    S31A00104EC0000EA1FF000EA01C0018AF1C000EFF7F0032EC47007B
    S31A00104ED518AF1C0018BF1D0032EC42000EABFF000EAC18000EE3
    S31A00104EEAAEFF000EADFF0033EC370018AC210018AB200018AE52
    S31A00104EFF1D0018AD1C000EAFFE0002FF00003A7FB7000CAFCED5
    S31A00104F14000CAFBD000EABFF000EAC18003AFB06000EA1BE00C8
    S31A00104F290EA05C0018AF0D000E1F000036EC2B0018050D0035A6
    S31A00104F3EEC2B0004AFBF000EBF7F0001BFBF0033EC24000EA102
    S31A00104F53BE000EA05C0018050E0030EC240004AFBF000E2F80D1
    S31A00104F680001BFBF000EA1BE000EA05C0018AF0F000E1F000025
    S31A00104F7D36EC190018050F0035EC190004AFBF000EBFBF000169
    S31A00104F92BFBF0033EC12000EA1BE000EA05C001805100030EC85
    S31A00104FA7120004AFBF000E2F400001BFBF000EA1BD000EA076CF
    S31A00104FBC0018AF180002FF030018AF190002FF040018A41B002B
    S31A00104FD118A51A000EA1BE000EA0370018AF03000E2FFE000285
    S31A00104FE6FF05000E1FFF0036EBF9000EABFE000EACF8003A7F34
    S31A00104FFBA50002FB030002FC04000EABFE000EACF6003A7FA51F
    S31A00105010000CAFC4000CAFB50004AF580036EBAC001EAC0400E0
    S31A001050251EAB0300041BC50032EBB000041CC40032EBB000042E
    S31A0010503A15C30032EBB0000414C20032EBB0001EAC02001EAB6A
    S31A0010504F01001E0B030032EBE8001E1C040030EBD6001EAF0503
    S31A001050640036EBDA000EA1FF000EA01C0018AF14000EFF7F0047
    S31A0010507936EBD6000EABFF000EAC11000EADFB003A7FA4003A45
    S31A0010508EFAF70033EBD6000EABFF000EAC11000EADFB003A7F20
    S31A001050A3A4001EAC02001EAB01000C0B5F0032EBD1000C1C4FCD
    S31A001050B80035EBAC000EA1BE000EA0370018AB03000E2BFE00B2
    S31A001050CD0E1BFF0036EBB0000EA1FF000EA01C0018AF14000E5E
    S31A001050E2FF7F0032EBAC0018AF140018BF150036EBAC0004AF15
    S31A001050F7B80032EBAC0018AB0B000E2BFB000E1BFF0036EBB70B
    S31A0010510C000EABFF000EAC11000EADFB003A7FA30033EBB30012
    S31A001051210EABFF000EAC11000EADFB003A7FA4003AFAF70000A2
    S31A00105136FEB80033EBAC000EABFF000EAC11000EADFB003A7FDC
    S31A0010514BA3001EAF030001BFC5001EAF040001BFC40001B5C373
    S31A001051600001B4C20004AF580036EB8F000EA1BD000EA0760062
    S31A001051751EAC02001EAB0100180B1C0032EB9D00181C1D0030FF
    S31A0010518AEB980004AFBF000EBFEF0001BFBF0033EB8F001EAC53
    S31A0010519F02001EAB0100180B1E0032EB9300181C1F0035EB8F26
    S31A001051B40004AFBF000E2F100001BFBF0000FE580004ABBF00CE
    S31A001051C90E2B7F000E1BFF0032EB7B000EA1FF000EA01C0018B3
    S31A001051DEAB0A000E2BF7000E1BFF0032EB7B0018AB1B000E2BEA
    S31A001051F3F7000E1BFF0032EB7B000EABFF000EAC11000EADF7A5
    S31A00105208003A7FA40033EB77000EABFF000EAC11000EADF70054
    S31A0010521D3A7FA30004ABBF000E2BBF000E1BFF0036EB6E000EDF
    S31A00105232ABFF000EAC12000EADFD003A7FA40033EB6A000EAB85
    S31A00105247FF000EAC12000EADFD003A7FA30004ABBF000E2BEFC7
    S31A0010525C000E1BFF0036EB61000EABFF000EAC11000EADFD0042
    S31A001052713A7FA40033EB5D000EABFF000EAC11000EADFD003AC5
    S31A001052867FA30016AF0600397FAC0023FFFF00397FAD0016AF61
    S31A0010529BF8000EA5FF000EA41C001CAB00000E2BF3000E1BFB59
    S31A001052B00036EB4E000EA0BF000EA17F000EAFFC0002CF00003F
    S31A001052C51CAF080002FF05001CAF090002FF06003AFF18001C9D
    S31A001052DAAB00000E2BEF000E1BFF0036EB37000EACFE000EABE5
    S31A001052EFFF000EAFFE0002FF070033EB31000EABFF000EAC1CF5
    S31A00105304000EADFB003A7FA3000EABFF000EAC1C000EADF7002C
    S31A001053193A7FA30033EB0D000EA1BF000EA0FF0018AC360018B5
    S31A0010532EAB35000EAFFF0002FF07000EAFFF0002FF030002FFEF
    S31A0010534304000CAFC4000CAFB5000CB45F0036EB0D000EA09FB2
    S31A00105358000EA17F0018AB00000EBBFA0002CB00003AFF180058
    S31A0010536D0EA1FF000EA01C001EAC0600183C09001EAB0500188A
    S31A001053827B08003A7FC0000EA1BF000EA0FF00180B400032EB69
    S31A001053971800181C410030EB40001EAF0400043FDC0002FF040E
    S31A001053AC001EAF0300047FDD0002FF03000DBF44000DFF550031
    S31A001053C10CB45F0032EB2A000EA0BF000EA17F000EAFFD000204
    S31A001053D6CF00001EAF070036EAFE000EA1BF000EA0FF001EAC06
    S31A001053EB04001EAB030018AE360018AD3500397FDD0002FD033A
    S31A001054000002FE04000CB45F0032EAC6000EA1FF000EA01C0004
    S31A0010541518AB00000E2BF3000E1BFB0036EAF1001EAF03000177
    S31A0010542ABFA2001EAF040001BFA10033EAE4001EAF0400043FAF
    S31A0010543FA10002FF02000CAF6E000ECEFD000D5F7D000EAFBF37
    S31A001054540002FF00000EAFF50002FF01000EACFE000EABFF0008
    S31A001054693AFDBB000EA1FF000EA01C0018AB00000E2BF7000EAD
    S31A0010547E1BFF0036EADA000CAF1B000CAF0C000EADF70033EA83
    S31A00105493D30018AB00000E2BFB000E1BFF0036EAD2000CAF1B34
    S31A001054A8000CAF0C000EADFB003A7FA3000EA1FF000EA01C0088
    S31A001054BD18AF080001BFA00018AF090001BF9F0018AF06000198
    S31A001054D2BF9E0018AF070001BF9D000EACFE0033EAC5000EACD3
    S31A001054E7FF000EA09F000EA17F0018AB00000EBBFA0002CB00CD
    S31A001054FC000EABFF0016AF0800397FAC0023FFFF00397FAD0016
    S31A0010551116AFFF000EFADF000CAFFB0002FB00000E2A20000EAB
    S31A00105526FADF0032EAB70004AFC00036EAB00005BFC00001BF27
    S31A0010553BC0001EAB00000CBABA0004ABDF000E2BEF000E1BFF5E
    S31A001055500036EAA6000EABE8000EAC3C000EADFE003AFF0500DC
    S31A001055650EA1FE000EA08700191F220002CF2200195F21000251
    S31A0010557ACF2100195F200002CF2000195F1F0002CF1F00191FCE
    S31A0010558F230002CF2300191F2D0002CF2D00195F2C0002CF2CD6
    S31A001055A400195F2B0002CF2B00195F2A0002CF2A0018AF2300B6
    S31A001055B90E1F1F0034EA6500191F250002CF2500195F24000207
    S31A001055CECF240018AF23000ECFE00002CF23000EABFE000EACB3
    S31A001055E37F003A7FB4000EABFE000EAC83003A7FB40004AFB6E7
    S31A001055F80036EA7E0005BFB60001BFB6000EA1FE000EA0870018
    S31A0010560D18AC050018AB04003AE190000CAFC4000CAFB5000E3A
    S31A00105622A1BF000EA0AE0018AC10000EABFF000EA1BD000EA0FB
    S31A00105637760018AE0D0018AD0C003A7FB9000C15BF0032EA6B55
    S31A0010564C000C14CF0035EA65000EA1FF000EA01C0018AF010080
    S31A001056610EBFFB0002CF01003AEA3A000EA1FF000EA0120018A0
    S31A00105676AB00000E2BCF0018AC01000E2CEB000CBCBF0032EAC9
    S31A0010568B55000EA1FF000EA0020018AC01000E2CC3000EABFFC7
    S31A001056A0000CBCBF0036EA49000EA1BE000EA0370018AB0300D7
    S31A001056B50E2BFE000E1BFF0032EA3E0018AB00000E2BEF000E18
    S31A001056CA1BFF0036EA3E003AFAF70033EA3E000EA1BE000EA09C
    S31A001056DF370018AB03000E2BFE000E1BFF0032EA3E0018AB0027
    S31A001056F4000E2BEF000E1BFF0036EA3E003AFADC003AEEF000B5
    S31A0010570916AF0100397FAC0023FFFF00397FAD0016AFF9000EF9
    S31A0010571EFADF000CAFFB0002FB02000EA1FF000EA01C0018AF93
    S31A0010573307000ECFAB0002FF040018AF06000EDF0A0002FF03EF
    S31A00105748000E2A20000EFADF0032EA2D0004AFA3000E1FFD002E
    S31A0010575D32EA00000EA1BE000EA05C000EA5F500186513000C4A
    S31A00105772AFF4001EAC04001EAB03000C0B5F0032EA1D000C1CF8
    S31A001057874F0035EA13000EABF500186B17000CAFFC001EAE04A7
    S31A0010579C001EAD03000C0DBF0032EA14000C1ECF0034E9CB002B
    S31A001057B10EABFF000EAC11000EAD7F003A7FA4000EA1FF000EF7
    S31A001057C6A01C000EAFFF0002CF300002CF31000EAFFF0002CFB0
    S31A001057DB2E0002CF2F001EAC04001EAB03000C0B5F0032EA0247
    S31A001057F0000C1C4F0035E9DA0033E9CF000EA5BE000EA45C00B5
    S31A001058050EADF5001C6D13000CAFFE0002FD050002FE06001E4B
    S31A0010581AA004001EA103000C01DF0032E9F4000C10EF0035E9D9
    S31A0010582FEC000EABF5001C6B16000CAFFC000C01BF0032E9ED8C
    S31A00105844000C10CF0034E9CB000EABFF000EAC12000EADF70030
    S31A001058593A7FA4000EA1FF000EA01C000EAFFF0002CF30000290
    S31A0010586ECF31000EAFFF0002CF2E0002CF2F001EAC04001EABBD
    S31A0010588303001E0B050032E9DB001E1C060031E9D80000FFB7EB
    S31A001058980033E92A000EABF5001C6B17000CAFFC001EAE0400CC
    S31A001058AD1EAD03000C0DBF0032E9D0000C1ECF0034E9CD00005C
    S31A001058C2FAB70033E92A0000FBB70033E92A0004AFB7000E1F35
    S31A001058D7FD0032E9BD000EA1BE000EA05A0018A413000CAF458D
    S31A001058EC000E65FE000EA1BE000EA05B0018A813000CAF890093
    S31A001059010E69FE0033E9820004AFB7000E1FFD0034E99A000419
    S31A00105916AFB7000E1FFA0032E9B4000EA433000EA5F30033E963
    S31A0010592BAB0004ACB7000EABFF000CAFC0000EC05C000CAFB176
    S31A00105940000ED1BE0018A413000CAF45000E65FE0004ACB700F8
    S31A001059550EABFF000EA3BE000EA25C000CAFC0000EC05D000C42
    S31A0010596AAFB1000ED1BE0018AE13000CAFED000E6DFE001AAC55
    S31A0010597F18000CAFCB000E6BFE000C4CE8000C5BD90033E982CA
    S31A00105994000EA3BE000EA25C0004A8B7000EA9FF000CC2800006
    S31A001059A90CD3910018AE13000CAFED000E6DFE001AAC18000C7F
    S31A001059BEAFCB000E6BFE000CCCE4000CDBD50004AFB70032E9D0
    S31A001059D387000EA8FF000EA9FF0033E982000CC280000CD3915B
    S31A001059E80018A812000CAF89000E69FE000CAF5B000CAF4C00EC
    S31A001059FD0EAEF5000EADFF00397FDD001EA004001EA103000CEF
    S31A00105A1201DF0032E978000C10EF0034E97400051FB70001BFBF
    S31A00105A27B70033E967000CAF9B000CAF8C000EAEF5000EADFF12
    S31A00105A3C00397FDD001EAC04001EAB03000C0BDF0032E96A0095
    S31A00105A510C1CEF0031E9670005BFB70001BFB70004AFB7000E28
    S31A00105A661FFA0034E9630000FAB70004AFB70036E92A0004AF65
    S31A00105A7BB7000E1FFB0030E95A000EABFF000EAC11000EAD7FF1
    S31A00105A90003A7FA30004AFB7000E1FFC0030E953000EABFF00D8
    S31A00105AA50EAC12000EADF7003A7FA3000EA5FF000EA41C001C60
    S31A00105ABAAB0A000E2BF7000E1BFF0032E92A001CAB0B000E2B64
    S31A00105ACF7F000E1BFF0032E92A000EADBE000EAE5C0004ACB7C8
    S31A00105AE4000EABFF000DBFCC000DFFBB000CCCCC000CDBBB003A
    S31A00105AF90CCEC0000CDDB10018AF190002EF2E0018AF1A00026C
    S31A00105B0EEF2F0004ACB7000EABFF000CCEC0000CDDB10018AC37
    S31A00105B2320000EABFF000EA1BD000EA0760018AE0D0018AD0C4B
    S31A00105B38000EAFFF0002FF00000EAF9B0002FF01003A7FBE00B4
    S31A00105B4D02EB300002EC31000EA1FF000EA01C0018AB0A000E9E
    S31A00105B622BFD000E1BFF0036E91E000EAFFF0002CF300002CFFD
    S31A00105B7731000EAFFF0002CF2E0002CF2F001EAB02000CBABACC
    S31A00105B8C0016AF0700397FAC0023FFFF00397FAD0016AFFB0078
    S31A00105BA10CAFB50002FC04000EABFF000EAC1A003A7FA5000E6F
    S31A00105BB615FC0036E8E7000E05FC0030E907000E15FE0036E840
    S31A00105BCBAE000E05FE0030E8F5000E15FF0036E9000033E8AED9
    S31A00105BE0000E15FA0036E8BE000E05FA0035E8D9000E15F90082
    S31A00105BF536E8B90033E8AE000EA1BF000EA0BD0018AF0500023E
    S31A00105C0AFF000018AF060002FF010018AF070002FF020018AF09
    S31A00105C1F080002FF030033E8AA000EA5FF000EA41C001CAC152C
    S31A00105C34001CAB14001CAE09001CAD08003AF9BB0002FB0200D9
    S31A00105C4902FC03001CAF140002FF00001CAF150002FF0100333A
    S31A00105C5EE8AA000EA5FF000EA41C001CAC39001CAB38001CAE3F
    S31A00105C7309001CAD08003AF9BB0002FB020002FC03001CAF383B
    S31A00105C880002FF00001CAF390002FF010033E8AA000EA1BD00B9
    S31A00105C9D0EA0760018AE0D0018AD0C000EAFFA00037FFF000ECE
    S31A00105CB2AFFF00037FFF00397FD80016AF02000D9FEF0002FFA5
    S31A00105CC701000DCFDF0002FF000018AE0F0018AD0E000EAFFA96
    S31A00105CDC00037FFF000EAFFF00037FFF00397FD80016AF020088
    S31A00105CF10D9FEF0002FF03000DCFDF0002FF020033E8AA000264
    S31A00105D06FB000002FC010002FB020002FC030033E8AA000EA104
    S31A00105D1BBF000EA0AE0018AF490002FF000018AF4A0002FF011E
    S31A00105D300018AF4B0002FF020018AF4C0002FF030033E8AA0057
    S31A00105D450CAF7B000CAF6C000EADFF003AF55F001EAF04003687
    S31A00105D5AE873000EA5BF000EA4AE001CAF580036E891001EAC55
    S31A00105D6F03001EAB02003A7FC0000CAFC8000CAFB9000EA3BD5D
    S31A00105D84000EA276001CA058000EA1FF000370FF000371FF0027
    S31A00105D991AAE0F001AAD0E00397FD80016AF02000C09DF0032B6
    S31A00105DAEE892000C18EF0030E87A000EA5BF000EA4AE001CAF0E
    S31A00105DC3590036E876001EAC03001EAB02003A7FC0000CAFC834
    S31A00105DD8000CAFB9000EA3BD000EA276001CA059000EA1FF00D5
    S31A00105DED0370FF000371FF001AAE0F001AAD0E00397FD8001654
    S31A00105E02AF02000C09DF0032E87B000C18EF0031E876000D9FED
    S31A00105E17EF0002FF03000DCFDF0002FF02001EAC03001EAB0217
    S31A00105E2C0033E83F000EA5BF000EA4AE001CAF580036E85C0082
    S31A00105E411EAC01001EAB00003A7FC0000CAFC8000CAFB9000E24
    S31A00105E56A3BD000EA276001CA058000EA1FF000370FF000371F3
    S31A00105E6BFF001AAE0D001AAD0C00397FD80016AF02000C09DF1A
    S31A00105E800032E85D000C18EF0030E845000EA5BF000EA4AE003E
    S31A00105E951CAF590036E841001EAC01001EAB00003A7FC0000C46
    S31A00105EAAAFC8000CAFB9000EA3BD000EA276001CA059000EA18A
    S31A00105EBFFF000370FF000371FF001AAE0D001AAD0C00397FD89C
    S31A00105ED40016AF02000C09DF0032E846000C18EF0031E841001B
    S31A00105EE90D9FEF0002FF01000DCFDF0002FF00001EAC01001E4C
    S31A00105EFEAB000016AF0500397FAC0023FFFF00397FA90016AF59
    S31A00105F1301000EA09F000EA17F0018AB00000EBBFA0002CB0094
    S31A00105F280000FDB70004AFDF0032E82E003AE785003AE73700C2
    S31A00105F3D0EABFF0033E8250004ABDF000E2BEF000E1BFF00362D
    S31A00105F52E8240004AFDF000E2F100001BFDF003AEF2C000EAB8C
    S31A00105F67FE003AE630003AF044000EA1BE000EA0370018AB023C
    S31A00105F7C000E2BFB000E1BFF0036E810000EA1BF000EA03A001A
    S31A00105F9118AB00000EACFF000E1BFB0032E810000E1CFF0032C0
    S31A00105FA6E810000EA1FF000EA01C0018AF34000EBFBF0002CF08
    S31A00105FBB34000EABFF003AE7CC0004AFA3000E1FFD0032E80642
    S31A00105FD0000EABFF003AE63E003AF861000EABFD0033E80F001D
    S31A00105FE504AFA3000E1F010032E7FE000EABFE003AE63E003AA7
    S31A00105FFAF7FE000EAB010033E80F000EABFF003AE63E003AE172
    S31A0010600FA80033E81000397FA80023FFFF00397FA90016AFFFED
    S31A00106024000EA1FF000EA01C0018AC390018AB38000EAFFF0025
    S31A0010603902FF00000EAEC3000EADFF003AE654000CAFCE000CF9
    S31A0010604EAFBD000EABFF000EAC06003AFB060016AF0100397F8A
    S31A00106063A80023FFFF000E1DFF0036E7E1000ECCFD000D5FBB23
    S31A001060780023FFFF000EA1BF000EA0AE0018AC00000E0CFF0035
    S31A0010608D35E7D8000E0CFC0030E7D8000EACFF0023FFFF000E07
    S31A001060A2FB7F0036E7D3000EACFF000EABFF000C0BDF0032E7E9
    S31A001060B7D0000C1CEF0034E7CD000CAFDB000CAFEC0023FFFF91
    S31A001060CC000374FF000375FF000CAFB3000EABFE000EAC870056
    S31A001060E10CAFC0000CAFB10018AE220018AD21000EA5BE000E60
    S31A001060F6A41F000EA1BF000EA0AE00181D390032E7BC00181E79
    S31A0010610B3A0034E7B80018AE3A0018AD390033E7A6000E13017C
    S31A001061200032E7B3001C3E07001C7D060033E7A6000E13FD00AA
    S31A0010613532E7AC001CAC08000EABFF000C4CEE000C5BDD003335
    S31A0010614AE7A6000EAEFF000EADFF000CAFC0000CAFB10002CD72
    S31A0010615F280002CE29000CBEDF0036E7A0000EA1FE000EA087AC
    S31A001061740002CD280002CE29000EAEFF000EADFF0004AFA30045
    S31A001061890E1F000036E7980004AFA3000E1FFE0032E78F000ED2
    S31A0010619E13FD0032E793001CAE08000EADFF0033E78F000E13C4
    S31A001061B3010032E78F001CAE07001CAD06000EA1FE000EA08796
    S31A001061C80002CE220002CD21000EAFFF0002CF1F0002CF20002D
    S31A001061DD16A5010016A4010023FFFF00397FAD003AFCFB000E5B
    S31A001061F2A5FF000EA41C000EA1BD000EA0760018AF000002EFC8
    S31A00106207080018AF010002EF090018AF0C0002EF1C0018AF0DEE
    S31A0010621C0002EF1D0018AE0D0018AD0C000EABFF000EAC0E0025
    S31A001062313AFB06001CAE1D001CAD1C000EABFF000EAC0A003A85
    S31A00106246FB06000EABFF000EAC11000EADFE003A7FA4000EAFD6
    S31A0010625BF40002EF06000EAF8D0002EF070004AFBF000EBFF7B5
    S31A001062700001BFBF000EA1BD000EA0760018AE190018AD180038
    S31A001062850EABFE000EACF8003A7FA6000EA1BD000EA07600187E
    S31A0010629AAE1B0018AD1A000EABFE000EACF6003A7FA6000EA1BC
    S31A001062AFBF000EA0AE0018AF01000E1FFD0036E7460018AB0190
    S31A001062C4000E2BFE000EEBF7000CAFFB001CAF01000E2F0800C1
    S31A001062D902EF01000CBFBF0002EF01003AEF2C001CAC09001CEA
    S31A001062EEAB08003AD774003AEE85001CAF080001BFA0001CAFA2
    S31A00106303090001BF9F001CAF060001BF9E001CAF070001BF9DA9
    S31A0010631800397FAC0023FFFF00397FA90016AFFC000EACFF00FA
    S31A0010632D0EA1BD000EA0910018AF0D0002FF020018AF0E0002EC
    S31A00106342FF03000EA09F000EA17F0018AB00000E2BF7000C1B99
    S31A00106357CF0036E7210018AB00000E2B080002CB00000CAF6C16
    S31A0010636C000ECCFC000D5F7B003AE70C0004AFDF0032E71B0056
    S31A001063810CAF6C000ECCFD000D5F7B003AE70C000E1CFF003680
    S31A00106396E70F000CAF6E000ECEFD000D5F7D000EAFBD0002FF80
    S31A001063AB00000EAF840002FF01000EACFD000EABFF003AFDBB23
    S31A001063C00016AF0400397FA80023FFFF000CAFC0000CAFB10081
    S31A001063D50EABFF0018AF00000E1F050036E70300191F00000292
    S31A001063EACF00000EABFE000CAFBC000EABFF0023FFFF00397FFA
    S31A001063FFA9003AEE1F003AEC6B003AE7F8003AE6F200397FA867
    S31A001064140023FFFF00397FA9003AEABC003AEF20003AECF90093
    S31A001064290EABFF00397FA80023FFFF00397FA90016AFFC000EDF
    S31A0010643EA3FE000EA287000EA1BD000EA076001AAC1C00183C95
    S31A001064530B001AAB1B00187B0A0002FB020002FC03000EFB7F0E
    S31A001064680032E6CA0002DB1B0002DC1C0018AC090018AB08009D
    S31A0010647D0E1B000032E6DC000E1C000036E6D7000D1FCF0002BD
    S31A00106492FF03000D5FBF0002FF020033E6D4000EAF000002FF04
    S31A001064A7020002FF03000CAF6E000ECEFD000D5F7D000EAFBD5F
    S31A001064BC0002FF00000EAF6E0002FF01000EACFD000EABFF0018
    S31A001064D13AFDBB0016AF0400397FA80023FFFF000EA3FE000EA7
    S31A001064E6A2AB000EA1FE000EA04D001AAE06000CAFED000E6DA5
    S31A001064FBFE00181E050002CF050018AF04000C7FDF0002CF045D
    S31A00106510000EA1FE000EA08700181E070002CF070018AF06009C
    S31A001065250C7FDF0002CF0600181E010002CF010018AF00000C2E
    S31A0010653A7FDF0002CF0000181C030002CF030018AF02000C7FA8
    S31A0010654FBF0002CF02001AAF06000E0FFF0031E6A200181E1C99
    S31A001065640002CF1C0018AF1B000C7FDF0002CF1B0018CE1800E9
    S31A0010657902CE180018DD170002CD170018CC1A0002CC1A00181F
    S31A0010658EDB190002CB190023FFFF00397FAD000EA1BD000EA068
    S31A001065A3760018AE17000EADFF000EAC17000EABFC00397FDDA5
    S31A001065B8000CAFDC000E6CFE000CAFCB00037EFF00037DFF0024
    S31A001065CD037CFF00037BFF0004AEBB0004ADBC0004ACBD00045D
    S31A001065E2ABBE00397FD60016AF04000CAFE4000CAFD5000EA1F0
    S31A001065F7FE000EA0AB0018AC06000CAFCB000E6BFE0004AFA305
    S31A0010660C000E1FFD0032E678003AC5730033E6750018AE0100E2
    S31A0010662118AD0000397FDC0004CEBB0001BEBB0004DDBC000150
    S31A00106636BDBC0004DCBD0001BCBD0004DBBE0001BBBE000EA1E3
    S31A0010664BBD000EA0760018AE17000EADFF000EAC17000EABFC26
    S31A0010666000397FDD000CAFDC000E6CFE000CAFCB00037EFF0065
    S31A00106675037DFF00037CFF00037BFF0004AEBB0004ADBC0004A2
    S31A0010668AACBD0004ABBE00397FD60016AF04000C44EB000CAFC2
    S31A0010669FBC000E6BFE00397FAC0023FFFF00397FAD0016AFFEF0
    S31A001066B4000CAFE4000CAFD5000EFB7F0032E64B000EAC0000E7
    S31A001066C90EAB000033E641003A7FC0000EA1FF000EA01C00188A
    S31A001066DEAE110018AD100002FB000002FC01000CAF5B000CAF30
    S31A001066F34C003A7FBD0016AF0200397FAC0023FFFF00397FA90D
    S31A00106708000E1BFF0036E636000EABFF000EAC11000EADFE00B0
    S31A0010671D3A7FA40033E632000EABFF000EAC11000EADFE003A33
    S31A001067327FA300397FA80023FFFF00397FAD0016AFD40002FB9E
    S31A001067472A000EA1FE000EA087000EA5FF000EA41C001CAF06CA
    S31A0010675C0002CF1D001CAF070002CF1E000EA1BF000EA0BD008A
    S31A0010677118AF0B0001BFCE0018AF0C0001BFCD0018AF0D000168
    S31A00106786BFCC0018AF0E0001BFCB0018AB02000EEBBF000E2B47
    S31A0010679BFE001CAF01000E2F010002EF01000CBFBF0002EF015D
    S31A001067B0001F8B2A000E2BFE000EEBFB000CAFFB001CAF01003D
    S31A001067C50E2F040002EF01000CBFBF0002EF01003AEFA9000C1C
    S31A001067DAAF6C000ECCFD000D5F7B000EADFE003AE59B000EAF8B
    S31A001067EFFF0002FF2B003ADFF9000E1CFF0036E5FB001F9B2A1F
    S31A00106804001EBB2A000EEBFD0002FB2B001EAF2B0002FF160039
    S31A001068191CAF080002FF26001CAF090002FF27000EA1BE000EE3
    S31A0010682EA0370018AB03000E2BFB000E1BFF0036E5EA001CAF76
    S31A00106843360002FF28001CAF370002FF290033E5E6001CAF14C2
    S31A001068580002FF28001CAF150002FF29000CAF6C000ECCFD00E4
    S31A0010686D0D5F7B003AE03A001EAF2A0036E5DC001EAF23000ED9
    S31A001068822F3F0002FF230033E5D7001EAF23000E2F3F0002FFFD
    S31A0010689723000EBFFE0002FF23001EAF23000EBF7F0002FF2364
    S31A001068AC000E2F400002FF23000EA5FF000EA41C001D1C09005E
    S31A001068C11D5B08001CAE07001CAD06001CAF140002FF00001C90
    S31A001068D6AF150002FF01003AC4F2001E4C1C001E5B1B003A7F0E
    S31A001068EBC00002FB240002FC25000CAF6C000ECCFD000D5F7B99
    S31A00106900003AE141000EAFFE0002FF18000CAF6C000ECCFD003E
    S31A001069150D5F7B000EADFF003AE3130000FE610000FE93001C7A
    S31A0010692AAF1C0002EF18001CAF1D0002EF19000EA1FE000EA021
    S31A0010693F870018AC180018AB17001CAE1D001CAD1C003AE7D72C
    S31A001069540002EB200002EC21000EA1FE000EA0870018AC18003E
    S31A0010696918AB17001CAE1D001CAD1C003AE7D70002EB22000254
    S31A0010697EEC23003ADFD20016AF2C00397FAC0023FFFF00397FC6
    S31A00106993AD0016AFF1000CAFC4000CAFB5000EA1FE000EA087A5
    S31A001069A80018AF1F0002FF030018AF200002FF040018AF210006
    S31A001069BD02FF050018AF220002FF06000EA9FF000CAF98000CA4
    S31A001069D21D9F0036E57D000EADD7003A7FB2000EA1FF000EA0ED
    S31A001069E71C0018AF34000EBFDF0002CF34000CAF1B000CAF0C20
    S31A001069FC000EAD7F003A7FA30033E316000EA1BF000EA0AE00E4
    S31A00106A1118AE0A0018AD09000EACFF000EABFF001EAF06000375
    S31A00106A267FFF001EAF0600037FFF001EAF0600037FFF001EAF52
    S31A00106A3B0600037FFF001E0B000032E568001E1C010032E56847
    S31A00106A50001E1D020032E568001E1E030016AF040030E54E00F4
    S31A00106A6518AC1E0018CC6B0018AB1D0018DB6A000EA1FF000EDC
    S31A00106A7AA01C00180B080032E55D00181C090031E5550018AB2B
    S31A00106A8F34000E2BBF000E1BFF0032E5550004AFBF000E2F026B
    S31A00106AA40001BFBF0004ABBF000E2BFD000E1BFF0036E54F0012
    S31A00106AB90EA8FE0033E54E000EA9FE000EA3FF000EA21C001A4D
    S31A00106ACEAB34000E2BBF000E1BFF0036E528000EA1BF000EA03F
    S31A00106AE3AE0018AC1E0018CC6B0018AB1D0018DB6A001A0B083F
    S31A00106AF80032E53F001A1C090031E5360004ABBF000E2BFD00EE
    S31A00106B0D0E1BFF0036E5280004AFBF000EBFFE0001BFBF003303
    S31A00106B22E52D0004ABBF000E2BFE000E1BFF0036E52D0004AF6E
    S31A00106B37BF000E2F020001BFBF000E2F010001BFBF0004ABBF8B
    S31A00106B4C000E2BFD000E1BFF0036E528000EA8FE000E18FF00A4
    S31A00106B6136E50C000EA9FF000EA1BF000EA0AE0018AC52001834
    S31A00106B76AB51000EAEF5000EADFF00397FDB001EAF0600037FA5
    S31A00106B8BFF001EAF0600037FFF001EAF0600037FFF001EAF0665
    S31A00106BA000037FFF001E0B000032E50F001E1C010032E50F0099
    S31A00106BB51E1D020032E50F001E1E030016AF040030E50C000E1B
    S31A00106BCAA9FE000E19FF0036E375000EA3FF000EA21C001AAE01
    S31A00106BDF09001AAD08000CAFDC000E6CFE000CAFCB001CCE0E26
    S31A00106BF40002EE0E001CDD0D0002ED0D001CDC0C0002EC0C0078
    S31A00106C091CDB0B0002EB0B000EA1BE000EA0370018AB03000E40
    S31A00106C1E2BFB000E1BFF0036E4EF001AAE37001AAD36000CAF3D
    S31A00106C33DC000E6CFE000CAFCB0033E4EA001AAE15001AAD14A3
    S31A00106C48000CAFDC000E6CFE000CAFCB001CCE120002EE12008E
    S31A00106C5D1CDD110002ED11001CDC100002EC10001CDB0F0002F4
    S31A00106C72EB0F001D1F010002EF01001D5F000002EF00001CA2A3
    S31A00106C8701001CA300000EA1BF000EA0AE001813180032E439C6
    S31A00106C9C001812190032E439001CAE0E001C3E0A001CAD0D0029
    S31A00106CB11C7D09001CAC0C001C7C08001CAB0B001C7B07003AF8
    S31A00106CC67FC1000EAFFF0002FF02000EA1BF000EA0AE0018A81A
    S31A00106CDB1C000EA9FF000CAF80000CAF91000CAF18000E68FEEE
    S31A00106CF0000CAF89000370FF000371FF000378FF000379FF005B
    S31A00106D051E0B000032E4B7001E1C010032E4B7001E1D020032F6
    S31A00106D1AE4B7001E1E030016AF040030E4B3000EAFFE0002FF28
    S31A00106D2F02000EA3BF000EA2AE001AA019001AA118000EA8FF0E
    S31A00106D44000EA9FF000370FF000371FF000378FF000379FF0094
    S31A00106D591CAE0E001CAD0D001CAC0C001CAB0B00397FD6001617
    S31A00106D6EAF010002FF0A0016AF010002FF0A0016AF010002FFA7
    S31A00106D830A0016AF010002FF0A0002ED240002EE25000370FF70
    S31A00106D98000371FF000378FF000379FF001CAE12001CAD1100B2
    S31A00106DAD1CAC10001CAB0F00397FD60016AF040002ED2600029F
    S31A00106DC2EE27001EAF020036E484001CAF130036E484000EA1F9
    S31A00106DD7FF000EA01C0018AB01000E2BFE000E1BFF0032E46D22
    S31A00106DEC000EA1BF000EA0AE0018AE1B0018AD1A000EACFF0039
    S31A00106E010EABFF001EAF0600037FFF001EAF0600037FFF001EE8
    S31A00106E16AF0600037FFF001EAF0600037FFF001E0B000032E488
    S31A00106E2B6F001E1C010032E46F001E1D020032E46F001E1E030C
    S31A00106E400016AF040030E450003ADFF90002EC140002EC1B00DD
    S31A00106E550CAF5B000CAF4C003AE03A001CAF21000EBFBF000227
    S31A00106E6AEF21000EA1FF000EA01C00191C0900195B080018AEF5
    S31A00106E7F070018AD060018AF140002FF000018AF150002FF015C
    S31A00106E94003AC4F2001C4C1A001C5B19003A7FC00002EB220049
    S31A00106EA902EC23000EAFFE0002EF15001EAF060002EF02001E08
    S31A00106EBEAF020002EF13001CAF0B0002EF07001CAF0C0002EF5E
    S31A00106ED308001CAF0D0002EF09001CAF0E0002EF0A000EAFFF2A
    S31A00106EE80002EF0B0002EF0C0002EF0D0002EF0E000EAFFF00CD
    S31A00106EFD02EF0F0002EF100002EF110002EF12000EAFFF0002A6
    S31A00106F12EF000002EF01000EA1FF000EA01C0018AB34000E2BCB
    S31A00106F27DF000E1BFF0032E42F001D1F060002EF06001D5F0539
    S31A00106F3C0002EF05001CAF150036E375001EAB06001C3B02009E
    S31A00106F510EA1BF000EA0AE00181B250035E375000EAFFF0002A8
    S31A00106F66EF15000EAFFE0002EF160000FEB5000CAF5B000CAFB6
    S31A00106F7B4C003AE285000CAF5B000CAF4C003AE141000EA1FED8
    S31A00106F90000EA087000EA3FF000EA21C001AAE3B0018CE01003B
    S31A00106FA51AAD3A0018DD00000EABFE000EACE2003AFB06000E2F
    S31A00106FBAA1FF000EA01C0018AB34000E2BDF000E1BFF0036E3F2
    S31A00106FCFF6001CAF1B0036E3F6001CAE1A001CAD19000EABFE2F
    S31A00106FE4000EACE0003AFB06000EABFE000EACE2000EAEFF009F
    S31A00106FF90EADFF003AFB06000EA3FF000EA21C000CAF31000C04
    S31A0010700EAF200018AF34000E2F200002DF34000EAFFE0002EF6F
    S31A0010702317000EA1BF000EA0AE001CA206001CA3050018130BA3
    S31A001070380032E3EF0018120C0034E37A001CAF1B0036E3E7007C
    S31A0010704D1CAE1A001CAD19000EABFE000EACDA003AFB06000EBE
    S31A00107062A1BF000EA0BD0018AC010018AB00000EA1FF000EA054
    S31A001070771C000CAF02000CAF130018AE3D001A3E430018AD3CA8
    S31A0010708C001A7D42000D9FEE000E5DBF003AC255000EA1FF003D
    S31A001070A10EA01C00183C3B00187B3A001CAF050002FF00001CB1
    S31A001070B6AF060002FF01000EAEEF000EADF1003A7FBE000CAF6F
    S31A001070CBCE000CAFBD000CAF4F000ECFE30002FF0C000D5F5FB2
    S31A001070E00002FF0B000EA3BD000EA276001AAF150002FF010005
    S31A001070F50EAFFF0002FF00001EAC0C001EAB0B003AFAAB001E0C
    S31A0010710AAC0C001EAB0B003A7FA0000CAFCE000CAFBD000EABBB
    S31A0010711FFE000EACEA003AFB06001CAF20000E1F000036E3B087
    S31A00107134001D1F200002EF20000EA1BD000EA076001CAF200048
    S31A00107149181F160035E38B000CAF02000CAF13001AAF140003C0
    S31A0010715E7FFF001AAF1300037FFF0018AE0D0018AD0C00397FCF
    S31A00107173D80016AF02000D9FEE000DCFDD000EA1FF000EA01C87
    S31A001071880018AF3200037FFF0018A0330016A101000C01DF00D3
    S31A0010719D32E396000C10EF0030E38B000EA1BE000EA037001809
    S31A001071B2AB02000E2BEF000E1BFF0036E38B000EABFF000EAC9F
    S31A001071C701000EADDF003A7FA4001CAF200001BFC1000EA1FF8B
    S31A001071DC000EA01C0018AE430018AD42000EABFE000EACE0005D
    S31A001071F13AFB06000EABFE000EACE2000EAEFF000EADFF003A36
    S31A00107206FB06000EAFFF0002EF050002EF06000EA1FF000EA057
    S31A0010721B1C0018AF01000E2F040002CF01001EAC06001C3C0425
    S31A00107230001EAB05001C7B03000EA1BF000EA0AE00181B0B00C3
    S31A0010724532E36C00181C0C0031E363001CAF170032E363000E7E
    S31A0010725AA1FF000EA01C0018AB34000E2BFE000E1BFF0036E330
    S31A0010726F36001EAF050002EF03001EAF060002EF04001CAF164F
    S31A001072840032E357000EA1FF000EA01C0018AB34000E2BFE00CD
    S31A001072990E1BFF0036E3360004AF620032E336001CAF160036DC
    S31A001072AEE350000CAF5B000CAF4C003AE026000EA1BF000EA009
    S31A001072C3BD0018AF090002FF0D0018AF0A0002FF0E001EAC0E4D
    S31A001072D8001EAB0D003AC414003AE7E0000CAFCB0004AFD20097
    S31A001072ED02FF000004AFD10002FF01001EAD0E001EAC0D000E31
    S31A00107302AEF7003AC8B6000EAFFF0002EF17000EA1FF000EA0E3
    S31A001073171C0018AF34000E2F010002CF34000EA1BF000EA0AE27
    S31A0010732C0018AE480018AD47000CAFDC000E6CFE000CAFCB0087
    S31A001073411EAF0600037FFF001EAF0600037FFF001EAF060003A3
    S31A001073567FFF001EAF0600037FFF001E0B000032E320001E1CA2
    S31A0010736B010032E320001E1D020032E320001E1E030016AF0447
    S31A001073800030E316000EA3FE000EA287000EA1FF000EA01C005B
    S31A0010739518AF060002DF1D0018AF070002DF1E0016AF0F003928
    S31A001073AA7FAC0023FFFF00397FAD0016AFF8000CAFC4000CAF10
    S31A001073BFB50002FD030004ABBF000E2BFB000E1BFF0036E2BD4D
    S31A001073D40004AFB50032E2BD0004AFBF000E2F040001BFBF0023
    S31A001073E90CAF4F000ECFE60002FF05000D5F5F0002FF04000EC8
    S31A001073FEAFFD0002FF00001EAC05001EAB04000EADFE000EAEA6
    S31A001074134D003A7FE0000EA1FE000EA04D0018AE050018AD042C
    S31A00107428001EAC05001EAB04003AE1B0000EA1BF000EA0BD00F9
    S31A0010743D191C0400195B03000EA1FF000EA01C0018AE07001817
    S31A00107452AD060018AF140002FF000018AF150002FF01003AC4A4
    S31A00107467F2001C4C1A001C5B19003A7FC00002EB220002EC235D
    S31A0010747C001CAF21000E2F800002EF21000E2F3F0002EF21009C
    S31A001074910EBFFD0002EF21001EAF03000E1FFD0032E2D2001CF8
    S31A001074A6AF21000EBFBF0002EF210033E2CF001CAF21000E2F40
    S31A001074BB400002EF21001EAF03000E1FFE0034E2C4000EAFFEC4
    S31A001074D00002EF14000CAF5B000CAF4C003AE285000CAF5B00B8
    S31A001074E50CAF4C003AE141000EAFFE0002EF16000EA1FF000E9B
    S31A001074FAA01C0018AF01000E2F040002CF01001CAF160036E2D7
    S31A0010750FA30004AF620032E2A3000CAF5B000CAF4C003AE02685
    S31A00107524000EA1BF000EA0BD0018AF090002FF060018AF0A00BB
    S31A0010753902FF07001EAC07001EAB06003AC414003AE7E0000C60
    S31A0010754EAFCB0004AFD20002FF000004AFD10002FF01001EADC1
    S31A0010756307001EAC06000EAEF7003AC8B6001CAF180036E28838
    S31A00107578001CAF140036E29A000EA1FF000EA01C0018AF010017
    S31A0010758D0EBFFD0002CF01000EFADF000CAFFB0002FB02000E8D
    S31A001075A22A20000EFADF0032E297000EA1FE000EA09C000EAF2E
    S31A001075B7C00002CF00000EAF000002CF010000FFBE0000FFBD10
    S31A001075CC0000FFBC0000FFBB001EAB02000CBABA0016AF080007
    S31A001075E1397FAC0023FFFF00397FAD0016AFF40002FB040002D9
    S31A001075F6FC05000EA5FE000EA487001CAC07001CAB06003A7F2A
    S31A0010760BC00002FB060002FC07001CAC09001CAB08003AE19041
    S31A001076200002FB080002FC09000EA1BF000EA0AE0018AC3D0068
    S31A001076350EABFF000EA3BD000EA276001AAE0D001AAD0C003AFC
    S31A0010764A7FB6000EA5FF001EAE09001EAD08000C1DBF0032E28A
    S31A0010765F66000C1ECF0031E264000EA5FE001EA005001EA104F3
    S31A001076740018AF140036E1BA000EA1FF000EA01C0018AB010003
    S31A001076890E2BFD000E1BFF0036E1BA000E15FF0036E1B8000EA8
    S31A0010769EA1BF000EA0BD0018AB02000E2BFC000E1BFF0036E2BC
    S31A001076B333001EAC05000ECCE6001F5B04000EA3BF000EA2AE9E
    S31A001076C8001AAD3B003AE0C8000E1CFF0036E238000EA1BF00CC
    S31A001076DD0EA0AE0018AC3F000EABFF000EA3BD000EA276001ABD
    S31A001076F2AE0D001AAD0C00397FDC000CAFDE000CAFCD000CAF6F
    S31A00107707BC000E6BFE001E0D060032E239001E1E070034E2331A
    S31A0010771C001EA005001EA104000EAFFF0002CF140033E1B30054
    S31A001077310EA1FF000EA01C0018AF01000E2F020002CF01000ECE
    S31A00107746A1FE000EA0870018AC090018AB08003AE1900002FB04
    S31A0010775B0A0002FC0B000EA3BF000EA2AE001AAC3D000EABFF67
    S31A00107770001EAE07001EAD06003A7FB6000EA5FF001EAE0B0052
    S31A001077851EAD0A000C1DBF0032E21A000C1ECF0031E218000EBC
    S31A0010779AA5FE000EA1BF000EA0BD0018AB02000E2BFC000E1B25
    S31A001077AFFF0032E209001EAC05000ECCE6001F5B04000EA3BF16
    S31A001077C4000EA2AE001AAD3C003AE0C8000E1CFF0036E1B30064
    S31A001077D90E15FF0036E1B3000EAFFC0002FF00000D1F6C000D3A
    S31A001077EE5F7B000EADBF000EAEBD003A7FE0000EA1FE000EA0AF
    S31A0010780357001EA205001EA304001AAC1A00183C09001AAB195E
    S31A0010781800187B08003A7FC0000CAFC8000CAFB9001EAE070067
    S31A0010782D1EAD06000CAFDC000E6CFE000CAFCB000EECBF000C05
    S31A00107842AFFB000EEDBF000CAFFC000CBBDB000EEEBF000CAFE8
    S31A00107857FD000CBCEC000EAEFF000CAF80000CAF91000CAF1840
    S31A0010786C000E68FE000CAF89000370FF000371FF000378FF00DA
    S31A001078810379FF00397FD60016AF040002FD010002FE02000CFC
    S31A00107896AFDB000CAFEC003AE12C0002FB010002FC02000CBC89
    S31A001078ABBF0036E1B3000EABFF003AC5D9003AC65E000E1CFF12
    S31A001078C00036E1C8001EAF03000E2F030002FF03000EBFFE00DF
    S31A001078D502FF030033E1C3001EAF03000E2F030002FF03000E8B
    S31A001078EABFFD0002FF03000D1F6C000D5F7B003AE0A70000FE75
    S31A001078FF61001EA005001EA104000EAFFE0002CF170033E1B30D
    S31A00107914000E15FF0032E1B3000EA1FF000EA01C0018AF010020
    S31A001079290E2F020002CF010016AF0C00397FAC0023FFFF003993
    S31A0010793E7FAD000CAFC4000CAFB5003AC2F80002EB000002EC34
    S31A001079530100397FAC0023FFFF00397FA90016AFD8000CAF7B4F
    S31A00107968000CAF6C000EADFE003AE59B003AEE85000CAF7B0077
    S31A0010797D0CAF6C000EADFF003AE59B0004AFA3000E1FFD00368E
    S31A00107992E1970004AFA3000E1F010032E1A2000CAF7B000CAF28
    S31A001079A76C000EADFD003AE3130016AF2800397FA80023FFFFF3
    S31A001079BC00397FA9000CAFC0000CAFB1000EA8FF000EA9FF00ED
    S31A001079D10EA3BF000EA2FF001AAC31000EABFF000CAFCE000C28
    S31A001079E6AFBD000CAFDC000E6CFE000CAFCB00037EFF00037D75
    S31A001079FBFF00037CFF00037BFF000370FF000371FF000378FF08
    S31A00107A10000379FF00397FDA0016AF08000EAFFE00397FCD0031
    S31A00107A251AAF0700037FFF001AAF0600037FFF001AAF050003C4
    S31A00107A3A7FFF001AAF0400037FFF00397FD90016AF04000EAF3E
    S31A00107A4F9400037FFF000EAF0700037FFF000EAF9F00037FFFD5
    S31A00107A64000EAF9C00037FFF00397FD90016AF04000CAFE00028
    S31A00107A790CAFD1000CAFC8000CAFB9000CAF9B000CAF8C000CB6
    S31A00107A8EAF1D000CAF0E000CAFBF0036E14A000EFC7F0032E1C1
    S31A00107AA34A000E1B700032E14E000E1C800032E14E000E1D013D
    S31A00107AB80032E14E000E1EFF0036E14D0034E14A000EAC00009A
    S31A00107ACD0EAB800033E143000CAF9B000CAF8C000CAF1D000C7D
    S31A00107AE2AF0E00397FD1000CAFDB000CAFEC00397FA80023FF74
    S31A00107AF7FF00397FAD0016AFFF000CAFC4000CAFB5001CAF146E
    S31A00107B0C0036E12F000EABFE000EAC81000EADF2003A7FB200FE
    S31A00107B210CAF4E000ECEE6000D5F5D000EAFFD0002FF00000EDC
    S31A00107B36ABFE000EAC4F003A7FE00016AF0100397FAC0023FF8D
    S31A00107B4BFF00397FAD0016AFF40002FB060002FC07000EA1BF7C
    S31A00107B60000EA0BD0018AB02000E2BFC000E1BFF0036E0CD008A
    S31A00107B750EAFFF0002FF020002FF030002FF040002FF05000C0B
    S31A00107B8AAF6F000ECFFD0002FF0B000D5F7F0002FF0A001EA216
    S31A00107B9F0B001EA30A0018AF000002DF010018AF010002DF0291
    S31A00107BB4000EA1FE000EA0870018AC070018AB06003A7FC000B7
    S31A00107BC90CAFC8000CAFB9000EA1BF000EA0AE0018AC3F000EBF
    S31A00107BDEABFF000EA1BD000EA0760018AE0D0018AD0C0002F9A3
    S31A00107BF3000002F801003A7FBE000CAFC4000CAFB5001EA20B3B
    S31A00107C08001EA30A001EAC07001A3C02001EAB06001A7B0100F8
    S31A00107C1D3A7FC00002FB080002FC09000EA1BF000EA0AE0018D5
    S31A00107C32AC3E000EABFF001EA20B001EA30A001AAE02001AAD5E
    S31A00107C4701003A7FB9001EAE09001EAD08000C1DBF0032E0E716
    S31A00107C5C000C1ECF0030E0D0000E05FF0032E0E3000E140000FB
    S31A00107C7130E0D0000EF57F0032E0D0000CB45F0036E0D000029D
    S31A00107C86F5000002F401001EAC0B001EAB0A001EAE07001EADA1
    S31A00107C9B06003AFAAB001EA00B001EA10A0018AF010002FF0678
    S31A00107CB00018AF020002FF070033E0CD000EAFFF0002FF060035
    S31A00107CC502FF07001EAC07001EAB060016AF0C00397FAC002394
    S31A00107CDAFFFF00397FAD0016AFFD0002FB000002FC01000EAFA1
    S31A00107CEFFE0002FF02000CAFDC000EABFF000EAEFF000EADBFE5
    S31A00107D04003A7FB9000CAFC4000CAFB5000EA1FE000EA0570041
    S31A00107D191EA201001EA300001AAC0100183C09001AAB000018BC
    S31A00107D2E7B08003A7FC0000C0B5F0032E0AF000C1C4F0031E06F
    S31A00107D43AC000EAFFF0002FF02001EAC02000EABFF0016AF035E
    S31A00107D5800397FAC0023FFFF00397FAD0016AFF6000CAFC400DC
    S31A00107D6D0CAFB5000EA1BF000EA0BD0018AF000002FF020018C0
    S31A00107D82AF010002FF03000EA1BF000EA0AE0018AC60000EAB7B
    S31A00107D97FF000EA1BD000EA0760018AF0C0002FF060018AF0D84
    S31A00107DAC0002FF07001EAE07001EAD06003A7FB90002FB04008D
    S31A00107DC102FC05000EA1BF000EA0AE0018AC61000EABFF001ECF
    S31A00107DD6AE07001EAD06003A7FB90002FB080002FC09003AC282
    S31A00107DEBD0000E1CFF0036E046001CAF00000EFF7F0032E03D72
    S31A00107E00001CAF00001CBF010036E03D001CAC01001E3C030037
    S31A00107E151CAB00001E7B02001E0B040032E075001E1C050034B9
    S31A00107E2AE06D001EAF03001ECF050002EF01001EAF02001EDF60
    S31A00107E3F040002EF000033E05F001EAC03001C3C01001EAB02C0
    S31A00107E54001C7B00001E0B040032E066001E1C050034E05F0015
    S31A00107E691EAF03001E3F050002EF01001EAF02001E7F04000258
    S31A00107E7EEF00001CAC01001CAB00001E0B080032E05A001E1C83
    S31A00107E93090034E055001EAF080002EF00001EAF090002EF01C4
    S31A00107EA8001CAF00000EFF7F0032E03D001CAF00001CBF010062
    S31A00107EBD36E03D001CAC01001E3C03001CAB00001E7B02003A85
    S31A00107ED27FC0001E0B040032E047001E1C050030E03D000EAF77
    S31A00107EE7BF0002FF00000EAFBD0002FF01000EACFC000EABFFC6
    S31A00107EFC000CAF5D000CAF4E003AFDBB0016AF0A00397FAC0015
    S31A00107F1123FFFF00397FAD0016AFFE000CAFC4000CAFB5001CF1
    S31A00107F26AC25001CAB24000EA1FF000EA01C0018AE070018AD6A
    S31A00107F3B06001CAF260002FF00001CAF270002FF01003AC4F23F
    S31A00107F500002EB190002EC1A0016AF0200397FAC0023FFFF00AC
    S31A00107F65397FAD0016AFFF000CAFC4000CAFB5003ADFCD000EE5
    S31A00107F7AABFF000EAC1C000EAD7F003A7FA4000EABFE000EAC54
    S31A00107F8F87000EADF9003A7FB2000CAF4E000ECEE6000D5F5D8D
    S31A00107FA4000EAFFD0002FF00000EABFE000EAC51003A7FE0009C
    S31A00107FB90EAFFF0002EF16000EAFFE0002EF18000EA1FF000E5A
    S31A00107FCEA01C0018AE07000ECEAB0018AD06000EDD0A000EA109
    S31A00107FE3BF000EA0AE000EABF500186B6C000CAFFC000C0DBF2C
    S31A00107FF80032DFFF000C1ECF0034DFFD003AEFA90000FFCA00AA
    S31A0010800D16AF0100397FAC0023FFFF000EA1FF000EA01C00186D
    S31A00108022AB01000E2BFE000E1BFF0036DFD5000EA3BF000EA21E
    S31A00108037AE0018AE090018AD08001A0D1F0032DFEC001A1E2039
    S31A0010804C0034DFE6001A0D1D0032DFE8001A1E1E0031DFE60087
    S31A001080610EABFF000EA1FF000EA01C0018AE07000ECEAB001858
    S31A00108076AD06000EDD0A000EA1BF000EA0AE00180D210032DF16
    S31A0010808BDB00181E220030DFD600180D230032DFD700181E2428
    S31A001080A00031DFD5000EABFF000CAFBC000EABFF0023FFFF00C8
    S31A001080B50EA1FE000EA057000EAF000002CF020023FFFF003904
    S31A001080CA7FAD0016AFF20002FB000002FC01000EA1BE000EA091
    S31A001080DF370018AB02000E2BFD000E1BFF0036DF36001EAC0106
    S31A001080F4001EAB00003ADF2C000CAFC4000CAFB5000CB45F0045
    S31A0010810932DFBA000EA4FE000EA5FF001EA001001EA100001888
    S31A0010811EAB21000E2B7F000E1BFF0036DFAF000EA1FE000EA06B
    S31A00108133870002C52E0002C42F0033DF36003ADE86003AC1616E
    S31A00108148000EA3FE000EA287001AAF2F0002FF09001AAF2E002D
    S31A0010815D02FF08000EAFFF0002FF060002FF07000CAF40000C1C
    S31A00108172AF51000EA8FF000EA9FF000CAF0F001ECF090002FFB6
    S31A0010818705000CAF1F001EDF080002FF04000CAF8F001EDF0796
    S31A0010819C0002FF03000CAF9F001EDF060002FF02001EAF020085
    S31A001081B11EBF03001EBF04001EBF050036DF36000CAFCE000C20
    S31A001081C6AFBD000CAFDC000E6CFE000CAFCB00037EFF00037D8D
    S31A001081DBFF00037CFF00037BFF000370FF000371FF000378FF20
    S31A001081F0000379FF00397FDA0016AF080002FB0A0002FC0B007A
    S31A0010820502FD0C0002FE0D001EA001001EA1000018AE1A0018C0
    S31A0010821AAD19000CAFDC000E6CFE000CAFCB00037EFF00037DDE
    S31A0010822FFF00037CFF00037BFF001EAF0D00037FFF001EAF0DF5
    S31A0010824400037FFF001EAF0D00037FFF001EAF0D00037FFF00D8
    S31A00108259397FDA0016AF08000CAFE0001EC00D000CAFD1001E6B
    S31A0010826ED10C000CAFC8001ED80B000CAFB9001ED90A001EAF42
    S31A001082830500037FFF001EAF0500037FFF001EAF0500037FFFA4
    S31A00108298001EAF0500037FFF000CAF9B000CAF8C000CAF1D00F3
    S31A001082AD0CAF0E00397FCB0016AF04001EA001001EA100000211
    S31A001082C2CD190002CE1A001AAC2F001AAB2E000CAF5D000CAF06
    S31A001082D74E00397FDB001EAF0500037FFF001EAF0500037FFFF5
    S31A001082EC001EAF0500037FFF001EAF0500037FFF00397FCB003E
    S31A0010830116AF040002DD2E0002DE2F000CBEDF0032DF36000E6E
    S31A00108316AFFF0002DF2E000EAFFE0002DF2F000EA1FE000EA059
    S31A0010832B87000EAFFF0002CF2A0002CF2B0002CF2C0002CF2DF2
    S31A001083400016AF0E00397FAC0023FFFF00397FAD0016AFF4009C
    S31A0010835502FB020002FC03000CAFC0000CAFB10018AB21000E24
    S31A0010836A2BC0000CAFBC000EABFF000CCCCC000CDBBB000CAFCD
    S31A0010837FC0000EC0AE000CAFB1000ED1BF0018AF300002FF078E
    S31A001083940018AF2F0002FF06000E2F7F0036DF15000EAF00001E
    S31A001083A902FF050002FF04000EA1FF000EA01C0018AC07000E4D
    S31A001083BECCA50018AB06000EDB0B000EA3BF000EA2AE001AAED0
    S31A001083D336001AAD35000EAFFC0002FF00000EAF170002FF01BD
    S31A001083E8003A7FBE003A7FC0000CAFCE000CAFBD000CAFDC00E2
    S31A001083FD0E6CFE000CAFCB001ECE070002FE07001EDD0600025A
    S31A00108412FD06001EDC050002FC05001EDB040002FB04001EA07E
    S31A0010842703001EA1020018AB21000E2BBF000E1BFF0036DEA2AC
    S31A0010843C000EA5FE000EA487001CAE29001CAD28000EACFF008E
    S31A001084510EABFF001CCE22001CDD21001CDC20001CDB1F000EE6
    S31A00108466AFFF00397FCD003A7FC30002FB080002FC090002FD31
    S31A0010847B0A0002FE0B001CAE22001CAD21001CAC20001CAB1F1D
    S31A00108490000EAFFF00397FCD003A7FC3001EAF0B00037FFF00AB
    S31A001084A51EAF0B00037FFF001EAF0B00037FFF001EAF0B00031F
    S31A001084BA7FFF000E8C7F00397FD40016AF04000CAFE0000CAF55
    S31A001084CFD1000CAFC8000CAFB9000EA3BF000EA2AE001AAD38ED
    S31A001084E4001AAC37000EAFFE00397FD2000370FF000371FF0046
    S31A001084F90378FF000379FF00397FD90016AF04000EAFFF00034A
    S31A0010850E7FFF000EAFFF00037FFF000EAFFF00037FFF000EAF8D
    S31A001085238800037FFF00397FD90016AF0400397FD1000CAFDBAB
    S31A00108538000CAFEC003A7FC0000CAFCE000CAFBD000CAFDC0060
    S31A0010854D0E6CFE000CAFCB001ECE070002FE07001EDD06000208
    S31A00108562FD06001EDC050002FC05001EDB040002FB04001EA02D
    S31A0010857703001EA1020018AE230018AD22000EACFF000EABFFD4
    S31A0010858C00037EFF00037DFF00037CFF00037BFF001EAF0B00F2
    S31A001085A1037FFF001EAF0B00037FFF001EAF0B00037FFF001E5E
    S31A001085B6AF0B00037FFF00397FDA0016AF080002FB040002FC01
    S31A001085CB050002FD060002FE07003ADE120016AF0C00397FAC15
    S31A001085E00023FFFF00397FAD0016AFF8000EA5FE000EA4870043
    S31A001085F51CAF2A0002FF00001CAF2B0002FF01001CAF2C000274
    S31A0010860AFF02001CAF2D0002FF03000EA1BF000EA0FF0018AC69
    S31A0010861F31000EABFF000CAFCE000CAFBD000CAFDC000E6CFE37
    S31A00108634000CAFCB00037EFF00037DFF00037CFF00037BFF009B
    S31A001086491EAF0700037FFF001EAF0700037FFF001EAF07000385
    S31A0010865E7FFF001EAF0700037FFF00397FDA0016AF08000EAF02
    S31A00108673FF00397FCD0018AF0300037FFF0018AF0200037FFFC3
    S31A001086880018AF0100037FFF0018AF0000037FFF00397FD900A5
    S31A0010869D16AF04000EAF0700037FFF000EAFCB00037FFF000E8D
    S31A001086B2AF9800037FFF000EAF7D00037FFF00397FD50016AFC8
    S31A001086C70400397FCE000EA1BF000EA0BD0018AF0000037FFFDD
    S31A001086DC0018A0010016A101000EA8FF000EA9FF000370FF0025
    S31A001086F10371FF000378FF000379FF00397FCB0016AF040002A8
    S31A00108706FB040002FC050002FD060002FE07001CAE2F001CAD78
    S31A0010871B2E000EACFF000EABFF000371FF000CAFB1000CAFCB2F
    S31A00108730000CAFDC000CAFED000EEDBF000CAFFE000EECBF00B3
    S31A001087450CBDFD000EEBBF000CBCFC000EE1BF000CBBFB001641
    S31A0010875AA101000EAFFF00397FCD003A7FC300397FCE001ECE23
    S31A0010876F070002FE03001EDD060002FD02001EDC050002FC01D5
    S31A00108784001EDB040002FB00001EAE03001EAD02001EAC010069
    S31A001087991EAB00003ADE120002EB2E0002EC2F0016AF08003984
    S31A001087AE7FAC0023FFFF00397FA9000CAFE0000CAFD1000CAF11
    S31A001087C3C8000CAFB9000E19FF0032DE06000E18FF0032DE06D8
    S31A001087D8000E11F80032DE06000E10000030DDF1000370FF00BB
    S31A001087ED0371FF000378FF000379FF000370FF000371FF000311
    S31A0010880278FF000379FF00397FDA0016AF08000EEEFB000EED08
    S31A00108817FB000CBEFE000EECFB000CBDFD000EEBFB000CBCFC00
    S31A0010882C000CAFDB000CAFEC0033DDEF000EAC00000EAB000072
    S31A00108841397FA80023FFFF00397FA9003AD84F003ADDE4000CC2
    S31A00108856AFCB003AD84B000E1CFD0036DDEC00397FA80023FF78
    S31A0010886BFF0004ABBF000EEBFD000CAFBC000EABFF000E8CFEB8
    S31A001088800023FFFF00397FAD0016AFFD000EAFFF0002FF0200C6
    S31A0010889504AF9C0036DDB3000EABFF000EACE0000EADDF003A7D
    S31A001088AA7FA4000EA04F000EA17F000EAFFF0002CF00000EAB0F
    S31A001088BFFE003AD9F5000EA5BE000EA437001CAC01000E2CFE2D
    S31A001088D4000EABF8000EADFE003AD91E001CAB00000E2BF800E6
    S31A001088E90EA04F000EA17F0002CB00000EABFF000EACE0000E0C
    S31A001088FEADDF003A7FA3003AFF18000EA06F000EA17F000EAF0E
    S31A00108913020002CF00000E2A010004ACB30004ABB4000EAFFEAC
    S31A001089280002FF000033DD9D003AD771003AD6BD000D9FCC00AF
    S31A0010893D0DCFBB0001BBB40001BCB3000EFADF000CAFFD0002F7
    S31A00108952FD01000E2A20000EFADF0032DDAA000EA1FE000EA0A9
    S31A00108967D800191F260002CF260002CB270002CC28001EAD0102
    S31A0010897C000CBADA000EAFFF0002FF00000EAEFE000EADFF00FF
    S31A001089913ADBA70004A0E40004A1E50018AB08000E2B7F000E5C
    S31A001089A61BFF0036DD8E000EA1FF000EA01C0018AF34000EBFAB
    S31A001089BBFB0002CF340033DD8C003AD7D5003ADC7D000EA1BE0F
    S31A001089D0000EA0370018AB03000E2BF7000E1BFF0036DD6900FD
    S31A001089E50EA3FF000EA21C001AAB01000E2BEF000E1BFF00369F
    S31A001089FADD69000EA06F000EA17F0018AB03000E2BFC000E1B9D
    S31A00108A0FFF0032DD69001AAC15001AAB14003A7FC0000EA1BE2B
    S31A00108A24000EA02C00180B020032DD7200181C030034DD6900F6
    S31A00108A3904ACB30004ABB400196D09000CAFDE000EADFF000E5C
    S31A00108A4EAFFE0002FF00003ADBA7000EA06F000EA17F0018AB85
    S31A00108A6303000E2BFC000E1BFF0032DD27000EA5FF000EA41CD2
    S31A00108A78001CAB00000E2BF3000E1BFF0032DD27001CAC1500A5
    S31A00108A8D1CAB14003A7FC0000EA1BE000EA02C00180B020032CC
    S31A00108AA2DD5500181C030030DD27000EA1FE000EA0A20018AC4B
    S31A00108AB7030018AB02003A7FC0000EA1BE000EA02C00180B02E7
    S31A00108ACC0032DD4A00181C030030DD27001CAB00000E2BEF00CC
    S31A00108AE10E1BFF0032DD27000EA1BE000EA0370018AB01000EE8
    S31A00108AF62BDF000E1BFF0036DD27000EABFF000EAC1B000EADA1
    S31A00108B0BEF003A7FA4000EA1BE000EA02C0018AF09000E1FFEB1
    S31A00108B200034DD3200051F9B0001BF9B000E1FFE0032DD2F0064
    S31A00108B350EAFFE0002FF020033DD1D000EA1BE000EA02C0004DF
    S31A00108B4AAF9B00181F090032DD1D000EAF000002FF020033DD7A
    S31A00108B5F1D000EA06F000EA17F000EAF030002CF03000EAF0032
    S31A00108B740002FF02000EABFF000EAC1B000EADEF003A7FA30040
    S31A00108B891EAF02000E1FFE0032DD180004AF9C0032DD13001E11
    S31A00108B9EAF02000E1F000032DD110004AF9C0032DD11000EAF82
    S31A00108BB3FF0002FF02001EAF02000E1FFE0032DCEA000EFADFBC
    S31A00108BC8000CAFFB0002FB010000FE9C000E2A20000EFADF00F5
    S31A00108BDD32DD0A000EA06F000EA17F000EAF020002CF00001861
    S31A00108BF2AB01000EBBFD0002CB01000EA09F000EA17F0018ABDA
    S31A00108C0700000EBBF80002CB00000EAF000002CF010018AB0062
    S31A00108C1C000EBBF80002CB00000EA0BF000EA17F000EAFFF0048
    S31A00108C3102CF00000EA24F000EA37F000EA1BE000EA0370018AE
    S31A00108C46AB00000E2BF80002DB000033DCBF001EAF02000E1F80
    S31A00108C5B000032DCBD000EFADF000CAFFB0002FB010000FF9CED
    S31A00108C700000FF9B000E2A20000EFADF0032DCE2000EA26F00F1
    S31A00108C850EA37F001AAB01000E2B020002DB01000EA09F000E5A
    S31A00108C9AA17F000EAF000002CF01000EAF080002DF00000EA0AC
    S31A00108CAF4F000EA17F000EAFFF0002CF00000EAF030002DF03EC
    S31A00108CC4000EA2BF000EA37F000EAFFC0002DF00000EA1FF009E
    S31A00108CD90EA01C0018AB00000E2BF7000E1BFF0032DCC2000EAD
    S31A00108CEEAFFD0002DF000004AFE0000E2F010001BFE0001EAB94
    S31A00108D0301000CBABA0004AFA30032DC850004AF9C000E1FFE61
    S31A00108D180032DC85000EFADF000CAFFB0002FB01000E2A2000AA
    S31A00108D2D0EFADF0032DCB5000EA1BE000EA02C0018AF0C003621
    S31A00108D42DCA80018AF0C00041FA40034DCA200051FA40001BFAE
    S31A00108D57A40033DC9F000EA1FF000EA01C0018AB01000E2BDF4B
    S31A00108D6C000E1BFF0036DC9F0004AFE0000EBFFE0001BFE00005
    S31A00108D810EA5FF000EA41C001CAC15001CAB14003A7FC0000E08
    S31A00108D96A1BE000EA02C0018AF0200037FFF0018A0030016A1BD
    S31A00108DAB01000C01BF0032DC91000C10CF0034DC87001CAC09DE
    S31A00108DC0001CAB08000EA1BE000EA02C00180B0A0032DC8900AE
    S31A00108DD5181C0B0031DC87003AFAC1001EAB01000CBABA00045D
    S31A00108DEAA0E40004A1E50018AF08000EBF7F0002CF080016AF97
    S31A00108DFF0300397FAC0023FFFF00397FAD003AD6ED000EA1FEB2
    S31A00108E14000EA0AB0018AE050018AD04000EABFF000EAC1600BE
    S31A00108E293AFB06003AD52F003AD5A2003AD756000EA1BE000E12
    S31A00108E3EA0370018AB04000E2BFE000E1BFF0036DC5A000EA1F1
    S31A00108E53FF000EA01C0018AC1F00043CA50018AB1E00047BA65D
    S31A00108E68003A7FC0000EA1BF000EA0AE00180B700032DC5F009C
    S31A00108E7D181C710034DC5A000EABFF000EAC11000EADEF003A54
    S31A00108E927FA4003AD630000EA02F000EA17F0018A500000E1C60
    S31A00108EA7FF0036DBB1000EA1FF000EA01C0018AB01000E2BBFAB
    S31A00108EBC000E1BFF0036DC260018AB3F000E2BFE000E1BFF00CA
    S31A00108ED136DC48000EB5FE0033DC47000E2501000EA1FF000E15
    S31A00108EE6A01C0018AB3F000E2BFD000E1BFF0036DC3F000EB531
    S31A00108EFBFD0033DC3E000E2502000EA1FF000EA01C0018AF3E50
    S31A00108F10000E1FFE0034DC340019BF3E0002CF3E000E1FFE0077
    S31A00108F2532DC34000E2503000EF5FC000CAFFB000E1BFF00329A
    S31A00108F3ADC2C000EABFF000EAC1B000EADBF003A7FA3000EA1F2
    S31A00108F4FFF000EA01C0018AB01000E2BBF000E1BFF0032DC2517
    S31A00108F64000E2503000EA1FF000EA01C00196B1B000E2BFE005E
    S31A00108F790CAFBE000EADFF000EACFF000EABFF000EA3BE000EAC
    S31A00108F8EA237001AA404000E247F000E14FF0036DC110018AB65
    S31A00108FA31B000E2BF7000D9FBB000EEBFD000CAFBC000E6BFE0D
    S31A00108FB8000CBBD9000CBCE8000EAEFF000EADFF001AAB040000
    S31A00108FCD0E2BBF000E1BFF0036DC020018AB0A000E2BFD000D35
    S31A00108FE29FBB000EEBFD000CAFBE000CAFED000E6DFE000CBDB1
    S31A00108FF799000CBE88000EAEFF000EADFF001AAB04000E2BDF0E
    S31A0010900C000E1BFF0036DBF30018AB0A000E2BF7000D9FBB00A9
    S31A001090210EEBFD000CAFBE000CAFED000E6DFE000CBD99000C26
    S31A00109036BE88000EAEFF000EADFF001AAB04000E2BEF000E1B3A
    S31A0010904BFF0036DBE30018AC0B000E2C7F000D9FFB000CBBCB46
    S31A00109060000EEBFD000CAFBE000CAFED000E6DFE000CBD9B00F1
    S31A001090750CBE8C000CBCBF0036DBDE000EB5FD0018AB1B000E58
    S31A0010908A2BFE000CAFB8000EA9FF000EAEFF000EADFF000E14D2
    S31A0010909FFF0036DBCF0018AB1B000E2BFB000D9FBB000EEBFD58
    S31A001090B4000CAFBE000CAFED000E6DFE000CBD9B000CBE8C003D
    S31A001090C90CBCBF0036DBCA000EB5FE000EA3FE000EA2A2000E4A
    S31A001090DEA1BD000EA0BB00199C0B0019CB0A001AAE03001AAD60
    S31A001090F302000C0DBF0032DBBF000C1ECF0030DBBD000E2502B6
    S31A00109108001AAC03001AAB0200180B0A0032DBB800181C0B007B
    S31A0010911D35DBB6000E2501000EABFF000EAC01000EAD7F003A46
    S31A001091327FA30033DBAC000EB5FC000EABFF000EAC01000EAD49
    S31A001091477F003A7FA4000EA02F000EA17F0002C50000397FACEB
    S31A0010915C0023FFFF00397FAD0016AFF00002FD040002FE0500A5
    S31A001091711EA414003AD679000EA1FE000EA0AB0002CB0200029D
    S31A00109186CC03000E14FF0032DB97000EA1FE000EA0A20002CB60
    S31A0010919B020002CC030004AE7C0004AD7D0004AC7E0004AB7F1E
    S31A001091B000397FD1000CAFDB000CAFEC003A7FC0000EA5BF00E3
    S31A001091C50EA4FF001CAE32000EADFF000C0BDF0032DB88000C81
    S31A001091DA1CEF0030DB310004AF7C00037FFF0004AF7D00037FC1
    S31A001091EFFF0004AF7E00037FFF0004AF7F00037FFF0004AEAC93
    S31A001092040004ADAD0004ACAE0004ABAF00397FD40016AF0400D0
    S31A0010921901BBAF0001BCAE0001BDAD0001BEAC0000FF7F000000
    S31A0010922EFF7E0000FF7D0000FF7C00051FAA0001BFAA00055F05
    S31A00109243AB0001BFAB0004ACAA0004ABAB001C1B330032DB6857
    S31A00109258001C1C340035DB19000EAFFF00037FFF000EAFFF005D
    S31A0010926D037FFF000EAFFF00037FFF000EAF7900037FFF00045D
    S31A00109282AEAC0004ADAD0004ACAE0004ABAF00397FD90016AFF7
    S31A0010929704000CAFE0000CAFD1000CAFC8000CAFB9001CAD348D
    S31A001092AC001CAC33000EAFFF00397FD200037EFF00037DFF0057
    S31A001092C1037CFF00037BFF000CAF9B000CAF8C000CAF1D000C06
    S31A001092D6AF0E00397FD50016AF0400397FD1000CAFDB000CAF80
    S31A001092EBEC003A7FC0001CAE31000EADFF000C0BDF0032DB3EFD
    S31A00109300000C1CEF0034DB340004AFAF0001BF7F0004AFAE00E6
    S31A0010931501BF7E0004AFAD0001BF7D0004AFAC0001BF7C003384
    S31A0010932ADB1F000000AB000000AA0033DB1D0004AFAC00037FBD
    S31A0010933FFF0004AFAD00037FFF0004AFAE00037FFF0004AFAFDF
    S31A0010935400037FFF0004AE7C0004AD7D0004AC7E0004AB7F00B5
    S31A00109369397FD40016AF040001BB7F0001BC7E0001BD7D0001D2
    S31A0010937EBE7C0000FFAB0000FFAA0000FFAF0000FFAE0000FFDD
    S31A00109393AD0000FFAC000EA1BF000EA0FF0018AF0700037FFFED
    S31A001093A80018AF0600037FFF0018AF0500037FFF0018AF040034
    S31A001093BD037FFF0004AE7C0004AD7D0004AC7E0004AB7F003913
    S31A001093D27FD90016AF040001BB7F0001BC7E0001BD7D0001BEDF
    S31A001093E77C001EAD05001EAC04000EAFFE00397FD20004AF7CCD
    S31A001093FC00037FFF0004AF7D00037FFF0004AF7E00037FFF0062
    S31A0010941104AF7F00037FFF00397FD90016AF040001BB7F0001E7
    S31A00109426BC7E0001BD7D0001BE7C000EA5FE000EA49C001CAFA1
    S31A0010943B000002FF06001CAF010002FF070002FB000002FC012F
    S31A001094500002FD020002FE03000CAF5B000CAF4C003A7FC20055
    S31A001094650EA1FE000EA0AB001CAF01001E3F070002CF060018B7
    S31A0010947AAC030018AB02003AD68C0004AF93000E1FFE0032DA3A
    S31A0010948FD90000FF980000FF970004AF900036DA70000EA1BF7B
    S31A001094A4000EA0AE0018A4730018A572000CB45F0032DACF00E9
    S31A001094B90EA4FE000EA5FF0004AF93000E1FFD0032DAC8003AA8
    S31A001094CEC1930001BB980001BC970000FF92000EA1BE000EA0CB
    S31A001094E3370018AB04000E2BF7000E1BFF0036DAC00000FE92A8
    S31A001094F80000FE91000EA1FF000EA01C0018A2230018A3220088
    S31A0010950D1813200032DAB8001812210036DAAB000EA3FE000E61
    S31A00109522A2AB001AAC06000CAFCB000E6BFE0018CC210018DB10
    S31A00109537200018AE230018AD22000C1DBF0032DAAA000C1ECF82
    S31A0010954C0032DAAA0000FE920004AD970004AC98000EAFFE0063
    S31A00109561397FD2000EAFFF00037FFF000EAFFF00037FFF000ECD
    S31A00109576AFFF00037FFF000EAF5E00037FFF00397FD90016AFA9
    S31A0010958B04000CAFE0000CAFD1000CAFC8000CAFB9000CAF5C7C
    S31A001095A0000CAF4D000EAFFF00397FD200037EFF00037DFF0053
    S31A001095B5037CFF00037BFF000CAF9B000CAF8C000CAF1D000C0F
    S31A001095CAAF0E00397FD50016AF040004AF920032DA16000EA34B
    S31A001095DFFE000EA287001AAF17000EFF7F0032DA16000EA1FFF0
    S31A001095F4000EA01C001AA818001AA9170018091C0032DA7C0009
    S31A0010960918181D0030DA160004AF7C00037FFF0004AF7D0003E6
    S31A0010961E7FFF0004AF7E00037FFF0004AF7F00037FFF00397F86
    S31A00109633D40016AF040033DA16000EA1FE000EA0AB0018AF027D
    S31A00109648000EFF7F0032DA680018AF020018BF030032DA3E000A
    S31A0010965D04AF93000E1FFD0032DA62003AC1B00001BB98000104
    S31A00109672BC970004AD970004AC98000EAFFE00397FD20002FBA8
    S31A00109687080002FC090002FD0A0002FE0B000EA1BE000EA03743
    S31A0010969C0018AD0A0018AC09000EAFFF00397FD200037EFF0041
    S31A001096B1037DFF00037CFF00037BFF001EAE0F001EAD0E001E42
    S31A001096C6AC0D001EAB0C00397FD50016AF04000EAFFF00037F57
    S31A001096DBFF000EAFFF00037FFF000EAFFF00037FFF000EAF7EB0
    S31A001096F000037FFF000E8C7F00397FD40016AF040033DA200033
    S31A0010970504AF93000E1FFD0032DA38003AC1D10001BB98000164
    S31A0010971ABC970004AD970004AC98000EAFFE00397FD20002FBFF
    S31A0010972F0C0002FC0D0002FD0E0002FE0F000EA1BE000EA0378A
    S31A001097440018AD0A0018AC09000EAFFF00397FD200037EFF0098
    S31A00109759037DFF00037CFF00037BFF001EAE13001EAD12001E91
    S31A0010976EAC11001EAB1000397FD50016AF040004AF7C00037F33
    S31A00109783FF0004AF7D00037FFF0004AF7E00037FFF0004AF7F27
    S31A0010979800037FFF00397FD90016AF040000FF93000EA5FE0088
    S31A001097AD0EA496000EAFC00002EF00000EAF000002EF0100022A
    S31A001097C2FB000002FC010002FD020002FE03000CAF5B000CAFAD
    S31A001097D74C003A7FC2001D1C01001CAB00000EDB3F0001BBBA01
    S31A001097EC0001BCB90004AF900036D9F8003A7FC00001BBBA00A3
    S31A0010980101BCB9000E0BFF0032D9FB000E1CFE0034D9F800007B
    S31A00109816FFBA0000FEB90016AF1000397FAC0023FFFF00397FA5
    S31A0010982BAD0016AFF90002FB01000EAFFF0002FF06000E2A208E
    S31A00109840000EFADF0032D9F0000EA0CF000EA17F0018AB0100AC
    S31A001098550EBBFB0002CB01000EBADF000EA1BE000EA037001845
    S31A0010986AAB03000E2BFB000E1BFF0032D9DF001EAF010036D902
    S31A0010987FD5000EA0BF000EA17F0018AB00000E2BFD000E1BFF2D
    S31A001098940032D9D5000EAFFD0002CF00000EAFFE0002FF06007C
    S31A001098A90EA4CF000EA57F001CAB01000EBBEF0002EB01000E65
    S31A001098BEABFC001EAF010036D9CC000EABDC003AF9A0003AF994
    S31A001098D39A0002FB020002FC030002FD040002FE05000E2A2070
    S31A001098E8000EFADF0032D9C6001CAB01000E2B040002EB0100AA
    S31A001098FD0EBADF001EAF060036D9B9000EA0BF000EA17F000E55
    S31A00109912AFFF0002CF00001CAB01000E2B100002EB0100059C0B
    S31A00109927950005CB96003AD679001EAF010032D9AC000EA1FE5F
    S31A0010993C000EA0AB0002CB070002CC080033D9A8000EA1FE009C
    S31A001099510EA0A20002CB020002CC03001EAE0500043E78001E52
    S31A00109966AD0400047D79001EAC0300047C7A001EAB0200047B1A
    S31A0010997B7B000ECE7F000D5FDD000D5FCC000D5FBB000CAFDEAA
    S31A00109990000CAFCD000CAFBC000E6BFE000CAFE2000CAFD3000B
    S31A001099A50EFD7F0036D992000EA2FF000EA3FF00041383003241
    S31A001099BAD98F000412820030D9740004AE840004AD85000EACDF
    S31A001099CFFF000EABFF000CAFDB000CAFEC000EAEFF000EADFF04
    S31A001099E40004A0820004A183000EA8FF000EA9FF000370FF002D
    S31A001099F90371FF000378FF000379FF00397FD60016AF04000C78
    S31A00109A0EAFDB000CAFEC000CAF3D000CAF2E003A7FC8000CAFDF
    S31A00109A23C4000CAFB50033D9690004AC800004AB81000CAF2E26
    S31A00109A3800043E82000CAF3D00047D83003A7FC8000CAFC40043
    S31A00109A4D04C484000CAFB50004D585000EABFE000EACAF000CA8
    S31A00109A62AF5D000CAF4E003A7FA6000EA1BF000EA0FF0018AC86
    S31A00109A770D000CAFCB000E6BFE000CCC44000CDB55000EA1FFB4
    S31A00109A8C000EA01C0018AF280018BF290036D92B000EAC7B0087
    S31A00109AA10EABFC0018AE290018AD28000E0DF10032D951000E93
    S31A00109AB61ECF0030D946000EACAD000EAB01000E0DF70032D90B
    S31A00109ACB4B000E1E020034D946000CAFEC000ECCAB000CAFDBE2
    S31A00109AE0000EDB0A000CAFC8000EC8F9000DFFB9000EA1BF00E3
    S31A00109AF50EA0FF0018AE2C000EADFF000CAF9B000CAF8C003917
    S31A00109B0A7FDD000EAFFB0002FF00000EABBF000EACDB003A7F55
    S31A00109B1FBC000EA1BF000EA0FF0018AF2E00037FFF0018AF2DDA
    S31A00109B3400037FFF000CAFCE000CAFBD00397FD80016AF02002D
    S31A00109B490C4E44000C5D55001EAF010032D925000EA1FE000EDC
    S31A00109B5EA0AB0002C5000002C401000EA1FE000EA0A20002C53F
    S31A00109B73000002C4010016AF0700397FAC0023FFFF00397FAD4A
    S31A00109B880016AFFB0002FB000002FC010002FD02000EAFFF0039
    S31A00109B9D02FF03000EAFFA0002FF04000E1CFF0036D8EB000EAD
    S31A00109BB21DFF0032D8FB000EABFA003AF9A0003AF99A000CAF59
    S31A00109BC7DE000CAFCD000CAFBC000E6BFE000CAFE4000CAFD5F0
    S31A00109BDC000434790004757A000CAF5B000CAF4C000EADFF00E3
    S31A00109BF13AF976000CAFC4000CAFB5000EABFE000EACF4000C40
    S31A00109C06AF5D000CAF4E003AFB06001EAF01000E1FFE0032D8E0
    S31A00109C1BF6000EAFBE0002FF04001EAF010036D8EB000E2A2089
    S31A00109C30000EFADF0032D8F4000EA0CF000EA17F0018AB0100B5
    S31A00109C450EBBF70002CB01000EBADF001EAF020036D8DF000EF5
    S31A00109C5AA0BF000EA17F0018AB00000E2BFD000E1BFF0032D827
    S31A00109C6FDF000EAFFD0002CF00000EAFFE0002FF03000EABCF19
    S31A00109C84003AF9A0000EABCF003AF9A4000EA0CF000EA17F00D8
    S31A00109C9918AB01000EBBEF0002CB01001EAF020036D8D1001E8A
    S31A00109CAEAF04000EBFDF0002FF04001EAB04003AF9A4001EAFB6
    S31A00109CC3020032D8CA001EAB00003AF9890033D8C9003AF99A7A
    S31A00109CD8000CAFDE000CAFCD000CAFBC000E6BFE000CAFE400B3
    S31A00109CED0CAFD5001EAF010036D8B8000E2A20000EFADF0032B7
    S31A00109D02D8C1000EA0CF000EA17F0018AB01000E2B080002CB20
    S31A00109D1701000EBADF001EAF030036D8B2000EA0BF000EA17F4E
    S31A00109D2C000EAFFF0002CF00000EA0CF000EA17F0018AB010010
    S31A00109D410E2B100002CB0100059C950005CB96003AD679001E9D
    S31A00109D56AF020036D8A0000EA1FE000EA0A200180B020032D857
    S31A00109D6BA300181C030034D8A00002CB020002CC0300043479F6
    S31A00109D800004757A000CAF5B000CAF4C001EAD01003AF9760033
    S31A00109D950CAFC4000CAFB5001EAF020032D88B000EA1FE000E95
    S31A00109DAAA0AB0002C5040002C405001EAF010032D88B000EAB91
    S31A00109DBFFE000EACF4000CAF5D000CAF4E003AFB06000EA1FEC4
    S31A00109DD4000EA0A20002C5040002C405001EAC010016AF0500E9
    S31A00109DE9397FAC0023FFFF00397FA90016AFFE0016AF02003AA5
    S31A00109DFEFE3F003AD7E9000EABEF003A7FE20001BB850001BCC2
    S31A00109E1384000EABEE003A7FE20001BB830001BC82000EABED3A
    S31A00109E28003A7FE20001BB810001BC80000EABC6003A7FE200E0
    S31A00109E3D0CAFCE000CAFBD0001BD9A0001BE99000CAFEF000E91
    S31A00109E52CFEF0002FF01000CAFDF000EDFD80002FF00000EAC0B
    S31A00109E6700000EAB80003A7FBE0001BB9A0001BC990000FFA3D2
    S31A00109E7C000EA0BF000EA17F000EAFFD0002CF000004AFA3003F
    S31A00109E910E1FFD0032D857003ADDED0033D85C003AD84F003A15
    S31A00109EA6DDE4000EABFF003AD84B0033D85C0016AF0200397FD5
    S31A00109EBBA80023FFFF00397FA9003ADDDE00397FA80023FFFFDC
    S31A00109ED000397FAD0016AFFE0002FB00000EA1FF000EA01C00CA
    S31A00109EE518A4150018A5140004ADA3000EA1BE000EA01F00180A
    S31A00109EFA05020032D83E001814030035D83B000EABFD0033D8B6
    S31A00109F0F32000EA1BE000EA01F00199C010019CB00000C05BF51
    S31A00109F240032D834000C14CF0030D82E000EAB01000EACFF003C
    S31A00109F393AD76B000CAFCD0033D827000EA1BE000EA01F001875
    S31A00109F4EAC09000EABFF0002FD01003AD76B001EAD01000E1D08
    S31A00109F63FF0036D7FA000E1D010032D81C000D9F44000DCF555A
    S31A00109F78000EA1BE000EA01F0018AC070018AB060033D81800CD
    S31A00109F8D0EA1BE000EA01F0018AC08000EABFF000EA1BE000E70
    S31A00109FA2A01F001805040032D813001814050034D80F0001BB8F
    S31A00109FB7B20001BCB10033D7FC001EAF000036D80B000EADFFB9
    S31A00109FCC0033D7FC0004ACB10004ABB2000E1BFF0032D806006A
    S31A00109FE10E1CFE0030D800000CAFDB000EEBFD000CCBDB000DDA
    S31A00109FF60FBD0033D7FC0005BFB10001BFB10005FFB20001BF12
    S31A0010A00BB2000E1DFF0032D7EF000EA1BE000EA0370018AB033E
    S31A0010A020000E2BDF000E1BFF0036D7EF0000FE900004AFA300F5
    S31A0010A03536D7EE0000FD930033D7EE0000FF900001BDA3000C81
    S31A0010A04AAFDC0016AF0200397FAC0023FFFF00397FAD000EA100
    S31A0010A05FBF000EA0FF0018AF080001BFA20018AF090001BFA108
    S31A0010A074000EA4BF000EA57F000EAFFD0002EF00003AD69600CD
    S31A0010A0890EAFFF0002EF00000EA06F000EA17F000EAF080002ED
    S31A0010A09ECF0000397FAC0023FFFF00397FAD0016AFFE000EA16C
    S31A0010A0B3FE000EA0AB0018A4030018A502000CAF5B000CAF4C90
    S31A0010A0C8003A7FC0000EA1BF000EA0FF0018AE30000EADFF0029
    S31A0010A0DD0C0BDF0032D7C5000C1CEF0031D7C2000EA4FF000EF4
    S31A0010A0F2A5FF0018AF2F0002FF01000EAFFF0002FF00000EAB31
    S31A0010A107FF000EAC8F000CAF5D000CAF4E003AFAAB000EABFF2D
    S31A0010A11C000EAC08000CAF5D000CAF4E003AFB06000EABFF0042
    S31A0010A1310EAC8F003A7FA0000CAFCE000CAFBD000EABFE000E9B
    S31A0010A146ACE4003AFB060016AF0200397FAC0023FFFF00397F1F
    S31A0010A15BA90016AFFC000CAFCD000CAFBC000EAFFE00397FD22B
    S31A0010A1700002FB000002FC010002FD020002FE03000EA3BF0054
    S31A0010A1850EA2FF001AAC0A000CAFCB000E6BFE0004CCA10004BE
    S31A0010A19ADBA2000CAFCD000CAFBC000EAFFE00397FD2000CAF1E
    S31A0010A1AFE0000CAFD1000CAFC8000CAFB9001AAD36001AAC352A
    S31A0010A1C4000EAFFE00397FD200037EFF00037DFF00037CFF00AE
    S31A0010A1D9037BFF000CAF9B000CAF8C000CAF1D000CAF0E003967
    S31A0010A1EE7FD50016AF04001EAF0300037FFF001EAF0300037F86
    S31A0010A203FF001EAF0300037FFF001EAF0300037FFF000E8C7F76
    S31A0010A21800397FD40016AF040016AF0400397FA80023FFFF007C
    S31A0010A22D01BB8A0001BC890023FFFF00397FA9000EABFF003A06
    S31A0010A242D9F5003AD6AF00397FA80023FFFF000E1B010036D7AC
    S31A0010A25767000E1BFD0032D7590004AFB0000E1FFE0034D75EF6
    S31A0010A26C0004AFA3000E1F010036D75E0004AFA3000E1FFD0058
    S31A0010A28132D75C000CAFBC0033D7570005BFB00001BFB000335E
    S31A0010A296D7580001BCB00004ACA30023FFFF00397FAD0016AF63
    S31A0010A2ABFE000EA5FF000EA41C001CAC0900043C9F001CAB088B
    S31A0010A2C000047BA0000EAFFD0002FF00000EAFFE0002FF0100DC
    S31A0010A2D50EADBF000EAEC8003AD724001CAC0700043C9D001C63
    S31A0010A2EAAB0600047B9E000EAFFE0002FF00000EAFFE0002FF03
    S31A0010A2FF01000EADBF000EAEC5003AD724001CAC15001CAB144B
    S31A0010A314000EAFFB0002FF00000EAF7E0002FF01000EADBF00AE
    S31A0010A3290EAEC2003AD7240004AB86000E2BFC000E1BFF00368E
    S31A0010A33ED7270004AB86000E2BFB000E1BFF0036D727000CAF76
    S31A0010A3535B000CAF4C000EADF7003A7FA40016AF0200397FAC43
    S31A0010A3680023FFFF00397FAD0016AFFF000CAFC8000CAFB90089
    S31A0010A37D0CAFE4000CAFD5003A7FC0000CAFC0000CAFB1000C1A
    S31A0010A392AF19000CAF08001EAB0500042B86000E1BFF0036D65E
    S31A0010A3A7FE000EACFF001CAE01001CAD00001EAB06000E2B7FB9
    S31A0010A3BC000C1BCF0036D709000C01DF0032D70B000C10EF005F
    S31A0010A3D134D7040033D705000C01DF0032D706000C10EF00310C
    S31A0010A3E6D704000EACFE000E1CFF0036D6F2001F8B0500042FB0
    S31A0010A3FB860001BF860033D6F2001EAF060002FF00000CAF9B46
    S31A0010A410000CAF8C000CAF5D000CAF4E003ACC74000CAFCE00B6
    S31A0010A4251EAB05000EACFF000EAD87003ACC8400051F6700012D
    S31A0010A43ABF670016AF0100397FAC0023FFFF00397FAD0016AF5C
    S31A0010A44FFE000EA5FE000EA4AB001CAE01001CAD00000EA1BFD4
    S31A0010A464000EA0FF0018AF2F0002FF01000EAFFF0002FF00006B
    S31A0010A4790EABFF000EAC8B003AFAAB001CAE01001CAD00000E3A
    S31A0010A48EABFF000EAC14003AFB06000EABFF000EAC8B003A7F3A
    S31A0010A4A3A0000CAFCE000CAFBD000EABFE000EACB4003A7FA669
    S31A0010A4B8001CAE08001CAD07000EABFE000EACE6003AFB060045
    S31A0010A4CD0EA1FF000EA01C0018AC150018AB14001CAE01001C55
    S31A0010A4E2AD00003AF9BB000CAFCE000CAFBD000EABFE000EAC42
    S31A0010A4F7DC003AFB060016AF0200397FAC0023FFFF00397FA976
    S31A0010A50C000E2A20000EFADF0032D6BC000EA06F000EA17F00D6
    S31A0010A52118AB01000EBBF70002CB01003AFF180004ACDA0004DE
    S31A0010A536ABDB00397FA80023FFFF00397FAD0016AFFA000EA51C
    S31A0010A54BBE000EA437001CAC01000E2CFE000EABF8000EADFFD2
    S31A0010A560003AD91E0001BCA9003AF99A0002FB000002FC010070
    S31A0010A57502FD020002FE03001CAF070002FF04001CAF0800020B
    S31A0010A58AFF05000EABFF000EAC7B003AFA920016AF0600397F6C
    S31A0010A59FAC0023FFFF00397FA9000EABF8003AF9A0003AF99A12
    S31A0010A5B40001BB7B0001BC7A0001BD790001BE7800397FA80040
    S31A0010A5C923FFFF000EADFF000EFB7F0032D686000CBCBF0036B9
    S31A0010A5DED686000EADFE00041DA80036D67B0004AFA30032D68F
    S31A0010A5F37C000EA1BE000EA0370018AB03000E2BDF000E1BFF69
    S31A0010A6080032D67B0000FD930001BDA80023FFFF00397FA9002C
    S31A0010A61D16AFFC000CAFCD000CAFBC000EAFFE00397FD200020B
    S31A0010A632FB000002FC010002FD020002FE03000EA3BF000EA2DF
    S31A0010A647FF001AAC0A000CAFCB000E6BFE0004CCA10004DBA22A
    S31A0010A65C000CAFCD000CAFBC000EAFFE00397FD2000CAFE000F4
    S31A0010A6710CAFD1000CAFC8000CAFB9001AAD36001AAC35000E35
    S31A0010A686AFFE00397FD200037EFF00037DFF00037CFF00037B77
    S31A0010A69BFF000CAF9B000CAF8C000CAF1D000CAF0E00397FD5CA
    S31A0010A6B00016AF04001EAF0300037FFF001EAF0300037FFF0014
    S31A0010A6C51EAF0300037FFF001EAF0300037FFF000E8C7F003976
    S31A0010A6DA7FD40016AF04000E8C7F0001BC7E0001BB7F0001BDEC
    S31A0010A6EF7D0001BE7C001AAF0300037FFF001AAF0200037FFFEF
    S31A0010A704001AAF0100037FFF001AAF0000037FFF0004AE7C0067
    S31A0010A71904AD7D0004AC7E0004AB7F00397FD90016AF04003AF7
    S31A0010A72E7FBF0016AF0400397FA80023FFFF00397FAD000EA461
    S31A0010A743FC003ACF8B000EFB7F0036D628000EACFF000EABFF2E
    S31A0010A7580033D5F2000EA5FF000EA0A9000EA17F0018AB0000E2
    S31A0010A76D041B770032D60E000EA0A8000EA17F0018AB000004CA
    S31A0010A7821B760032D60E000EA0A7000EA17F0018AB0000041BA0
    S31A0010A797750032D60E000EA1BD000EA0910004AC730004AB741B
    S31A0010A7AC00181B190032D60E00181C1A0032D60E000415A700FC
    S31A0010A7C132D5FD000EA5FE0001B5A7003AD5F0000E1CFF0036FD
    S31A0010A7D6D62B000EA0A9000EA17F0004AF770002CF00000EA029
    S31A0010A7EBA7000EA17F0004AF750002CF00000EA0A8000EA17FF1
    S31A0010A8000004AF760002CF00000E15FF0036D5F8000DBF4400FE
    S31A0010A8150E14000032D628000EACFF000EABFF000E15FF003201
    S31A0010A82AD5F2000EACFE000EABFF00397FAC0023FFFF00397F8F
    S31A0010A83FAD0016AFFE000EABDB003A7FE20001BC77000EA1BEAE
    S31A0010A854000EA0320018AF00000E1FC00034D5E3000EACFF00A0
    S31A0010A8690EABFF0033D5A50018AF000001BF75000EA1BE000EE8
    S31A0010A87EA0310018AB00000E1BF80030D5E6000EA3BD000EA2F1
    S31A0010A893A5000CAFBC000EABFF000CCCCC000CDBBB000CC2C0F2
    S31A0010A8A8000CD3B10018AC01001A3C110018AB00001A7B100061
    S31A0010A8BD1AAF120002FF00001AAF130002FF01000EAE17000ED5
    S31A0010A8D2ADFC003A7FBE000CAFC4000CAFB5000EABE8003A7FF2
    S31A0010A8E7E2000CAFCB000EECBF000EABFF000C44CC000C55BB35
    S31A0010A8FC000EFB7F0036D5BB000ECCBF000D5FBB0033D5B50066
    S31A0010A9110E0BFF0032D5B8000E1CC00034D5B5000ECC3F000D76
    S31A0010A926FFBB000E1BFF0032D5B2000E1CC00030D5E6000CAFDB
    S31A0010A93BCF000EEFFB000CAFFB0001BB76000EA1BD000EA09197
    S31A0010A9500018AF190001BF740018AF1A0001BF73000EACFE00FC
    S31A0010A9650EABFF0016AF0200397FAC0023FFFF00397FAD001648
    S31A0010A97AAFFC000EA5FE000EA4A2001CAE05000ECEAB001CADE3
    S31A0010A98F04000EDD0A000EAFBD0002FF00000EAFAF0002FF01BB
    S31A0010A9A4000EABFF0004AFA3000E1FFD0032D591000EABFE0001
    S31A0010A9B902FB02000EABF7000CAFDC000CAFED003AD52D001C2D
    S31A0010A9CEAE05000ECEAB001CAD04000EDD0A000EAFBD0002FFE7
    S31A0010A9E300000EAFAA0002FF01000EABFF0004AFA3000E1F01A4
    S31A0010A9F80032D57F000EABFE0002FB02000EABFB000CAFDC00AD
    S31A0010AA0D0CAFED003AD52D001CAE01001CAD00000EAFBD00022A
    S31A0010AA22FF00000EAFBB0002FF01000EAFFE0002FF02000EAB19
    S31A0010AA37FD000CAFDC000CAFED003AD52D001CAE01001CAD00E8
    S31A0010AA4C000EAFBD0002FF00000EAFB60002FF01000EAF7E00B4
    S31A0010AA6102FF02000EABFE000CAFDC000CAFED003AD52D001C79
    S31A0010AA76AE01001CAD00000EAFBD0002FF00000EAF510002FFB3
    S31A0010AA8B01000EAFFE0002FF02000EABDF000CAFDC000CAFED0A
    S31A0010AAA0003AD52D001CAE01001CAD00000EAFBD0002FF000040
    S31A0010AAB50EAF560002FF01000EAF7E0002FF02000EABEF000C6F
    S31A0010AACAAFDC000CAFED003AD52D000EFADF000CAFFB0002FB58
    S31A0010AADF03000E2A20000EFADF0032D547000EA1FF000EA0124E
    S31A0010AAF40004AC71000E2CCF0018AB00000E2B30000CBFCF0047
    S31A0010AB0902CF00000EA1FF000EA0010004AC71000E2CF0001890
    S31A0010AB1EAB00000E2B0F000CBFCF0002CF00001EAB03000CBA1C
    S31A0010AB33BA0016AF0400397FAC0023FFFF0000FF670023FFFF68
    S31A0010AB4800397FAB0016AFFF000CAFB5000CAFD8000CAFC90034
    S31A0010AB5D1EA005001EA104001EAC06000CAF5B00042B71000EB3
    S31A0010AB721BFF0036D5090018AE040018AD03000E2C7F000CAF84
    S31A0010AB87CB000E1BFF0036D515000EABFF000C09DF0032D517C6
    S31A0010AB9C000C18EF0035D50F0033D510000EABFF000C09DF009E
    S31A0010ABB132D511000C18EF0030D50F000EABFE000E1BFF003625
    S31A0010ABC6D4FE000D8F5B00042F710001BF710033D4FE0002FCC3
    S31A0010ABDB00000CAF9B000CAF8C000CAF1D000CAF0E003ACC7497
    S31A0010ABF0000CAFCE000CAF5B000EACFF000EAD72003ACC84002B
    S31A0010AC05051F670001BF670016AF0100397FAA0023FFFF0039F0
    S31A0010AC1A7FAB000CAFB5000EACFF0004AB69000E1BD90036D498
    S31A0010AC2FB4000E0BD90030D4E3000E0BE60030D4EA000E0BFB6C
    S31A0010AC440031D4CC000C0BCF0035D4950033D4D1000E1BDB00B4
    S31A0010AC5936D4B4000E0BDB0030D4C1000E0BE30035D49500338C
    S31A0010AC6ED4CC000E0BD00030D4DA000E0BD30031D4AF000E1B8B
    S31A0010AC83D80036D4C1000E0BD60030D4950033D4CC000E0BC1CE
    S31A0010AC980035D495000E0B9E0034D497000E0B880030D4950063
    S31A0010ACAD0E0B8B0035D4950033D4A40004AC69000EABFF000EB0
    S31A0010ACC2CC1D000EDBFF0033D49A000EA1FF000EA01C0018ABBA
    S31A0010ACD700000E2BDF000E1BFF0032D4950004AC69000EABFFA6
    S31A0010ACEC000ECC1D000EDBFF0033D49A000EA1BE000EA037006B
    S31A0010AD0118AB03000E2BFE000E1BFF0036D4B40004AB68000E1F
    S31A0010AD162B80003ACCF8000E1CFF0036D4B4003AFADC0000FF73
    S31A0010AD2BB80004AC69000EABFF000ECC1D000EDBFF0033D49AF4
    S31A0010AD40000EA1FF000EA01C0018AB00000E2BDF000E1BFF006D
    S31A0010AD5532D4950004AC69000EABFF000ECC1F000EDBFF003353
    S31A0010AD6AD49A000EA1FF000EA01C0018AB00000E2BDF000E1BD4
    S31A0010AD7FFF0032D4950004AC69000EABFF000ECC53000EDBFF29
    S31A0010AD94000CAF5D003AD37B0033D495000CAF5B003ACE3E00FC
    S31A0010ADA90E1CFF0036D48D0004AF69000EBF7F0001BF6800052A
    S31A0010ADBE1F690001BF690033D48C0000FE68000EABFF00397F50
    S31A0010ADD3AA0023FFFF00397FA9000EA1FF000EA01C0018AC00ED
    S31A0010ADE8000EECF7000E2CFE0004AB69000E0BAB0030D46400D3
    S31A0010ADFD0E0BBF0031D412000E0BCA0030D470000E0BCB0031D0
    S31A0010AE12D43A000E0BD60030D473000E0BFD0031D446000E0B27
    S31A0010AE27FF0035D3DA0033D44A000E0BD40034D4420033D43E52
    S31A0010AE3C000E0BC40030D469000E0BC50031D42E000E0BC800AF
    S31A0010AE5134D4360033D432000E1BC10036D415000E0BC100304C
    S31A0010AE66D4000033D42A000E0B8E0030D454000E0B910031D30F
    S31A0010AE7BEC000E0B9A0030D459000E0B9B0031D3F4000E0B9E4D
    S31A0010AE900034D40A0033D3F8000E0B980034D3F0000E1B920024
    S31A0010AEA536D4220033D3DA000E0B880030D44F000E0B8B0031AD
    S31A0010AEBAD4260033D3E8000E1B860036D3E4000E0B860030D347
    S31A0010AECFE00033D4190004AB69003AD208003ACD0D0033D3D63C
    S31A0010AEE4000EABFF000EAC1A000EADFD0033D3DD000EABBD00A6
    S31A0010AEF90EAC6E000EADD50033D3DD000EABFE000EACF2000E22
    S31A0010AF0EADD30033D3DD000EABFE000EAC87000EADCB0033D331
    S31A0010AF23DD000EABFE000EAC51000EADC90033D3DD000EABFE46
    S31A0010AF38000EACEA000EADC70033D3DD000EABBE000EAC37007D
    S31A0010AF4D0EADC50033D3DD000EABBD000EAC6A000EADC300332B
    S31A0010AF62D3DD000EABFE000EACDE000EAD8B0033D3DD000EA0EE
    S31A0010AF772F000EA17F0018AC01000E2CC00018AB00000EEBBF18
    S31A0010AF8C000CAFFB000CBCBC0033D3D6000EA02F000EA17F0079
    S31A0010AFA118AC030033D3D6000E1CFF0032D3DA0033D400000EC5
    S31A0010AFB61CFF0036D400000EA1FE000EA0D80018AF01000E1F23
    S31A0010AFCBFB0030D3DA0033D400000E1CFF0036D400000EA1FE9C
    S31A0010AFE0000EA0D80019BB01000E1BFC0030D3DA0004AF6900CD
    S31A0010AFF50E1F9E0036D3DA0004AC69000EABFF000CAFC0000E29
    S31A0010B00AC016000CAFB1000ED1FF0018AC000033D3D6000EABA2
    S31A0010B01FFE000EAC4D000EAD9D0033D3DD000EABFE000EAC74E1
    S31A0010B034000EAD9B0033D3DD000EABFE000EAC7A000EAD990079
    S31A0010B04933D3DD000EABFE000EACE8000EAD910033D3DD000E63
    S31A0010B05EABFE000EAC70000EAD8D0033D3DD000EA1FE000EA06E
    S31A0010B073D80018AC260033D3D6000EABFE000EACB1000EAD85B2
    S31A0010B088003ACD18003ACD0D0033D3D60000FE68000EAC00006E
    S31A0010B09D0EABFF0033D3D10004AF690001BF6800051F69000127
    S31A0010B0B2BF69000EABFF00397FA80023FFFF00397FAB000CAFF4
    S31A0010B0C7BC000EA1FF000EA01C0018AB00000EEBF7000E2BFE40
    S31A0010B0DC000E1C920036D3A0000E0C920030D3A0000E0CAB00D0
    S31A0010B0F130D3B9000E0CBF0031D3B1000E1CC10036D3B4000E34
    S31A0010B1060CC10030D3A0000E0CFF0035D39D0033D3A0000E0C30
    S31A0010B11B9E0034D3A9000E0C980030D39D0033D3A0000E1BFF9B
    S31A0010B1300032D39D0033D3A0000E1BFF0036D3A0000EA1FE002E
    S31A0010B1450EA0D80018AF01000E1FFB0030D39D0033D3A0000E15
    S31A0010B15A1BFF0036D3A0000EA1FE000EA0D80019BB01000E1BD6
    S31A0010B16FFC0030D39D000E1C9E0036D39D0001BC69000EA5FED4
    S31A0010B1840033D39C000EA5FF0004AB68000E2B80003ACCF8007E
    S31A0010B1990E1CFF0036D395000E15FF0032D3940000FE68000C97
    S31A0010B1AEAF5C000EABFF00397FAA0023FFFF00397FAB000EA11E
    S31A0010B1C3FF000EA01C0018A500000E2560000EABF9003A7F9F3E
    S31A0010B1D8000E1B000032D385000E1C000036D384000EB59F0080
    S31A0010B1ED0EA1FF000EA01C0002C500000EA1FE000EA0D8000EB7
    S31A0010B202AFFF0002CF0100397FAA0023FFFF00397FAD0016AFF4
    S31A0010B217FF000CAFC4000CAFB50002FD00003A7FF40004AB685B
    S31A0010B22C000E2B7F000E1BFF0036D35D0004AB68000E2B8000E1
    S31A0010B24101BB68003ACCF8000E1CFF0036D35D001EAB00000E5A
    S31A0010B256ACFF0004AE70000EADFF000CCECE000CDDBD0004AB49
    S31A0010B26B680032D35F000CAFDB000CAFEC003AD00F0033D35D33
    S31A0010B2800002ED000002EE01001EAF000001BF70000EACFE000E
    S31A0010B2950EABFF0016AF0100397FAC0023FFFF0016AFFC000EBC
    S31A0010B2AAA1FE000EA0D80018AB00000E1BBD0036D2A8000E0BE2
    S31A0010B2BFBD0030D327000E1BCE0036D2D9000E0BCE0030D33784
    S31A0010B2D4000E1BDD0036D2F5000E0BDD0030D341000E1BFD00EC
    S31A0010B2E936D303000E1BEF0036D2FC0033D239000E1BD800369D
    S31A0010B2FED2E7000E0BD80030D33A000E1BDB0036D2EE0033D23F
    S31A0010B31339000E1BCF0036D2E00033D239000E1BC50036D2C4FE
    S31A0010B328000E0BC50030D32E000E1BC70036D2D2000E1BC60032
    S31A0010B33D36D2CB0033D239000E1BC30036D2B6000E0BC3003519
    S31A0010B352D2BD000E1BBF0036D2AF0033D239000E1BAA0036D289
    S31A0010B36777000E0BAA0030D315000E1BAE0036D293000E0BAE30
    S31A0010B37C0030D31A000E1BBB0036D2A1000E1BAF0036D29A0082
    S31A0010B39133D239000E1BAC0036D285000E0BAC0030D27E003379
    S31A0010B3A6D28C000E1B950036D254000E0B950030D30A000E0B30
    S31A0010B3BBA70035D239000E0BA60034D269000E1B970036D25B2F
    S31A0010B3D00033D239000E1B930036D270000E0B930035D24D00E0
    S31A0010B3E50E1B8F0036D2460033D239000EAFBD0002FF00000E70
    S31A0010B3FAAFBB0002FF01000EA0E9000EA1FF0033D235000EAF80
    S31A0010B40FBD0002FF00000EAFA50002FF01000EA0EB000EA1FFA9
    S31A0010B4240033D235000EAFBE0002FF00000EAF5C0002FF01002C
    S31A0010B4390EA0F9000EA1FF0033D235000EAFBE0002FF00000ECF
    S31A0010B44EAF560002FF01000EA0F2000EA1FF0033D235000EAF87
    S31A0010B463BE0002FF00000EAF490002FF01000EA0ED000EA1FFAE
    S31A0010B4780033D235000EAFBD0002FF00000EAF760002FF0100BF
    S31A0010B48D0EA0E7000EA1FF0033D235000EAFBD0002FF00000E8E
    S31A0010B4A2AF5E0002FF01000EA0ED000EA1FF0033D235000EAF30
    S31A0010B4B7BD0002FF00000EAF900002FF01000EA0F3000EA1FF0E
    S31A0010B4CC0033D235000EAFBD0002FF00000EAF840002FF01005D
    S31A0010B4E10EA0F1000EA1FF0033D235000EAFBD0002FF00000E30
    S31A0010B4F6AF4C0002FF01000EA0BF000EA1FF0033D235000EAF1C
    S31A0010B50BBD0002FF00000EAFFB0002FF01000EA0F3000EA1FF4E
    S31A0010B5200033D235000EAFBD0002FF00000EAFEF0002FF01009D
    S31A0010B5350EA0FC000EA1FF0033D235000EAFBE0002FF00000ECF
    S31A0010B54AAF370002FF01000EA0F4000EA1FF0033D235000EAFA7
    S31A0010B55FBD0002FF00000EAFEC0002FF01000EA0FA000EA1FF02
    S31A0010B5740033D235000EAFBE0002FF00000EAF2C0002FF01000B
    S31A0010B5890EA0F2000EA1FF0033D235000EAFBF0002FF00000E84
    S31A0010B59EAFAE0002FF01000EA08B000EA1FF0033D235000EAF45
    S31A0010B5B3BE0002FF00000EAF1F0002FF01000EA0F3000EA1FF81
    S31A0010B5C80033D235000EAFBF0002FF00000EAFBD0002FF010025
    S31A0010B5DD0EA0F0000EA1FF0033D235000EAFBF0002FF00000E32
    S31A0010B5F2AF3A0002FF01000EA0AD000EA1FF0033D235000EAF43
    S31A0010B607BE0002FF00000EAFE80002FF01000EA0AF000EA1FFA7
    S31A0010B61C0033D235000EAFBE0002FF00000EAF980002FF0100F6
    S31A0010B6310EA0E1000EA1FF0033D235000EAFBE0002FF00000EED
    S31A0010B646AF7A0002FF01000EA0E1000EA1FF0033D2350018AE71
    S31A0010B65B00000EADFF000EEEBF00037FFF000EEDBF000CBFED5C
    S31A0010B6700016AE01000ECEFF0002FE01000EDDD20002FD000052
    S31A0010B6850EA0DF000EA1FF0033D235000EAFBF0002FF00000E9A
    S31A0010B69AAFFF0002FF01000EA0F1000EA1FF0033D235000EAF91
    S31A0010B6AFBF0002FF00000EAFF10002FF01000EA0DE000EA1FFC6
    S31A0010B6C40033D235000EAFBF0002FF00000EAFD00002FF010015
    S31A0010B6D90EA0EC000EA1FF0033D235000EA1FF000EA01C001834
    S31A0010B6EEAB00000E2BBF000E1BFF0032D239000EAFBE0002FFAD
    S31A0010B70300000EAF130002FF01000EA0E7000EA1FF0033D235CC
    S31A0010B718000EAFFF0002FF000002FF010033D210000EA3FE0083
    S31A0010B72D0EA2D8001AAE01000EADFF000EEEDF00037FFF000E7C
    S31A0010B742EDDF000CBFED0016AE01001ECE010002FE01001EDDAA
    S31A0010B757000002FD00000CAF0C000ECCE0000D5F1B000EECF7CF
    S31A0010B76C000EEBF7000CBCFC000CAFCD000DBFDB001A1B010099
    S31A0010B78134D21B000EAFDF0002FF030033D20E001A1D0100345D
    S31A0010B796D210000CAFDE000EADFF000DBFEE000DFFDD000EEEB4
    S31A0010B7ABDF000CAFFE000C4E0F0002FF030033D20E000EAFFF9F
    S31A0010B7C00002FF03001EAE03001EAD02001EAC01001EAB00002A
    S31A0010B7D516AF040023FFFF00397FA90004AB6F000E1BF8003689
    S31A0010B7EAD1C9000E0BF80030D1F2000E1BFD0036D1DA000E0B76
    S31A0010B7FFFD0030D1F9000E1BFF0036D1E2000E1BFE0036D1DD0C
    S31A0010B8140033D1B0000E1BFB0036D1D4000E0BFB0035D1D70065
    S31A0010B8290E1BFA0036D1CE0033D1B0000E0BF40030D1E9000E43
    S31A0010B83E0BF50031D1BB000E1BF70036D1C6000E1BF60036D10F
    S31A0010B853C10033D1B0000E1BF30036D1B8000E0BE50030D1B0CB
    S31A0010B868000E0BE80035D1B00033D1B3000EA1FF000EA01C00CF
    S31A0010B87D18AC010018AB000033D1AE000EACBD000EABF800330B
    S31A0010B892D1AE000EABEF003A7F9F0033D1AE0004ACD5000EAB1C
    S31A0010B8A7FF0033D1AE000EA08F000EA17F0018AB04000CAFBC1C
    S31A0010B8BC000EABFF0033D1AE000EA1BD000EA0910018AC0D007B
    S31A0010B8D10EABFF0033D1AE0004AC6E000EABFF0033D1AE000E4C
    S31A0010B8E6A1BF000EA03A0018AC010018AB000033D1AE000EA106
    S31A0010B8FBBF000EA0FF0018AC0A000CAFCB000E6BFE0033D1AE39
    S31A0010B9100004ACA10004ABA20033D1AE000EA1BD000EA091000D
    S31A0010B92518AC0C0018AB0B0033D1AE0004AC6B0004AB6C00333E
    S31A0010B93AD1AE000EACFF000EABFF00397FA80023FFFF00397FB9
    S31A0010B94FA9000E1BFF0032D1A8000E1CE50034D1A3000E1BFF72
    S31A0010B9640032D144000E1CDC0032D1440004AF6F0001BF6E00D4
    S31A0010B97901BC6F000E0CEB0030D191000E0CEC0031D183000E47
    S31A0010B98E1CFA0036D141000E0CFA0034D141000E0CF80035D1BE
    S31A0010B9A341000E0CF30034D141000E1CEF0036D1830033D141FD
    S31A0010B9B8000E1CE60036D169000E0CE60030D188000E1CE80049
    S31A0010B9CD36D175000E1CE70036D1810033D141000E1CE50036B0
    S31A0010B9E2D153000E1CDC0036D14F0033D141003AD13F0033D127
    S31A0010B9F741003ACF6A0001BB6C0001BC6B000EFB800001BF6C6C
    S31A0010BA0C0001BC6B000EA1BD000EA0910018AB13000E2B8000AD
    S31A0010BA2118AC140033D15E003ACF0E0001BB6C0001BC6B000E4B
    S31A0010BA36FB800001BF6C0001BC6B000EA1BD000EA0910018ABA8
    S31A0010BA4B15000E2B800018AC160033D15E003ACED50001BB6CC1
    S31A0010BA600001BC6B000EFB800001BF6C0001BC6B000EA1BD004A
    S31A0010BA750EA0910018AB17000E2B800018AC180004AE6B0004D7
    S31A0010BA8AAD6C000C1DBF0032D158000C1ECF0036D141000CAF39
    S31A0010BA9FDF000EBF7F0001BF6C0001BE6B0033D141003ACF8B22
    S31A0010BAB40001BB6C0001BC6B0033D141000EA1FF000EA01C005A
    S31A0010BAC918AF1E0001BFA60018AF1F0001BFA5000EABFF000EF6
    S31A0010BADEAC11000EADEF003A7FA30033D1410004AF6D0032D112
    S31A0010BAF3410000FBC000397FA80023FFFF00397FAD0016AFF78A
    S31A0010BB08000CAFC4000CAFB5000E15FF0032D138000E140000A4
    S31A0010BB1D30D014000CAF4B000CAFBC000EABFF000E1BFF00325A
    S31A0010BB32D130000E1CDF0036D0B7000E0BFF0032D12D000E1CAF
    S31A0010BB47DF0030D105000E1BFF0032D128000E1CEF0036D0C1BB
    S31A0010BB5C000E0BFF0032D125000E1CEF0030D112000E1BFF002A
    S31A0010BB7132D120000E1CF50036D0D1000E0BFF0032D11D000E4A
    S31A0010BB861CF50030D117000E1BFF0032D118000E1CF60036D002
    S31A0010BB9BD60033D014000E1BFF0032D113000E1CF40036D0CB65
    S31A0010BBB00033D014000E1BFF0032D10E000E1CEB0036D0B90046
    S31A0010BBC50E0BFF0032D10B000E1CEB0030D014000E1BFF0032AC
    S31A0010BBDAD106000E1CEC0036D0BB0033D014000E1BFF0032D150
    S31A0010BBEF01000E1CBF0036D05F000E0BFF0032D0FE000E1CBFDB
    S31A0010BC040030D0EC000E1BFF0032D0F9000E1CDD0036D07E007B
    S31A0010BC190E0BFF0032D0F6000E1CDD0035D09F000E1BFF0032EB
    S31A0010BC2ED0F1000E1CDB0036D043000E1BFF0032D0ED000E1C9B
    S31A0010BC43D20036D05F0033D014000E1BFF0032D0E8000E1C7FCD
    S31A0010BC580036D06E000E0BFF0032D0E5000E1C7F0030D0DF00C6
    S31A0010BC6D0E1BFF0032D0E0000E1CBE0036D0190033D014000E76
    S31A0010BC821BFF0032D0DB000E1C7E0036D05F000E1BFF0032D069
    S31A0010BC97D7000E1C7D0036D0570033D014000EA1FF000EA01C18
    S31A0010BCAC0018AF00000EBFFB0002CF00000EA1FF000EA01C0095
    S31A0010BCC118AF00000EBFF70002CF000033D014000EAFBF000267
    S31A0010BCD6FF00000EAFF70002FF01000EACFD000EABFF000EAD64
    S31A0010BCEBFF000EAEA2003AFDBB0033D014000EA1FF000EA01C50
    S31A0010BD000018AF01000EBFDF0002CF010033D014003AFAC100C6
    S31A0010BD1533D014003AFAB60033D014000EABF9003A7F9F0002DF
    S31A0010BD2AFB020002FC03000E1B000032D0A1000E1C000032D0F8
    S31A0010BD3FA1000EAFF80002FF02000EAFBD0002FF03000CAF6FD8
    S31A0010BD54000ECFFD0002FF01000D5F7F0002FF00000EACFF0043
    S31A0010BD690EABFF000EADF9000EAEFE003A7FEF003AD390003311
    S31A0010BD7ED017000EA1BD000EA0910018A515000E25800018A4C7
    S31A0010BD9316003ACF0E000E2B80000C15BF0032D017000C14CFB7
    S31A0010BDA80032D017000EA1BF000EA0BD0018AB02000E2BFB0085
    S31A0010BDBD0E1BFF0032D0800018AF020002FF04000EBFFB000219
    S31A0010BDD2FF04000CAF6E000ECEFB000D5F7D000EAFBF0002FFDD
    S31A0010BDE700000EAFBB0002FF01000EACFE000EABFF003AFDBB55
    S31A0010BDFC0000EEDF0033D017003A7FE90002FB050002FC06008D
    S31A0010BE1102FD070002FE08000CAF6E000ECEFA000D5F7D000E02
    S31A0010BE26AFBD0002FF00000EAF820002FF01000EACFB000EABD5
    S31A0010BE3BFF003AFDBB0033D017000EA0BF000EA17F000EAFFD7C
    S31A0010BE500002CF00000EABFF000EAC1C000EADEF003A7FA30062
    S31A0010BE650EA1BF000EA0FF0018AF080001BFA20018AF09000195
    S31A0010BE7ABFA10033D017000EA0BF000EA17F000EAFFD0002CFFD
    S31A0010BE8F00000EABFF000EAC1C000EADEF0033D04A000EA3FF53
    S31A0010BEA4000EA21C001AAB00000E2BEF000E1BFF0036D0170075
    S31A0010BEB90EA0BF000EA17F000EAFFC0002CF00000CAF3B000C37
    S31A0010BECEAF2C000EADF7003A7FA4000EA1FE000EA0D8000EAF6F
    S31A0010BEE3FF0002CF260001B46F0033D017000EA1FF000EA01C88
    S31A0010BEF80018AB01000E2BFE000E1BFF0032D0170018AB3F00E1
    S31A0010BF0D0EEBFB000CAFB8000EA9FF00196B3F000E2BFE000CE6
    S31A0010BF22AFBE000EADFF0018AB3F000E2BFE000CAFBC000EAB64
    S31A0010BF37FF000CCCEE000CDBDD0018AB3F000EEBBF000E2BFE65
    S31A0010BF4C000CAFBC000EABFF000CCCEE000CDBDD000C19DF000D
    S31A0010BF6132D01C000C18EF0032D01C000CCCCC000CDBBB000D13
    S31A0010BF761FCF0002CF3E0018AF01000EBFBF0002CF010033D07A
    S31A0010BF8B17000EAF000002CF3E0033D017003ACCC20033FFFF95
    S31A0010BFA0000EACFE000EABFF0033D012000EACFF000EABFF0080
    S31A0010BFB516AF0900397FAC0023FFFF00397FAD0016AFF8000CE0
    S31A0010BFCAAFC4000CAFB5000EA1FF000EA01C0018AF000002FF29
    S31A0010BFDF05000EA1BD000EA076000EA3FF000EA21C0018AB085B
    S31A0010BFF4001A8B100018AC09001A8C11000E8BCA0002FB010088
    S31A0010C0090E8C310002FC020018AB08001A8B100018AC09001ADA
    S31A0010C01E8C11000D1F6F0002FF07000D5F7F0002FF06001EA007
    S31A0010C03307001EA106000E8B590002CB02000E8C0D0002CC03DD
    S31A0010C048000EAFFE0002FF00000CAF5B000CAF4C000EADBE007B
    S31A0010C05D0EAE13003ACFA6000E1CFF0036CFDE000EA3FF000E70
    S31A0010C072A21C001EAF05000E2F200002DF000033CFA9000EAF6D
    S31A0010C087FB0002FF00000CAF5B000CAF4C001EAE07001EAD06D1
    S31A0010C09C003ACFA6000E1CFF0036CFCF000EA1FF000EA01C0055
    S31A0010C0B11EAF05000E2F600002CF000033CFA9001EAB05000E9D
    S31A0010C0C62BDF000E1BFF0032CFAC000EAFFD0002FF00000CAFFA
    S31A0010C0DB5B000CAF4C000EADBE000EAE0F003ACFA6000E1CFFBC
    S31A0010C0F00036CFBC000EA3FF000EA21C001EAF05000E2F600079
    S31A0010C10502DF000033CFA9000E15F00032CFB1000E14FF00326B
    S31A0010C11ACFB1001EAB05000E2BBF000E1BFF0032CFB1003ACCD4
    S31A0010C12FC2003A7FFB0033CFA9000CAF5B000CAF4C003AD13F5D
    S31A0010C144000E1CFF0032CFA9000CAF5B000CAF4C003AD1AC0029
    S31A0010C15916AF0800397FAC0023FFFF000CAFE0000CAFD1001E24
    S31A0010C16EAE00000EADFF00041DC00036CF9E0001BD6D0033CF8D
    S31A0010C1838E0004AF6D0032CF9600181B020032CF9600181C0349
    S31A0010C1980032CF960001BE6D0033CF8E00041E6D0032CF8E000B
    S31A0010C1AD181B000032CF8F00181C010032CF8F000EADFE000026
    S31A0010C1C2FF6D000CAFDC000EABFF0023FFFF0016AFFF000EFAAA
    S31A0010C1D7DF000CAFFB0002FB00000E2A20000EFADF0032CF87E4
    S31A0010C1EC000EA1BE000EA0320018AE00000EADFF000EA1BE00EE
    S31A0010C2010EA0310018AC00000EABFF000CCCEE000CDBDD000E1F
    S31A0010C216A1BD000EA0910018AB19000E2B800018AC1A000C1DC4
    S31A0010C22BBF0032CF71000C1ECF0036CF70000EBD7F001EAB0036
    S31A0010C240000CBABA000CAFDB000CAFEC0016AF010023FFFF002F
    S31A0010C255397FA90016AFFD000EAEFF000EADFF000EA0FF000E6B
    S31A0010C26AA1BF000EFADF000CAFFB0002FB02000E2A20000EFA4D
    S31A0010C27FDF0032CF61000EA880000EA9FC0010AC01000EABFFF5
    S31A0010C294000CCCEE000CDBDD000DBF88000DFF99000EF97F0076
    S31A0010C2A936CF5C0002FD000002FE01000EABBD000EAC4C000E7F
    S31A0010C2BEAEBF000EADFF003ACE69000CAFCE000CAFBD0002FDBD
    S31A0010C2D3000002FE01000EABBF000EACFF000EAEF1000EADFFA7
    S31A0010C2E8003ACE69000CAFCE000CAFBD0002FD000002FE0100B9
    S31A0010C2FD0EABBD000EAC90000EAEFD000EADFF003ACE69000C66
    S31A0010C312AFCE000CAFBD0002FD000002FE01000EABBD000EACDB
    S31A0010C3278E000EAEFD000EADFF003ACE69000CAFCE000CAFBD78
    S31A0010C33C0002FD000002FE01000EABBD000EAC84000EAEFE0068
    S31A0010C3510EADFF003ACE69000CAFCE000CAFBD0002FD00000294
    S31A0010C366FE01000EABBD000EAC83000EAEFE000EADFF003ACE7E
    S31A0010C37B69000CAFCE000CAFBD0002FD000002FE01000EABBDB7
    S31A0010C390000EAC7E000EAEFD000EADFF003ACE69000CAFCE00DD
    S31A0010C3A50CAFBD001EAB02000CBABA000CAFDB000CAFEC001657
    S31A0010C3BAAF0300397FA80023FFFF0016AFFF000EA2FF000EA301
    S31A0010C3CFFF000EFADF000CAFFB0002FB00000E2A20000EFADF6B
    S31A0010C3E40032CF08000EA1BF000EA03A000CAF3D000CAF2E00EE
    S31A0010C3F910AC01000EABFF000CCC22000CDB33000D1FEE000D69
    S31A0010C40E5FDD000E1DFF0032CEF8000E1E220034CF01000EA1A4
    S31A0010C423BF000EA091000EAEFF000EADFF0010AC01000EABFF06
    S31A0010C438000CCC22000CDB33000D1FEE000D5FDD000E1DFF0038
    S31A0010C44D32CEEA000E1EFE0034CEF3000EA1BF000EA08F000E02
    S31A0010C462AEFF000EADFF0010AC01000EABFF000CCC22000CDBF2
    S31A0010C47733000D1FEE000D5FDD000E1DFF0032CEDC000E1EFED4
    S31A0010C48C0034CEE5001EAB00000CBABA000CAF3B000CAF2C0078
    S31A0010C4A116AF010023FFFF00397FA90016AFFD000EFADF000C73
    S31A0010C4B6AFFB0002FB02000E2A20000EFADF0032CED0003ACF9A
    S31A0010C4CB6A000CAFCE000CAFBD0002FD000002FE01000EABBF63
    S31A0010C4E0000EACBD000EAEFD000EADFF003ACE69000CAFCE004D
    S31A0010C4F50CAFBD0002FD000002FE01000EABBF000EACBB000EA9
    S31A0010C50AAEFE000EADFF003ACE69000CAFCE000CAFBD0002FD2F
    S31A0010C51F000002FE01000EABBF000EACBA000EAEFD000EADFF91
    S31A0010C534003ACE69000CAFCE000CAFBD0002FD000002FE01006A
    S31A0010C5490EABBF000EACB8000EAEFD000EADFF003ACE69000CED
    S31A0010C55EAFCE000CAFBD0002FD000002FE01000EABBF000EAC8B
    S31A0010C573B6000EAEFD000EADFF003ACE69000CAFCE000CAFBD02
    S31A0010C5880002FD000002FE01000EABBF000EACB4000EAEFD00E9
    S31A0010C59D0EADFF003ACE69000CAFCE000CAFBD0002FD00000246
    S31A0010C5B2FE01000EABBD000EACFB000EAEF0000EADFF003ACEC6
    S31A0010C5C769000CAFCE000CAFBD0002FD000002FE01000EABBC6A
    S31A0010C5DC000EACFF000EAE7F000EADFF003ACE69000CAFCE008C
    S31A0010C5F10CAFBD0002FD000002FE01000EABBD000EAC7A000EEF
    S31A0010C606AEFD000EADFF003ACE69000CAFCE000CAFBD0002FD33
    S31A0010C61B000002FE01000EABBD000EAC6E000EAEFD000EADFFE2
    S31A0010C630003ACE69000CAFCE000CAFBD001EAB02000CBABA0022
    S31A0010C6450CAFDB000CAFEC0016AF0300397FA80023FFFF000C38
    S31A0010C65AAFC0000CAFB1001EA201001EA300000CBEDF0036CEAB
    S31A0010C66F5B000DBFEE000DFFDD0010AC01000EABFF000C4C22B3
    S31A0010C684000C5B33000CBEDF0032CE63000CAF3B000CAF2C0008
    S31A0010C69923FFFF00397FA90016AFFE0016AF010000FE68003ACB
    S31A0010C6AED390003A7FF9000EA0EF000EA17F000EAF550002CF9E
    S31A0010C6C3060004AFFF000EBFFE0001BFFF000EAFD40002FF0078
    S31A0010C6D8000EAFF90002FF01000EABD3000EACCF000EADD400DB
    S31A0010C6ED0EAE89003A7FFA0033CE4B0016AF0200397FA8002394
    S31A0010C702FFFF00397FAD0016AFF70002FB06000EAFFE0002FF2E
    S31A0010C71707000EA1FF000EA01C0018A100000EE1F70002F108DE
    S31A0010C72C000EF1FE0002FF080004AB69000E1BAB0036CDC1002C
    S31A0010C7410E0BAB0030CE26000E0BBF0031CDC9000E1BC1003626
    S31A0010C756CE20000E1BC00036CE1D0033CD26000E0BA00034CDE0
    S31A0010C76B94000E1B9F0036CD8C000E1B9E0032CD26001EAF08F7
    S31A0010C7800036CD260033CD72003A7FF4000EA5FE000EA4D8000B
    S31A0010C7951EAF060002EF01000EABFE000EACD6000EADDF003A99
    S31A0010C7AA7FB2001EAF080032CE0F001CAF23000E1FFE0032CD37
    S31A0010C7BFF0001CAB01000E0BFE0035CDF6000E0BFC0034CE076A
    S31A0010C7D4000E1BFB0036CDFD0033CDF6001DBB01000EEBDF006F
    S31A0010C7E90CAFFC000ECC4C0002FC03000EDBBD0002FB02000E94
    S31A0010C7FEAFDF0002FF050033CDD6000EAFBD0002FF02000EAF6C
    S31A0010C813FB0002FF03000EAFF30002FF050033CDD6000EAFFFB3
    S31A0010C8280002FF020002FF03000EAFFF0002FF050033CDD60046
    S31A0010C83D1CAF230032CDE8003AD3560002FB020002FC03000296
    S31A0010C852FD040002FE050033CDD6001CAF23000E1FFD0032CDC8
    S31A0010C867DE000EABFE000EACD6003ACC98000EABF7003ACCEE3F
    S31A0010C87C0002EC220033CD1D001CAF010002FF02001CAF0000CA
    S31A0010C89102FF03001CAB23000E2BE0000D1FBF0002FF05001E66
    S31A0010C8A6AE03001EAD02001EAF050002FF00000EABFE000EACA5
    S31A0010C8BBD6003A7FE0000EABDF003ACCEE000EA1FE000EA0D824
    S31A0010C8D00002CC220033CD1D001EAF080036CD26000EA1FE0085
    S31A0010C8E50EA0D80018AF01000E1FFB0034CD260033CD72001EFB
    S31A0010C8FAAF080032CDBA000EA1FE000EA0D80018AF23000E1F59
    S31A0010C90FFE0032CD26000EA1FE000EA0D80018AF010032CD26BA
    S31A0010C924000EABEB003ACCEE001E1C060032CD72000EA5BE002E
    S31A0010C9390EA40B003A7FF4000EABFE000EACD6000EADEB003A42
    S31A0010C94ECCE2000CAF5B000CAF4C000EADEF003ACCA5000E1C74
    S31A0010C963FF0036CDA3000EA4FF000EA5FF000CAF5B000CAF4C84
    S31A0010C978000EADFE000EAED6003A7FDF000CAF5B000CAF4C0094
    S31A0010C98D0EADFE000EAED6003A7FDF000EABFE000EACD6000E47
    S31A0010C9A2ADEB003ACCE20033CD1D001EAF080036CD26000EA120
    S31A0010C9B7FE000EA0D80019BB01000E1BFC0034CD260033CD723E
    S31A0010C9CC000EABDF003ACCEE001E1C060032CD72001EAF08002E
    S31A0010C9E132CD81000EA5FE000EA4D8001CAF23000E1FFE003225
    S31A0010C9F6CD48000EA1FE000EA0D80018AB01000E0BFC0030CDF8
    S31A0010CA0B77000E0BFD0031CD6F000E1BFE0036CD740033CD72F6
    S31A0010CA20000E1BFB0036CD5D0033CD72001EAF080036CD6F00AE
    S31A0010CA350EAFFF0002FF070033CD1D000EA1FE000EA0D80019A9
    S31A0010CA4ABB01000EEBDF000CAFFC000ECC4C0002FC03000EDB66
    S31A0010CA5FBD0002FB02000CAF64000EC4FD000D5F75000EAFDF85
    S31A0010CA740002EF03003A7FF4001CAC03000EABFF0033CD3E0035
    S31A0010CA890EAFBD0002FF02000EAFFB0002FF03000CAF64000E1C
    S31A0010CA9EC4FD000D5F75000EAFF30002EF03003A7FF4001CACB2
    S31A0010CAB303000EABFF001EAF020002FF00001EAF030002FF01FB
    S31A0010CAC8000EADFE000EAED6003AFDBB003AEF2C0033CD1D0094
    S31A0010CADD1CAF230032CD36003AD3560002FB020002FC030002A6
    S31A0010CAF2FD040002FE05003A7FF4001EAC05000EABFF001EAF12
    S31A0010CB07020002FF00001EAF030002FF01000EADFE000EAED6E3
    S31A0010CB1C003AFDBB0033CD1D003A7FF4001CAF010002FF020063
    S31A0010CB311CAF000002FF03001CAD23000E2DE0000D1FDD0002F8
    S31A0010CB46FD05001EAC03001EAB020002FD00000EADFE000EAEB6
    S31A0010CB5BD6003A7FE00033CD1D003A7FF40004AC69000EABFFA5
    S31A0010CB70000CAFC0000EC016000CAFB1000ED1FF001EAF06001E
    S31A0010CB8502CF00001EAC07000EABFF0016AF0900397FAC0023D6
    S31A0010CB9AFFFF000CAFC0000CAFB100044D69000E2D01000CAFDA
    S31A0010CBAFDC000EABFF000CCC00000CDB110018AC010018AB006F
    S31A0010CBC40023FFFF00397FAD000CAFC4000CAFB50004AB6800BA
    S31A0010CBD93ACCF8000E1CFF0036CD040004AC6A0033CCFB000CE3
    S31A0010CBEEAF5E000EADFF0001BE6A0004AB69000E2BFE000CAF22
    S31A0010CC034C000E1BFF0036CCFB000CAFEC000EABFF00397FACD2
    S31A0010CC180023FFFF000CAFBD000EACFF0004AB69000E2B01004D
    S31A0010CC2D0C1BDF0032CCF00004AC69000E2CFE000EABFF0023BC
    S31A0010CC42FFFF000EACFF000EA1FE000EA0D60033CCE90010CC1B
    S31A0010CC5701000DBFBB000E1B000032CCEA000D8FCB000CAFBC3B
    S31A0010CC6C000EABFF0023FFFF000374FF000375FF000379FF005C
    S31A0010CC810CAFC2000CAFB3000CAFD9000CAF9C000EABFF000CEE
    S31A0010CC96CC24000CDB35000E19FE0034CCC8000DBF99000E09FE
    S31A0010CCABFF0034CCC8001AAB00000CAF9E000EADFF000CCE20C5
    S31A0010CCC0000CDD310018AF0000035F010002CB00000EC9010060
    S31A0010CCD50E09FF0030CCD3000CAF5B000CAF4C0016A90100165C
    S31A0010CCEAA5010016A4010023FFFF00397FAD000E2A20000EFAD8
    S31A0010CCFFDF0032CCC1000E2A5C000EA4FF000EA57F001CAB919D
    S31A0010CD14000E2BC70002EB91000EAFFE0002EF60003AFE3500FD
    S31A0010CD290EAFFF0002EF40000EAFFF0002EF30000EAFFF000257
    S31A0010CD3EEF90003EBFFF003EBFFF003EBFFF003EBFFF003EBF5E
    S31A0010CD53FF003EBFFF003EBFFF003EBFFF00397FAC0023FFFF3D
    S31A0010CD68000CAFC0000CAFB1000EACFE0033CC9D0010AB0100A9
    S31A0010CD7D36CC9D000EACFF0033CC9A000DBFDD000E1D00003294
    S31A0010CD92CCA1000EABFF0023FFFF00397FAD0016AFFF000CAF4C
    S31A0010CDA7C4000CAFB5000EA0FF000CAF0B000ECBF30002F000FC
    S31A0010CDBC003A7FE2000CAFBE000EADFF00036E0100036C01009C
    S31A0010CDD11EA000000D1F00000E10FC0034CC930016AF010039A1
    S31A0010CDE67FAC0023FFFF000CAFD0000CAFC1000E1EFF0036CCA2
    S31A0010CDFB7B000E0EFF0034CC77000CAFBF0018BF010002CF01DC
    S31A0010CE10000D8FBB00182F000002CF000033CC750018BB000041
    S31A0010CE2502CB000023FFFF00397FA9000CAFC8000CAFB9000C90
    S31A0010CE3AAFE0000CAFD1001EAD02000CB01F0036CC54000EFDA9
    S31A0010CE4F7F000CAFFB000E1BFF0036CC62000EABFF001809001E
    S31A0010CE640032CC64001818010030CC5C0033CC5D000EABFF00A4
    S31A0010CE791809000032CC5E001818010035CC5C000EABFE000EBE
    S31A0010CE8EACFF000C1BCF0036CC57000E2DFE000CAFDC000CAFF4
    S31A0010CEA3CB0018AC020033CC52000CAFDB000CAF8C003ACC4F50
    S31A0010CEB800397FA80023FFFF000CAFBD000CAFCE0004AC6700B6
    S31A0010CECD0EABFF000CAFC0000EC090000CAFB1000ED1FE00045C
    S31A0010CEE2AF67000E1FF70030CC34000E1DFF0036CC36000E1E2D
    S31A0010CEF7FF0036CC3600191F000002CF0000181E000031CC3865
    S31A0010CF0C000EAFFF0002CF00000EACFE0033CC33000EAC0000C9
    S31A0010CF2133CC33000EAFFF0002CF00000EACFF0023FFFF003913
    S31A0010CF367FAD0016AFFC000EA1BF000EA0AE0018AC6E0018AB24
    S31A0010CF4B6D0018AE6F000EADFF000EAFF10002FF00000EAFEF04
    S31A0010CF600002FF01003A7FBE000CAFCE000CAFBD000EA1FE007F
    S31A0010CF750EA0870018CE010018DD00000EA1BE000EA037001816
    S31A0010CF8AAB04000E2BFD000E1BFF0036CC15000EA3BF000EA238
    S31A0010CF9FAE001ACE4E001ADD4D000EABFE000EAC51003AC2F889
    S31A0010CFB40002FB020002FC03000EA1FF000EA01C0018AE07000D
    S31A0010CFC918AD06000EAFFF0002FF00003AC49E0004AED1000492
    S31A0010CFDEADD2000EAFFC0002FF00000EAF170002FF01003A7F60
    S31A0010CFF3BE000CAFC4000CAFB5000EA3BF000EA2AE000CAF31AC
    S31A0010D008000CAF20001AAC5D0018CC5F001AAB5C0018DB5E004A
    S31A0010D01D0CCC44000CDB55000EA3FF000EA21C001AAE07001A2B
    S31A0010D032AD06001EAC03001EAB02003AC4D0000EF57F0032CB3B
    S31A0010D047DB000CB45F0036CBDB000EA1BF000EA0AE00183C4189
    S31A0010D05C00187B400002F5000002F401000EAEFF000EADFB0077
    S31A0010D0713A7FBE000CAFCE000CAFBD000EFD7F0036CBD9000EAA
    S31A0010D086AEFF000EADFF0033CBD1000EAEFF000EADFF000EA125
    S31A0010D09BBF000EA0AE00180D6D0032CBD400181E6E0034CBD178
    S31A0010D0B00018AE6E0018AD6D000EABFE000EACFE003A7FA60021
    S31A0010D0C516AF0400397FAC0023FFFF00397FAD0016AFF50002D1
    S31A0010D0DAFB020002FC030002FD040002FE05000EAFFE0002FF69
    S31A0010D0EF06003AC2D0000E1CFF0036CB33000EA1FE000EA05438
    S31A0010D104000CAF02000CAF13001B1F020002CF02001AAF02009B
    S31A0010D1190E1FFE0032CBB2000EAFEF0002DF01000EAFD80002EC
    S31A0010D12EDF000033CBA9000EA1BF000EA0AE000EA3FE000EA227
    S31A0010D14354001AAF0200181F130035CBA9000EAFFF0002DF0210
    S31A0010D158000EA1FE000EA0540018A8010018A900000EAF1700A7
    S31A0010D16D037FFF000EAFFC00037FFF000CAF9D000CAF8E003902
    S31A0010D1827FD80016AF020002FD090002FE0A0002FD070002FE4C
    S31A0010D19708001EA203001EA302001AAE01001AAD00001EAF047E
    S31A0010D1AC0002FF00001EAF050002FF01000CAF9B000CAF8C00E6
    S31A0010D1C13A7FBE000EA1FE000EA0540002CB000002CC01000E73
    S31A0010D1D6AF1700037FFF000EAFFC00037FFF000CAFCE000CAF69
    S31A0010D1EBBD00397FD80016AF02000CAFDB000CAFEC001EA20305
    S31A0010D200001EA302001AAF00000EFF7F0036CB74000CAF1B00A0
    S31A0010D2150CAF0C000EADFC003A7FB2000EAFFF0002FF0600330F
    S31A0010D22ACB33000EA1BF000EA0AE0018A411000EA5FF000C1D69
    S31A0010D23F5F0032CB6D000C1E4F0034CB61000EA1BE000EA037D0
    S31A0010D2540018AB01000E2BBF000E1BFF0036CB39001EAF0900BB
    S31A0010D26902FF00001EAF0A0002FF010033CB510018A412000E95
    S31A0010D27EA5FF000C1B5F0032CB5C000C1C4F0031CB33000EA1AD
    S31A0010D293BE000EA0370018AB01000E2BBF000E1BFF0036CB39AF
    S31A0010D2A8001EAF070002FF00001EAF080002FF01000CAF5B0099
    S31A0010D2BD0CAF4C001EAE05001EAD04003A7FBE001EA003001E49
    S31A0010D2D2A1020002CB000002CC01000CAF5B000CAF4C000EAE19
    S31A0010D2E717000EADFC00397FDD000EA3FE000EA2540002DD0027
    S31A0010D2FC0002DE01000EA1FF000EA01C0018AF01000EBFFB001E
    S31A0010D31102CF010033CB37000EAFFF0002FF06000EABFE000E62
    S31A0010D326AC54000EADFC003A7FB2001EAC06000EABFF0016AF6D
    S31A0010D33B0B00397FAC0023FFFF00397FAD0016AFCE0002FB0C36
    S31A0010D3500002FC0D0002FD0E0002FE0F000EAFFF0002FF1000BE
    S31A0010D3650EAFFE0002FF11000EAFFF0002FF220002FF230002CB
    S31A0010D37AFF240002FF250002FD260002FE27000EAFFF0002FF36
    S31A0010D38F280002FF29000EAFFF0002FF2C0002FF2D000EA1BF9C
    S31A0010D3A4000EA0AE0018AC44000EABFF000EA1BF000EA0BD0069
    S31A0010D3B918AE010018AD00003A7FB60002FB1A0002FC1B00021C
    S31A0010D3CEFB1C0002FC1D001EA20D001EA30C001AAF000002FF9E
    S31A0010D3E318001AAF010002FF19000EA1FE000EA087001EAC0F68
    S31A0010D3F8001EAB0E00180B1D0032CAFD00181C1E0031CAFA00B3
    S31A0010D40D02CB1D0002CC1E001EA00D001EA10C0018AC090018A3
    S31A0010D422AB08001EAF0E0002FF00001EAF0F0002FF01000CAFB7
    S31A0010D4376F000ECFF70002FF03000D5F7F0002FF02000EAFFFD9
    S31A0010D44C0002FF04000EAFFF0002FF05001EAF370002FF0600E3
    S31A0010D4611EAF380002FF07001EAE19001EAD18003AC532001E7C
    S31A0010D476AB36000E2BF7000E1BFF0036CADB000EAFFF0002FFBA
    S31A0010D48B0A0002FF0B000CAF64000EC4F7000D5F75000EA3BF27
    S31A0010D4A0000EA2AE000CAF31000CAF20001AAC5D0018CC5F00D6
    S31A0010D4B51AAB5C0018DB5E001CCC03001CDB020002EB02000205
    S31A0010D4CAEC030002FB200002FC21000CAF5B000CAF4C001EAE23
    S31A0010D4DF0D001EAD0C003AC7F70002FB120002FC13000E1B7F7E
    S31A0010D4F40032CABF000E1CFE0036C8C1001EA20D001EA30C00D1
    S31A0010D5091AAC01001AAB00001A0B020032CAB8001A1C03003126
    S31A0010D51EC8C1000CAF5B000CAF4C001EAE13001EAD12003AC581
    S31A0010D533460002FB160002FC17001EA00D001EA10C00180B06A0
    S31A0010D5480032CAAB00181C070034C8C1000CAF6F000ECFF7001B
    S31A0010D55D02FF2F000D5F7F0002FF2E001F1F100002FF10001EDC
    S31A0010D572AF19001ECF1B0002FF1F001EAF18001EDF1A0002FFA1
    S31A0010D5871E001EAC1F001EAB1E001EA20D001EA30C001A0B02CA
    S31A0010D59C0032CA96001A1C030034CA91001AAF020002FF1E0020
    S31A0010D5B11AAF030002FF1F001EAF1F001E3F190002FF1B001EC7
    S31A0010D5C6AF1E001E7F180002FF1A001EAC1B001EAB1A001EAE09
    S31A0010D5DB13001EAD12003AC0830002FB2A0002FC2B000EA1FFBA
    S31A0010D5F0000EA0470018AF150036CA780018AF150036CA680083
    S31A0010D6050EA1BE000EA0370018AB03000E2BBF000E1BFF00368C
    S31A0010D61ACA68001EAC21001EAB20001EAE13001EAD12003AFEEB
    S31A0010D62F2C000CAFCE000CAFBD001EAF2A0002FF00001EAF2BB3
    S31A0010D6440002FF01001EAC27001EAB26003AFE100002FB0E0086
    S31A0010D65902FC0F001EA00D001EA10C0018AC090018AB08001E4D
    S31A0010D66EAF0E0002FF00001EAF0F0002FF01000CAF6F000ECFEE
    S31A0010D683F70002FF03000D5F7F0002FF02000EAFFF0002FF04D2
    S31A0010D698000EAFFF0002FF05001EAF370002FF06001EAF380095
    S31A0010D6AD02FF07001EAE1F001EAD1E003AC532001EAB36000E38
    S31A0010D6C22BF7000E1BFF0036CA06000EA3BF000EA2AE001AAC59
    S31A0010D6D746001AAB45000CCCCC000CDBBB001EAE29001EAD28AA
    S31A0010D6EC000C1DBF0032CA41000C1ECF0031CA06000CAFEC004D
    S31A0010D7011ECC2B000CAFDB001EDB2A000CAFCD000CAFBC000E22
    S31A0010D716AFFF00397FD2000CAFE0000CAFD1000CAFC8000CAF4B
    S31A0010D72BB9000E887F001AAD46001AAC45000EAFFF00397FD2A7
    S31A0010D74000037EFF00037DFF00037CFF00037BFF000CAF9B006E
    S31A0010D7550CAF8C000CAF1D000CAF0E00397FD50016AF04003A31
    S31A0010D76A7FC5000EAFFF00037FFF000EAFFF00037FFF000EAF19
    S31A0010D77FFF00037FFF000EAF7E00037FFF000E8C7F00397FD49E
    S31A0010D7940016AF04000CAFE0000CAFD1000CAFC8000CAFB90083
    S31A0010D7A91EA22F001EA32E001AAD03001AAC02000EAFFE0039F1
    S31A0010D7BE7FD2000370FF000371FF000378FF000379FF00397F5D
    S31A0010D7D3D90016AF0400397FD10002DD020002DE03000EA1BFCE
    S31A0010D7E8000EA0AE000CAF02000CAF130018AC5D001ACC5F00C9
    S31A0010D7FD18AB5C001ADB5E001EA02F001EA12E0018CC030002CC
    S31A0010D812CC030018DB020002CB02000CAF1B000CAF0C001EAEEF
    S31A0010D8270D001EAD0C003AC7F70002FB140002FC15001EAC2FDD
    S31A0010D83C001EAB2E001EAE15001EAD14003AC546000CAFC40046
    S31A0010D8510CAFB5000EA3BF000EA2AE000CAF31000CAF20001A8D
    S31A0010D866AC410018CC43001AAB400018DB42000C05BF0032C97E
    S31A0010D87BDF000C14CF0031C9B6000EA1BE000EA0370018AB02ED
    S31A0010D890000E2BDF000E1BFF0036C9B6000CAF4F001E3F1700FA
    S31A0010D8A502FF31000CAF5F001E7F160002FF30001EAF1C00023D
    S31A0010D8BAFF00001EAF1D0002FF01001EAC2D001EAB2C001EAEA0
    S31A0010D8CF1B001EAD1A003A7FBE001EA231001EA330000C03BF07
    S31A0010D8E40032C9C4000C12CF0034C9B6001EAF1C0002FF0000D0
    S31A0010D8F91EAF1D0002FF01001EAC2D001EAB2C001EAE1B001E27
    S31A0010D90EAD1A003A7FBE000CAFC4001EC417000CAFB5001ED5D5
    S31A0010D92316000CAF4F001E3F170002FF2D000CAF5F001E7F164A
    S31A0010D9380002FF2C001EAF1A0002FF1C001EAF1B0002FF1D008D
    S31A0010D94D1EAC15001EAB14000E1B7F0032C9A6000E1CFE00364C
    S31A0010D962C98A001E1417000CAFFC001EAB16000C7B5B000EFB7D
    S31A0010D9777F0036C99E000D9FCC000DCFBB000E0BF80032C99BB3
    S31A0010D98C000E1C000030C991000EECEF00037FFF000EEBEF006A
    S31A0010D9A10CBFCB0016AC01001E0B160032C992001E1C170034B1
    S31A0010D9B6C98E000EACFE000EABFF0033C98C000EACFF000EAB85
    S31A0010D9CBFF000E1CFF0036C950001EAF110036C950001EAE1BA6
    S31A0010D9E0001EAD1A000E0DFF0032C983000E1EFE0034C9500028
    S31A0010D9F50D0FD1000D4FE00002F11A0002F01B001EA20D001ED9
    S31A0010DA0AA30C001AA803001E3819001AA902001E791800037027
    S31A0010DA1FFF000371FF000CAF9D000CAF8E00397FD80016AF0272
    S31A0010DA34001EAC10000CAFCB000E6BFE000CCECC000CDDBB00A6
    S31A0010DA490E0BFF0032C96A000E1CD80034CAA5000EABFE001EBB
    S31A0010DA5EAF10000E0FD80030C963001EAB10000E4BD7000CAFC9
    S31A0010DA73BC000E6BFE00037CFF00037BFF000CAF9D000CAF8EB9
    S31A0010DA8800397FD80016AF02001E1D1A0032C955001E1E1B0020
    S31A0010DA9D32C955001F1E1B001F5D1A0002FD1A0002FE1B000EDE
    S31A0010DAB2AFFF0002FF110033CAA5001EAF29001ECF2B0002FFD8
    S31A0010DAC729001EAF28001EDF2A0002FF28001EAC15001EAB140A
    S31A0010DADC000E1B7F0032C944000E1CFE0036C8CA001EA00D007D
    S31A0010DAF11EA10C001805060032C93F001814070034C8F3001FA1
    S31A0010DB060B16001F4C17000D0F5D000D4F4E000CCECC000CDD9F
    S31A0010DB1BBB001EAE1B001EAD1A00397FDC001ECE250002FE258E
    S31A0010DB30001EDD240002FD24001EDC230002FC23001EDB22002F
    S31A0010DB4502FB22001EA21F001EA31E001803020032C928001880
    S31A0010DB5A12030031C914001EAF0E0002FF26001EAF0F0002FF9E
    S31A0010DB6F270002F3180002F219001EAF140002FF12001EAF1574
    S31A0010DB840002FF130002F5160002F417001EA02F001EA12E006E
    S31A0010DB9918AF020002FF200018AF030002FF210033CAA5001ECB
    S31A0010DBAEA20D001EA30C001AAF03001A3F010002DF03001AAFFD
    S31A0010DBC302001A7F000002DF02000EA1BD000EA0760018AE174C
    S31A0010DBD8000EADFF000EAC17000EABFC00397FDD000CAFDC00B6
    S31A0010DBED0E6CFE000CAFCB00037EFF00037DFF00037CFF00038F
    S31A0010DC027BFF001EAE29001EAD28001EAC27001EAB2600397FFD
    S31A0010DC17D60016AF04001EA00D001EA10C0002CD040002CE0505
    S31A0010DC2C0033C8B9001EA20D001EA30C001AAC07001E3C170041
    S31A0010DC411AAB06001E7B16001E34170002F401001E7516000233
    S31A0010DC56F500001EAE1B001EAD1A003A7FBE0002FB1A0002FC56
    S31A0010DC6B1B001ECC19001EDB18001EA00D001EA10C00183C0174
    S31A0010DC800002CC0300187B000002CB02001EAC170018CC07007A
    S31A0010DC951EAB160018DB06000D0FBB000D4FCC001EAE1B001E88
    S31A0010DCAAAD1A00397FDC001ECE250002FE25001EDD240002FDA0
    S31A0010DCBF24001EDC230002FC23001EDB220002FB220033C90C96
    S31A0010DCD4001EA20D001EA30C001EAF19001A3F010002DF030067
    S31A0010DCE91EAF18001A7F000002DF020033C90C001EA00D001EBE
    S31A0010DCFEA10C000EAFFF0002CF040002CF05000EAFFF0002CF5A
    S31A0010DD13020002CF030016AF3200397FAC0023FFFF00397FAD2E
    S31A0010DD280016AFE8000CAFB9000CAFCB000CAFDC0002FE0D0085
    S31A0010DD3D0EA5BF000EA4BD001CAF000002FF12001CAF0100022E
    S31A0010DD52FF130000FE62000EA1BF000EA0AE0018CC410002FC47
    S31A0010DD670A0018DB400002FB09000EA1FF000EA01C0018AB0112
    S31A0010DD7C000EEBDF000E2BFE000CAFBC000CAF9B003AE9190064
    S31A0010DD9102FB070002FC08000EAFFE0002FF0B000EAF51000286
    S31A0010DDA6FF0C000CAF5B000CAF4C003AC0D70002FB050002FC59
    S31A0010DDBB06000EA5FE000EA487001CAF000002FF03001CAF01B2
    S31A0010DDD00002FF04000EA1FF000EA01C0018AE070018AD060013
    S31A0010DDE51EAF0D0002FF00001EAF1C0002FF01001EAF1D000261
    S31A0010DDFAFF02000CAF6C000ECCFC000D5F7B003ACB2E003AC1EB
    S31A0010DE0F61000CAFCE000CAFBD001EAB0D000E2BF7000E1BFF58
    S31A0010DE240032C86C001EAF05001EBF060032C86C001CAF170070
    S31A0010DE390EFF7F0032C7FA001CAF17001CBF180036C7FA000073
    S31A0010DE4EFF59001EAB0D000E2BF7000E1BFF0036C86200040DB2
    S31A0010DE635D0032C86400041E5C0034C8620000FE590004AF599A
    S31A0010DE780036C83500041E5C000CAFFC0004AB5D000C7BDB00A9
    S31A0010DE8D1EAE13001EAD1200397FDC000EEDFB000EECFB000C23
    S31A0010DEA2BFDE000E6BFB000CBFCD000CAFBC000E6BFD0002FBC2
    S31A0010DEB7140002FC150002FD160002FE17001EAF160002FF0EFB
    S31A0010DECC001EAF170002FF0F000EA1BF000EA0AE0018A841006C
    S31A0010DEE118A940000EA1BD000EA0760018AE17000EADFF000EE0
    S31A0010DEF6AC17000EABFC00397FDD0002FD000002FE01001EAC2A
    S31A0010DF0B17001EAB16000CAF9D000CAF8E003A7FBE0002FB10D0
    S31A0010DF200002FC110033C82D001EAF050002FF0E001EAF0600EB
    S31A0010DF3502FF0F001EAF070002FF10001EAF080002FF11000ED7
    S31A0010DF4AABBF000EACBD003AC0D70002FB050002FC06000EA541
    S31A0010DF5FFE000EA487001CAF000002FF03001CAF010002FF04C0
    S31A0010DF74000EAFFF0002FF070002FF08000EA1FF000EA01C003D
    S31A0010DF8918AE070018AD06001EAF0D0002FF00000EAFFC00023F
    S31A0010DF9EFF01000EAF170002FF02000CAF6C000ECCFC000D5F18
    S31A0010DFB37B003ACB2E001EAC06001CCC14001EAB05001CDB13F1
    S31A0010DFC8000CAFCE001CCE01000CAFBD001CDD00000EFD7F00BF
    S31A0010DFDD36C802000EABFF000EAC0E000EAEFF000EADFF0033F1
    S31A0010DFF2C800000EABFF000EAC0E003AFB06001EAE11001EADD9
    S31A0010E00710001EAC0F001EAB0E003AC1570016AF1800397FAC9B
    S31A0010E01C0023FFFF00397FAD0016AFF4000CAFC2000CAFB300AF
    S31A0010E0310CAFE4000CAFD5000EAFFE0002FF03000EAF7F000298
    S31A0010E046FF02001CAF04000EFF7F0036C700000EA1FF000EA0FA
    S31A0010E05B1C0018AB01000E2BF7000E1BFF0036C7050018AB3469
    S31A0010E070000E2B7F000E1BFF0032C705001AAF02000EFF7F0050
    S31A0010E08532C718001AAF02001ABF030036C718001AAE01001AC0
    S31A0010E09AAD00000CAFDC000E6CFE000CAFCB000EECFD000CAF67
    S31A0010E0AFFB000EEDFD000CAFFC000CBBDB000EEEFD000CAFFD49
    S31A0010E0C4000CBCEC000EAEFF000EAFFE00397FCD000CAFE000E7
    S31A0010E0D90CAFD1000CAFC8000CAFB9001AAD03001AAC02000EF9
    S31A0010E0EEAFFE00397FD200037EFF00037DFF00037CFF00037BD5
    S31A0010E103FF000CAF9B000CAF8C000CAF1D000CAF0E00397FD527
    S31A0010E1180016AF040002FB040002FC050002FD060002FE070003
    S31A0010E12D1CAC05001CAB04001AAE03001AAD0200397FDC000EF9
    S31A0010E142AFFE00397FCD000CAFE0000CAFD1000CAFC8000CAF1B
    S31A0010E157B9001AAC01001AAB00001AAE01001AAD0000397FDC34
    S31A0010E16C000EAFFE00397FCD00037EFF00037DFF00037CFF00CB
    S31A0010E181037BFF000CAF9B000CAF8C000CAF1D000CAF0E00397F
    S31A0010E1967FD50016AF040002FB080002FC090002FD0A0002FE2C
    S31A0010E1AB0B000EA1BD000EA0760018AE17000EADFF000EAC1746
    S31A0010E1C0000EABFC00397FDD000CAFDC000CAFED000EAFFE00F0
    S31A0010E1D5397FD2000EAFFF00037FFF000EAFFF00037FFF000E0D
    S31A0010E1EAAFFF00037FFF000EAF7C00037FFF00397FD90016AFCB
    S31A0010E1FF04000EAFFF00037FFF000EAFFF00037FFF000EAFFFBB
    S31A0010E21400037FFF000EAF8800037FFF00397FD90016AF04003E
    S31A0010E2291EAF0B00037FFF001EAF0B00037FFF001EAF0B00033D
    S31A0010E23E7FFF001EAF0B00037FFF00397FD90016AF040002FB87
    S31A0010E253080002FC090002FD0A0002FE0B000CAFBF0036C75AAC
    S31A0010E268000EFC7F0036C75A000E1B7E0032C75B000E1C7F0007
    S31A0010E27D32C75B000E1DFF0032C75B000E1EFF0036C6FD003050
    S31A0010E292C6FD000EAFFF00037FFF000EAFFF00037FFF000EAF67
    S31A0010E2A7FF00037FFF000EAF7E00037FFF001EAE0F001EAD0E5C
    S31A0010E2BC001EAC0D001EAB0C00397FD40016AF04003A7FC300BA
    S31A0010E2D10EAFFF00037FFF000EAFFF00037FFF000EAFFF0003E9
    S31A0010E2E67FFF000EAF7E00037FFF000E8C7F00397FD40016AF69
    S31A0010E2FB04001EAF0700037FFF001EAF0700037FFF001EAF0776
    S31A0010E31000037FFF001EAF0700037FFF00397FD90016AF0400B2
    S31A0010E32502FB040002FC050002FD060002FE07000CAFBF00360D
    S31A0010E33AC725000EFC7F0032C725000E1B700032C726000E1C43
    S31A0010E34F800032C726000E1D010032C726000E1EFF0036C6FD95
    S31A0010E3640030C6FD001EAE05000E8E7F001EAD04001EA9060013
    S31A0010E3791EA807000CAFDB000CAFEC000CAF9D000CAF8E003995
    S31A0010E38E7FD10002FD020002FE030033C6FD000EA1BD000EA000
    S31A0010E3A3760018AE17000EADFF000EAC17000EABFC00397FDD27
    S31A0010E3B8000CAFDB000CAFEC001CAE05001CAD04001AAF000098
    S31A0010E3CD02FF00001AAF010002FF01003A7FBE0002FB020002E0
    S31A0010E3E2FC030033C6FD001CAF040002FF02001CAF050002FF78
    S31A0010E3F7030033C6FD000EAFFF0002FF020002FF03001EAC0372
    S31A0010E40C001EAB020016AF0C00397FAC0023FFFF00397FAD005F
    S31A0010E42116AFEC000EA1BE000EA05C000EA3BF000EA2BD001AB1
    S31A0010E436AF030002FF12001AAF040002FF130018AF060001BF88
    S31A0010E44B5F0018AF070001BF5E000EACFF000EABFF000EAE59D5
    S31A0010E460000EADF4003AC077000CAFC4000CAFB5000EACFF00C9
    S31A0010E4750EABBF000EAE59000EADF4003AC0770002FB000002D0
    S31A0010E48AFC010002F5020002F403001EAC13001EAB12000EAE04
    S31A0010E49F59000EADF4003AC03D0002FB0E0002FC0F000CAF6FD1
    S31A0010E4B4000ECFF10002FF0D000D5F7F0002FF0C000EAFFF00AD
    S31A0010E4C902FF040002FF05000EA1BF000EA0BD0018AE01001865
    S31A0010E4DEAD00000D9FCC000E5BBF00397FDC000ECDDF000D5F0C
    S31A0010E4F3CC000D5FBB000EEDFB000EECFB000CBFDE000E6BFB03
    S31A0010E508000CBFCD000CAFBC000E6BFD0002FD060002FE070057
    S31A0010E51D0EA3BD000EA276001AAF100002FF08001AAF11000281
    S31A0010E532FF09001AAC11001AAB10000EAFEF0002FF01000EAF9F
    S31A0010E547D80002FF00000EAEEF000EADF1003A7FBE0002FB08FD
    S31A0010E55C0002FC09000EA1BF000EA0AE0018AF410018CF57007D
    S31A0010E57102FF0B0018AF400018DF560002FF0A000EA5FF000E54
    S31A0010E586A41C001CAF34000EBF7F0002EF34000EAFF70002FF85
    S31A0010E59B00000EAFFC0002FF01000EAF170002FF02000CAF6C9C
    S31A0010E5B0000ECCFB000D5F7B000EAE59000EADF4003ACB2E008D
    S31A0010E5C51CAF34000E2F800002EF34001EAC07001EAB06000E9C
    S31A0010E5DAA1BD000EA0760018AE0D0018AD0C003A7FBA0002FB80
    S31A0010E5EF100002FC11001CAC2D001CAB2C000EA3BD000EA27666
    S31A0010E604001AAE12000EADFF000EAFFF0002FF00000EAF9B0042
    S31A0010E61902FF01003A7FBE001EAE11001EAD10000C0DBF00329B
    S31A0010E62EC672000C1ECF0031C667000EA1BE000EA0370018AB1D
    S31A0010E64302000E2BBF000E1BFF0036C667000EABFF000EAC01B4
    S31A0010E658000EADEF003A7FA4000EABFE000EACF0001EAE110052
    S31A0010E66D1EAD10003AFB060000FF610016AF1400397FAC0023AC
    S31A0010E682FFFF00397FAB000EA1BF000EA0BD0018AC02000E2C33
    S31A0010E697FC000E8CFD000D9FFB000CBBCB000CAFB5000EE5FD2C
    S31A0010E6AC003AC0FA000E1CFF0036C650000EA5FF000CAF5C0011
    S31A0010E6C10EABFF00397FAA0023FFFF00397FAD0016AFF90002CE
    S31A0010E6D6FB020002FC030002FD040002FE05001EA20D001EAC7C
    S31A0010E6EB0C001EAB0B000CBCBF0032C63F000EACFE000EABFFF6
    S31A0010E7000002FB0B0002FC0C000EA1BF000EA0AE001812530095
    S31A0010E71530C6200033C623000CAF2C000EABFF000CCCCC000C58
    S31A0010E72ADBBB000CAFC4001EC403000CAFB5001ED502001CAC9D
    S31A0010E73F01001CAB00001EAF0B0002FF00001EAF0C0002FF0133
    S31A0010E754001EAE05001EAD040002F206003A7FBE0002EB00009C
    S31A0010E76902EC01001EA206000DBF22000E12000032C638001F73
    S31A0010E77E8C05001F8B04000CAFBC000EECFD000EABFF0016AF46
    S31A0010E7930700397FAC0023FFFF00397FAD0016AFF80002FB02AE
    S31A0010E7A80002FC030002FD040002FE05001EAE0D001EAD0C008D
    S31A0010E7BD0CBEDF0032C60C000EAEFE000EADFF0002FD0C000203
    S31A0010E7D2FE0D001EAC05001EAB04003ACBCB0002FC06001EACD7
    S31A0010E7E70E000EABFF000CCCCC000CDBBB000CAFC0001EC0039F
    S31A0010E7FC000CAFB1001ED102001EA205001EA304001AAF000042
    S31A0010E81102CF00001AAF010002CF010033C5E2001EAC0E000EAF
    S31A0010E826ABFF000CCCCC000CDBBB000CAFC4001EC403000CAFB8
    S31A0010E83BB5001ED502001CAC01001CAB00001EA005001EA104F2
    S31A0010E8500018AE010018AD00001EAF0C0002FF00001EAF0D005D
    S31A0010E86502FF01003A7FBE0002EB000002EC01001F1F0E0002E5
    S31A0010E87AFF0E000E1FF10034C5F7001EAC06000EABFF0016AF0B
    S31A0010E88F0800397FAC0023FFFF00397FA90016AFFE0002FB01AF
    S31A0010E8A4003AC2B4000CAFC0000CAFB10018AF00001E1F0100AD
    S31A0010E8B936C5BE0018AF01000E1FAA0032C5BE0018AF00000E52
    S31A0010E8CE1FAA0036C5C70018AF00000E1FFA0032C5BE000D1FC5
    S31A0010E8E36E000D5F7D000EAFFF0002FF00000EABFE000CAFDCA8
    S31A0010E8F8000CAFED000EAEE7003AFD1F0016AF0200397FA8002D
    S31A0010E90D23FFFF00397FAD0016AFFC000CAFC4000CAFB5003A6F
    S31A0010E922C2D0000E1CFF0032C5A7000EAFAA0002EF00000EAF5C
    S31A0010E937AA0002EF01003AC2B40002FB000002FC01000EACDFD4
    S31A0010E94C000EABFF000CAF5D000CAF4E003AFDBB0033C5760067
    S31A0010E9610EAFE70002FF03000EAFE70002FF02003AC2B4000C80
    S31A0010E976AFC0000CAFB10018AF01000E1FAA0032C59A000EAFAE
    S31A0010E98BE50002FF020033C598000EAFE50002FF03003AFBB25C
    S31A0010E9A0001EAB02003AFD04000CAF4E000ECEFD000D5F5D009B
    S31A0010E9B50EAFFD0002FF00000EABE1000CAFDC000CAFED001E85
    S31A0010E9CAAE02003AFD1F000EAFFF0002EF00000EAFAA0002EF17
    S31A0010E9DF01000EAFFF0002FF00000EABFD000CAF5C000CAF4D7A
    S31A0010E9F4001EAE02003AFD1F000EAFFF0002EF01000EAFFF006A
    S31A0010EA0902FF00000EABFD000CAF5C000CAF4D001EAE03003A03
    S31A0010EA1EFD1F003AFBAB0016AF0400397FAC0023FFFF00397FCB
    S31A0010EA33AD000CAFC4000CAFB5000EA1BF000EA0BD0018AE0677
    S31A0010EA480018AD05000EABFF000EAC66003AC546000CAF5D00A4
    S31A0010EA5D0CAF4E00397FDC00397FAC0023FFFF00397FA90016F5
    S31A0010EA72AFF8000EA1FE000EA0870018AE010018AD00000EA1B5
    S31A0010EA87FF000EA01C0018AF060002FF000018AF070002FF01FD
    S31A0010EA9C000EAFFF0002FF02000EAF660002FF03000EAFFE00AE
    S31A0010EAB102FF04000EAFFE0002FF050004AFD20002FF060004E4
    S31A0010EAC6AFD10002FF07000EABFE000EAC51003AC5320016AFE5
    S31A0010EADB0800397FA80023FFFF00397FAD0016AFFE000CAFC4E0
    S31A0010EAF0000CAFB5001CAC03001CAB02000EAFFF0002FF010039
    S31A0010EB050EAFFB0002FF00003A7FBE001CCC01001CDB00000EC7
    S31A0010EB1AFB7F0036C535000EACFF000EABFF0016AF0200397F36
    S31A0010EB2FAC0023FFFF000374FF00397FA90016AFFC001EA40B89
    S31A0010EB44003AC2F80002FB020002FC03001EAE08001EAD07000C
    S31A0010EB593AC4D0001EA00A001EA1090002CB000002CC01000E89
    S31A0010EB6EAFFF0002FF00001EAC03001EAB02001EAE08001EAD96
    S31A0010EB8307003AC49E001EA20A001EA3090002DB020002DC0370
    S31A0010EB98000EAFFC0002FF00000EAF170002FF01001EAE0E00E8
    S31A0010EBAD1EAD0D003A7FBE001EA00A001EA1090002CB0200028D
    S31A0010EBC2CC03000E14FF0036C502000EA1BF000EA0AE001EA2B1
    S31A0010EBD70A001EA309001AAF030018CF5F0002DF03001AAF027E
    S31A0010EBEC0018DF5E0002DF02001EAF0C0036C4F6000EA1BF008F
    S31A0010EC010EA0AE001EA20A001EA309001AAF030018CF5D0002E6
    S31A0010EC16DF03001AAF020018DF5C0002DF020016AF0400397F6F
    S31A0010EC2BA80016A4010023FFFF00397FAD0016AFF80002FB0417
    S31A0010EC400002FC05000CAFE4000CAFD5001EAF0C0001BF5F007F
    S31A0010EC551EAF0D0001BF5E000EACFF000EABFF003AC0770002B8
    S31A0010EC6AFB060002FC07000EACFF000EABBF000CAF5D000CAF75
    S31A0010EC7F4E003AC0770002FB000002FC01001EAF060002FF02D9
    S31A0010EC94001EAF070002FF03001EAC05001EAB04000CAF5D00C9
    S31A0010ECA90CAF4E003AC03D0016AF0800397FAC0023FFFF003975
    S31A0010ECBE7FAD0016AFFA0002FB000002FC010002FD020002FE43
    S31A0010ECD303000CAF7B000CAF6C003AC0B5000EABFF000CCCC4B3
    S31A0010ECE8000CDBB5000CAF4C000ECC38000CAF5B000EDBBF008E
    S31A0010ECFD1EAE01001EAD00003AC0CB0002FB040002FC05000C7F
    S31A0010ED12AF4C000ECCE8000CAF5B000EDBBE001EAE01001EADC4
    S31A0010ED2700003AC0CB001EAE03000ECEAB001EAD02000EDD0AE4
    S31A0010ED3C00397FDC000ECDBF000D5FCC000D5FBB000EEDFD0027
    S31A0010ED510EECFD000CBFDE000E6BFD000CBFCD000CAFBC000E64
    S31A0010ED666BFD000CAFEC001ECC05000CAFDB001EDB040016AF2C
    S31A0010ED7B0600397FAC0023FFFF00397FAB0016AFF80002FB00C5
    S31A0010ED900002FC010002FD020002FE03001EAB0B000EAFFF00C5
    S31A0010EDA502FF060002FF07000E1BFF0036C48C000EA1BF000E0A
    S31A0010EDBAA0AE0018AF5D0002FF070018AF5C0002FF06000CAFCF
    S31A0010EDCF7B000CAF6C003AC22F000CAFC50032C47D0004AF6046
    S31A0010EDE40036C47D003AC2C1000CAFC0000CAFB10018AF04001E
    S31A0010EDF902FF040018AF050002FF050033C46F003AC2C1000CE9
    S31A0010EE0EAF5E000EADFF000CCEEE000CDDDD000ECEFD000D5F3F
    S31A0010EE23DD000CCECC000CDDBB001EAE01001EAD00003AC245C4
    S31A0010EE380002FB040002FC05001EAC03001EAB02003AC2B10066
    S31A0010EE4D0CAF5E000EADFF000CCEEE000CDDDD000CCECC000C87
    S31A0010EE62DDBB001EAE01001EAD00003AC245000CAFCE000CAFD0
    S31A0010EE77BD001EAC03001EAB02003AC431000CAFE0000CAFD1C5
    S31A0010EE8C000CAFC8000CAFB9001EAD05001EAC04000EAFFE000B
    S31A0010EEA1397FD2000370FF000371FF000378FF000379FF0039A9
    S31A0010EEB67FD90016AF0400397FCF001EA007001EA106000CAF44
    S31A0010EECB18000E68FE000CAF89000CC0E0000CD1D1000CD8C846
    S31A0010EEE0000CD9B9000E09FF0032C43F000E18FF0032C43F00C4
    S31A0010EEF50E11800032C43F000E10000034C43B000EAC00000E05
    S31A0010EF0AAB800033C434000EF97F0032C436000CAF1B000CAF43
    S31A0010EF1F0C0033C434000EACFF000EABFF0016AF0800397FAAF0
    S31A0010EF340023FFFF00397FA9000ECCA5000EDB0B00397FDC0029
    S31A0010EF490EAFFE00397FCD000EAFFF00037FFF000EAFFF000361
    S31A0010EF5E7FFF000EAFFF00037FFF000EAF8E00037FFF00397F49
    S31A0010EF73D90016AF04003A7FC500397FA80023FFFF00397FA971
    S31A0010EF880016AFFE0002FD000002FE01000EAEFF000EADFB002A
    S31A0010EF9D3A7FBE0016AF0200397FA80023FFFF00397FAD00160F
    S31A0010EFB2AFF1000CAFC4000CAFB5003AC2A7000EABBF000EACD0
    S31A0010EFC7BD000EADFE000EAE4D003AC0E90002FB0D0002FC0EA7
    S31A0010EFDC000EAFFE0002FF0B000EAF4D0002FF0C000EAFFF0070
    S31A0010EFF102FF030002FF04000EA1BF000EA0BD0018AF0000024A
    S31A0010F006FF050018AF010002FF06000EA1BF000EA0AE0018C466
    S31A0010F01B410002F40A0018D5400002F509003AE7E0000CAFCBD5
    S31A0010F030000EA5FF000EA41C001CAC01000EECDF000E2CFE005B
    S31A0010F0453AE9190002FB070002FC08001CAE07001CAD06000EAC
    S31A0010F05AAFF70002FF000004AFD20002FF010004AFD10002FFD8
    S31A0010F06F02000CAF6C000ECCFC000D5F7B003ACB2E001EAF058B
    S31A0010F0840001BF5B001EAF060001BF5A001EA20C001EA30B00C1
    S31A0010F09904AE5A0004AD5B000CAFDC000E6CFE000CAFCB000E91
    S31A0010F0AEECBF000CAFFB000EEDBF000CAFFC000CBBDB000EEEC7
    S31A0010F0C3BF000CAFFD000CBCEC000EAEFF000EA5BF000EA4BD5B
    S31A0010F0D8001CA001001CA100000CAF18000E68FE000CAF890008
    S31A0010F0ED0370FF000371FF000378FF000379FF00397FD600167A
    S31A0010F102AF04001ACE010001BE5C001ADD000001BD5D000EA16A
    S31A0010F117BD000EA0760018A8010018A9000018AE17000EADFFD3
    S31A0010F12C000EAC17000EABFC00397FDD0002FD000002FE01009D
    S31A0010F1411EAC0E001EAB0D000CAF9D000CAF8E003A7FBE000ECF
    S31A0010F156A1FE000EA0870002CB150002CC16001EAF0D0002CF49
    S31A0010F16B13001EAF0E0002CF140016AF0F00397FAC0023FFFF4D
    S31A0010F18000397FAD000EA5FF000EA41C000EA3BF000EA2AE00B1
    S31A0010F1951CA009001CA108001A01400032C395001A1041003045
    S31A0010F1AAC37D000EA1FF000EA047000EAFFE0002CF14001CA0FB
    S31A0010F1BF09001CA108001A01400032C38B001A10410030C37DA1
    S31A0010F1D4000EA1FE000EA0870018AF17000EFF7F0032C37D0052
    S31A0010F1E918AF170018BF180036C37D000EACFF000EABFF000C3B
    S31A0010F1FEAFCE000CAFBD003AC15700397FAC0023FFFF00397F62
    S31A0010F213A9000E1BF80030C35E000CAFBE000EADFF000CAFFCCB
    S31A0010F228000CAFFB000EECBF000CAFFB000EEDBF000CAFFC0025
    S31A0010F23D0CBBDB000EEEBF000CAFFD000CBCEC000EAEFF000E14
    S31A0010F252AFF600037FFF000EAFFF00037FFF000EAFFF00037FF0
    S31A0010F267FF000EAFFF00037FFF00397FD60016AF04000CAFDB53
    S31A0010F27C000CAFEC0033C33A000CAFBC000EABFF000ECC060081
    S31A0010F2910DFFBB000CAFCE000CAFBD000CAFDC000E6CFE000C6F
    S31A0010F2A6AFCB000EECBF000CAFFB000EEDBF000CAFFC000CBB1C
    S31A0010F2BBDB000EEEBF000CAFFD000CBCEC000EAEFF000CCEEEA3
    S31A0010F2D0000CDDDD000CDCCC000CDBBB000EAFC000037FFF00F9
    S31A0010F2E50EAFFF00037FFF000EAFFF00037FFF000EAFFF0003C5
    S31A0010F2FA7FFF00397FD60016AF04000CAFDB000CAFEC000ECCFD
    S31A0010F30F38000EDBCE00397FA80023FFFF00397FA9000CBCBF7B
    S31A0010F3240032C333000EA9FF0033C2FC000E0BC00032C33000F1
    S31A0010F3390E1C000034C32D000EA9F10033C2FC000E0BCE0032A9
    S31A0010F34EC32A000E1C390030C324000EAEF6000EADFF00397F09
    S31A0010F363DC000EA9FF0033C304000ECCC6000EDB31000EAEC0BD
    S31A0010F378000EADFF00397FDC000CAFE0000CAFD1000CAFC80072
    S31A0010F38D0CAFB9000D0F9B000D4F8C000D4F1D000D4F0E000E51
    S31A0010F3A26BFB000CAFBE000E6BFD000CAFBC000CAFBD000EEB03
    S31A0010F3B7FD000CAFBE000EADFF000EACFF000EABFF000CCE00B0
    S31A0010F3CC000CDD11000CDC88000CDB99000D0F9B000D4F8C008D
    S31A0010F3E10D4F1D000D4F0E000EA9F8000EEDFB000EECFB000C78
    S31A0010F3F6BFDE000E6BFB000CBFCD000CAFBC000E6BFD000CC981
    S31A0010F40BE9000CAF9C000EABFF00397FA80023FFFF00397FA9FC
    S31A0010F420000CAFC2000CAFB3000EA1BF000EA0BD000CAFDC0066
    S31A0010F4350E6CFE000CAFCB000EECBF000CAFFB000EEDBF000C79
    S31A0010F44AAFFC000CBBDB000EEEBF000CAFFD000CBCEC000EAE67
    S31A0010F45FFF0018AF0000037FFF0018A0010016A101000CAF18F7
    S31A0010F474000E68FE000CAF89000370FF000371FF000378FF0056
    S31A0010F4890379FF00397FD60016AF04000CAFEC001ACC01000CEC
    S31A0010F49EAFDB001ADB00000EFB7F0036C2D2000EACFF000EAB00
    S31A0010F4B3FF00397FA80023FFFF00397FA9003AC2B4000CAFC022
    S31A0010F4C8000CAFB1000EACFF000EABFF0018AF01000E1FAA009D
    S31A0010F4DD32C2C50018AF000032C2C3000EACFE000EABFF003924
    S31A0010F4F27FA80023FFFF00397FA9003AC2B4000CAFC0000CAF60
    S31A0010F507B10018AF01000E1FAA0036C2B8000EC0BF000D5F11CF
    S31A0010F51C000CAF1B000CAF0C00397FA80023FFFF000EABBC0031
    S31A0010F5310EACFF0023FFFF000E0BF40032C2AE000E1C59003073
    S31A0010F546C2AA000EABBE000EAC7A0033C2A8000EABBE000EACB5
    S31A0010F55B980023FFFF00397FAD0016AFF80004AFA3000E1FFD2A
    S31A0010F5700032C29E0004ABBF000E2BFB000E1BFF0036C292008A
    S31A0010F5850EA1BE000EA0370018AB02000E2B7F000E1BFF00362E
    S31A0010F59AC292000EA1FF000EA01C0018AB34000E2BFD000E1B24
    S31A0010F5AFFF0032C260000EA1BF000EA0BD000EA3BE000EA25C8A
    S31A0010F5C40018AF030002FF040018AF040002FF05000EA1FF00CE
    S31A0010F5D90EA01C0018A4070018A506001AAF060001BF5F001AAF
    S31A0010F5EEAF070001BF5E000EACFF000EABFF000CAF5D000CAFDA
    S31A0010F6034E003AC0770002FB060002FC07000EACFF000EABBFE4
    S31A0010F618000CAF5D000CAF4E003AC0770002FB000002FC010039
    S31A0010F62D1EAF060002FF02001EAF070002FF03001EAC05001E17
    S31A0010F642AB04000CAF5D000CAF4E003AC03D000EA1FE000EA03B
    S31A0010F6574D0002CB000002CC01000EA3FF000EA21C000CAF3137
    S31A0010F66C000CAF200018AF34000EBFFD0002DF34000EA3FE000F
    S31A0010F6810EA24D000EA1FF000EA01C0018AF060002DF02001821
    S31A0010F696AF070002DF030016AF0800397FAC0023FFFF000D9FB1
    S31A0010F6ABEE000E5DBF00397FDC000ECDDF000D5FCC000D5FBB6F
    S31A0010F6C0000EEDFB000EECFB000CBFDE000E6BFB000CBFCD007F
    S31A0010F6D50CAFBC000E6BFD000CAFDB000CAFEC0023FFFF000CB3
    S31A0010F6EAAFC0000CAFB10018AC0300183C010018AB0200187BA6
    S31A0010F6FF0000397FDC000ECDDF000D5FCC000D5FBB000EEDFB3D
    S31A0010F714000EECFB000CBFDE000E6BFB000CBFCD000CAFBC00A9
    S31A0010F7290E6BFD000CAFEC0018CC01000CAFDB0018DB00002307
    S31A0010F73EFFFF00397FAD000CAFC4000CAFB5000EA0FF000EA1F2
    S31A0010F753FF000EA8FF000EA9FF001CAF00001CBF010032C22363
    S31A0010F768000EA3FF0033C1DA001CAC01001CAB00000E0BC0008F
    S31A0010F77D32C21E000E1C000034C21B000EA3F10033C1DA001C88
    S31A0010F792AC01001CAB00000E0BCE0032C216000E1C390030C292
    S31A0010F7A70C000EAEF6000EADFF00397FDC000CAFE0000CAFD104
    S31A0010F7BC000CAFC8000CAFB9000EA3FF0033C1E6001CAC0100D8
    S31A0010F7D10ECCC6001CAB00000EDB31000EAEC0000EADFF00391D
    S31A0010F7E67FDC000CAFE0000CAFD1000CAFC8000CAFB9000D0F63
    S31A0010F7FB9B000D4F8C000D4F1D000D4F0E000E6BFB000CAFBE90
    S31A0010F810000E6BFD000CAFBC000CAFBD000EEBFD000CAFBE00F9
    S31A0010F8250EADFF000EACFF000EABFF000CCE00000CDD11000CAD
    S31A0010F83ADC88000CDB99000D0F9B000D4F8C000D4F1D000D4F4B
    S31A0010F84F0E000CAFE0000CAFD1000CAFC8000CAFB9000EA3F8B9
    S31A0010F864000D0F9B000D4F8C000D4F1D000D4F0E000EEDF70005
    S31A0010F8790EECF7000CBFDE000E6BF7000CBFCD000CAFBC000E3D
    S31A0010F88E6BFD000CC3E3000CAF1B000E2BC0000CAF0C0002EBB2
    S31A0010F8A3000002EC01000CAF3C000EABFF00397FAC0023FFFF17
    S31A0010F8B800397FA90016AFFE000EA3FF000EA21C000EA1FE00D8
    S31A0010F8CD0EA087001AA81D00183818001AA91C00187917000EFF
    S31A0010F8E2F97F0032C1C3000CB89F0032C1C0000EACFF000EAB45
    S31A0010F8F7FF0033C1B3001AAC19001A3C23001AAB18001A7B2254
    S31A0010F90C000C48CC000C59BB000EA1BE000EA0370018AE0A006E
    S31A0010F92118AD090002F9000002F801003A7FBE0016AF02003980
    S31A0010F9367FA80023FFFF00397FA90016AFFE000EA1FE000EA0DF
    S31A0010F94B870018A8180018A917000EF97F0032C198000CB89FE6
    S31A0010F9600036C198000EA1FF000EA01C000CAF8C00183C2300B7
    S31A0010F9750CAF9B00187B22000EA1BE000EA0370018AE0A001822
    S31A0010F98AAD090002F9000002F801003A7FBE0033C196000EACEB
    S31A0010F99FFF000EABFF0016AF0200397FA80023FFFF00397FADD9
    S31A0010F9B40016AFFC000EA1FE000EA0870018AF170002FF0000A6
    S31A0010F9C918AF180002FF01000EA5FF000EA41C001EAC01001EC9
    S31A0010F9DEAB00001C0B1C0032C184001C1C1D0034C17F001CAF05
    S31A0010F9F31C0002FF00001CAF1D0002FF01001EAC01001C3C239C
    S31A0010FA08001EAB00001C7B22003A7FC00002FB020002FC0300D8
    S31A0010FA1D1CAC1D001C3C19001CAB1C001C7B18003A7FC0001E3F
    S31A0010FA32AE03001EAD02000C0DBF0032C16E000C1ECF0030C108
    S31A0010FA4768001CAC1D001C3C19001CAB1C001C7B180033C164EC
    S31A0010FA5C001EAC01001C3C23001EAB00001C7B220016AF0400EE
    S31A0010FA71397FAC0023FFFF00397FA9000EA1FE000EA08700188A
    S31A0010FA86AE010018AD00000EABFE000EAC51003AC2F800397F73
    S31A0010FA9BA80023FFFF00397FA90016AFFA0002FB020002FC0357
    S31A0010FAB00002FD040002FE05000EA3BF000EA2AE001EAF030085
    S31A0010FAC51A3F4E0002FF03001EAF02001A7F4D0002FF02001E95
    S31A0010FADAAC05001A3C50001EAB04001A7B4F0002FB040002FCFA
    S31A0010FAEF05000EA1FE000EA087001EAF020002CF17001EAF037E
    S31A0010FB040002CF180002CB190002CC1A0004AF590032C12800F8
    S31A0010FB1918AC140018CC010018AB130018DB00001ECC0300024C
    S31A0010FB2EFC03001EDB020002FB020018AC160018CC030018AB2F
    S31A0010FB43150018DB02001ECC050002FC05001EDB040002FB049D
    S31A0010FB580033C1100004A85A001A384E0004A95B001A794D00F0
    S31A0010FB6D02F9020002F803000EA1BD000EA0760018A201001810
    S31A0010FB82A3000018AE17000EADFF000EAC17000EABFC00397FE0
    S31A0010FB97DD0002FD000002FE01000CAF9B000CAF8C000CAF3DD1
    S31A0010FBAC000CAF2E003A7FBE0002FB040002FC05001EAF0200FB
    S31A0010FBC10EFF7F0036C107000EAFFF0002FF020002FF03000EBE
    S31A0010FBD6AFFF0002FF040002FF05000EABFF000EAC00001EAE0D
    S31A0010FBEB03001EAD02003AFB060004AF93000E1FFE0036C0FD80
    S31A0010FC000000FD930000FF920016AF0600397FA80023FFFF006C
    S31A0010FC15397FAB000EA5FE003AC2B4000CAFC0000CAFB1001801
    S31A0010FC2AAF01000E1FAA0032C0ED00198C00000D9FFB000CBB36
    S31A0010FC3FCB000CAFB5000EE5FD000CAF5C000EABFF00397FAA3E
    S31A0010FC540023FFFF00397FA9000CAFE2000CAFD3000EA1FE002B
    S31A0010FC690EA0510018AE01001A3E010018AD00001A7D00000CE9
    S31A0010FC7EAFC0000CAFB10018AC010018AB00000D9FEE000E5DF3
    S31A0010FC93BF003AC25500397FA80023FFFF00397FA9000CAFC0D9
    S31A0010FCA8000CAFB1000EA3FE000EA2510018AC010018AB00008D
    S31A0010FCBD1AAE01001AAD00003AC25500397FA80023FFFF000CAE
    S31A0010FCD2AFC0000CAFB10018AC0300183C010018AB0200187BB8
    S31A0010FCE70000397FDC000ECDDF000D5FCC000D5FBB000EEDFB4F
    S31A0010FCFC000EECFB000CBFDE000E6BFB000CBFCD000CAFBC00BC
    S31A0010FD110E6BFD000CAFEC0018CC01000CAFDB0018DB00002319
    S31A0010FD26FFFF00397FA9000CAFC2000CAFB3000EA0FF000EA10C
    S31A0010FD3BFF000EA8FF000EA9FF001AAF00001ABF010032C0A9F5
    S31A0010FD50000EADFF0033C08C001AAC01001AAB00000E0BC000EA
    S31A0010FD6532C0A4000E1C000034C0A1000EADD80033C08C001AF2
    S31A0010FD7AAC01001AAB00000EAED8000EADFF00397FDC000CAF4F
    S31A0010FD8FE0000CAFD1000CAFC8000CAFB9000D0F9B000D4F8C47
    S31A0010FDA4000D4F1D000D4F0E000EEDF7000EECF7000CBFDE00C5
    S31A0010FDB90E6BF7000CBFCD000CAFBC000E6BFD000CAFED000C76
    S31A0010FDCEAF1B000E2BC0000CAF0C0002DB000002DC01000CAF09
    S31A0010FDE3DC000EABFF00397FA80023FFFF00397FA90016AFFEBC
    S31A0010FDF8000D9FEF0002FF01000DCFDF0002FF00000EAEEF00DC
    S31A0010FE0D0EADF1003A7FBE0016AF0200397FA80023FFFF003926
    S31A0010FE227FAD0016AFF8000CAFC4000CAFB50002FD060002FED8
    S31A0010FE3707003AC4D00002FB020002FC03000EAFFE0002FF000F
    S31A0010FE4C000CAF5B000CAF4C001EAE07001EAD06003AC49E002E
    S31A0010FE6102FB040002FC050004AE5E0004AD5F000EAFFF000294
    S31A0010FE76FF01000EAFFB0002FF00003A7FBE001ECC03001EDB4B
    S31A0010FE8B02000EFB7F0036C058000EACFF000EABFF000CAFCE7A
    S31A0010FEA0000CAFBD0004AF5F000EFF7F0032C0420004AF5F00DB
    S31A0010FEB504BF5E0036C042000CAFEC001E3C03000CAFDB001E11
    S31A0010FECA7B02000EA1BE000EA01F00180B0A0032C04700181CBC
    S31A0010FEDF0B0034C042001EAE030018CE0B001EAD020018DD0A2B
    S31A0010FEF4000CAFDB000CAFEC0016AF0800397FAC0023FFFF0054
    S31A0010FF09397FA90016AFFA001E0B0A0032C038001E1C0B0035D6
    S31A0010FF1EC034000EACFF000EABFF0033C01E001E0B080032C01F
    S31A0010FF3331001E1C090030C02D000EACFF000EABBF0033C01ED0
    S31A0010FF480000FF60000EAFFF0002FF01000EAFBF0002FF0000F4
    S31A0010FF5D02FB020002FC030002FD040002FE05000EABC0000EEA
    S31A0010FF72AC77000EAEFF000EADFF003A7FBB0000FE600016AF35
    S31A0010FF870600397FA80023FFFF00397FA9003AC2B4000CAFC03C
    S31A0010FF9C000CAFB10018AF01000E1FAA0032C012000EC0BF009E
    S31A0010FFB10D5F11000CAF1B000CAF0C00397FA80023FFFF003F4B
    S31A0010FFC6FFFF003FFFFF003FFFFF003FFFFF003FFFFF003FFFE0
    S31A0010FFDBFF003FFFFF003FFFFF003FFFFF003FFFFF003FFFFFCB
    S3150010FFF0003FFFFF003FFFFF003FFFFF003FFFFFF7
    S70500100000EA
    Thank you for sending that over. I forgot to ask but now can you send the srec file from a golden unit that does not experience the abnormal Ra table value.
    Regards.
    Adrian
  • FYI
    S00F00004657303734325F30315F303304 S31A000040008064476F9501DB6D05BD020000F751F6C9F4145209FF S31A0000401521326D00000000CFDC17F30000167A00003564F9A158 S31A0000402A0015300100EF0522050100001001003C00503C0064DC S31A0000403F3C002012560010EFFC7FF2A90003003203E80101016A S31A00004054F4001EC81408003C0E10000A46050F050F0320003234 S31A00004069006446500A0EE70E9B0190006419DC5C6000C8000428 S31A0000407E0332000100140001001403230708255A0F1E600D4832 S31A0000409300C82801F40000000000000000000043800400C8009E S31A000040A80001140036000000000582000A138800C80A03002889 S31A000040BD0F21340A01F403E8521110FC10C610971078105810AE S31A000040D23C101F10050FEB0FD20FBA0FA30F900F7D0F6C0F5CEC S31A000040E70F4B0F3A0F1E0F070EF80EEC0EE40EDC0ED60ED10E2B S31A000040FCCD0ECA0ECC0EC80EC20EBC0EAD0E9F0E8C0E790E78AB S31A000041110E620DE80BE8FBB5FD63FE4CFE77FEB6FE75FEDCFE6D S31A0000412679FE9CFE87FF0DFF19FED1FEC0FEB5FE56FEBDFF3B39 S31A0000413BFE30FEDCFFEB003AFFD1FFFEFF86FF69FF69FE81FBA1 S31A0000415096F91DF74EF58CF7DDF7A1F53CFAE4FA2AFD7BEEEDF0 S31A00004165B70DFFD0FFD1FFD0FFC3FFBBFFD5FFD4FFD1FFD8FF44 S31A0000417AD8FFD0FFE1000400A30099FF20FF27FF26FF20FF4A91 S31A0000418FFF33FF40FEE0FEE1FED7FEC4FEBCFE0CFDD6FF0210A8 S31A000041A4FEFFCE022601C20019006428FF62FF620032000A2D7A S31A000041B9323C0110FE10FE10CC109A32505050097F8018800B0D S31A000041CE07001404000AF0000F05003201C214089800003C00C4 S31A000041E34B0028003C3C01019019861115FFFFFFFF234545676F S31A000041F889ABCDEFFEDCBA9876545432000002580BB810FE0015 S31A0000420D0000000038000A1964003C000000000000000000009B S31A0000422200000000000000000000000000000000000000000081 S31A000042370000000000000000000000000011490110E009C40153 S31A0000424C0A28003C01F40501C2025805022610B310CC10E51001 S31A00004261FE1117113011491162116212AB0E00000000000000D0 S31A0000427600000000000D009B7A28F70000038A000000120ED867 S31A0000428B0031000000010000119411A84318FE7050000A7F07DF S31A000042A001009600AF004B00640B54020BB810CC021068000094 S31A000042B5000000000000000000000000000000000000000000EE S31A000042CA000000000000000000000000000000000000000000D9 S31A000042DF000000000000000000000000000000000000000000C4 S31A000042F4FFFFFFFFFFFFFFFFFFFFFFFF0055005100520055006E S31A000043095E006F0059006100640067006B0064007500950192DB S31A0000431E046E0000000000000000000000000000000000000012 S31A0000433300000000000000000000000000000000510052005577 S31A00004348005E006F0059006100640067006B006400750095012E S31A0000435DB304CB000000000000000000000000000000000000C3 S31A00004372000000000000000000000000000076545432000002DE S31A00004387580BB810FE000000000038000A1964003C00000000F7 S31A0000439C00000000000000000000000000000000000000000006 S31A000043B1000000000000000000000000000000FFFFFFFF0001F4 S31A000043C62FCDFFFED031FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1 S31A000043DBFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDC S315000043F0FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC7 S31A001000000033FFEA0033FBEB0033FC6D0033FE650033FE7D00C0 S31A00100015155454003FFFFF003FFFFF003FFFFF003FFFFF003FD0 S31A0010002AFFFF003FFFFF003FFFFF003FFFFF003FFFFF003FFF7B S31A0010003FFF003F01030033CB58000800ED000000000000000009 S31A00100054000EAAFF000EA7FB000EA6FF000EA1FF000EA0FF000C S31A001000690EA3FE000EA247003AFFD2000EA1FF000EA058000EF9 S31A0010007EA3FF000EA257000EA5BD000EA40C003AFFCA000EA1CE S31A00100093FE000EA047000EA3FE000EA247003AFFCA003AFFC2AB S31A001000A80033FFD6000EAFFF00034F01000C113F0030FFCD00BE S31A001000BD35FFD4000C102F0035FFD40023FFFF0014AF010003D5 S31A001000D24F01000C113F0030FFC50035FFCC000C102F0035FFE4 S31A001000E7CC0023FFFF000BDFFF0033FFC400397FA90016AFFEFE S31A001000FC000EABC1003A7FE20001BCD5000E1C8B0036FFB60092 S31A001001110E1C030036FFB6000E1CBA0036FFB6003A7FFB000E1A S31A00100126ABC1003A7FE2000CAFBC000EABFF0001BCD5003AFBB1 S31A0010013BB90000FEDE000EAFFF0002FF000002FF01000EACFF8C S31A00100150000EABFF000CAFCE000CAFBD003AFDBB0000FFDE00FC S31A001001650EA1BE000EA0370018AB00000E2BBF000E1BFF003604 S31A0010017AFF9B000EA08F000EA17F0018AB0D000EBBFB0033FF8F S31A0010018F97000EA08F000EA17F0018AB0D000E2B040002CB0D5C S31A001001A4000EA1BE000EA0370018AB00000E2BDF000E1BFF00DB S31A001001B936FF8B000EA08F000EA17F0018AB02000E2B040033BB S31A001001CEFF87000EA08F000EA17F0018AB02000EBBFB0002CBBF S31A001001E302000EA0AF000EA17F000EAFF40002CF00000EBA7F9B S31A001001F8000E2A40003AFF09000EACFE000EABFF0016AF0200EB S31A0010020D397FA80023FFFF0004AFE30004BFE20036FF7300045E S31A00100222A0E20004A1E30002C7000002C6010004AFE50001BFBD S31A00100237E30004AFE40001BFE2000EACFF00041CE10031FF2C6A S31A0010024C0004A0E20004A1E30018AB02000E2B7F000E1BFF00D4 S31A0010026132FF61000EFAFC000CAFFB00182B02000E1BFF003683 S31A00100276FF3A0018AF02000EBF7F0002CF020018A7000018A6BF S31A0010028B010018AB02000E2BDF000E1BFF0036FF4C0016A50105 S31A001002A00016A4010016A9010016A8010018AB02000E2B2000DB S31A001002B502CB02000E2BBF000E1BFF0032FF19000EBADF00330B S31A001002CAFF190016A9010016A801002DFFFF0016AB010016ACC3 S31A001002DF010016AD010016AE010016A5010016A4010016A30139 S31A001002F40016A2010016A1010016A0010016A9010016A8010038 S31A0010030917AF010016AF01003F1FFF0018AB02000E2BBF000E14 S31A0010031E1BFF0032FF340018A7000018A6010004AFE2000ECF45 S31A00100333FC0001BFE200055FE30001BFE3000D1FCC00041CE11E S31A001003480035FF6C0000FFE30000FFE20005BBE0000E1BFE0060 S31A0010035D30FF1F000EABF70004AFE0000E1FFE0032FF22000E58 S31A00100372ABF5000EA0AF000EA17F0002CB00000EBADF000BDFD7 S31A00100387FF000E2A20000EFADF0032FF1D0033FF730023FFFFF9 S31A0010039C000E2A20000EFADF0032FF180004A0E20004A1E300A0 S31A001003B118AB02000E2B80000EBFDF0002CF02000378FF0003A7 S31A001003C679FF000374FF000375FF0033FF7A0023FFFF00397F22 S31A001003DBA9003AFECD00397FA80023FFFF00397FA90016AFFDA5 S31A001003F0000CAFC8000CAFB9000E2A20000EFADF0032FF01007A S31A0010040504ABDF000E2BEF000CBDFF0001BFDF0004AFE0000E0E S31A0010041A2F0B0001BFE0000EAFFC0002FF00000EAFF20002FF73 S31A0010042F01000EAF5F0002FF02000EABFD000CAF9C000CAF8D2D S31A00100444003AFEE70000FFE30000FFE2003AFF7A0016AF030030 S31A00100459397FA80023FFFF000374FF00397FA9000CAFD8000C81 S31A0010046EAFC9001EAE04001EAD03001EA405000EEBFC000CAFD6 S31A00100483FC000CAFC2000EC257000CAFB3000ED3FF000CAFE0C5 S31A00100498000EC001000DFFD10002C9000002C801000ECE030018 S31A001004AD02DE01000DFFDF0002DF000002D40200397FA8001629 S31A001004C2A4010023FFFF00397FA90016AFFD000E2A20000EFAC6 S31A001004D7DF0032FECB003AFE9D0000FFE0000EAFFF0001BFE50B S31A001004EC000EAF570001BFE40000FCE1000EAFFB0002FF000097 S31A001005010EAFFF0002FF01000EAF1F0002FF02000EABFF000E6C S31A00100516ACCE000EAD58003AFEE7000EAFFC0002FF00000EAF97 S31A0010052B980002FF01000EAF5E0002FF02000EABFE000EACD8A4 S31A00100540000EAD83003AFEE7000EAFFC0002FF00000EAFF200CA S31A0010055502FF01000EAF5F0002FF02000EABFD000EACE8000EF4 S31A0010056AAD3C003AFEE70000FFE30000FFE2003AFF7A0016AF23 S31A0010057F0300397FA80023FFFF000EA2FF000EA37F000EAFFF32 S31A001005940002DF40000EAFFF0002DF30000EA1BE000EA03700FC S31A001005A918AB01000E2B7F000E1BFF0036FE8F000EAFFD000204 S31A001005BEDF31001AAB91000E2B1A0002DB91000EAF1A0002DF33 S31A001005D390000EA04F000EA17F000EAFFF0002CF00000EAF00F8 S31A001005E80002DF61001AAB60000E2B020002DB60000E2A43008E S31A001005FD0EAF070002DF930023FFFF00397FA9000E2A04000ECF S31A00100612FAFB000CAFFB000E1BFF0032FE76003AFF180004AF40 S31A00100627E0000E1FFE0032FE67000EA1BE000EA02C0018AF0CEC S31A0010063C0036FE6D0000FFA40033FE68000EA1FF000EA01C003E S31A0010065118AF01000E2F200002CF010000FFE000397FA8002325 S31A00100666FFFF00037FFF000CAFFF000B7FFF00037FFF000378AB S31A0010067BFF000379FF000370FF000371FF000372FF000373FF0C S31A00100690000374FF000375FF00037EFF00037DFF00037CFF00D5 S31A001006A5037BFF003EBFFF000378FF000379FF000EA0EF000E11 S31A001006BAA17F0018AB03000E2B7F000E1BFF0036FE460018AB12 S31A001006CF04000EBB7F0002CB040018AB04000E2B800002CB0492 S31A001006E4000EA1FF000EA0570018AF02000EBF7F0002CF020050 S31A001006F933FF7A0023FFFF000E2A20000EFADF0032FE3F000E4D S31A0010070EA0CF000EA17F0018AB01000E2B040002CB01000EBA8C S31A00100723DF0023FFFF000EA0CF000EA17F0018AB01000E2B04FF S31A001007380002CB010018AB01000E2B080002CB010023FFFF00D4 S31A0010074D397FAD0016AFFE000CAFE4000CAFD5000EAFFF00026C S31A00100762FF01000EAFFB0002FF00003A7FBE000CAFC8000CAFFE S31A00100777B9000EA1BD000EA0760018AE17000EADFF000EAC17A6 S31A0010078C000EABFC00397FDD0002FD000002FE01000CAF9B00A2 S31A001007A10CAF8C000CAF5D000CAF4E003A7FBE0016AF0200394E S31A001007B67FAC0023FFFF00397FAD0016AFFA0002FB000002FCAD S31A001007CB01001EA80B001EA90A0004ACCD0004ABCE00397FDCD2 S31A001007E0000CAFDE000CAFCD000CAFBC000E6BFE000CAFE40040 S31A001007F50CAFD5000EA1FE000EA0870018C41E0018D51D000C57 S31A0010080AAF9C000CAF8D000EAFFE00397FD2000CAFE0000CAF95 S31A0010081FD1000CAFC8000CAFB9000E887F0004ADCB0004ACCCD9 S31A00100834000EAFFE00397FD200037EFF00037DFF00037CFF00D7 S31A00100849037BFF000CAF9B000CAF8C000CAF1D000CAF0E003990 S31A0010085E7FD50016AF04003A7FC50002FB020002FC030002FDD5 S31A00100873040002FE05000CAF5C000CAF4D000EAFFE00397FD2ED S31A00100888000CAFE0000CAFD1000CAFC8000CAFB9001E140100F4 S31A0010089D0CAFFC001EAB00000C7B5B000CAFCD000CAFBC000EC1 S31A001008B2AFFE00397FD2001EAF0500037FFF001EAF0500037F3D S31A001008C7FF001EAF0500037FFF001EAF0500037FFF00397FD9D0 S31A001008DC0016AF04000370FF000371FF000378FF000379FF004E S31A001008F1397FD40016AF0400397FD1000CAFDB000CAFEC0016AB S31A00100906AF0600397FAC0023FFFF00397FAD0016AFF80002FB6D S31A0010091B020002FC030002FD040002FE05003AFC82000E1CFFC5 S31A001009300036FD220004ACE40004ABE500041BE30032FDAB0043 S31A00100945041CE20032FDAB003AFBA4003AFBB2003AFCBC000EEB S31A0010095A1CFF0032FDA50000FED40033FD2A001EAB0C000E2B49 S31A0010096FFC001EAC0D000EECF7000E6BF7000CBCFC000E2C012A S31A001009840002FC06001EA50D000E25C0001EAF02001EBF0300D2 S31A0010099936FD2A000E15BF0002FF07001EAC07000EABFF001E45 S31A001009AE1B020032FD91001E1C030034FD8E001EAF030002FF74 S31A001009C307001EAE06000EADFF000EEEDF00037FFF000EEDDF40 S31A001009D8000CBFED0016AE01000EBDBF0002FD0C0002FE0D00D5 S31A001009ED0EABE3003A7FEB001EAF0C0002FF00001EAF0D0002E9 S31A00100A02FF01000EABE3000EACFF000CAF5D003A7F9B001EAF3B S31A00100A170C0002FF00001EAF0D0002FF01000EABE3000EACFF76 S31A00100A2C000CAF5D003A7F9C000E1CFF0036FDA7001EAF04005E S31A00100A4102FF00001EAF050002FF01000EABE3000CAF5C001EE4 S31A00100A56AD07003A7F9B001EAF040002FF00001EAF050002FFC8 S31A00100A6B01000EABE3000CAF5C001EAD07003A7F9C000E1CFF5C S31A00100A800036FDA7001EC507000CAF5C000EABFF001ECC0D00C1 S31A00100A9502FC0D001EDB0C0002FB0C000CAF54000E44BF001EDF S31A00100AAAAF0C0002FF00001EAF0D0002FF01000EABE3000CAF32 S31A00100ABF5C000CAF4D003A7F9B001EAF0C0002FF00001EAF0DA0 S31A00100AD40002FF01000EABE3000CAF5C000CAF4D003A7F9C00E5 S31A00100AE90E1CFF0036FDA7001EAB06003A7F99000E1CFF00365F S31A00100AFEFDA7003AFCBC000E1CFF0036FDA7001EAC07000EABAA S31A00100B13FF001E1C030002FF03001EAF02000C7FBF0002FF025B S31A00100B28001ECC050002FC05001EDB040002FB04001EAF0600DF S31A00100B3D0ECFFD0002FF06000EA5FF001EAF02001EBF03003219 S31A00100B52FD98003AFBAB0004ACE40004ABE500041BE30032FDAA S31A00100B672200041CE20032FD22003AFB930016AF0800397FACF5 S31A00100B7C0023FFFF00397FAD0016AFFC0002FB02000CAFD40079 S31A00100B910CAFC50002FE03003AFC82000E1CFF0036FD07000299 S31A00100BA6F5000002F401001EAB03001EAC08001EAD02003A7F14 S31A00100BBBED0002F5000002F401001EAB03001EAC08001EAD02C9 S31A00100BD0003A7F9C000E1CFF0032FD070000FED40016AF0400AB S31A00100BE5397FAC0023FFFF00397FAB000CAFB5003AFC82000EC7 S31A00100BFA1CFF0036FCFD000CAF5B003A7FEB00397FAA0023FF48 S31A00100C0FFF00397FA90016AFFC000EA1BD000EA0910018AF0F18 S31A00100C240002FF000018AF100002FF010018AF110002FF0200F0 S31A00100C3918AF120002FF03001EAF00001EBF01001EBF02001E0B S31A00100C4EBF030036FCBF000EA1FF000EA01C0018AB00000E2B54 S31A00100C63DF000E1BFF0036FCD9001EAF03000ECFBC0002FF03E7 S31A00100C78001EAF02000EDFF80002FF02001EAF01000EDF3F00A0 S31A00100C8D02FF01001FFF000002FF00001EAF00001EBF01001E52 S31A00100CA2BF02001EBF030036FCBF003A7FE9001EAF0300037FA1 S31A00100CB7FF001EAF0300037FFF001EAF0300037FFF001EAF03A1 S31A00100CCC00037FFF001E1B000032FCC1001E1C010032FCC1002A S31A00100CE11E1D020032FCC1001E1E030032FCC10016AF04003392 S31A00100CF6FCBF0016AF040000FED40016AF0400397FA80023FF32 S31A00100D0BFF00397FAD0016AFFD000EA5FE000EA03F000EA1BC8E S31A00100D200018A400003A7F97000E1CFF0032FCAF003A7F980045 S31A00100D350EACFE000EABFF0033FC85000E14E00030FC87000EAC S31A00100D4AFADF000CAFFB0002FB02000E2A20000EFADF0032FC83 S31A00100D5FAA000CAF4B003A7FEB000EAFBC0002FF00000EAF7F5F S31A00100D740002FF01000CAF4B000EACFF000EADBF003A7F9B00C5 S31A00100D890EAFBC0002FF00000EAF7F0002FF01000CAF4B000E73 S31A00100D9EACFF000EADBF003A7F9C000CAFC5001EAB02000CBA9F S31A00100DB3BA000E15FF0036FC87003A7F98000EA03F000EA1BCD7 S31A00100DC80018AF00000E1F000032FC88000E25FE0033FC87006F S31A00100DDD0EA5FF000CAF5C000EABFF0016AF0300397FAC00231B S31A00100DF2FFFF000EA1BE000EA02C0018AE010018AD00000EAB4C S31A00100E07FF00041BD40032FC70000EA1FF000EA01C0018A209F5 S31A00100E1C0018A308000C03DF0032FC74000C12EF0031FC7100AD S31A00100E31041BDE0036FC70000EABFE000CAFBC000EABFF0023EE S31A00100E46FFFF00037FFF000CAFFF000B7FFF00037FFF000378C3 S31A00100E5BFF000379FF000370FF000371FF000372FF000373FF24 S31A00100E70000374FF000375FF00037EFF00037DFF00037CFF00ED S31A00100E85037BFF003EBFFF000378FF000379FF000EA26F000EA7 S31A00100E9AA37F001AAC00000E2FFB000CAFFB000E1BFF0036FCFD S31A00100EAF51000EAF040002DF00001AAB01000C2CBC000E2FF737 S31A00100EC4000CAFFB000E1BFF0036FC33000EAF080002DF00001A S31A00100ED90EA0BF000EA17F0018AE020018AD010001BDDD000129 S31A00100EEEBEDC0018AB00000E2BFE000E1BFF0032FC3D0001BDF4 S31A00100F03DB0001BEDA000EA1FF000EA0540018AF02000EBF7F8A S31A00100F180002CF02001AAB01000E2B080002DB01000E2A1000AE S31A00100F2D33FF7A000E2CEF000CAFCB000E1BFF0036FBFF0000E6 S31A00100F42FFD90000FFD80000FFD70000FFD6000EA2CF000EA3FA S31A00100F577F001AAF020001BFD9001AAF030001BFD8000EA0BFBB S31A00100F6C000EA17F0018AB00000E2BFE000E1BFF0032FC1700C5 S31A00100F811AAB01000E2BEF000E1BFF0036FC17001AAF04000118 S31A00100F96BF96001AAF050001BF95000EA0CF000EA17F0018AB4A S31A00100FAB00000E2B800002CB000004AFD30036FC0D0004AFD34A S31A00100FC00002CF000000FFD3000EA1FF000EA0540018AF0200EA S31A00100FD50EBF7F0002CF02000EA06F000EA17F0018AB01000EB5 S31A00100FEA2B100002CB01000EAF100002CF00000E2A100033FFBB S31A00100FFF7A000E2A100016A9010016A801002DFFFF0016AB0199 S31A001010140016AC010016AD010016AE010016A5010016A40100EE S31A0010102916A3010016A2010016A1010016A0010016A9010016E4 S31A0010103EA8010017AF010016AF01003F1FFF0023FFFF00037F51 S31A00101053FF000CAFFF000B7FFF00037FFF000378FF000379FFBA S31A00101068000370FF000371FF000372FF000373FF000374FF0019 S31A0010107D0375FF00037EFF00037DFF00037CFF00037BFF003E99 S31A00101092BFFF000378FF000379FF000EA06F000EA17F000EAF78 S31A001010A7100002CF03000EA3FF000EA230000EA02F000EA17F9F S31A001010BC0018AB01001ABF0E0002DF0E000E2A080016A901006F S31A001010D116A801002DFFFF0016AB010016AC010016AD010016AB S31A001010E6AE010016A5010016A4010016A3010016A2010016A18F S31A001010FB010016A0010016A9010016A8010017AF010016AF0106 S31A00101110003F1FFF0023FFFF00397FA9000EABFF000EAC4E0015 S31A001011250EADFC003A7FA700397FA80023FFFF00397FA9000E98 S31A0010113AABFF000EAC4E000EADFC003AFB8300397FA80023FFE7 S31A0010114FFF00397FA9000EABFF000EAC4E000EADFC003AFB4F1A S31A0010116400397FA80023FFFF000EA06F000EA17F0018AB0100D0 S31A001011790CAFBE000EADFF0004ABFF000E2BEF000E1BFF0036E4 S31A0010118EFB98000E2E80000CAFEB0033FB96000E2E40000CAF46 S31A001011A3EB0002CB01000E2A040023FFFF000EA06F000EA17FC0 S31A001011B80018AB01000CAFBE000EADFF0004ABFF000E2BEF003F S31A001011CD0E1BFF0036FB87000EBE7F000CAFEB0033FB85000E65 S31A001011E2BEBF000CAFEB0002CB010023FFFF00397FAD0016AFA6 S31A001011F7FF000CAFC4000CAFB5000EFADF000CAFFB0002FB0045 S31A0010120C000E2A20000EFADF0032FB7C001CAF000036FB56007D S31A001012210D1F40000D5F51000DBFDD0036FB5E000CAF42000E36 S31A00101236C2FC000D5F530018AF000018BF010032FB640004AF2D S31A0010124BE30002CF000004AFE20002CF010004A0E20004A1E34F S31A001012600018AF020002DF000033FB5E000EC2FC000D5F3300C2 S31A001012750EC0FC000D5F11000DBFDD0032FB70001EAB00000CEC S31A0010128ABABA0004A0E20004A1E30018AF02000E2F030002CFDD S31A0010129F02003AFF18000EAFFE0002EF00001EAB00000CBABADC S31A001012B40016AF0100397FAC0023FFFF00397FAD0016AFFF009B S31A001012C90CAFC8000CAFB9000EFADF000CAFFB0002FB00000E5B S31A001012DE2A20000EFADF0032FB48000D1F84000D5F95000CAFD3 S31A001012F380000CAF910018AF010018BF020036FB1A0018AF0150 S31A0010130800037FFF0018A0020016A101001CAB02000E2BFC00C9 S31A0010131D0EBB7F0018BF020002CF02000ECD010036FB1F000C79 S31A00101332AF82000EC2FC000D5F93000CAF80000EC0FB000D5F24 S31A00101347910018AF000002EF000018AF010002EF010018AF02AF S31A0010135C0002DF00000EC0FC000D5F11000EC2FC000D5F3300D3 S31A001013710EC4FC000D5F55000DBFDD0032FB2D000EAFFF000201 S31A00101386EF000002EF01003AFB110033FB16000CAF82000CAFD9 S31A0010139B93000EAFFF0002DF00001EAB00000CBABA0016AF01E8 S31A001013B000397FAC0023FFFF0004A0E20004A1E30018AF0200B6 S31A001013C50EBFDF0002CF02000378FF000379FF000374FF000310 S31A001013DA75FF0033FF7A0023FFFF0016AFFF000CAFC0000CAFAD S31A001013EFB1000EFADF000CAFFB0002FB00000E2A20000EFADF49 S31A001014040032FB000002CD000002CE01001EAB00000CBABA00A7 S31A0010141916AF010023FFFF0016AFFF000EFADF000CAFFB00025E S31A0010142EFB00000E2A20000EFADF0032FAF3000EA1BE000EA01F S31A00101443370018AB00000E2BDF000E1BFF0036FAE5000EA08FF2 S31A00101458000EA17F0018AB02000EBBFB0033FAE1000EA08F0067 S31A0010146D0EA17F0018AB02000E2B040002CB02001EAB00000C80 S31A00101482BABA0016AF010023FFFF0016AFFF000EFADF000CAF7E S31A00101497FB0002FB00000E2A20000EFADF0032FAD8000EA1BE82 S31A001014AC000EA0370018AB00000E2BDF000E1BFF0036FACA0033 S31A001014C10EA08F000EA17F0018AB02000E2B040033FAC6000E92 S31A001014D6A08F000EA17F0018AB02000EBBFB0002CB02001EAB6D S31A001014EB00000CBABA0016AF010023FFFF000EA1FF000EA01CF7 S31A001015000018AF01000EBF7F0002CF01000EA02F000EA17F00CF S31A0010151518AB00000EBBFB0002CB000023FFFF000EA02F000E4B S31A0010152AA17F0018AB00000E2B040002CB00000EA1FF000EA04D S31A0010153F1C0018AF01000E2F800002CF010023FFFF00397FA98C S31A001015540016AFFA000CAFC0000CAFB1001EA809001EA9080028 S31A001015690CAFDC000E6CFE000CAFCB000CAFCB000CAFDC000C99 S31A0010157EAFED000EAEFF0002FB000002FC010002FD020002FEEE S31A00101593030002F9040002F805000CAF1B000CAF0C003AFA92C9 S31A001015A80016AF0600397FA80023FFFF00397FA90016AFFA00AC S31A001015BD1EAE0D001EAD0C000E1DFE0032FA8B000E1EFF003414 S31A001015D2FA88000EAEFF000EADFE001EAF080002FF00001EAF55 S31A001015E7090002FF01001EAF0A0002FF02001EAF0B0002FF0318 S31A001015FC0002FD040002FE05003A7FA10016AF0600397FA80037 S31A0010161123FFFF00397FAD0016AFFE000CAFC2000CAFB3000C6E S31A00101626AFE4001A3403000CAFD5001A7502001EAF07001A3F67 S31A0010163B050002FF01001EAF06001A7F040002FF00001AA00151 S31A00101650001AA100000CAF18000E68FE000CAF89000CAF5B0013 S31A001016650CAF4C000CAF5D000CAF4E00397FDC00037EFF00031B S31A0010167A7DFF00037CFF00037BFF000370FF000371FF0003786E S31A0010168FFF000379FF00397FDA0016AF08001B1801001B5900AF S31A001016A4000CAF80000CAF91000CAF18000E68FE000CAF890009 S31A001016B90370FF000371FF000378FF000379FF00397FD6001688 S31A001016CEAF04001ACE090002DE09001ADD080002DD08001ADC88 S31A001016E3070002DC07001ADB060002DB06001AA001001AA1009C S31A001016F8000CAF18000E68FE000CAF89001EAC01001EAB0000A8 S31A0010170D0CAF5D000CAF4E00397FDC00037EFF00037DFF0003FA S31A001017227CFF00037BFF000370FF000371FF000378FF000379C9 S31A00101737FF00397FDA0016AF08001B1801001B5900000CAF8046 S31A0010174C000CAF91000CAF18000E68FE000CAF89000370FF0029 S31A001017610371FF000378FF000379FF00397FD60016AF04001A84 S31A00101776CE0D0002DE0D001ADD0C0002DD0C001ADC0B0002DCB3 S31A0010178B0B001ADB0A0002DB0A001B1F010002DF01001B5F00AB S31A001017A00002DF00001AAF0100037FFF001AAF0000037FFF00A8 S31A001017B50CAF5D000CAF4E00397FD80016AF02001ACE030002A4 S31A001017CADE03001ADD020002DD02001AAF0100037FFF001AAF25 S31A001017DF0000037FFF001EAE03001EAD0200397FD80016AF026B S31A001017F4001ACE050002DE05001ADD040002DD040016AF020053 S31A00101809397FAC0023FFFF00397FAD000CAFC2000CAFB3000CD3 S31A0010181EAFE4000CAFD5001AAF06001ABF07001ABF08001ABF13 S31A00101833090032F9EE001AAC05001AAB040033F9BD001AAE0D16 S31A00101848001AAD0C001AAC0B001AAB0A000EAFFE00397FCD00C2 S31A0010185D0CAFE0000CAFD1000CAFC8000CAFB9000CAF4C001A21 S31A001018723C03000CAF5B001A7B02000CAFCD000CAFBC000EAFA3 S31A00101887FE00397FD2000370FF000371FF000378FF000379FFD4 S31A0010189C00397FD90016AF04000CAFE0000CAFD1000CAFC8001D S31A001018B10CAFB9001AAE09001AAD08001AAC07001AAB06000E52 S31A001018C6AFFE00397FCD00037EFF00037DFF00037CFF00037BCA S31A001018DBFF000CAF9B000CAF8C000CAF1D000CAF0E00397FD518 S31A001018F00016AF0400397FD1000CAFEC001ACC05000CAFDB0053 S31A001019051ADB0400397FAC0023FFFF00397FA90016AFFE000C09 S31A0010191AAFC8000CAFB9000CAFE2000CAFD3000EA1BD000EA072 S31A0010192F760018AE17000EADFF000EAC17000EABFC00397FDD65 S31A001019440002FD000002FE01000CAF9B000CAF8C000CAF3D00E3 S31A001019590CAF2E003A7FBE0016AF0200397FA80023FFFF003982 S31A0010196E7FA9003AF98900397FA80023FFFF0000FFD3000EA069 S31A00101983CF000EA17F000EBB7F0002CB000023FFFF00397FA9A5 S31A00101998000E2A20000EFADF0032F999000EA06F000EA17F00D6 S31A001019AD18AB01000EBBEF0002CB01003AFF180004AED70004E7 S31A001019C2ADD80004ACD90004ABD9000E6BFE00397FA80023FF6B S31A001019D7FF00397FA9000EBB7F0001BBD3000E2A20000EFADF6F S31A001019EC0032F986000EA06F000EA17F0018AB01000EBBEF0058 S31A00101A0102CB01003AFF180004AED70004ADD80004ACD90004FC S31A00101A16ABD9000E6BFE00397FA80023FFFF00397FAD0016AFFF S31A00101A2BFD000CAFC4000CAFB50002FD02000E1DFF0032F961ED S31A00101A40000EA1BF000EA0E7001805080032F96A001814090089 S31A00101A5531F9660018A40B0018A50A0033F92D000EAFFB000235 S31A00101A6AFF00000CAF1B000CAF0C0033F932000EAFEC0002FFAD S31A00101A7F00000EAF770002FF01000EAC9F000EABFF000CAF5DDD S31A00101A94000CAF4E003A7FBE000CCC44000CDB5500041499009E S31A00101AA90CAFFC0004AB9A000C7B5B000EA1BF000EA0FF0018FD S31A00101ABEAE17000E4E000018AD16000E5D800004AF99000E4F6D S31A00101AD3000002FF010004AF9A000E5F800002FF00003A7FBE34 S31A00101AE8000EA1BF000EA0FF0018AE170018AD16000CC4CF0061 S31A00101AFD02FF01000CD5BF0002FF00000CAFDB000CAFEC000CD2 S31A00101B12AF5D000CAF4E003A7FBE000CAFC4000CAFB5000EAF70 S31A00101B27FB0002FF00000EABBF000EACF1000CAF5D000CAF4E53 S31A00101B3C003A7FBC000CAFC4000CAFB5000EA1BE000EA03700C8 S31A00101B5118AB01000E2BFE001E1B020032F922000EABFE000E21 S31A00101B66ACAD000CAF5D000CAF4E003A7FA6001EAC02000EABF6 S31A00101B7BFF000CAFC0000EC0F4000CAFB1000ED1BF0018AC0035 S31A00101B90000CAFCB000E6BFE000CCC44000CDB55000CAF5B00BF S31A00101BA50CAF4C0016AF0300397FAC0023FFFF00397FAD001646 S31A00101BBAAFD4000CAFC4000CAFB5000E1DFF0036F9050004AF7D S31A00101BCFBF000E2F040001BFBF0000FFB5000EAFFF0002EF0308 S31A00101BE40033F86F001CAF030032F864000EA1FE000EA09C00E9 S31A00101BF918AF02001C3F050002FF2B0018AF01001C7F04000203 S31A00101C0EFF2A000EA1BE000EA05C0018A80C000EA9FF0003780E S31A00101C23FF000379FF000EAEEF000EADF100397FD80016AF026E S31A00101C38001EAC2B001EAB2A00397FDC000CAFDE000CAFCD00E4 S31A00101C4D0CAFBC000E6BFE000EA3FF000EA21C001AAC0900181B S31A00101C62CC0B001AAB080018DB0A00180B000032F8E100181C54 S31A00101C77010035F86F00180D060032F8DD00181E070031F86F9E S31A00101C8C001D1F010002EF01001D5F000002EF00001CA20100D2 S31A00101CA11CA300000C139F0032F8D3000C128F0035F864001E42 S31A00101CB6AC2B001EAB2A00180B080032F8CD00181C090034F8AE S31A00101CCB6F001D1F020002EF02000E1FFD0032F86D000EAFFED2 S31A00101CE00002EF030018AF0D000E1F000032F8C00004AFBF0088 S31A00101CF50EBF7F0001BFBF0018AF0F000E1F000032F8BA00040E S31A00101D0AAFBF000EBFBF0001BFBF000EA1BF000EA0BD000EA3AB S31A00101D1FFF000EA21C001AAF0800037FFF001AA2090016A301FD S31A00101D34001813030032F8AE001812040036F8A5000EAFBF0001 S31A00101D4902FF00000EAFBA0002FF01000EACFD000EABFF000E78 S31A00101D5EADFF000EAE14003AFDBB000CAF6C000ECCFD000D5F82 S31A00101D737B000EADFE003AE59B000EA1FE000EA04D000EAFFFF3 S31A00101D880002CF040002CF05003AC2A70004AFBF000EBFFB00A8 S31A00101D9D01BFBF000EA1FF000EA01C0018AB34000E2BBF000E27 S31A00101DB21BFF0036F88C000CAF6C000ECCFD000D5F7B000EAD92 S31A00101DC7FC0033F888000CAF6C000ECCFD000D5F7B000EADFEA4 S31A00101DDC003AE3130004AFBF000EBFFB0001BFBF000EA1BE0086 S31A00101DF10EA0370018AB01000E2BEF000E1BFF0036F86D000E25 S31A00101E06A3FE000EA287000EA1FF000EA01C001AAC18001AABBE S31A00101E1B1700180B1C0032F87500181C1D0031F86D0018AF1CDD S31A00101E300002DF170018AF1D0002DF180033F86D000EAFFF005E S31A00101E4502EF02000EAFFF0002EF000002EF01000EA1FE000E25 S31A00101E5AA09C0018AF010002EF040018AF020002EF050016AFE0 S31A00101E6F2C00397FAC0023FFFF00397FAD0016AFF7000CAF6C4F S31A00101E84000ECCFD000D5F7B000EADFE003AF912000EAFFF00BB S31A00101E9902FF080004AF620032F845000EA1BF000EA0BD0018A0 S31A00101EAEA40A0018A509000CAF5B000CAF4C003AC414003AE745 S31A00101EC3E0000CAFCB0004AFD20002FF000004AFD10002FF0182 S31A00101ED8000CAF5C000CAF4D000EAEF7003AC8B6000EA5BF00E3 S31A00101EED0EA4AE000CAF6C000ECCFD000D5F7B000EADFF003A91 S31A00101F02F912001FBF080002FF08000E1F000032F837000EAF6F S31A00101F17FB0002FF08003AC564001CAC41001CCC43001CAB40FD S31A00101F2C001CDB42000EA1FE000EA0D80018AF2400037FFF00B2 S31A00101F4118A0250016A101000C01BF0032F82A000C10CF0034A1 S31A00101F56F818001CAC68000EABFF000EA1FF000EA01C0018AF29 S31A00101F6B2A00037FFF0018A02B0016A101000C11BF0032F81EE1 S31A00101F80000C10CF0034F818003AEFA9000EA1FF000EA0470092 S31A00101F950EAFFF0002CF15003AEE850004AFA3000E1FFD00361C S31A00101FAAF843000EA3FF000EA21C001AAB34000E2BBF000E1B3B S31A00101FBFFF0032F804000EA1BF000EA0AE0018AC1E0018CC6BCF S31A00101FD40018AB1D0018DB6A001A0B080032F805001A1C09000A S31A00101FE935F8010004AFBF000EBFFD0001BFBF0016AF090039DD S31A00101FFE7FAC0023FFFF00397FAD0016AFAA0004AFB50032F707 S31A00102013F0000CAF6C000ECCD1000D5F7B000EADFE003AE59B86 S31A00102028000CAF6C000ECCD1000D5F7B000EADFB003AE31300EE S31A0010203D3AF51A000CAF6C000ECCFD000D5F7B000EADFE003A57 S31A00102052F6B1000CAF6C000ECCE1000D5F7B003AF05F0004AFB7 S31A00102067620032F7D3000EA1BF000EA0BD0018A40A0018A5098B S31A0010207C000CAF5B000CAF4C003AC414003AE7E0000CAFCB0083 S31A0010209104AFD20002FF000004AFD10002FF01000CAF5C000CF5 S31A001020A6AF4D000EAEF7003AC8B6000CAF6C000ECCFD000D5F3E S31A001020BB7B000EADFF003AF6B1000E1CFF0036F7C5000CAF6CA2 S31A001020D0000ECCFD000D5F7B000CAF6E000ECEE1000D5F7D0058 S31A001020E53AF2F7000CAF6C000ECCE1000D5F7B000EADFF003AF0 S31A001020FAF4C7003AF4AB0000FE60000EA5FF003AEFE1000C1CE5 S31A0010210F5F0036F7B3003AF5C50000FE61000EA1FF000EA04770 S31A00102124001815150032F7B3000EA5FE000EA3FF000EA247001A S31A001021391AAF160036F7AC000EA5FE000EAFFF0002DF16000E51 S31A0010214E15FF0036F7890004AF620032F788000EA1FF000EA07A S31A00102163470018AC110018AB10003AC414000EA3FF000EA247A9 S31A00102178001AAF150032F799000EA1BF000EA0AE0018AB00000F S31A0010218D1AAE11001AAD100033F792000EA3BF000EA2AE001AD3 S31A001021A2AB69000EA1FF000EA0470018AE110018AD100004AFFC S31A001021B7D20002FF000004AFD10002FF01000CAFDC000CAFED65 S31A001021CC000EAEFF003AC8B60033F788003AC39F003AEE85007A S31A001021E13AF502000EA3BF000EA2AE001AAC2E000EABFF001A0E S31A001021F6CC41001ADB40000EA1FF000EA01C0018AF0800037FB3 S31A0010220BFF0018A0090016A101000C01BF0032F777000C10CFD9 S31A001022200030F76F000EA3FF000EA21C000CAF31000CAF2000BA S31A0010223518AF34000EBFEF0002DF340004AFA3000E1F010036F8 S31A0010224AF7D3003AF45A003AF756000EA1FF000EA0470018AF26 S31A0010225F140032F760000EA1BF000EA0BD0018AB02000E2BFCE4 S31A00102274000E1BFD0036F75B000CAF6C000ECCE1000D5F7B00C8 S31A001022890EADFE003AF4C7000EABFA003AC5D90016AF5600399D S31A0010229E7FAC0023FFFF00397FAD0016AFF9000EA1FF000EA04A S31A001022B31C0018AB01000E2BFE000E1BFF0036F6B4000EA3BF71 S31A001022C8000EA2BD001AAB02000E2BFC000E1BFD0032F6B40080 S31A001022DD0EA1BE000EA0370018AB03000E2B7F000E1BFF0036A8 S31A001022F2F6B4000EA1FE000EA0870018AF100032F6B40018ACBE S31A00102307090018AB08003AE1900002FB050002FC06000EA3BFB6 S31A0010231C000EA2AE001AA43D000EA5FF000EA1FE000EA08700A9 S31A0010233118AC070018AB06003A7FC0000CAFCE000CAFBD000C67 S31A00102346AF5B000CAF4C003A7FB6001EA206001EA305000C1341 S31A0010235BBF0032F726000C12CF0031F6B4000EAFFC0002FF00C7 S31A00102370000CAF6C000ECCFD000D5F7B000EADBF000EAEBD006A S31A001023853A7FE0000EA1FE000EA0870018AE0B0018AD0A000E04 S31A0010239AABFE000EAC4F003AC2F8000CAFC4000CAFB5000EA3D2 S31A001023AFBF000EA2AE001AAC28000EABFF000EAEFF000EADBF0B S31A001023C4003A7FB9000C15BF0032F70A000C14CF0030F7030050 S31A001023D90EA1FF000EA01C0018AB34000E2BEF000E1BFF0036E4 S31A001023EEF6DE000EA3BF000EA2AE001AAC2D000EABFF000EA1C8 S31A00102403FE000EA0870018AF1100037FFF0018A0120016A101A0 S31A00102418000C11BF0032F6F6000C10CF0035F6DE000EA1BD003F S31A0010242D0EA076001AAC3F000EABFF0018AE0D0018AD0C0039C6 S31A001024427FDC000CAFDE000CAFCD000CAFBC000E6BFE000EA354 S31A00102457FE000EA287001A0D060032F6E5001A1E070030F6DEA8 S31A0010246C000EABFE000EAC7B003A7FA0003AE12C0002FB0200BA S31A0010248102FC03000EA5BF000EA4BD001EAC03001EAB02001C9A S31A001024961B000032F6D6001C1C010036F6B4000CBCBF0036F636 S31A001024ABB8000CAF6C000ECCFD000D5F7B003AE0A7000EA1FEFB S31A001024C0000EA087000EAFFE0002CF100004AF620032F6B4002F S31A001024D51CAF0900037FFF001CA40A0016A501000CAF5B000CDF S31A001024EAAF4C003AC414003AE7E0000CAFCB0004AFD20002FFAD S31A001024FF000004AFD10002FF01000CAF5C000CAF4D000EAEFF52 S31A00102514003AC8B60033F6B4000EABFE000EAC7D000EADF60068 S31A001025293A7FB20016AF0700397FAC0023FFFF00397FAD001650 S31A0010253EAFF8000CAFC4000CAFB5000EAFFF0002FF00000E1DF4 S31A00102553FF0036F69A000EADE3003A7FB2000EABFE000EACA975 S31A00102568003A7FA50002EB180002EC19000EA1BF000EA0AE0014 S31A0010257D18AE030018AD02000CAF5B000CAF4C003AF48B00339A S31A00102592F5CA000CAF5B000CAF4C003AF4350002FC03000EAB25 S31A001025A7FE000EACA9003A7FA5000CAFCE000CAFBD000CAFDCB2 S31A001025BC000E6CFE000CAFCB001CCE100002EE10001CDD0F00F4 S31A001025D102ED0F001CDC0E0002EC0E001CDB0D0002EB0D001DC4 S31A001025E61F110002EF11001CAC11000EABFF000CAFCE000CAFC3 S31A001025FBBD000CAFDC000E6CFE000CAFCB00037EFF00037DFF64 S31A0010261000037CFF00037BFF001CAE10001CAD0F001CAC0E001C S31A001026251CAB0D00397FD60016AF04000CAFE8000CAFD9000C1C S31A0010263AAFCE000CAFBD0002F9010002F802001CAF1A001CBFC8 S31A0010264F1B0036F666001DBF1B0002EF1B001DFF1A0002EF1A6F S31A00102664000CAF4C000ECCF2000D5F5B000CAF9D000CAF8E0010 S31A001026793AF482000E1CFF0032F62F000EA3BF000EA2AE001C1C S31A0010268EAF11001A1F070035F600000EA1BE000EA01F00199C07 S31A001026A3010019CB00001CAE19001CAD18000C0DBF0032F65013 S31A001026B8000C1ECF0030F64C001AAE05001AAD040033F64A0081 S31A001026CD1AAE03001AAD02000CAF5B000CAF4C003AF48B001E5A S31A001026E2AF010002EF18001EAF020002EF19001CAF0D0002EF72 S31A001026F712001CAF0E0002EF13001CAF0F0002EF14001CAF100F S31A0010270C0002EF15001CAF110002EF17000EAFFF0002EF1600F5 S31A001027210EAFFF0002EF11000EAFFF0002EF0D0002EF0E000214 S31A00102736EF0F0002EF100033F5CA001CA017001CA116000E11C2 S31A0010274B000032F62A000E10FF0030F607001CAF15001CCF10EC S31A001027600002EF15001CAF14001CDF0F0002EF14001CAF13007C S31A001027751CDF0E0002EF13001CAF12001CDF0D0002EF12001C28 S31A0010278AAC11000EABFF000CC0CF0002EF17000CD1BF0002EF7F S31A0010279F16001CAE17001CAD16000EACFF000EABFF00037EFF48 S31A001027B400037DFF00037CFF00037BFF001CAE15001CAD1400C4 S31A001027C91CAC13001CAB1200397FD60016AF040002ED180002D1 S31A001027DEEE19000EAFFF0002EF11000EAFFF0002EF0D0002EF60 S31A001027F30E0002EF0F0002EF10001CAF1A001CBF1B0032F5CAE0 S31A00102808001EAF030036F5CA000CAF40000EC0F2000D5F510068 S31A0010281D0EA3BF000EA2AE001AAC08000EABFF000CAFCE000CA7 S31A00102832AFBD000CAFDC000E6CFE000CAFCB00037EFF00037D7A S31A00102847FF00037CFF00037BFF001CAE08001CAD07001CAC06FC S31A0010285C001CAB0500397FD60016AF010002FF070016AF010063 S31A0010287102FF070016AF010002FF070016AF010002FF07000C8C S31A00102886AFE8000CAFD9000CAFCE000CAFBD000CAF1B000CAF6A S31A0010289B0C000CAF9D000CAF8E003AF482000E1CFF0036F5CA97 S31A001028B0000EA1BF000EA0AE0018AE050018AD04000CAF5B0089 S31A001028C50CAF4C003AF48B000EAFFE0002FF00001EAC00000E94 S31A001028DAABFF0016AF0800397FAC0023FFFF000374FF000375E9 S31A001028EFFF000EA1FF000EA0470018AC0F0018AB0E000EFB7FF0 S31A001029040036F5BB000EACFF000EABFF00191F120002CF120024 S31A0010291936F5AA00183C1100187B100018AE12000EADFF000321 S31A0010292E7EFF00037DFF000CAFCE000CAFBD00397FD80016AF2C S31A00102943020018CE110002CE110018DD100002CD10000EA5BF39 S31A00102958000EA4BD000EA3BF000EA2AE001CAC0A001ACC6300FC S31A0010296D1CAB09001ADB620018AE110018AD10000C0DBF003262 S31A00102982F59D000C1ECF0030F592001CAC0A001A3C63001CAB96 S31A0010299709001A7B620018AE110018AD10000C0DBF0032F593D7 S31A001029AC000C1ECF0031F5900002CB100002CC11000EA1BF0027 S31A001029C10EA0AE0018AF540018BF550036F57F000EA3FF000EE0 S31A001029D6A247001AAC11001AAB1000180B540032F58400181CEB S31A001029EB550034F57F0018AF540002DF100018AF550002DF11AA S31A00102A00000EA1BF000EA0AE0018AF56000EFF7F0032F56E00A3 S31A00102A150EA3FF000EA247001AAE11001AAD1000180D56003292 S31A00102A2AF57300181E570031F56E0018AF560002DF100018AF23 S31A00102A3F570002DF11000EACFF000EABFF000CCCCC000CDBBB6C S31A00102A54000CAFC0000EC047000CAFB1000ED1FF000EAFFE00C2 S31A00102A6902CF0F000EAF7F0002CF0E0016A5010016A4010023AD S31A00102A7EFFFF00397FAD000CAFC4000CAFB5000EA3FF000EA27B S31A00102A9347001AAF08001ABF09001ABF0A001ABF0B0036F52FFD S31A00102AA8000E1DFF0032F5500004AFA3000E1F010032F52F0088 S31A00102ABD1AAF0B00037FFF001AAF0A00037FFF001AAF09000370 S31A00102AD27FFF001AAF0800037FFF001AAE07001AAD06001AACA7 S31A00102AE705001AAB0400397FD60016AF040002ED020002EE03BB S31A00102AFC001AAF0B00037FFF001AAF0A00037FFF001AAF090034 S31A00102B11037FFF001AAF0800037FFF001AAE03001AAD02001A18 S31A00102B26AC01001AAB0000397FD60016AF040002ED000002EEDC S31A00102B3B010033F525000EA1BF000EA0BD0018AF050002EF008B S31A00102B500018AF060002EF010018AF070002EF020018AF08000B S31A00102B6502EF0300397FAC0023FFFF000EA1FE000EA057001901 S31A00102B7A8C02000D9FFB000CBBCB000EEBFD000CAFBC000EAB43 S31A00102B8FFF0023FFFF00397FA90004AFBF000E2F040001BFBF68 S31A00102BA40000FFB5000EA1FF000EA01C0018AF34000E2F100092 S31A00102BB902CF34000EABFF000EAC47000EADE8003A7FB2000E17 S31A00102BCEA3FF000EA247000EA1BF000EA0BD0018AF090002DFB9 S31A00102BE3100018AF0A0002DF1100397FA80023FFFF000374FFFD S31A00102BF8000375FF000EA3FF000EA247000EA5FF000EA41C0014 S31A00102C0D1D9C15001DCB14000EA1BE000EA01F00180B0400323F S31A00102C22F4F500181C050035F4CD001CAE15001CAD14000CAFF8 S31A00102C37DC000E6CFE000CAFCB001ACE030002DE03001ADD02D1 S31A00102C4C0002DD02001ADC010002DC01001ADB000002DB0000D4 S31A00102C611CAE41001CAD40000CAFDC000E6CFE000CAFCB001A85 S31A00102C76CE070002DE07001ADD060002DD06001ADC050002DCBC S31A00102C8B05001ADB040002DB04001B1F0B0002DF0B001B5F0A8A S31A00102CA00002DF0A001B5F090002DF09001B5F080002DF080046 S31A00102CB51B1F0D0002DF0D001B5F0C0002DF0C0033F4CA000E4D S31A00102CCAAFFF0002DF0C0002DF0D0016A5010016A4010023FFBD S31A00102CDFFF00397FAD0016AFFC0002FD03000EAFFF0002FF01E5 S31A00102CF40002FF02000EA5FF000EA447001CAF13000E2F0800E4 S31A00102D0902EF13000D1F6E000D5F7D001EAF030002FF00003A0D S31A00102D1EF01B000E1CFF0036F4AE001EAC02001EAB01001EAD1D S31A00102D3303003AF3E5001CAF13000EBFF70002EF130016AF04F1 S31A00102D4800397FAC0023FFFF00397FAD000EA1BF000EA0AE00AC S31A00102D5D0EA3FF000EA247001AAF0C00037FFF001AA20D00166F S31A00102D72A301001813020032F49F001812030035F48D000EA10E S31A00102D87FE000EA0D80018A4250018A524000EABFE000EACABBF S31A00102D9C003A7FA5000C4C4C000C5B5B000EA1FF000EA04700A5 S31A00102DB1180B0E0032F49000181C0F0034F48D0002CB0E00023B S31A00102DC6CC0F00397FAC0023FFFF000CAFC0000CAFB100181D66 S31A00102DDB1A0032F48600181E1B0034F4830002CD1A0002CE1B37 S31A00102DF00023FFFF00397FAD0016AFFC000CAFC4000CAFB50082 S31A00102E051C1E0C000CAFFC001CAB0B000C7BDB003A7FC00002F6 S31A00102E1AFB000002FC01000EA1BF000EA0AE0018AF060002FFFB S31A00102E2F03000EAFFF0002FF02001CAC0C001CAB0B003A7FC097 S31A00102E44000CAFCE000CAFBD001EAC03001EAB02003A7FB6005B S31A00102E590EAEFF000EADFF001EA001001EA100000C11BF00324D S31A00102E6EF462000C10CF0030F45F000EAEFE000EADFF000CAF46 S31A00102E83DB000CAFEC0016AF0400397FAC0023FFFF00397FA9F3 S31A00102E980016AFF4003AF523000E1CFF0036F438000CAF6C0052 S31A00102EAD0ECCFD000D5F7B000EADFE003AF55F000EA1FF000E39 S31A00102EC2A0470018AF100002FF060018AF110002FF070004AF8D S31A00102ED7CE0002FF080004AFCD0002FF090004AFCC0002FF0AE5 S31A00102EEC0004AFCB0002FF0B000EAFBF0002FF00000EAFB8003F S31A00102F0102FF01000EACF5000EABFF000CAF6E000ECEFD000D2D S31A00102F165F7D003AFDBB0016AF0C00397FA80023FFFF00397FB8 S31A00102F2BAD000CAFC4000CAFB5000EA1BF000EA0AE001CAF004A S31A00102F4000181F080032F42B000EADF2003A7FB2001D1F000082 S31A00102F5502EF00000EABFE000EACAB003A7FA5000CAFCE000C51 S31A00102F6AAFBD000CAFDC000E6CFE000CAFCB001CCE040002EE5D S31A00102F7F04001CDD030002ED03001CDC020002EC02001CDB0153 S31A00102F940002EB01000EA1BE000EA0370018AB03000E2BFB00D8 S31A00102FA90E1BFF0036F410000EABFE000EACA40033F40E000E43 S31A00102FBEABFE000EACA9003A7FA5000CAFCE000CAFBD000CAFC2 S31A00102FD3DC000E6CFE000CAFCB001CCE080002EE08001CDD070F S31A00102FE80002ED07001CDC060002EC06001CDB050002EB0500E8 S31A00102FFD0EABFE000EACA7003A7FA5000CAFCE000CAFBD000C26 S31A00103012AFDC000E6CFE000CAFCB001CCE0C0002EE0C001CDD1F S31A001030270B0002ED0B001CDC0A0002EC0A001CDB090002EB0989 S31A0010303C000EACFF000EABFF000EA1BF000EA0AE001CAF000063 S31A00103051181F080032F3E7000EACFE000EABFF00397FAC002312 S31A00103066FFFF00397FAD0016AFD40002FB230002FC240002FD02 S31A0010307B25003AC2B4000CAFC0000CAFB10018AF00000E1FFA80 S31A001030900032F3D6000CAF0E000ECEBF000D5F1D0033F3D30034 S31A001030A53AC2C1000CAFCE000CAFBD000EABDF000CAF62000E7F S31A001030BAC2FC000D5F73000CAFE0000CAFD10010AF0100035F05 S31A001030CF01000DBFBB0032F3CD000EA1FE000EA0570018AC00E6 S31A001030E4000EABFF000CCCCC000CDBBB000CCCE0000CDBD10053 S31A001030F918AF020002FF260018AF030002FF27000EA1FF000E0E S31A0010310EA01C0018AB01000E2BFB000E1BFF0032F2FA000EA1ED S31A00103123BF000EA0BD0018AB02000E2BFC000E1BFD0032F354BE S31A00103138000EA5BF000EA4AE001CA215001CA314000CAF200019 S31A0010314D0CAF31000EA8FF000EA9FF001EAE27001EAD26000C10 S31A00103162AFDC000E6CFE000CAFCB00037EFF00037DFF00037C3B S31A00103177FF00037BFF000370FF000371FF000378FF000379FFD7 S31A0010318C00397FDA0016AF08000CAFE0000CAFD1000CAFC8000F S31A001031A10CAFB9000E4217000E53FC0002F22B0002F32A000E7F S31A001031B6AFFF0002FF280002FF29001EAE24001EAD23000CAF54 S31A001031CBDC000E6CFE000CAFCB00037EFF00037DFF00037CFF82 S31A001031E000037BFF001EAF2F00037FFF001EAF2F00037FFF004D S31A001031F51EAF2F00037FFF001EAF2F00037FFF00397FDA00160D S31A0010320AAF08000CCE00000CDD11000CDC88000CDB99000EAF61 S31A0010321F1700037FFF000EAFFC00037FFF000EAFFF00037FFF75 S31A00103234000EAFFF00037FFF000CAF9B000CAF8C000CAF1D00BD S31A001032490CAF0E00397FD60016AF04000CAFDB000CAFEC001EDF S31A0010325EAE27001CCE5B001EAD26001CDD5A000C0BDF0032F3CC S31A0010327361000C1CEF0030F358001EAE27001C3E5B001EAD26A4 S31A00103288001C7D5A000C0BDF0032F359000C1CEF0031F3560023 S31A0010329D0CAFDB000CAFEC0002FB230002FC24000CAF6C000E52 S31A001032B2CCFA000D5F7B000CAF6E000ECEDC000D5F7D001EAFAD S31A001032C7260002FF00001EAF270002FF01000EA3FE000EA25709 S31A001032DC001AAF000002FF02003AC618000E1CFF0036F307008A S31A001032F10EA1FE000EA0570018AF02000E1F000032F32E000CAB S31A00103306AF02000CAF13001AAF000002CF01000CAF6C000ECC81 S31A0010331BFA000D5F7B001EAE24001EAD23001EAF260002FF00D4 S31A00103330001EAF270002FF01001AAF000002FF02003AC64C0064 S31A001033450EA1FE000EA0570018AF00000E1FF10032F322001E61 S31A0010335AAF250032F322000EA1FF000EA01C0018AF01000EBF20 S31A0010336FFB0002CF01001EAF23000EFF7F0032F302001EAF23D3 S31A00103384001EBF240036F302000CAF6C000ECCFC000D5F7B000E S31A001033993AC5BB0004AFC90036F3020004ACCF0004ABD0001E8C S31A001033AEAF230002FF00001EAF240002FF01001EAE27001EAD70 S31A001033C326003A7FBE0001BBD00001BCCF003AEF6A0001BBD209 S31A001033D80001BCD10033F302000EA1FF000EA01C0018AF0100D4 S31A001033ED0EBFFB0002CF01000EA3FE000EA257000CAF31000C6D S31A00103402AF200018AF000002DF02001B1F000002CF000016AF56 S31A001034172C00397FAC0023FFFF00397FAD0016AFD00002FB06DC S31A0010342C0002FC070002FD080002FE09000EA1FE000EA05700AE S31A0010344119BF000002FF0A000EA3BF000EA2AE001AAC08000ED3 S31A00103456ABFF000CAFC0000CAFB1000CAF18000E68FE000CAFB8 S31A0010346B89001EA207001EA306000370FF000371FF000378FFC0 S31A00103480000379FF001AAE08001AAD07001AAC06001AAB050072 S31A00103495397FD60016AF010002FF1A0016AF010002FF1A0016A6 S31A001034AAAF010002FF1A0016AF010002FF1A0002FB130002FC3D S31A001034BF140002FD150002FE16001EAF150002FF0D001EAF16D1 S31A001034D40002FF0E000370FF000371FF000378FF000379FF00E4 S31A001034E91AAE0C001AAD0B001AAC0A001AAB0900397FD60016D0 S31A001034FEAF010002FF220016AF010002FF220016AF010002FF20 S31A00103513220016AF010002FF220002FB1B0002FC1C0002FD1D34 S31A001035280002FE1E001EAF1D0002FF0F001EAF1E0002FF100064 S31A0010353D0370FF000371FF000378FF000379FF001AAE04001AA3 S31A00103552AD03001AAC02001AAB0100397FD60016AF040002FBBC S31A00103567230002FC240002FD250002FE26001EAF250002FF0BAC S31A0010357C001EAF260002FF0C001EAC16001EAB15003A7FC000ED S31A001035910CAFC8000CAFB9000EA1BD000EA076000EA3BF000E0A S31A001035A6A2AE001AAF2C00037FFF001AAF2B00037FFF0018AEF9 S31A001035BB0D0018AD0C00397FD70016AF02000C19DF0032F28AFF S31A001035D0000C18EF0030F1D1001AAE03001AAD02000EACFF007E S31A001035E50EABFF000EA1FE000EA0870018AF2200037FFF00189F S31A001035FAAF2100037FFF0018AF2000037FFF0018AF1F00037F85 S31A0010360FFF001E1B000032F274001E1C010032F274001E1D02B0 S31A001036240032F274001E1E030016AF040030F1D1001EAF150007 S31A0010363902FF00001EAF160002FF01001EAC26001EAB25001E84 S31A0010364EAE1E001EAD1D003AC4F20002FB020002FC03000EA3FC S31A00103663FF000EA21C001AAB01000E2BFC000E1BFC0032F1D15D S31A00103678000EA1FE000EA0870018AE070018AD06000EABFE00F6 S31A0010368D0EAC4F003AC2F8000CAFC4000CAFB5000EA3BF000EA8 S31A001036A2A2AE001AAC27000EABFF000EAEFF000EADBF003A7F1A S31A001036B7B9000C15BF0032F24E000C14CF0030F243000EA1BF1B S31A001036CC000EA0AE0018AF290018BF2A0036F1D1001EAC26009E S31A001036E11EAB25003AEF8C000E1CFF0036F1D1000CAF6C000EC5 S31A001036F6CCFD000D5F7B000EA3BF000EA2AE001AAD3B003AE00F S31A0010370BC8000E1CFF0036F1D1000EA1BF000EA0AE0018AC3BE1 S31A00103720000EABFF000EA3BD000EA276001AAE0D001AAD0C008A S31A001037353A7FB9000EA1FE000EA0870018AF0600037FFF0018AF S31A0010374AA0070016A101000C01BF0032F228000C10CF0035F1CC S31A0010375FD1000EA3FF000EA21C001AAF14000EFF7F0036F1D191 S31A00103774001EAC1E001EAB1D003AEF7C000E1CFF0036F1D10096 S31A001037890EA1FE000EA0870018AC070018AB06003A7FC0000C1A S31A0010379EAFC4000CAFB5000EA3FE000EA257001EAC03001A3C44 S31A001037B309001EAB02001A7B08003A7FC0000CAFC8000CAFB90A S31A001037C8000CAF4E000CAF5D000CAFDC000E6CFE000CAFCB0020 S31A001037DD0EECBF000CAFFB000EEDBF000CAFFC000CBBDB000E31 S31A001037F2EEBF000CAFFD000CBCEC000EAEFF000CAF80000CAFE2 S31A0010380791000CAF18000E68FE000CAF89000370FF000371FF95 S31A0010381C000378FF000379FF00397FD60016AF04000CAFE80092 S31A001038310CAFD9000CAFCE000CAFBD000EA1FE000EA087000CE9 S31A00103846AF02000CAF13001B1F120002CF12001B5F110002CF4D S31A0010385B11001AAF0D001ABF0E0032F1E20002D90D0002D80E9F S31A001038700033F1D7000EA1BF000EA0AE0018AF260002FF010079 S31A001038850EAFFF0002FF00000EABFE000EAC7B000CAF9D000C0B S31A0010389AAF8E003AFAAB000EA1FE000EA0870018AF060002CF67 S31A001038AF0A0018AF070002CF0B001EA207001EA306001AA008EA S31A001038C4001AA107001AA806001AA905000D0F9B000D4F8C00E8 S31A001038D90D4F1D000D4F0E000E6BFB000CAFBE000E6BFD000C72 S31A001038EEAFBC000CAFBD000EEBFD000CAFBE000EADFF000EACE9 S31A00103903FF000EABFF000CCE00000CDD11000CDC88000CDB991E S31A00103918000D0F9B000D4F8C000D4F1D000D4F0E000EA0EF0065 S31A0010392D0EA1F1000EA8FF000EA9FF000370FF000371FF00037C S31A0010394278FF000379FF00397FD60016AF04000EA1FE000EA0B6 S31A00103957870018CE010018DD00000EABFE000EAC51003AC2F82C S31A0010396C001EA209001EA3080002DB0E0002DC0F001EAC0E00EE S31A001039811EAB0D001EAE0C001EAD0B003AEF5A000E1CFF0036B5 S31A00103996F062001EA009001EA1080018AC0F0018AB0E001EAEB6 S31A001039AB10001EAD0F003AC4D0001E4C0C001E5B0B001EAE0E65 S31A001039C0001EAD0D003AC41E0002FB110002FC12000EA3BF005A S31A001039D50EA2AE000CAFCF001A3F5D0002FF12000CAFBF001A82 S31A001039EA7F5C0002FF11000EA1BE000EA0370018AB02000E2B75 S31A001039FFFE000E1BFF0036F0DB001AAE03001AAD02000EACFF29 S31A00103A14000EABFF000EA3FE000EA287001AAF2200037FFF007D S31A00103A291AAF2100037FFF001AAF2000037FFF001AAF1F0003B2 S31A00103A3E7FFF001E1B000032F168001E1C010032F168001E1D1A S31A00103A53020032F168001E1E030016AF040030F0DB001EA009F1 S31A00103A68001EA1080018AC0F0018AB0E000EAFFF0002FF00000B S31A00103A7D1EAE10001EAD0F003AC49E0002FB000002FC01001EB2 S31A00103A92AC12001EAB11000EAE17000EADFC003A7FBE000CAFB5 S31A00103AA7C4000CAFB5000EF57F0032F1500004AFCA0036F10522 S31A00103ABC001EAF0D0002FF00001EAF0E0002FF01001EAC0C0051 S31A00103AD11EAB0B001EAE10001EAD0F003AC4F2000CBCBF003693 S31A00103AE6F105000EA1FE000EA05700183C0700187B06000EA16A S31A00103AFBBF000EA0BD0018AE010018AD0000397FDC000ECDDF9C S31A00103B10000D5FCC000D5FBB000EEDFB000EECFB000CBFDE0097 S31A00103B250E6BFB000CBFCD000CAFBC000E6BFD0002FB27000256 S31A00103B3AFC280002FD290002FE2A000EA3FE000EA287001EAF37 S31A00103B4F290002DF00001EAF2A0002DF01000EA1BD000EA076D8 S31A00103B640018A8010018A9000018AE17000EADFF000EAC17004C S31A00103B790EABFC00397FDD0002FD000002FE01001EAC2A001EC5 S31A00103B8EAB29000CAF9D000CAF8E003A7FBE000EA1FE000EA0C5 S31A00103BA3870002CB020002CC03000EA1FF000EA01C0018AF0190 S31A00103BB8000EBFFB0002CF01003AEFA90000FECA000EF57F002C S31A00103BCD36F105000EA1FF000EA047000EAFFE0002CF16000E4E S31A00103BE2A417000EA5FC000EA3BF000EA2AE001AAC41001ACC93 S31A00103BF743001AAB40001ADB42001EAE0C001EAD0B000C0DBF9E S31A00103C0C0032F0FA000C1ECF0035F0EF000EA1FF000EA01C00EC S31A00103C211AAC68000EABFF0018AE2B0018AD2A000C1DBF003298 S31A00103C36F0F0000C1ECF0030F0DB001EA00C001EA10B001A01E0 S31A00103C4B400032F0EA001A10410035F0DB000EA1FF000EA047F4 S31A00103C60000EAFFE0002CF15000EAFFE0002CF160000FEC9002F S31A00103C750CAF5B000CAF4C003AEF6A0001BBD20001BCD1000157 S31A00103C8AB5D00001B4CF001EAB0A003AC37B001EA209001EA331 S31A00103C9F08001A1C0F0002FF2C001A5B0E0002FB2B000EA1BF67 S31A00103CB4000EA0AE0018AF0F0002FF2E000EAFFF0002FF2D009A S31A00103CC91F1B0A003AC37B000CAFC4000CAFB5001EAB0A003A18 S31A00103CDEC37B000C4C4E000C5B5D001EAC2E001EAB2D003A7F6C S31A00103CF3B9001EAE2C001EAD2B000C0DBF0032F0BD000C1ECF4F S31A00103D080035F062000EA1FE000EA0870018AF26000E1F00000D S31A00103D1D32F0B50018AF270002CF26001EA009001EA108001819 S31A00103D32AF0E0002FF040018AF0F0002FF05000CAF6C000ECCC7 S31A00103D47FB000D5F7B003AC22F0002FC2F000EA5FF000EA41C97 S31A00103D5C001CAC07001CAB06003AC2B1001EAE2F000EADFF003E S31A00103D710CCEEE000CDDDD000CCECC000CDDBB001EAE05001E60 S31A00103D86AD04003AC245001CA807001CA906000D9FCE000DCF34 S31A00103D9BBD000CAF9B000CAF8C003AC431000CAFE0000CAFD14D S31A00103DB0000CAFC8000CAFB9001EAD12001EAC11000EAFFE007E S31A00103DC5397FD2000370FF000371FF000378FF000379FF003936 S31A00103DDA7FD90016AF0400397FCF000CAFE0000CAFD1000CAF34 S31A00103DEFC8000CAFB9000E09FF0032F07B000E18FF0032F07BF8 S31A00103E04000E11800032F07B000E10000034F075000EAF800063 S31A00103E1902FF11000EAF000002FF120033F06D000EF97F003650 S31A00103E2EF06F001CAF01000EBFFB0002EF010033F0620002F10C S31A00103E43110002F012001EA209001EA308001AAE0F001AAD0E01 S31A00103E58001EAF110002FF00001EAF120002FF01000CAF3B0089 S31A00103E6D0CAF2C003AFA7A0016AF3000397FAC0023FFFF0039E2 S31A00103E827FA9000EADF1003A7FB2000EABFE000EAC57003AF0E4 S31A00103E9752000EA1FE000EA087000EAF000002CF260002CC2723 S31A00103EAC00397FA80023FFFF00397FAD000CAFC4000CAFB50016 S31A00103EC13AC161003AC3380002EC01000D1FCF0002EF00000E5C S31A00103ED6AF000002EF02001CAC00000EABFF00397FAC0023FF19 S31A00103EEBFF00397FAD0016AFDE003AC2B4000CAFC4000CAFB506 S31A00103F00001CAB00001CAF01000E1FAA0032F01E000E1BFF00C4 S31A00103F1536F01E000E1B000036F01E000E1BFA0036F01E000E5B S31A00103F2AABDF000CAF62000EC2FD000D5F73000CAF40000EC050 S31A00103F3FBF000D5F510010AF0100035F01000DBFBB0032F02EE1 S31A00103F54000EAF000002FF02000EAFAA0002FF030002F5000020 S31A00103F6902F401000EACDF000EABFF000CAF6E000ECEFD000DD6 S31A00103F7E5F7D003AFDBB0016AF2200397FAC0023FFFF00397F26 S31A00103F93AD0016AFFB0002FB000002FC010002FD020002FE0396 S31A00103FA8001EAB09000EAFFF0002FF04000EA5FE000EA45700A1 S31A00103FBD0E1BFF0032F00A001CAB00003AEFA3000E1CFF003693 S31A00103FD2EFE6001EA001001EA1000018AF0000037FFF0018A071 S31A00103FE7010016A101000E01FF0032F001000E10FE0034EFEC9A S31A00103FFC000EA1FF000EA01C0018AB01000E2BFA000E1BFE0004 S31A0010401132EFEC001CAB00003AC37B000CAFCE000CAFBD001E19 S31A00104026AC01001EAB00003AF9FB001EA003001EA1020002CB7C S31A0010403B000002CC01000EAFFE0002FF040033EFEA001D1F0083 S31A001040500002EF00001EAC01001EAB00000EADF1003A7FB200A9 S31A001040651EAC04000EABFF0016AF0500397FAC0023FFFF000358 S31A0010407A74FF000375FF000EA5FE000EA457000EA3FE000EA218 S31A0010408F87001CAF00001A1F270034EFBA000EA1BF000EA0AEAD S31A001040A40018AE030018AD02000EACFF000EABFF001AAF220005 S31A001040B9037FFF001AAF2100037FFF001AAF2000037FFF001A6C S31A001040CEAF1F00037FFF001E1B000032EFC3001E1C010032EFFF S31A001040E3C3001E1D020032EFC3001E1E030016AF040030EFBAED S31A001040F8000EA1FF000EA0470018AF13000EBFFD0002CF130072 S31A0010410D1CAF000002DF27000EA1FF000EA0470018AB13000E2D S31A001041222BF5000E1BFD0032EFAF0018AF13000E2F020002CF72 S31A0010413713000EABFE0033EFAE000EABFF000CAFBC000EABFFDC S31A0010414C0016A5010016A4010023FFFF0000FCD2000017D100FA S31A0010416100FCD0000017CF0000FFC90023FFFF00397FAD00161D S31A00104176AFFE0002FB00000EAFFF0002FF01000E1BF10030EF7D S31A0010418B91003AC161000CAFC4000CAFB5001EAB00003AC37BEC S31A001041A0000C05BF0032EF94000C14CF0035EF91000EAFFE0010 S31A001041B502FF01001EAC01000EABFF0016AF0200397FAC00230C S31A001041CAFFFF000EA1BF000EA0AE0018AE410018CE2A0018AD26 S31A001041DF400018DD29000C0BDF0032EF83000C1CEF0035EF7F03 S31A001041F4000EACFF000EABFF0033EF7D000EACFE000EABFF0020 S31A0010420923FFFF000ECCAB000EDB0A000EA1BF000EA0AE00180F S31A0010421E0B210032EF7500181C220030EF6D00180B230032EF6A S31A001042337100181C240035EF6D000EACFE000EABFF0033EF6B09 S31A00104248000EACFF000EABFF0023FFFF000EA1BF000EA0AE00EF S31A0010425D180B640032EF6500181C650034EF610018AC650018CB S31A00104272AB640033EF5B00180B660032EF5E00181C670031EFD2 S31A001042875B0018AC670018AB660023FFFF00397FAD0016AFFD15 S31A0010429C0002FD000002FE01000EAFFF0002FF02003A7FC000BF S31A001042B10CAFC8000CAFB9000EA1BD000EA076000EA5BF000EDB S31A001042C6A4AE001CAF0E00037FFF001CAF0D00037FFF0018AE02 S31A001042DB0D0018AD0C00397FD80016AF02000C09DF0032EF422C S31A001042F0000C18EF0034EF3F000EAFFE0002FF02003AC1610014 S31A001043050EA1FF000EA01C0018AE070018AD06003AC4D0001E91 S31A0010431A3C01001E7B00001C0B160032EF34001C1C170034EF9E S31A0010432F31000EAFFE0002FF02001EAC02000EABFF0016AF0328 S31A0010434400397FAC0023FFFF00397FA90016AFFF000EAFEB00FC S31A0010435902FF00000EABFF000EAC30000EADBD000EAEFB003A2D S31A0010436E7FE00016AF0100397FA80023FFFF00397FAD000EA566 S31A00104383FF000EA41C001CAB01000E2BFE000E1BFF0036EEF205 S31A00104398001CAC07000ECCAB001CAB06000EDB0A000EADFF002C S31A001043AD3AEEC7001CAC09001CAB08000EADFE003AEEC7001C92 S31A001043C2AC15001CAB14000EADFD003AEEC7000EA1BE000EA072 S31A001043D7370018AB03000E2BFD000E1BFF0036EEFE000EA1FF90 S31A001043EC000EA030000EA22F000EA37F001AAB010018BF0E000E S31A0010440102CF0E000EA3FF000EA230000EA1BD000EA0FB001AF2 S31A00104416AF0E00181F0E0036EEF20004AFC80004BFC70032EE3E S31A0010442BF20000FFC80000FEC700397FAC0023FFFF00397FA902 S31A001044400004AFC80004BFC70036EEDF000EA1BD000EA0FB0034 S31A0010445504ACC70004ABC8000D1FCF0001BFC7000D5FBF0001A0 S31A0010446ABFC800181B120032EEE100181C130035EEDF003AEEE9 S31A0010447FDD00397FA80023FFFF00397FA90016AFFE0000FFC8C9 S31A001044940000FFC7000EA1FF000EA03000191F0D0002CF0D0088 S31A001044A9195F0C0002CF0C000EAFBD0002FF00000EAFFB000252 S31A001044BEFF01000EACEB000EABFF000CAF1D000CAF0E003AFD9E S31A001044D3BB0016AF0200397FA80023FFFF00397FAD0016AFFF92 S31A001044E8000CAFC2000CAFB3000EAFFF0002FF00000CAFDE0068 S31A001044FD0EADFF000CAFE0000EC0FB000CAFD1000ED1BD001836 S31A00104512A80F000EA9FF000EEEFB00037FFF000EEDFB000CBFD8 S31A00104527ED0016AE01000CAFE0000EC030000CAFD1000ED1FFB4 S31A0010453C000CAFE4000EC4FB000CAFD5000ED5BD00180300009D S31A0010455132EEA9001812010034EEA10002C3000002C201000CF2 S31A00104566AF2C001C3C01000CAF3B001C7B000033EE9700180396 S31A0010457B020032EE9E001812030031EE910002C3020002C203EA S31A00104590001C1203000CAFFC001CAB02000C7B3B000C0B9F00D7 S31A001045A532EE94000C1C8F0034EE91000EAFFE0002FF00001EF3 S31A001045BAAF000036EE8A0004AFC80004BFC70032EE8A0000FFCB S31A001045CFC80000FEC7001EAC00000EABFF0016AF0100397FAC88 S31A001045E40023FFFF00397FAD0016AFFE003AE700000EA5FF0090 S31A001045F90EA41C000EA1FE000EA04D001CAC0700183C03001CDF S31A0010460EAB0600187B02003A7FC0000EA1BE000EA05C00180B28 S31A00104623110032EE7400181C120034EE450004AF620032EE45A0 S31A001046380004AFA30032EE6B001CAF34000EBFFE0002EF340087 S31A0010464D33EE450004AFA3000E1F010032EE56000EA5FF000E22 S31A00104662A447001CAC11001CAB10003AC414000EA1BF000EA064 S31A00104677AE0018AB00001CAE11001CAD100004AFD20002FF006D S31A0010468C0004AFD10002FF01000CAFDC000CAFED000EAEFF0083 S31A001046A133EE46000EA1BF000EA0BD0018A40A0018A509000C16 S31A001046B6AF5B000CAF4C003AC414003AE7E0000CAFCB0004AF7C S31A001046CBD20002FF000004AFD10002FF01000CAF5C000CAF4D4C S31A001046E0000EAEF7003AC8B60004AF610036EE400004AF6200B7 S31A001046F532EE40003AC6F8000E2A20000EFADF0032EE40000E95 S31A0010470AA3FF000EA21C001AAB34000E2BFB000E1BFF0036EE9D S31A0010471F2F000EA09F000EA17F0018AB00000EBBFA0002CB0072 S31A00104734001AAF34000E2F040002DF34003AFF180000FF620055 S31A001047490EA09F000EA17F0018AB00000EBBFA0002CB00003A3D S31A0010475EE699000CAFCB000E6BFE003AE6C7003AE6F9003ACCAE S31A00104773320016AF0200397FAC0023FFFF00397FAD000EA1FE8B S31A00104788000EA0870018AC180018AB17000EA5FF000EA41C009B S31A0010479D1CAE1D001CAD1C003AE7D7000CAFC8000CAFB9000E28 S31A001047B2ABFE000EACFC000CAF9D000CAF8E003AFB06000EA1F2 S31A001047C7BE000EA0370018AB01000E2BFB000E1BFF0036EE00E0 S31A001047DC001CAC1D001C3C21001CAB1C001C7B20000EFB7F0032 S31A001047F132EDF6000CBCBF0036EDF60018AB01000E2BFD000EE0 S31A001048061BFF0036EDE8001CAF20000EFF7F0032EDF6001CAF0B S31A0010481B20001CBF210032EDE8000EA5FF000EA41C001CAE21E4 S31A00104830001CAD20000EABFE000EACFA003AFB06001CAE1D00E7 S31A001048451CAD1C000EABFF000EAC04003AFB060000FE930033EE S31A0010485AED6A0004AF900032EDDD000EA1FE000EA0AB0018AFD0 S31A0010486F02000EFF7F0032EDDE0018AF020018BF030032ED9041 S31A001048840033EDC90004AF920036EDD6000EA1FF000EA01C006A S31A0010489918A8210018A9200033EDC3000EA1FF000EA01C0018BF S31A001048AEAC230018AB2200180B200032EDCF00181C210034ED84 S31A001048C3C7000CAFC8000438B9000CAFB9000479BA0033EDC3FD S31A001048D8000EA1FF000EA01C0018A8230004C8B90018A92200F2 S31A001048ED04D9BA000EF97F0032EDB9000EA1FE000EA0870018B1 S31A00104902AF17000EFF7F0032EDB90018AF170018BF180032ED74 S31A00104917B7000EA8FF000EA9FF000EABFE000EACFA000CAF9D90 S31A0010492C000CAF8E003AFB060004AF900036ED6A0004AF9100C8 S31A0010494136EDA7000EA1FF000EA01C0018AE1D0018AD1C000E37 S31A00104956ABFF000EAC04003AFB06000EA1FF000EA01C0018AC57 S31A0010496B190018AB1800180B1C0032EDA000181C1D0034ED9B22 S31A0010498000059FB90001BFB90005CFBA0001BFBA0018AC190051 S31A0010499518AB1800181B1C0032ED9500181C1D0036ED6A000C2F S31A001049AAAFCE0004CEB9000CAFBD0004DDBA0033ED6D000EA587 S31A001049BFFF000EA41C0018AE06000CAFED000E6DFE001CCE2306 S31A001049D4001CDD22000EABFE000EACFA003AFB06001CA819001A S31A001049E91C3823001CA918001C7922000EF97F0032ED71000C76 S31A001049FEB89F0036ED71001CAC1D001C3C21001CAB1C001C7BCB S31A00104A1320000EFB7F0032ED71000CBCBF0036ED71001CAE1942 S31A00104A2800043EB9001CAD1800047DBA0033ED6D000EA1FF0011 S31A00104A3D0EA01C0018AE230018AD22000EABFF000EAC04003A04 S31A00104A52FB06000EA1BE000EA0370018AB03000E2BEF000E1BCF S31A00104A67FF0036ED5A000EA5FF000EA41C001CAE19001CAD1864 S31A00104A7C000EABFF000EAC0A003AFB06001CA823001CA922008A S31A00104A9133ED51000EA5FF000EA41C001CAE1D001CAD1C000E2F S31A00104AA6ABFF000EAC0A003AFB06001CA821001CA920000EA3C1 S31A00104ABBFF000EA21C001AAE13000ECE9C001B5D12000EAF9BD0 S31A00104AD000037FFF000EAFFF00037FFF00397FD80016AF0200A6 S31A00104AE51A4E13001A5D12000EA1BE000EA0370018AB01000E7E S31A00104AFA2BF7000E1BFF0036ED2C000CB89F0032ED2C001AAF81 S31A00104B0F10000EFF7F0032ED2C001AAF10001ABF110036ED2C82 S31A00104B24000EA1BF000EA0AE001AAC09001AAB0800180B40009D S31A00104B3932ED2F00181C410034ED2C000EA8FE000EA9FF000EC9 S31A00104B4EA1BE000EA0370018AB00000E2BF7000E1BFF0036EDBA S31A00104B6314000C09DF0032ED23000C18EF0035ED14000EA1FFE6 S31A00104B78000EA01C0018AC2B0018AB2A000E1BFF0032ED1B000A S31A00104B8D0E1C9C0030ED140004ABBF000E2BFB000E1BFF00320A S31A00104BA2ED14000CAFE8000CAFD9000EABFF000EAC0C000CAF77 S31A00104BB79D000CAF8E003AFB06000EA1FF000EA01C0018AC2155 S31A00104BCC0018CC0F0018AB200018DB0E000CAFCE00183E1D00EB S31A00104BE10CAFBD00187D1C000EFD7F0036ECFE000EABFF000E10 S31A00104BF6AC10000EAEFF000EADFF0033ECFC000EABFF000EACD6 S31A00104C0B10003AFB0600397FAC0023FFFF00397FAD0016AFFD87 S31A00104C200004ABFF000E2BEF000E1BFF0036ECEC000EA0EF00C0 S31A00104C350EA17F0018AB03000E2B7F000E1BFF0032ECE6003349 S31A00104C4AECD4000EA0DF000EA17F0018AB03000E2B7F000E1B1D S31A00104C5FFF0036ECD40004ACC6000EABFF000ECCFD000D5FBB09 S31A00104C74000EA1BE000EA02C0018AE04000EADFF000C0BDF0054 S31A00104C8932ECDB000C1CEF0035ECD7000EAFFE0002FF02003307 S31A00104C9EECD100051FC60001BFC60033ECD30000FFC6000EAF4A S31A00104CB3FF0002FF02000EA1FF000EA01C0018AB00000E2BF36D S31A00104CC8000E1BFF0036ECBA000EA0BF000EA17F0018AB00005F S31A00104CDD0E2BFD000E1BFF0036ECBA003AEB5A000E2CFE000CAF S31A00104CF2AFCB000EEBF7000CAFFB0004AFBF000E2F080001BF00 S31A00104D07BF000CBFBF0001BFBF0033EC8C000EA5FF000EA41C8E S31A00104D1C001CAC15001CAB14003A7FC0000EA1BE000EA02C00F4 S31A00104D31180B020032ECB000181C030030EC8C0004ABBF000E09 S31A00104D462BF7000E1BFF0032EC8C001CAC07000ECCAB001CAB33 S31A00104D5B06000EDB0A00180B070032ECA400181C080030EC8C64 S31A00104D7000180B050032ECA000181C060035EC8C001CAF14006C S31A00104D851CBF150036EC8C0004AFB60032EC8C001CAF00000E79 S31A00104D9ABFF70002EF00003AEB5A000E2CFE000CAFCB000EEB11 S31A00104DAFF7000CAFFB0004AFBF000E2F080001BFBF000CBFBF6C S31A00104DC40001BFBF00005FB6001EAF020032EC870004AFBF004A S31A00104DD90E2F080001BFBF000EA1BF000EA0FF0004ACA100047B S31A00104DEEABA200181B080032EC7F00181C090036EC70000EA1F7 S31A00104E03FF000EA01C0018AB00000E2BEF000E1BFF0032EC701A S31A00104E18000EAFBF0002FF00000EAFF70002FF01000EACFD0085 S31A00104E2D0EABFF000EADFF000EAEA2003AFDBB000EACFF000ED1 S31A00104E42ABFF0016AF0300397FAC0023FFFF00397FAD0016AF24 S31A00104E57FA000EA1FF000EA01C0018AF100002FF010018AF110D S31A00104E6C0002FF020018AE130018AD12000EFD7F0032EC5D0063 S31A00104E810CBEDF0032EC5B000EA5FF0033EC55000EAFFE000201 S31A00104E96FF00001EAC02001EAB01003A7FB7000CAFC5000CAFB1 S31A00104EAB5D000EABFE000EACF2000CAFDE000E6DFE003AFB06CF S31A00104EC0000EA1FF000EA01C0018AF1C000EFF7F0032EC47007B S31A00104ED518AF1C0018BF1D0032EC42000EABFF000EAC18000EE3 S31A00104EEAAEFF000EADFF0033EC370018AC210018AB200018AE52 S31A00104EFF1D0018AD1C000EAFFE0002FF00003A7FB7000CAFCED5 S31A00104F14000CAFBD000EABFF000EAC18003AFB06000EA1BE00C8 S31A00104F290EA05C0018AF0D000E1F000036EC2B0018050D0035A6 S31A00104F3EEC2B0004AFBF000EBF7F0001BFBF0033EC24000EA102 S31A00104F53BE000EA05C0018050E0030EC240004AFBF000E2F80D1 S31A00104F680001BFBF000EA1BE000EA05C0018AF0F000E1F000025 S31A00104F7D36EC190018050F0035EC190004AFBF000EBFBF000169 S31A00104F92BFBF0033EC12000EA1BE000EA05C001805100030EC85 S31A00104FA7120004AFBF000E2F400001BFBF000EA1BD000EA076CF S31A00104FBC0018AF180002FF030018AF190002FF040018A41B002B S31A00104FD118A51A000EA1BE000EA0370018AF03000E2FFE000285 S31A00104FE6FF05000E1FFF0036EBF9000EABFE000EACF8003A7F34 S31A00104FFBA50002FB030002FC04000EABFE000EACF6003A7FA51F S31A00105010000CAFC4000CAFB50004AF580036EBAC001EAC0400E0 S31A001050251EAB0300041BC50032EBB000041CC40032EBB000042E S31A0010503A15C30032EBB0000414C20032EBB0001EAC02001EAB6A S31A0010504F01001E0B030032EBE8001E1C040030EBD6001EAF0503 S31A001050640036EBDA000EA1FF000EA01C0018AF14000EFF7F0047 S31A0010507936EBD6000EABFF000EAC11000EADFB003A7FA4003A45 S31A0010508EFAF70033EBD6000EABFF000EAC11000EADFB003A7F20 S31A001050A3A4001EAC02001EAB01000C0B5F0032EBD1000C1C4FCD S31A001050B80035EBAC000EA1BE000EA0370018AB03000E2BFE00B2 S31A001050CD0E1BFF0036EBB0000EA1FF000EA01C0018AF14000E5E S31A001050E2FF7F0032EBAC0018AF140018BF150036EBAC0004AF15 S31A001050F7B80032EBAC0018AB0B000E2BFB000E1BFF0036EBB70B S31A0010510C000EABFF000EAC11000EADFB003A7FA30033EBB30012 S31A001051210EABFF000EAC11000EADFB003A7FA4003AFAF70000A2 S31A00105136FEB80033EBAC000EABFF000EAC11000EADFB003A7FDC S31A0010514BA3001EAF030001BFC5001EAF040001BFC40001B5C373 S31A001051600001B4C20004AF580036EB8F000EA1BD000EA0760062 S31A001051751EAC02001EAB0100180B1C0032EB9D00181C1D0030FF S31A0010518AEB980004AFBF000EBFEF0001BFBF0033EB8F001EAC53 S31A0010519F02001EAB0100180B1E0032EB9300181C1F0035EB8F26 S31A001051B40004AFBF000E2F100001BFBF0000FE580004ABBF00CE S31A001051C90E2B7F000E1BFF0032EB7B000EA1FF000EA01C0018B3 S31A001051DEAB0A000E2BF7000E1BFF0032EB7B0018AB1B000E2BEA S31A001051F3F7000E1BFF0032EB7B000EABFF000EAC11000EADF7A5 S31A00105208003A7FA40033EB77000EABFF000EAC11000EADF70054 S31A0010521D3A7FA30004ABBF000E2BBF000E1BFF0036EB6E000EDF S31A00105232ABFF000EAC12000EADFD003A7FA40033EB6A000EAB85 S31A00105247FF000EAC12000EADFD003A7FA30004ABBF000E2BEFC7 S31A0010525C000E1BFF0036EB61000EABFF000EAC11000EADFD0042 S31A001052713A7FA40033EB5D000EABFF000EAC11000EADFD003AC5 S31A001052867FA30016AF0600397FAC0023FFFF00397FAD0016AF61 S31A0010529BF8000EA5FF000EA41C001CAB00000E2BF3000E1BFB59 S31A001052B00036EB4E000EA0BF000EA17F000EAFFC0002CF00003F S31A001052C51CAF080002FF05001CAF090002FF06003AFF18001C9D S31A001052DAAB00000E2BEF000E1BFF0036EB37000EACFE000EABE5 S31A001052EFFF000EAFFE0002FF070033EB31000EABFF000EAC1CF5 S31A00105304000EADFB003A7FA3000EABFF000EAC1C000EADF7002C S31A001053193A7FA30033EB0D000EA1BF000EA0FF0018AC360018B5 S31A0010532EAB35000EAFFF0002FF07000EAFFF0002FF030002FFEF S31A0010534304000CAFC4000CAFB5000CB45F0036EB0D000EA09FB2 S31A00105358000EA17F0018AB00000EBBFA0002CB00003AFF180058 S31A0010536D0EA1FF000EA01C001EAC0600183C09001EAB0500188A S31A001053827B08003A7FC0000EA1BF000EA0FF00180B400032EB69 S31A001053971800181C410030EB40001EAF0400043FDC0002FF040E S31A001053AC001EAF0300047FDD0002FF03000DBF44000DFF550031 S31A001053C10CB45F0032EB2A000EA0BF000EA17F000EAFFD000204 S31A001053D6CF00001EAF070036EAFE000EA1BF000EA0FF001EAC06 S31A001053EB04001EAB030018AE360018AD3500397FDD0002FD033A S31A001054000002FE04000CB45F0032EAC6000EA1FF000EA01C0004 S31A0010541518AB00000E2BF3000E1BFB0036EAF1001EAF03000177 S31A0010542ABFA2001EAF040001BFA10033EAE4001EAF0400043FAF S31A0010543FA10002FF02000CAF6E000ECEFD000D5F7D000EAFBF37 S31A001054540002FF00000EAFF50002FF01000EACFE000EABFF0008 S31A001054693AFDBB000EA1FF000EA01C0018AB00000E2BF7000EAD S31A0010547E1BFF0036EADA000CAF1B000CAF0C000EADF70033EA83 S31A00105493D30018AB00000E2BFB000E1BFF0036EAD2000CAF1B34 S31A001054A8000CAF0C000EADFB003A7FA3000EA1FF000EA01C0088 S31A001054BD18AF080001BFA00018AF090001BF9F0018AF06000198 S31A001054D2BF9E0018AF070001BF9D000EACFE0033EAC5000EACD3 S31A001054E7FF000EA09F000EA17F0018AB00000EBBFA0002CB00CD S31A001054FC000EABFF0016AF0800397FAC0023FFFF00397FAD0016 S31A0010551116AFFF000EFADF000CAFFB0002FB00000E2A20000EAB S31A00105526FADF0032EAB70004AFC00036EAB00005BFC00001BF27 S31A0010553BC0001EAB00000CBABA0004ABDF000E2BEF000E1BFF5E S31A001055500036EAA6000EABE8000EAC3C000EADFE003AFF0500DC S31A001055650EA1FE000EA08700191F220002CF2200195F21000251 S31A0010557ACF2100195F200002CF2000195F1F0002CF1F00191FCE S31A0010558F230002CF2300191F2D0002CF2D00195F2C0002CF2CD6 S31A001055A400195F2B0002CF2B00195F2A0002CF2A0018AF2300B6 S31A001055B90E1F1F0034EA6500191F250002CF2500195F24000207 S31A001055CECF240018AF23000ECFE00002CF23000EABFE000EACB3 S31A001055E37F003A7FB4000EABFE000EAC83003A7FB40004AFB6E7 S31A001055F80036EA7E0005BFB60001BFB6000EA1FE000EA0870018 S31A0010560D18AC050018AB04003AE190000CAFC4000CAFB5000E3A S31A00105622A1BF000EA0AE0018AC10000EABFF000EA1BD000EA0FB S31A00105637760018AE0D0018AD0C003A7FB9000C15BF0032EA6B55 S31A0010564C000C14CF0035EA65000EA1FF000EA01C0018AF010080 S31A001056610EBFFB0002CF01003AEA3A000EA1FF000EA0120018A0 S31A00105676AB00000E2BCF0018AC01000E2CEB000CBCBF0032EAC9 S31A0010568B55000EA1FF000EA0020018AC01000E2CC3000EABFFC7 S31A001056A0000CBCBF0036EA49000EA1BE000EA0370018AB0300D7 S31A001056B50E2BFE000E1BFF0032EA3E0018AB00000E2BEF000E18 S31A001056CA1BFF0036EA3E003AFAF70033EA3E000EA1BE000EA09C S31A001056DF370018AB03000E2BFE000E1BFF0032EA3E0018AB0027 S31A001056F4000E2BEF000E1BFF0036EA3E003AFADC003AEEF000B5 S31A0010570916AF0100397FAC0023FFFF00397FAD0016AFF9000EF9 S31A0010571EFADF000CAFFB0002FB02000EA1FF000EA01C0018AF93 S31A0010573307000ECFAB0002FF040018AF06000EDF0A0002FF03EF S31A00105748000E2A20000EFADF0032EA2D0004AFA3000E1FFD002E S31A0010575D32EA00000EA1BE000EA05C000EA5F500186513000C4A S31A00105772AFF4001EAC04001EAB03000C0B5F0032EA1D000C1CF8 S31A001057874F0035EA13000EABF500186B17000CAFFC001EAE04A7 S31A0010579C001EAD03000C0DBF0032EA14000C1ECF0034E9CB002B S31A001057B10EABFF000EAC11000EAD7F003A7FA4000EA1FF000EF7 S31A001057C6A01C000EAFFF0002CF300002CF31000EAFFF0002CFB0 S31A001057DB2E0002CF2F001EAC04001EAB03000C0B5F0032EA0247 S31A001057F0000C1C4F0035E9DA0033E9CF000EA5BE000EA45C00B5 S31A001058050EADF5001C6D13000CAFFE0002FD050002FE06001E4B S31A0010581AA004001EA103000C01DF0032E9F4000C10EF0035E9D9 S31A0010582FEC000EABF5001C6B16000CAFFC000C01BF0032E9ED8C S31A00105844000C10CF0034E9CB000EABFF000EAC12000EADF70030 S31A001058593A7FA4000EA1FF000EA01C000EAFFF0002CF30000290 S31A0010586ECF31000EAFFF0002CF2E0002CF2F001EAC04001EABBD S31A0010588303001E0B050032E9DB001E1C060031E9D80000FFB7EB S31A001058980033E92A000EABF5001C6B17000CAFFC001EAE0400CC S31A001058AD1EAD03000C0DBF0032E9D0000C1ECF0034E9CD00005C S31A001058C2FAB70033E92A0000FBB70033E92A0004AFB7000E1F35 S31A001058D7FD0032E9BD000EA1BE000EA05A0018A413000CAF458D S31A001058EC000E65FE000EA1BE000EA05B0018A813000CAF890093 S31A001059010E69FE0033E9820004AFB7000E1FFD0034E99A000419 S31A00105916AFB7000E1FFA0032E9B4000EA433000EA5F30033E963 S31A0010592BAB0004ACB7000EABFF000CAFC0000EC05C000CAFB176 S31A00105940000ED1BE0018A413000CAF45000E65FE0004ACB700F8 S31A001059550EABFF000EA3BE000EA25C000CAFC0000EC05D000C42 S31A0010596AAFB1000ED1BE0018AE13000CAFED000E6DFE001AAC55 S31A0010597F18000CAFCB000E6BFE000C4CE8000C5BD90033E982CA S31A00105994000EA3BE000EA25C0004A8B7000EA9FF000CC2800006 S31A001059A90CD3910018AE13000CAFED000E6DFE001AAC18000C7F S31A001059BEAFCB000E6BFE000CCCE4000CDBD50004AFB70032E9D0 S31A001059D387000EA8FF000EA9FF0033E982000CC280000CD3915B S31A001059E80018A812000CAF89000E69FE000CAF5B000CAF4C00EC S31A001059FD0EAEF5000EADFF00397FDD001EA004001EA103000CEF S31A00105A1201DF0032E978000C10EF0034E97400051FB70001BFBF S31A00105A27B70033E967000CAF9B000CAF8C000EAEF5000EADFF12 S31A00105A3C00397FDD001EAC04001EAB03000C0BDF0032E96A0095 S31A00105A510C1CEF0031E9670005BFB70001BFB70004AFB7000E28 S31A00105A661FFA0034E9630000FAB70004AFB70036E92A0004AF65 S31A00105A7BB7000E1FFB0030E95A000EABFF000EAC11000EAD7FF1 S31A00105A90003A7FA30004AFB7000E1FFC0030E953000EABFF00D8 S31A00105AA50EAC12000EADF7003A7FA3000EA5FF000EA41C001C60 S31A00105ABAAB0A000E2BF7000E1BFF0032E92A001CAB0B000E2B64 S31A00105ACF7F000E1BFF0032E92A000EADBE000EAE5C0004ACB7C8 S31A00105AE4000EABFF000DBFCC000DFFBB000CCCCC000CDBBB003A S31A00105AF90CCEC0000CDDB10018AF190002EF2E0018AF1A00026C S31A00105B0EEF2F0004ACB7000EABFF000CCEC0000CDDB10018AC37 S31A00105B2320000EABFF000EA1BD000EA0760018AE0D0018AD0C4B S31A00105B38000EAFFF0002FF00000EAF9B0002FF01003A7FBE00B4 S31A00105B4D02EB300002EC31000EA1FF000EA01C0018AB0A000E9E S31A00105B622BFD000E1BFF0036E91E000EAFFF0002CF300002CFFD S31A00105B7731000EAFFF0002CF2E0002CF2F001EAB02000CBABACC S31A00105B8C0016AF0700397FAC0023FFFF00397FAD0016AFFB0078 S31A00105BA10CAFB50002FC04000EABFF000EAC1A003A7FA5000E6F S31A00105BB615FC0036E8E7000E05FC0030E907000E15FE0036E840 S31A00105BCBAE000E05FE0030E8F5000E15FF0036E9000033E8AED9 S31A00105BE0000E15FA0036E8BE000E05FA0035E8D9000E15F90082 S31A00105BF536E8B90033E8AE000EA1BF000EA0BD0018AF0500023E S31A00105C0AFF000018AF060002FF010018AF070002FF020018AF09 S31A00105C1F080002FF030033E8AA000EA5FF000EA41C001CAC152C S31A00105C34001CAB14001CAE09001CAD08003AF9BB0002FB0200D9 S31A00105C4902FC03001CAF140002FF00001CAF150002FF0100333A S31A00105C5EE8AA000EA5FF000EA41C001CAC39001CAB38001CAE3F S31A00105C7309001CAD08003AF9BB0002FB020002FC03001CAF383B S31A00105C880002FF00001CAF390002FF010033E8AA000EA1BD00B9 S31A00105C9D0EA0760018AE0D0018AD0C000EAFFA00037FFF000ECE S31A00105CB2AFFF00037FFF00397FD80016AF02000D9FEF0002FFA5 S31A00105CC701000DCFDF0002FF000018AE0F0018AD0E000EAFFA96 S31A00105CDC00037FFF000EAFFF00037FFF00397FD80016AF020088 S31A00105CF10D9FEF0002FF03000DCFDF0002FF020033E8AA000264 S31A00105D06FB000002FC010002FB020002FC030033E8AA000EA104 S31A00105D1BBF000EA0AE0018AF490002FF000018AF4A0002FF011E S31A00105D300018AF4B0002FF020018AF4C0002FF030033E8AA0057 S31A00105D450CAF7B000CAF6C000EADFF003AF55F001EAF04003687 S31A00105D5AE873000EA5BF000EA4AE001CAF580036E891001EAC55 S31A00105D6F03001EAB02003A7FC0000CAFC8000CAFB9000EA3BD5D S31A00105D84000EA276001CA058000EA1FF000370FF000371FF0027 S31A00105D991AAE0F001AAD0E00397FD80016AF02000C09DF0032B6 S31A00105DAEE892000C18EF0030E87A000EA5BF000EA4AE001CAF0E S31A00105DC3590036E876001EAC03001EAB02003A7FC0000CAFC834 S31A00105DD8000CAFB9000EA3BD000EA276001CA059000EA1FF00D5 S31A00105DED0370FF000371FF001AAE0F001AAD0E00397FD8001654 S31A00105E02AF02000C09DF0032E87B000C18EF0031E876000D9FED S31A00105E17EF0002FF03000DCFDF0002FF02001EAC03001EAB0217 S31A00105E2C0033E83F000EA5BF000EA4AE001CAF580036E85C0082 S31A00105E411EAC01001EAB00003A7FC0000CAFC8000CAFB9000E24 S31A00105E56A3BD000EA276001CA058000EA1FF000370FF000371F3 S31A00105E6BFF001AAE0D001AAD0C00397FD80016AF02000C09DF1A S31A00105E800032E85D000C18EF0030E845000EA5BF000EA4AE003E S31A00105E951CAF590036E841001EAC01001EAB00003A7FC0000C46 S31A00105EAAAFC8000CAFB9000EA3BD000EA276001CA059000EA18A S31A00105EBFFF000370FF000371FF001AAE0D001AAD0C00397FD89C S31A00105ED40016AF02000C09DF0032E846000C18EF0031E841001B S31A00105EE90D9FEF0002FF01000DCFDF0002FF00001EAC01001E4C S31A00105EFEAB000016AF0500397FAC0023FFFF00397FA90016AF59 S31A00105F1301000EA09F000EA17F0018AB00000EBBFA0002CB0094 S31A00105F280000FDB70004AFDF0032E82E003AE785003AE73700C2 S31A00105F3D0EABFF0033E8250004ABDF000E2BEF000E1BFF00362D S31A00105F52E8240004AFDF000E2F100001BFDF003AEF2C000EAB8C S31A00105F67FE003AE630003AF044000EA1BE000EA0370018AB023C S31A00105F7C000E2BFB000E1BFF0036E810000EA1BF000EA03A001A S31A00105F9118AB00000EACFF000E1BFB0032E810000E1CFF0032C0 S31A00105FA6E810000EA1FF000EA01C0018AF34000EBFBF0002CF08 S31A00105FBB34000EABFF003AE7CC0004AFA3000E1FFD0032E80642 S31A00105FD0000EABFF003AE63E003AF861000EABFD0033E80F001D S31A00105FE504AFA3000E1F010032E7FE000EABFE003AE63E003AA7 S31A00105FFAF7FE000EAB010033E80F000EABFF003AE63E003AE172 S31A0010600FA80033E81000397FA80023FFFF00397FA90016AFFFED S31A00106024000EA1FF000EA01C0018AC390018AB38000EAFFF0025 S31A0010603902FF00000EAEC3000EADFF003AE654000CAFCE000CF9 S31A0010604EAFBD000EABFF000EAC06003AFB060016AF0100397F8A S31A00106063A80023FFFF000E1DFF0036E7E1000ECCFD000D5FBB23 S31A001060780023FFFF000EA1BF000EA0AE0018AC00000E0CFF0035 S31A0010608D35E7D8000E0CFC0030E7D8000EACFF0023FFFF000E07 S31A001060A2FB7F0036E7D3000EACFF000EABFF000C0BDF0032E7E9 S31A001060B7D0000C1CEF0034E7CD000CAFDB000CAFEC0023FFFF91 S31A001060CC000374FF000375FF000CAFB3000EABFE000EAC870056 S31A001060E10CAFC0000CAFB10018AE220018AD21000EA5BE000E60 S31A001060F6A41F000EA1BF000EA0AE00181D390032E7BC00181E79 S31A0010610B3A0034E7B80018AE3A0018AD390033E7A6000E13017C S31A001061200032E7B3001C3E07001C7D060033E7A6000E13FD00AA S31A0010613532E7AC001CAC08000EABFF000C4CEE000C5BDD003335 S31A0010614AE7A6000EAEFF000EADFF000CAFC0000CAFB10002CD72 S31A0010615F280002CE29000CBEDF0036E7A0000EA1FE000EA087AC S31A001061740002CD280002CE29000EAEFF000EADFF0004AFA30045 S31A001061890E1F000036E7980004AFA3000E1FFE0032E78F000ED2 S31A0010619E13FD0032E793001CAE08000EADFF0033E78F000E13C4 S31A001061B3010032E78F001CAE07001CAD06000EA1FE000EA08796 S31A001061C80002CE220002CD21000EAFFF0002CF1F0002CF20002D S31A001061DD16A5010016A4010023FFFF00397FAD003AFCFB000E5B S31A001061F2A5FF000EA41C000EA1BD000EA0760018AF000002EFC8 S31A00106207080018AF010002EF090018AF0C0002EF1C0018AF0DEE S31A0010621C0002EF1D0018AE0D0018AD0C000EABFF000EAC0E0025 S31A001062313AFB06001CAE1D001CAD1C000EABFF000EAC0A003A85 S31A00106246FB06000EABFF000EAC11000EADFE003A7FA4000EAFD6 S31A0010625BF40002EF06000EAF8D0002EF070004AFBF000EBFF7B5 S31A001062700001BFBF000EA1BD000EA0760018AE190018AD180038 S31A001062850EABFE000EACF8003A7FA6000EA1BD000EA07600187E S31A0010629AAE1B0018AD1A000EABFE000EACF6003A7FA6000EA1BC S31A001062AFBF000EA0AE0018AF01000E1FFD0036E7460018AB0190 S31A001062C4000E2BFE000EEBF7000CAFFB001CAF01000E2F0800C1 S31A001062D902EF01000CBFBF0002EF01003AEF2C001CAC09001CEA S31A001062EEAB08003AD774003AEE85001CAF080001BFA0001CAFA2 S31A00106303090001BF9F001CAF060001BF9E001CAF070001BF9DA9 S31A0010631800397FAC0023FFFF00397FA90016AFFC000EACFF00FA S31A0010632D0EA1BD000EA0910018AF0D0002FF020018AF0E0002EC S31A00106342FF03000EA09F000EA17F0018AB00000E2BF7000C1B99 S31A00106357CF0036E7210018AB00000E2B080002CB00000CAF6C16 S31A0010636C000ECCFC000D5F7B003AE70C0004AFDF0032E71B0056 S31A001063810CAF6C000ECCFD000D5F7B003AE70C000E1CFF003680 S31A00106396E70F000CAF6E000ECEFD000D5F7D000EAFBD0002FF80 S31A001063AB00000EAF840002FF01000EACFD000EABFF003AFDBB23 S31A001063C00016AF0400397FA80023FFFF000CAFC0000CAFB10081 S31A001063D50EABFF0018AF00000E1F050036E70300191F00000292 S31A001063EACF00000EABFE000CAFBC000EABFF0023FFFF00397FFA S31A001063FFA9003AEE1F003AEC6B003AE7F8003AE6F200397FA867 S31A001064140023FFFF00397FA9003AEABC003AEF20003AECF90093 S31A001064290EABFF00397FA80023FFFF00397FA90016AFFC000EDF S31A0010643EA3FE000EA287000EA1BD000EA076001AAC1C00183C95 S31A001064530B001AAB1B00187B0A0002FB020002FC03000EFB7F0E S31A001064680032E6CA0002DB1B0002DC1C0018AC090018AB08009D S31A0010647D0E1B000032E6DC000E1C000036E6D7000D1FCF0002BD S31A00106492FF03000D5FBF0002FF020033E6D4000EAF000002FF04 S31A001064A7020002FF03000CAF6E000ECEFD000D5F7D000EAFBD5F S31A001064BC0002FF00000EAF6E0002FF01000EACFD000EABFF0018 S31A001064D13AFDBB0016AF0400397FA80023FFFF000EA3FE000EA7 S31A001064E6A2AB000EA1FE000EA04D001AAE06000CAFED000E6DA5 S31A001064FBFE00181E050002CF050018AF04000C7FDF0002CF045D S31A00106510000EA1FE000EA08700181E070002CF070018AF06009C S31A001065250C7FDF0002CF0600181E010002CF010018AF00000C2E S31A0010653A7FDF0002CF0000181C030002CF030018AF02000C7FA8 S31A0010654FBF0002CF02001AAF06000E0FFF0031E6A200181E1C99 S31A001065640002CF1C0018AF1B000C7FDF0002CF1B0018CE1800E9 S31A0010657902CE180018DD170002CD170018CC1A0002CC1A00181F S31A0010658EDB190002CB190023FFFF00397FAD000EA1BD000EA068 S31A001065A3760018AE17000EADFF000EAC17000EABFC00397FDDA5 S31A001065B8000CAFDC000E6CFE000CAFCB00037EFF00037DFF0024 S31A001065CD037CFF00037BFF0004AEBB0004ADBC0004ACBD00045D S31A001065E2ABBE00397FD60016AF04000CAFE4000CAFD5000EA1F0 S31A001065F7FE000EA0AB0018AC06000CAFCB000E6BFE0004AFA305 S31A0010660C000E1FFD0032E678003AC5730033E6750018AE0100E2 S31A0010662118AD0000397FDC0004CEBB0001BEBB0004DDBC000150 S31A00106636BDBC0004DCBD0001BCBD0004DBBE0001BBBE000EA1E3 S31A0010664BBD000EA0760018AE17000EADFF000EAC17000EABFC26 S31A0010666000397FDD000CAFDC000E6CFE000CAFCB00037EFF0065 S31A00106675037DFF00037CFF00037BFF0004AEBB0004ADBC0004A2 S31A0010668AACBD0004ABBE00397FD60016AF04000C44EB000CAFC2 S31A0010669FBC000E6BFE00397FAC0023FFFF00397FAD0016AFFEF0 S31A001066B4000CAFE4000CAFD5000EFB7F0032E64B000EAC0000E7 S31A001066C90EAB000033E641003A7FC0000EA1FF000EA01C00188A S31A001066DEAE110018AD100002FB000002FC01000CAF5B000CAF30 S31A001066F34C003A7FBD0016AF0200397FAC0023FFFF00397FA90D S31A00106708000E1BFF0036E636000EABFF000EAC11000EADFE00B0 S31A0010671D3A7FA40033E632000EABFF000EAC11000EADFE003A33 S31A001067327FA300397FA80023FFFF00397FAD0016AFD40002FB9E S31A001067472A000EA1FE000EA087000EA5FF000EA41C001CAF06CA S31A0010675C0002CF1D001CAF070002CF1E000EA1BF000EA0BD008A S31A0010677118AF0B0001BFCE0018AF0C0001BFCD0018AF0D000168 S31A00106786BFCC0018AF0E0001BFCB0018AB02000EEBBF000E2B47 S31A0010679BFE001CAF01000E2F010002EF01000CBFBF0002EF015D S31A001067B0001F8B2A000E2BFE000EEBFB000CAFFB001CAF01003D S31A001067C50E2F040002EF01000CBFBF0002EF01003AEFA9000C1C S31A001067DAAF6C000ECCFD000D5F7B000EADFE003AE59B000EAF8B S31A001067EFFF0002FF2B003ADFF9000E1CFF0036E5FB001F9B2A1F S31A00106804001EBB2A000EEBFD0002FB2B001EAF2B0002FF160039 S31A001068191CAF080002FF26001CAF090002FF27000EA1BE000EE3 S31A0010682EA0370018AB03000E2BFB000E1BFF0036E5EA001CAF76 S31A00106843360002FF28001CAF370002FF290033E5E6001CAF14C2 S31A001068580002FF28001CAF150002FF29000CAF6C000ECCFD00E4 S31A0010686D0D5F7B003AE03A001EAF2A0036E5DC001EAF23000ED9 S31A001068822F3F0002FF230033E5D7001EAF23000E2F3F0002FFFD S31A0010689723000EBFFE0002FF23001EAF23000EBF7F0002FF2364 S31A001068AC000E2F400002FF23000EA5FF000EA41C001D1C09005E S31A001068C11D5B08001CAE07001CAD06001CAF140002FF00001C90 S31A001068D6AF150002FF01003AC4F2001E4C1C001E5B1B003A7F0E S31A001068EBC00002FB240002FC25000CAF6C000ECCFD000D5F7B99 S31A00106900003AE141000EAFFE0002FF18000CAF6C000ECCFD003E S31A001069150D5F7B000EADFF003AE3130000FE610000FE93001C7A S31A0010692AAF1C0002EF18001CAF1D0002EF19000EA1FE000EA021 S31A0010693F870018AC180018AB17001CAE1D001CAD1C003AE7D72C S31A001069540002EB200002EC21000EA1FE000EA0870018AC18003E S31A0010696918AB17001CAE1D001CAD1C003AE7D70002EB22000254 S31A0010697EEC23003ADFD20016AF2C00397FAC0023FFFF00397FC6 S31A00106993AD0016AFF1000CAFC4000CAFB5000EA1FE000EA087A5 S31A001069A80018AF1F0002FF030018AF200002FF040018AF210006 S31A001069BD02FF050018AF220002FF06000EA9FF000CAF98000CA4 S31A001069D21D9F0036E57D000EADD7003A7FB2000EA1FF000EA0ED S31A001069E71C0018AF34000EBFDF0002CF34000CAF1B000CAF0C20 S31A001069FC000EAD7F003A7FA30033E316000EA1BF000EA0AE00E4 S31A00106A1118AE0A0018AD09000EACFF000EABFF001EAF06000375 S31A00106A267FFF001EAF0600037FFF001EAF0600037FFF001EAF52 S31A00106A3B0600037FFF001E0B000032E568001E1C010032E56847 S31A00106A50001E1D020032E568001E1E030016AF040030E54E00F4 S31A00106A6518AC1E0018CC6B0018AB1D0018DB6A000EA1FF000EDC S31A00106A7AA01C00180B080032E55D00181C090031E5550018AB2B S31A00106A8F34000E2BBF000E1BFF0032E5550004AFBF000E2F026B S31A00106AA40001BFBF0004ABBF000E2BFD000E1BFF0036E54F0012 S31A00106AB90EA8FE0033E54E000EA9FE000EA3FF000EA21C001A4D S31A00106ACEAB34000E2BBF000E1BFF0036E528000EA1BF000EA03F S31A00106AE3AE0018AC1E0018CC6B0018AB1D0018DB6A001A0B083F S31A00106AF80032E53F001A1C090031E5360004ABBF000E2BFD00EE S31A00106B0D0E1BFF0036E5280004AFBF000EBFFE0001BFBF003303 S31A00106B22E52D0004ABBF000E2BFE000E1BFF0036E52D0004AF6E S31A00106B37BF000E2F020001BFBF000E2F010001BFBF0004ABBF8B S31A00106B4C000E2BFD000E1BFF0036E528000EA8FE000E18FF00A4 S31A00106B6136E50C000EA9FF000EA1BF000EA0AE0018AC52001834 S31A00106B76AB51000EAEF5000EADFF00397FDB001EAF0600037FA5 S31A00106B8BFF001EAF0600037FFF001EAF0600037FFF001EAF0665 S31A00106BA000037FFF001E0B000032E50F001E1C010032E50F0099 S31A00106BB51E1D020032E50F001E1E030016AF040030E50C000E1B S31A00106BCAA9FE000E19FF0036E375000EA3FF000EA21C001AAE01 S31A00106BDF09001AAD08000CAFDC000E6CFE000CAFCB001CCE0E26 S31A00106BF40002EE0E001CDD0D0002ED0D001CDC0C0002EC0C0078 S31A00106C091CDB0B0002EB0B000EA1BE000EA0370018AB03000E40 S31A00106C1E2BFB000E1BFF0036E4EF001AAE37001AAD36000CAF3D S31A00106C33DC000E6CFE000CAFCB0033E4EA001AAE15001AAD14A3 S31A00106C48000CAFDC000E6CFE000CAFCB001CCE120002EE12008E S31A00106C5D1CDD110002ED11001CDC100002EC10001CDB0F0002F4 S31A00106C72EB0F001D1F010002EF01001D5F000002EF00001CA2A3 S31A00106C8701001CA300000EA1BF000EA0AE001813180032E439C6 S31A00106C9C001812190032E439001CAE0E001C3E0A001CAD0D0029 S31A00106CB11C7D09001CAC0C001C7C08001CAB0B001C7B07003AF8 S31A00106CC67FC1000EAFFF0002FF02000EA1BF000EA0AE0018A81A S31A00106CDB1C000EA9FF000CAF80000CAF91000CAF18000E68FEEE S31A00106CF0000CAF89000370FF000371FF000378FF000379FF005B S31A00106D051E0B000032E4B7001E1C010032E4B7001E1D020032F6 S31A00106D1AE4B7001E1E030016AF040030E4B3000EAFFE0002FF28 S31A00106D2F02000EA3BF000EA2AE001AA019001AA118000EA8FF0E S31A00106D44000EA9FF000370FF000371FF000378FF000379FF0094 S31A00106D591CAE0E001CAD0D001CAC0C001CAB0B00397FD6001617 S31A00106D6EAF010002FF0A0016AF010002FF0A0016AF010002FFA7 S31A00106D830A0016AF010002FF0A0002ED240002EE25000370FF70 S31A00106D98000371FF000378FF000379FF001CAE12001CAD1100B2 S31A00106DAD1CAC10001CAB0F00397FD60016AF040002ED2600029F S31A00106DC2EE27001EAF020036E484001CAF130036E484000EA1F9 S31A00106DD7FF000EA01C0018AB01000E2BFE000E1BFF0032E46D22 S31A00106DEC000EA1BF000EA0AE0018AE1B0018AD1A000EACFF0039 S31A00106E010EABFF001EAF0600037FFF001EAF0600037FFF001EE8 S31A00106E16AF0600037FFF001EAF0600037FFF001E0B000032E488 S31A00106E2B6F001E1C010032E46F001E1D020032E46F001E1E030C S31A00106E400016AF040030E450003ADFF90002EC140002EC1B00DD S31A00106E550CAF5B000CAF4C003AE03A001CAF21000EBFBF000227 S31A00106E6AEF21000EA1FF000EA01C00191C0900195B080018AEF5 S31A00106E7F070018AD060018AF140002FF000018AF150002FF015C S31A00106E94003AC4F2001C4C1A001C5B19003A7FC00002EB220049 S31A00106EA902EC23000EAFFE0002EF15001EAF060002EF02001E08 S31A00106EBEAF020002EF13001CAF0B0002EF07001CAF0C0002EF5E S31A00106ED308001CAF0D0002EF09001CAF0E0002EF0A000EAFFF2A S31A00106EE80002EF0B0002EF0C0002EF0D0002EF0E000EAFFF00CD S31A00106EFD02EF0F0002EF100002EF110002EF12000EAFFF0002A6 S31A00106F12EF000002EF01000EA1FF000EA01C0018AB34000E2BCB S31A00106F27DF000E1BFF0032E42F001D1F060002EF06001D5F0539 S31A00106F3C0002EF05001CAF150036E375001EAB06001C3B02009E S31A00106F510EA1BF000EA0AE00181B250035E375000EAFFF0002A8 S31A00106F66EF15000EAFFE0002EF160000FEB5000CAF5B000CAFB6 S31A00106F7B4C003AE285000CAF5B000CAF4C003AE141000EA1FED8 S31A00106F90000EA087000EA3FF000EA21C001AAE3B0018CE01003B S31A00106FA51AAD3A0018DD00000EABFE000EACE2003AFB06000E2F S31A00106FBAA1FF000EA01C0018AB34000E2BDF000E1BFF0036E3F2 S31A00106FCFF6001CAF1B0036E3F6001CAE1A001CAD19000EABFE2F S31A00106FE4000EACE0003AFB06000EABFE000EACE2000EAEFF009F S31A00106FF90EADFF003AFB06000EA3FF000EA21C000CAF31000C04 S31A0010700EAF200018AF34000E2F200002DF34000EAFFE0002EF6F S31A0010702317000EA1BF000EA0AE001CA206001CA3050018130BA3 S31A001070380032E3EF0018120C0034E37A001CAF1B0036E3E7007C S31A0010704D1CAE1A001CAD19000EABFE000EACDA003AFB06000EBE S31A00107062A1BF000EA0BD0018AC010018AB00000EA1FF000EA054 S31A001070771C000CAF02000CAF130018AE3D001A3E430018AD3CA8 S31A0010708C001A7D42000D9FEE000E5DBF003AC255000EA1FF003D S31A001070A10EA01C00183C3B00187B3A001CAF050002FF00001CB1 S31A001070B6AF060002FF01000EAEEF000EADF1003A7FBE000CAF6F S31A001070CBCE000CAFBD000CAF4F000ECFE30002FF0C000D5F5FB2 S31A001070E00002FF0B000EA3BD000EA276001AAF150002FF010005 S31A001070F50EAFFF0002FF00001EAC0C001EAB0B003AFAAB001E0C S31A0010710AAC0C001EAB0B003A7FA0000CAFCE000CAFBD000EABBB S31A0010711FFE000EACEA003AFB06001CAF20000E1F000036E3B087 S31A00107134001D1F200002EF20000EA1BD000EA076001CAF200048 S31A00107149181F160035E38B000CAF02000CAF13001AAF140003C0 S31A0010715E7FFF001AAF1300037FFF0018AE0D0018AD0C00397FCF S31A00107173D80016AF02000D9FEE000DCFDD000EA1FF000EA01C87 S31A001071880018AF3200037FFF0018A0330016A101000C01DF00D3 S31A0010719D32E396000C10EF0030E38B000EA1BE000EA037001809 S31A001071B2AB02000E2BEF000E1BFF0036E38B000EABFF000EAC9F S31A001071C701000EADDF003A7FA4001CAF200001BFC1000EA1FF8B S31A001071DC000EA01C0018AE430018AD42000EABFE000EACE0005D S31A001071F13AFB06000EABFE000EACE2000EAEFF000EADFF003A36 S31A00107206FB06000EAFFF0002EF050002EF06000EA1FF000EA057 S31A0010721B1C0018AF01000E2F040002CF01001EAC06001C3C0425 S31A00107230001EAB05001C7B03000EA1BF000EA0AE00181B0B00C3 S31A0010724532E36C00181C0C0031E363001CAF170032E363000E7E S31A0010725AA1FF000EA01C0018AB34000E2BFE000E1BFF0036E330 S31A0010726F36001EAF050002EF03001EAF060002EF04001CAF164F S31A001072840032E357000EA1FF000EA01C0018AB34000E2BFE00CD S31A001072990E1BFF0036E3360004AF620032E336001CAF160036DC S31A001072AEE350000CAF5B000CAF4C003AE026000EA1BF000EA009 S31A001072C3BD0018AF090002FF0D0018AF0A0002FF0E001EAC0E4D S31A001072D8001EAB0D003AC414003AE7E0000CAFCB0004AFD20097 S31A001072ED02FF000004AFD10002FF01001EAD0E001EAC0D000E31 S31A00107302AEF7003AC8B6000EAFFF0002EF17000EA1FF000EA0E3 S31A001073171C0018AF34000E2F010002CF34000EA1BF000EA0AE27 S31A0010732C0018AE480018AD47000CAFDC000E6CFE000CAFCB0087 S31A001073411EAF0600037FFF001EAF0600037FFF001EAF060003A3 S31A001073567FFF001EAF0600037FFF001E0B000032E320001E1CA2 S31A0010736B010032E320001E1D020032E320001E1E030016AF0447 S31A001073800030E316000EA3FE000EA287000EA1FF000EA01C005B S31A0010739518AF060002DF1D0018AF070002DF1E0016AF0F003928 S31A001073AA7FAC0023FFFF00397FAD0016AFF8000CAFC4000CAF10 S31A001073BFB50002FD030004ABBF000E2BFB000E1BFF0036E2BD4D S31A001073D40004AFB50032E2BD0004AFBF000E2F040001BFBF0023 S31A001073E90CAF4F000ECFE60002FF05000D5F5F0002FF04000EC8 S31A001073FEAFFD0002FF00001EAC05001EAB04000EADFE000EAEA6 S31A001074134D003A7FE0000EA1FE000EA04D0018AE050018AD042C S31A00107428001EAC05001EAB04003AE1B0000EA1BF000EA0BD00F9 S31A0010743D191C0400195B03000EA1FF000EA01C0018AE07001817 S31A00107452AD060018AF140002FF000018AF150002FF01003AC4A4 S31A00107467F2001C4C1A001C5B19003A7FC00002EB220002EC235D S31A0010747C001CAF21000E2F800002EF21000E2F3F0002EF21009C S31A001074910EBFFD0002EF21001EAF03000E1FFD0032E2D2001CF8 S31A001074A6AF21000EBFBF0002EF210033E2CF001CAF21000E2F40 S31A001074BB400002EF21001EAF03000E1FFE0034E2C4000EAFFEC4 S31A001074D00002EF14000CAF5B000CAF4C003AE285000CAF5B00B8 S31A001074E50CAF4C003AE141000EAFFE0002EF16000EA1FF000E9B S31A001074FAA01C0018AF01000E2F040002CF01001CAF160036E2D7 S31A0010750FA30004AF620032E2A3000CAF5B000CAF4C003AE02685 S31A00107524000EA1BF000EA0BD0018AF090002FF060018AF0A00BB S31A0010753902FF07001EAC07001EAB06003AC414003AE7E0000C60 S31A0010754EAFCB0004AFD20002FF000004AFD10002FF01001EADC1 S31A0010756307001EAC06000EAEF7003AC8B6001CAF180036E28838 S31A00107578001CAF140036E29A000EA1FF000EA01C0018AF010017 S31A0010758D0EBFFD0002CF01000EFADF000CAFFB0002FB02000E8D S31A001075A22A20000EFADF0032E297000EA1FE000EA09C000EAF2E S31A001075B7C00002CF00000EAF000002CF010000FFBE0000FFBD10 S31A001075CC0000FFBC0000FFBB001EAB02000CBABA0016AF080007 S31A001075E1397FAC0023FFFF00397FAD0016AFF40002FB040002D9 S31A001075F6FC05000EA5FE000EA487001CAC07001CAB06003A7F2A S31A0010760BC00002FB060002FC07001CAC09001CAB08003AE19041 S31A001076200002FB080002FC09000EA1BF000EA0AE0018AC3D0068 S31A001076350EABFF000EA3BD000EA276001AAE0D001AAD0C003AFC S31A0010764A7FB6000EA5FF001EAE09001EAD08000C1DBF0032E28A S31A0010765F66000C1ECF0031E264000EA5FE001EA005001EA104F3 S31A001076740018AF140036E1BA000EA1FF000EA01C0018AB010003 S31A001076890E2BFD000E1BFF0036E1BA000E15FF0036E1B8000EA8 S31A0010769EA1BF000EA0BD0018AB02000E2BFC000E1BFF0036E2BC S31A001076B333001EAC05000ECCE6001F5B04000EA3BF000EA2AE9E S31A001076C8001AAD3B003AE0C8000E1CFF0036E238000EA1BF00CC S31A001076DD0EA0AE0018AC3F000EABFF000EA3BD000EA276001ABD S31A001076F2AE0D001AAD0C00397FDC000CAFDE000CAFCD000CAF6F S31A00107707BC000E6BFE001E0D060032E239001E1E070034E2331A S31A0010771C001EA005001EA104000EAFFF0002CF140033E1B30054 S31A001077310EA1FF000EA01C0018AF01000E2F020002CF01000ECE S31A00107746A1FE000EA0870018AC090018AB08003AE1900002FB04 S31A0010775B0A0002FC0B000EA3BF000EA2AE001AAC3D000EABFF67 S31A00107770001EAE07001EAD06003A7FB6000EA5FF001EAE0B0052 S31A001077851EAD0A000C1DBF0032E21A000C1ECF0031E218000EBC S31A0010779AA5FE000EA1BF000EA0BD0018AB02000E2BFC000E1B25 S31A001077AFFF0032E209001EAC05000ECCE6001F5B04000EA3BF16 S31A001077C4000EA2AE001AAD3C003AE0C8000E1CFF0036E1B30064 S31A001077D90E15FF0036E1B3000EAFFC0002FF00000D1F6C000D3A S31A001077EE5F7B000EADBF000EAEBD003A7FE0000EA1FE000EA0AF S31A0010780357001EA205001EA304001AAC1A00183C09001AAB195E S31A0010781800187B08003A7FC0000CAFC8000CAFB9001EAE070067 S31A0010782D1EAD06000CAFDC000E6CFE000CAFCB000EECBF000C05 S31A00107842AFFB000EEDBF000CAFFC000CBBDB000EEEBF000CAFE8 S31A00107857FD000CBCEC000EAEFF000CAF80000CAF91000CAF1840 S31A0010786C000E68FE000CAF89000370FF000371FF000378FF00DA S31A001078810379FF00397FD60016AF040002FD010002FE02000CFC S31A00107896AFDB000CAFEC003AE12C0002FB010002FC02000CBC89 S31A001078ABBF0036E1B3000EABFF003AC5D9003AC65E000E1CFF12 S31A001078C00036E1C8001EAF03000E2F030002FF03000EBFFE00DF S31A001078D502FF030033E1C3001EAF03000E2F030002FF03000E8B S31A001078EABFFD0002FF03000D1F6C000D5F7B003AE0A70000FE75 S31A001078FF61001EA005001EA104000EAFFE0002CF170033E1B30D S31A00107914000E15FF0032E1B3000EA1FF000EA01C0018AF010020 S31A001079290E2F020002CF010016AF0C00397FAC0023FFFF003993 S31A0010793E7FAD000CAFC4000CAFB5003AC2F80002EB000002EC34 S31A001079530100397FAC0023FFFF00397FA90016AFD8000CAF7B4F S31A00107968000CAF6C000EADFE003AE59B003AEE85000CAF7B0077 S31A0010797D0CAF6C000EADFF003AE59B0004AFA3000E1FFD00368E S31A00107992E1970004AFA3000E1F010032E1A2000CAF7B000CAF28 S31A001079A76C000EADFD003AE3130016AF2800397FA80023FFFFF3 S31A001079BC00397FA9000CAFC0000CAFB1000EA8FF000EA9FF00ED S31A001079D10EA3BF000EA2FF001AAC31000EABFF000CAFCE000C28 S31A001079E6AFBD000CAFDC000E6CFE000CAFCB00037EFF00037D75 S31A001079FBFF00037CFF00037BFF000370FF000371FF000378FF08 S31A00107A10000379FF00397FDA0016AF08000EAFFE00397FCD0031 S31A00107A251AAF0700037FFF001AAF0600037FFF001AAF050003C4 S31A00107A3A7FFF001AAF0400037FFF00397FD90016AF04000EAF3E S31A00107A4F9400037FFF000EAF0700037FFF000EAF9F00037FFFD5 S31A00107A64000EAF9C00037FFF00397FD90016AF04000CAFE00028 S31A00107A790CAFD1000CAFC8000CAFB9000CAF9B000CAF8C000CB6 S31A00107A8EAF1D000CAF0E000CAFBF0036E14A000EFC7F0032E1C1 S31A00107AA34A000E1B700032E14E000E1C800032E14E000E1D013D S31A00107AB80032E14E000E1EFF0036E14D0034E14A000EAC00009A S31A00107ACD0EAB800033E143000CAF9B000CAF8C000CAF1D000C7D S31A00107AE2AF0E00397FD1000CAFDB000CAFEC00397FA80023FF74 S31A00107AF7FF00397FAD0016AFFF000CAFC4000CAFB5001CAF146E S31A00107B0C0036E12F000EABFE000EAC81000EADF2003A7FB200FE S31A00107B210CAF4E000ECEE6000D5F5D000EAFFD0002FF00000EDC S31A00107B36ABFE000EAC4F003A7FE00016AF0100397FAC0023FF8D S31A00107B4BFF00397FAD0016AFF40002FB060002FC07000EA1BF7C S31A00107B60000EA0BD0018AB02000E2BFC000E1BFF0036E0CD008A S31A00107B750EAFFF0002FF020002FF030002FF040002FF05000C0B S31A00107B8AAF6F000ECFFD0002FF0B000D5F7F0002FF0A001EA216 S31A00107B9F0B001EA30A0018AF000002DF010018AF010002DF0291 S31A00107BB4000EA1FE000EA0870018AC070018AB06003A7FC000B7 S31A00107BC90CAFC8000CAFB9000EA1BF000EA0AE0018AC3F000EBF S31A00107BDEABFF000EA1BD000EA0760018AE0D0018AD0C0002F9A3 S31A00107BF3000002F801003A7FBE000CAFC4000CAFB5001EA20B3B S31A00107C08001EA30A001EAC07001A3C02001EAB06001A7B0100F8 S31A00107C1D3A7FC00002FB080002FC09000EA1BF000EA0AE0018D5 S31A00107C32AC3E000EABFF001EA20B001EA30A001AAE02001AAD5E S31A00107C4701003A7FB9001EAE09001EAD08000C1DBF0032E0E716 S31A00107C5C000C1ECF0030E0D0000E05FF0032E0E3000E140000FB S31A00107C7130E0D0000EF57F0032E0D0000CB45F0036E0D000029D S31A00107C86F5000002F401001EAC0B001EAB0A001EAE07001EADA1 S31A00107C9B06003AFAAB001EA00B001EA10A0018AF010002FF0678 S31A00107CB00018AF020002FF070033E0CD000EAFFF0002FF060035 S31A00107CC502FF07001EAC07001EAB060016AF0C00397FAC002394 S31A00107CDAFFFF00397FAD0016AFFD0002FB000002FC01000EAFA1 S31A00107CEFFE0002FF02000CAFDC000EABFF000EAEFF000EADBFE5 S31A00107D04003A7FB9000CAFC4000CAFB5000EA1FE000EA0570041 S31A00107D191EA201001EA300001AAC0100183C09001AAB000018BC S31A00107D2E7B08003A7FC0000C0B5F0032E0AF000C1C4F0031E06F S31A00107D43AC000EAFFF0002FF02001EAC02000EABFF0016AF035E S31A00107D5800397FAC0023FFFF00397FAD0016AFF6000CAFC400DC S31A00107D6D0CAFB5000EA1BF000EA0BD0018AF000002FF020018C0 S31A00107D82AF010002FF03000EA1BF000EA0AE0018AC60000EAB7B S31A00107D97FF000EA1BD000EA0760018AF0C0002FF060018AF0D84 S31A00107DAC0002FF07001EAE07001EAD06003A7FB90002FB04008D S31A00107DC102FC05000EA1BF000EA0AE0018AC61000EABFF001ECF S31A00107DD6AE07001EAD06003A7FB90002FB080002FC09003AC282 S31A00107DEBD0000E1CFF0036E046001CAF00000EFF7F0032E03D72 S31A00107E00001CAF00001CBF010036E03D001CAC01001E3C030037 S31A00107E151CAB00001E7B02001E0B040032E075001E1C050034B9 S31A00107E2AE06D001EAF03001ECF050002EF01001EAF02001EDF60 S31A00107E3F040002EF000033E05F001EAC03001C3C01001EAB02C0 S31A00107E54001C7B00001E0B040032E066001E1C050034E05F0015 S31A00107E691EAF03001E3F050002EF01001EAF02001E7F04000258 S31A00107E7EEF00001CAC01001CAB00001E0B080032E05A001E1C83 S31A00107E93090034E055001EAF080002EF00001EAF090002EF01C4 S31A00107EA8001CAF00000EFF7F0032E03D001CAF00001CBF010062 S31A00107EBD36E03D001CAC01001E3C03001CAB00001E7B02003A85 S31A00107ED27FC0001E0B040032E047001E1C050030E03D000EAF77 S31A00107EE7BF0002FF00000EAFBD0002FF01000EACFC000EABFFC6 S31A00107EFC000CAF5D000CAF4E003AFDBB0016AF0A00397FAC0015 S31A00107F1123FFFF00397FAD0016AFFE000CAFC4000CAFB5001CF1 S31A00107F26AC25001CAB24000EA1FF000EA01C0018AE070018AD6A S31A00107F3B06001CAF260002FF00001CAF270002FF01003AC4F23F S31A00107F500002EB190002EC1A0016AF0200397FAC0023FFFF00AC S31A00107F65397FAD0016AFFF000CAFC4000CAFB5003ADFCD000EE5 S31A00107F7AABFF000EAC1C000EAD7F003A7FA4000EABFE000EAC54 S31A00107F8F87000EADF9003A7FB2000CAF4E000ECEE6000D5F5D8D S31A00107FA4000EAFFD0002FF00000EABFE000EAC51003A7FE0009C S31A00107FB90EAFFF0002EF16000EAFFE0002EF18000EA1FF000E5A S31A00107FCEA01C0018AE07000ECEAB0018AD06000EDD0A000EA109 S31A00107FE3BF000EA0AE000EABF500186B6C000CAFFC000C0DBF2C S31A00107FF80032DFFF000C1ECF0034DFFD003AEFA90000FFCA00AA S31A0010800D16AF0100397FAC0023FFFF000EA1FF000EA01C00186D S31A00108022AB01000E2BFE000E1BFF0036DFD5000EA3BF000EA21E S31A00108037AE0018AE090018AD08001A0D1F0032DFEC001A1E2039 S31A0010804C0034DFE6001A0D1D0032DFE8001A1E1E0031DFE60087 S31A001080610EABFF000EA1FF000EA01C0018AE07000ECEAB001858 S31A00108076AD06000EDD0A000EA1BF000EA0AE00180D210032DF16 S31A0010808BDB00181E220030DFD600180D230032DFD700181E2428 S31A001080A00031DFD5000EABFF000CAFBC000EABFF0023FFFF00C8 S31A001080B50EA1FE000EA057000EAF000002CF020023FFFF003904 S31A001080CA7FAD0016AFF20002FB000002FC01000EA1BE000EA091 S31A001080DF370018AB02000E2BFD000E1BFF0036DF36001EAC0106 S31A001080F4001EAB00003ADF2C000CAFC4000CAFB5000CB45F0045 S31A0010810932DFBA000EA4FE000EA5FF001EA001001EA100001888 S31A0010811EAB21000E2B7F000E1BFF0036DFAF000EA1FE000EA06B S31A00108133870002C52E0002C42F0033DF36003ADE86003AC1616E S31A00108148000EA3FE000EA287001AAF2F0002FF09001AAF2E002D S31A0010815D02FF08000EAFFF0002FF060002FF07000CAF40000C1C S31A00108172AF51000EA8FF000EA9FF000CAF0F001ECF090002FFB6 S31A0010818705000CAF1F001EDF080002FF04000CAF8F001EDF0796 S31A0010819C0002FF03000CAF9F001EDF060002FF02001EAF020085 S31A001081B11EBF03001EBF04001EBF050036DF36000CAFCE000C20 S31A001081C6AFBD000CAFDC000E6CFE000CAFCB00037EFF00037D8D S31A001081DBFF00037CFF00037BFF000370FF000371FF000378FF20 S31A001081F0000379FF00397FDA0016AF080002FB0A0002FC0B007A S31A0010820502FD0C0002FE0D001EA001001EA1000018AE1A0018C0 S31A0010821AAD19000CAFDC000E6CFE000CAFCB00037EFF00037DDE S31A0010822FFF00037CFF00037BFF001EAF0D00037FFF001EAF0DF5 S31A0010824400037FFF001EAF0D00037FFF001EAF0D00037FFF00D8 S31A00108259397FDA0016AF08000CAFE0001EC00D000CAFD1001E6B S31A0010826ED10C000CAFC8001ED80B000CAFB9001ED90A001EAF42 S31A001082830500037FFF001EAF0500037FFF001EAF0500037FFFA4 S31A00108298001EAF0500037FFF000CAF9B000CAF8C000CAF1D00F3 S31A001082AD0CAF0E00397FCB0016AF04001EA001001EA100000211 S31A001082C2CD190002CE1A001AAC2F001AAB2E000CAF5D000CAF06 S31A001082D74E00397FDB001EAF0500037FFF001EAF0500037FFFF5 S31A001082EC001EAF0500037FFF001EAF0500037FFF00397FCB003E S31A0010830116AF040002DD2E0002DE2F000CBEDF0032DF36000E6E S31A00108316AFFF0002DF2E000EAFFE0002DF2F000EA1FE000EA059 S31A0010832B87000EAFFF0002CF2A0002CF2B0002CF2C0002CF2DF2 S31A001083400016AF0E00397FAC0023FFFF00397FAD0016AFF4009C S31A0010835502FB020002FC03000CAFC0000CAFB10018AB21000E24 S31A0010836A2BC0000CAFBC000EABFF000CCCCC000CDBBB000CAFCD S31A0010837FC0000EC0AE000CAFB1000ED1BF0018AF300002FF078E S31A001083940018AF2F0002FF06000E2F7F0036DF15000EAF00001E S31A001083A902FF050002FF04000EA1FF000EA01C0018AC07000E4D S31A001083BECCA50018AB06000EDB0B000EA3BF000EA2AE001AAED0 S31A001083D336001AAD35000EAFFC0002FF00000EAF170002FF01BD S31A001083E8003A7FBE003A7FC0000CAFCE000CAFBD000CAFDC00E2 S31A001083FD0E6CFE000CAFCB001ECE070002FE07001EDD0600025A S31A00108412FD06001EDC050002FC05001EDB040002FB04001EA07E S31A0010842703001EA1020018AB21000E2BBF000E1BFF0036DEA2AC S31A0010843C000EA5FE000EA487001CAE29001CAD28000EACFF008E S31A001084510EABFF001CCE22001CDD21001CDC20001CDB1F000EE6 S31A00108466AFFF00397FCD003A7FC30002FB080002FC090002FD31 S31A0010847B0A0002FE0B001CAE22001CAD21001CAC20001CAB1F1D S31A00108490000EAFFF00397FCD003A7FC3001EAF0B00037FFF00AB S31A001084A51EAF0B00037FFF001EAF0B00037FFF001EAF0B00031F S31A001084BA7FFF000E8C7F00397FD40016AF04000CAFE0000CAF55 S31A001084CFD1000CAFC8000CAFB9000EA3BF000EA2AE001AAD38ED S31A001084E4001AAC37000EAFFE00397FD2000370FF000371FF0046 S31A001084F90378FF000379FF00397FD90016AF04000EAFFF00034A S31A0010850E7FFF000EAFFF00037FFF000EAFFF00037FFF000EAF8D S31A001085238800037FFF00397FD90016AF0400397FD1000CAFDBAB S31A00108538000CAFEC003A7FC0000CAFCE000CAFBD000CAFDC0060 S31A0010854D0E6CFE000CAFCB001ECE070002FE07001EDD06000208 S31A00108562FD06001EDC050002FC05001EDB040002FB04001EA02D S31A0010857703001EA1020018AE230018AD22000EACFF000EABFFD4 S31A0010858C00037EFF00037DFF00037CFF00037BFF001EAF0B00F2 S31A001085A1037FFF001EAF0B00037FFF001EAF0B00037FFF001E5E S31A001085B6AF0B00037FFF00397FDA0016AF080002FB040002FC01 S31A001085CB050002FD060002FE07003ADE120016AF0C00397FAC15 S31A001085E00023FFFF00397FAD0016AFF8000EA5FE000EA4870043 S31A001085F51CAF2A0002FF00001CAF2B0002FF01001CAF2C000274 S31A0010860AFF02001CAF2D0002FF03000EA1BF000EA0FF0018AC69 S31A0010861F31000EABFF000CAFCE000CAFBD000CAFDC000E6CFE37 S31A00108634000CAFCB00037EFF00037DFF00037CFF00037BFF009B S31A001086491EAF0700037FFF001EAF0700037FFF001EAF07000385 S31A0010865E7FFF001EAF0700037FFF00397FDA0016AF08000EAF02 S31A00108673FF00397FCD0018AF0300037FFF0018AF0200037FFFC3 S31A001086880018AF0100037FFF0018AF0000037FFF00397FD900A5 S31A0010869D16AF04000EAF0700037FFF000EAFCB00037FFF000E8D S31A001086B2AF9800037FFF000EAF7D00037FFF00397FD50016AFC8 S31A001086C70400397FCE000EA1BF000EA0BD0018AF0000037FFFDD S31A001086DC0018A0010016A101000EA8FF000EA9FF000370FF0025 S31A001086F10371FF000378FF000379FF00397FCB0016AF040002A8 S31A00108706FB040002FC050002FD060002FE07001CAE2F001CAD78 S31A0010871B2E000EACFF000EABFF000371FF000CAFB1000CAFCB2F S31A00108730000CAFDC000CAFED000EEDBF000CAFFE000EECBF00B3 S31A001087450CBDFD000EEBBF000CBCFC000EE1BF000CBBFB001641 S31A0010875AA101000EAFFF00397FCD003A7FC300397FCE001ECE23 S31A0010876F070002FE03001EDD060002FD02001EDC050002FC01D5 S31A00108784001EDB040002FB00001EAE03001EAD02001EAC010069 S31A001087991EAB00003ADE120002EB2E0002EC2F0016AF08003984 S31A001087AE7FAC0023FFFF00397FA9000CAFE0000CAFD1000CAF11 S31A001087C3C8000CAFB9000E19FF0032DE06000E18FF0032DE06D8 S31A001087D8000E11F80032DE06000E10000030DDF1000370FF00BB S31A001087ED0371FF000378FF000379FF000370FF000371FF000311 S31A0010880278FF000379FF00397FDA0016AF08000EEEFB000EED08 S31A00108817FB000CBEFE000EECFB000CBDFD000EEBFB000CBCFC00 S31A0010882C000CAFDB000CAFEC0033DDEF000EAC00000EAB000072 S31A00108841397FA80023FFFF00397FA9003AD84F003ADDE4000CC2 S31A00108856AFCB003AD84B000E1CFD0036DDEC00397FA80023FF78 S31A0010886BFF0004ABBF000EEBFD000CAFBC000EABFF000E8CFEB8 S31A001088800023FFFF00397FAD0016AFFD000EAFFF0002FF0200C6 S31A0010889504AF9C0036DDB3000EABFF000EACE0000EADDF003A7D S31A001088AA7FA4000EA04F000EA17F000EAFFF0002CF00000EAB0F S31A001088BFFE003AD9F5000EA5BE000EA437001CAC01000E2CFE2D S31A001088D4000EABF8000EADFE003AD91E001CAB00000E2BF800E6 S31A001088E90EA04F000EA17F0002CB00000EABFF000EACE0000E0C S31A001088FEADDF003A7FA3003AFF18000EA06F000EA17F000EAF0E S31A00108913020002CF00000E2A010004ACB30004ABB4000EAFFEAC S31A001089280002FF000033DD9D003AD771003AD6BD000D9FCC00AF S31A0010893D0DCFBB0001BBB40001BCB3000EFADF000CAFFD0002F7 S31A00108952FD01000E2A20000EFADF0032DDAA000EA1FE000EA0A9 S31A00108967D800191F260002CF260002CB270002CC28001EAD0102 S31A0010897C000CBADA000EAFFF0002FF00000EAEFE000EADFF00FF S31A001089913ADBA70004A0E40004A1E50018AB08000E2B7F000E5C S31A001089A61BFF0036DD8E000EA1FF000EA01C0018AF34000EBFAB S31A001089BBFB0002CF340033DD8C003AD7D5003ADC7D000EA1BE0F S31A001089D0000EA0370018AB03000E2BF7000E1BFF0036DD6900FD S31A001089E50EA3FF000EA21C001AAB01000E2BEF000E1BFF00369F S31A001089FADD69000EA06F000EA17F0018AB03000E2BFC000E1B9D S31A00108A0FFF0032DD69001AAC15001AAB14003A7FC0000EA1BE2B S31A00108A24000EA02C00180B020032DD7200181C030034DD6900F6 S31A00108A3904ACB30004ABB400196D09000CAFDE000EADFF000E5C S31A00108A4EAFFE0002FF00003ADBA7000EA06F000EA17F0018AB85 S31A00108A6303000E2BFC000E1BFF0032DD27000EA5FF000EA41CD2 S31A00108A78001CAB00000E2BF3000E1BFF0032DD27001CAC1500A5 S31A00108A8D1CAB14003A7FC0000EA1BE000EA02C00180B020032CC S31A00108AA2DD5500181C030030DD27000EA1FE000EA0A20018AC4B S31A00108AB7030018AB02003A7FC0000EA1BE000EA02C00180B02E7 S31A00108ACC0032DD4A00181C030030DD27001CAB00000E2BEF00CC S31A00108AE10E1BFF0032DD27000EA1BE000EA0370018AB01000EE8 S31A00108AF62BDF000E1BFF0036DD27000EABFF000EAC1B000EADA1 S31A00108B0BEF003A7FA4000EA1BE000EA02C0018AF09000E1FFEB1 S31A00108B200034DD3200051F9B0001BF9B000E1FFE0032DD2F0064 S31A00108B350EAFFE0002FF020033DD1D000EA1BE000EA02C0004DF S31A00108B4AAF9B00181F090032DD1D000EAF000002FF020033DD7A S31A00108B5F1D000EA06F000EA17F000EAF030002CF03000EAF0032 S31A00108B740002FF02000EABFF000EAC1B000EADEF003A7FA30040 S31A00108B891EAF02000E1FFE0032DD180004AF9C0032DD13001E11 S31A00108B9EAF02000E1F000032DD110004AF9C0032DD11000EAF82 S31A00108BB3FF0002FF02001EAF02000E1FFE0032DCEA000EFADFBC S31A00108BC8000CAFFB0002FB010000FE9C000E2A20000EFADF00F5 S31A00108BDD32DD0A000EA06F000EA17F000EAF020002CF00001861 S31A00108BF2AB01000EBBFD0002CB01000EA09F000EA17F0018ABDA S31A00108C0700000EBBF80002CB00000EAF000002CF010018AB0062 S31A00108C1C000EBBF80002CB00000EA0BF000EA17F000EAFFF0048 S31A00108C3102CF00000EA24F000EA37F000EA1BE000EA0370018AE S31A00108C46AB00000E2BF80002DB000033DCBF001EAF02000E1F80 S31A00108C5B000032DCBD000EFADF000CAFFB0002FB010000FF9CED S31A00108C700000FF9B000E2A20000EFADF0032DCE2000EA26F00F1 S31A00108C850EA37F001AAB01000E2B020002DB01000EA09F000E5A S31A00108C9AA17F000EAF000002CF01000EAF080002DF00000EA0AC S31A00108CAF4F000EA17F000EAFFF0002CF00000EAF030002DF03EC S31A00108CC4000EA2BF000EA37F000EAFFC0002DF00000EA1FF009E S31A00108CD90EA01C0018AB00000E2BF7000E1BFF0032DCC2000EAD S31A00108CEEAFFD0002DF000004AFE0000E2F010001BFE0001EAB94 S31A00108D0301000CBABA0004AFA30032DC850004AF9C000E1FFE61 S31A00108D180032DC85000EFADF000CAFFB0002FB01000E2A2000AA S31A00108D2D0EFADF0032DCB5000EA1BE000EA02C0018AF0C003621 S31A00108D42DCA80018AF0C00041FA40034DCA200051FA40001BFAE S31A00108D57A40033DC9F000EA1FF000EA01C0018AB01000E2BDF4B S31A00108D6C000E1BFF0036DC9F0004AFE0000EBFFE0001BFE00005 S31A00108D810EA5FF000EA41C001CAC15001CAB14003A7FC0000E08 S31A00108D96A1BE000EA02C0018AF0200037FFF0018A0030016A1BD S31A00108DAB01000C01BF0032DC91000C10CF0034DC87001CAC09DE S31A00108DC0001CAB08000EA1BE000EA02C00180B0A0032DC8900AE S31A00108DD5181C0B0031DC87003AFAC1001EAB01000CBABA00045D S31A00108DEAA0E40004A1E50018AF08000EBF7F0002CF080016AF97 S31A00108DFF0300397FAC0023FFFF00397FAD003AD6ED000EA1FEB2 S31A00108E14000EA0AB0018AE050018AD04000EABFF000EAC1600BE S31A00108E293AFB06003AD52F003AD5A2003AD756000EA1BE000E12 S31A00108E3EA0370018AB04000E2BFE000E1BFF0036DC5A000EA1F1 S31A00108E53FF000EA01C0018AC1F00043CA50018AB1E00047BA65D S31A00108E68003A7FC0000EA1BF000EA0AE00180B700032DC5F009C S31A00108E7D181C710034DC5A000EABFF000EAC11000EADEF003A54 S31A00108E927FA4003AD630000EA02F000EA17F0018A500000E1C60 S31A00108EA7FF0036DBB1000EA1FF000EA01C0018AB01000E2BBFAB S31A00108EBC000E1BFF0036DC260018AB3F000E2BFE000E1BFF00CA S31A00108ED136DC48000EB5FE0033DC47000E2501000EA1FF000E15 S31A00108EE6A01C0018AB3F000E2BFD000E1BFF0036DC3F000EB531 S31A00108EFBFD0033DC3E000E2502000EA1FF000EA01C0018AF3E50 S31A00108F10000E1FFE0034DC340019BF3E0002CF3E000E1FFE0077 S31A00108F2532DC34000E2503000EF5FC000CAFFB000E1BFF00329A S31A00108F3ADC2C000EABFF000EAC1B000EADBF003A7FA3000EA1F2 S31A00108F4FFF000EA01C0018AB01000E2BBF000E1BFF0032DC2517 S31A00108F64000E2503000EA1FF000EA01C00196B1B000E2BFE005E S31A00108F790CAFBE000EADFF000EACFF000EABFF000EA3BE000EAC S31A00108F8EA237001AA404000E247F000E14FF0036DC110018AB65 S31A00108FA31B000E2BF7000D9FBB000EEBFD000CAFBC000E6BFE0D S31A00108FB8000CBBD9000CBCE8000EAEFF000EADFF001AAB040000 S31A00108FCD0E2BBF000E1BFF0036DC020018AB0A000E2BFD000D35 S31A00108FE29FBB000EEBFD000CAFBE000CAFED000E6DFE000CBDB1 S31A00108FF799000CBE88000EAEFF000EADFF001AAB04000E2BDF0E S31A0010900C000E1BFF0036DBF30018AB0A000E2BF7000D9FBB00A9 S31A001090210EEBFD000CAFBE000CAFED000E6DFE000CBD99000C26 S31A00109036BE88000EAEFF000EADFF001AAB04000E2BEF000E1B3A S31A0010904BFF0036DBE30018AC0B000E2C7F000D9FFB000CBBCB46 S31A00109060000EEBFD000CAFBE000CAFED000E6DFE000CBD9B00F1 S31A001090750CBE8C000CBCBF0036DBDE000EB5FD0018AB1B000E58 S31A0010908A2BFE000CAFB8000EA9FF000EAEFF000EADFF000E14D2 S31A0010909FFF0036DBCF0018AB1B000E2BFB000D9FBB000EEBFD58 S31A001090B4000CAFBE000CAFED000E6DFE000CBD9B000CBE8C003D S31A001090C90CBCBF0036DBCA000EB5FE000EA3FE000EA2A2000E4A S31A001090DEA1BD000EA0BB00199C0B0019CB0A001AAE03001AAD60 S31A001090F302000C0DBF0032DBBF000C1ECF0030DBBD000E2502B6 S31A00109108001AAC03001AAB0200180B0A0032DBB800181C0B007B S31A0010911D35DBB6000E2501000EABFF000EAC01000EAD7F003A46 S31A001091327FA30033DBAC000EB5FC000EABFF000EAC01000EAD49 S31A001091477F003A7FA4000EA02F000EA17F0002C50000397FACEB S31A0010915C0023FFFF00397FAD0016AFF00002FD040002FE0500A5 S31A001091711EA414003AD679000EA1FE000EA0AB0002CB0200029D S31A00109186CC03000E14FF0032DB97000EA1FE000EA0A20002CB60 S31A0010919B020002CC030004AE7C0004AD7D0004AC7E0004AB7F1E S31A001091B000397FD1000CAFDB000CAFEC003A7FC0000EA5BF00E3 S31A001091C50EA4FF001CAE32000EADFF000C0BDF0032DB88000C81 S31A001091DA1CEF0030DB310004AF7C00037FFF0004AF7D00037FC1 S31A001091EFFF0004AF7E00037FFF0004AF7F00037FFF0004AEAC93 S31A001092040004ADAD0004ACAE0004ABAF00397FD40016AF0400D0 S31A0010921901BBAF0001BCAE0001BDAD0001BEAC0000FF7F000000 S31A0010922EFF7E0000FF7D0000FF7C00051FAA0001BFAA00055F05 S31A00109243AB0001BFAB0004ACAA0004ABAB001C1B330032DB6857 S31A00109258001C1C340035DB19000EAFFF00037FFF000EAFFF005D S31A0010926D037FFF000EAFFF00037FFF000EAF7900037FFF00045D S31A00109282AEAC0004ADAD0004ACAE0004ABAF00397FD90016AFF7 S31A0010929704000CAFE0000CAFD1000CAFC8000CAFB9001CAD348D S31A001092AC001CAC33000EAFFF00397FD200037EFF00037DFF0057 S31A001092C1037CFF00037BFF000CAF9B000CAF8C000CAF1D000C06 S31A001092D6AF0E00397FD50016AF0400397FD1000CAFDB000CAF80 S31A001092EBEC003A7FC0001CAE31000EADFF000C0BDF0032DB3EFD S31A00109300000C1CEF0034DB340004AFAF0001BF7F0004AFAE00E6 S31A0010931501BF7E0004AFAD0001BF7D0004AFAC0001BF7C003384 S31A0010932ADB1F000000AB000000AA0033DB1D0004AFAC00037FBD S31A0010933FFF0004AFAD00037FFF0004AFAE00037FFF0004AFAFDF S31A0010935400037FFF0004AE7C0004AD7D0004AC7E0004AB7F00B5 S31A00109369397FD40016AF040001BB7F0001BC7E0001BD7D0001D2 S31A0010937EBE7C0000FFAB0000FFAA0000FFAF0000FFAE0000FFDD S31A00109393AD0000FFAC000EA1BF000EA0FF0018AF0700037FFFED S31A001093A80018AF0600037FFF0018AF0500037FFF0018AF040034 S31A001093BD037FFF0004AE7C0004AD7D0004AC7E0004AB7F003913 S31A001093D27FD90016AF040001BB7F0001BC7E0001BD7D0001BEDF S31A001093E77C001EAD05001EAC04000EAFFE00397FD20004AF7CCD S31A001093FC00037FFF0004AF7D00037FFF0004AF7E00037FFF0062 S31A0010941104AF7F00037FFF00397FD90016AF040001BB7F0001E7 S31A00109426BC7E0001BD7D0001BE7C000EA5FE000EA49C001CAFA1 S31A0010943B000002FF06001CAF010002FF070002FB000002FC012F S31A001094500002FD020002FE03000CAF5B000CAF4C003A7FC20055 S31A001094650EA1FE000EA0AB001CAF01001E3F070002CF060018B7 S31A0010947AAC030018AB02003AD68C0004AF93000E1FFE0032DA3A S31A0010948FD90000FF980000FF970004AF900036DA70000EA1BF7B S31A001094A4000EA0AE0018A4730018A572000CB45F0032DACF00E9 S31A001094B90EA4FE000EA5FF0004AF93000E1FFD0032DAC8003AA8 S31A001094CEC1930001BB980001BC970000FF92000EA1BE000EA0CB S31A001094E3370018AB04000E2BF7000E1BFF0036DAC00000FE92A8 S31A001094F80000FE91000EA1FF000EA01C0018A2230018A3220088 S31A0010950D1813200032DAB8001812210036DAAB000EA3FE000E61 S31A00109522A2AB001AAC06000CAFCB000E6BFE0018CC210018DB10 S31A00109537200018AE230018AD22000C1DBF0032DAAA000C1ECF82 S31A0010954C0032DAAA0000FE920004AD970004AC98000EAFFE0063 S31A00109561397FD2000EAFFF00037FFF000EAFFF00037FFF000ECD S31A00109576AFFF00037FFF000EAF5E00037FFF00397FD90016AFA9 S31A0010958B04000CAFE0000CAFD1000CAFC8000CAFB9000CAF5C7C S31A001095A0000CAF4D000EAFFF00397FD200037EFF00037DFF0053 S31A001095B5037CFF00037BFF000CAF9B000CAF8C000CAF1D000C0F S31A001095CAAF0E00397FD50016AF040004AF920032DA16000EA34B S31A001095DFFE000EA287001AAF17000EFF7F0032DA16000EA1FFF0 S31A001095F4000EA01C001AA818001AA9170018091C0032DA7C0009 S31A0010960918181D0030DA160004AF7C00037FFF0004AF7D0003E6 S31A0010961E7FFF0004AF7E00037FFF0004AF7F00037FFF00397F86 S31A00109633D40016AF040033DA16000EA1FE000EA0AB0018AF027D S31A00109648000EFF7F0032DA680018AF020018BF030032DA3E000A S31A0010965D04AF93000E1FFD0032DA62003AC1B00001BB98000104 S31A00109672BC970004AD970004AC98000EAFFE00397FD20002FBA8 S31A00109687080002FC090002FD0A0002FE0B000EA1BE000EA03743 S31A0010969C0018AD0A0018AC09000EAFFF00397FD200037EFF0041 S31A001096B1037DFF00037CFF00037BFF001EAE0F001EAD0E001E42 S31A001096C6AC0D001EAB0C00397FD50016AF04000EAFFF00037F57 S31A001096DBFF000EAFFF00037FFF000EAFFF00037FFF000EAF7EB0 S31A001096F000037FFF000E8C7F00397FD40016AF040033DA200033 S31A0010970504AF93000E1FFD0032DA38003AC1D10001BB98000164 S31A0010971ABC970004AD970004AC98000EAFFE00397FD20002FBFF S31A0010972F0C0002FC0D0002FD0E0002FE0F000EA1BE000EA0378A S31A001097440018AD0A0018AC09000EAFFF00397FD200037EFF0098 S31A00109759037DFF00037CFF00037BFF001EAE13001EAD12001E91 S31A0010976EAC11001EAB1000397FD50016AF040004AF7C00037F33 S31A00109783FF0004AF7D00037FFF0004AF7E00037FFF0004AF7F27 S31A0010979800037FFF00397FD90016AF040000FF93000EA5FE0088 S31A001097AD0EA496000EAFC00002EF00000EAF000002EF0100022A S31A001097C2FB000002FC010002FD020002FE03000CAF5B000CAFAD S31A001097D74C003A7FC2001D1C01001CAB00000EDB3F0001BBBA01 S31A001097EC0001BCB90004AF900036D9F8003A7FC00001BBBA00A3 S31A0010980101BCB9000E0BFF0032D9FB000E1CFE0034D9F800007B S31A00109816FFBA0000FEB90016AF1000397FAC0023FFFF00397FA5 S31A0010982BAD0016AFF90002FB01000EAFFF0002FF06000E2A208E S31A00109840000EFADF0032D9F0000EA0CF000EA17F0018AB0100AC S31A001098550EBBFB0002CB01000EBADF000EA1BE000EA037001845 S31A0010986AAB03000E2BFB000E1BFF0032D9DF001EAF010036D902 S31A0010987FD5000EA0BF000EA17F0018AB00000E2BFD000E1BFF2D S31A001098940032D9D5000EAFFD0002CF00000EAFFE0002FF06007C S31A001098A90EA4CF000EA57F001CAB01000EBBEF0002EB01000E65 S31A001098BEABFC001EAF010036D9CC000EABDC003AF9A0003AF994 S31A001098D39A0002FB020002FC030002FD040002FE05000E2A2070 S31A001098E8000EFADF0032D9C6001CAB01000E2B040002EB0100AA S31A001098FD0EBADF001EAF060036D9B9000EA0BF000EA17F000E55 S31A00109912AFFF0002CF00001CAB01000E2B100002EB0100059C0B S31A00109927950005CB96003AD679001EAF010032D9AC000EA1FE5F S31A0010993C000EA0AB0002CB070002CC080033D9A8000EA1FE009C S31A001099510EA0A20002CB020002CC03001EAE0500043E78001E52 S31A00109966AD0400047D79001EAC0300047C7A001EAB0200047B1A S31A0010997B7B000ECE7F000D5FDD000D5FCC000D5FBB000CAFDEAA S31A00109990000CAFCD000CAFBC000E6BFE000CAFE2000CAFD3000B S31A001099A50EFD7F0036D992000EA2FF000EA3FF00041383003241 S31A001099BAD98F000412820030D9740004AE840004AD85000EACDF S31A001099CFFF000EABFF000CAFDB000CAFEC000EAEFF000EADFF04 S31A001099E40004A0820004A183000EA8FF000EA9FF000370FF002D S31A001099F90371FF000378FF000379FF00397FD60016AF04000C78 S31A00109A0EAFDB000CAFEC000CAF3D000CAF2E003A7FC8000CAFDF S31A00109A23C4000CAFB50033D9690004AC800004AB81000CAF2E26 S31A00109A3800043E82000CAF3D00047D83003A7FC8000CAFC40043 S31A00109A4D04C484000CAFB50004D585000EABFE000EACAF000CA8 S31A00109A62AF5D000CAF4E003A7FA6000EA1BF000EA0FF0018AC86 S31A00109A770D000CAFCB000E6BFE000CCC44000CDB55000EA1FFB4 S31A00109A8C000EA01C0018AF280018BF290036D92B000EAC7B0087 S31A00109AA10EABFC0018AE290018AD28000E0DF10032D951000E93 S31A00109AB61ECF0030D946000EACAD000EAB01000E0DF70032D90B S31A00109ACB4B000E1E020034D946000CAFEC000ECCAB000CAFDBE2 S31A00109AE0000EDB0A000CAFC8000EC8F9000DFFB9000EA1BF00E3 S31A00109AF50EA0FF0018AE2C000EADFF000CAF9B000CAF8C003917 S31A00109B0A7FDD000EAFFB0002FF00000EABBF000EACDB003A7F55 S31A00109B1FBC000EA1BF000EA0FF0018AF2E00037FFF0018AF2DDA S31A00109B3400037FFF000CAFCE000CAFBD00397FD80016AF02002D S31A00109B490C4E44000C5D55001EAF010032D925000EA1FE000EDC S31A00109B5EA0AB0002C5000002C401000EA1FE000EA0A20002C53F S31A00109B73000002C4010016AF0700397FAC0023FFFF00397FAD4A S31A00109B880016AFFB0002FB000002FC010002FD02000EAFFF0039 S31A00109B9D02FF03000EAFFA0002FF04000E1CFF0036D8EB000EAD S31A00109BB21DFF0032D8FB000EABFA003AF9A0003AF99A000CAF59 S31A00109BC7DE000CAFCD000CAFBC000E6BFE000CAFE4000CAFD5F0 S31A00109BDC000434790004757A000CAF5B000CAF4C000EADFF00E3 S31A00109BF13AF976000CAFC4000CAFB5000EABFE000EACF4000C40 S31A00109C06AF5D000CAF4E003AFB06001EAF01000E1FFE0032D8E0 S31A00109C1BF6000EAFBE0002FF04001EAF010036D8EB000E2A2089 S31A00109C30000EFADF0032D8F4000EA0CF000EA17F0018AB0100B5 S31A00109C450EBBF70002CB01000EBADF001EAF020036D8DF000EF5 S31A00109C5AA0BF000EA17F0018AB00000E2BFD000E1BFF0032D827 S31A00109C6FDF000EAFFD0002CF00000EAFFE0002FF03000EABCF19 S31A00109C84003AF9A0000EABCF003AF9A4000EA0CF000EA17F00D8 S31A00109C9918AB01000EBBEF0002CB01001EAF020036D8D1001E8A S31A00109CAEAF04000EBFDF0002FF04001EAB04003AF9A4001EAFB6 S31A00109CC3020032D8CA001EAB00003AF9890033D8C9003AF99A7A S31A00109CD8000CAFDE000CAFCD000CAFBC000E6BFE000CAFE400B3 S31A00109CED0CAFD5001EAF010036D8B8000E2A20000EFADF0032B7 S31A00109D02D8C1000EA0CF000EA17F0018AB01000E2B080002CB20 S31A00109D1701000EBADF001EAF030036D8B2000EA0BF000EA17F4E S31A00109D2C000EAFFF0002CF00000EA0CF000EA17F0018AB010010 S31A00109D410E2B100002CB0100059C950005CB96003AD679001E9D S31A00109D56AF020036D8A0000EA1FE000EA0A200180B020032D857 S31A00109D6BA300181C030034D8A00002CB020002CC0300043479F6 S31A00109D800004757A000CAF5B000CAF4C001EAD01003AF9760033 S31A00109D950CAFC4000CAFB5001EAF020032D88B000EA1FE000E95 S31A00109DAAA0AB0002C5040002C405001EAF010032D88B000EAB91 S31A00109DBFFE000EACF4000CAF5D000CAF4E003AFB06000EA1FEC4 S31A00109DD4000EA0A20002C5040002C405001EAC010016AF0500E9 S31A00109DE9397FAC0023FFFF00397FA90016AFFE0016AF02003AA5 S31A00109DFEFE3F003AD7E9000EABEF003A7FE20001BB850001BCC2 S31A00109E1384000EABEE003A7FE20001BB830001BC82000EABED3A S31A00109E28003A7FE20001BB810001BC80000EABC6003A7FE200E0 S31A00109E3D0CAFCE000CAFBD0001BD9A0001BE99000CAFEF000E91 S31A00109E52CFEF0002FF01000CAFDF000EDFD80002FF00000EAC0B S31A00109E6700000EAB80003A7FBE0001BB9A0001BC990000FFA3D2 S31A00109E7C000EA0BF000EA17F000EAFFD0002CF000004AFA3003F S31A00109E910E1FFD0032D857003ADDED0033D85C003AD84F003A15 S31A00109EA6DDE4000EABFF003AD84B0033D85C0016AF0200397FD5 S31A00109EBBA80023FFFF00397FA9003ADDDE00397FA80023FFFFDC S31A00109ED000397FAD0016AFFE0002FB00000EA1FF000EA01C00CA S31A00109EE518A4150018A5140004ADA3000EA1BE000EA01F00180A S31A00109EFA05020032D83E001814030035D83B000EABFD0033D8B6 S31A00109F0F32000EA1BE000EA01F00199C010019CB00000C05BF51 S31A00109F240032D834000C14CF0030D82E000EAB01000EACFF003C S31A00109F393AD76B000CAFCD0033D827000EA1BE000EA01F001875 S31A00109F4EAC09000EABFF0002FD01003AD76B001EAD01000E1D08 S31A00109F63FF0036D7FA000E1D010032D81C000D9F44000DCF555A S31A00109F78000EA1BE000EA01F0018AC070018AB060033D81800CD S31A00109F8D0EA1BE000EA01F0018AC08000EABFF000EA1BE000E70 S31A00109FA2A01F001805040032D813001814050034D80F0001BB8F S31A00109FB7B20001BCB10033D7FC001EAF000036D80B000EADFFB9 S31A00109FCC0033D7FC0004ACB10004ABB2000E1BFF0032D806006A S31A00109FE10E1CFE0030D800000CAFDB000EEBFD000CCBDB000DDA S31A00109FF60FBD0033D7FC0005BFB10001BFB10005FFB20001BF12 S31A0010A00BB2000E1DFF0032D7EF000EA1BE000EA0370018AB033E S31A0010A020000E2BDF000E1BFF0036D7EF0000FE900004AFA300F5 S31A0010A03536D7EE0000FD930033D7EE0000FF900001BDA3000C81 S31A0010A04AAFDC0016AF0200397FAC0023FFFF00397FAD000EA100 S31A0010A05FBF000EA0FF0018AF080001BFA20018AF090001BFA108 S31A0010A074000EA4BF000EA57F000EAFFD0002EF00003AD69600CD S31A0010A0890EAFFF0002EF00000EA06F000EA17F000EAF080002ED S31A0010A09ECF0000397FAC0023FFFF00397FAD0016AFFE000EA16C S31A0010A0B3FE000EA0AB0018A4030018A502000CAF5B000CAF4C90 S31A0010A0C8003A7FC0000EA1BF000EA0FF0018AE30000EADFF0029 S31A0010A0DD0C0BDF0032D7C5000C1CEF0031D7C2000EA4FF000EF4 S31A0010A0F2A5FF0018AF2F0002FF01000EAFFF0002FF00000EAB31 S31A0010A107FF000EAC8F000CAF5D000CAF4E003AFAAB000EABFF2D S31A0010A11C000EAC08000CAF5D000CAF4E003AFB06000EABFF0042 S31A0010A1310EAC8F003A7FA0000CAFCE000CAFBD000EABFE000E9B S31A0010A146ACE4003AFB060016AF0200397FAC0023FFFF00397F1F S31A0010A15BA90016AFFC000CAFCD000CAFBC000EAFFE00397FD22B S31A0010A1700002FB000002FC010002FD020002FE03000EA3BF0054 S31A0010A1850EA2FF001AAC0A000CAFCB000E6BFE0004CCA10004BE S31A0010A19ADBA2000CAFCD000CAFBC000EAFFE00397FD2000CAF1E S31A0010A1AFE0000CAFD1000CAFC8000CAFB9001AAD36001AAC352A S31A0010A1C4000EAFFE00397FD200037EFF00037DFF00037CFF00AE S31A0010A1D9037BFF000CAF9B000CAF8C000CAF1D000CAF0E003967 S31A0010A1EE7FD50016AF04001EAF0300037FFF001EAF0300037F86 S31A0010A203FF001EAF0300037FFF001EAF0300037FFF000E8C7F76 S31A0010A21800397FD40016AF040016AF0400397FA80023FFFF007C S31A0010A22D01BB8A0001BC890023FFFF00397FA9000EABFF003A06 S31A0010A242D9F5003AD6AF00397FA80023FFFF000E1B010036D7AC S31A0010A25767000E1BFD0032D7590004AFB0000E1FFE0034D75EF6 S31A0010A26C0004AFA3000E1F010036D75E0004AFA3000E1FFD0058 S31A0010A28132D75C000CAFBC0033D7570005BFB00001BFB000335E S31A0010A296D7580001BCB00004ACA30023FFFF00397FAD0016AF63 S31A0010A2ABFE000EA5FF000EA41C001CAC0900043C9F001CAB088B S31A0010A2C000047BA0000EAFFD0002FF00000EAFFE0002FF0100DC S31A0010A2D50EADBF000EAEC8003AD724001CAC0700043C9D001C63 S31A0010A2EAAB0600047B9E000EAFFE0002FF00000EAFFE0002FF03 S31A0010A2FF01000EADBF000EAEC5003AD724001CAC15001CAB144B S31A0010A314000EAFFB0002FF00000EAF7E0002FF01000EADBF00AE S31A0010A3290EAEC2003AD7240004AB86000E2BFC000E1BFF00368E S31A0010A33ED7270004AB86000E2BFB000E1BFF0036D727000CAF76 S31A0010A3535B000CAF4C000EADF7003A7FA40016AF0200397FAC43 S31A0010A3680023FFFF00397FAD0016AFFF000CAFC8000CAFB90089 S31A0010A37D0CAFE4000CAFD5003A7FC0000CAFC0000CAFB1000C1A S31A0010A392AF19000CAF08001EAB0500042B86000E1BFF0036D65E S31A0010A3A7FE000EACFF001CAE01001CAD00001EAB06000E2B7FB9 S31A0010A3BC000C1BCF0036D709000C01DF0032D70B000C10EF005F S31A0010A3D134D7040033D705000C01DF0032D706000C10EF00310C S31A0010A3E6D704000EACFE000E1CFF0036D6F2001F8B0500042FB0 S31A0010A3FB860001BF860033D6F2001EAF060002FF00000CAF9B46 S31A0010A410000CAF8C000CAF5D000CAF4E003ACC74000CAFCE00B6 S31A0010A4251EAB05000EACFF000EAD87003ACC8400051F6700012D S31A0010A43ABF670016AF0100397FAC0023FFFF00397FAD0016AF5C S31A0010A44FFE000EA5FE000EA4AB001CAE01001CAD00000EA1BFD4 S31A0010A464000EA0FF0018AF2F0002FF01000EAFFF0002FF00006B S31A0010A4790EABFF000EAC8B003AFAAB001CAE01001CAD00000E3A S31A0010A48EABFF000EAC14003AFB06000EABFF000EAC8B003A7F3A S31A0010A4A3A0000CAFCE000CAFBD000EABFE000EACB4003A7FA669 S31A0010A4B8001CAE08001CAD07000EABFE000EACE6003AFB060045 S31A0010A4CD0EA1FF000EA01C0018AC150018AB14001CAE01001C55 S31A0010A4E2AD00003AF9BB000CAFCE000CAFBD000EABFE000EAC42 S31A0010A4F7DC003AFB060016AF0200397FAC0023FFFF00397FA976 S31A0010A50C000E2A20000EFADF0032D6BC000EA06F000EA17F00D6 S31A0010A52118AB01000EBBF70002CB01003AFF180004ACDA0004DE S31A0010A536ABDB00397FA80023FFFF00397FAD0016AFFA000EA51C S31A0010A54BBE000EA437001CAC01000E2CFE000EABF8000EADFFD2 S31A0010A560003AD91E0001BCA9003AF99A0002FB000002FC010070 S31A0010A57502FD020002FE03001CAF070002FF04001CAF0800020B S31A0010A58AFF05000EABFF000EAC7B003AFA920016AF0600397F6C S31A0010A59FAC0023FFFF00397FA9000EABF8003AF9A0003AF99A12 S31A0010A5B40001BB7B0001BC7A0001BD790001BE7800397FA80040 S31A0010A5C923FFFF000EADFF000EFB7F0032D686000CBCBF0036B9 S31A0010A5DED686000EADFE00041DA80036D67B0004AFA30032D68F S31A0010A5F37C000EA1BE000EA0370018AB03000E2BDF000E1BFF69 S31A0010A6080032D67B0000FD930001BDA80023FFFF00397FA9002C S31A0010A61D16AFFC000CAFCD000CAFBC000EAFFE00397FD200020B S31A0010A632FB000002FC010002FD020002FE03000EA3BF000EA2DF S31A0010A647FF001AAC0A000CAFCB000E6BFE0004CCA10004DBA22A S31A0010A65C000CAFCD000CAFBC000EAFFE00397FD2000CAFE000F4 S31A0010A6710CAFD1000CAFC8000CAFB9001AAD36001AAC35000E35 S31A0010A686AFFE00397FD200037EFF00037DFF00037CFF00037B77 S31A0010A69BFF000CAF9B000CAF8C000CAF1D000CAF0E00397FD5CA S31A0010A6B00016AF04001EAF0300037FFF001EAF0300037FFF0014 S31A0010A6C51EAF0300037FFF001EAF0300037FFF000E8C7F003976 S31A0010A6DA7FD40016AF04000E8C7F0001BC7E0001BB7F0001BDEC S31A0010A6EF7D0001BE7C001AAF0300037FFF001AAF0200037FFFEF S31A0010A704001AAF0100037FFF001AAF0000037FFF0004AE7C0067 S31A0010A71904AD7D0004AC7E0004AB7F00397FD90016AF04003AF7 S31A0010A72E7FBF0016AF0400397FA80023FFFF00397FAD000EA461 S31A0010A743FC003ACF8B000EFB7F0036D628000EACFF000EABFF2E S31A0010A7580033D5F2000EA5FF000EA0A9000EA17F0018AB0000E2 S31A0010A76D041B770032D60E000EA0A8000EA17F0018AB000004CA S31A0010A7821B760032D60E000EA0A7000EA17F0018AB0000041BA0 S31A0010A797750032D60E000EA1BD000EA0910004AC730004AB741B S31A0010A7AC00181B190032D60E00181C1A0032D60E000415A700FC S31A0010A7C132D5FD000EA5FE0001B5A7003AD5F0000E1CFF0036FD S31A0010A7D6D62B000EA0A9000EA17F0004AF770002CF00000EA029 S31A0010A7EBA7000EA17F0004AF750002CF00000EA0A8000EA17FF1 S31A0010A8000004AF760002CF00000E15FF0036D5F8000DBF4400FE S31A0010A8150E14000032D628000EACFF000EABFF000E15FF003201 S31A0010A82AD5F2000EACFE000EABFF00397FAC0023FFFF00397F8F S31A0010A83FAD0016AFFE000EABDB003A7FE20001BC77000EA1BEAE S31A0010A854000EA0320018AF00000E1FC00034D5E3000EACFF00A0 S31A0010A8690EABFF0033D5A50018AF000001BF75000EA1BE000EE8 S31A0010A87EA0310018AB00000E1BF80030D5E6000EA3BD000EA2F1 S31A0010A893A5000CAFBC000EABFF000CCCCC000CDBBB000CC2C0F2 S31A0010A8A8000CD3B10018AC01001A3C110018AB00001A7B100061 S31A0010A8BD1AAF120002FF00001AAF130002FF01000EAE17000ED5 S31A0010A8D2ADFC003A7FBE000CAFC4000CAFB5000EABE8003A7FF2 S31A0010A8E7E2000CAFCB000EECBF000EABFF000C44CC000C55BB35 S31A0010A8FC000EFB7F0036D5BB000ECCBF000D5FBB0033D5B50066 S31A0010A9110E0BFF0032D5B8000E1CC00034D5B5000ECC3F000D76 S31A0010A926FFBB000E1BFF0032D5B2000E1CC00030D5E6000CAFDB S31A0010A93BCF000EEFFB000CAFFB0001BB76000EA1BD000EA09197 S31A0010A9500018AF190001BF740018AF1A0001BF73000EACFE00FC S31A0010A9650EABFF0016AF0200397FAC0023FFFF00397FAD001648 S31A0010A97AAFFC000EA5FE000EA4A2001CAE05000ECEAB001CADE3 S31A0010A98F04000EDD0A000EAFBD0002FF00000EAFAF0002FF01BB S31A0010A9A4000EABFF0004AFA3000E1FFD0032D591000EABFE0001 S31A0010A9B902FB02000EABF7000CAFDC000CAFED003AD52D001C2D S31A0010A9CEAE05000ECEAB001CAD04000EDD0A000EAFBD0002FFE7 S31A0010A9E300000EAFAA0002FF01000EABFF0004AFA3000E1F01A4 S31A0010A9F80032D57F000EABFE0002FB02000EABFB000CAFDC00AD S31A0010AA0D0CAFED003AD52D001CAE01001CAD00000EAFBD00022A S31A0010AA22FF00000EAFBB0002FF01000EAFFE0002FF02000EAB19 S31A0010AA37FD000CAFDC000CAFED003AD52D001CAE01001CAD00E8 S31A0010AA4C000EAFBD0002FF00000EAFB60002FF01000EAF7E00B4 S31A0010AA6102FF02000EABFE000CAFDC000CAFED003AD52D001C79 S31A0010AA76AE01001CAD00000EAFBD0002FF00000EAF510002FFB3 S31A0010AA8B01000EAFFE0002FF02000EABDF000CAFDC000CAFED0A S31A0010AAA0003AD52D001CAE01001CAD00000EAFBD0002FF000040 S31A0010AAB50EAF560002FF01000EAF7E0002FF02000EABEF000C6F S31A0010AACAAFDC000CAFED003AD52D000EFADF000CAFFB0002FB58 S31A0010AADF03000E2A20000EFADF0032D547000EA1FF000EA0124E S31A0010AAF40004AC71000E2CCF0018AB00000E2B30000CBFCF0047 S31A0010AB0902CF00000EA1FF000EA0010004AC71000E2CF0001890 S31A0010AB1EAB00000E2B0F000CBFCF0002CF00001EAB03000CBA1C S31A0010AB33BA0016AF0400397FAC0023FFFF0000FF670023FFFF68 S31A0010AB4800397FAB0016AFFF000CAFB5000CAFD8000CAFC90034 S31A0010AB5D1EA005001EA104001EAC06000CAF5B00042B71000EB3 S31A0010AB721BFF0036D5090018AE040018AD03000E2C7F000CAF84 S31A0010AB87CB000E1BFF0036D515000EABFF000C09DF0032D517C6 S31A0010AB9C000C18EF0035D50F0033D510000EABFF000C09DF009E S31A0010ABB132D511000C18EF0030D50F000EABFE000E1BFF003625 S31A0010ABC6D4FE000D8F5B00042F710001BF710033D4FE0002FCC3 S31A0010ABDB00000CAF9B000CAF8C000CAF1D000CAF0E003ACC7497 S31A0010ABF0000CAFCE000CAF5B000EACFF000EAD72003ACC84002B S31A0010AC05051F670001BF670016AF0100397FAA0023FFFF0039F0 S31A0010AC1A7FAB000CAFB5000EACFF0004AB69000E1BD90036D498 S31A0010AC2FB4000E0BD90030D4E3000E0BE60030D4EA000E0BFB6C S31A0010AC440031D4CC000C0BCF0035D4950033D4D1000E1BDB00B4 S31A0010AC5936D4B4000E0BDB0030D4C1000E0BE30035D49500338C S31A0010AC6ED4CC000E0BD00030D4DA000E0BD30031D4AF000E1B8B S31A0010AC83D80036D4C1000E0BD60030D4950033D4CC000E0BC1CE S31A0010AC980035D495000E0B9E0034D497000E0B880030D4950063 S31A0010ACAD0E0B8B0035D4950033D4A40004AC69000EABFF000EB0 S31A0010ACC2CC1D000EDBFF0033D49A000EA1FF000EA01C0018ABBA S31A0010ACD700000E2BDF000E1BFF0032D4950004AC69000EABFFA6 S31A0010ACEC000ECC1D000EDBFF0033D49A000EA1BE000EA037006B S31A0010AD0118AB03000E2BFE000E1BFF0036D4B40004AB68000E1F S31A0010AD162B80003ACCF8000E1CFF0036D4B4003AFADC0000FF73 S31A0010AD2BB80004AC69000EABFF000ECC1D000EDBFF0033D49AF4 S31A0010AD40000EA1FF000EA01C0018AB00000E2BDF000E1BFF006D S31A0010AD5532D4950004AC69000EABFF000ECC1F000EDBFF003353 S31A0010AD6AD49A000EA1FF000EA01C0018AB00000E2BDF000E1BD4 S31A0010AD7FFF0032D4950004AC69000EABFF000ECC53000EDBFF29 S31A0010AD94000CAF5D003AD37B0033D495000CAF5B003ACE3E00FC S31A0010ADA90E1CFF0036D48D0004AF69000EBF7F0001BF6800052A S31A0010ADBE1F690001BF690033D48C0000FE68000EABFF00397F50 S31A0010ADD3AA0023FFFF00397FA9000EA1FF000EA01C0018AC00ED S31A0010ADE8000EECF7000E2CFE0004AB69000E0BAB0030D46400D3 S31A0010ADFD0E0BBF0031D412000E0BCA0030D470000E0BCB0031D0 S31A0010AE12D43A000E0BD60030D473000E0BFD0031D446000E0B27 S31A0010AE27FF0035D3DA0033D44A000E0BD40034D4420033D43E52 S31A0010AE3C000E0BC40030D469000E0BC50031D42E000E0BC800AF S31A0010AE5134D4360033D432000E1BC10036D415000E0BC100304C S31A0010AE66D4000033D42A000E0B8E0030D454000E0B910031D30F S31A0010AE7BEC000E0B9A0030D459000E0B9B0031D3F4000E0B9E4D S31A0010AE900034D40A0033D3F8000E0B980034D3F0000E1B920024 S31A0010AEA536D4220033D3DA000E0B880030D44F000E0B8B0031AD S31A0010AEBAD4260033D3E8000E1B860036D3E4000E0B860030D347 S31A0010AECFE00033D4190004AB69003AD208003ACD0D0033D3D63C S31A0010AEE4000EABFF000EAC1A000EADFD0033D3DD000EABBD00A6 S31A0010AEF90EAC6E000EADD50033D3DD000EABFE000EACF2000E22 S31A0010AF0EADD30033D3DD000EABFE000EAC87000EADCB0033D331 S31A0010AF23DD000EABFE000EAC51000EADC90033D3DD000EABFE46 S31A0010AF38000EACEA000EADC70033D3DD000EABBE000EAC37007D S31A0010AF4D0EADC50033D3DD000EABBD000EAC6A000EADC300332B S31A0010AF62D3DD000EABFE000EACDE000EAD8B0033D3DD000EA0EE S31A0010AF772F000EA17F0018AC01000E2CC00018AB00000EEBBF18 S31A0010AF8C000CAFFB000CBCBC0033D3D6000EA02F000EA17F0079 S31A0010AFA118AC030033D3D6000E1CFF0032D3DA0033D400000EC5 S31A0010AFB61CFF0036D400000EA1FE000EA0D80018AF01000E1F23 S31A0010AFCBFB0030D3DA0033D400000E1CFF0036D400000EA1FE9C S31A0010AFE0000EA0D80019BB01000E1BFC0030D3DA0004AF6900CD S31A0010AFF50E1F9E0036D3DA0004AC69000EABFF000CAFC0000E29 S31A0010B00AC016000CAFB1000ED1FF0018AC000033D3D6000EABA2 S31A0010B01FFE000EAC4D000EAD9D0033D3DD000EABFE000EAC74E1 S31A0010B034000EAD9B0033D3DD000EABFE000EAC7A000EAD990079 S31A0010B04933D3DD000EABFE000EACE8000EAD910033D3DD000E63 S31A0010B05EABFE000EAC70000EAD8D0033D3DD000EA1FE000EA06E S31A0010B073D80018AC260033D3D6000EABFE000EACB1000EAD85B2 S31A0010B088003ACD18003ACD0D0033D3D60000FE68000EAC00006E S31A0010B09D0EABFF0033D3D10004AF690001BF6800051F69000127 S31A0010B0B2BF69000EABFF00397FA80023FFFF00397FAB000CAFF4 S31A0010B0C7BC000EA1FF000EA01C0018AB00000EEBF7000E2BFE40 S31A0010B0DC000E1C920036D3A0000E0C920030D3A0000E0CAB00D0 S31A0010B0F130D3B9000E0CBF0031D3B1000E1CC10036D3B4000E34 S31A0010B1060CC10030D3A0000E0CFF0035D39D0033D3A0000E0C30 S31A0010B11B9E0034D3A9000E0C980030D39D0033D3A0000E1BFF9B S31A0010B1300032D39D0033D3A0000E1BFF0036D3A0000EA1FE002E S31A0010B1450EA0D80018AF01000E1FFB0030D39D0033D3A0000E15 S31A0010B15A1BFF0036D3A0000EA1FE000EA0D80019BB01000E1BD6 S31A0010B16FFC0030D39D000E1C9E0036D39D0001BC69000EA5FED4 S31A0010B1840033D39C000EA5FF0004AB68000E2B80003ACCF8007E S31A0010B1990E1CFF0036D395000E15FF0032D3940000FE68000C97 S31A0010B1AEAF5C000EABFF00397FAA0023FFFF00397FAB000EA11E S31A0010B1C3FF000EA01C0018A500000E2560000EABF9003A7F9F3E S31A0010B1D8000E1B000032D385000E1C000036D384000EB59F0080 S31A0010B1ED0EA1FF000EA01C0002C500000EA1FE000EA0D8000EB7 S31A0010B202AFFF0002CF0100397FAA0023FFFF00397FAD0016AFF4 S31A0010B217FF000CAFC4000CAFB50002FD00003A7FF40004AB685B S31A0010B22C000E2B7F000E1BFF0036D35D0004AB68000E2B8000E1 S31A0010B24101BB68003ACCF8000E1CFF0036D35D001EAB00000E5A S31A0010B256ACFF0004AE70000EADFF000CCECE000CDDBD0004AB49 S31A0010B26B680032D35F000CAFDB000CAFEC003AD00F0033D35D33 S31A0010B2800002ED000002EE01001EAF000001BF70000EACFE000E S31A0010B2950EABFF0016AF0100397FAC0023FFFF0016AFFC000EBC S31A0010B2AAA1FE000EA0D80018AB00000E1BBD0036D2A8000E0BE2 S31A0010B2BFBD0030D327000E1BCE0036D2D9000E0BCE0030D33784 S31A0010B2D4000E1BDD0036D2F5000E0BDD0030D341000E1BFD00EC S31A0010B2E936D303000E1BEF0036D2FC0033D239000E1BD800369D S31A0010B2FED2E7000E0BD80030D33A000E1BDB0036D2EE0033D23F S31A0010B31339000E1BCF0036D2E00033D239000E1BC50036D2C4FE S31A0010B328000E0BC50030D32E000E1BC70036D2D2000E1BC60032 S31A0010B33D36D2CB0033D239000E1BC30036D2B6000E0BC3003519 S31A0010B352D2BD000E1BBF0036D2AF0033D239000E1BAA0036D289 S31A0010B36777000E0BAA0030D315000E1BAE0036D293000E0BAE30 S31A0010B37C0030D31A000E1BBB0036D2A1000E1BAF0036D29A0082 S31A0010B39133D239000E1BAC0036D285000E0BAC0030D27E003379 S31A0010B3A6D28C000E1B950036D254000E0B950030D30A000E0B30 S31A0010B3BBA70035D239000E0BA60034D269000E1B970036D25B2F S31A0010B3D00033D239000E1B930036D270000E0B930035D24D00E0 S31A0010B3E50E1B8F0036D2460033D239000EAFBD0002FF00000E70 S31A0010B3FAAFBB0002FF01000EA0E9000EA1FF0033D235000EAF80 S31A0010B40FBD0002FF00000EAFA50002FF01000EA0EB000EA1FFA9 S31A0010B4240033D235000EAFBE0002FF00000EAF5C0002FF01002C S31A0010B4390EA0F9000EA1FF0033D235000EAFBE0002FF00000ECF S31A0010B44EAF560002FF01000EA0F2000EA1FF0033D235000EAF87 S31A0010B463BE0002FF00000EAF490002FF01000EA0ED000EA1FFAE S31A0010B4780033D235000EAFBD0002FF00000EAF760002FF0100BF S31A0010B48D0EA0E7000EA1FF0033D235000EAFBD0002FF00000E8E S31A0010B4A2AF5E0002FF01000EA0ED000EA1FF0033D235000EAF30 S31A0010B4B7BD0002FF00000EAF900002FF01000EA0F3000EA1FF0E S31A0010B4CC0033D235000EAFBD0002FF00000EAF840002FF01005D S31A0010B4E10EA0F1000EA1FF0033D235000EAFBD0002FF00000E30 S31A0010B4F6AF4C0002FF01000EA0BF000EA1FF0033D235000EAF1C S31A0010B50BBD0002FF00000EAFFB0002FF01000EA0F3000EA1FF4E S31A0010B5200033D235000EAFBD0002FF00000EAFEF0002FF01009D S31A0010B5350EA0FC000EA1FF0033D235000EAFBE0002FF00000ECF S31A0010B54AAF370002FF01000EA0F4000EA1FF0033D235000EAFA7 S31A0010B55FBD0002FF00000EAFEC0002FF01000EA0FA000EA1FF02 S31A0010B5740033D235000EAFBE0002FF00000EAF2C0002FF01000B S31A0010B5890EA0F2000EA1FF0033D235000EAFBF0002FF00000E84 S31A0010B59EAFAE0002FF01000EA08B000EA1FF0033D235000EAF45 S31A0010B5B3BE0002FF00000EAF1F0002FF01000EA0F3000EA1FF81 S31A0010B5C80033D235000EAFBF0002FF00000EAFBD0002FF010025 S31A0010B5DD0EA0F0000EA1FF0033D235000EAFBF0002FF00000E32 S31A0010B5F2AF3A0002FF01000EA0AD000EA1FF0033D235000EAF43 S31A0010B607BE0002FF00000EAFE80002FF01000EA0AF000EA1FFA7 S31A0010B61C0033D235000EAFBE0002FF00000EAF980002FF0100F6 S31A0010B6310EA0E1000EA1FF0033D235000EAFBE0002FF00000EED S31A0010B646AF7A0002FF01000EA0E1000EA1FF0033D2350018AE71 S31A0010B65B00000EADFF000EEEBF00037FFF000EEDBF000CBFED5C S31A0010B6700016AE01000ECEFF0002FE01000EDDD20002FD000052 S31A0010B6850EA0DF000EA1FF0033D235000EAFBF0002FF00000E9A S31A0010B69AAFFF0002FF01000EA0F1000EA1FF0033D235000EAF91 S31A0010B6AFBF0002FF00000EAFF10002FF01000EA0DE000EA1FFC6 S31A0010B6C40033D235000EAFBF0002FF00000EAFD00002FF010015 S31A0010B6D90EA0EC000EA1FF0033D235000EA1FF000EA01C001834 S31A0010B6EEAB00000E2BBF000E1BFF0032D239000EAFBE0002FFAD S31A0010B70300000EAF130002FF01000EA0E7000EA1FF0033D235CC S31A0010B718000EAFFF0002FF000002FF010033D210000EA3FE0083 S31A0010B72D0EA2D8001AAE01000EADFF000EEEDF00037FFF000E7C S31A0010B742EDDF000CBFED0016AE01001ECE010002FE01001EDDAA S31A0010B757000002FD00000CAF0C000ECCE0000D5F1B000EECF7CF S31A0010B76C000EEBF7000CBCFC000CAFCD000DBFDB001A1B010099 S31A0010B78134D21B000EAFDF0002FF030033D20E001A1D0100345D S31A0010B796D210000CAFDE000EADFF000DBFEE000DFFDD000EEEB4 S31A0010B7ABDF000CAFFE000C4E0F0002FF030033D20E000EAFFF9F S31A0010B7C00002FF03001EAE03001EAD02001EAC01001EAB00002A S31A0010B7D516AF040023FFFF00397FA90004AB6F000E1BF8003689 S31A0010B7EAD1C9000E0BF80030D1F2000E1BFD0036D1DA000E0B76 S31A0010B7FFFD0030D1F9000E1BFF0036D1E2000E1BFE0036D1DD0C S31A0010B8140033D1B0000E1BFB0036D1D4000E0BFB0035D1D70065 S31A0010B8290E1BFA0036D1CE0033D1B0000E0BF40030D1E9000E43 S31A0010B83E0BF50031D1BB000E1BF70036D1C6000E1BF60036D10F S31A0010B853C10033D1B0000E1BF30036D1B8000E0BE50030D1B0CB S31A0010B868000E0BE80035D1B00033D1B3000EA1FF000EA01C00CF S31A0010B87D18AC010018AB000033D1AE000EACBD000EABF800330B S31A0010B892D1AE000EABEF003A7F9F0033D1AE0004ACD5000EAB1C S31A0010B8A7FF0033D1AE000EA08F000EA17F0018AB04000CAFBC1C S31A0010B8BC000EABFF0033D1AE000EA1BD000EA0910018AC0D007B S31A0010B8D10EABFF0033D1AE0004AC6E000EABFF0033D1AE000E4C S31A0010B8E6A1BF000EA03A0018AC010018AB000033D1AE000EA106 S31A0010B8FBBF000EA0FF0018AC0A000CAFCB000E6BFE0033D1AE39 S31A0010B9100004ACA10004ABA20033D1AE000EA1BD000EA091000D S31A0010B92518AC0C0018AB0B0033D1AE0004AC6B0004AB6C00333E S31A0010B93AD1AE000EACFF000EABFF00397FA80023FFFF00397FB9 S31A0010B94FA9000E1BFF0032D1A8000E1CE50034D1A3000E1BFF72 S31A0010B9640032D144000E1CDC0032D1440004AF6F0001BF6E00D4 S31A0010B97901BC6F000E0CEB0030D191000E0CEC0031D183000E47 S31A0010B98E1CFA0036D141000E0CFA0034D141000E0CF80035D1BE S31A0010B9A341000E0CF30034D141000E1CEF0036D1830033D141FD S31A0010B9B8000E1CE60036D169000E0CE60030D188000E1CE80049 S31A0010B9CD36D175000E1CE70036D1810033D141000E1CE50036B0 S31A0010B9E2D153000E1CDC0036D14F0033D141003AD13F0033D127 S31A0010B9F741003ACF6A0001BB6C0001BC6B000EFB800001BF6C6C S31A0010BA0C0001BC6B000EA1BD000EA0910018AB13000E2B8000AD S31A0010BA2118AC140033D15E003ACF0E0001BB6C0001BC6B000E4B S31A0010BA36FB800001BF6C0001BC6B000EA1BD000EA0910018ABA8 S31A0010BA4B15000E2B800018AC160033D15E003ACED50001BB6CC1 S31A0010BA600001BC6B000EFB800001BF6C0001BC6B000EA1BD004A S31A0010BA750EA0910018AB17000E2B800018AC180004AE6B0004D7 S31A0010BA8AAD6C000C1DBF0032D158000C1ECF0036D141000CAF39 S31A0010BA9FDF000EBF7F0001BF6C0001BE6B0033D141003ACF8B22 S31A0010BAB40001BB6C0001BC6B0033D141000EA1FF000EA01C005A S31A0010BAC918AF1E0001BFA60018AF1F0001BFA5000EABFF000EF6 S31A0010BADEAC11000EADEF003A7FA30033D1410004AF6D0032D112 S31A0010BAF3410000FBC000397FA80023FFFF00397FAD0016AFF78A S31A0010BB08000CAFC4000CAFB5000E15FF0032D138000E140000A4 S31A0010BB1D30D014000CAF4B000CAFBC000EABFF000E1BFF00325A S31A0010BB32D130000E1CDF0036D0B7000E0BFF0032D12D000E1CAF S31A0010BB47DF0030D105000E1BFF0032D128000E1CEF0036D0C1BB S31A0010BB5C000E0BFF0032D125000E1CEF0030D112000E1BFF002A S31A0010BB7132D120000E1CF50036D0D1000E0BFF0032D11D000E4A S31A0010BB861CF50030D117000E1BFF0032D118000E1CF60036D002 S31A0010BB9BD60033D014000E1BFF0032D113000E1CF40036D0CB65 S31A0010BBB00033D014000E1BFF0032D10E000E1CEB0036D0B90046 S31A0010BBC50E0BFF0032D10B000E1CEB0030D014000E1BFF0032AC S31A0010BBDAD106000E1CEC0036D0BB0033D014000E1BFF0032D150 S31A0010BBEF01000E1CBF0036D05F000E0BFF0032D0FE000E1CBFDB S31A0010BC040030D0EC000E1BFF0032D0F9000E1CDD0036D07E007B S31A0010BC190E0BFF0032D0F6000E1CDD0035D09F000E1BFF0032EB S31A0010BC2ED0F1000E1CDB0036D043000E1BFF0032D0ED000E1C9B S31A0010BC43D20036D05F0033D014000E1BFF0032D0E8000E1C7FCD S31A0010BC580036D06E000E0BFF0032D0E5000E1C7F0030D0DF00C6 S31A0010BC6D0E1BFF0032D0E0000E1CBE0036D0190033D014000E76 S31A0010BC821BFF0032D0DB000E1C7E0036D05F000E1BFF0032D069 S31A0010BC97D7000E1C7D0036D0570033D014000EA1FF000EA01C18 S31A0010BCAC0018AF00000EBFFB0002CF00000EA1FF000EA01C0095 S31A0010BCC118AF00000EBFF70002CF000033D014000EAFBF000267 S31A0010BCD6FF00000EAFF70002FF01000EACFD000EABFF000EAD64 S31A0010BCEBFF000EAEA2003AFDBB0033D014000EA1FF000EA01C50 S31A0010BD000018AF01000EBFDF0002CF010033D014003AFAC100C6 S31A0010BD1533D014003AFAB60033D014000EABF9003A7F9F0002DF S31A0010BD2AFB020002FC03000E1B000032D0A1000E1C000032D0F8 S31A0010BD3FA1000EAFF80002FF02000EAFBD0002FF03000CAF6FD8 S31A0010BD54000ECFFD0002FF01000D5F7F0002FF00000EACFF0043 S31A0010BD690EABFF000EADF9000EAEFE003A7FEF003AD390003311 S31A0010BD7ED017000EA1BD000EA0910018A515000E25800018A4C7 S31A0010BD9316003ACF0E000E2B80000C15BF0032D017000C14CFB7 S31A0010BDA80032D017000EA1BF000EA0BD0018AB02000E2BFB0085 S31A0010BDBD0E1BFF0032D0800018AF020002FF04000EBFFB000219 S31A0010BDD2FF04000CAF6E000ECEFB000D5F7D000EAFBF0002FFDD S31A0010BDE700000EAFBB0002FF01000EACFE000EABFF003AFDBB55 S31A0010BDFC0000EEDF0033D017003A7FE90002FB050002FC06008D S31A0010BE1102FD070002FE08000CAF6E000ECEFA000D5F7D000E02 S31A0010BE26AFBD0002FF00000EAF820002FF01000EACFB000EABD5 S31A0010BE3BFF003AFDBB0033D017000EA0BF000EA17F000EAFFD7C S31A0010BE500002CF00000EABFF000EAC1C000EADEF003A7FA30062 S31A0010BE650EA1BF000EA0FF0018AF080001BFA20018AF09000195 S31A0010BE7ABFA10033D017000EA0BF000EA17F000EAFFD0002CFFD S31A0010BE8F00000EABFF000EAC1C000EADEF0033D04A000EA3FF53 S31A0010BEA4000EA21C001AAB00000E2BEF000E1BFF0036D0170075 S31A0010BEB90EA0BF000EA17F000EAFFC0002CF00000CAF3B000C37 S31A0010BECEAF2C000EADF7003A7FA4000EA1FE000EA0D8000EAF6F S31A0010BEE3FF0002CF260001B46F0033D017000EA1FF000EA01C88 S31A0010BEF80018AB01000E2BFE000E1BFF0032D0170018AB3F00E1 S31A0010BF0D0EEBFB000CAFB8000EA9FF00196B3F000E2BFE000CE6 S31A0010BF22AFBE000EADFF0018AB3F000E2BFE000CAFBC000EAB64 S31A0010BF37FF000CCCEE000CDBDD0018AB3F000EEBBF000E2BFE65 S31A0010BF4C000CAFBC000EABFF000CCCEE000CDBDD000C19DF000D S31A0010BF6132D01C000C18EF0032D01C000CCCCC000CDBBB000D13 S31A0010BF761FCF0002CF3E0018AF01000EBFBF0002CF010033D07A S31A0010BF8B17000EAF000002CF3E0033D017003ACCC20033FFFF95 S31A0010BFA0000EACFE000EABFF0033D012000EACFF000EABFF0080 S31A0010BFB516AF0900397FAC0023FFFF00397FAD0016AFF8000CE0 S31A0010BFCAAFC4000CAFB5000EA1FF000EA01C0018AF000002FF29 S31A0010BFDF05000EA1BD000EA076000EA3FF000EA21C0018AB085B S31A0010BFF4001A8B100018AC09001A8C11000E8BCA0002FB010088 S31A0010C0090E8C310002FC020018AB08001A8B100018AC09001ADA S31A0010C01E8C11000D1F6F0002FF07000D5F7F0002FF06001EA007 S31A0010C03307001EA106000E8B590002CB02000E8C0D0002CC03DD S31A0010C048000EAFFE0002FF00000CAF5B000CAF4C000EADBE007B S31A0010C05D0EAE13003ACFA6000E1CFF0036CFDE000EA3FF000E70 S31A0010C072A21C001EAF05000E2F200002DF000033CFA9000EAF6D S31A0010C087FB0002FF00000CAF5B000CAF4C001EAE07001EAD06D1 S31A0010C09C003ACFA6000E1CFF0036CFCF000EA1FF000EA01C0055 S31A0010C0B11EAF05000E2F600002CF000033CFA9001EAB05000E9D S31A0010C0C62BDF000E1BFF0032CFAC000EAFFD0002FF00000CAFFA S31A0010C0DB5B000CAF4C000EADBE000EAE0F003ACFA6000E1CFFBC S31A0010C0F00036CFBC000EA3FF000EA21C001EAF05000E2F600079 S31A0010C10502DF000033CFA9000E15F00032CFB1000E14FF00326B S31A0010C11ACFB1001EAB05000E2BBF000E1BFF0032CFB1003ACCD4 S31A0010C12FC2003A7FFB0033CFA9000CAF5B000CAF4C003AD13F5D S31A0010C144000E1CFF0032CFA9000CAF5B000CAF4C003AD1AC0029 S31A0010C15916AF0800397FAC0023FFFF000CAFE0000CAFD1001E24 S31A0010C16EAE00000EADFF00041DC00036CF9E0001BD6D0033CF8D S31A0010C1838E0004AF6D0032CF9600181B020032CF9600181C0349 S31A0010C1980032CF960001BE6D0033CF8E00041E6D0032CF8E000B S31A0010C1AD181B000032CF8F00181C010032CF8F000EADFE000026 S31A0010C1C2FF6D000CAFDC000EABFF0023FFFF0016AFFF000EFAAA S31A0010C1D7DF000CAFFB0002FB00000E2A20000EFADF0032CF87E4 S31A0010C1EC000EA1BE000EA0320018AE00000EADFF000EA1BE00EE S31A0010C2010EA0310018AC00000EABFF000CCCEE000CDBDD000E1F S31A0010C216A1BD000EA0910018AB19000E2B800018AC1A000C1DC4 S31A0010C22BBF0032CF71000C1ECF0036CF70000EBD7F001EAB0036 S31A0010C240000CBABA000CAFDB000CAFEC0016AF010023FFFF002F S31A0010C255397FA90016AFFD000EAEFF000EADFF000EA0FF000E6B S31A0010C26AA1BF000EFADF000CAFFB0002FB02000E2A20000EFA4D S31A0010C27FDF0032CF61000EA880000EA9FC0010AC01000EABFFF5 S31A0010C294000CCCEE000CDBDD000DBF88000DFF99000EF97F0076 S31A0010C2A936CF5C0002FD000002FE01000EABBD000EAC4C000E7F S31A0010C2BEAEBF000EADFF003ACE69000CAFCE000CAFBD0002FDBD S31A0010C2D3000002FE01000EABBF000EACFF000EAEF1000EADFFA7 S31A0010C2E8003ACE69000CAFCE000CAFBD0002FD000002FE0100B9 S31A0010C2FD0EABBD000EAC90000EAEFD000EADFF003ACE69000C66 S31A0010C312AFCE000CAFBD0002FD000002FE01000EABBD000EACDB S31A0010C3278E000EAEFD000EADFF003ACE69000CAFCE000CAFBD78 S31A0010C33C0002FD000002FE01000EABBD000EAC84000EAEFE0068 S31A0010C3510EADFF003ACE69000CAFCE000CAFBD0002FD00000294 S31A0010C366FE01000EABBD000EAC83000EAEFE000EADFF003ACE7E S31A0010C37B69000CAFCE000CAFBD0002FD000002FE01000EABBDB7 S31A0010C390000EAC7E000EAEFD000EADFF003ACE69000CAFCE00DD S31A0010C3A50CAFBD001EAB02000CBABA000CAFDB000CAFEC001657 S31A0010C3BAAF0300397FA80023FFFF0016AFFF000EA2FF000EA301 S31A0010C3CFFF000EFADF000CAFFB0002FB00000E2A20000EFADF6B S31A0010C3E40032CF08000EA1BF000EA03A000CAF3D000CAF2E00EE S31A0010C3F910AC01000EABFF000CCC22000CDB33000D1FEE000D69 S31A0010C40E5FDD000E1DFF0032CEF8000E1E220034CF01000EA1A4 S31A0010C423BF000EA091000EAEFF000EADFF0010AC01000EABFF06 S31A0010C438000CCC22000CDB33000D1FEE000D5FDD000E1DFF0038 S31A0010C44D32CEEA000E1EFE0034CEF3000EA1BF000EA08F000E02 S31A0010C462AEFF000EADFF0010AC01000EABFF000CCC22000CDBF2 S31A0010C47733000D1FEE000D5FDD000E1DFF0032CEDC000E1EFED4 S31A0010C48C0034CEE5001EAB00000CBABA000CAF3B000CAF2C0078 S31A0010C4A116AF010023FFFF00397FA90016AFFD000EFADF000C73 S31A0010C4B6AFFB0002FB02000E2A20000EFADF0032CED0003ACF9A S31A0010C4CB6A000CAFCE000CAFBD0002FD000002FE01000EABBF63 S31A0010C4E0000EACBD000EAEFD000EADFF003ACE69000CAFCE004D S31A0010C4F50CAFBD0002FD000002FE01000EABBF000EACBB000EA9 S31A0010C50AAEFE000EADFF003ACE69000CAFCE000CAFBD0002FD2F S31A0010C51F000002FE01000EABBF000EACBA000EAEFD000EADFF91 S31A0010C534003ACE69000CAFCE000CAFBD0002FD000002FE01006A S31A0010C5490EABBF000EACB8000EAEFD000EADFF003ACE69000CED S31A0010C55EAFCE000CAFBD0002FD000002FE01000EABBF000EAC8B S31A0010C573B6000EAEFD000EADFF003ACE69000CAFCE000CAFBD02 S31A0010C5880002FD000002FE01000EABBF000EACB4000EAEFD00E9 S31A0010C59D0EADFF003ACE69000CAFCE000CAFBD0002FD00000246 S31A0010C5B2FE01000EABBD000EACFB000EAEF0000EADFF003ACEC6 S31A0010C5C769000CAFCE000CAFBD0002FD000002FE01000EABBC6A S31A0010C5DC000EACFF000EAE7F000EADFF003ACE69000CAFCE008C S31A0010C5F10CAFBD0002FD000002FE01000EABBD000EAC7A000EEF S31A0010C606AEFD000EADFF003ACE69000CAFCE000CAFBD0002FD33 S31A0010C61B000002FE01000EABBD000EAC6E000EAEFD000EADFFE2 S31A0010C630003ACE69000CAFCE000CAFBD001EAB02000CBABA0022 S31A0010C6450CAFDB000CAFEC0016AF0300397FA80023FFFF000C38 S31A0010C65AAFC0000CAFB1001EA201001EA300000CBEDF0036CEAB S31A0010C66F5B000DBFEE000DFFDD0010AC01000EABFF000C4C22B3 S31A0010C684000C5B33000CBEDF0032CE63000CAF3B000CAF2C0008 S31A0010C69923FFFF00397FA90016AFFE0016AF010000FE68003ACB S31A0010C6AED390003A7FF9000EA0EF000EA17F000EAF550002CF9E S31A0010C6C3060004AFFF000EBFFE0001BFFF000EAFD40002FF0078 S31A0010C6D8000EAFF90002FF01000EABD3000EACCF000EADD400DB S31A0010C6ED0EAE89003A7FFA0033CE4B0016AF0200397FA8002394 S31A0010C702FFFF00397FAD0016AFF70002FB06000EAFFE0002FF2E S31A0010C71707000EA1FF000EA01C0018A100000EE1F70002F108DE S31A0010C72C000EF1FE0002FF080004AB69000E1BAB0036CDC1002C S31A0010C7410E0BAB0030CE26000E0BBF0031CDC9000E1BC1003626 S31A0010C756CE20000E1BC00036CE1D0033CD26000E0BA00034CDE0 S31A0010C76B94000E1B9F0036CD8C000E1B9E0032CD26001EAF08F7 S31A0010C7800036CD260033CD72003A7FF4000EA5FE000EA4D8000B S31A0010C7951EAF060002EF01000EABFE000EACD6000EADDF003A99 S31A0010C7AA7FB2001EAF080032CE0F001CAF23000E1FFE0032CD37 S31A0010C7BFF0001CAB01000E0BFE0035CDF6000E0BFC0034CE076A S31A0010C7D4000E1BFB0036CDFD0033CDF6001DBB01000EEBDF006F S31A0010C7E90CAFFC000ECC4C0002FC03000EDBBD0002FB02000E94 S31A0010C7FEAFDF0002FF050033CDD6000EAFBD0002FF02000EAF6C S31A0010C813FB0002FF03000EAFF30002FF050033CDD6000EAFFFB3 S31A0010C8280002FF020002FF03000EAFFF0002FF050033CDD60046 S31A0010C83D1CAF230032CDE8003AD3560002FB020002FC03000296 S31A0010C852FD040002FE050033CDD6001CAF23000E1FFD0032CDC8 S31A0010C867DE000EABFE000EACD6003ACC98000EABF7003ACCEE3F S31A0010C87C0002EC220033CD1D001CAF010002FF02001CAF0000CA S31A0010C89102FF03001CAB23000E2BE0000D1FBF0002FF05001E66 S31A0010C8A6AE03001EAD02001EAF050002FF00000EABFE000EACA5 S31A0010C8BBD6003A7FE0000EABDF003ACCEE000EA1FE000EA0D824 S31A0010C8D00002CC220033CD1D001EAF080036CD26000EA1FE0085 S31A0010C8E50EA0D80018AF01000E1FFB0034CD260033CD72001EFB S31A0010C8FAAF080032CDBA000EA1FE000EA0D80018AF23000E1F59 S31A0010C90FFE0032CD26000EA1FE000EA0D80018AF010032CD26BA S31A0010C924000EABEB003ACCEE001E1C060032CD72000EA5BE002E S31A0010C9390EA40B003A7FF4000EABFE000EACD6000EADEB003A42 S31A0010C94ECCE2000CAF5B000CAF4C000EADEF003ACCA5000E1C74 S31A0010C963FF0036CDA3000EA4FF000EA5FF000CAF5B000CAF4C84 S31A0010C978000EADFE000EAED6003A7FDF000CAF5B000CAF4C0094 S31A0010C98D0EADFE000EAED6003A7FDF000EABFE000EACD6000E47 S31A0010C9A2ADEB003ACCE20033CD1D001EAF080036CD26000EA120 S31A0010C9B7FE000EA0D80019BB01000E1BFC0034CD260033CD723E S31A0010C9CC000EABDF003ACCEE001E1C060032CD72001EAF08002E S31A0010C9E132CD81000EA5FE000EA4D8001CAF23000E1FFE003225 S31A0010C9F6CD48000EA1FE000EA0D80018AB01000E0BFC0030CDF8 S31A0010CA0B77000E0BFD0031CD6F000E1BFE0036CD740033CD72F6 S31A0010CA20000E1BFB0036CD5D0033CD72001EAF080036CD6F00AE S31A0010CA350EAFFF0002FF070033CD1D000EA1FE000EA0D80019A9 S31A0010CA4ABB01000EEBDF000CAFFC000ECC4C0002FC03000EDB66 S31A0010CA5FBD0002FB02000CAF64000EC4FD000D5F75000EAFDF85 S31A0010CA740002EF03003A7FF4001CAC03000EABFF0033CD3E0035 S31A0010CA890EAFBD0002FF02000EAFFB0002FF03000CAF64000E1C S31A0010CA9EC4FD000D5F75000EAFF30002EF03003A7FF4001CACB2 S31A0010CAB303000EABFF001EAF020002FF00001EAF030002FF01FB S31A0010CAC8000EADFE000EAED6003AFDBB003AEF2C0033CD1D0094 S31A0010CADD1CAF230032CD36003AD3560002FB020002FC030002A6 S31A0010CAF2FD040002FE05003A7FF4001EAC05000EABFF001EAF12 S31A0010CB07020002FF00001EAF030002FF01000EADFE000EAED6E3 S31A0010CB1C003AFDBB0033CD1D003A7FF4001CAF010002FF020063 S31A0010CB311CAF000002FF03001CAD23000E2DE0000D1FDD0002F8 S31A0010CB46FD05001EAC03001EAB020002FD00000EADFE000EAEB6 S31A0010CB5BD6003A7FE00033CD1D003A7FF40004AC69000EABFFA5 S31A0010CB70000CAFC0000EC016000CAFB1000ED1FF001EAF06001E S31A0010CB8502CF00001EAC07000EABFF0016AF0900397FAC0023D6 S31A0010CB9AFFFF000CAFC0000CAFB100044D69000E2D01000CAFDA S31A0010CBAFDC000EABFF000CCC00000CDB110018AC010018AB006F S31A0010CBC40023FFFF00397FAD000CAFC4000CAFB50004AB6800BA S31A0010CBD93ACCF8000E1CFF0036CD040004AC6A0033CCFB000CE3 S31A0010CBEEAF5E000EADFF0001BE6A0004AB69000E2BFE000CAF22 S31A0010CC034C000E1BFF0036CCFB000CAFEC000EABFF00397FACD2 S31A0010CC180023FFFF000CAFBD000EACFF0004AB69000E2B01004D S31A0010CC2D0C1BDF0032CCF00004AC69000E2CFE000EABFF0023BC S31A0010CC42FFFF000EACFF000EA1FE000EA0D60033CCE90010CC1B S31A0010CC5701000DBFBB000E1B000032CCEA000D8FCB000CAFBC3B S31A0010CC6C000EABFF0023FFFF000374FF000375FF000379FF005C S31A0010CC810CAFC2000CAFB3000CAFD9000CAF9C000EABFF000CEE S31A0010CC96CC24000CDB35000E19FE0034CCC8000DBF99000E09FE S31A0010CCABFF0034CCC8001AAB00000CAF9E000EADFF000CCE20C5 S31A0010CCC0000CDD310018AF0000035F010002CB00000EC9010060 S31A0010CCD50E09FF0030CCD3000CAF5B000CAF4C0016A90100165C S31A0010CCEAA5010016A4010023FFFF00397FAD000E2A20000EFAD8 S31A0010CCFFDF0032CCC1000E2A5C000EA4FF000EA57F001CAB919D S31A0010CD14000E2BC70002EB91000EAFFE0002EF60003AFE3500FD S31A0010CD290EAFFF0002EF40000EAFFF0002EF30000EAFFF000257 S31A0010CD3EEF90003EBFFF003EBFFF003EBFFF003EBFFF003EBF5E S31A0010CD53FF003EBFFF003EBFFF003EBFFF00397FAC0023FFFF3D S31A0010CD68000CAFC0000CAFB1000EACFE0033CC9D0010AB0100A9 S31A0010CD7D36CC9D000EACFF0033CC9A000DBFDD000E1D00003294 S31A0010CD92CCA1000EABFF0023FFFF00397FAD0016AFFF000CAF4C S31A0010CDA7C4000CAFB5000EA0FF000CAF0B000ECBF30002F000FC S31A0010CDBC003A7FE2000CAFBE000EADFF00036E0100036C01009C S31A0010CDD11EA000000D1F00000E10FC0034CC930016AF010039A1 S31A0010CDE67FAC0023FFFF000CAFD0000CAFC1000E1EFF0036CCA2 S31A0010CDFB7B000E0EFF0034CC77000CAFBF0018BF010002CF01DC S31A0010CE10000D8FBB00182F000002CF000033CC750018BB000041 S31A0010CE2502CB000023FFFF00397FA9000CAFC8000CAFB9000C90 S31A0010CE3AAFE0000CAFD1001EAD02000CB01F0036CC54000EFDA9 S31A0010CE4F7F000CAFFB000E1BFF0036CC62000EABFF001809001E S31A0010CE640032CC64001818010030CC5C0033CC5D000EABFF00A4 S31A0010CE791809000032CC5E001818010035CC5C000EABFE000EBE S31A0010CE8EACFF000C1BCF0036CC57000E2DFE000CAFDC000CAFF4 S31A0010CEA3CB0018AC020033CC52000CAFDB000CAF8C003ACC4F50 S31A0010CEB800397FA80023FFFF000CAFBD000CAFCE0004AC6700B6 S31A0010CECD0EABFF000CAFC0000EC090000CAFB1000ED1FE00045C S31A0010CEE2AF67000E1FF70030CC34000E1DFF0036CC36000E1E2D S31A0010CEF7FF0036CC3600191F000002CF0000181E000031CC3865 S31A0010CF0C000EAFFF0002CF00000EACFE0033CC33000EAC0000C9 S31A0010CF2133CC33000EAFFF0002CF00000EACFF0023FFFF003913 S31A0010CF367FAD0016AFFC000EA1BF000EA0AE0018AC6E0018AB24 S31A0010CF4B6D0018AE6F000EADFF000EAFF10002FF00000EAFEF04 S31A0010CF600002FF01003A7FBE000CAFCE000CAFBD000EA1FE007F S31A0010CF750EA0870018CE010018DD00000EA1BE000EA037001816 S31A0010CF8AAB04000E2BFD000E1BFF0036CC15000EA3BF000EA238 S31A0010CF9FAE001ACE4E001ADD4D000EABFE000EAC51003AC2F889 S31A0010CFB40002FB020002FC03000EA1FF000EA01C0018AE07000D S31A0010CFC918AD06000EAFFF0002FF00003AC49E0004AED1000492 S31A0010CFDEADD2000EAFFC0002FF00000EAF170002FF01003A7F60 S31A0010CFF3BE000CAFC4000CAFB5000EA3BF000EA2AE000CAF31AC S31A0010D008000CAF20001AAC5D0018CC5F001AAB5C0018DB5E004A S31A0010D01D0CCC44000CDB55000EA3FF000EA21C001AAE07001A2B S31A0010D032AD06001EAC03001EAB02003AC4D0000EF57F0032CB3B S31A0010D047DB000CB45F0036CBDB000EA1BF000EA0AE00183C4189 S31A0010D05C00187B400002F5000002F401000EAEFF000EADFB0077 S31A0010D0713A7FBE000CAFCE000CAFBD000EFD7F0036CBD9000EAA S31A0010D086AEFF000EADFF0033CBD1000EAEFF000EADFF000EA125 S31A0010D09BBF000EA0AE00180D6D0032CBD400181E6E0034CBD178 S31A0010D0B00018AE6E0018AD6D000EABFE000EACFE003A7FA60021 S31A0010D0C516AF0400397FAC0023FFFF00397FAD0016AFF50002D1 S31A0010D0DAFB020002FC030002FD040002FE05000EAFFE0002FF69 S31A0010D0EF06003AC2D0000E1CFF0036CB33000EA1FE000EA05438 S31A0010D104000CAF02000CAF13001B1F020002CF02001AAF02009B S31A0010D1190E1FFE0032CBB2000EAFEF0002DF01000EAFD80002EC S31A0010D12EDF000033CBA9000EA1BF000EA0AE000EA3FE000EA227 S31A0010D14354001AAF0200181F130035CBA9000EAFFF0002DF0210 S31A0010D158000EA1FE000EA0540018A8010018A900000EAF1700A7 S31A0010D16D037FFF000EAFFC00037FFF000CAF9D000CAF8E003902 S31A0010D1827FD80016AF020002FD090002FE0A0002FD070002FE4C S31A0010D19708001EA203001EA302001AAE01001AAD00001EAF047E S31A0010D1AC0002FF00001EAF050002FF01000CAF9B000CAF8C00E6 S31A0010D1C13A7FBE000EA1FE000EA0540002CB000002CC01000E73 S31A0010D1D6AF1700037FFF000EAFFC00037FFF000CAFCE000CAF69 S31A0010D1EBBD00397FD80016AF02000CAFDB000CAFEC001EA20305 S31A0010D200001EA302001AAF00000EFF7F0036CB74000CAF1B00A0 S31A0010D2150CAF0C000EADFC003A7FB2000EAFFF0002FF0600330F S31A0010D22ACB33000EA1BF000EA0AE0018A411000EA5FF000C1D69 S31A0010D23F5F0032CB6D000C1E4F0034CB61000EA1BE000EA037D0 S31A0010D2540018AB01000E2BBF000E1BFF0036CB39001EAF0900BB S31A0010D26902FF00001EAF0A0002FF010033CB510018A412000E95 S31A0010D27EA5FF000C1B5F0032CB5C000C1C4F0031CB33000EA1AD S31A0010D293BE000EA0370018AB01000E2BBF000E1BFF0036CB39AF S31A0010D2A8001EAF070002FF00001EAF080002FF01000CAF5B0099 S31A0010D2BD0CAF4C001EAE05001EAD04003A7FBE001EA003001E49 S31A0010D2D2A1020002CB000002CC01000CAF5B000CAF4C000EAE19 S31A0010D2E717000EADFC00397FDD000EA3FE000EA2540002DD0027 S31A0010D2FC0002DE01000EA1FF000EA01C0018AF01000EBFFB001E S31A0010D31102CF010033CB37000EAFFF0002FF06000EABFE000E62 S31A0010D326AC54000EADFC003A7FB2001EAC06000EABFF0016AF6D S31A0010D33B0B00397FAC0023FFFF00397FAD0016AFCE0002FB0C36 S31A0010D3500002FC0D0002FD0E0002FE0F000EAFFF0002FF1000BE S31A0010D3650EAFFE0002FF11000EAFFF0002FF220002FF230002CB S31A0010D37AFF240002FF250002FD260002FE27000EAFFF0002FF36 S31A0010D38F280002FF29000EAFFF0002FF2C0002FF2D000EA1BF9C S31A0010D3A4000EA0AE0018AC44000EABFF000EA1BF000EA0BD0069 S31A0010D3B918AE010018AD00003A7FB60002FB1A0002FC1B00021C S31A0010D3CEFB1C0002FC1D001EA20D001EA30C001AAF000002FF9E S31A0010D3E318001AAF010002FF19000EA1FE000EA087001EAC0F68 S31A0010D3F8001EAB0E00180B1D0032CAFD00181C1E0031CAFA00B3 S31A0010D40D02CB1D0002CC1E001EA00D001EA10C0018AC090018A3 S31A0010D422AB08001EAF0E0002FF00001EAF0F0002FF01000CAFB7 S31A0010D4376F000ECFF70002FF03000D5F7F0002FF02000EAFFFD9 S31A0010D44C0002FF04000EAFFF0002FF05001EAF370002FF0600E3 S31A0010D4611EAF380002FF07001EAE19001EAD18003AC532001E7C S31A0010D476AB36000E2BF7000E1BFF0036CADB000EAFFF0002FFBA S31A0010D48B0A0002FF0B000CAF64000EC4F7000D5F75000EA3BF27 S31A0010D4A0000EA2AE000CAF31000CAF20001AAC5D0018CC5F00D6 S31A0010D4B51AAB5C0018DB5E001CCC03001CDB020002EB02000205 S31A0010D4CAEC030002FB200002FC21000CAF5B000CAF4C001EAE23 S31A0010D4DF0D001EAD0C003AC7F70002FB120002FC13000E1B7F7E S31A0010D4F40032CABF000E1CFE0036C8C1001EA20D001EA30C00D1 S31A0010D5091AAC01001AAB00001A0B020032CAB8001A1C03003126 S31A0010D51EC8C1000CAF5B000CAF4C001EAE13001EAD12003AC581 S31A0010D533460002FB160002FC17001EA00D001EA10C00180B06A0 S31A0010D5480032CAAB00181C070034C8C1000CAF6F000ECFF7001B S31A0010D55D02FF2F000D5F7F0002FF2E001F1F100002FF10001EDC S31A0010D572AF19001ECF1B0002FF1F001EAF18001EDF1A0002FFA1 S31A0010D5871E001EAC1F001EAB1E001EA20D001EA30C001A0B02CA S31A0010D59C0032CA96001A1C030034CA91001AAF020002FF1E0020 S31A0010D5B11AAF030002FF1F001EAF1F001E3F190002FF1B001EC7 S31A0010D5C6AF1E001E7F180002FF1A001EAC1B001EAB1A001EAE09 S31A0010D5DB13001EAD12003AC0830002FB2A0002FC2B000EA1FFBA S31A0010D5F0000EA0470018AF150036CA780018AF150036CA680083 S31A0010D6050EA1BE000EA0370018AB03000E2BBF000E1BFF00368C S31A0010D61ACA68001EAC21001EAB20001EAE13001EAD12003AFEEB S31A0010D62F2C000CAFCE000CAFBD001EAF2A0002FF00001EAF2BB3 S31A0010D6440002FF01001EAC27001EAB26003AFE100002FB0E0086 S31A0010D65902FC0F001EA00D001EA10C0018AC090018AB08001E4D S31A0010D66EAF0E0002FF00001EAF0F0002FF01000CAF6F000ECFEE S31A0010D683F70002FF03000D5F7F0002FF02000EAFFF0002FF04D2 S31A0010D698000EAFFF0002FF05001EAF370002FF06001EAF380095 S31A0010D6AD02FF07001EAE1F001EAD1E003AC532001EAB36000E38 S31A0010D6C22BF7000E1BFF0036CA06000EA3BF000EA2AE001AAC59 S31A0010D6D746001AAB45000CCCCC000CDBBB001EAE29001EAD28AA S31A0010D6EC000C1DBF0032CA41000C1ECF0031CA06000CAFEC004D S31A0010D7011ECC2B000CAFDB001EDB2A000CAFCD000CAFBC000E22 S31A0010D716AFFF00397FD2000CAFE0000CAFD1000CAFC8000CAF4B S31A0010D72BB9000E887F001AAD46001AAC45000EAFFF00397FD2A7 S31A0010D74000037EFF00037DFF00037CFF00037BFF000CAF9B006E S31A0010D7550CAF8C000CAF1D000CAF0E00397FD50016AF04003A31 S31A0010D76A7FC5000EAFFF00037FFF000EAFFF00037FFF000EAF19 S31A0010D77FFF00037FFF000EAF7E00037FFF000E8C7F00397FD49E S31A0010D7940016AF04000CAFE0000CAFD1000CAFC8000CAFB90083 S31A0010D7A91EA22F001EA32E001AAD03001AAC02000EAFFE0039F1 S31A0010D7BE7FD2000370FF000371FF000378FF000379FF00397F5D S31A0010D7D3D90016AF0400397FD10002DD020002DE03000EA1BFCE S31A0010D7E8000EA0AE000CAF02000CAF130018AC5D001ACC5F00C9 S31A0010D7FD18AB5C001ADB5E001EA02F001EA12E0018CC030002CC S31A0010D812CC030018DB020002CB02000CAF1B000CAF0C001EAEEF S31A0010D8270D001EAD0C003AC7F70002FB140002FC15001EAC2FDD S31A0010D83C001EAB2E001EAE15001EAD14003AC546000CAFC40046 S31A0010D8510CAFB5000EA3BF000EA2AE000CAF31000CAF20001A8D S31A0010D866AC410018CC43001AAB400018DB42000C05BF0032C97E S31A0010D87BDF000C14CF0031C9B6000EA1BE000EA0370018AB02ED S31A0010D890000E2BDF000E1BFF0036C9B6000CAF4F001E3F1700FA S31A0010D8A502FF31000CAF5F001E7F160002FF30001EAF1C00023D S31A0010D8BAFF00001EAF1D0002FF01001EAC2D001EAB2C001EAEA0 S31A0010D8CF1B001EAD1A003A7FBE001EA231001EA330000C03BF07 S31A0010D8E40032C9C4000C12CF0034C9B6001EAF1C0002FF0000D0 S31A0010D8F91EAF1D0002FF01001EAC2D001EAB2C001EAE1B001E27 S31A0010D90EAD1A003A7FBE000CAFC4001EC417000CAFB5001ED5D5 S31A0010D92316000CAF4F001E3F170002FF2D000CAF5F001E7F164A S31A0010D9380002FF2C001EAF1A0002FF1C001EAF1B0002FF1D008D S31A0010D94D1EAC15001EAB14000E1B7F0032C9A6000E1CFE00364C S31A0010D962C98A001E1417000CAFFC001EAB16000C7B5B000EFB7D S31A0010D9777F0036C99E000D9FCC000DCFBB000E0BF80032C99BB3 S31A0010D98C000E1C000030C991000EECEF00037FFF000EEBEF006A S31A0010D9A10CBFCB0016AC01001E0B160032C992001E1C170034B1 S31A0010D9B6C98E000EACFE000EABFF0033C98C000EACFF000EAB85 S31A0010D9CBFF000E1CFF0036C950001EAF110036C950001EAE1BA6 S31A0010D9E0001EAD1A000E0DFF0032C983000E1EFE0034C9500028 S31A0010D9F50D0FD1000D4FE00002F11A0002F01B001EA20D001ED9 S31A0010DA0AA30C001AA803001E3819001AA902001E791800037027 S31A0010DA1FFF000371FF000CAF9D000CAF8E00397FD80016AF0272 S31A0010DA34001EAC10000CAFCB000E6BFE000CCECC000CDDBB00A6 S31A0010DA490E0BFF0032C96A000E1CD80034CAA5000EABFE001EBB S31A0010DA5EAF10000E0FD80030C963001EAB10000E4BD7000CAFC9 S31A0010DA73BC000E6BFE00037CFF00037BFF000CAF9D000CAF8EB9 S31A0010DA8800397FD80016AF02001E1D1A0032C955001E1E1B0020 S31A0010DA9D32C955001F1E1B001F5D1A0002FD1A0002FE1B000EDE S31A0010DAB2AFFF0002FF110033CAA5001EAF29001ECF2B0002FFD8 S31A0010DAC729001EAF28001EDF2A0002FF28001EAC15001EAB140A S31A0010DADC000E1B7F0032C944000E1CFE0036C8CA001EA00D007D S31A0010DAF11EA10C001805060032C93F001814070034C8F3001FA1 S31A0010DB060B16001F4C17000D0F5D000D4F4E000CCECC000CDD9F S31A0010DB1BBB001EAE1B001EAD1A00397FDC001ECE250002FE258E S31A0010DB30001EDD240002FD24001EDC230002FC23001EDB22002F S31A0010DB4502FB22001EA21F001EA31E001803020032C928001880 S31A0010DB5A12030031C914001EAF0E0002FF26001EAF0F0002FF9E S31A0010DB6F270002F3180002F219001EAF140002FF12001EAF1574 S31A0010DB840002FF130002F5160002F417001EA02F001EA12E006E S31A0010DB9918AF020002FF200018AF030002FF210033CAA5001ECB S31A0010DBAEA20D001EA30C001AAF03001A3F010002DF03001AAFFD S31A0010DBC302001A7F000002DF02000EA1BD000EA0760018AE174C S31A0010DBD8000EADFF000EAC17000EABFC00397FDD000CAFDC00B6 S31A0010DBED0E6CFE000CAFCB00037EFF00037DFF00037CFF00038F S31A0010DC027BFF001EAE29001EAD28001EAC27001EAB2600397FFD S31A0010DC17D60016AF04001EA00D001EA10C0002CD040002CE0505 S31A0010DC2C0033C8B9001EA20D001EA30C001AAC07001E3C170041 S31A0010DC411AAB06001E7B16001E34170002F401001E7516000233 S31A0010DC56F500001EAE1B001EAD1A003A7FBE0002FB1A0002FC56 S31A0010DC6B1B001ECC19001EDB18001EA00D001EA10C00183C0174 S31A0010DC800002CC0300187B000002CB02001EAC170018CC07007A S31A0010DC951EAB160018DB06000D0FBB000D4FCC001EAE1B001E88 S31A0010DCAAAD1A00397FDC001ECE250002FE25001EDD240002FDA0 S31A0010DCBF24001EDC230002FC23001EDB220002FB220033C90C96 S31A0010DCD4001EA20D001EA30C001EAF19001A3F010002DF030067 S31A0010DCE91EAF18001A7F000002DF020033C90C001EA00D001EBE S31A0010DCFEA10C000EAFFF0002CF040002CF05000EAFFF0002CF5A S31A0010DD13020002CF030016AF3200397FAC0023FFFF00397FAD2E S31A0010DD280016AFE8000CAFB9000CAFCB000CAFDC0002FE0D0085 S31A0010DD3D0EA5BF000EA4BD001CAF000002FF12001CAF0100022E S31A0010DD52FF130000FE62000EA1BF000EA0AE0018CC410002FC47 S31A0010DD670A0018DB400002FB09000EA1FF000EA01C0018AB0112 S31A0010DD7C000EEBDF000E2BFE000CAFBC000CAF9B003AE9190064 S31A0010DD9102FB070002FC08000EAFFE0002FF0B000EAF51000286 S31A0010DDA6FF0C000CAF5B000CAF4C003AC0D70002FB050002FC59 S31A0010DDBB06000EA5FE000EA487001CAF000002FF03001CAF01B2 S31A0010DDD00002FF04000EA1FF000EA01C0018AE070018AD060013 S31A0010DDE51EAF0D0002FF00001EAF1C0002FF01001EAF1D000261 S31A0010DDFAFF02000CAF6C000ECCFC000D5F7B003ACB2E003AC1EB S31A0010DE0F61000CAFCE000CAFBD001EAB0D000E2BF7000E1BFF58 S31A0010DE240032C86C001EAF05001EBF060032C86C001CAF170070 S31A0010DE390EFF7F0032C7FA001CAF17001CBF180036C7FA000073 S31A0010DE4EFF59001EAB0D000E2BF7000E1BFF0036C86200040DB2 S31A0010DE635D0032C86400041E5C0034C8620000FE590004AF599A S31A0010DE780036C83500041E5C000CAFFC0004AB5D000C7BDB00A9 S31A0010DE8D1EAE13001EAD1200397FDC000EEDFB000EECFB000C23 S31A0010DEA2BFDE000E6BFB000CBFCD000CAFBC000E6BFD0002FBC2 S31A0010DEB7140002FC150002FD160002FE17001EAF160002FF0EFB S31A0010DECC001EAF170002FF0F000EA1BF000EA0AE0018A841006C S31A0010DEE118A940000EA1BD000EA0760018AE17000EADFF000EE0 S31A0010DEF6AC17000EABFC00397FDD0002FD000002FE01001EAC2A S31A0010DF0B17001EAB16000CAF9D000CAF8E003A7FBE0002FB10D0 S31A0010DF200002FC110033C82D001EAF050002FF0E001EAF0600EB S31A0010DF3502FF0F001EAF070002FF10001EAF080002FF11000ED7 S31A0010DF4AABBF000EACBD003AC0D70002FB050002FC06000EA541 S31A0010DF5FFE000EA487001CAF000002FF03001CAF010002FF04C0 S31A0010DF74000EAFFF0002FF070002FF08000EA1FF000EA01C003D S31A0010DF8918AE070018AD06001EAF0D0002FF00000EAFFC00023F S31A0010DF9EFF01000EAF170002FF02000CAF6C000ECCFC000D5F18 S31A0010DFB37B003ACB2E001EAC06001CCC14001EAB05001CDB13F1 S31A0010DFC8000CAFCE001CCE01000CAFBD001CDD00000EFD7F00BF S31A0010DFDD36C802000EABFF000EAC0E000EAEFF000EADFF0033F1 S31A0010DFF2C800000EABFF000EAC0E003AFB06001EAE11001EADD9 S31A0010E00710001EAC0F001EAB0E003AC1570016AF1800397FAC9B S31A0010E01C0023FFFF00397FAD0016AFF4000CAFC2000CAFB300AF S31A0010E0310CAFE4000CAFD5000EAFFE0002FF03000EAF7F000298 S31A0010E046FF02001CAF04000EFF7F0036C700000EA1FF000EA0FA S31A0010E05B1C0018AB01000E2BF7000E1BFF0036C7050018AB3469 S31A0010E070000E2B7F000E1BFF0032C705001AAF02000EFF7F0050 S31A0010E08532C718001AAF02001ABF030036C718001AAE01001AC0 S31A0010E09AAD00000CAFDC000E6CFE000CAFCB000EECFD000CAF67 S31A0010E0AFFB000EEDFD000CAFFC000CBBDB000EEEFD000CAFFD49 S31A0010E0C4000CBCEC000EAEFF000EAFFE00397FCD000CAFE000E7 S31A0010E0D90CAFD1000CAFC8000CAFB9001AAD03001AAC02000EF9 S31A0010E0EEAFFE00397FD200037EFF00037DFF00037CFF00037BD5 S31A0010E103FF000CAF9B000CAF8C000CAF1D000CAF0E00397FD527 S31A0010E1180016AF040002FB040002FC050002FD060002FE070003 S31A0010E12D1CAC05001CAB04001AAE03001AAD0200397FDC000EF9 S31A0010E142AFFE00397FCD000CAFE0000CAFD1000CAFC8000CAF1B S31A0010E157B9001AAC01001AAB00001AAE01001AAD0000397FDC34 S31A0010E16C000EAFFE00397FCD00037EFF00037DFF00037CFF00CB S31A0010E181037BFF000CAF9B000CAF8C000CAF1D000CAF0E00397F S31A0010E1967FD50016AF040002FB080002FC090002FD0A0002FE2C S31A0010E1AB0B000EA1BD000EA0760018AE17000EADFF000EAC1746 S31A0010E1C0000EABFC00397FDD000CAFDC000CAFED000EAFFE00F0 S31A0010E1D5397FD2000EAFFF00037FFF000EAFFF00037FFF000E0D S31A0010E1EAAFFF00037FFF000EAF7C00037FFF00397FD90016AFCB S31A0010E1FF04000EAFFF00037FFF000EAFFF00037FFF000EAFFFBB S31A0010E21400037FFF000EAF8800037FFF00397FD90016AF04003E S31A0010E2291EAF0B00037FFF001EAF0B00037FFF001EAF0B00033D S31A0010E23E7FFF001EAF0B00037FFF00397FD90016AF040002FB87 S31A0010E253080002FC090002FD0A0002FE0B000CAFBF0036C75AAC S31A0010E268000EFC7F0036C75A000E1B7E0032C75B000E1C7F0007 S31A0010E27D32C75B000E1DFF0032C75B000E1EFF0036C6FD003050 S31A0010E292C6FD000EAFFF00037FFF000EAFFF00037FFF000EAF67 S31A0010E2A7FF00037FFF000EAF7E00037FFF001EAE0F001EAD0E5C S31A0010E2BC001EAC0D001EAB0C00397FD40016AF04003A7FC300BA S31A0010E2D10EAFFF00037FFF000EAFFF00037FFF000EAFFF0003E9 S31A0010E2E67FFF000EAF7E00037FFF000E8C7F00397FD40016AF69 S31A0010E2FB04001EAF0700037FFF001EAF0700037FFF001EAF0776 S31A0010E31000037FFF001EAF0700037FFF00397FD90016AF0400B2 S31A0010E32502FB040002FC050002FD060002FE07000CAFBF00360D S31A0010E33AC725000EFC7F0032C725000E1B700032C726000E1C43 S31A0010E34F800032C726000E1D010032C726000E1EFF0036C6FD95 S31A0010E3640030C6FD001EAE05000E8E7F001EAD04001EA9060013 S31A0010E3791EA807000CAFDB000CAFEC000CAF9D000CAF8E003995 S31A0010E38E7FD10002FD020002FE030033C6FD000EA1BD000EA000 S31A0010E3A3760018AE17000EADFF000EAC17000EABFC00397FDD27 S31A0010E3B8000CAFDB000CAFEC001CAE05001CAD04001AAF000098 S31A0010E3CD02FF00001AAF010002FF01003A7FBE0002FB020002E0 S31A0010E3E2FC030033C6FD001CAF040002FF02001CAF050002FF78 S31A0010E3F7030033C6FD000EAFFF0002FF020002FF03001EAC0372 S31A0010E40C001EAB020016AF0C00397FAC0023FFFF00397FAD005F S31A0010E42116AFEC000EA1BE000EA05C000EA3BF000EA2BD001AB1 S31A0010E436AF030002FF12001AAF040002FF130018AF060001BF88 S31A0010E44B5F0018AF070001BF5E000EACFF000EABFF000EAE59D5 S31A0010E460000EADF4003AC077000CAFC4000CAFB5000EACFF00C9 S31A0010E4750EABBF000EAE59000EADF4003AC0770002FB000002D0 S31A0010E48AFC010002F5020002F403001EAC13001EAB12000EAE04 S31A0010E49F59000EADF4003AC03D0002FB0E0002FC0F000CAF6FD1 S31A0010E4B4000ECFF10002FF0D000D5F7F0002FF0C000EAFFF00AD S31A0010E4C902FF040002FF05000EA1BF000EA0BD0018AE01001865 S31A0010E4DEAD00000D9FCC000E5BBF00397FDC000ECDDF000D5F0C S31A0010E4F3CC000D5FBB000EEDFB000EECFB000CBFDE000E6BFB03 S31A0010E508000CBFCD000CAFBC000E6BFD0002FD060002FE070057 S31A0010E51D0EA3BD000EA276001AAF100002FF08001AAF11000281 S31A0010E532FF09001AAC11001AAB10000EAFEF0002FF01000EAF9F S31A0010E547D80002FF00000EAEEF000EADF1003A7FBE0002FB08FD S31A0010E55C0002FC09000EA1BF000EA0AE0018AF410018CF57007D S31A0010E57102FF0B0018AF400018DF560002FF0A000EA5FF000E54 S31A0010E586A41C001CAF34000EBF7F0002EF34000EAFF70002FF85 S31A0010E59B00000EAFFC0002FF01000EAF170002FF02000CAF6C9C S31A0010E5B0000ECCFB000D5F7B000EAE59000EADF4003ACB2E008D S31A0010E5C51CAF34000E2F800002EF34001EAC07001EAB06000E9C S31A0010E5DAA1BD000EA0760018AE0D0018AD0C003A7FBA0002FB80 S31A0010E5EF100002FC11001CAC2D001CAB2C000EA3BD000EA27666 S31A0010E604001AAE12000EADFF000EAFFF0002FF00000EAF9B0042 S31A0010E61902FF01003A7FBE001EAE11001EAD10000C0DBF00329B S31A0010E62EC672000C1ECF0031C667000EA1BE000EA0370018AB1D S31A0010E64302000E2BBF000E1BFF0036C667000EABFF000EAC01B4 S31A0010E658000EADEF003A7FA4000EABFE000EACF0001EAE110052 S31A0010E66D1EAD10003AFB060000FF610016AF1400397FAC0023AC S31A0010E682FFFF00397FAB000EA1BF000EA0BD0018AC02000E2C33 S31A0010E697FC000E8CFD000D9FFB000CBBCB000CAFB5000EE5FD2C S31A0010E6AC003AC0FA000E1CFF0036C650000EA5FF000CAF5C0011 S31A0010E6C10EABFF00397FAA0023FFFF00397FAD0016AFF90002CE S31A0010E6D6FB020002FC030002FD040002FE05001EA20D001EAC7C S31A0010E6EB0C001EAB0B000CBCBF0032C63F000EACFE000EABFFF6 S31A0010E7000002FB0B0002FC0C000EA1BF000EA0AE001812530095 S31A0010E71530C6200033C623000CAF2C000EABFF000CCCCC000C58 S31A0010E72ADBBB000CAFC4001EC403000CAFB5001ED502001CAC9D S31A0010E73F01001CAB00001EAF0B0002FF00001EAF0C0002FF0133 S31A0010E754001EAE05001EAD040002F206003A7FBE0002EB00009C S31A0010E76902EC01001EA206000DBF22000E12000032C638001F73 S31A0010E77E8C05001F8B04000CAFBC000EECFD000EABFF0016AF46 S31A0010E7930700397FAC0023FFFF00397FAD0016AFF80002FB02AE S31A0010E7A80002FC030002FD040002FE05001EAE0D001EAD0C008D S31A0010E7BD0CBEDF0032C60C000EAEFE000EADFF0002FD0C000203 S31A0010E7D2FE0D001EAC05001EAB04003ACBCB0002FC06001EACD7 S31A0010E7E70E000EABFF000CCCCC000CDBBB000CAFC0001EC0039F S31A0010E7FC000CAFB1001ED102001EA205001EA304001AAF000042 S31A0010E81102CF00001AAF010002CF010033C5E2001EAC0E000EAF S31A0010E826ABFF000CCCCC000CDBBB000CAFC4001EC403000CAFB8 S31A0010E83BB5001ED502001CAC01001CAB00001EA005001EA104F2 S31A0010E8500018AE010018AD00001EAF0C0002FF00001EAF0D005D S31A0010E86502FF01003A7FBE0002EB000002EC01001F1F0E0002E5 S31A0010E87AFF0E000E1FF10034C5F7001EAC06000EABFF0016AF0B S31A0010E88F0800397FAC0023FFFF00397FA90016AFFE0002FB01AF S31A0010E8A4003AC2B4000CAFC0000CAFB10018AF00001E1F0100AD S31A0010E8B936C5BE0018AF01000E1FAA0032C5BE0018AF00000E52 S31A0010E8CE1FAA0036C5C70018AF00000E1FFA0032C5BE000D1FC5 S31A0010E8E36E000D5F7D000EAFFF0002FF00000EABFE000CAFDCA8 S31A0010E8F8000CAFED000EAEE7003AFD1F0016AF0200397FA8002D S31A0010E90D23FFFF00397FAD0016AFFC000CAFC4000CAFB5003A6F S31A0010E922C2D0000E1CFF0032C5A7000EAFAA0002EF00000EAF5C S31A0010E937AA0002EF01003AC2B40002FB000002FC01000EACDFD4 S31A0010E94C000EABFF000CAF5D000CAF4E003AFDBB0033C5760067 S31A0010E9610EAFE70002FF03000EAFE70002FF02003AC2B4000C80 S31A0010E976AFC0000CAFB10018AF01000E1FAA0032C59A000EAFAE S31A0010E98BE50002FF020033C598000EAFE50002FF03003AFBB25C S31A0010E9A0001EAB02003AFD04000CAF4E000ECEFD000D5F5D009B S31A0010E9B50EAFFD0002FF00000EABE1000CAFDC000CAFED001E85 S31A0010E9CAAE02003AFD1F000EAFFF0002EF00000EAFAA0002EF17 S31A0010E9DF01000EAFFF0002FF00000EABFD000CAF5C000CAF4D7A S31A0010E9F4001EAE02003AFD1F000EAFFF0002EF01000EAFFF006A S31A0010EA0902FF00000EABFD000CAF5C000CAF4D001EAE03003A03 S31A0010EA1EFD1F003AFBAB0016AF0400397FAC0023FFFF00397FCB S31A0010EA33AD000CAFC4000CAFB5000EA1BF000EA0BD0018AE0677 S31A0010EA480018AD05000EABFF000EAC66003AC546000CAF5D00A4 S31A0010EA5D0CAF4E00397FDC00397FAC0023FFFF00397FA90016F5 S31A0010EA72AFF8000EA1FE000EA0870018AE010018AD00000EA1B5 S31A0010EA87FF000EA01C0018AF060002FF000018AF070002FF01FD S31A0010EA9C000EAFFF0002FF02000EAF660002FF03000EAFFE00AE S31A0010EAB102FF04000EAFFE0002FF050004AFD20002FF060004E4 S31A0010EAC6AFD10002FF07000EABFE000EAC51003AC5320016AFE5 S31A0010EADB0800397FA80023FFFF00397FAD0016AFFE000CAFC4E0 S31A0010EAF0000CAFB5001CAC03001CAB02000EAFFF0002FF010039 S31A0010EB050EAFFB0002FF00003A7FBE001CCC01001CDB00000EC7 S31A0010EB1AFB7F0036C535000EACFF000EABFF0016AF0200397F36 S31A0010EB2FAC0023FFFF000374FF00397FA90016AFFC001EA40B89 S31A0010EB44003AC2F80002FB020002FC03001EAE08001EAD07000C S31A0010EB593AC4D0001EA00A001EA1090002CB000002CC01000E89 S31A0010EB6EAFFF0002FF00001EAC03001EAB02001EAE08001EAD96 S31A0010EB8307003AC49E001EA20A001EA3090002DB020002DC0370 S31A0010EB98000EAFFC0002FF00000EAF170002FF01001EAE0E00E8 S31A0010EBAD1EAD0D003A7FBE001EA00A001EA1090002CB0200028D S31A0010EBC2CC03000E14FF0036C502000EA1BF000EA0AE001EA2B1 S31A0010EBD70A001EA309001AAF030018CF5F0002DF03001AAF027E S31A0010EBEC0018DF5E0002DF02001EAF0C0036C4F6000EA1BF008F S31A0010EC010EA0AE001EA20A001EA309001AAF030018CF5D0002E6 S31A0010EC16DF03001AAF020018DF5C0002DF020016AF0400397F6F S31A0010EC2BA80016A4010023FFFF00397FAD0016AFF80002FB0417 S31A0010EC400002FC05000CAFE4000CAFD5001EAF0C0001BF5F007F S31A0010EC551EAF0D0001BF5E000EACFF000EABFF003AC0770002B8 S31A0010EC6AFB060002FC07000EACFF000EABBF000CAF5D000CAF75 S31A0010EC7F4E003AC0770002FB000002FC01001EAF060002FF02D9 S31A0010EC94001EAF070002FF03001EAC05001EAB04000CAF5D00C9 S31A0010ECA90CAF4E003AC03D0016AF0800397FAC0023FFFF003975 S31A0010ECBE7FAD0016AFFA0002FB000002FC010002FD020002FE43 S31A0010ECD303000CAF7B000CAF6C003AC0B5000EABFF000CCCC4B3 S31A0010ECE8000CDBB5000CAF4C000ECC38000CAF5B000EDBBF008E S31A0010ECFD1EAE01001EAD00003AC0CB0002FB040002FC05000C7F S31A0010ED12AF4C000ECCE8000CAF5B000EDBBE001EAE01001EADC4 S31A0010ED2700003AC0CB001EAE03000ECEAB001EAD02000EDD0AE4 S31A0010ED3C00397FDC000ECDBF000D5FCC000D5FBB000EEDFD0027 S31A0010ED510EECFD000CBFDE000E6BFD000CBFCD000CAFBC000E64 S31A0010ED666BFD000CAFEC001ECC05000CAFDB001EDB040016AF2C S31A0010ED7B0600397FAC0023FFFF00397FAB0016AFF80002FB00C5 S31A0010ED900002FC010002FD020002FE03001EAB0B000EAFFF00C5 S31A0010EDA502FF060002FF07000E1BFF0036C48C000EA1BF000E0A S31A0010EDBAA0AE0018AF5D0002FF070018AF5C0002FF06000CAFCF S31A0010EDCF7B000CAF6C003AC22F000CAFC50032C47D0004AF6046 S31A0010EDE40036C47D003AC2C1000CAFC0000CAFB10018AF04001E S31A0010EDF902FF040018AF050002FF050033C46F003AC2C1000CE9 S31A0010EE0EAF5E000EADFF000CCEEE000CDDDD000ECEFD000D5F3F S31A0010EE23DD000CCECC000CDDBB001EAE01001EAD00003AC245C4 S31A0010EE380002FB040002FC05001EAC03001EAB02003AC2B10066 S31A0010EE4D0CAF5E000EADFF000CCEEE000CDDDD000CCECC000C87 S31A0010EE62DDBB001EAE01001EAD00003AC245000CAFCE000CAFD0 S31A0010EE77BD001EAC03001EAB02003AC431000CAFE0000CAFD1C5 S31A0010EE8C000CAFC8000CAFB9001EAD05001EAC04000EAFFE000B S31A0010EEA1397FD2000370FF000371FF000378FF000379FF0039A9 S31A0010EEB67FD90016AF0400397FCF001EA007001EA106000CAF44 S31A0010EECB18000E68FE000CAF89000CC0E0000CD1D1000CD8C846 S31A0010EEE0000CD9B9000E09FF0032C43F000E18FF0032C43F00C4 S31A0010EEF50E11800032C43F000E10000034C43B000EAC00000E05 S31A0010EF0AAB800033C434000EF97F0032C436000CAF1B000CAF43 S31A0010EF1F0C0033C434000EACFF000EABFF0016AF0800397FAAF0 S31A0010EF340023FFFF00397FA9000ECCA5000EDB0B00397FDC0029 S31A0010EF490EAFFE00397FCD000EAFFF00037FFF000EAFFF000361 S31A0010EF5E7FFF000EAFFF00037FFF000EAF8E00037FFF00397F49 S31A0010EF73D90016AF04003A7FC500397FA80023FFFF00397FA971 S31A0010EF880016AFFE0002FD000002FE01000EAEFF000EADFB002A S31A0010EF9D3A7FBE0016AF0200397FA80023FFFF00397FAD00160F S31A0010EFB2AFF1000CAFC4000CAFB5003AC2A7000EABBF000EACD0 S31A0010EFC7BD000EADFE000EAE4D003AC0E90002FB0D0002FC0EA7 S31A0010EFDC000EAFFE0002FF0B000EAF4D0002FF0C000EAFFF0070 S31A0010EFF102FF030002FF04000EA1BF000EA0BD0018AF0000024A S31A0010F006FF050018AF010002FF06000EA1BF000EA0AE0018C466 S31A0010F01B410002F40A0018D5400002F509003AE7E0000CAFCBD5 S31A0010F030000EA5FF000EA41C001CAC01000EECDF000E2CFE005B S31A0010F0453AE9190002FB070002FC08001CAE07001CAD06000EAC S31A0010F05AAFF70002FF000004AFD20002FF010004AFD10002FFD8 S31A0010F06F02000CAF6C000ECCFC000D5F7B003ACB2E001EAF058B S31A0010F0840001BF5B001EAF060001BF5A001EA20C001EA30B00C1 S31A0010F09904AE5A0004AD5B000CAFDC000E6CFE000CAFCB000E91 S31A0010F0AEECBF000CAFFB000EEDBF000CAFFC000CBBDB000EEEC7 S31A0010F0C3BF000CAFFD000CBCEC000EAEFF000EA5BF000EA4BD5B S31A0010F0D8001CA001001CA100000CAF18000E68FE000CAF890008 S31A0010F0ED0370FF000371FF000378FF000379FF00397FD600167A S31A0010F102AF04001ACE010001BE5C001ADD000001BD5D000EA16A S31A0010F117BD000EA0760018A8010018A9000018AE17000EADFFD3 S31A0010F12C000EAC17000EABFC00397FDD0002FD000002FE01009D S31A0010F1411EAC0E001EAB0D000CAF9D000CAF8E003A7FBE000ECF S31A0010F156A1FE000EA0870002CB150002CC16001EAF0D0002CF49 S31A0010F16B13001EAF0E0002CF140016AF0F00397FAC0023FFFF4D S31A0010F18000397FAD000EA5FF000EA41C000EA3BF000EA2AE00B1 S31A0010F1951CA009001CA108001A01400032C395001A1041003045 S31A0010F1AAC37D000EA1FF000EA047000EAFFE0002CF14001CA0FB S31A0010F1BF09001CA108001A01400032C38B001A10410030C37DA1 S31A0010F1D4000EA1FE000EA0870018AF17000EFF7F0032C37D0052 S31A0010F1E918AF170018BF180036C37D000EACFF000EABFF000C3B S31A0010F1FEAFCE000CAFBD003AC15700397FAC0023FFFF00397F62 S31A0010F213A9000E1BF80030C35E000CAFBE000EADFF000CAFFCCB S31A0010F228000CAFFB000EECBF000CAFFB000EEDBF000CAFFC0025 S31A0010F23D0CBBDB000EEEBF000CAFFD000CBCEC000EAEFF000E14 S31A0010F252AFF600037FFF000EAFFF00037FFF000EAFFF00037FF0 S31A0010F267FF000EAFFF00037FFF00397FD60016AF04000CAFDB53 S31A0010F27C000CAFEC0033C33A000CAFBC000EABFF000ECC060081 S31A0010F2910DFFBB000CAFCE000CAFBD000CAFDC000E6CFE000C6F S31A0010F2A6AFCB000EECBF000CAFFB000EEDBF000CAFFC000CBB1C S31A0010F2BBDB000EEEBF000CAFFD000CBCEC000EAEFF000CCEEEA3 S31A0010F2D0000CDDDD000CDCCC000CDBBB000EAFC000037FFF00F9 S31A0010F2E50EAFFF00037FFF000EAFFF00037FFF000EAFFF0003C5 S31A0010F2FA7FFF00397FD60016AF04000CAFDB000CAFEC000ECCFD S31A0010F30F38000EDBCE00397FA80023FFFF00397FA9000CBCBF7B S31A0010F3240032C333000EA9FF0033C2FC000E0BC00032C33000F1 S31A0010F3390E1C000034C32D000EA9F10033C2FC000E0BCE0032A9 S31A0010F34EC32A000E1C390030C324000EAEF6000EADFF00397F09 S31A0010F363DC000EA9FF0033C304000ECCC6000EDB31000EAEC0BD S31A0010F378000EADFF00397FDC000CAFE0000CAFD1000CAFC80072 S31A0010F38D0CAFB9000D0F9B000D4F8C000D4F1D000D4F0E000E51 S31A0010F3A26BFB000CAFBE000E6BFD000CAFBC000CAFBD000EEB03 S31A0010F3B7FD000CAFBE000EADFF000EACFF000EABFF000CCE00B0 S31A0010F3CC000CDD11000CDC88000CDB99000D0F9B000D4F8C008D S31A0010F3E10D4F1D000D4F0E000EA9F8000EEDFB000EECFB000C78 S31A0010F3F6BFDE000E6BFB000CBFCD000CAFBC000E6BFD000CC981 S31A0010F40BE9000CAF9C000EABFF00397FA80023FFFF00397FA9FC S31A0010F420000CAFC2000CAFB3000EA1BF000EA0BD000CAFDC0066 S31A0010F4350E6CFE000CAFCB000EECBF000CAFFB000EEDBF000C79 S31A0010F44AAFFC000CBBDB000EEEBF000CAFFD000CBCEC000EAE67 S31A0010F45FFF0018AF0000037FFF0018A0010016A101000CAF18F7 S31A0010F474000E68FE000CAF89000370FF000371FF000378FF0056 S31A0010F4890379FF00397FD60016AF04000CAFEC001ACC01000CEC S31A0010F49EAFDB001ADB00000EFB7F0036C2D2000EACFF000EAB00 S31A0010F4B3FF00397FA80023FFFF00397FA9003AC2B4000CAFC022 S31A0010F4C8000CAFB1000EACFF000EABFF0018AF01000E1FAA009D S31A0010F4DD32C2C50018AF000032C2C3000EACFE000EABFF003924 S31A0010F4F27FA80023FFFF00397FA9003AC2B4000CAFC0000CAF60 S31A0010F507B10018AF01000E1FAA0036C2B8000EC0BF000D5F11CF S31A0010F51C000CAF1B000CAF0C00397FA80023FFFF000EABBC0031 S31A0010F5310EACFF0023FFFF000E0BF40032C2AE000E1C59003073 S31A0010F546C2AA000EABBE000EAC7A0033C2A8000EABBE000EACB5 S31A0010F55B980023FFFF00397FAD0016AFF80004AFA3000E1FFD2A S31A0010F5700032C29E0004ABBF000E2BFB000E1BFF0036C292008A S31A0010F5850EA1BE000EA0370018AB02000E2B7F000E1BFF00362E S31A0010F59AC292000EA1FF000EA01C0018AB34000E2BFD000E1B24 S31A0010F5AFFF0032C260000EA1BF000EA0BD000EA3BE000EA25C8A S31A0010F5C40018AF030002FF040018AF040002FF05000EA1FF00CE S31A0010F5D90EA01C0018A4070018A506001AAF060001BF5F001AAF S31A0010F5EEAF070001BF5E000EACFF000EABFF000CAF5D000CAFDA S31A0010F6034E003AC0770002FB060002FC07000EACFF000EABBFE4 S31A0010F618000CAF5D000CAF4E003AC0770002FB000002FC010039 S31A0010F62D1EAF060002FF02001EAF070002FF03001EAC05001E17 S31A0010F642AB04000CAF5D000CAF4E003AC03D000EA1FE000EA03B S31A0010F6574D0002CB000002CC01000EA3FF000EA21C000CAF3137 S31A0010F66C000CAF200018AF34000EBFFD0002DF34000EA3FE000F S31A0010F6810EA24D000EA1FF000EA01C0018AF060002DF02001821 S31A0010F696AF070002DF030016AF0800397FAC0023FFFF000D9FB1 S31A0010F6ABEE000E5DBF00397FDC000ECDDF000D5FCC000D5FBB6F S31A0010F6C0000EEDFB000EECFB000CBFDE000E6BFB000CBFCD007F S31A0010F6D50CAFBC000E6BFD000CAFDB000CAFEC0023FFFF000CB3 S31A0010F6EAAFC0000CAFB10018AC0300183C010018AB0200187BA6 S31A0010F6FF0000397FDC000ECDDF000D5FCC000D5FBB000EEDFB3D S31A0010F714000EECFB000CBFDE000E6BFB000CBFCD000CAFBC00A9 S31A0010F7290E6BFD000CAFEC0018CC01000CAFDB0018DB00002307 S31A0010F73EFFFF00397FAD000CAFC4000CAFB5000EA0FF000EA1F2 S31A0010F753FF000EA8FF000EA9FF001CAF00001CBF010032C22363 S31A0010F768000EA3FF0033C1DA001CAC01001CAB00000E0BC0008F S31A0010F77D32C21E000E1C000034C21B000EA3F10033C1DA001C88 S31A0010F792AC01001CAB00000E0BCE0032C216000E1C390030C292 S31A0010F7A70C000EAEF6000EADFF00397FDC000CAFE0000CAFD104 S31A0010F7BC000CAFC8000CAFB9000EA3FF0033C1E6001CAC0100D8 S31A0010F7D10ECCC6001CAB00000EDB31000EAEC0000EADFF00391D S31A0010F7E67FDC000CAFE0000CAFD1000CAFC8000CAFB9000D0F63 S31A0010F7FB9B000D4F8C000D4F1D000D4F0E000E6BFB000CAFBE90 S31A0010F810000E6BFD000CAFBC000CAFBD000EEBFD000CAFBE00F9 S31A0010F8250EADFF000EACFF000EABFF000CCE00000CDD11000CAD S31A0010F83ADC88000CDB99000D0F9B000D4F8C000D4F1D000D4F4B S31A0010F84F0E000CAFE0000CAFD1000CAFC8000CAFB9000EA3F8B9 S31A0010F864000D0F9B000D4F8C000D4F1D000D4F0E000EEDF70005 S31A0010F8790EECF7000CBFDE000E6BF7000CBFCD000CAFBC000E3D S31A0010F88E6BFD000CC3E3000CAF1B000E2BC0000CAF0C0002EBB2 S31A0010F8A3000002EC01000CAF3C000EABFF00397FAC0023FFFF17 S31A0010F8B800397FA90016AFFE000EA3FF000EA21C000EA1FE00D8 S31A0010F8CD0EA087001AA81D00183818001AA91C00187917000EFF S31A0010F8E2F97F0032C1C3000CB89F0032C1C0000EACFF000EAB45 S31A0010F8F7FF0033C1B3001AAC19001A3C23001AAB18001A7B2254 S31A0010F90C000C48CC000C59BB000EA1BE000EA0370018AE0A006E S31A0010F92118AD090002F9000002F801003A7FBE0016AF02003980 S31A0010F9367FA80023FFFF00397FA90016AFFE000EA1FE000EA0DF S31A0010F94B870018A8180018A917000EF97F0032C198000CB89FE6 S31A0010F9600036C198000EA1FF000EA01C000CAF8C00183C2300B7 S31A0010F9750CAF9B00187B22000EA1BE000EA0370018AE0A001822 S31A0010F98AAD090002F9000002F801003A7FBE0033C196000EACEB S31A0010F99FFF000EABFF0016AF0200397FA80023FFFF00397FADD9 S31A0010F9B40016AFFC000EA1FE000EA0870018AF170002FF0000A6 S31A0010F9C918AF180002FF01000EA5FF000EA41C001EAC01001EC9 S31A0010F9DEAB00001C0B1C0032C184001C1C1D0034C17F001CAF05 S31A0010F9F31C0002FF00001CAF1D0002FF01001EAC01001C3C239C S31A0010FA08001EAB00001C7B22003A7FC00002FB020002FC0300D8 S31A0010FA1D1CAC1D001C3C19001CAB1C001C7B18003A7FC0001E3F S31A0010FA32AE03001EAD02000C0DBF0032C16E000C1ECF0030C108 S31A0010FA4768001CAC1D001C3C19001CAB1C001C7B180033C164EC S31A0010FA5C001EAC01001C3C23001EAB00001C7B220016AF0400EE S31A0010FA71397FAC0023FFFF00397FA9000EA1FE000EA08700188A S31A0010FA86AE010018AD00000EABFE000EAC51003AC2F800397F73 S31A0010FA9BA80023FFFF00397FA90016AFFA0002FB020002FC0357 S31A0010FAB00002FD040002FE05000EA3BF000EA2AE001EAF030085 S31A0010FAC51A3F4E0002FF03001EAF02001A7F4D0002FF02001E95 S31A0010FADAAC05001A3C50001EAB04001A7B4F0002FB040002FCFA S31A0010FAEF05000EA1FE000EA087001EAF020002CF17001EAF037E S31A0010FB040002CF180002CB190002CC1A0004AF590032C12800F8 S31A0010FB1918AC140018CC010018AB130018DB00001ECC0300024C S31A0010FB2EFC03001EDB020002FB020018AC160018CC030018AB2F S31A0010FB43150018DB02001ECC050002FC05001EDB040002FB049D S31A0010FB580033C1100004A85A001A384E0004A95B001A794D00F0 S31A0010FB6D02F9020002F803000EA1BD000EA0760018A201001810 S31A0010FB82A3000018AE17000EADFF000EAC17000EABFC00397FE0 S31A0010FB97DD0002FD000002FE01000CAF9B000CAF8C000CAF3DD1 S31A0010FBAC000CAF2E003A7FBE0002FB040002FC05001EAF0200FB S31A0010FBC10EFF7F0036C107000EAFFF0002FF020002FF03000EBE S31A0010FBD6AFFF0002FF040002FF05000EABFF000EAC00001EAE0D S31A0010FBEB03001EAD02003AFB060004AF93000E1FFE0036C0FD80 S31A0010FC000000FD930000FF920016AF0600397FA80023FFFF006C S31A0010FC15397FAB000EA5FE003AC2B4000CAFC0000CAFB1001801 S31A0010FC2AAF01000E1FAA0032C0ED00198C00000D9FFB000CBB36 S31A0010FC3FCB000CAFB5000EE5FD000CAF5C000EABFF00397FAA3E S31A0010FC540023FFFF00397FA9000CAFE2000CAFD3000EA1FE002B S31A0010FC690EA0510018AE01001A3E010018AD00001A7D00000CE9 S31A0010FC7EAFC0000CAFB10018AC010018AB00000D9FEE000E5DF3 S31A0010FC93BF003AC25500397FA80023FFFF00397FA9000CAFC0D9 S31A0010FCA8000CAFB1000EA3FE000EA2510018AC010018AB00008D S31A0010FCBD1AAE01001AAD00003AC25500397FA80023FFFF000CAE S31A0010FCD2AFC0000CAFB10018AC0300183C010018AB0200187BB8 S31A0010FCE70000397FDC000ECDDF000D5FCC000D5FBB000EEDFB4F S31A0010FCFC000EECFB000CBFDE000E6BFB000CBFCD000CAFBC00BC S31A0010FD110E6BFD000CAFEC0018CC01000CAFDB0018DB00002319 S31A0010FD26FFFF00397FA9000CAFC2000CAFB3000EA0FF000EA10C S31A0010FD3BFF000EA8FF000EA9FF001AAF00001ABF010032C0A9F5 S31A0010FD50000EADFF0033C08C001AAC01001AAB00000E0BC000EA S31A0010FD6532C0A4000E1C000034C0A1000EADD80033C08C001AF2 S31A0010FD7AAC01001AAB00000EAED8000EADFF00397FDC000CAF4F S31A0010FD8FE0000CAFD1000CAFC8000CAFB9000D0F9B000D4F8C47 S31A0010FDA4000D4F1D000D4F0E000EEDF7000EECF7000CBFDE00C5 S31A0010FDB90E6BF7000CBFCD000CAFBC000E6BFD000CAFED000C76 S31A0010FDCEAF1B000E2BC0000CAF0C0002DB000002DC01000CAF09 S31A0010FDE3DC000EABFF00397FA80023FFFF00397FA90016AFFEBC S31A0010FDF8000D9FEF0002FF01000DCFDF0002FF00000EAEEF00DC S31A0010FE0D0EADF1003A7FBE0016AF0200397FA80023FFFF003926 S31A0010FE227FAD0016AFF8000CAFC4000CAFB50002FD060002FED8 S31A0010FE3707003AC4D00002FB020002FC03000EAFFE0002FF000F S31A0010FE4C000CAF5B000CAF4C001EAE07001EAD06003AC49E002E S31A0010FE6102FB040002FC050004AE5E0004AD5F000EAFFF000294 S31A0010FE76FF01000EAFFB0002FF00003A7FBE001ECC03001EDB4B S31A0010FE8B02000EFB7F0036C058000EACFF000EABFF000CAFCE7A S31A0010FEA0000CAFBD0004AF5F000EFF7F0032C0420004AF5F00DB S31A0010FEB504BF5E0036C042000CAFEC001E3C03000CAFDB001E11 S31A0010FECA7B02000EA1BE000EA01F00180B0A0032C04700181CBC S31A0010FEDF0B0034C042001EAE030018CE0B001EAD020018DD0A2B S31A0010FEF4000CAFDB000CAFEC0016AF0800397FAC0023FFFF0054 S31A0010FF09397FA90016AFFA001E0B0A0032C038001E1C0B0035D6 S31A0010FF1EC034000EACFF000EABFF0033C01E001E0B080032C01F S31A0010FF3331001E1C090030C02D000EACFF000EABBF0033C01ED0 S31A0010FF480000FF60000EAFFF0002FF01000EAFBF0002FF0000F4 S31A0010FF5D02FB020002FC030002FD040002FE05000EABC0000EEA S31A0010FF72AC77000EAEFF000EADFF003A7FBB0000FE600016AF35 S31A0010FF870600397FA80023FFFF00397FA9003AC2B4000CAFC03C S31A0010FF9C000CAFB10018AF01000E1FAA0032C012000EC0BF009E S31A0010FFB10D5F11000CAF1B000CAF0C00397FA80023FFFF003F4B S31A0010FFC6FFFF003FFFFF003FFFFF003FFFFF003FFFFF003FFFE0 S31A0010FFDBFF003FFFFF003FFFFF003FFFFF003FFFFF003FFFFFCB S3150010FFF0003FFFFF003FFFFF003FFFFF003FFFFFF7 S70500100000EA
  • FYI
    S00F00004657303734325F30315F303304 S31A000040008064476F9501DB6D05BD020000F751F6C9F4145209FF S31A0000401521326D00000000CFDC17F30000167A00003564F9A158 S31A0000402A0015300100EF0522050100001001003C00503C0064DC S31A0000403F3C002012560010EFFC7FF2A90003003203E80101016A S31A00004054F4001EC81408003C0E10000A46050F050F0320003234 S31A00004069006446500A0EE70E9B0190006419DC5C6000C8000428 S31A0000407E0332000100140001001403230708255A0F1E600D4832 S31A0000409300C82801F40000000000000000000043800400C8009E S31A000040A80001140036000000000582000A138800C80A03002889 S31A000040BD0F21340A01F403E8521110FC10C610971078105810AE S31A000040D23C101F10050FEB0FD20FBA0FA30F900F7D0F6C0F5CEC S31A000040E70F4B0F3A0F1E0F070EF80EEC0EE40EDC0ED60ED10E2B S31A000040FCCD0ECA0ECC0EC80EC20EBC0EAD0E9F0E8C0E790E78AB S31A000041110E620DE80BE8FBB5FD63FE4CFE77FEB6FE75FEDCFE6D S31A0000412679FE9CFE87FF0DFF19FED1FEC0FEB5FE56FEBDFF3B39 S31A0000413BFE30FEDCFFEB003AFFD1FFFEFF86FF69FF69FE81FBA1 S31A0000415096F91DF74EF58CF7DDF7A1F53CFAE4FA2AFD7BEEEDF0 S31A00004165B70DFFD0FFD1FFD0FFC3FFBBFFD5FFD4FFD1FFD8FF44 S31A0000417AD8FFD0FFE1000400A30099FF20FF27FF26FF20FF4A91 S31A0000418FFF33FF40FEE0FEE1FED7FEC4FEBCFE0CFDD6FF0210A8 S31A000041A4FEFFCE022601C20019006428FF62FF620032000A2D7A S31A000041B9323C0110FE10FE10CC109A32505050097F8018800B0D S31A000041CE07001404000AF0000F05003201C214089800003C00C4 S31A000041E34B0028003C3C01019019861115FFFFFFFF234545676F S31A000041F889ABCDEFFEDCBA9876545432000002580BB810FE0015 S31A0000420D0000000038000A1964003C000000000000000000009B S31A0000422200000000000000000000000000000000000000000081 S31A000042370000000000000000000000000011490110E009C40153 S31A0000424C0A28003C01F40501C2025805022610B310CC10E51001 S31A00004261FE1117113011491162116212AB0E00000000000000D0 S31A0000427600000000000D009B7A28F70000038A000000120ED867 S31A0000428B0031000000010000119411A84318FE7050000A7F07DF S31A000042A001009600AF004B00640B54020BB810CC021068000094 S31A000042B5000000000000000000000000000000000000000000EE S31A000042CA000000000000000000000000000000000000000000D9 S31A000042DF000000000000000000000000000000000000000000C4 S31A000042F4FFFFFFFFFFFFFFFFFFFFFFFF0055005100520055006E S31A000043095E006F0059006100640067006B0064007500950192DB S31A0000431E046E0000000000000000000000000000000000000012 S31A0000433300000000000000000000000000000000510052005577 S31A00004348005E006F0059006100640067006B006400750095012E S31A0000435DB304CB000000000000000000000000000000000000C3 S31A00004372000000000000000000000000000076545432000002DE S31A00004387580BB810FE000000000038000A1964003C00000000F7 S31A0000439C00000000000000000000000000000000000000000006 S31A000043B1000000000000000000000000000000FFFFFFFF0001F4 S31A000043C62FCDFFFED031FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1 S31A000043DBFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDC S315000043F0FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC7 S31A001000000033FFEA0033FBEB0033FC6D0033FE650033FE7D00C0 S31A00100015155454003FFFFF003FFFFF003FFFFF003FFFFF003FD0 S31A0010002AFFFF003FFFFF003FFFFF003FFFFF003FFFFF003FFF7B S31A0010003FFF003F01030033CB58000800ED000000000000000009 S31A00100054000EAAFF000EA7FB000EA6FF000EA1FF000EA0FF000C S31A001000690EA3FE000EA247003AFFD2000EA1FF000EA058000EF9 S31A0010007EA3FF000EA257000EA5BD000EA40C003AFFCA000EA1CE S31A00100093FE000EA047000EA3FE000EA247003AFFCA003AFFC2AB S31A001000A80033FFD6000EAFFF00034F01000C113F0030FFCD00BE S31A001000BD35FFD4000C102F0035FFD40023FFFF0014AF010003D5 S31A001000D24F01000C113F0030FFC50035FFCC000C102F0035FFE4 S31A001000E7CC0023FFFF000BDFFF0033FFC400397FA90016AFFEFE S31A001000FC000EABC1003A7FE20001BCD5000E1C8B0036FFB60092 S31A001001110E1C030036FFB6000E1CBA0036FFB6003A7FFB000E1A S31A00100126ABC1003A7FE2000CAFBC000EABFF0001BCD5003AFBB1 S31A0010013BB90000FEDE000EAFFF0002FF000002FF01000EACFF8C S31A00100150000EABFF000CAFCE000CAFBD003AFDBB0000FFDE00FC S31A001001650EA1BE000EA0370018AB00000E2BBF000E1BFF003604 S31A0010017AFF9B000EA08F000EA17F0018AB0D000EBBFB0033FF8F S31A0010018F97000EA08F000EA17F0018AB0D000E2B040002CB0D5C S31A001001A4000EA1BE000EA0370018AB00000E2BDF000E1BFF00DB S31A001001B936FF8B000EA08F000EA17F0018AB02000E2B040033BB S31A001001CEFF87000EA08F000EA17F0018AB02000EBBFB0002CBBF S31A001001E302000EA0AF000EA17F000EAFF40002CF00000EBA7F9B S31A001001F8000E2A40003AFF09000EACFE000EABFF0016AF0200EB S31A0010020D397FA80023FFFF0004AFE30004BFE20036FF7300045E S31A00100222A0E20004A1E30002C7000002C6010004AFE50001BFBD S31A00100237E30004AFE40001BFE2000EACFF00041CE10031FF2C6A S31A0010024C0004A0E20004A1E30018AB02000E2B7F000E1BFF00D4 S31A0010026132FF61000EFAFC000CAFFB00182B02000E1BFF003683 S31A00100276FF3A0018AF02000EBF7F0002CF020018A7000018A6BF S31A0010028B010018AB02000E2BDF000E1BFF0036FF4C0016A50105 S31A001002A00016A4010016A9010016A8010018AB02000E2B2000DB S31A001002B502CB02000E2BBF000E1BFF0032FF19000EBADF00330B S31A001002CAFF190016A9010016A801002DFFFF0016AB010016ACC3 S31A001002DF010016AD010016AE010016A5010016A4010016A30139 S31A001002F40016A2010016A1010016A0010016A9010016A8010038 S31A0010030917AF010016AF01003F1FFF0018AB02000E2BBF000E14 S31A0010031E1BFF0032FF340018A7000018A6010004AFE2000ECF45 S31A00100333FC0001BFE200055FE30001BFE3000D1FCC00041CE11E S31A001003480035FF6C0000FFE30000FFE20005BBE0000E1BFE0060 S31A0010035D30FF1F000EABF70004AFE0000E1FFE0032FF22000E58 S31A00100372ABF5000EA0AF000EA17F0002CB00000EBADF000BDFD7 S31A00100387FF000E2A20000EFADF0032FF1D0033FF730023FFFFF9 S31A0010039C000E2A20000EFADF0032FF180004A0E20004A1E300A0 S31A001003B118AB02000E2B80000EBFDF0002CF02000378FF0003A7 S31A001003C679FF000374FF000375FF0033FF7A0023FFFF00397F22 S31A001003DBA9003AFECD00397FA80023FFFF00397FA90016AFFDA5 S31A001003F0000CAFC8000CAFB9000E2A20000EFADF0032FF01007A S31A0010040504ABDF000E2BEF000CBDFF0001BFDF0004AFE0000E0E S31A0010041A2F0B0001BFE0000EAFFC0002FF00000EAFF20002FF73 S31A0010042F01000EAF5F0002FF02000EABFD000CAF9C000CAF8D2D S31A00100444003AFEE70000FFE30000FFE2003AFF7A0016AF030030 S31A00100459397FA80023FFFF000374FF00397FA9000CAFD8000C81 S31A0010046EAFC9001EAE04001EAD03001EA405000EEBFC000CAFD6 S31A00100483FC000CAFC2000EC257000CAFB3000ED3FF000CAFE0C5 S31A00100498000EC001000DFFD10002C9000002C801000ECE030018 S31A001004AD02DE01000DFFDF0002DF000002D40200397FA8001629 S31A001004C2A4010023FFFF00397FA90016AFFD000E2A20000EFAC6 S31A001004D7DF0032FECB003AFE9D0000FFE0000EAFFF0001BFE50B S31A001004EC000EAF570001BFE40000FCE1000EAFFB0002FF000097 S31A001005010EAFFF0002FF01000EAF1F0002FF02000EABFF000E6C S31A00100516ACCE000EAD58003AFEE7000EAFFC0002FF00000EAF97 S31A0010052B980002FF01000EAF5E0002FF02000EABFE000EACD8A4 S31A00100540000EAD83003AFEE7000EAFFC0002FF00000EAFF200CA S31A0010055502FF01000EAF5F0002FF02000EABFD000EACE8000EF4 S31A0010056AAD3C003AFEE70000FFE30000FFE2003AFF7A0016AF23 S31A0010057F0300397FA80023FFFF000EA2FF000EA37F000EAFFF32 S31A001005940002DF40000EAFFF0002DF30000EA1BE000EA03700FC S31A001005A918AB01000E2B7F000E1BFF0036FE8F000EAFFD000204 S31A001005BEDF31001AAB91000E2B1A0002DB91000EAF1A0002DF33 S31A001005D390000EA04F000EA17F000EAFFF0002CF00000EAF00F8 S31A001005E80002DF61001AAB60000E2B020002DB60000E2A43008E S31A001005FD0EAF070002DF930023FFFF00397FA9000E2A04000ECF S31A00100612FAFB000CAFFB000E1BFF0032FE76003AFF180004AF40 S31A00100627E0000E1FFE0032FE67000EA1BE000EA02C0018AF0CEC S31A0010063C0036FE6D0000FFA40033FE68000EA1FF000EA01C003E S31A0010065118AF01000E2F200002CF010000FFE000397FA8002325 S31A00100666FFFF00037FFF000CAFFF000B7FFF00037FFF000378AB S31A0010067BFF000379FF000370FF000371FF000372FF000373FF0C S31A00100690000374FF000375FF00037EFF00037DFF00037CFF00D5 S31A001006A5037BFF003EBFFF000378FF000379FF000EA0EF000E11 S31A001006BAA17F0018AB03000E2B7F000E1BFF0036FE460018AB12 S31A001006CF04000EBB7F0002CB040018AB04000E2B800002CB0492 S31A001006E4000EA1FF000EA0570018AF02000EBF7F0002CF020050 S31A001006F933FF7A0023FFFF000E2A20000EFADF0032FE3F000E4D S31A0010070EA0CF000EA17F0018AB01000E2B040002CB01000EBA8C S31A00100723DF0023FFFF000EA0CF000EA17F0018AB01000E2B04FF S31A001007380002CB010018AB01000E2B080002CB010023FFFF00D4 S31A0010074D397FAD0016AFFE000CAFE4000CAFD5000EAFFF00026C S31A00100762FF01000EAFFB0002FF00003A7FBE000CAFC8000CAFFE S31A00100777B9000EA1BD000EA0760018AE17000EADFF000EAC17A6 S31A0010078C000EABFC00397FDD0002FD000002FE01000CAF9B00A2 S31A001007A10CAF8C000CAF5D000CAF4E003A7FBE0016AF0200394E S31A001007B67FAC0023FFFF00397FAD0016AFFA0002FB000002FCAD S31A001007CB01001EA80B001EA90A0004ACCD0004ABCE00397FDCD2 S31A001007E0000CAFDE000CAFCD000CAFBC000E6BFE000CAFE40040 S31A001007F50CAFD5000EA1FE000EA0870018C41E0018D51D000C57 S31A0010080AAF9C000CAF8D000EAFFE00397FD2000CAFE0000CAF95 S31A0010081FD1000CAFC8000CAFB9000E887F0004ADCB0004ACCCD9 S31A00100834000EAFFE00397FD200037EFF00037DFF00037CFF00D7 S31A00100849037BFF000CAF9B000CAF8C000CAF1D000CAF0E003990 S31A0010085E7FD50016AF04003A7FC50002FB020002FC030002FDD5 S31A00100873040002FE05000CAF5C000CAF4D000EAFFE00397FD2ED S31A00100888000CAFE0000CAFD1000CAFC8000CAFB9001E140100F4 S31A0010089D0CAFFC001EAB00000C7B5B000CAFCD000CAFBC000EC1 S31A001008B2AFFE00397FD2001EAF0500037FFF001EAF0500037F3D S31A001008C7FF001EAF0500037FFF001EAF0500037FFF00397FD9D0 S31A001008DC0016AF04000370FF000371FF000378FF000379FF004E S31A001008F1397FD40016AF0400397FD1000CAFDB000CAFEC0016AB S31A00100906AF0600397FAC0023FFFF00397FAD0016AFF80002FB6D S31A0010091B020002FC030002FD040002FE05003AFC82000E1CFFC5 S31A001009300036FD220004ACE40004ABE500041BE30032FDAB0043 S31A00100945041CE20032FDAB003AFBA4003AFBB2003AFCBC000EEB S31A0010095A1CFF0032FDA50000FED40033FD2A001EAB0C000E2B49 S31A0010096FFC001EAC0D000EECF7000E6BF7000CBCFC000E2C012A S31A001009840002FC06001EA50D000E25C0001EAF02001EBF0300D2 S31A0010099936FD2A000E15BF0002FF07001EAC07000EABFF001E45 S31A001009AE1B020032FD91001E1C030034FD8E001EAF030002FF74 S31A001009C307001EAE06000EADFF000EEEDF00037FFF000EEDDF40 S31A001009D8000CBFED0016AE01000EBDBF0002FD0C0002FE0D00D5 S31A001009ED0EABE3003A7FEB001EAF0C0002FF00001EAF0D0002E9 S31A00100A02FF01000EABE3000EACFF000CAF5D003A7F9B001EAF3B S31A00100A170C0002FF00001EAF0D0002FF01000EABE3000EACFF76 S31A00100A2C000CAF5D003A7F9C000E1CFF0036FDA7001EAF04005E S31A00100A4102FF00001EAF050002FF01000EABE3000CAF5C001EE4 S31A00100A56AD07003A7F9B001EAF040002FF00001EAF050002FFC8 S31A00100A6B01000EABE3000CAF5C001EAD07003A7F9C000E1CFF5C S31A00100A800036FDA7001EC507000CAF5C000EABFF001ECC0D00C1 S31A00100A9502FC0D001EDB0C0002FB0C000CAF54000E44BF001EDF S31A00100AAAAF0C0002FF00001EAF0D0002FF01000EABE3000CAF32 S31A00100ABF5C000CAF4D003A7F9B001EAF0C0002FF00001EAF0DA0 S31A00100AD40002FF01000EABE3000CAF5C000CAF4D003A7F9C00E5 S31A00100AE90E1CFF0036FDA7001EAB06003A7F99000E1CFF00365F S31A00100AFEFDA7003AFCBC000E1CFF0036FDA7001EAC07000EABAA S31A00100B13FF001E1C030002FF03001EAF02000C7FBF0002FF025B S31A00100B28001ECC050002FC05001EDB040002FB04001EAF0600DF S31A00100B3D0ECFFD0002FF06000EA5FF001EAF02001EBF03003219 S31A00100B52FD98003AFBAB0004ACE40004ABE500041BE30032FDAA S31A00100B672200041CE20032FD22003AFB930016AF0800397FACF5 S31A00100B7C0023FFFF00397FAD0016AFFC0002FB02000CAFD40079 S31A00100B910CAFC50002FE03003AFC82000E1CFF0036FD07000299 S31A00100BA6F5000002F401001EAB03001EAC08001EAD02003A7F14 S31A00100BBBED0002F5000002F401001EAB03001EAC08001EAD02C9 S31A00100BD0003A7F9C000E1CFF0032FD070000FED40016AF0400AB S31A00100BE5397FAC0023FFFF00397FAB000CAFB5003AFC82000EC7 S31A00100BFA1CFF0036FCFD000CAF5B003A7FEB00397FAA0023FF48 S31A00100C0FFF00397FA90016AFFC000EA1BD000EA0910018AF0F18 S31A00100C240002FF000018AF100002FF010018AF110002FF0200F0 S31A00100C3918AF120002FF03001EAF00001EBF01001EBF02001E0B S31A00100C4EBF030036FCBF000EA1FF000EA01C0018AB00000E2B54 S31A00100C63DF000E1BFF0036FCD9001EAF03000ECFBC0002FF03E7 S31A00100C78001EAF02000EDFF80002FF02001EAF01000EDF3F00A0 S31A00100C8D02FF01001FFF000002FF00001EAF00001EBF01001E52 S31A00100CA2BF02001EBF030036FCBF003A7FE9001EAF0300037FA1 S31A00100CB7FF001EAF0300037FFF001EAF0300037FFF001EAF03A1 S31A00100CCC00037FFF001E1B000032FCC1001E1C010032FCC1002A S31A00100CE11E1D020032FCC1001E1E030032FCC10016AF04003392 S31A00100CF6FCBF0016AF040000FED40016AF0400397FA80023FF32 S31A00100D0BFF00397FAD0016AFFD000EA5FE000EA03F000EA1BC8E S31A00100D200018A400003A7F97000E1CFF0032FCAF003A7F980045 S31A00100D350EACFE000EABFF0033FC85000E14E00030FC87000EAC S31A00100D4AFADF000CAFFB0002FB02000E2A20000EFADF0032FC83 S31A00100D5FAA000CAF4B003A7FEB000EAFBC0002FF00000EAF7F5F S31A00100D740002FF01000CAF4B000EACFF000EADBF003A7F9B00C5 S31A00100D890EAFBC0002FF00000EAF7F0002FF01000CAF4B000E73 S31A00100D9EACFF000EADBF003A7F9C000CAFC5001EAB02000CBA9F S31A00100DB3BA000E15FF0036FC87003A7F98000EA03F000EA1BCD7 S31A00100DC80018AF00000E1F000032FC88000E25FE0033FC87006F S31A00100DDD0EA5FF000CAF5C000EABFF0016AF0300397FAC00231B S31A00100DF2FFFF000EA1BE000EA02C0018AE010018AD00000EAB4C S31A00100E07FF00041BD40032FC70000EA1FF000EA01C0018A209F5 S31A00100E1C0018A308000C03DF0032FC74000C12EF0031FC7100AD S31A00100E31041BDE0036FC70000EABFE000CAFBC000EABFF0023EE S31A00100E46FFFF00037FFF000CAFFF000B7FFF00037FFF000378C3 S31A00100E5BFF000379FF000370FF000371FF000372FF000373FF24 S31A00100E70000374FF000375FF00037EFF00037DFF00037CFF00ED S31A00100E85037BFF003EBFFF000378FF000379FF000EA26F000EA7 S31A00100E9AA37F001AAC00000E2FFB000CAFFB000E1BFF0036FCFD S31A00100EAF51000EAF040002DF00001AAB01000C2CBC000E2FF737 S31A00100EC4000CAFFB000E1BFF0036FC33000EAF080002DF00001A S31A00100ED90EA0BF000EA17F0018AE020018AD010001BDDD000129 S31A00100EEEBEDC0018AB00000E2BFE000E1BFF0032FC3D0001BDF4 S31A00100F03DB0001BEDA000EA1FF000EA0540018AF02000EBF7F8A S31A00100F180002CF02001AAB01000E2B080002DB01000E2A1000AE S31A00100F2D33FF7A000E2CEF000CAFCB000E1BFF0036FBFF0000E6 S31A00100F42FFD90000FFD80000FFD70000FFD6000EA2CF000EA3FA S31A00100F577F001AAF020001BFD9001AAF030001BFD8000EA0BFBB S31A00100F6C000EA17F0018AB00000E2BFE000E1BFF0032FC1700C5 S31A00100F811AAB01000E2BEF000E1BFF0036FC17001AAF04000118 S31A00100F96BF96001AAF050001BF95000EA0CF000EA17F0018AB4A S31A00100FAB00000E2B800002CB000004AFD30036FC0D0004AFD34A S31A00100FC00002CF000000FFD3000EA1FF000EA0540018AF0200EA S31A00100FD50EBF7F0002CF02000EA06F000EA17F0018AB01000EB5 S31A00100FEA2B100002CB01000EAF100002CF00000E2A100033FFBB S31A00100FFF7A000E2A100016A9010016A801002DFFFF0016AB0199 S31A001010140016AC010016AD010016AE010016A5010016A40100EE S31A0010102916A3010016A2010016A1010016A0010016A9010016E4 S31A0010103EA8010017AF010016AF01003F1FFF0023FFFF00037F51 S31A00101053FF000CAFFF000B7FFF00037FFF000378FF000379FFBA S31A00101068000370FF000371FF000372FF000373FF000374FF0019 S31A0010107D0375FF00037EFF00037DFF00037CFF00037BFF003E99 S31A00101092BFFF000378FF000379FF000EA06F000EA17F000EAF78 S31A001010A7100002CF03000EA3FF000EA230000EA02F000EA17F9F S31A001010BC0018AB01001ABF0E0002DF0E000E2A080016A901006F S31A001010D116A801002DFFFF0016AB010016AC010016AD010016AB S31A001010E6AE010016A5010016A4010016A3010016A2010016A18F S31A001010FB010016A0010016A9010016A8010017AF010016AF0106 S31A00101110003F1FFF0023FFFF00397FA9000EABFF000EAC4E0015 S31A001011250EADFC003A7FA700397FA80023FFFF00397FA9000E98 S31A0010113AABFF000EAC4E000EADFC003AFB8300397FA80023FFE7 S31A0010114FFF00397FA9000EABFF000EAC4E000EADFC003AFB4F1A S31A0010116400397FA80023FFFF000EA06F000EA17F0018AB0100D0 S31A001011790CAFBE000EADFF0004ABFF000E2BEF000E1BFF0036E4 S31A0010118EFB98000E2E80000CAFEB0033FB96000E2E40000CAF46 S31A001011A3EB0002CB01000E2A040023FFFF000EA06F000EA17FC0 S31A001011B80018AB01000CAFBE000EADFF0004ABFF000E2BEF003F S31A001011CD0E1BFF0036FB87000EBE7F000CAFEB0033FB85000E65 S31A001011E2BEBF000CAFEB0002CB010023FFFF00397FAD0016AFA6 S31A001011F7FF000CAFC4000CAFB5000EFADF000CAFFB0002FB0045 S31A0010120C000E2A20000EFADF0032FB7C001CAF000036FB56007D S31A001012210D1F40000D5F51000DBFDD0036FB5E000CAF42000E36 S31A00101236C2FC000D5F530018AF000018BF010032FB640004AF2D S31A0010124BE30002CF000004AFE20002CF010004A0E20004A1E34F S31A001012600018AF020002DF000033FB5E000EC2FC000D5F3300C2 S31A001012750EC0FC000D5F11000DBFDD0032FB70001EAB00000CEC S31A0010128ABABA0004A0E20004A1E30018AF02000E2F030002CFDD S31A0010129F02003AFF18000EAFFE0002EF00001EAB00000CBABADC S31A001012B40016AF0100397FAC0023FFFF00397FAD0016AFFF009B S31A001012C90CAFC8000CAFB9000EFADF000CAFFB0002FB00000E5B S31A001012DE2A20000EFADF0032FB48000D1F84000D5F95000CAFD3 S31A001012F380000CAF910018AF010018BF020036FB1A0018AF0150 S31A0010130800037FFF0018A0020016A101001CAB02000E2BFC00C9 S31A0010131D0EBB7F0018BF020002CF02000ECD010036FB1F000C79 S31A00101332AF82000EC2FC000D5F93000CAF80000EC0FB000D5F24 S31A00101347910018AF000002EF000018AF010002EF010018AF02AF S31A0010135C0002DF00000EC0FC000D5F11000EC2FC000D5F3300D3 S31A001013710EC4FC000D5F55000DBFDD0032FB2D000EAFFF000201 S31A00101386EF000002EF01003AFB110033FB16000CAF82000CAFD9 S31A0010139B93000EAFFF0002DF00001EAB00000CBABA0016AF01E8 S31A001013B000397FAC0023FFFF0004A0E20004A1E30018AF0200B6 S31A001013C50EBFDF0002CF02000378FF000379FF000374FF000310 S31A001013DA75FF0033FF7A0023FFFF0016AFFF000CAFC0000CAFAD S31A001013EFB1000EFADF000CAFFB0002FB00000E2A20000EFADF49 S31A001014040032FB000002CD000002CE01001EAB00000CBABA00A7 S31A0010141916AF010023FFFF0016AFFF000EFADF000CAFFB00025E S31A0010142EFB00000E2A20000EFADF0032FAF3000EA1BE000EA01F S31A00101443370018AB00000E2BDF000E1BFF0036FAE5000EA08FF2 S31A00101458000EA17F0018AB02000EBBFB0033FAE1000EA08F0067 S31A0010146D0EA17F0018AB02000E2B040002CB02001EAB00000C80 S31A00101482BABA0016AF010023FFFF0016AFFF000EFADF000CAF7E S31A00101497FB0002FB00000E2A20000EFADF0032FAD8000EA1BE82 S31A001014AC000EA0370018AB00000E2BDF000E1BFF0036FACA0033 S31A001014C10EA08F000EA17F0018AB02000E2B040033FAC6000E92 S31A001014D6A08F000EA17F0018AB02000EBBFB0002CB02001EAB6D S31A001014EB00000CBABA0016AF010023FFFF000EA1FF000EA01CF7 S31A001015000018AF01000EBF7F0002CF01000EA02F000EA17F00CF S31A0010151518AB00000EBBFB0002CB000023FFFF000EA02F000E4B S31A0010152AA17F0018AB00000E2B040002CB00000EA1FF000EA04D S31A0010153F1C0018AF01000E2F800002CF010023FFFF00397FA98C S31A001015540016AFFA000CAFC0000CAFB1001EA809001EA9080028 S31A001015690CAFDC000E6CFE000CAFCB000CAFCB000CAFDC000C99 S31A0010157EAFED000EAEFF0002FB000002FC010002FD020002FEEE S31A00101593030002F9040002F805000CAF1B000CAF0C003AFA92C9 S31A001015A80016AF0600397FA80023FFFF00397FA90016AFFA00AC S31A001015BD1EAE0D001EAD0C000E1DFE0032FA8B000E1EFF003414 S31A001015D2FA88000EAEFF000EADFE001EAF080002FF00001EAF55 S31A001015E7090002FF01001EAF0A0002FF02001EAF0B0002FF0318 S31A001015FC0002FD040002FE05003A7FA10016AF0600397FA80037 S31A0010161123FFFF00397FAD0016AFFE000CAFC2000CAFB3000C6E S31A00101626AFE4001A3403000CAFD5001A7502001EAF07001A3F67 S31A0010163B050002FF01001EAF06001A7F040002FF00001AA00151 S31A00101650001AA100000CAF18000E68FE000CAF89000CAF5B0013 S31A001016650CAF4C000CAF5D000CAF4E00397FDC00037EFF00031B S31A0010167A7DFF00037CFF00037BFF000370FF000371FF0003786E S31A0010168FFF000379FF00397FDA0016AF08001B1801001B5900AF S31A001016A4000CAF80000CAF91000CAF18000E68FE000CAF890009 S31A001016B90370FF000371FF000378FF000379FF00397FD6001688 S31A001016CEAF04001ACE090002DE09001ADD080002DD08001ADC88 S31A001016E3070002DC07001ADB060002DB06001AA001001AA1009C S31A001016F8000CAF18000E68FE000CAF89001EAC01001EAB0000A8 S31A0010170D0CAF5D000CAF4E00397FDC00037EFF00037DFF0003FA S31A001017227CFF00037BFF000370FF000371FF000378FF000379C9 S31A00101737FF00397FDA0016AF08001B1801001B5900000CAF8046 S31A0010174C000CAF91000CAF18000E68FE000CAF89000370FF0029 S31A001017610371FF000378FF000379FF00397FD60016AF04001A84 S31A00101776CE0D0002DE0D001ADD0C0002DD0C001ADC0B0002DCB3 S31A0010178B0B001ADB0A0002DB0A001B1F010002DF01001B5F00AB S31A001017A00002DF00001AAF0100037FFF001AAF0000037FFF00A8 S31A001017B50CAF5D000CAF4E00397FD80016AF02001ACE030002A4 S31A001017CADE03001ADD020002DD02001AAF0100037FFF001AAF25 S31A001017DF0000037FFF001EAE03001EAD0200397FD80016AF026B S31A001017F4001ACE050002DE05001ADD040002DD040016AF020053 S31A00101809397FAC0023FFFF00397FAD000CAFC2000CAFB3000CD3 S31A0010181EAFE4000CAFD5001AAF06001ABF07001ABF08001ABF13 S31A00101833090032F9EE001AAC05001AAB040033F9BD001AAE0D16 S31A00101848001AAD0C001AAC0B001AAB0A000EAFFE00397FCD00C2 S31A0010185D0CAFE0000CAFD1000CAFC8000CAFB9000CAF4C001A21 S31A001018723C03000CAF5B001A7B02000CAFCD000CAFBC000EAFA3 S31A00101887FE00397FD2000370FF000371FF000378FF000379FFD4 S31A0010189C00397FD90016AF04000CAFE0000CAFD1000CAFC8001D S31A001018B10CAFB9001AAE09001AAD08001AAC07001AAB06000E52 S31A001018C6AFFE00397FCD00037EFF00037DFF00037CFF00037BCA S31A001018DBFF000CAF9B000CAF8C000CAF1D000CAF0E00397FD518 S31A001018F00016AF0400397FD1000CAFEC001ACC05000CAFDB0053 S31A001019051ADB0400397FAC0023FFFF00397FA90016AFFE000C09 S31A0010191AAFC8000CAFB9000CAFE2000CAFD3000EA1BD000EA072 S31A0010192F760018AE17000EADFF000EAC17000EABFC00397FDD65 S31A001019440002FD000002FE01000CAF9B000CAF8C000CAF3D00E3 S31A001019590CAF2E003A7FBE0016AF0200397FA80023FFFF003982 S31A0010196E7FA9003AF98900397FA80023FFFF0000FFD3000EA069 S31A00101983CF000EA17F000EBB7F0002CB000023FFFF00397FA9A5 S31A00101998000E2A20000EFADF0032F999000EA06F000EA17F00D6 S31A001019AD18AB01000EBBEF0002CB01003AFF180004AED70004E7 S31A001019C2ADD80004ACD90004ABD9000E6BFE00397FA80023FF6B S31A001019D7FF00397FA9000EBB7F0001BBD3000E2A20000EFADF6F S31A001019EC0032F986000EA06F000EA17F0018AB01000EBBEF0058 S31A00101A0102CB01003AFF180004AED70004ADD80004ACD90004FC S31A00101A16ABD9000E6BFE00397FA80023FFFF00397FAD0016AFFF S31A00101A2BFD000CAFC4000CAFB50002FD02000E1DFF0032F961ED S31A00101A40000EA1BF000EA0E7001805080032F96A001814090089 S31A00101A5531F9660018A40B0018A50A0033F92D000EAFFB000235 S31A00101A6AFF00000CAF1B000CAF0C0033F932000EAFEC0002FFAD S31A00101A7F00000EAF770002FF01000EAC9F000EABFF000CAF5DDD S31A00101A94000CAF4E003A7FBE000CCC44000CDB5500041499009E S31A00101AA90CAFFC0004AB9A000C7B5B000EA1BF000EA0FF0018FD S31A00101ABEAE17000E4E000018AD16000E5D800004AF99000E4F6D S31A00101AD3000002FF010004AF9A000E5F800002FF00003A7FBE34 S31A00101AE8000EA1BF000EA0FF0018AE170018AD16000CC4CF0061 S31A00101AFD02FF01000CD5BF0002FF00000CAFDB000CAFEC000CD2 S31A00101B12AF5D000CAF4E003A7FBE000CAFC4000CAFB5000EAF70 S31A00101B27FB0002FF00000EABBF000EACF1000CAF5D000CAF4E53 S31A00101B3C003A7FBC000CAFC4000CAFB5000EA1BE000EA03700C8 S31A00101B5118AB01000E2BFE001E1B020032F922000EABFE000E21 S31A00101B66ACAD000CAF5D000CAF4E003A7FA6001EAC02000EABF6 S31A00101B7BFF000CAFC0000EC0F4000CAFB1000ED1BF0018AC0035 S31A00101B90000CAFCB000E6BFE000CCC44000CDB55000CAF5B00BF S31A00101BA50CAF4C0016AF0300397FAC0023FFFF00397FAD001646 S31A00101BBAAFD4000CAFC4000CAFB5000E1DFF0036F9050004AF7D S31A00101BCFBF000E2F040001BFBF0000FFB5000EAFFF0002EF0308 S31A00101BE40033F86F001CAF030032F864000EA1FE000EA09C00E9 S31A00101BF918AF02001C3F050002FF2B0018AF01001C7F04000203 S31A00101C0EFF2A000EA1BE000EA05C0018A80C000EA9FF0003780E S31A00101C23FF000379FF000EAEEF000EADF100397FD80016AF026E S31A00101C38001EAC2B001EAB2A00397FDC000CAFDE000CAFCD00E4 S31A00101C4D0CAFBC000E6BFE000EA3FF000EA21C001AAC0900181B S31A00101C62CC0B001AAB080018DB0A00180B000032F8E100181C54 S31A00101C77010035F86F00180D060032F8DD00181E070031F86F9E S31A00101C8C001D1F010002EF01001D5F000002EF00001CA20100D2 S31A00101CA11CA300000C139F0032F8D3000C128F0035F864001E42 S31A00101CB6AC2B001EAB2A00180B080032F8CD00181C090034F8AE S31A00101CCB6F001D1F020002EF02000E1FFD0032F86D000EAFFED2 S31A00101CE00002EF030018AF0D000E1F000032F8C00004AFBF0088 S31A00101CF50EBF7F0001BFBF0018AF0F000E1F000032F8BA00040E S31A00101D0AAFBF000EBFBF0001BFBF000EA1BF000EA0BD000EA3AB S31A00101D1FFF000EA21C001AAF0800037FFF001AA2090016A301FD S31A00101D34001813030032F8AE001812040036F8A5000EAFBF0001 S31A00101D4902FF00000EAFBA0002FF01000EACFD000EABFF000E78 S31A00101D5EADFF000EAE14003AFDBB000CAF6C000ECCFD000D5F82 S31A00101D737B000EADFE003AE59B000EA1FE000EA04D000EAFFFF3 S31A00101D880002CF040002CF05003AC2A70004AFBF000EBFFB00A8 S31A00101D9D01BFBF000EA1FF000EA01C0018AB34000E2BBF000E27 S31A00101DB21BFF0036F88C000CAF6C000ECCFD000D5F7B000EAD92 S31A00101DC7FC0033F888000CAF6C000ECCFD000D5F7B000EADFEA4 S31A00101DDC003AE3130004AFBF000EBFFB0001BFBF000EA1BE0086 S31A00101DF10EA0370018AB01000E2BEF000E1BFF0036F86D000E25 S31A00101E06A3FE000EA287000EA1FF000EA01C001AAC18001AABBE S31A00101E1B1700180B1C0032F87500181C1D0031F86D0018AF1CDD S31A00101E300002DF170018AF1D0002DF180033F86D000EAFFF005E S31A00101E4502EF02000EAFFF0002EF000002EF01000EA1FE000E25 S31A00101E5AA09C0018AF010002EF040018AF020002EF050016AFE0 S31A00101E6F2C00397FAC0023FFFF00397FAD0016AFF7000CAF6C4F S31A00101E84000ECCFD000D5F7B000EADFE003AF912000EAFFF00BB S31A00101E9902FF080004AF620032F845000EA1BF000EA0BD0018A0 S31A00101EAEA40A0018A509000CAF5B000CAF4C003AC414003AE745 S31A00101EC3E0000CAFCB0004AFD20002FF000004AFD10002FF0182 S31A00101ED8000CAF5C000CAF4D000EAEF7003AC8B6000EA5BF00E3 S31A00101EED0EA4AE000CAF6C000ECCFD000D5F7B000EADFF003A91 S31A00101F02F912001FBF080002FF08000E1F000032F837000EAF6F S31A00101F17FB0002FF08003AC564001CAC41001CCC43001CAB40FD S31A00101F2C001CDB42000EA1FE000EA0D80018AF2400037FFF00B2 S31A00101F4118A0250016A101000C01BF0032F82A000C10CF0034A1 S31A00101F56F818001CAC68000EABFF000EA1FF000EA01C0018AF29 S31A00101F6B2A00037FFF0018A02B0016A101000C11BF0032F81EE1 S31A00101F80000C10CF0034F818003AEFA9000EA1FF000EA0470092 S31A00101F950EAFFF0002CF15003AEE850004AFA3000E1FFD00361C S31A00101FAAF843000EA3FF000EA21C001AAB34000E2BBF000E1B3B S31A00101FBFFF0032F804000EA1BF000EA0AE0018AC1E0018CC6BCF S31A00101FD40018AB1D0018DB6A001A0B080032F805001A1C09000A S31A00101FE935F8010004AFBF000EBFFD0001BFBF0016AF090039DD S31A00101FFE7FAC0023FFFF00397FAD0016AFAA0004AFB50032F707 S31A00102013F0000CAF6C000ECCD1000D5F7B000EADFE003AE59B86 S31A00102028000CAF6C000ECCD1000D5F7B000EADFB003AE31300EE S31A0010203D3AF51A000CAF6C000ECCFD000D5F7B000EADFE003A57 S31A00102052F6B1000CAF6C000ECCE1000D5F7B003AF05F0004AFB7 S31A00102067620032F7D3000EA1BF000EA0BD0018A40A0018A5098B S31A0010207C000CAF5B000CAF4C003AC414003AE7E0000CAFCB0083 S31A0010209104AFD20002FF000004AFD10002FF01000CAF5C000CF5 S31A001020A6AF4D000EAEF7003AC8B6000CAF6C000ECCFD000D5F3E S31A001020BB7B000EADFF003AF6B1000E1CFF0036F7C5000CAF6CA2 S31A001020D0000ECCFD000D5F7B000CAF6E000ECEE1000D5F7D0058 S31A001020E53AF2F7000CAF6C000ECCE1000D5F7B000EADFF003AF0 S31A001020FAF4C7003AF4AB0000FE60000EA5FF003AEFE1000C1CE5 S31A0010210F5F0036F7B3003AF5C50000FE61000EA1FF000EA04770 S31A00102124001815150032F7B3000EA5FE000EA3FF000EA247001A S31A001021391AAF160036F7AC000EA5FE000EAFFF0002DF16000E51 S31A0010214E15FF0036F7890004AF620032F788000EA1FF000EA07A S31A00102163470018AC110018AB10003AC414000EA3FF000EA247A9 S31A00102178001AAF150032F799000EA1BF000EA0AE0018AB00000F S31A0010218D1AAE11001AAD100033F792000EA3BF000EA2AE001AD3 S31A001021A2AB69000EA1FF000EA0470018AE110018AD100004AFFC S31A001021B7D20002FF000004AFD10002FF01000CAFDC000CAFED65 S31A001021CC000EAEFF003AC8B60033F788003AC39F003AEE85007A S31A001021E13AF502000EA3BF000EA2AE001AAC2E000EABFF001A0E S31A001021F6CC41001ADB40000EA1FF000EA01C0018AF0800037FB3 S31A0010220BFF0018A0090016A101000C01BF0032F777000C10CFD9 S31A001022200030F76F000EA3FF000EA21C000CAF31000CAF2000BA S31A0010223518AF34000EBFEF0002DF340004AFA3000E1F010036F8 S31A0010224AF7D3003AF45A003AF756000EA1FF000EA0470018AF26 S31A0010225F140032F760000EA1BF000EA0BD0018AB02000E2BFCE4 S31A00102274000E1BFD0036F75B000CAF6C000ECCE1000D5F7B00C8 S31A001022890EADFE003AF4C7000EABFA003AC5D90016AF5600399D S31A0010229E7FAC0023FFFF00397FAD0016AFF9000EA1FF000EA04A S31A001022B31C0018AB01000E2BFE000E1BFF0036F6B4000EA3BF71 S31A001022C8000EA2BD001AAB02000E2BFC000E1BFD0032F6B40080 S31A001022DD0EA1BE000EA0370018AB03000E2B7F000E1BFF0036A8 S31A001022F2F6B4000EA1FE000EA0870018AF100032F6B40018ACBE S31A00102307090018AB08003AE1900002FB050002FC06000EA3BFB6 S31A0010231C000EA2AE001AA43D000EA5FF000EA1FE000EA08700A9 S31A0010233118AC070018AB06003A7FC0000CAFCE000CAFBD000C67 S31A00102346AF5B000CAF4C003A7FB6001EA206001EA305000C1341 S31A0010235BBF0032F726000C12CF0031F6B4000EAFFC0002FF00C7 S31A00102370000CAF6C000ECCFD000D5F7B000EADBF000EAEBD006A S31A001023853A7FE0000EA1FE000EA0870018AE0B0018AD0A000E04 S31A0010239AABFE000EAC4F003AC2F8000CAFC4000CAFB5000EA3D2 S31A001023AFBF000EA2AE001AAC28000EABFF000EAEFF000EADBF0B S31A001023C4003A7FB9000C15BF0032F70A000C14CF0030F7030050 S31A001023D90EA1FF000EA01C0018AB34000E2BEF000E1BFF0036E4 S31A001023EEF6DE000EA3BF000EA2AE001AAC2D000EABFF000EA1C8 S31A00102403FE000EA0870018AF1100037FFF0018A0120016A101A0 S31A00102418000C11BF0032F6F6000C10CF0035F6DE000EA1BD003F S31A0010242D0EA076001AAC3F000EABFF0018AE0D0018AD0C0039C6 S31A001024427FDC000CAFDE000CAFCD000CAFBC000E6BFE000EA354 S31A00102457FE000EA287001A0D060032F6E5001A1E070030F6DEA8 S31A0010246C000EABFE000EAC7B003A7FA0003AE12C0002FB0200BA S31A0010248102FC03000EA5BF000EA4BD001EAC03001EAB02001C9A S31A001024961B000032F6D6001C1C010036F6B4000CBCBF0036F636 S31A001024ABB8000CAF6C000ECCFD000D5F7B003AE0A7000EA1FEFB S31A001024C0000EA087000EAFFE0002CF100004AF620032F6B4002F S31A001024D51CAF0900037FFF001CA40A0016A501000CAF5B000CDF S31A001024EAAF4C003AC414003AE7E0000CAFCB0004AFD20002FFAD S31A001024FF000004AFD10002FF01000CAF5C000CAF4D000EAEFF52 S31A00102514003AC8B60033F6B4000EABFE000EAC7D000EADF60068 S31A001025293A7FB20016AF0700397FAC0023FFFF00397FAD001650 S31A0010253EAFF8000CAFC4000CAFB5000EAFFF0002FF00000E1DF4 S31A00102553FF0036F69A000EADE3003A7FB2000EABFE000EACA975 S31A00102568003A7FA50002EB180002EC19000EA1BF000EA0AE0014 S31A0010257D18AE030018AD02000CAF5B000CAF4C003AF48B00339A S31A00102592F5CA000CAF5B000CAF4C003AF4350002FC03000EAB25 S31A001025A7FE000EACA9003A7FA5000CAFCE000CAFBD000CAFDCB2 S31A001025BC000E6CFE000CAFCB001CCE100002EE10001CDD0F00F4 S31A001025D102ED0F001CDC0E0002EC0E001CDB0D0002EB0D001DC4 S31A001025E61F110002EF11001CAC11000EABFF000CAFCE000CAFC3 S31A001025FBBD000CAFDC000E6CFE000CAFCB00037EFF00037DFF64 S31A0010261000037CFF00037BFF001CAE10001CAD0F001CAC0E001C S31A001026251CAB0D00397FD60016AF04000CAFE8000CAFD9000C1C S31A0010263AAFCE000CAFBD0002F9010002F802001CAF1A001CBFC8 S31A0010264F1B0036F666001DBF1B0002EF1B001DFF1A0002EF1A6F S31A00102664000CAF4C000ECCF2000D5F5B000CAF9D000CAF8E0010 S31A001026793AF482000E1CFF0032F62F000EA3BF000EA2AE001C1C S31A0010268EAF11001A1F070035F600000EA1BE000EA01F00199C07 S31A001026A3010019CB00001CAE19001CAD18000C0DBF0032F65013 S31A001026B8000C1ECF0030F64C001AAE05001AAD040033F64A0081 S31A001026CD1AAE03001AAD02000CAF5B000CAF4C003AF48B001E5A S31A001026E2AF010002EF18001EAF020002EF19001CAF0D0002EF72 S31A001026F712001CAF0E0002EF13001CAF0F0002EF14001CAF100F S31A0010270C0002EF15001CAF110002EF17000EAFFF0002EF1600F5 S31A001027210EAFFF0002EF11000EAFFF0002EF0D0002EF0E000214 S31A00102736EF0F0002EF100033F5CA001CA017001CA116000E11C2 S31A0010274B000032F62A000E10FF0030F607001CAF15001CCF10EC S31A001027600002EF15001CAF14001CDF0F0002EF14001CAF13007C S31A001027751CDF0E0002EF13001CAF12001CDF0D0002EF12001C28 S31A0010278AAC11000EABFF000CC0CF0002EF17000CD1BF0002EF7F S31A0010279F16001CAE17001CAD16000EACFF000EABFF00037EFF48 S31A001027B400037DFF00037CFF00037BFF001CAE15001CAD1400C4 S31A001027C91CAC13001CAB1200397FD60016AF040002ED180002D1 S31A001027DEEE19000EAFFF0002EF11000EAFFF0002EF0D0002EF60 S31A001027F30E0002EF0F0002EF10001CAF1A001CBF1B0032F5CAE0 S31A00102808001EAF030036F5CA000CAF40000EC0F2000D5F510068 S31A0010281D0EA3BF000EA2AE001AAC08000EABFF000CAFCE000CA7 S31A00102832AFBD000CAFDC000E6CFE000CAFCB00037EFF00037D7A S31A00102847FF00037CFF00037BFF001CAE08001CAD07001CAC06FC S31A0010285C001CAB0500397FD60016AF010002FF070016AF010063 S31A0010287102FF070016AF010002FF070016AF010002FF07000C8C S31A00102886AFE8000CAFD9000CAFCE000CAFBD000CAF1B000CAF6A S31A0010289B0C000CAF9D000CAF8E003AF482000E1CFF0036F5CA97 S31A001028B0000EA1BF000EA0AE0018AE050018AD04000CAF5B0089 S31A001028C50CAF4C003AF48B000EAFFE0002FF00001EAC00000E94 S31A001028DAABFF0016AF0800397FAC0023FFFF000374FF000375E9 S31A001028EFFF000EA1FF000EA0470018AC0F0018AB0E000EFB7FF0 S31A001029040036F5BB000EACFF000EABFF00191F120002CF120024 S31A0010291936F5AA00183C1100187B100018AE12000EADFF000321 S31A0010292E7EFF00037DFF000CAFCE000CAFBD00397FD80016AF2C S31A00102943020018CE110002CE110018DD100002CD10000EA5BF39 S31A00102958000EA4BD000EA3BF000EA2AE001CAC0A001ACC6300FC S31A0010296D1CAB09001ADB620018AE110018AD10000C0DBF003262 S31A00102982F59D000C1ECF0030F592001CAC0A001A3C63001CAB96 S31A0010299709001A7B620018AE110018AD10000C0DBF0032F593D7 S31A001029AC000C1ECF0031F5900002CB100002CC11000EA1BF0027 S31A001029C10EA0AE0018AF540018BF550036F57F000EA3FF000EE0 S31A001029D6A247001AAC11001AAB1000180B540032F58400181CEB S31A001029EB550034F57F0018AF540002DF100018AF550002DF11AA S31A00102A00000EA1BF000EA0AE0018AF56000EFF7F0032F56E00A3 S31A00102A150EA3FF000EA247001AAE11001AAD1000180D56003292 S31A00102A2AF57300181E570031F56E0018AF560002DF100018AF23 S31A00102A3F570002DF11000EACFF000EABFF000CCCCC000CDBBB6C S31A00102A54000CAFC0000EC047000CAFB1000ED1FF000EAFFE00C2 S31A00102A6902CF0F000EAF7F0002CF0E0016A5010016A4010023AD S31A00102A7EFFFF00397FAD000CAFC4000CAFB5000EA3FF000EA27B S31A00102A9347001AAF08001ABF09001ABF0A001ABF0B0036F52FFD S31A00102AA8000E1DFF0032F5500004AFA3000E1F010032F52F0088 S31A00102ABD1AAF0B00037FFF001AAF0A00037FFF001AAF09000370 S31A00102AD27FFF001AAF0800037FFF001AAE07001AAD06001AACA7 S31A00102AE705001AAB0400397FD60016AF040002ED020002EE03BB S31A00102AFC001AAF0B00037FFF001AAF0A00037FFF001AAF090034 S31A00102B11037FFF001AAF0800037FFF001AAE03001AAD02001A18 S31A00102B26AC01001AAB0000397FD60016AF040002ED000002EEDC S31A00102B3B010033F525000EA1BF000EA0BD0018AF050002EF008B S31A00102B500018AF060002EF010018AF070002EF020018AF08000B S31A00102B6502EF0300397FAC0023FFFF000EA1FE000EA057001901 S31A00102B7A8C02000D9FFB000CBBCB000EEBFD000CAFBC000EAB43 S31A00102B8FFF0023FFFF00397FA90004AFBF000E2F040001BFBF68 S31A00102BA40000FFB5000EA1FF000EA01C0018AF34000E2F100092 S31A00102BB902CF34000EABFF000EAC47000EADE8003A7FB2000E17 S31A00102BCEA3FF000EA247000EA1BF000EA0BD0018AF090002DFB9 S31A00102BE3100018AF0A0002DF1100397FA80023FFFF000374FFFD S31A00102BF8000375FF000EA3FF000EA247000EA5FF000EA41C0014 S31A00102C0D1D9C15001DCB14000EA1BE000EA01F00180B0400323F S31A00102C22F4F500181C050035F4CD001CAE15001CAD14000CAFF8 S31A00102C37DC000E6CFE000CAFCB001ACE030002DE03001ADD02D1 S31A00102C4C0002DD02001ADC010002DC01001ADB000002DB0000D4 S31A00102C611CAE41001CAD40000CAFDC000E6CFE000CAFCB001A85 S31A00102C76CE070002DE07001ADD060002DD06001ADC050002DCBC S31A00102C8B05001ADB040002DB04001B1F0B0002DF0B001B5F0A8A S31A00102CA00002DF0A001B5F090002DF09001B5F080002DF080046 S31A00102CB51B1F0D0002DF0D001B5F0C0002DF0C0033F4CA000E4D S31A00102CCAAFFF0002DF0C0002DF0D0016A5010016A4010023FFBD S31A00102CDFFF00397FAD0016AFFC0002FD03000EAFFF0002FF01E5 S31A00102CF40002FF02000EA5FF000EA447001CAF13000E2F0800E4 S31A00102D0902EF13000D1F6E000D5F7D001EAF030002FF00003A0D S31A00102D1EF01B000E1CFF0036F4AE001EAC02001EAB01001EAD1D S31A00102D3303003AF3E5001CAF13000EBFF70002EF130016AF04F1 S31A00102D4800397FAC0023FFFF00397FAD000EA1BF000EA0AE00AC S31A00102D5D0EA3FF000EA247001AAF0C00037FFF001AA20D00166F S31A00102D72A301001813020032F49F001812030035F48D000EA10E S31A00102D87FE000EA0D80018A4250018A524000EABFE000EACABBF S31A00102D9C003A7FA5000C4C4C000C5B5B000EA1FF000EA04700A5 S31A00102DB1180B0E0032F49000181C0F0034F48D0002CB0E00023B S31A00102DC6CC0F00397FAC0023FFFF000CAFC0000CAFB100181D66 S31A00102DDB1A0032F48600181E1B0034F4830002CD1A0002CE1B37 S31A00102DF00023FFFF00397FAD0016AFFC000CAFC4000CAFB50082 S31A00102E051C1E0C000CAFFC001CAB0B000C7BDB003A7FC00002F6 S31A00102E1AFB000002FC01000EA1BF000EA0AE0018AF060002FFFB S31A00102E2F03000EAFFF0002FF02001CAC0C001CAB0B003A7FC097 S31A00102E44000CAFCE000CAFBD001EAC03001EAB02003A7FB6005B S31A00102E590EAEFF000EADFF001EA001001EA100000C11BF00324D S31A00102E6EF462000C10CF0030F45F000EAEFE000EADFF000CAF46 S31A00102E83DB000CAFEC0016AF0400397FAC0023FFFF00397FA9F3 S31A00102E980016AFF4003AF523000E1CFF0036F438000CAF6C0052 S31A00102EAD0ECCFD000D5F7B000EADFE003AF55F000EA1FF000E39 S31A00102EC2A0470018AF100002FF060018AF110002FF070004AF8D S31A00102ED7CE0002FF080004AFCD0002FF090004AFCC0002FF0AE5 S31A00102EEC0004AFCB0002FF0B000EAFBF0002FF00000EAFB8003F S31A00102F0102FF01000EACF5000EABFF000CAF6E000ECEFD000D2D S31A00102F165F7D003AFDBB0016AF0C00397FA80023FFFF00397FB8 S31A00102F2BAD000CAFC4000CAFB5000EA1BF000EA0AE001CAF004A S31A00102F4000181F080032F42B000EADF2003A7FB2001D1F000082 S31A00102F5502EF00000EABFE000EACAB003A7FA5000CAFCE000C51 S31A00102F6AAFBD000CAFDC000E6CFE000CAFCB001CCE040002EE5D S31A00102F7F04001CDD030002ED03001CDC020002EC02001CDB0153 S31A00102F940002EB01000EA1BE000EA0370018AB03000E2BFB00D8 S31A00102FA90E1BFF0036F410000EABFE000EACA40033F40E000E43 S31A00102FBEABFE000EACA9003A7FA5000CAFCE000CAFBD000CAFC2 S31A00102FD3DC000E6CFE000CAFCB001CCE080002EE08001CDD070F S31A00102FE80002ED07001CDC060002EC06001CDB050002EB0500E8 S31A00102FFD0EABFE000EACA7003A7FA5000CAFCE000CAFBD000C26 S31A00103012AFDC000E6CFE000CAFCB001CCE0C0002EE0C001CDD1F S31A001030270B0002ED0B001CDC0A0002EC0A001CDB090002EB0989 S31A0010303C000EACFF000EABFF000EA1BF000EA0AE001CAF000063 S31A00103051181F080032F3E7000EACFE000EABFF00397FAC002312 S31A00103066FFFF00397FAD0016AFD40002FB230002FC240002FD02 S31A0010307B25003AC2B4000CAFC0000CAFB10018AF00000E1FFA80 S31A001030900032F3D6000CAF0E000ECEBF000D5F1D0033F3D30034 S31A001030A53AC2C1000CAFCE000CAFBD000EABDF000CAF62000E7F S31A001030BAC2FC000D5F73000CAFE0000CAFD10010AF0100035F05 S31A001030CF01000DBFBB0032F3CD000EA1FE000EA0570018AC00E6 S31A001030E4000EABFF000CCCCC000CDBBB000CCCE0000CDBD10053 S31A001030F918AF020002FF260018AF030002FF27000EA1FF000E0E S31A0010310EA01C0018AB01000E2BFB000E1BFF0032F2FA000EA1ED S31A00103123BF000EA0BD0018AB02000E2BFC000E1BFD0032F354BE S31A00103138000EA5BF000EA4AE001CA215001CA314000CAF200019 S31A0010314D0CAF31000EA8FF000EA9FF001EAE27001EAD26000C10 S31A00103162AFDC000E6CFE000CAFCB00037EFF00037DFF00037C3B S31A00103177FF00037BFF000370FF000371FF000378FF000379FFD7 S31A0010318C00397FDA0016AF08000CAFE0000CAFD1000CAFC8000F S31A001031A10CAFB9000E4217000E53FC0002F22B0002F32A000E7F S31A001031B6AFFF0002FF280002FF29001EAE24001EAD23000CAF54 S31A001031CBDC000E6CFE000CAFCB00037EFF00037DFF00037CFF82 S31A001031E000037BFF001EAF2F00037FFF001EAF2F00037FFF004D S31A001031F51EAF2F00037FFF001EAF2F00037FFF00397FDA00160D S31A0010320AAF08000CCE00000CDD11000CDC88000CDB99000EAF61 S31A0010321F1700037FFF000EAFFC00037FFF000EAFFF00037FFF75 S31A00103234000EAFFF00037FFF000CAF9B000CAF8C000CAF1D00BD S31A001032490CAF0E00397FD60016AF04000CAFDB000CAFEC001EDF S31A0010325EAE27001CCE5B001EAD26001CDD5A000C0BDF0032F3CC S31A0010327361000C1CEF0030F358001EAE27001C3E5B001EAD26A4 S31A00103288001C7D5A000C0BDF0032F359000C1CEF0031F3560023 S31A0010329D0CAFDB000CAFEC0002FB230002FC24000CAF6C000E52 S31A001032B2CCFA000D5F7B000CAF6E000ECEDC000D5F7D001EAFAD S31A001032C7260002FF00001EAF270002FF01000EA3FE000EA25709 S31A001032DC001AAF000002FF02003AC618000E1CFF0036F307008A S31A001032F10EA1FE000EA0570018AF02000E1F000032F32E000CAB S31A00103306AF02000CAF13001AAF000002CF01000CAF6C000ECC81 S31A0010331BFA000D5F7B001EAE24001EAD23001EAF260002FF00D4 S31A00103330001EAF270002FF01001AAF000002FF02003AC64C0064 S31A001033450EA1FE000EA0570018AF00000E1FF10032F322001E61 S31A0010335AAF250032F322000EA1FF000EA01C0018AF01000EBF20 S31A0010336FFB0002CF01001EAF23000EFF7F0032F302001EAF23D3 S31A00103384001EBF240036F302000CAF6C000ECCFC000D5F7B000E S31A001033993AC5BB0004AFC90036F3020004ACCF0004ABD0001E8C S31A001033AEAF230002FF00001EAF240002FF01001EAE27001EAD70 S31A001033C326003A7FBE0001BBD00001BCCF003AEF6A0001BBD209 S31A001033D80001BCD10033F302000EA1FF000EA01C0018AF0100D4 S31A001033ED0EBFFB0002CF01000EA3FE000EA257000CAF31000C6D S31A00103402AF200018AF000002DF02001B1F000002CF000016AF56 S31A001034172C00397FAC0023FFFF00397FAD0016AFD00002FB06DC S31A0010342C0002FC070002FD080002FE09000EA1FE000EA05700AE S31A0010344119BF000002FF0A000EA3BF000EA2AE001AAC08000ED3 S31A00103456ABFF000CAFC0000CAFB1000CAF18000E68FE000CAFB8 S31A0010346B89001EA207001EA306000370FF000371FF000378FFC0 S31A00103480000379FF001AAE08001AAD07001AAC06001AAB050072 S31A00103495397FD60016AF010002FF1A0016AF010002FF1A0016A6 S31A001034AAAF010002FF1A0016AF010002FF1A0002FB130002FC3D S31A001034BF140002FD150002FE16001EAF150002FF0D001EAF16D1 S31A001034D40002FF0E000370FF000371FF000378FF000379FF00E4 S31A001034E91AAE0C001AAD0B001AAC0A001AAB0900397FD60016D0 S31A001034FEAF010002FF220016AF010002FF220016AF010002FF20 S31A00103513220016AF010002FF220002FB1B0002FC1C0002FD1D34 S31A001035280002FE1E001EAF1D0002FF0F001EAF1E0002FF100064 S31A0010353D0370FF000371FF000378FF000379FF001AAE04001AA3 S31A00103552AD03001AAC02001AAB0100397FD60016AF040002FBBC S31A00103567230002FC240002FD250002FE26001EAF250002FF0BAC S31A0010357C001EAF260002FF0C001EAC16001EAB15003A7FC000ED S31A001035910CAFC8000CAFB9000EA1BD000EA076000EA3BF000E0A S31A001035A6A2AE001AAF2C00037FFF001AAF2B00037FFF0018AEF9 S31A001035BB0D0018AD0C00397FD70016AF02000C19DF0032F28AFF S31A001035D0000C18EF0030F1D1001AAE03001AAD02000EACFF007E S31A001035E50EABFF000EA1FE000EA0870018AF2200037FFF00189F S31A001035FAAF2100037FFF0018AF2000037FFF0018AF1F00037F85 S31A0010360FFF001E1B000032F274001E1C010032F274001E1D02B0 S31A001036240032F274001E1E030016AF040030F1D1001EAF150007 S31A0010363902FF00001EAF160002FF01001EAC26001EAB25001E84 S31A0010364EAE1E001EAD1D003AC4F20002FB020002FC03000EA3FC S31A00103663FF000EA21C001AAB01000E2BFC000E1BFC0032F1D15D S31A00103678000EA1FE000EA0870018AE070018AD06000EABFE00F6 S31A0010368D0EAC4F003AC2F8000CAFC4000CAFB5000EA3BF000EA8 S31A001036A2A2AE001AAC27000EABFF000EAEFF000EADBF003A7F1A S31A001036B7B9000C15BF0032F24E000C14CF0030F243000EA1BF1B S31A001036CC000EA0AE0018AF290018BF2A0036F1D1001EAC26009E S31A001036E11EAB25003AEF8C000E1CFF0036F1D1000CAF6C000EC5 S31A001036F6CCFD000D5F7B000EA3BF000EA2AE001AAD3B003AE00F S31A0010370BC8000E1CFF0036F1D1000EA1BF000EA0AE0018AC3BE1 S31A00103720000EABFF000EA3BD000EA276001AAE0D001AAD0C008A S31A001037353A7FB9000EA1FE000EA0870018AF0600037FFF0018AF S31A0010374AA0070016A101000C01BF0032F228000C10CF0035F1CC S31A0010375FD1000EA3FF000EA21C001AAF14000EFF7F0036F1D191 S31A00103774001EAC1E001EAB1D003AEF7C000E1CFF0036F1D10096 S31A001037890EA1FE000EA0870018AC070018AB06003A7FC0000C1A S31A0010379EAFC4000CAFB5000EA3FE000EA257001EAC03001A3C44 S31A001037B309001EAB02001A7B08003A7FC0000CAFC8000CAFB90A S31A001037C8000CAF4E000CAF5D000CAFDC000E6CFE000CAFCB0020 S31A001037DD0EECBF000CAFFB000EEDBF000CAFFC000CBBDB000E31 S31A001037F2EEBF000CAFFD000CBCEC000EAEFF000CAF80000CAFE2 S31A0010380791000CAF18000E68FE000CAF89000370FF000371FF95 S31A0010381C000378FF000379FF00397FD60016AF04000CAFE80092 S31A001038310CAFD9000CAFCE000CAFBD000EA1FE000EA087000CE9 S31A00103846AF02000CAF13001B1F120002CF12001B5F110002CF4D S31A0010385B11001AAF0D001ABF0E0032F1E20002D90D0002D80E9F S31A001038700033F1D7000EA1BF000EA0AE0018AF260002FF010079 S31A001038850EAFFF0002FF00000EABFE000EAC7B000CAF9D000C0B S31A0010389AAF8E003AFAAB000EA1FE000EA0870018AF060002CF67 S31A001038AF0A0018AF070002CF0B001EA207001EA306001AA008EA S31A001038C4001AA107001AA806001AA905000D0F9B000D4F8C00E8 S31A001038D90D4F1D000D4F0E000E6BFB000CAFBE000E6BFD000C72 S31A001038EEAFBC000CAFBD000EEBFD000CAFBE000EADFF000EACE9 S31A00103903FF000EABFF000CCE00000CDD11000CDC88000CDB991E S31A00103918000D0F9B000D4F8C000D4F1D000D4F0E000EA0EF0065 S31A0010392D0EA1F1000EA8FF000EA9FF000370FF000371FF00037C S31A0010394278FF000379FF00397FD60016AF04000EA1FE000EA0B6 S31A00103957870018CE010018DD00000EABFE000EAC51003AC2F82C S31A0010396C001EA209001EA3080002DB0E0002DC0F001EAC0E00EE S31A001039811EAB0D001EAE0C001EAD0B003AEF5A000E1CFF0036B5 S31A00103996F062001EA009001EA1080018AC0F0018AB0E001EAEB6 S31A001039AB10001EAD0F003AC4D0001E4C0C001E5B0B001EAE0E65 S31A001039C0001EAD0D003AC41E0002FB110002FC12000EA3BF005A S31A001039D50EA2AE000CAFCF001A3F5D0002FF12000CAFBF001A82 S31A001039EA7F5C0002FF11000EA1BE000EA0370018AB02000E2B75 S31A001039FFFE000E1BFF0036F0DB001AAE03001AAD02000EACFF29 S31A00103A14000EABFF000EA3FE000EA287001AAF2200037FFF007D S31A00103A291AAF2100037FFF001AAF2000037FFF001AAF1F0003B2 S31A00103A3E7FFF001E1B000032F168001E1C010032F168001E1D1A S31A00103A53020032F168001E1E030016AF040030F0DB001EA009F1 S31A00103A68001EA1080018AC0F0018AB0E000EAFFF0002FF00000B S31A00103A7D1EAE10001EAD0F003AC49E0002FB000002FC01001EB2 S31A00103A92AC12001EAB11000EAE17000EADFC003A7FBE000CAFB5 S31A00103AA7C4000CAFB5000EF57F0032F1500004AFCA0036F10522 S31A00103ABC001EAF0D0002FF00001EAF0E0002FF01001EAC0C0051 S31A00103AD11EAB0B001EAE10001EAD0F003AC4F2000CBCBF003693 S31A00103AE6F105000EA1FE000EA05700183C0700187B06000EA16A S31A00103AFBBF000EA0BD0018AE010018AD0000397FDC000ECDDF9C S31A00103B10000D5FCC000D5FBB000EEDFB000EECFB000CBFDE0097 S31A00103B250E6BFB000CBFCD000CAFBC000E6BFD0002FB27000256 S31A00103B3AFC280002FD290002FE2A000EA3FE000EA287001EAF37 S31A00103B4F290002DF00001EAF2A0002DF01000EA1BD000EA076D8 S31A00103B640018A8010018A9000018AE17000EADFF000EAC17004C S31A00103B790EABFC00397FDD0002FD000002FE01001EAC2A001EC5 S31A00103B8EAB29000CAF9D000CAF8E003A7FBE000EA1FE000EA0C5 S31A00103BA3870002CB020002CC03000EA1FF000EA01C0018AF0190 S31A00103BB8000EBFFB0002CF01003AEFA90000FECA000EF57F002C S31A00103BCD36F105000EA1FF000EA047000EAFFE0002CF16000E4E S31A00103BE2A417000EA5FC000EA3BF000EA2AE001AAC41001ACC93 S31A00103BF743001AAB40001ADB42001EAE0C001EAD0B000C0DBF9E S31A00103C0C0032F0FA000C1ECF0035F0EF000EA1FF000EA01C00EC S31A00103C211AAC68000EABFF0018AE2B0018AD2A000C1DBF003298 S31A00103C36F0F0000C1ECF0030F0DB001EA00C001EA10B001A01E0 S31A00103C4B400032F0EA001A10410035F0DB000EA1FF000EA047F4 S31A00103C60000EAFFE0002CF15000EAFFE0002CF160000FEC9002F S31A00103C750CAF5B000CAF4C003AEF6A0001BBD20001BCD1000157 S31A00103C8AB5D00001B4CF001EAB0A003AC37B001EA209001EA331 S31A00103C9F08001A1C0F0002FF2C001A5B0E0002FB2B000EA1BF67 S31A00103CB4000EA0AE0018AF0F0002FF2E000EAFFF0002FF2D009A S31A00103CC91F1B0A003AC37B000CAFC4000CAFB5001EAB0A003A18 S31A00103CDEC37B000C4C4E000C5B5D001EAC2E001EAB2D003A7F6C S31A00103CF3B9001EAE2C001EAD2B000C0DBF0032F0BD000C1ECF4F S31A00103D080035F062000EA1FE000EA0870018AF26000E1F00000D S31A00103D1D32F0B50018AF270002CF26001EA009001EA108001819 S31A00103D32AF0E0002FF040018AF0F0002FF05000CAF6C000ECCC7 S31A00103D47FB000D5F7B003AC22F0002FC2F000EA5FF000EA41C97 S31A00103D5C001CAC07001CAB06003AC2B1001EAE2F000EADFF003E S31A00103D710CCEEE000CDDDD000CCECC000CDDBB001EAE05001E60 S31A00103D86AD04003AC245001CA807001CA906000D9FCE000DCF34 S31A00103D9BBD000CAF9B000CAF8C003AC431000CAFE0000CAFD14D S31A00103DB0000CAFC8000CAFB9001EAD12001EAC11000EAFFE007E S31A00103DC5397FD2000370FF000371FF000378FF000379FF003936 S31A00103DDA7FD90016AF0400397FCF000CAFE0000CAFD1000CAF34 S31A00103DEFC8000CAFB9000E09FF0032F07B000E18FF0032F07BF8 S31A00103E04000E11800032F07B000E10000034F075000EAF800063 S31A00103E1902FF11000EAF000002FF120033F06D000EF97F003650 S31A00103E2EF06F001CAF01000EBFFB0002EF010033F0620002F10C S31A00103E43110002F012001EA209001EA308001AAE0F001AAD0E01 S31A00103E58001EAF110002FF00001EAF120002FF01000CAF3B0089 S31A00103E6D0CAF2C003AFA7A0016AF3000397FAC0023FFFF0039E2 S31A00103E827FA9000EADF1003A7FB2000EABFE000EAC57003AF0E4 S31A00103E9752000EA1FE000EA087000EAF000002CF260002CC2723 S31A00103EAC00397FA80023FFFF00397FAD000CAFC4000CAFB50016 S31A00103EC13AC161003AC3380002EC01000D1FCF0002EF00000E5C S31A00103ED6AF000002EF02001CAC00000EABFF00397FAC0023FF19 S31A00103EEBFF00397FAD0016AFDE003AC2B4000CAFC4000CAFB506 S31A00103F00001CAB00001CAF01000E1FAA0032F01E000E1BFF00C4 S31A00103F1536F01E000E1B000036F01E000E1BFA0036F01E000E5B S31A00103F2AABDF000CAF62000EC2FD000D5F73000CAF40000EC050 S31A00103F3FBF000D5F510010AF0100035F01000DBFBB0032F02EE1 S31A00103F54000EAF000002FF02000EAFAA0002FF030002F5000020 S31A00103F6902F401000EACDF000EABFF000CAF6E000ECEFD000DD6 S31A00103F7E5F7D003AFDBB0016AF2200397FAC0023FFFF00397F26 S31A00103F93AD0016AFFB0002FB000002FC010002FD020002FE0396 S31A00103FA8001EAB09000EAFFF0002FF04000EA5FE000EA45700A1 S31A00103FBD0E1BFF0032F00A001CAB00003AEFA3000E1CFF003693 S31A00103FD2EFE6001EA001001EA1000018AF0000037FFF0018A071 S31A00103FE7010016A101000E01FF0032F001000E10FE0034EFEC9A S31A00103FFC000EA1FF000EA01C0018AB01000E2BFA000E1BFE0004 S31A0010401132EFEC001CAB00003AC37B000CAFCE000CAFBD001E19 S31A00104026AC01001EAB00003AF9FB001EA003001EA1020002CB7C S31A0010403B000002CC01000EAFFE0002FF040033EFEA001D1F0083 S31A001040500002EF00001EAC01001EAB00000EADF1003A7FB200A9 S31A001040651EAC04000EABFF0016AF0500397FAC0023FFFF000358 S31A0010407A74FF000375FF000EA5FE000EA457000EA3FE000EA218 S31A0010408F87001CAF00001A1F270034EFBA000EA1BF000EA0AEAD S31A001040A40018AE030018AD02000EACFF000EABFF001AAF220005 S31A001040B9037FFF001AAF2100037FFF001AAF2000037FFF001A6C S31A001040CEAF1F00037FFF001E1B000032EFC3001E1C010032EFFF S31A001040E3C3001E1D020032EFC3001E1E030016AF040030EFBAED S31A001040F8000EA1FF000EA0470018AF13000EBFFD0002CF130072 S31A0010410D1CAF000002DF27000EA1FF000EA0470018AB13000E2D S31A001041222BF5000E1BFD0032EFAF0018AF13000E2F020002CF72 S31A0010413713000EABFE0033EFAE000EABFF000CAFBC000EABFFDC S31A0010414C0016A5010016A4010023FFFF0000FCD2000017D100FA S31A0010416100FCD0000017CF0000FFC90023FFFF00397FAD00161D S31A00104176AFFE0002FB00000EAFFF0002FF01000E1BF10030EF7D S31A0010418B91003AC161000CAFC4000CAFB5001EAB00003AC37BEC S31A001041A0000C05BF0032EF94000C14CF0035EF91000EAFFE0010 S31A001041B502FF01001EAC01000EABFF0016AF0200397FAC00230C S31A001041CAFFFF000EA1BF000EA0AE0018AE410018CE2A0018AD26 S31A001041DF400018DD29000C0BDF0032EF83000C1CEF0035EF7F03 S31A001041F4000EACFF000EABFF0033EF7D000EACFE000EABFF0020 S31A0010420923FFFF000ECCAB000EDB0A000EA1BF000EA0AE00180F S31A0010421E0B210032EF7500181C220030EF6D00180B230032EF6A S31A001042337100181C240035EF6D000EACFE000EABFF0033EF6B09 S31A00104248000EACFF000EABFF0023FFFF000EA1BF000EA0AE00EF S31A0010425D180B640032EF6500181C650034EF610018AC650018CB S31A00104272AB640033EF5B00180B660032EF5E00181C670031EFD2 S31A001042875B0018AC670018AB660023FFFF00397FAD0016AFFD15 S31A0010429C0002FD000002FE01000EAFFF0002FF02003A7FC000BF S31A001042B10CAFC8000CAFB9000EA1BD000EA076000EA5BF000EDB S31A001042C6A4AE001CAF0E00037FFF001CAF0D00037FFF0018AE02 S31A001042DB0D0018AD0C00397FD80016AF02000C09DF0032EF422C S31A001042F0000C18EF0034EF3F000EAFFE0002FF02003AC1610014 S31A001043050EA1FF000EA01C0018AE070018AD06003AC4D0001E91 S31A0010431A3C01001E7B00001C0B160032EF34001C1C170034EF9E S31A0010432F31000EAFFE0002FF02001EAC02000EABFF0016AF0328 S31A0010434400397FAC0023FFFF00397FA90016AFFF000EAFEB00FC S31A0010435902FF00000EABFF000EAC30000EADBD000EAEFB003A2D S31A0010436E7FE00016AF0100397FA80023FFFF00397FAD000EA566 S31A00104383FF000EA41C001CAB01000E2BFE000E1BFF0036EEF205 S31A00104398001CAC07000ECCAB001CAB06000EDB0A000EADFF002C S31A001043AD3AEEC7001CAC09001CAB08000EADFE003AEEC7001C92 S31A001043C2AC15001CAB14000EADFD003AEEC7000EA1BE000EA072 S31A001043D7370018AB03000E2BFD000E1BFF0036EEFE000EA1FF90 S31A001043EC000EA030000EA22F000EA37F001AAB010018BF0E000E S31A0010440102CF0E000EA3FF000EA230000EA1BD000EA0FB001AF2 S31A00104416AF0E00181F0E0036EEF20004AFC80004BFC70032EE3E S31A0010442BF20000FFC80000FEC700397FAC0023FFFF00397FA902 S31A001044400004AFC80004BFC70036EEDF000EA1BD000EA0FB0034 S31A0010445504ACC70004ABC8000D1FCF0001BFC7000D5FBF0001A0 S31A0010446ABFC800181B120032EEE100181C130035EEDF003AEEE9 S31A0010447FDD00397FA80023FFFF00397FA90016AFFE0000FFC8C9 S31A001044940000FFC7000EA1FF000EA03000191F0D0002CF0D0088 S31A001044A9195F0C0002CF0C000EAFBD0002FF00000EAFFB000252 S31A001044BEFF01000EACEB000EABFF000CAF1D000CAF0E003AFD9E S31A001044D3BB0016AF0200397FA80023FFFF00397FAD0016AFFF92 S31A001044E8000CAFC2000CAFB3000EAFFF0002FF00000CAFDE0068 S31A001044FD0EADFF000CAFE0000EC0FB000CAFD1000ED1BD001836 S31A00104512A80F000EA9FF000EEEFB00037FFF000EEDFB000CBFD8 S31A00104527ED0016AE01000CAFE0000EC030000CAFD1000ED1FFB4 S31A0010453C000CAFE4000EC4FB000CAFD5000ED5BD00180300009D S31A0010455132EEA9001812010034EEA10002C3000002C201000CF2 S31A00104566AF2C001C3C01000CAF3B001C7B000033EE9700180396 S31A0010457B020032EE9E001812030031EE910002C3020002C203EA S31A00104590001C1203000CAFFC001CAB02000C7B3B000C0B9F00D7 S31A001045A532EE94000C1C8F0034EE91000EAFFE0002FF00001EF3 S31A001045BAAF000036EE8A0004AFC80004BFC70032EE8A0000FFCB S31A001045CFC80000FEC7001EAC00000EABFF0016AF0100397FAC88 S31A001045E40023FFFF00397FAD0016AFFE003AE700000EA5FF0090 S31A001045F90EA41C000EA1FE000EA04D001CAC0700183C03001CDF S31A0010460EAB0600187B02003A7FC0000EA1BE000EA05C00180B28 S31A00104623110032EE7400181C120034EE450004AF620032EE45A0 S31A001046380004AFA30032EE6B001CAF34000EBFFE0002EF340087 S31A0010464D33EE450004AFA3000E1F010032EE56000EA5FF000E22 S31A00104662A447001CAC11001CAB10003AC414000EA1BF000EA064 S31A00104677AE0018AB00001CAE11001CAD100004AFD20002FF006D S31A0010468C0004AFD10002FF01000CAFDC000CAFED000EAEFF0083 S31A001046A133EE46000EA1BF000EA0BD0018A40A0018A509000C16 S31A001046B6AF5B000CAF4C003AC414003AE7E0000CAFCB0004AF7C S31A001046CBD20002FF000004AFD10002FF01000CAF5C000CAF4D4C S31A001046E0000EAEF7003AC8B60004AF610036EE400004AF6200B7 S31A001046F532EE40003AC6F8000E2A20000EFADF0032EE40000E95 S31A0010470AA3FF000EA21C001AAB34000E2BFB000E1BFF0036EE9D S31A0010471F2F000EA09F000EA17F0018AB00000EBBFA0002CB0072 S31A00104734001AAF34000E2F040002DF34003AFF180000FF620055 S31A001047490EA09F000EA17F0018AB00000EBBFA0002CB00003A3D S31A0010475EE699000CAFCB000E6BFE003AE6C7003AE6F9003ACCAE S31A00104773320016AF0200397FAC0023FFFF00397FAD000EA1FE8B S31A00104788000EA0870018AC180018AB17000EA5FF000EA41C009B S31A0010479D1CAE1D001CAD1C003AE7D7000CAFC8000CAFB9000E28 S31A001047B2ABFE000EACFC000CAF9D000CAF8E003AFB06000EA1F2 S31A001047C7BE000EA0370018AB01000E2BFB000E1BFF0036EE00E0 S31A001047DC001CAC1D001C3C21001CAB1C001C7B20000EFB7F0032 S31A001047F132EDF6000CBCBF0036EDF60018AB01000E2BFD000EE0 S31A001048061BFF0036EDE8001CAF20000EFF7F0032EDF6001CAF0B S31A0010481B20001CBF210032EDE8000EA5FF000EA41C001CAE21E4 S31A00104830001CAD20000EABFE000EACFA003AFB06001CAE1D00E7 S31A001048451CAD1C000EABFF000EAC04003AFB060000FE930033EE S31A0010485AED6A0004AF900032EDDD000EA1FE000EA0AB0018AFD0 S31A0010486F02000EFF7F0032EDDE0018AF020018BF030032ED9041 S31A001048840033EDC90004AF920036EDD6000EA1FF000EA01C006A S31A0010489918A8210018A9200033EDC3000EA1FF000EA01C0018BF S31A001048AEAC230018AB2200180B200032EDCF00181C210034ED84 S31A001048C3C7000CAFC8000438B9000CAFB9000479BA0033EDC3FD S31A001048D8000EA1FF000EA01C0018A8230004C8B90018A92200F2 S31A001048ED04D9BA000EF97F0032EDB9000EA1FE000EA0870018B1 S31A00104902AF17000EFF7F0032EDB90018AF170018BF180032ED74 S31A00104917B7000EA8FF000EA9FF000EABFE000EACFA000CAF9D90 S31A0010492C000CAF8E003AFB060004AF900036ED6A0004AF9100C8 S31A0010494136EDA7000EA1FF000EA01C0018AE1D0018AD1C000E37 S31A00104956ABFF000EAC04003AFB06000EA1FF000EA01C0018AC57 S31A0010496B190018AB1800180B1C0032EDA000181C1D0034ED9B22 S31A0010498000059FB90001BFB90005CFBA0001BFBA0018AC190051 S31A0010499518AB1800181B1C0032ED9500181C1D0036ED6A000C2F S31A001049AAAFCE0004CEB9000CAFBD0004DDBA0033ED6D000EA587 S31A001049BFFF000EA41C0018AE06000CAFED000E6DFE001CCE2306 S31A001049D4001CDD22000EABFE000EACFA003AFB06001CA819001A S31A001049E91C3823001CA918001C7922000EF97F0032ED71000C76 S31A001049FEB89F0036ED71001CAC1D001C3C21001CAB1C001C7BCB S31A00104A1320000EFB7F0032ED71000CBCBF0036ED71001CAE1942 S31A00104A2800043EB9001CAD1800047DBA0033ED6D000EA1FF0011 S31A00104A3D0EA01C0018AE230018AD22000EABFF000EAC04003A04 S31A00104A52FB06000EA1BE000EA0370018AB03000E2BEF000E1BCF S31A00104A67FF0036ED5A000EA5FF000EA41C001CAE19001CAD1864 S31A00104A7C000EABFF000EAC0A003AFB06001CA823001CA922008A S31A00104A9133ED51000EA5FF000EA41C001CAE1D001CAD1C000E2F S31A00104AA6ABFF000EAC0A003AFB06001CA821001CA920000EA3C1 S31A00104ABBFF000EA21C001AAE13000ECE9C001B5D12000EAF9BD0 S31A00104AD000037FFF000EAFFF00037FFF00397FD80016AF0200A6 S31A00104AE51A4E13001A5D12000EA1BE000EA0370018AB01000E7E S31A00104AFA2BF7000E1BFF0036ED2C000CB89F0032ED2C001AAF81 S31A00104B0F10000EFF7F0032ED2C001AAF10001ABF110036ED2C82 S31A00104B24000EA1BF000EA0AE001AAC09001AAB0800180B40009D S31A00104B3932ED2F00181C410034ED2C000EA8FE000EA9FF000EC9 S31A00104B4EA1BE000EA0370018AB00000E2BF7000E1BFF0036EDBA S31A00104B6314000C09DF0032ED23000C18EF0035ED14000EA1FFE6 S31A00104B78000EA01C0018AC2B0018AB2A000E1BFF0032ED1B000A S31A00104B8D0E1C9C0030ED140004ABBF000E2BFB000E1BFF00320A S31A00104BA2ED14000CAFE8000CAFD9000EABFF000EAC0C000CAF77 S31A00104BB79D000CAF8E003AFB06000EA1FF000EA01C0018AC2155 S31A00104BCC0018CC0F0018AB200018DB0E000CAFCE00183E1D00EB S31A00104BE10CAFBD00187D1C000EFD7F0036ECFE000EABFF000E10 S31A00104BF6AC10000EAEFF000EADFF0033ECFC000EABFF000EACD6 S31A00104C0B10003AFB0600397FAC0023FFFF00397FAD0016AFFD87 S31A00104C200004ABFF000E2BEF000E1BFF0036ECEC000EA0EF00C0 S31A00104C350EA17F0018AB03000E2B7F000E1BFF0032ECE6003349 S31A00104C4AECD4000EA0DF000EA17F0018AB03000E2B7F000E1B1D S31A00104C5FFF0036ECD40004ACC6000EABFF000ECCFD000D5FBB09 S31A00104C74000EA1BE000EA02C0018AE04000EADFF000C0BDF0054 S31A00104C8932ECDB000C1CEF0035ECD7000EAFFE0002FF02003307 S31A00104C9EECD100051FC60001BFC60033ECD30000FFC6000EAF4A S31A00104CB3FF0002FF02000EA1FF000EA01C0018AB00000E2BF36D S31A00104CC8000E1BFF0036ECBA000EA0BF000EA17F0018AB00005F S31A00104CDD0E2BFD000E1BFF0036ECBA003AEB5A000E2CFE000CAF S31A00104CF2AFCB000EEBF7000CAFFB0004AFBF000E2F080001BF00 S31A00104D07BF000CBFBF0001BFBF0033EC8C000EA5FF000EA41C8E S31A00104D1C001CAC15001CAB14003A7FC0000EA1BE000EA02C00F4 S31A00104D31180B020032ECB000181C030030EC8C0004ABBF000E09 S31A00104D462BF7000E1BFF0032EC8C001CAC07000ECCAB001CAB33 S31A00104D5B06000EDB0A00180B070032ECA400181C080030EC8C64 S31A00104D7000180B050032ECA000181C060035EC8C001CAF14006C S31A00104D851CBF150036EC8C0004AFB60032EC8C001CAF00000E79 S31A00104D9ABFF70002EF00003AEB5A000E2CFE000CAFCB000EEB11 S31A00104DAFF7000CAFFB0004AFBF000E2F080001BFBF000CBFBF6C S31A00104DC40001BFBF00005FB6001EAF020032EC870004AFBF004A S31A00104DD90E2F080001BFBF000EA1BF000EA0FF0004ACA100047B S31A00104DEEABA200181B080032EC7F00181C090036EC70000EA1F7 S31A00104E03FF000EA01C0018AB00000E2BEF000E1BFF0032EC701A S31A00104E18000EAFBF0002FF00000EAFF70002FF01000EACFD0085 S31A00104E2D0EABFF000EADFF000EAEA2003AFDBB000EACFF000ED1 S31A00104E42ABFF0016AF0300397FAC0023FFFF00397FAD0016AF24 S31A00104E57FA000EA1FF000EA01C0018AF100002FF010018AF110D S31A00104E6C0002FF020018AE130018AD12000EFD7F0032EC5D0063 S31A00104E810CBEDF0032EC5B000EA5FF0033EC55000EAFFE000201 S31A00104E96FF00001EAC02001EAB01003A7FB7000CAFC5000CAFB1 S31A00104EAB5D000EABFE000EACF2000CAFDE000E6DFE003AFB06CF S31A00104EC0000EA1FF000EA01C0018AF1C000EFF7F0032EC47007B S31A00104ED518AF1C0018BF1D0032EC42000EABFF000EAC18000EE3 S31A00104EEAAEFF000EADFF0033EC370018AC210018AB200018AE52 S31A00104EFF1D0018AD1C000EAFFE0002FF00003A7FB7000CAFCED5 S31A00104F14000CAFBD000EABFF000EAC18003AFB06000EA1BE00C8 S31A00104F290EA05C0018AF0D000E1F000036EC2B0018050D0035A6 S31A00104F3EEC2B0004AFBF000EBF7F0001BFBF0033EC24000EA102 S31A00104F53BE000EA05C0018050E0030EC240004AFBF000E2F80D1 S31A00104F680001BFBF000EA1BE000EA05C0018AF0F000E1F000025 S31A00104F7D36EC190018050F0035EC190004AFBF000EBFBF000169 S31A00104F92BFBF0033EC12000EA1BE000EA05C001805100030EC85 S31A00104FA7120004AFBF000E2F400001BFBF000EA1BD000EA076CF S31A00104FBC0018AF180002FF030018AF190002FF040018A41B002B S31A00104FD118A51A000EA1BE000EA0370018AF03000E2FFE000285 S31A00104FE6FF05000E1FFF0036EBF9000EABFE000EACF8003A7F34 S31A00104FFBA50002FB030002FC04000EABFE000EACF6003A7FA51F S31A00105010000CAFC4000CAFB50004AF580036EBAC001EAC0400E0 S31A001050251EAB0300041BC50032EBB000041CC40032EBB000042E S31A0010503A15C30032EBB0000414C20032EBB0001EAC02001EAB6A S31A0010504F01001E0B030032EBE8001E1C040030EBD6001EAF0503 S31A001050640036EBDA000EA1FF000EA01C0018AF14000EFF7F0047 S31A0010507936EBD6000EABFF000EAC11000EADFB003A7FA4003A45 S31A0010508EFAF70033EBD6000EABFF000EAC11000EADFB003A7F20 S31A001050A3A4001EAC02001EAB01000C0B5F0032EBD1000C1C4FCD S31A001050B80035EBAC000EA1BE000EA0370018AB03000E2BFE00B2 S31A001050CD0E1BFF0036EBB0000EA1FF000EA01C0018AF14000E5E S31A001050E2FF7F0032EBAC0018AF140018BF150036EBAC0004AF15 S31A001050F7B80032EBAC0018AB0B000E2BFB000E1BFF0036EBB70B S31A0010510C000EABFF000EAC11000EADFB003A7FA30033EBB30012 S31A001051210EABFF000EAC11000EADFB003A7FA4003AFAF70000A2 S31A00105136FEB80033EBAC000EABFF000EAC11000EADFB003A7FDC S31A0010514BA3001EAF030001BFC5001EAF040001BFC40001B5C373 S31A001051600001B4C20004AF580036EB8F000EA1BD000EA0760062 S31A001051751EAC02001EAB0100180B1C0032EB9D00181C1D0030FF S31A0010518AEB980004AFBF000EBFEF0001BFBF0033EB8F001EAC53 S31A0010519F02001EAB0100180B1E0032EB9300181C1F0035EB8F26 S31A001051B40004AFBF000E2F100001BFBF0000FE580004ABBF00CE S31A001051C90E2B7F000E1BFF0032EB7B000EA1FF000EA01C0018B3 S31A001051DEAB0A000E2BF7000E1BFF0032EB7B0018AB1B000E2BEA S31A001051F3F7000E1BFF0032EB7B000EABFF000EAC11000EADF7A5 S31A00105208003A7FA40033EB77000EABFF000EAC11000EADF70054 S31A0010521D3A7FA30004ABBF000E2BBF000E1BFF0036EB6E000EDF S31A00105232ABFF000EAC12000EADFD003A7FA40033EB6A000EAB85 S31A00105247FF000EAC12000EADFD003A7FA30004ABBF000E2BEFC7 S31A0010525C000E1BFF0036EB61000EABFF000EAC11000EADFD0042 S31A001052713A7FA40033EB5D000EABFF000EAC11000EADFD003AC5 S31A001052867FA30016AF0600397FAC0023FFFF00397FAD0016AF61 S31A0010529BF8000EA5FF000EA41C001CAB00000E2BF3000E1BFB59 S31A001052B00036EB4E000EA0BF000EA17F000EAFFC0002CF00003F S31A001052C51CAF080002FF05001CAF090002FF06003AFF18001C9D S31A001052DAAB00000E2BEF000E1BFF0036EB37000EACFE000EABE5 S31A001052EFFF000EAFFE0002FF070033EB31000EABFF000EAC1CF5 S31A00105304000EADFB003A7FA3000EABFF000EAC1C000EADF7002C S31A001053193A7FA30033EB0D000EA1BF000EA0FF0018AC360018B5 S31A0010532EAB35000EAFFF0002FF07000EAFFF0002FF030002FFEF S31A0010534304000CAFC4000CAFB5000CB45F0036EB0D000EA09FB2 S31A00105358000EA17F0018AB00000EBBFA0002CB00003AFF180058 S31A0010536D0EA1FF000EA01C001EAC0600183C09001EAB0500188A S31A001053827B08003A7FC0000EA1BF000EA0FF00180B400032EB69 S31A001053971800181C410030EB40001EAF0400043FDC0002FF040E S31A001053AC001EAF0300047FDD0002FF03000DBF44000DFF550031 S31A001053C10CB45F0032EB2A000EA0BF000EA17F000EAFFD000204 S31A001053D6CF00001EAF070036EAFE000EA1BF000EA0FF001EAC06 S31A001053EB04001EAB030018AE360018AD3500397FDD0002FD033A S31A001054000002FE04000CB45F0032EAC6000EA1FF000EA01C0004 S31A0010541518AB00000E2BF3000E1BFB0036EAF1001EAF03000177 S31A0010542ABFA2001EAF040001BFA10033EAE4001EAF0400043FAF S31A0010543FA10002FF02000CAF6E000ECEFD000D5F7D000EAFBF37 S31A001054540002FF00000EAFF50002FF01000EACFE000EABFF0008 S31A001054693AFDBB000EA1FF000EA01C0018AB00000E2BF7000EAD S31A0010547E1BFF0036EADA000CAF1B000CAF0C000EADF70033EA83 S31A00105493D30018AB00000E2BFB000E1BFF0036EAD2000CAF1B34 S31A001054A8000CAF0C000EADFB003A7FA3000EA1FF000EA01C0088 S31A001054BD18AF080001BFA00018AF090001BF9F0018AF06000198 S31A001054D2BF9E0018AF070001BF9D000EACFE0033EAC5000EACD3 S31A001054E7FF000EA09F000EA17F0018AB00000EBBFA0002CB00CD S31A001054FC000EABFF0016AF0800397FAC0023FFFF00397FAD0016 S31A0010551116AFFF000EFADF000CAFFB0002FB00000E2A20000EAB S31A00105526FADF0032EAB70004AFC00036EAB00005BFC00001BF27 S31A0010553BC0001EAB00000CBABA0004ABDF000E2BEF000E1BFF5E S31A001055500036EAA6000EABE8000EAC3C000EADFE003AFF0500DC S31A001055650EA1FE000EA08700191F220002CF2200195F21000251 S31A0010557ACF2100195F200002CF2000195F1F0002CF1F00191FCE S31A0010558F230002CF2300191F2D0002CF2D00195F2C0002CF2CD6 S31A001055A400195F2B0002CF2B00195F2A0002CF2A0018AF2300B6 S31A001055B90E1F1F0034EA6500191F250002CF2500195F24000207 S31A001055CECF240018AF23000ECFE00002CF23000EABFE000EACB3 S31A001055E37F003A7FB4000EABFE000EAC83003A7FB40004AFB6E7 S31A001055F80036EA7E0005BFB60001BFB6000EA1FE000EA0870018 S31A0010560D18AC050018AB04003AE190000CAFC4000CAFB5000E3A S31A00105622A1BF000EA0AE0018AC10000EABFF000EA1BD000EA0FB S31A00105637760018AE0D0018AD0C003A7FB9000C15BF0032EA6B55 S31A0010564C000C14CF0035EA65000EA1FF000EA01C0018AF010080 S31A001056610EBFFB0002CF01003AEA3A000EA1FF000EA0120018A0 S31A00105676AB00000E2BCF0018AC01000E2CEB000CBCBF0032EAC9 S31A0010568B55000EA1FF000EA0020018AC01000E2CC3000EABFFC7 S31A001056A0000CBCBF0036EA49000EA1BE000EA0370018AB0300D7 S31A001056B50E2BFE000E1BFF0032EA3E0018AB00000E2BEF000E18 S31A001056CA1BFF0036EA3E003AFAF70033EA3E000EA1BE000EA09C S31A001056DF370018AB03000E2BFE000E1BFF0032EA3E0018AB0027 S31A001056F4000E2BEF000E1BFF0036EA3E003AFADC003AEEF000B5 S31A0010570916AF0100397FAC0023FFFF00397FAD0016AFF9000EF9 S31A0010571EFADF000CAFFB0002FB02000EA1FF000EA01C0018AF93 S31A0010573307000ECFAB0002FF040018AF06000EDF0A0002FF03EF S31A00105748000E2A20000EFADF0032EA2D0004AFA3000E1FFD002E S31A0010575D32EA00000EA1BE000EA05C000EA5F500186513000C4A S31A00105772AFF4001EAC04001EAB03000C0B5F0032EA1D000C1CF8 S31A001057874F0035EA13000EABF500186B17000CAFFC001EAE04A7 S31A0010579C001EAD03000C0DBF0032EA14000C1ECF0034E9CB002B S31A001057B10EABFF000EAC11000EAD7F003A7FA4000EA1FF000EF7 S31A001057C6A01C000EAFFF0002CF300002CF31000EAFFF0002CFB0 S31A001057DB2E0002CF2F001EAC04001EAB03000C0B5F0032EA0247 S31A001057F0000C1C4F0035E9DA0033E9CF000EA5BE000EA45C00B5 S31A001058050EADF5001C6D13000CAFFE0002FD050002FE06001E4B S31A0010581AA004001EA103000C01DF0032E9F4000C10EF0035E9D9 S31A0010582FEC000EABF5001C6B16000CAFFC000C01BF0032E9ED8C S31A00105844000C10CF0034E9CB000EABFF000EAC12000EADF70030 S31A001058593A7FA4000EA1FF000EA01C000EAFFF0002CF30000290 S31A0010586ECF31000EAFFF0002CF2E0002CF2F001EAC04001EABBD S31A0010588303001E0B050032E9DB001E1C060031E9D80000FFB7EB S31A001058980033E92A000EABF5001C6B17000CAFFC001EAE0400CC S31A001058AD1EAD03000C0DBF0032E9D0000C1ECF0034E9CD00005C S31A001058C2FAB70033E92A0000FBB70033E92A0004AFB7000E1F35 S31A001058D7FD0032E9BD000EA1BE000EA05A0018A413000CAF458D S31A001058EC000E65FE000EA1BE000EA05B0018A813000CAF890093 S31A001059010E69FE0033E9820004AFB7000E1FFD0034E99A000419 S31A00105916AFB7000E1FFA0032E9B4000EA433000EA5F30033E963 S31A0010592BAB0004ACB7000EABFF000CAFC0000EC05C000CAFB176 S31A00105940000ED1BE0018A413000CAF45000E65FE0004ACB700F8 S31A001059550EABFF000EA3BE000EA25C000CAFC0000EC05D000C42 S31A0010596AAFB1000ED1BE0018AE13000CAFED000E6DFE001AAC55 S31A0010597F18000CAFCB000E6BFE000C4CE8000C5BD90033E982CA S31A00105994000EA3BE000EA25C0004A8B7000EA9FF000CC2800006 S31A001059A90CD3910018AE13000CAFED000E6DFE001AAC18000C7F S31A001059BEAFCB000E6BFE000CCCE4000CDBD50004AFB70032E9D0 S31A001059D387000EA8FF000EA9FF0033E982000CC280000CD3915B S31A001059E80018A812000CAF89000E69FE000CAF5B000CAF4C00EC S31A001059FD0EAEF5000EADFF00397FDD001EA004001EA103000CEF S31A00105A1201DF0032E978000C10EF0034E97400051FB70001BFBF S31A00105A27B70033E967000CAF9B000CAF8C000EAEF5000EADFF12 S31A00105A3C00397FDD001EAC04001EAB03000C0BDF0032E96A0095 S31A00105A510C1CEF0031E9670005BFB70001BFB70004AFB7000E28 S31A00105A661FFA0034E9630000FAB70004AFB70036E92A0004AF65 S31A00105A7BB7000E1FFB0030E95A000EABFF000EAC11000EAD7FF1 S31A00105A90003A7FA30004AFB7000E1FFC0030E953000EABFF00D8 S31A00105AA50EAC12000EADF7003A7FA3000EA5FF000EA41C001C60 S31A00105ABAAB0A000E2BF7000E1BFF0032E92A001CAB0B000E2B64 S31A00105ACF7F000E1BFF0032E92A000EADBE000EAE5C0004ACB7C8 S31A00105AE4000EABFF000DBFCC000DFFBB000CCCCC000CDBBB003A S31A00105AF90CCEC0000CDDB10018AF190002EF2E0018AF1A00026C S31A00105B0EEF2F0004ACB7000EABFF000CCEC0000CDDB10018AC37 S31A00105B2320000EABFF000EA1BD000EA0760018AE0D0018AD0C4B S31A00105B38000EAFFF0002FF00000EAF9B0002FF01003A7FBE00B4 S31A00105B4D02EB300002EC31000EA1FF000EA01C0018AB0A000E9E S31A00105B622BFD000E1BFF0036E91E000EAFFF0002CF300002CFFD S31A00105B7731000EAFFF0002CF2E0002CF2F001EAB02000CBABACC S31A00105B8C0016AF0700397FAC0023FFFF00397FAD0016AFFB0078 S31A00105BA10CAFB50002FC04000EABFF000EAC1A003A7FA5000E6F S31A00105BB615FC0036E8E7000E05FC0030E907000E15FE0036E840 S31A00105BCBAE000E05FE0030E8F5000E15FF0036E9000033E8AED9 S31A00105BE0000E15FA0036E8BE000E05FA0035E8D9000E15F90082 S31A00105BF536E8B90033E8AE000EA1BF000EA0BD0018AF0500023E S31A00105C0AFF000018AF060002FF010018AF070002FF020018AF09 S31A00105C1F080002FF030033E8AA000EA5FF000EA41C001CAC152C S31A00105C34001CAB14001CAE09001CAD08003AF9BB0002FB0200D9 S31A00105C4902FC03001CAF140002FF00001CAF150002FF0100333A S31A00105C5EE8AA000EA5FF000EA41C001CAC39001CAB38001CAE3F S31A00105C7309001CAD08003AF9BB0002FB020002FC03001CAF383B S31A00105C880002FF00001CAF390002FF010033E8AA000EA1BD00B9 S31A00105C9D0EA0760018AE0D0018AD0C000EAFFA00037FFF000ECE S31A00105CB2AFFF00037FFF00397FD80016AF02000D9FEF0002FFA5 S31A00105CC701000DCFDF0002FF000018AE0F0018AD0E000EAFFA96 S31A00105CDC00037FFF000EAFFF00037FFF00397FD80016AF020088 S31A00105CF10D9FEF0002FF03000DCFDF0002FF020033E8AA000264 S31A00105D06FB000002FC010002FB020002FC030033E8AA000EA104 S31A00105D1BBF000EA0AE0018AF490002FF000018AF4A0002FF011E S31A00105D300018AF4B0002FF020018AF4C0002FF030033E8AA0057 S31A00105D450CAF7B000CAF6C000EADFF003AF55F001EAF04003687 S31A00105D5AE873000EA5BF000EA4AE001CAF580036E891001EAC55 S31A00105D6F03001EAB02003A7FC0000CAFC8000CAFB9000EA3BD5D S31A00105D84000EA276001CA058000EA1FF000370FF000371FF0027 S31A00105D991AAE0F001AAD0E00397FD80016AF02000C09DF0032B6 S31A00105DAEE892000C18EF0030E87A000EA5BF000EA4AE001CAF0E S31A00105DC3590036E876001EAC03001EAB02003A7FC0000CAFC834 S31A00105DD8000CAFB9000EA3BD000EA276001CA059000EA1FF00D5 S31A00105DED0370FF000371FF001AAE0F001AAD0E00397FD8001654 S31A00105E02AF02000C09DF0032E87B000C18EF0031E876000D9FED S31A00105E17EF0002FF03000DCFDF0002FF02001EAC03001EAB0217 S31A00105E2C0033E83F000EA5BF000EA4AE001CAF580036E85C0082 S31A00105E411EAC01001EAB00003A7FC0000CAFC8000CAFB9000E24 S31A00105E56A3BD000EA276001CA058000EA1FF000370FF000371F3 S31A00105E6BFF001AAE0D001AAD0C00397FD80016AF02000C09DF1A S31A00105E800032E85D000C18EF0030E845000EA5BF000EA4AE003E S31A00105E951CAF590036E841001EAC01001EAB00003A7FC0000C46 S31A00105EAAAFC8000CAFB9000EA3BD000EA276001CA059000EA18A S31A00105EBFFF000370FF000371FF001AAE0D001AAD0C00397FD89C S31A00105ED40016AF02000C09DF0032E846000C18EF0031E841001B S31A00105EE90D9FEF0002FF01000DCFDF0002FF00001EAC01001E4C S31A00105EFEAB000016AF0500397FAC0023FFFF00397FA90016AF59 S31A00105F1301000EA09F000EA17F0018AB00000EBBFA0002CB0094 S31A00105F280000FDB70004AFDF0032E82E003AE785003AE73700C2 S31A00105F3D0EABFF0033E8250004ABDF000E2BEF000E1BFF00362D S31A00105F52E8240004AFDF000E2F100001BFDF003AEF2C000EAB8C S31A00105F67FE003AE630003AF044000EA1BE000EA0370018AB023C S31A00105F7C000E2BFB000E1BFF0036E810000EA1BF000EA03A001A S31A00105F9118AB00000EACFF000E1BFB0032E810000E1CFF0032C0 S31A00105FA6E810000EA1FF000EA01C0018AF34000EBFBF0002CF08 S31A00105FBB34000EABFF003AE7CC0004AFA3000E1FFD0032E80642 S31A00105FD0000EABFF003AE63E003AF861000EABFD0033E80F001D S31A00105FE504AFA3000E1F010032E7FE000EABFE003AE63E003AA7 S31A00105FFAF7FE000EAB010033E80F000EABFF003AE63E003AE172 S31A0010600FA80033E81000397FA80023FFFF00397FA90016AFFFED S31A00106024000EA1FF000EA01C0018AC390018AB38000EAFFF0025 S31A0010603902FF00000EAEC3000EADFF003AE654000CAFCE000CF9 S31A0010604EAFBD000EABFF000EAC06003AFB060016AF0100397F8A S31A00106063A80023FFFF000E1DFF0036E7E1000ECCFD000D5FBB23 S31A001060780023FFFF000EA1BF000EA0AE0018AC00000E0CFF0035 S31A0010608D35E7D8000E0CFC0030E7D8000EACFF0023FFFF000E07 S31A001060A2FB7F0036E7D3000EACFF000EABFF000C0BDF0032E7E9 S31A001060B7D0000C1CEF0034E7CD000CAFDB000CAFEC0023FFFF91 S31A001060CC000374FF000375FF000CAFB3000EABFE000EAC870056 S31A001060E10CAFC0000CAFB10018AE220018AD21000EA5BE000E60 S31A001060F6A41F000EA1BF000EA0AE00181D390032E7BC00181E79 S31A0010610B3A0034E7B80018AE3A0018AD390033E7A6000E13017C S31A001061200032E7B3001C3E07001C7D060033E7A6000E13FD00AA S31A0010613532E7AC001CAC08000EABFF000C4CEE000C5BDD003335 S31A0010614AE7A6000EAEFF000EADFF000CAFC0000CAFB10002CD72 S31A0010615F280002CE29000CBEDF0036E7A0000EA1FE000EA087AC S31A001061740002CD280002CE29000EAEFF000EADFF0004AFA30045 S31A001061890E1F000036E7980004AFA3000E1FFE0032E78F000ED2 S31A0010619E13FD0032E793001CAE08000EADFF0033E78F000E13C4 S31A001061B3010032E78F001CAE07001CAD06000EA1FE000EA08796 S31A001061C80002CE220002CD21000EAFFF0002CF1F0002CF20002D S31A001061DD16A5010016A4010023FFFF00397FAD003AFCFB000E5B S31A001061F2A5FF000EA41C000EA1BD000EA0760018AF000002EFC8 S31A00106207080018AF010002EF090018AF0C0002EF1C0018AF0DEE S31A0010621C0002EF1D0018AE0D0018AD0C000EABFF000EAC0E0025 S31A001062313AFB06001CAE1D001CAD1C000EABFF000EAC0A003A85 S31A00106246FB06000EABFF000EAC11000EADFE003A7FA4000EAFD6 S31A0010625BF40002EF06000EAF8D0002EF070004AFBF000EBFF7B5 S31A001062700001BFBF000EA1BD000EA0760018AE190018AD180038 S31A001062850EABFE000EACF8003A7FA6000EA1BD000EA07600187E S31A0010629AAE1B0018AD1A000EABFE000EACF6003A7FA6000EA1BC S31A001062AFBF000EA0AE0018AF01000E1FFD0036E7460018AB0190 S31A001062C4000E2BFE000EEBF7000CAFFB001CAF01000E2F0800C1 S31A001062D902EF01000CBFBF0002EF01003AEF2C001CAC09001CEA S31A001062EEAB08003AD774003AEE85001CAF080001BFA0001CAFA2 S31A00106303090001BF9F001CAF060001BF9E001CAF070001BF9DA9 S31A0010631800397FAC0023FFFF00397FA90016AFFC000EACFF00FA S31A0010632D0EA1BD000EA0910018AF0D0002FF020018AF0E0002EC S31A00106342FF03000EA09F000EA17F0018AB00000E2BF7000C1B99 S31A00106357CF0036E7210018AB00000E2B080002CB00000CAF6C16 S31A0010636C000ECCFC000D5F7B003AE70C0004AFDF0032E71B0056 S31A001063810CAF6C000ECCFD000D5F7B003AE70C000E1CFF003680 S31A00106396E70F000CAF6E000ECEFD000D5F7D000EAFBD0002FF80 S31A001063AB00000EAF840002FF01000EACFD000EABFF003AFDBB23 S31A001063C00016AF0400397FA80023FFFF000CAFC0000CAFB10081 S31A001063D50EABFF0018AF00000E1F050036E70300191F00000292 S31A001063EACF00000EABFE000CAFBC000EABFF0023FFFF00397FFA S31A001063FFA9003AEE1F003AEC6B003AE7F8003AE6F200397FA867 S31A001064140023FFFF00397FA9003AEABC003AEF20003AECF90093 S31A001064290EABFF00397FA80023FFFF00397FA90016AFFC000EDF S31A0010643EA3FE000EA287000EA1BD000EA076001AAC1C00183C95 S31A001064530B001AAB1B00187B0A0002FB020002FC03000EFB7F0E S31A001064680032E6CA0002DB1B0002DC1C0018AC090018AB08009D S31A0010647D0E1B000032E6DC000E1C000036E6D7000D1FCF0002BD S31A00106492FF03000D5FBF0002FF020033E6D4000EAF000002FF04 S31A001064A7020002FF03000CAF6E000ECEFD000D5F7D000EAFBD5F S31A001064BC0002FF00000EAF6E0002FF01000EACFD000EABFF0018 S31A001064D13AFDBB0016AF0400397FA80023FFFF000EA3FE000EA7 S31A001064E6A2AB000EA1FE000EA04D001AAE06000CAFED000E6DA5 S31A001064FBFE00181E050002CF050018AF04000C7FDF0002CF045D S31A00106510000EA1FE000EA08700181E070002CF070018AF06009C S31A001065250C7FDF0002CF0600181E010002CF010018AF00000C2E S31A0010653A7FDF0002CF0000181C030002CF030018AF02000C7FA8 S31A0010654FBF0002CF02001AAF06000E0FFF0031E6A200181E1C99 S31A001065640002CF1C0018AF1B000C7FDF0002CF1B0018CE1800E9 S31A0010657902CE180018DD170002CD170018CC1A0002CC1A00181F S31A0010658EDB190002CB190023FFFF00397FAD000EA1BD000EA068 S31A001065A3760018AE17000EADFF000EAC17000EABFC00397FDDA5 S31A001065B8000CAFDC000E6CFE000CAFCB00037EFF00037DFF0024 S31A001065CD037CFF00037BFF0004AEBB0004ADBC0004ACBD00045D S31A001065E2ABBE00397FD60016AF04000CAFE4000CAFD5000EA1F0 S31A001065F7FE000EA0AB0018AC06000CAFCB000E6BFE0004AFA305 S31A0010660C000E1FFD0032E678003AC5730033E6750018AE0100E2 S31A0010662118AD0000397FDC0004CEBB0001BEBB0004DDBC000150 S31A00106636BDBC0004DCBD0001BCBD0004DBBE0001BBBE000EA1E3 S31A0010664BBD000EA0760018AE17000EADFF000EAC17000EABFC26 S31A0010666000397FDD000CAFDC000E6CFE000CAFCB00037EFF0065 S31A00106675037DFF00037CFF00037BFF0004AEBB0004ADBC0004A2 S31A0010668AACBD0004ABBE00397FD60016AF04000C44EB000CAFC2 S31A0010669FBC000E6BFE00397FAC0023FFFF00397FAD0016AFFEF0 S31A001066B4000CAFE4000CAFD5000EFB7F0032E64B000EAC0000E7 S31A001066C90EAB000033E641003A7FC0000EA1FF000EA01C00188A S31A001066DEAE110018AD100002FB000002FC01000CAF5B000CAF30 S31A001066F34C003A7FBD0016AF0200397FAC0023FFFF00397FA90D S31A00106708000E1BFF0036E636000EABFF000EAC11000EADFE00B0 S31A0010671D3A7FA40033E632000EABFF000EAC11000EADFE003A33 S31A001067327FA300397FA80023FFFF00397FAD0016AFD40002FB9E S31A001067472A000EA1FE000EA087000EA5FF000EA41C001CAF06CA S31A0010675C0002CF1D001CAF070002CF1E000EA1BF000EA0BD008A S31A0010677118AF0B0001BFCE0018AF0C0001BFCD0018AF0D000168 S31A00106786BFCC0018AF0E0001BFCB0018AB02000EEBBF000E2B47 S31A0010679BFE001CAF01000E2F010002EF01000CBFBF0002EF015D S31A001067B0001F8B2A000E2BFE000EEBFB000CAFFB001CAF01003D S31A001067C50E2F040002EF01000CBFBF0002EF01003AEFA9000C1C S31A001067DAAF6C000ECCFD000D5F7B000EADFE003AE59B000EAF8B S31A001067EFFF0002FF2B003ADFF9000E1CFF0036E5FB001F9B2A1F S31A00106804001EBB2A000EEBFD0002FB2B001EAF2B0002FF160039 S31A001068191CAF080002FF26001CAF090002FF27000EA1BE000EE3 S31A0010682EA0370018AB03000E2BFB000E1BFF0036E5EA001CAF76 S31A00106843360002FF28001CAF370002FF290033E5E6001CAF14C2 S31A001068580002FF28001CAF150002FF29000CAF6C000ECCFD00E4 S31A0010686D0D5F7B003AE03A001EAF2A0036E5DC001EAF23000ED9 S31A001068822F3F0002FF230033E5D7001EAF23000E2F3F0002FFFD S31A0010689723000EBFFE0002FF23001EAF23000EBF7F0002FF2364 S31A001068AC000E2F400002FF23000EA5FF000EA41C001D1C09005E S31A001068C11D5B08001CAE07001CAD06001CAF140002FF00001C90 S31A001068D6AF150002FF01003AC4F2001E4C1C001E5B1B003A7F0E S31A001068EBC00002FB240002FC25000CAF6C000ECCFD000D5F7B99 S31A00106900003AE141000EAFFE0002FF18000CAF6C000ECCFD003E S31A001069150D5F7B000EADFF003AE3130000FE610000FE93001C7A S31A0010692AAF1C0002EF18001CAF1D0002EF19000EA1FE000EA021 S31A0010693F870018AC180018AB17001CAE1D001CAD1C003AE7D72C S31A001069540002EB200002EC21000EA1FE000EA0870018AC18003E S31A0010696918AB17001CAE1D001CAD1C003AE7D70002EB22000254 S31A0010697EEC23003ADFD20016AF2C00397FAC0023FFFF00397FC6 S31A00106993AD0016AFF1000CAFC4000CAFB5000EA1FE000EA087A5 S31A001069A80018AF1F0002FF030018AF200002FF040018AF210006 S31A001069BD02FF050018AF220002FF06000EA9FF000CAF98000CA4 S31A001069D21D9F0036E57D000EADD7003A7FB2000EA1FF000EA0ED S31A001069E71C0018AF34000EBFDF0002CF34000CAF1B000CAF0C20 S31A001069FC000EAD7F003A7FA30033E316000EA1BF000EA0AE00E4 S31A00106A1118AE0A0018AD09000EACFF000EABFF001EAF06000375 S31A00106A267FFF001EAF0600037FFF001EAF0600037FFF001EAF52 S31A00106A3B0600037FFF001E0B000032E568001E1C010032E56847 S31A00106A50001E1D020032E568001E1E030016AF040030E54E00F4 S31A00106A6518AC1E0018CC6B0018AB1D0018DB6A000EA1FF000EDC S31A00106A7AA01C00180B080032E55D00181C090031E5550018AB2B S31A00106A8F34000E2BBF000E1BFF0032E5550004AFBF000E2F026B S31A00106AA40001BFBF0004ABBF000E2BFD000E1BFF0036E54F0012 S31A00106AB90EA8FE0033E54E000EA9FE000EA3FF000EA21C001A4D S31A00106ACEAB34000E2BBF000E1BFF0036E528000EA1BF000EA03F S31A00106AE3AE0018AC1E0018CC6B0018AB1D0018DB6A001A0B083F S31A00106AF80032E53F001A1C090031E5360004ABBF000E2BFD00EE S31A00106B0D0E1BFF0036E5280004AFBF000EBFFE0001BFBF003303 S31A00106B22E52D0004ABBF000E2BFE000E1BFF0036E52D0004AF6E S31A00106B37BF000E2F020001BFBF000E2F010001BFBF0004ABBF8B S31A00106B4C000E2BFD000E1BFF0036E528000EA8FE000E18FF00A4 S31A00106B6136E50C000EA9FF000EA1BF000EA0AE0018AC52001834 S31A00106B76AB51000EAEF5000EADFF00397FDB001EAF0600037FA5 S31A00106B8BFF001EAF0600037FFF001EAF0600037FFF001EAF0665 S31A00106BA000037FFF001E0B000032E50F001E1C010032E50F0099 S31A00106BB51E1D020032E50F001E1E030016AF040030E50C000E1B S31A00106BCAA9FE000E19FF0036E375000EA3FF000EA21C001AAE01 S31A00106BDF09001AAD08000CAFDC000E6CFE000CAFCB001CCE0E26 S31A00106BF40002EE0E001CDD0D0002ED0D001CDC0C0002EC0C0078 S31A00106C091CDB0B0002EB0B000EA1BE000EA0370018AB03000E40 S31A00106C1E2BFB000E1BFF0036E4EF001AAE37001AAD36000CAF3D S31A00106C33DC000E6CFE000CAFCB0033E4EA001AAE15001AAD14A3 S31A00106C48000CAFDC000E6CFE000CAFCB001CCE120002EE12008E S31A00106C5D1CDD110002ED11001CDC100002EC10001CDB0F0002F4 S31A00106C72EB0F001D1F010002EF01001D5F000002EF00001CA2A3 S31A00106C8701001CA300000EA1BF000EA0AE001813180032E439C6 S31A00106C9C001812190032E439001CAE0E001C3E0A001CAD0D0029 S31A00106CB11C7D09001CAC0C001C7C08001CAB0B001C7B07003AF8 S31A00106CC67FC1000EAFFF0002FF02000EA1BF000EA0AE0018A81A S31A00106CDB1C000EA9FF000CAF80000CAF91000CAF18000E68FEEE S31A00106CF0000CAF89000370FF000371FF000378FF000379FF005B S31A00106D051E0B000032E4B7001E1C010032E4B7001E1D020032F6 S31A00106D1AE4B7001E1E030016AF040030E4B3000EAFFE0002FF28 S31A00106D2F02000EA3BF000EA2AE001AA019001AA118000EA8FF0E S31A00106D44000EA9FF000370FF000371FF000378FF000379FF0094 S31A00106D591CAE0E001CAD0D001CAC0C001CAB0B00397FD6001617 S31A00106D6EAF010002FF0A0016AF010002FF0A0016AF010002FFA7 S31A00106D830A0016AF010002FF0A0002ED240002EE25000370FF70 S31A00106D98000371FF000378FF000379FF001CAE12001CAD1100B2 S31A00106DAD1CAC10001CAB0F00397FD60016AF040002ED2600029F S31A00106DC2EE27001EAF020036E484001CAF130036E484000EA1F9 S31A00106DD7FF000EA01C0018AB01000E2BFE000E1BFF0032E46D22 S31A00106DEC000EA1BF000EA0AE0018AE1B0018AD1A000EACFF0039 S31A00106E010EABFF001EAF0600037FFF001EAF0600037FFF001EE8 S31A00106E16AF0600037FFF001EAF0600037FFF001E0B000032E488 S31A00106E2B6F001E1C010032E46F001E1D020032E46F001E1E030C S31A00106E400016AF040030E450003ADFF90002EC140002EC1B00DD S31A00106E550CAF5B000CAF4C003AE03A001CAF21000EBFBF000227 S31A00106E6AEF21000EA1FF000EA01C00191C0900195B080018AEF5 S31A00106E7F070018AD060018AF140002FF000018AF150002FF015C S31A00106E94003AC4F2001C4C1A001C5B19003A7FC00002EB220049 S31A00106EA902EC23000EAFFE0002EF15001EAF060002EF02001E08 S31A00106EBEAF020002EF13001CAF0B0002EF07001CAF0C0002EF5E S31A00106ED308001CAF0D0002EF09001CAF0E0002EF0A000EAFFF2A S31A00106EE80002EF0B0002EF0C0002EF0D0002EF0E000EAFFF00CD S31A00106EFD02EF0F0002EF100002EF110002EF12000EAFFF0002A6 S31A00106F12EF000002EF01000EA1FF000EA01C0018AB34000E2BCB S31A00106F27DF000E1BFF0032E42F001D1F060002EF06001D5F0539 S31A00106F3C0002EF05001CAF150036E375001EAB06001C3B02009E S31A00106F510EA1BF000EA0AE00181B250035E375000EAFFF0002A8 S31A00106F66EF15000EAFFE0002EF160000FEB5000CAF5B000CAFB6 S31A00106F7B4C003AE285000CAF5B000CAF4C003AE141000EA1FED8 S31A00106F90000EA087000EA3FF000EA21C001AAE3B0018CE01003B S31A00106FA51AAD3A0018DD00000EABFE000EACE2003AFB06000E2F S31A00106FBAA1FF000EA01C0018AB34000E2BDF000E1BFF0036E3F2 S31A00106FCFF6001CAF1B0036E3F6001CAE1A001CAD19000EABFE2F S31A00106FE4000EACE0003AFB06000EABFE000EACE2000EAEFF009F S31A00106FF90EADFF003AFB06000EA3FF000EA21C000CAF31000C04 S31A0010700EAF200018AF34000E2F200002DF34000EAFFE0002EF6F S31A0010702317000EA1BF000EA0AE001CA206001CA3050018130BA3 S31A001070380032E3EF0018120C0034E37A001CAF1B0036E3E7007C S31A0010704D1CAE1A001CAD19000EABFE000EACDA003AFB06000EBE S31A00107062A1BF000EA0BD0018AC010018AB00000EA1FF000EA054 S31A001070771C000CAF02000CAF130018AE3D001A3E430018AD3CA8 S31A0010708C001A7D42000D9FEE000E5DBF003AC255000EA1FF003D S31A001070A10EA01C00183C3B00187B3A001CAF050002FF00001CB1 S31A001070B6AF060002FF01000EAEEF000EADF1003A7FBE000CAF6F S31A001070CBCE000CAFBD000CAF4F000ECFE30002FF0C000D5F5FB2 S31A001070E00002FF0B000EA3BD000EA276001AAF150002FF010005 S31A001070F50EAFFF0002FF00001EAC0C001EAB0B003AFAAB001E0C S31A0010710AAC0C001EAB0B003A7FA0000CAFCE000CAFBD000EABBB S31A0010711FFE000EACEA003AFB06001CAF20000E1F000036E3B087 S31A00107134001D1F200002EF20000EA1BD000EA076001CAF200048 S31A00107149181F160035E38B000CAF02000CAF13001AAF140003C0 S31A0010715E7FFF001AAF1300037FFF0018AE0D0018AD0C00397FCF S31A00107173D80016AF02000D9FEE000DCFDD000EA1FF000EA01C87 S31A001071880018AF3200037FFF0018A0330016A101000C01DF00D3 S31A0010719D32E396000C10EF0030E38B000EA1BE000EA037001809 S31A001071B2AB02000E2BEF000E1BFF0036E38B000EABFF000EAC9F S31A001071C701000EADDF003A7FA4001CAF200001BFC1000EA1FF8B S31A001071DC000EA01C0018AE430018AD42000EABFE000EACE0005D S31A001071F13AFB06000EABFE000EACE2000EAEFF000EADFF003A36 S31A00107206FB06000EAFFF0002EF050002EF06000EA1FF000EA057 S31A0010721B1C0018AF01000E2F040002CF01001EAC06001C3C0425 S31A00107230001EAB05001C7B03000EA1BF000EA0AE00181B0B00C3 S31A0010724532E36C00181C0C0031E363001CAF170032E363000E7E S31A0010725AA1FF000EA01C0018AB34000E2BFE000E1BFF0036E330 S31A0010726F36001EAF050002EF03001EAF060002EF04001CAF164F S31A001072840032E357000EA1FF000EA01C0018AB34000E2BFE00CD S31A001072990E1BFF0036E3360004AF620032E336001CAF160036DC S31A001072AEE350000CAF5B000CAF4C003AE026000EA1BF000EA009 S31A001072C3BD0018AF090002FF0D0018AF0A0002FF0E001EAC0E4D S31A001072D8001EAB0D003AC414003AE7E0000CAFCB0004AFD20097 S31A001072ED02FF000004AFD10002FF01001EAD0E001EAC0D000E31 S31A00107302AEF7003AC8B6000EAFFF0002EF17000EA1FF000EA0E3 S31A001073171C0018AF34000E2F010002CF34000EA1BF000EA0AE27 S31A0010732C0018AE480018AD47000CAFDC000E6CFE000CAFCB0087 S31A001073411EAF0600037FFF001EAF0600037FFF001EAF060003A3 S31A001073567FFF001EAF0600037FFF001E0B000032E320001E1CA2 S31A0010736B010032E320001E1D020032E320001E1E030016AF0447 S31A001073800030E316000EA3FE000EA287000EA1FF000EA01C005B S31A0010739518AF060002DF1D0018AF070002DF1E0016AF0F003928 S31A001073AA7FAC0023FFFF00397FAD0016AFF8000CAFC4000CAF10 S31A001073BFB50002FD030004ABBF000E2BFB000E1BFF0036E2BD4D S31A001073D40004AFB50032E2BD0004AFBF000E2F040001BFBF0023 S31A001073E90CAF4F000ECFE60002FF05000D5F5F0002FF04000EC8 S31A001073FEAFFD0002FF00001EAC05001EAB04000EADFE000EAEA6 S31A001074134D003A7FE0000EA1FE000EA04D0018AE050018AD042C S31A00107428001EAC05001EAB04003AE1B0000EA1BF000EA0BD00F9 S31A0010743D191C0400195B03000EA1FF000EA01C0018AE07001817 S31A00107452AD060018AF140002FF000018AF150002FF01003AC4A4 S31A00107467F2001C4C1A001C5B19003A7FC00002EB220002EC235D S31A0010747C001CAF21000E2F800002EF21000E2F3F0002EF21009C S31A001074910EBFFD0002EF21001EAF03000E1FFD0032E2D2001CF8 S31A001074A6AF21000EBFBF0002EF210033E2CF001CAF21000E2F40 S31A001074BB400002EF21001EAF03000E1FFE0034E2C4000EAFFEC4 S31A001074D00002EF14000CAF5B000CAF4C003AE285000CAF5B00B8 S31A001074E50CAF4C003AE141000EAFFE0002EF16000EA1FF000E9B S31A001074FAA01C0018AF01000E2F040002CF01001CAF160036E2D7 S31A0010750FA30004AF620032E2A3000CAF5B000CAF4C003AE02685 S31A00107524000EA1BF000EA0BD0018AF090002FF060018AF0A00BB S31A0010753902FF07001EAC07001EAB06003AC414003AE7E0000C60 S31A0010754EAFCB0004AFD20002FF000004AFD10002FF01001EADC1 S31A0010756307001EAC06000EAEF7003AC8B6001CAF180036E28838 S31A00107578001CAF140036E29A000EA1FF000EA01C0018AF010017 S31A0010758D0EBFFD0002CF01000EFADF000CAFFB0002FB02000E8D S31A001075A22A20000EFADF0032E297000EA1FE000EA09C000EAF2E S31A001075B7C00002CF00000EAF000002CF010000FFBE0000FFBD10 S31A001075CC0000FFBC0000FFBB001EAB02000CBABA0016AF080007 S31A001075E1397FAC0023FFFF00397FAD0016AFF40002FB040002D9 S31A001075F6FC05000EA5FE000EA487001CAC07001CAB06003A7F2A S31A0010760BC00002FB060002FC07001CAC09001CAB08003AE19041 S31A001076200002FB080002FC09000EA1BF000EA0AE0018AC3D0068 S31A001076350EABFF000EA3BD000EA276001AAE0D001AAD0C003AFC S31A0010764A7FB6000EA5FF001EAE09001EAD08000C1DBF0032E28A S31A0010765F66000C1ECF0031E264000EA5FE001EA005001EA104F3 S31A001076740018AF140036E1BA000EA1FF000EA01C0018AB010003 S31A001076890E2BFD000E1BFF0036E1BA000E15FF0036E1B8000EA8 S31A0010769EA1BF000EA0BD0018AB02000E2BFC000E1BFF0036E2BC S31A001076B333001EAC05000ECCE6001F5B04000EA3BF000EA2AE9E S31A001076C8001AAD3B003AE0C8000E1CFF0036E238000EA1BF00CC S31A001076DD0EA0AE0018AC3F000EABFF000EA3BD000EA276001ABD S31A001076F2AE0D001AAD0C00397FDC000CAFDE000CAFCD000CAF6F S31A00107707BC000E6BFE001E0D060032E239001E1E070034E2331A S31A0010771C001EA005001EA104000EAFFF0002CF140033E1B30054 S31A001077310EA1FF000EA01C0018AF01000E2F020002CF01000ECE S31A00107746A1FE000EA0870018AC090018AB08003AE1900002FB04 S31A0010775B0A0002FC0B000EA3BF000EA2AE001AAC3D000EABFF67 S31A00107770001EAE07001EAD06003A7FB6000EA5FF001EAE0B0052 S31A001077851EAD0A000C1DBF0032E21A000C1ECF0031E218000EBC S31A0010779AA5FE000EA1BF000EA0BD0018AB02000E2BFC000E1B25 S31A001077AFFF0032E209001EAC05000ECCE6001F5B04000EA3BF16 S31A001077C4000EA2AE001AAD3C003AE0C8000E1CFF0036E1B30064 S31A001077D90E15FF0036E1B3000EAFFC0002FF00000D1F6C000D3A S31A001077EE5F7B000EADBF000EAEBD003A7FE0000EA1FE000EA0AF S31A0010780357001EA205001EA304001AAC1A00183C09001AAB195E S31A0010781800187B08003A7FC0000CAFC8000CAFB9001EAE070067 S31A0010782D1EAD06000CAFDC000E6CFE000CAFCB000EECBF000C05 S31A00107842AFFB000EEDBF000CAFFC000CBBDB000EEEBF000CAFE8 S31A00107857FD000CBCEC000EAEFF000CAF80000CAF91000CAF1840 S31A0010786C000E68FE000CAF89000370FF000371FF000378FF00DA S31A001078810379FF00397FD60016AF040002FD010002FE02000CFC S31A00107896AFDB000CAFEC003AE12C0002FB010002FC02000CBC89 S31A001078ABBF0036E1B3000EABFF003AC5D9003AC65E000E1CFF12 S31A001078C00036E1C8001EAF03000E2F030002FF03000EBFFE00DF S31A001078D502FF030033E1C3001EAF03000E2F030002FF03000E8B S31A001078EABFFD0002FF03000D1F6C000D5F7B003AE0A70000FE75 S31A001078FF61001EA005001EA104000EAFFE0002CF170033E1B30D S31A00107914000E15FF0032E1B3000EA1FF000EA01C0018AF010020 S31A001079290E2F020002CF010016AF0C00397FAC0023FFFF003993 S31A0010793E7FAD000CAFC4000CAFB5003AC2F80002EB000002EC34 S31A001079530100397FAC0023FFFF00397FA90016AFD8000CAF7B4F S31A00107968000CAF6C000EADFE003AE59B003AEE85000CAF7B0077 S31A0010797D0CAF6C000EADFF003AE59B0004AFA3000E1FFD00368E S31A00107992E1970004AFA3000E1F010032E1A2000CAF7B000CAF28 S31A001079A76C000EADFD003AE3130016AF2800397FA80023FFFFF3 S31A001079BC00397FA9000CAFC0000CAFB1000EA8FF000EA9FF00ED S31A001079D10EA3BF000EA2FF001AAC31000EABFF000CAFCE000C28 S31A001079E6AFBD000CAFDC000E6CFE000CAFCB00037EFF00037D75 S31A001079FBFF00037CFF00037BFF000370FF000371FF000378FF08 S31A00107A10000379FF00397FDA0016AF08000EAFFE00397FCD0031 S31A00107A251AAF0700037FFF001AAF0600037FFF001AAF050003C4 S31A00107A3A7FFF001AAF0400037FFF00397FD90016AF04000EAF3E S31A00107A4F9400037FFF000EAF0700037FFF000EAF9F00037FFFD5 S31A00107A64000EAF9C00037FFF00397FD90016AF04000CAFE00028 S31A00107A790CAFD1000CAFC8000CAFB9000CAF9B000CAF8C000CB6 S31A00107A8EAF1D000CAF0E000CAFBF0036E14A000EFC7F0032E1C1 S31A00107AA34A000E1B700032E14E000E1C800032E14E000E1D013D S31A00107AB80032E14E000E1EFF0036E14D0034E14A000EAC00009A S31A00107ACD0EAB800033E143000CAF9B000CAF8C000CAF1D000C7D S31A00107AE2AF0E00397FD1000CAFDB000CAFEC00397FA80023FF74 S31A00107AF7FF00397FAD0016AFFF000CAFC4000CAFB5001CAF146E S31A00107B0C0036E12F000EABFE000EAC81000EADF2003A7FB200FE S31A00107B210CAF4E000ECEE6000D5F5D000EAFFD0002FF00000EDC S31A00107B36ABFE000EAC4F003A7FE00016AF0100397FAC0023FF8D S31A00107B4BFF00397FAD0016AFF40002FB060002FC07000EA1BF7C S31A00107B60000EA0BD0018AB02000E2BFC000E1BFF0036E0CD008A S31A00107B750EAFFF0002FF020002FF030002FF040002FF05000C0B S31A00107B8AAF6F000ECFFD0002FF0B000D5F7F0002FF0A001EA216 S31A00107B9F0B001EA30A0018AF000002DF010018AF010002DF0291 S31A00107BB4000EA1FE000EA0870018AC070018AB06003A7FC000B7 S31A00107BC90CAFC8000CAFB9000EA1BF000EA0AE0018AC3F000EBF S31A00107BDEABFF000EA1BD000EA0760018AE0D0018AD0C0002F9A3 S31A00107BF3000002F801003A7FBE000CAFC4000CAFB5001EA20B3B S31A00107C08001EA30A001EAC07001A3C02001EAB06001A7B0100F8 S31A00107C1D3A7FC00002FB080002FC09000EA1BF000EA0AE0018D5 S31A00107C32AC3E000EABFF001EA20B001EA30A001AAE02001AAD5E S31A00107C4701003A7FB9001EAE09001EAD08000C1DBF0032E0E716 S31A00107C5C000C1ECF0030E0D0000E05FF0032E0E3000E140000FB S31A00107C7130E0D0000EF57F0032E0D0000CB45F0036E0D000029D S31A00107C86F5000002F401001EAC0B001EAB0A001EAE07001EADA1 S31A00107C9B06003AFAAB001EA00B001EA10A0018AF010002FF0678 S31A00107CB00018AF020002FF070033E0CD000EAFFF0002FF060035 S31A00107CC502FF07001EAC07001EAB060016AF0C00397FAC002394 S31A00107CDAFFFF00397FAD0016AFFD0002FB000002FC01000EAFA1 S31A00107CEFFE0002FF02000CAFDC000EABFF000EAEFF000EADBFE5 S31A00107D04003A7FB9000CAFC4000CAFB5000EA1FE000EA0570041 S31A00107D191EA201001EA300001AAC0100183C09001AAB000018BC S31A00107D2E7B08003A7FC0000C0B5F0032E0AF000C1C4F0031E06F S31A00107D43AC000EAFFF0002FF02001EAC02000EABFF0016AF035E S31A00107D5800397FAC0023FFFF00397FAD0016AFF6000CAFC400DC S31A00107D6D0CAFB5000EA1BF000EA0BD0018AF000002FF020018C0 S31A00107D82AF010002FF03000EA1BF000EA0AE0018AC60000EAB7B S31A00107D97FF000EA1BD000EA0760018AF0C0002FF060018AF0D84 S31A00107DAC0002FF07001EAE07001EAD06003A7FB90002FB04008D S31A00107DC102FC05000EA1BF000EA0AE0018AC61000EABFF001ECF S31A00107DD6AE07001EAD06003A7FB90002FB080002FC09003AC282 S31A00107DEBD0000E1CFF0036E046001CAF00000EFF7F0032E03D72 S31A00107E00001CAF00001CBF010036E03D001CAC01001E3C030037 S31A00107E151CAB00001E7B02001E0B040032E075001E1C050034B9 S31A00107E2AE06D001EAF03001ECF050002EF01001EAF02001EDF60 S31A00107E3F040002EF000033E05F001EAC03001C3C01001EAB02C0 S31A00107E54001C7B00001E0B040032E066001E1C050034E05F0015 S31A00107E691EAF03001E3F050002EF01001EAF02001E7F04000258 S31A00107E7EEF00001CAC01001CAB00001E0B080032E05A001E1C83 S31A00107E93090034E055001EAF080002EF00001EAF090002EF01C4 S31A00107EA8001CAF00000EFF7F0032E03D001CAF00001CBF010062 S31A00107EBD36E03D001CAC01001E3C03001CAB00001E7B02003A85 S31A00107ED27FC0001E0B040032E047001E1C050030E03D000EAF77 S31A00107EE7BF0002FF00000EAFBD0002FF01000EACFC000EABFFC6 S31A00107EFC000CAF5D000CAF4E003AFDBB0016AF0A00397FAC0015 S31A00107F1123FFFF00397FAD0016AFFE000CAFC4000CAFB5001CF1 S31A00107F26AC25001CAB24000EA1FF000EA01C0018AE070018AD6A S31A00107F3B06001CAF260002FF00001CAF270002FF01003AC4F23F S31A00107F500002EB190002EC1A0016AF0200397FAC0023FFFF00AC S31A00107F65397FAD0016AFFF000CAFC4000CAFB5003ADFCD000EE5 S31A00107F7AABFF000EAC1C000EAD7F003A7FA4000EABFE000EAC54 S31A00107F8F87000EADF9003A7FB2000CAF4E000ECEE6000D5F5D8D S31A00107FA4000EAFFD0002FF00000EABFE000EAC51003A7FE0009C S31A00107FB90EAFFF0002EF16000EAFFE0002EF18000EA1FF000E5A S31A00107FCEA01C0018AE07000ECEAB0018AD06000EDD0A000EA109 S31A00107FE3BF000EA0AE000EABF500186B6C000CAFFC000C0DBF2C S31A00107FF80032DFFF000C1ECF0034DFFD003AEFA90000FFCA00AA S31A0010800D16AF0100397FAC0023FFFF000EA1FF000EA01C00186D S31A00108022AB01000E2BFE000E1BFF0036DFD5000EA3BF000EA21E S31A00108037AE0018AE090018AD08001A0D1F0032DFEC001A1E2039 S31A0010804C0034DFE6001A0D1D0032DFE8001A1E1E0031DFE60087 S31A001080610EABFF000EA1FF000EA01C0018AE07000ECEAB001858 S31A00108076AD06000EDD0A000EA1BF000EA0AE00180D210032DF16 S31A0010808BDB00181E220030DFD600180D230032DFD700181E2428 S31A001080A00031DFD5000EABFF000CAFBC000EABFF0023FFFF00C8 S31A001080B50EA1FE000EA057000EAF000002CF020023FFFF003904 S31A001080CA7FAD0016AFF20002FB000002FC01000EA1BE000EA091 S31A001080DF370018AB02000E2BFD000E1BFF0036DF36001EAC0106 S31A001080F4001EAB00003ADF2C000CAFC4000CAFB5000CB45F0045 S31A0010810932DFBA000EA4FE000EA5FF001EA001001EA100001888 S31A0010811EAB21000E2B7F000E1BFF0036DFAF000EA1FE000EA06B S31A00108133870002C52E0002C42F0033DF36003ADE86003AC1616E S31A00108148000EA3FE000EA287001AAF2F0002FF09001AAF2E002D S31A0010815D02FF08000EAFFF0002FF060002FF07000CAF40000C1C S31A00108172AF51000EA8FF000EA9FF000CAF0F001ECF090002FFB6 S31A0010818705000CAF1F001EDF080002FF04000CAF8F001EDF0796 S31A0010819C0002FF03000CAF9F001EDF060002FF02001EAF020085 S31A001081B11EBF03001EBF04001EBF050036DF36000CAFCE000C20 S31A001081C6AFBD000CAFDC000E6CFE000CAFCB00037EFF00037D8D S31A001081DBFF00037CFF00037BFF000370FF000371FF000378FF20 S31A001081F0000379FF00397FDA0016AF080002FB0A0002FC0B007A S31A0010820502FD0C0002FE0D001EA001001EA1000018AE1A0018C0 S31A0010821AAD19000CAFDC000E6CFE000CAFCB00037EFF00037DDE S31A0010822FFF00037CFF00037BFF001EAF0D00037FFF001EAF0DF5 S31A0010824400037FFF001EAF0D00037FFF001EAF0D00037FFF00D8 S31A00108259397FDA0016AF08000CAFE0001EC00D000CAFD1001E6B S31A0010826ED10C000CAFC8001ED80B000CAFB9001ED90A001EAF42 S31A001082830500037FFF001EAF0500037FFF001EAF0500037FFFA4 S31A00108298001EAF0500037FFF000CAF9B000CAF8C000CAF1D00F3 S31A001082AD0CAF0E00397FCB0016AF04001EA001001EA100000211 S31A001082C2CD190002CE1A001AAC2F001AAB2E000CAF5D000CAF06 S31A001082D74E00397FDB001EAF0500037FFF001EAF0500037FFFF5 S31A001082EC001EAF0500037FFF001EAF0500037FFF00397FCB003E S31A0010830116AF040002DD2E0002DE2F000CBEDF0032DF36000E6E S31A00108316AFFF0002DF2E000EAFFE0002DF2F000EA1FE000EA059 S31A0010832B87000EAFFF0002CF2A0002CF2B0002CF2C0002CF2DF2 S31A001083400016AF0E00397FAC0023FFFF00397FAD0016AFF4009C S31A0010835502FB020002FC03000CAFC0000CAFB10018AB21000E24 S31A0010836A2BC0000CAFBC000EABFF000CCCCC000CDBBB000CAFCD S31A0010837FC0000EC0AE000CAFB1000ED1BF0018AF300002FF078E S31A001083940018AF2F0002FF06000E2F7F0036DF15000EAF00001E S31A001083A902FF050002FF04000EA1FF000EA01C0018AC07000E4D S31A001083BECCA50018AB06000EDB0B000EA3BF000EA2AE001AAED0 S31A001083D336001AAD35000EAFFC0002FF00000EAF170002FF01BD S31A001083E8003A7FBE003A7FC0000CAFCE000CAFBD000CAFDC00E2 S31A001083FD0E6CFE000CAFCB001ECE070002FE07001EDD0600025A S31A00108412FD06001EDC050002FC05001EDB040002FB04001EA07E S31A0010842703001EA1020018AB21000E2BBF000E1BFF0036DEA2AC S31A0010843C000EA5FE000EA487001CAE29001CAD28000EACFF008E S31A001084510EABFF001CCE22001CDD21001CDC20001CDB1F000EE6 S31A00108466AFFF00397FCD003A7FC30002FB080002FC090002FD31 S31A0010847B0A0002FE0B001CAE22001CAD21001CAC20001CAB1F1D S31A00108490000EAFFF00397FCD003A7FC3001EAF0B00037FFF00AB S31A001084A51EAF0B00037FFF001EAF0B00037FFF001EAF0B00031F S31A001084BA7FFF000E8C7F00397FD40016AF04000CAFE0000CAF55 S31A001084CFD1000CAFC8000CAFB9000EA3BF000EA2AE001AAD38ED S31A001084E4001AAC37000EAFFE00397FD2000370FF000371FF0046 S31A001084F90378FF000379FF00397FD90016AF04000EAFFF00034A S31A0010850E7FFF000EAFFF00037FFF000EAFFF00037FFF000EAF8D S31A001085238800037FFF00397FD90016AF0400397FD1000CAFDBAB S31A00108538000CAFEC003A7FC0000CAFCE000CAFBD000CAFDC0060 S31A0010854D0E6CFE000CAFCB001ECE070002FE07001EDD06000208 S31A00108562FD06001EDC050002FC05001EDB040002FB04001EA02D S31A0010857703001EA1020018AE230018AD22000EACFF000EABFFD4 S31A0010858C00037EFF00037DFF00037CFF00037BFF001EAF0B00F2 S31A001085A1037FFF001EAF0B00037FFF001EAF0B00037FFF001E5E S31A001085B6AF0B00037FFF00397FDA0016AF080002FB040002FC01 S31A001085CB050002FD060002FE07003ADE120016AF0C00397FAC15 S31A001085E00023FFFF00397FAD0016AFF8000EA5FE000EA4870043 S31A001085F51CAF2A0002FF00001CAF2B0002FF01001CAF2C000274 S31A0010860AFF02001CAF2D0002FF03000EA1BF000EA0FF0018AC69 S31A0010861F31000EABFF000CAFCE000CAFBD000CAFDC000E6CFE37 S31A00108634000CAFCB00037EFF00037DFF00037CFF00037BFF009B S31A001086491EAF0700037FFF001EAF0700037FFF001EAF07000385 S31A0010865E7FFF001EAF0700037FFF00397FDA0016AF08000EAF02 S31A00108673FF00397FCD0018AF0300037FFF0018AF0200037FFFC3 S31A001086880018AF0100037FFF0018AF0000037FFF00397FD900A5 S31A0010869D16AF04000EAF0700037FFF000EAFCB00037FFF000E8D S31A001086B2AF9800037FFF000EAF7D00037FFF00397FD50016AFC8 S31A001086C70400397FCE000EA1BF000EA0BD0018AF0000037FFFDD S31A001086DC0018A0010016A101000EA8FF000EA9FF000370FF0025 S31A001086F10371FF000378FF000379FF00397FCB0016AF040002A8 S31A00108706FB040002FC050002FD060002FE07001CAE2F001CAD78 S31A0010871B2E000EACFF000EABFF000371FF000CAFB1000CAFCB2F S31A00108730000CAFDC000CAFED000EEDBF000CAFFE000EECBF00B3 S31A001087450CBDFD000EEBBF000CBCFC000EE1BF000CBBFB001641 S31A0010875AA101000EAFFF00397FCD003A7FC300397FCE001ECE23 S31A0010876F070002FE03001EDD060002FD02001EDC050002FC01D5 S31A00108784001EDB040002FB00001EAE03001EAD02001EAC010069 S31A001087991EAB00003ADE120002EB2E0002EC2F0016AF08003984 S31A001087AE7FAC0023FFFF00397FA9000CAFE0000CAFD1000CAF11 S31A001087C3C8000CAFB9000E19FF0032DE06000E18FF0032DE06D8 S31A001087D8000E11F80032DE06000E10000030DDF1000370FF00BB S31A001087ED0371FF000378FF000379FF000370FF000371FF000311 S31A0010880278FF000379FF00397FDA0016AF08000EEEFB000EED08 S31A00108817FB000CBEFE000EECFB000CBDFD000EEBFB000CBCFC00 S31A0010882C000CAFDB000CAFEC0033DDEF000EAC00000EAB000072 S31A00108841397FA80023FFFF00397FA9003AD84F003ADDE4000CC2 S31A00108856AFCB003AD84B000E1CFD0036DDEC00397FA80023FF78 S31A0010886BFF0004ABBF000EEBFD000CAFBC000EABFF000E8CFEB8 S31A001088800023FFFF00397FAD0016AFFD000EAFFF0002FF0200C6 S31A0010889504AF9C0036DDB3000EABFF000EACE0000EADDF003A7D S31A001088AA7FA4000EA04F000EA17F000EAFFF0002CF00000EAB0F S31A001088BFFE003AD9F5000EA5BE000EA437001CAC01000E2CFE2D S31A001088D4000EABF8000EADFE003AD91E001CAB00000E2BF800E6 S31A001088E90EA04F000EA17F0002CB00000EABFF000EACE0000E0C S31A001088FEADDF003A7FA3003AFF18000EA06F000EA17F000EAF0E S31A00108913020002CF00000E2A010004ACB30004ABB4000EAFFEAC S31A001089280002FF000033DD9D003AD771003AD6BD000D9FCC00AF S31A0010893D0DCFBB0001BBB40001BCB3000EFADF000CAFFD0002F7 S31A00108952FD01000E2A20000EFADF0032DDAA000EA1FE000EA0A9 S31A00108967D800191F260002CF260002CB270002CC28001EAD0102 S31A0010897C000CBADA000EAFFF0002FF00000EAEFE000EADFF00FF S31A001089913ADBA70004A0E40004A1E50018AB08000E2B7F000E5C S31A001089A61BFF0036DD8E000EA1FF000EA01C0018AF34000EBFAB S31A001089BBFB0002CF340033DD8C003AD7D5003ADC7D000EA1BE0F S31A001089D0000EA0370018AB03000E2BF7000E1BFF0036DD6900FD S31A001089E50EA3FF000EA21C001AAB01000E2BEF000E1BFF00369F S31A001089FADD69000EA06F000EA17F0018AB03000E2BFC000E1B9D S31A00108A0FFF0032DD69001AAC15001AAB14003A7FC0000EA1BE2B S31A00108A24000EA02C00180B020032DD7200181C030034DD6900F6 S31A00108A3904ACB30004ABB400196D09000CAFDE000EADFF000E5C S31A00108A4EAFFE0002FF00003ADBA7000EA06F000EA17F0018AB85 S31A00108A6303000E2BFC000E1BFF0032DD27000EA5FF000EA41CD2 S31A00108A78001CAB00000E2BF3000E1BFF0032DD27001CAC1500A5 S31A00108A8D1CAB14003A7FC0000EA1BE000EA02C00180B020032CC S31A00108AA2DD5500181C030030DD27000EA1FE000EA0A20018AC4B S31A00108AB7030018AB02003A7FC0000EA1BE000EA02C00180B02E7 S31A00108ACC0032DD4A00181C030030DD27001CAB00000E2BEF00CC S31A00108AE10E1BFF0032DD27000EA1BE000EA0370018AB01000EE8 S31A00108AF62BDF000E1BFF0036DD27000EABFF000EAC1B000EADA1 S31A00108B0BEF003A7FA4000EA1BE000EA02C0018AF09000E1FFEB1 S31A00108B200034DD3200051F9B0001BF9B000E1FFE0032DD2F0064 S31A00108B350EAFFE0002FF020033DD1D000EA1BE000EA02C0004DF S31A00108B4AAF9B00181F090032DD1D000EAF000002FF020033DD7A S31A00108B5F1D000EA06F000EA17F000EAF030002CF03000EAF0032 S31A00108B740002FF02000EABFF000EAC1B000EADEF003A7FA30040 S31A00108B891EAF02000E1FFE0032DD180004AF9C0032DD13001E11 S31A00108B9EAF02000E1F000032DD110004AF9C0032DD11000EAF82 S31A00108BB3FF0002FF02001EAF02000E1FFE0032DCEA000EFADFBC S31A00108BC8000CAFFB0002FB010000FE9C000E2A20000EFADF00F5 S31A00108BDD32DD0A000EA06F000EA17F000EAF020002CF00001861 S31A00108BF2AB01000EBBFD0002CB01000EA09F000EA17F0018ABDA S31A00108C0700000EBBF80002CB00000EAF000002CF010018AB0062 S31A00108C1C000EBBF80002CB00000EA0BF000EA17F000EAFFF0048 S31A00108C3102CF00000EA24F000EA37F000EA1BE000EA0370018AE S31A00108C46AB00000E2BF80002DB000033DCBF001EAF02000E1F80 S31A00108C5B000032DCBD000EFADF000CAFFB0002FB010000FF9CED S31A00108C700000FF9B000E2A20000EFADF0032DCE2000EA26F00F1 S31A00108C850EA37F001AAB01000E2B020002DB01000EA09F000E5A S31A00108C9AA17F000EAF000002CF01000EAF080002DF00000EA0AC S31A00108CAF4F000EA17F000EAFFF0002CF00000EAF030002DF03EC S31A00108CC4000EA2BF000EA37F000EAFFC0002DF00000EA1FF009E S31A00108CD90EA01C0018AB00000E2BF7000E1BFF0032DCC2000EAD S31A00108CEEAFFD0002DF000004AFE0000E2F010001BFE0001EAB94 S31A00108D0301000CBABA0004AFA30032DC850004AF9C000E1FFE61 S31A00108D180032DC85000EFADF000CAFFB0002FB01000E2A2000AA S31A00108D2D0EFADF0032DCB5000EA1BE000EA02C0018AF0C003621 S31A00108D42DCA80018AF0C00041FA40034DCA200051FA40001BFAE S31A00108D57A40033DC9F000EA1FF000EA01C0018AB01000E2BDF4B S31A00108D6C000E1BFF0036DC9F0004AFE0000EBFFE0001BFE00005 S31A00108D810EA5FF000EA41C001CAC15001CAB14003A7FC0000E08 S31A00108D96A1BE000EA02C0018AF0200037FFF0018A0030016A1BD S31A00108DAB01000C01BF0032DC91000C10CF0034DC87001CAC09DE S31A00108DC0001CAB08000EA1BE000EA02C00180B0A0032DC8900AE S31A00108DD5181C0B0031DC87003AFAC1001EAB01000CBABA00045D S31A00108DEAA0E40004A1E50018AF08000EBF7F0002CF080016AF97 S31A00108DFF0300397FAC0023FFFF00397FAD003AD6ED000EA1FEB2 S31A00108E14000EA0AB0018AE050018AD04000EABFF000EAC1600BE S31A00108E293AFB06003AD52F003AD5A2003AD756000EA1BE000E12 S31A00108E3EA0370018AB04000E2BFE000E1BFF0036DC5A000EA1F1 S31A00108E53FF000EA01C0018AC1F00043CA50018AB1E00047BA65D S31A00108E68003A7FC0000EA1BF000EA0AE00180B700032DC5F009C S31A00108E7D181C710034DC5A000EABFF000EAC11000EADEF003A54 S31A00108E927FA4003AD630000EA02F000EA17F0018A500000E1C60 S31A00108EA7FF0036DBB1000EA1FF000EA01C0018AB01000E2BBFAB S31A00108EBC000E1BFF0036DC260018AB3F000E2BFE000E1BFF00CA S31A00108ED136DC48000EB5FE0033DC47000E2501000EA1FF000E15 S31A00108EE6A01C0018AB3F000E2BFD000E1BFF0036DC3F000EB531 S31A00108EFBFD0033DC3E000E2502000EA1FF000EA01C0018AF3E50 S31A00108F10000E1FFE0034DC340019BF3E0002CF3E000E1FFE0077 S31A00108F2532DC34000E2503000EF5FC000CAFFB000E1BFF00329A S31A00108F3ADC2C000EABFF000EAC1B000EADBF003A7FA3000EA1F2 S31A00108F4FFF000EA01C0018AB01000E2BBF000E1BFF0032DC2517 S31A00108F64000E2503000EA1FF000EA01C00196B1B000E2BFE005E S31A00108F790CAFBE000EADFF000EACFF000EABFF000EA3BE000EAC S31A00108F8EA237001AA404000E247F000E14FF0036DC110018AB65 S31A00108FA31B000E2BF7000D9FBB000EEBFD000CAFBC000E6BFE0D S31A00108FB8000CBBD9000CBCE8000EAEFF000EADFF001AAB040000 S31A00108FCD0E2BBF000E1BFF0036DC020018AB0A000E2BFD000D35 S31A00108FE29FBB000EEBFD000CAFBE000CAFED000E6DFE000CBDB1 S31A00108FF799000CBE88000EAEFF000EADFF001AAB04000E2BDF0E S31A0010900C000E1BFF0036DBF30018AB0A000E2BF7000D9FBB00A9 S31A001090210EEBFD000CAFBE000CAFED000E6DFE000CBD99000C26 S31A00109036BE88000EAEFF000EADFF001AAB04000E2BEF000E1B3A S31A0010904BFF0036DBE30018AC0B000E2C7F000D9FFB000CBBCB46 S31A00109060000EEBFD000CAFBE000CAFED000E6DFE000CBD9B00F1 S31A001090750CBE8C000CBCBF0036DBDE000EB5FD0018AB1B000E58 S31A0010908A2BFE000CAFB8000EA9FF000EAEFF000EADFF000E14D2 S31A0010909FFF0036DBCF0018AB1B000E2BFB000D9FBB000EEBFD58 S31A001090B4000CAFBE000CAFED000E6DFE000CBD9B000CBE8C003D S31A001090C90CBCBF0036DBCA000EB5FE000EA3FE000EA2A2000E4A S31A001090DEA1BD000EA0BB00199C0B0019CB0A001AAE03001AAD60 S31A001090F302000C0DBF0032DBBF000C1ECF0030DBBD000E2502B6 S31A00109108001AAC03001AAB0200180B0A0032DBB800181C0B007B S31A0010911D35DBB6000E2501000EABFF000EAC01000EAD7F003A46 S31A001091327FA30033DBAC000EB5FC000EABFF000EAC01000EAD49 S31A001091477F003A7FA4000EA02F000EA17F0002C50000397FACEB S31A0010915C0023FFFF00397FAD0016AFF00002FD040002FE0500A5 S31A001091711EA414003AD679000EA1FE000EA0AB0002CB0200029D S31A00109186CC03000E14FF0032DB97000EA1FE000EA0A20002CB60 S31A0010919B020002CC030004AE7C0004AD7D0004AC7E0004AB7F1E S31A001091B000397FD1000CAFDB000CAFEC003A7FC0000EA5BF00E3 S31A001091C50EA4FF001CAE32000EADFF000C0BDF0032DB88000C81 S31A001091DA1CEF0030DB310004AF7C00037FFF0004AF7D00037FC1 S31A001091EFFF0004AF7E00037FFF0004AF7F00037FFF0004AEAC93 S31A001092040004ADAD0004ACAE0004ABAF00397FD40016AF0400D0 S31A0010921901BBAF0001BCAE0001BDAD0001BEAC0000FF7F000000 S31A0010922EFF7E0000FF7D0000FF7C00051FAA0001BFAA00055F05 S31A00109243AB0001BFAB0004ACAA0004ABAB001C1B330032DB6857 S31A00109258001C1C340035DB19000EAFFF00037FFF000EAFFF005D S31A0010926D037FFF000EAFFF00037FFF000EAF7900037FFF00045D S31A00109282AEAC0004ADAD0004ACAE0004ABAF00397FD90016AFF7 S31A0010929704000CAFE0000CAFD1000CAFC8000CAFB9001CAD348D S31A001092AC001CAC33000EAFFF00397FD200037EFF00037DFF0057 S31A001092C1037CFF00037BFF000CAF9B000CAF8C000CAF1D000C06 S31A001092D6AF0E00397FD50016AF0400397FD1000CAFDB000CAF80 S31A001092EBEC003A7FC0001CAE31000EADFF000C0BDF0032DB3EFD S31A00109300000C1CEF0034DB340004AFAF0001BF7F0004AFAE00E6 S31A0010931501BF7E0004AFAD0001BF7D0004AFAC0001BF7C003384 S31A0010932ADB1F000000AB000000AA0033DB1D0004AFAC00037FBD S31A0010933FFF0004AFAD00037FFF0004AFAE00037FFF0004AFAFDF S31A0010935400037FFF0004AE7C0004AD7D0004AC7E0004AB7F00B5 S31A00109369397FD40016AF040001BB7F0001BC7E0001BD7D0001D2 S31A0010937EBE7C0000FFAB0000FFAA0000FFAF0000FFAE0000FFDD S31A00109393AD0000FFAC000EA1BF000EA0FF0018AF0700037FFFED S31A001093A80018AF0600037FFF0018AF0500037FFF0018AF040034 S31A001093BD037FFF0004AE7C0004AD7D0004AC7E0004AB7F003913 S31A001093D27FD90016AF040001BB7F0001BC7E0001BD7D0001BEDF S31A001093E77C001EAD05001EAC04000EAFFE00397FD20004AF7CCD S31A001093FC00037FFF0004AF7D00037FFF0004AF7E00037FFF0062 S31A0010941104AF7F00037FFF00397FD90016AF040001BB7F0001E7 S31A00109426BC7E0001BD7D0001BE7C000EA5FE000EA49C001CAFA1 S31A0010943B000002FF06001CAF010002FF070002FB000002FC012F S31A001094500002FD020002FE03000CAF5B000CAF4C003A7FC20055 S31A001094650EA1FE000EA0AB001CAF01001E3F070002CF060018B7 S31A0010947AAC030018AB02003AD68C0004AF93000E1FFE0032DA3A S31A0010948FD90000FF980000FF970004AF900036DA70000EA1BF7B S31A001094A4000EA0AE0018A4730018A572000CB45F0032DACF00E9 S31A001094B90EA4FE000EA5FF0004AF93000E1FFD0032DAC8003AA8 S31A001094CEC1930001BB980001BC970000FF92000EA1BE000EA0CB S31A001094E3370018AB04000E2BF7000E1BFF0036DAC00000FE92A8 S31A001094F80000FE91000EA1FF000EA01C0018A2230018A3220088 S31A0010950D1813200032DAB8001812210036DAAB000EA3FE000E61 S31A00109522A2AB001AAC06000CAFCB000E6BFE0018CC210018DB10 S31A00109537200018AE230018AD22000C1DBF0032DAAA000C1ECF82 S31A0010954C0032DAAA0000FE920004AD970004AC98000EAFFE0063 S31A00109561397FD2000EAFFF00037FFF000EAFFF00037FFF000ECD S31A00109576AFFF00037FFF000EAF5E00037FFF00397FD90016AFA9 S31A0010958B04000CAFE0000CAFD1000CAFC8000CAFB9000CAF5C7C S31A001095A0000CAF4D000EAFFF00397FD200037EFF00037DFF0053 S31A001095B5037CFF00037BFF000CAF9B000CAF8C000CAF1D000C0F S31A001095CAAF0E00397FD50016AF040004AF920032DA16000EA34B S31A001095DFFE000EA287001AAF17000EFF7F0032DA16000EA1FFF0 S31A001095F4000EA01C001AA818001AA9170018091C0032DA7C0009 S31A0010960918181D0030DA160004AF7C00037FFF0004AF7D0003E6 S31A0010961E7FFF0004AF7E00037FFF0004AF7F00037FFF00397F86 S31A00109633D40016AF040033DA16000EA1FE000EA0AB0018AF027D S31A00109648000EFF7F0032DA680018AF020018BF030032DA3E000A S31A0010965D04AF93000E1FFD0032DA62003AC1B00001BB98000104 S31A00109672BC970004AD970004AC98000EAFFE00397FD20002FBA8 S31A00109687080002FC090002FD0A0002FE0B000EA1BE000EA03743 S31A0010969C0018AD0A0018AC09000EAFFF00397FD200037EFF0041 S31A001096B1037DFF00037CFF00037BFF001EAE0F001EAD0E001E42 S31A001096C6AC0D001EAB0C00397FD50016AF04000EAFFF00037F57 S31A001096DBFF000EAFFF00037FFF000EAFFF00037FFF000EAF7EB0 S31A001096F000037FFF000E8C7F00397FD40016AF040033DA200033 S31A0010970504AF93000E1FFD0032DA38003AC1D10001BB98000164 S31A0010971ABC970004AD970004AC98000EAFFE00397FD20002FBFF S31A0010972F0C0002FC0D0002FD0E0002FE0F000EA1BE000EA0378A S31A001097440018AD0A0018AC09000EAFFF00397FD200037EFF0098 S31A00109759037DFF00037CFF00037BFF001EAE13001EAD12001E91 S31A0010976EAC11001EAB1000397FD50016AF040004AF7C00037F33 S31A00109783FF0004AF7D00037FFF0004AF7E00037FFF0004AF7F27 S31A0010979800037FFF00397FD90016AF040000FF93000EA5FE0088 S31A001097AD0EA496000EAFC00002EF00000EAF000002EF0100022A S31A001097C2FB000002FC010002FD020002FE03000CAF5B000CAFAD S31A001097D74C003A7FC2001D1C01001CAB00000EDB3F0001BBBA01 S31A001097EC0001BCB90004AF900036D9F8003A7FC00001BBBA00A3 S31A0010980101BCB9000E0BFF0032D9FB000E1CFE0034D9F800007B S31A00109816FFBA0000FEB90016AF1000397FAC0023FFFF00397FA5 S31A0010982BAD0016AFF90002FB01000EAFFF0002FF06000E2A208E S31A00109840000EFADF0032D9F0000EA0CF000EA17F0018AB0100AC S31A001098550EBBFB0002CB01000EBADF000EA1BE000EA037001845 S31A0010986AAB03000E2BFB000E1BFF0032D9DF001EAF010036D902 S31A0010987FD5000EA0BF000EA17F0018AB00000E2BFD000E1BFF2D S31A001098940032D9D5000EAFFD0002CF00000EAFFE0002FF06007C S31A001098A90EA4CF000EA57F001CAB01000EBBEF0002EB01000E65 S31A001098BEABFC001EAF010036D9CC000EABDC003AF9A0003AF994 S31A001098D39A0002FB020002FC030002FD040002FE05000E2A2070 S31A001098E8000EFADF0032D9C6001CAB01000E2B040002EB0100AA S31A001098FD0EBADF001EAF060036D9B9000EA0BF000EA17F000E55 S31A00109912AFFF0002CF00001CAB01000E2B100002EB0100059C0B S31A00109927950005CB96003AD679001EAF010032D9AC000EA1FE5F S31A0010993C000EA0AB0002CB070002CC080033D9A8000EA1FE009C S31A001099510EA0A20002CB020002CC03001EAE0500043E78001E52 S31A00109966AD0400047D79001EAC0300047C7A001EAB0200047B1A S31A0010997B7B000ECE7F000D5FDD000D5FCC000D5FBB000CAFDEAA S31A00109990000CAFCD000CAFBC000E6BFE000CAFE2000CAFD3000B S31A001099A50EFD7F0036D992000EA2FF000EA3FF00041383003241 S31A001099BAD98F000412820030D9740004AE840004AD85000EACDF S31A001099CFFF000EABFF000CAFDB000CAFEC000EAEFF000EADFF04 S31A001099E40004A0820004A183000EA8FF000EA9FF000370FF002D S31A001099F90371FF000378FF000379FF00397FD60016AF04000C78 S31A00109A0EAFDB000CAFEC000CAF3D000CAF2E003A7FC8000CAFDF S31A00109A23C4000CAFB50033D9690004AC800004AB81000CAF2E26 S31A00109A3800043E82000CAF3D00047D83003A7FC8000CAFC40043 S31A00109A4D04C484000CAFB50004D585000EABFE000EACAF000CA8 S31A00109A62AF5D000CAF4E003A7FA6000EA1BF000EA0FF0018AC86 S31A00109A770D000CAFCB000E6BFE000CCC44000CDB55000EA1FFB4 S31A00109A8C000EA01C0018AF280018BF290036D92B000EAC7B0087 S31A00109AA10EABFC0018AE290018AD28000E0DF10032D951000E93 S31A00109AB61ECF0030D946000EACAD000EAB01000E0DF70032D90B S31A00109ACB4B000E1E020034D946000CAFEC000ECCAB000CAFDBE2 S31A00109AE0000EDB0A000CAFC8000EC8F9000DFFB9000EA1BF00E3 S31A00109AF50EA0FF0018AE2C000EADFF000CAF9B000CAF8C003917 S31A00109B0A7FDD000EAFFB0002FF00000EABBF000EACDB003A7F55 S31A00109B1FBC000EA1BF000EA0FF0018AF2E00037FFF0018AF2DDA S31A00109B3400037FFF000CAFCE000CAFBD00397FD80016AF02002D S31A00109B490C4E44000C5D55001EAF010032D925000EA1FE000EDC S31A00109B5EA0AB0002C5000002C401000EA1FE000EA0A20002C53F S31A00109B73000002C4010016AF0700397FAC0023FFFF00397FAD4A S31A00109B880016AFFB0002FB000002FC010002FD02000EAFFF0039 S31A00109B9D02FF03000EAFFA0002FF04000E1CFF0036D8EB000EAD S31A00109BB21DFF0032D8FB000EABFA003AF9A0003AF99A000CAF59 S31A00109BC7DE000CAFCD000CAFBC000E6BFE000CAFE4000CAFD5F0 S31A00109BDC000434790004757A000CAF5B000CAF4C000EADFF00E3 S31A00109BF13AF976000CAFC4000CAFB5000EABFE000EACF4000C40 S31A00109C06AF5D000CAF4E003AFB06001EAF01000E1FFE0032D8E0 S31A00109C1BF6000EAFBE0002FF04001EAF010036D8EB000E2A2089 S31A00109C30000EFADF0032D8F4000EA0CF000EA17F0018AB0100B5 S31A00109C450EBBF70002CB01000EBADF001EAF020036D8DF000EF5 S31A00109C5AA0BF000EA17F0018AB00000E2BFD000E1BFF0032D827 S31A00109C6FDF000EAFFD0002CF00000EAFFE0002FF03000EABCF19 S31A00109C84003AF9A0000EABCF003AF9A4000EA0CF000EA17F00D8 S31A00109C9918AB01000EBBEF0002CB01001EAF020036D8D1001E8A S31A00109CAEAF04000EBFDF0002FF04001EAB04003AF9A4001EAFB6 S31A00109CC3020032D8CA001EAB00003AF9890033D8C9003AF99A7A S31A00109CD8000CAFDE000CAFCD000CAFBC000E6BFE000CAFE400B3 S31A00109CED0CAFD5001EAF010036D8B8000E2A20000EFADF0032B7 S31A00109D02D8C1000EA0CF000EA17F0018AB01000E2B080002CB20 S31A00109D1701000EBADF001EAF030036D8B2000EA0BF000EA17F4E S31A00109D2C000EAFFF0002CF00000EA0CF000EA17F0018AB010010 S31A00109D410E2B100002CB0100059C950005CB96003AD679001E9D S31A00109D56AF020036D8A0000EA1FE000EA0A200180B020032D857 S31A00109D6BA300181C030034D8A00002CB020002CC0300043479F6 S31A00109D800004757A000CAF5B000CAF4C001EAD01003AF9760033 S31A00109D950CAFC4000CAFB5001EAF020032D88B000EA1FE000E95 S31A00109DAAA0AB0002C5040002C405001EAF010032D88B000EAB91 S31A00109DBFFE000EACF4000CAF5D000CAF4E003AFB06000EA1FEC4 S31A00109DD4000EA0A20002C5040002C405001EAC010016AF0500E9 S31A00109DE9397FAC0023FFFF00397FA90016AFFE0016AF02003AA5 S31A00109DFEFE3F003AD7E9000EABEF003A7FE20001BB850001BCC2 S31A00109E1384000EABEE003A7FE20001BB830001BC82000EABED3A S31A00109E28003A7FE20001BB810001BC80000EABC6003A7FE200E0 S31A00109E3D0CAFCE000CAFBD0001BD9A0001BE99000CAFEF000E91 S31A00109E52CFEF0002FF01000CAFDF000EDFD80002FF00000EAC0B S31A00109E6700000EAB80003A7FBE0001BB9A0001BC990000FFA3D2 S31A00109E7C000EA0BF000EA17F000EAFFD0002CF000004AFA3003F S31A00109E910E1FFD0032D857003ADDED0033D85C003AD84F003A15 S31A00109EA6DDE4000EABFF003AD84B0033D85C0016AF0200397FD5 S31A00109EBBA80023FFFF00397FA9003ADDDE00397FA80023FFFFDC S31A00109ED000397FAD0016AFFE0002FB00000EA1FF000EA01C00CA S31A00109EE518A4150018A5140004ADA3000EA1BE000EA01F00180A S31A00109EFA05020032D83E001814030035D83B000EABFD0033D8B6 S31A00109F0F32000EA1BE000EA01F00199C010019CB00000C05BF51 S31A00109F240032D834000C14CF0030D82E000EAB01000EACFF003C S31A00109F393AD76B000CAFCD0033D827000EA1BE000EA01F001875 S31A00109F4EAC09000EABFF0002FD01003AD76B001EAD01000E1D08 S31A00109F63FF0036D7FA000E1D010032D81C000D9F44000DCF555A S31A00109F78000EA1BE000EA01F0018AC070018AB060033D81800CD S31A00109F8D0EA1BE000EA01F0018AC08000EABFF000EA1BE000E70 S31A00109FA2A01F001805040032D813001814050034D80F0001BB8F S31A00109FB7B20001BCB10033D7FC001EAF000036D80B000EADFFB9 S31A00109FCC0033D7FC0004ACB10004ABB2000E1BFF0032D806006A S31A00109FE10E1CFE0030D800000CAFDB000EEBFD000CCBDB000DDA S31A00109FF60FBD0033D7FC0005BFB10001BFB10005FFB20001BF12 S31A0010A00BB2000E1DFF0032D7EF000EA1BE000EA0370018AB033E S31A0010A020000E2BDF000E1BFF0036D7EF0000FE900004AFA300F5 S31A0010A03536D7EE0000FD930033D7EE0000FF900001BDA3000C81 S31A0010A04AAFDC0016AF0200397FAC0023FFFF00397FAD000EA100 S31A0010A05FBF000EA0FF0018AF080001BFA20018AF090001BFA108 S31A0010A074000EA4BF000EA57F000EAFFD0002EF00003AD69600CD S31A0010A0890EAFFF0002EF00000EA06F000EA17F000EAF080002ED S31A0010A09ECF0000397FAC0023FFFF00397FAD0016AFFE000EA16C S31A0010A0B3FE000EA0AB0018A4030018A502000CAF5B000CAF4C90 S31A0010A0C8003A7FC0000EA1BF000EA0FF0018AE30000EADFF0029 S31A0010A0DD0C0BDF0032D7C5000C1CEF0031D7C2000EA4FF000EF4 S31A0010A0F2A5FF0018AF2F0002FF01000EAFFF0002FF00000EAB31 S31A0010A107FF000EAC8F000CAF5D000CAF4E003AFAAB000EABFF2D S31A0010A11C000EAC08000CAF5D000CAF4E003AFB06000EABFF0042 S31A0010A1310EAC8F003A7FA0000CAFCE000CAFBD000EABFE000E9B S31A0010A146ACE4003AFB060016AF0200397FAC0023FFFF00397F1F S31A0010A15BA90016AFFC000CAFCD000CAFBC000EAFFE00397FD22B S31A0010A1700002FB000002FC010002FD020002FE03000EA3BF0054 S31A0010A1850EA2FF001AAC0A000CAFCB000E6BFE0004CCA10004BE S31A0010A19ADBA2000CAFCD000CAFBC000EAFFE00397FD2000CAF1E S31A0010A1AFE0000CAFD1000CAFC8000CAFB9001AAD36001AAC352A S31A0010A1C4000EAFFE00397FD200037EFF00037DFF00037CFF00AE S31A0010A1D9037BFF000CAF9B000CAF8C000CAF1D000CAF0E003967 S31A0010A1EE7FD50016AF04001EAF0300037FFF001EAF0300037F86 S31A0010A203FF001EAF0300037FFF001EAF0300037FFF000E8C7F76 S31A0010A21800397FD40016AF040016AF0400397FA80023FFFF007C S31A0010A22D01BB8A0001BC890023FFFF00397FA9000EABFF003A06 S31A0010A242D9F5003AD6AF00397FA80023FFFF000E1B010036D7AC S31A0010A25767000E1BFD0032D7590004AFB0000E1FFE0034D75EF6 S31A0010A26C0004AFA3000E1F010036D75E0004AFA3000E1FFD0058 S31A0010A28132D75C000CAFBC0033D7570005BFB00001BFB000335E S31A0010A296D7580001BCB00004ACA30023FFFF00397FAD0016AF63 S31A0010A2ABFE000EA5FF000EA41C001CAC0900043C9F001CAB088B S31A0010A2C000047BA0000EAFFD0002FF00000EAFFE0002FF0100DC S31A0010A2D50EADBF000EAEC8003AD724001CAC0700043C9D001C63 S31A0010A2EAAB0600047B9E000EAFFE0002FF00000EAFFE0002FF03 S31A0010A2FF01000EADBF000EAEC5003AD724001CAC15001CAB144B S31A0010A314000EAFFB0002FF00000EAF7E0002FF01000EADBF00AE S31A0010A3290EAEC2003AD7240004AB86000E2BFC000E1BFF00368E S31A0010A33ED7270004AB86000E2BFB000E1BFF0036D727000CAF76 S31A0010A3535B000CAF4C000EADF7003A7FA40016AF0200397FAC43 S31A0010A3680023FFFF00397FAD0016AFFF000CAFC8000CAFB90089 S31A0010A37D0CAFE4000CAFD5003A7FC0000CAFC0000CAFB1000C1A S31A0010A392AF19000CAF08001EAB0500042B86000E1BFF0036D65E S31A0010A3A7FE000EACFF001CAE01001CAD00001EAB06000E2B7FB9 S31A0010A3BC000C1BCF0036D709000C01DF0032D70B000C10EF005F S31A0010A3D134D7040033D705000C01DF0032D706000C10EF00310C S31A0010A3E6D704000EACFE000E1CFF0036D6F2001F8B0500042FB0 S31A0010A3FB860001BF860033D6F2001EAF060002FF00000CAF9B46 S31A0010A410000CAF8C000CAF5D000CAF4E003ACC74000CAFCE00B6 S31A0010A4251EAB05000EACFF000EAD87003ACC8400051F6700012D S31A0010A43ABF670016AF0100397FAC0023FFFF00397FAD0016AF5C S31A0010A44FFE000EA5FE000EA4AB001CAE01001CAD00000EA1BFD4 S31A0010A464000EA0FF0018AF2F0002FF01000EAFFF0002FF00006B S31A0010A4790EABFF000EAC8B003AFAAB001CAE01001CAD00000E3A S31A0010A48EABFF000EAC14003AFB06000EABFF000EAC8B003A7F3A S31A0010A4A3A0000CAFCE000CAFBD000EABFE000EACB4003A7FA669 S31A0010A4B8001CAE08001CAD07000EABFE000EACE6003AFB060045 S31A0010A4CD0EA1FF000EA01C0018AC150018AB14001CAE01001C55 S31A0010A4E2AD00003AF9BB000CAFCE000CAFBD000EABFE000EAC42 S31A0010A4F7DC003AFB060016AF0200397FAC0023FFFF00397FA976 S31A0010A50C000E2A20000EFADF0032D6BC000EA06F000EA17F00D6 S31A0010A52118AB01000EBBF70002CB01003AFF180004ACDA0004DE S31A0010A536ABDB00397FA80023FFFF00397FAD0016AFFA000EA51C S31A0010A54BBE000EA437001CAC01000E2CFE000EABF8000EADFFD2 S31A0010A560003AD91E0001BCA9003AF99A0002FB000002FC010070 S31A0010A57502FD020002FE03001CAF070002FF04001CAF0800020B S31A0010A58AFF05000EABFF000EAC7B003AFA920016AF0600397F6C S31A0010A59FAC0023FFFF00397FA9000EABF8003AF9A0003AF99A12 S31A0010A5B40001BB7B0001BC7A0001BD790001BE7800397FA80040 S31A0010A5C923FFFF000EADFF000EFB7F0032D686000CBCBF0036B9 S31A0010A5DED686000EADFE00041DA80036D67B0004AFA30032D68F S31A0010A5F37C000EA1BE000EA0370018AB03000E2BDF000E1BFF69 S31A0010A6080032D67B0000FD930001BDA80023FFFF00397FA9002C S31A0010A61D16AFFC000CAFCD000CAFBC000EAFFE00397FD200020B S31A0010A632FB000002FC010002FD020002FE03000EA3BF000EA2DF S31A0010A647FF001AAC0A000CAFCB000E6BFE0004CCA10004DBA22A S31A0010A65C000CAFCD000CAFBC000EAFFE00397FD2000CAFE000F4 S31A0010A6710CAFD1000CAFC8000CAFB9001AAD36001AAC35000E35 S31A0010A686AFFE00397FD200037EFF00037DFF00037CFF00037B77 S31A0010A69BFF000CAF9B000CAF8C000CAF1D000CAF0E00397FD5CA S31A0010A6B00016AF04001EAF0300037FFF001EAF0300037FFF0014 S31A0010A6C51EAF0300037FFF001EAF0300037FFF000E8C7F003976 S31A0010A6DA7FD40016AF04000E8C7F0001BC7E0001BB7F0001BDEC S31A0010A6EF7D0001BE7C001AAF0300037FFF001AAF0200037FFFEF S31A0010A704001AAF0100037FFF001AAF0000037FFF0004AE7C0067 S31A0010A71904AD7D0004AC7E0004AB7F00397FD90016AF04003AF7 S31A0010A72E7FBF0016AF0400397FA80023FFFF00397FAD000EA461 S31A0010A743FC003ACF8B000EFB7F0036D628000EACFF000EABFF2E S31A0010A7580033D5F2000EA5FF000EA0A9000EA17F0018AB0000E2 S31A0010A76D041B770032D60E000EA0A8000EA17F0018AB000004CA S31A0010A7821B760032D60E000EA0A7000EA17F0018AB0000041BA0 S31A0010A797750032D60E000EA1BD000EA0910004AC730004AB741B S31A0010A7AC00181B190032D60E00181C1A0032D60E000415A700FC S31A0010A7C132D5FD000EA5FE0001B5A7003AD5F0000E1CFF0036FD S31A0010A7D6D62B000EA0A9000EA17F0004AF770002CF00000EA029 S31A0010A7EBA7000EA17F0004AF750002CF00000EA0A8000EA17FF1 S31A0010A8000004AF760002CF00000E15FF0036D5F8000DBF4400FE S31A0010A8150E14000032D628000EACFF000EABFF000E15FF003201 S31A0010A82AD5F2000EACFE000EABFF00397FAC0023FFFF00397F8F S31A0010A83FAD0016AFFE000EABDB003A7FE20001BC77000EA1BEAE S31A0010A854000EA0320018AF00000E1FC00034D5E3000EACFF00A0 S31A0010A8690EABFF0033D5A50018AF000001BF75000EA1BE000EE8 S31A0010A87EA0310018AB00000E1BF80030D5E6000EA3BD000EA2F1 S31A0010A893A5000CAFBC000EABFF000CCCCC000CDBBB000CC2C0F2 S31A0010A8A8000CD3B10018AC01001A3C110018AB00001A7B100061 S31A0010A8BD1AAF120002FF00001AAF130002FF01000EAE17000ED5 S31A0010A8D2ADFC003A7FBE000CAFC4000CAFB5000EABE8003A7FF2 S31A0010A8E7E2000CAFCB000EECBF000EABFF000C44CC000C55BB35 S31A0010A8FC000EFB7F0036D5BB000ECCBF000D5FBB0033D5B50066 S31A0010A9110E0BFF0032D5B8000E1CC00034D5B5000ECC3F000D76 S31A0010A926FFBB000E1BFF0032D5B2000E1CC00030D5E6000CAFDB S31A0010A93BCF000EEFFB000CAFFB0001BB76000EA1BD000EA09197 S31A0010A9500018AF190001BF740018AF1A0001BF73000EACFE00FC S31A0010A9650EABFF0016AF0200397FAC0023FFFF00397FAD001648 S31A0010A97AAFFC000EA5FE000EA4A2001CAE05000ECEAB001CADE3 S31A0010A98F04000EDD0A000EAFBD0002FF00000EAFAF0002FF01BB S31A0010A9A4000EABFF0004AFA3000E1FFD0032D591000EABFE0001 S31A0010A9B902FB02000EABF7000CAFDC000CAFED003AD52D001C2D S31A0010A9CEAE05000ECEAB001CAD04000EDD0A000EAFBD0002FFE7 S31A0010A9E300000EAFAA0002FF01000EABFF0004AFA3000E1F01A4 S31A0010A9F80032D57F000EABFE0002FB02000EABFB000CAFDC00AD S31A0010AA0D0CAFED003AD52D001CAE01001CAD00000EAFBD00022A S31A0010AA22FF00000EAFBB0002FF01000EAFFE0002FF02000EAB19 S31A0010AA37FD000CAFDC000CAFED003AD52D001CAE01001CAD00E8 S31A0010AA4C000EAFBD0002FF00000EAFB60002FF01000EAF7E00B4 S31A0010AA6102FF02000EABFE000CAFDC000CAFED003AD52D001C79 S31A0010AA76AE01001CAD00000EAFBD0002FF00000EAF510002FFB3 S31A0010AA8B01000EAFFE0002FF02000EABDF000CAFDC000CAFED0A S31A0010AAA0003AD52D001CAE01001CAD00000EAFBD0002FF000040 S31A0010AAB50EAF560002FF01000EAF7E0002FF02000EABEF000C6F S31A0010AACAAFDC000CAFED003AD52D000EFADF000CAFFB0002FB58 S31A0010AADF03000E2A20000EFADF0032D547000EA1FF000EA0124E S31A0010AAF40004AC71000E2CCF0018AB00000E2B30000CBFCF0047 S31A0010AB0902CF00000EA1FF000EA0010004AC71000E2CF0001890 S31A0010AB1EAB00000E2B0F000CBFCF0002CF00001EAB03000CBA1C S31A0010AB33BA0016AF0400397FAC0023FFFF0000FF670023FFFF68 S31A0010AB4800397FAB0016AFFF000CAFB5000CAFD8000CAFC90034 S31A0010AB5D1EA005001EA104001EAC06000CAF5B00042B71000EB3 S31A0010AB721BFF0036D5090018AE040018AD03000E2C7F000CAF84 S31A0010AB87CB000E1BFF0036D515000EABFF000C09DF0032D517C6 S31A0010AB9C000C18EF0035D50F0033D510000EABFF000C09DF009E S31A0010ABB132D511000C18EF0030D50F000EABFE000E1BFF003625 S31A0010ABC6D4FE000D8F5B00042F710001BF710033D4FE0002FCC3 S31A0010ABDB00000CAF9B000CAF8C000CAF1D000CAF0E003ACC7497 S31A0010ABF0000CAFCE000CAF5B000EACFF000EAD72003ACC84002B S31A0010AC05051F670001BF670016AF0100397FAA0023FFFF0039F0 S31A0010AC1A7FAB000CAFB5000EACFF0004AB69000E1BD90036D498 S31A0010AC2FB4000E0BD90030D4E3000E0BE60030D4EA000E0BFB6C S31A0010AC440031D4CC000C0BCF0035D4950033D4D1000E1BDB00B4 S31A0010AC5936D4B4000E0BDB0030D4C1000E0BE30035D49500338C S31A0010AC6ED4CC000E0BD00030D4DA000E0BD30031D4AF000E1B8B S31A0010AC83D80036D4C1000E0BD60030D4950033D4CC000E0BC1CE S31A0010AC980035D495000E0B9E0034D497000E0B880030D4950063 S31A0010ACAD0E0B8B0035D4950033D4A40004AC69000EABFF000EB0 S31A0010ACC2CC1D000EDBFF0033D49A000EA1FF000EA01C0018ABBA S31A0010ACD700000E2BDF000E1BFF0032D4950004AC69000EABFFA6 S31A0010ACEC000ECC1D000EDBFF0033D49A000EA1BE000EA037006B S31A0010AD0118AB03000E2BFE000E1BFF0036D4B40004AB68000E1F S31A0010AD162B80003ACCF8000E1CFF0036D4B4003AFADC0000FF73 S31A0010AD2BB80004AC69000EABFF000ECC1D000EDBFF0033D49AF4 S31A0010AD40000EA1FF000EA01C0018AB00000E2BDF000E1BFF006D S31A0010AD5532D4950004AC69000EABFF000ECC1F000EDBFF003353 S31A0010AD6AD49A000EA1FF000EA01C0018AB00000E2BDF000E1BD4 S31A0010AD7FFF0032D4950004AC69000EABFF000ECC53000EDBFF29 S31A0010AD94000CAF5D003AD37B0033D495000CAF5B003ACE3E00FC S31A0010ADA90E1CFF0036D48D0004AF69000EBF7F0001BF6800052A S31A0010ADBE1F690001BF690033D48C0000FE68000EABFF00397F50 S31A0010ADD3AA0023FFFF00397FA9000EA1FF000EA01C0018AC00ED S31A0010ADE8000EECF7000E2CFE0004AB69000E0BAB0030D46400D3 S31A0010ADFD0E0BBF0031D412000E0BCA0030D470000E0BCB0031D0 S31A0010AE12D43A000E0BD60030D473000E0BFD0031D446000E0B27 S31A0010AE27FF0035D3DA0033D44A000E0BD40034D4420033D43E52 S31A0010AE3C000E0BC40030D469000E0BC50031D42E000E0BC800AF S31A0010AE5134D4360033D432000E1BC10036D415000E0BC100304C S31A0010AE66D4000033D42A000E0B8E0030D454000E0B910031D30F S31A0010AE7BEC000E0B9A0030D459000E0B9B0031D3F4000E0B9E4D S31A0010AE900034D40A0033D3F8000E0B980034D3F0000E1B920024 S31A0010AEA536D4220033D3DA000E0B880030D44F000E0B8B0031AD S31A0010AEBAD4260033D3E8000E1B860036D3E4000E0B860030D347 S31A0010AECFE00033D4190004AB69003AD208003ACD0D0033D3D63C S31A0010AEE4000EABFF000EAC1A000EADFD0033D3DD000EABBD00A6 S31A0010AEF90EAC6E000EADD50033D3DD000EABFE000EACF2000E22 S31A0010AF0EADD30033D3DD000EABFE000EAC87000EADCB0033D331 S31A0010AF23DD000EABFE000EAC51000EADC90033D3DD000EABFE46 S31A0010AF38000EACEA000EADC70033D3DD000EABBE000EAC37007D S31A0010AF4D0EADC50033D3DD000EABBD000EAC6A000EADC300332B S31A0010AF62D3DD000EABFE000EACDE000EAD8B0033D3DD000EA0EE S31A0010AF772F000EA17F0018AC01000E2CC00018AB00000EEBBF18 S31A0010AF8C000CAFFB000CBCBC0033D3D6000EA02F000EA17F0079 S31A0010AFA118AC030033D3D6000E1CFF0032D3DA0033D400000EC5 S31A0010AFB61CFF0036D400000EA1FE000EA0D80018AF01000E1F23 S31A0010AFCBFB0030D3DA0033D400000E1CFF0036D400000EA1FE9C S31A0010AFE0000EA0D80019BB01000E1BFC0030D3DA0004AF6900CD S31A0010AFF50E1F9E0036D3DA0004AC69000EABFF000CAFC0000E29 S31A0010B00AC016000CAFB1000ED1FF0018AC000033D3D6000EABA2 S31A0010B01FFE000EAC4D000EAD9D0033D3DD000EABFE000EAC74E1 S31A0010B034000EAD9B0033D3DD000EABFE000EAC7A000EAD990079 S31A0010B04933D3DD000EABFE000EACE8000EAD910033D3DD000E63 S31A0010B05EABFE000EAC70000EAD8D0033D3DD000EA1FE000EA06E S31A0010B073D80018AC260033D3D6000EABFE000EACB1000EAD85B2 S31A0010B088003ACD18003ACD0D0033D3D60000FE68000EAC00006E S31A0010B09D0EABFF0033D3D10004AF690001BF6800051F69000127 S31A0010B0B2BF69000EABFF00397FA80023FFFF00397FAB000CAFF4 S31A0010B0C7BC000EA1FF000EA01C0018AB00000EEBF7000E2BFE40 S31A0010B0DC000E1C920036D3A0000E0C920030D3A0000E0CAB00D0 S31A0010B0F130D3B9000E0CBF0031D3B1000E1CC10036D3B4000E34 S31A0010B1060CC10030D3A0000E0CFF0035D39D0033D3A0000E0C30 S31A0010B11B9E0034D3A9000E0C980030D39D0033D3A0000E1BFF9B S31A0010B1300032D39D0033D3A0000E1BFF0036D3A0000EA1FE002E S31A0010B1450EA0D80018AF01000E1FFB0030D39D0033D3A0000E15 S31A0010B15A1BFF0036D3A0000EA1FE000EA0D80019BB01000E1BD6 S31A0010B16FFC0030D39D000E1C9E0036D39D0001BC69000EA5FED4 S31A0010B1840033D39C000EA5FF0004AB68000E2B80003ACCF8007E S31A0010B1990E1CFF0036D395000E15FF0032D3940000FE68000C97 S31A0010B1AEAF5C000EABFF00397FAA0023FFFF00397FAB000EA11E S31A0010B1C3FF000EA01C0018A500000E2560000EABF9003A7F9F3E S31A0010B1D8000E1B000032D385000E1C000036D384000EB59F0080 S31A0010B1ED0EA1FF000EA01C0002C500000EA1FE000EA0D8000EB7 S31A0010B202AFFF0002CF0100397FAA0023FFFF00397FAD0016AFF4 S31A0010B217FF000CAFC4000CAFB50002FD00003A7FF40004AB685B S31A0010B22C000E2B7F000E1BFF0036D35D0004AB68000E2B8000E1 S31A0010B24101BB68003ACCF8000E1CFF0036D35D001EAB00000E5A S31A0010B256ACFF0004AE70000EADFF000CCECE000CDDBD0004AB49 S31A0010B26B680032D35F000CAFDB000CAFEC003AD00F0033D35D33 S31A0010B2800002ED000002EE01001EAF000001BF70000EACFE000E S31A0010B2950EABFF0016AF0100397FAC0023FFFF0016AFFC000EBC S31A0010B2AAA1FE000EA0D80018AB00000E1BBD0036D2A8000E0BE2 S31A0010B2BFBD0030D327000E1BCE0036D2D9000E0BCE0030D33784 S31A0010B2D4000E1BDD0036D2F5000E0BDD0030D341000E1BFD00EC S31A0010B2E936D303000E1BEF0036D2FC0033D239000E1BD800369D S31A0010B2FED2E7000E0BD80030D33A000E1BDB0036D2EE0033D23F S31A0010B31339000E1BCF0036D2E00033D239000E1BC50036D2C4FE S31A0010B328000E0BC50030D32E000E1BC70036D2D2000E1BC60032 S31A0010B33D36D2CB0033D239000E1BC30036D2B6000E0BC3003519 S31A0010B352D2BD000E1BBF0036D2AF0033D239000E1BAA0036D289 S31A0010B36777000E0BAA0030D315000E1BAE0036D293000E0BAE30 S31A0010B37C0030D31A000E1BBB0036D2A1000E1BAF0036D29A0082 S31A0010B39133D239000E1BAC0036D285000E0BAC0030D27E003379 S31A0010B3A6D28C000E1B950036D254000E0B950030D30A000E0B30 S31A0010B3BBA70035D239000E0BA60034D269000E1B970036D25B2F S31A0010B3D00033D239000E1B930036D270000E0B930035D24D00E0 S31A0010B3E50E1B8F0036D2460033D239000EAFBD0002FF00000E70 S31A0010B3FAAFBB0002FF01000EA0E9000EA1FF0033D235000EAF80 S31A0010B40FBD0002FF00000EAFA50002FF01000EA0EB000EA1FFA9 S31A0010B4240033D235000EAFBE0002FF00000EAF5C0002FF01002C S31A0010B4390EA0F9000EA1FF0033D235000EAFBE0002FF00000ECF S31A0010B44EAF560002FF01000EA0F2000EA1FF0033D235000EAF87 S31A0010B463BE0002FF00000EAF490002FF01000EA0ED000EA1FFAE S31A0010B4780033D235000EAFBD0002FF00000EAF760002FF0100BF S31A0010B48D0EA0E7000EA1FF0033D235000EAFBD0002FF00000E8E S31A0010B4A2AF5E0002FF01000EA0ED000EA1FF0033D235000EAF30 S31A0010B4B7BD0002FF00000EAF900002FF01000EA0F3000EA1FF0E S31A0010B4CC0033D235000EAFBD0002FF00000EAF840002FF01005D S31A0010B4E10EA0F1000EA1FF0033D235000EAFBD0002FF00000E30 S31A0010B4F6AF4C0002FF01000EA0BF000EA1FF0033D235000EAF1C S31A0010B50BBD0002FF00000EAFFB0002FF01000EA0F3000EA1FF4E S31A0010B5200033D235000EAFBD0002FF00000EAFEF0002FF01009D S31A0010B5350EA0FC000EA1FF0033D235000EAFBE0002FF00000ECF S31A0010B54AAF370002FF01000EA0F4000EA1FF0033D235000EAFA7 S31A0010B55FBD0002FF00000EAFEC0002FF01000EA0FA000EA1FF02 S31A0010B5740033D235000EAFBE0002FF00000EAF2C0002FF01000B S31A0010B5890EA0F2000EA1FF0033D235000EAFBF0002FF00000E84 S31A0010B59EAFAE0002FF01000EA08B000EA1FF0033D235000EAF45 S31A0010B5B3BE0002FF00000EAF1F0002FF01000EA0F3000EA1FF81 S31A0010B5C80033D235000EAFBF0002FF00000EAFBD0002FF010025 S31A0010B5DD0EA0F0000EA1FF0033D235000EAFBF0002FF00000E32 S31A0010B5F2AF3A0002FF01000EA0AD000EA1FF0033D235000EAF43 S31A0010B607BE0002FF00000EAFE80002FF01000EA0AF000EA1FFA7 S31A0010B61C0033D235000EAFBE0002FF00000EAF980002FF0100F6 S31A0010B6310EA0E1000EA1FF0033D235000EAFBE0002FF00000EED S31A0010B646AF7A0002FF01000EA0E1000EA1FF0033D2350018AE71 S31A0010B65B00000EADFF000EEEBF00037FFF000EEDBF000CBFED5C S31A0010B6700016AE01000ECEFF0002FE01000EDDD20002FD000052 S31A0010B6850EA0DF000EA1FF0033D235000EAFBF0002FF00000E9A S31A0010B69AAFFF0002FF01000EA0F1000EA1FF0033D235000EAF91 S31A0010B6AFBF0002FF00000EAFF10002FF01000EA0DE000EA1FFC6 S31A0010B6C40033D235000EAFBF0002FF00000EAFD00002FF010015 S31A0010B6D90EA0EC000EA1FF0033D235000EA1FF000EA01C001834 S31A0010B6EEAB00000E2BBF000E1BFF0032D239000EAFBE0002FFAD S31A0010B70300000EAF130002FF01000EA0E7000EA1FF0033D235CC S31A0010B718000EAFFF0002FF000002FF010033D210000EA3FE0083 S31A0010B72D0EA2D8001AAE01000EADFF000EEEDF00037FFF000E7C S31A0010B742EDDF000CBFED0016AE01001ECE010002FE01001EDDAA S31A0010B757000002FD00000CAF0C000ECCE0000D5F1B000EECF7CF S31A0010B76C000EEBF7000CBCFC000CAFCD000DBFDB001A1B010099 S31A0010B78134D21B000EAFDF0002FF030033D20E001A1D0100345D S31A0010B796D210000CAFDE000EADFF000DBFEE000DFFDD000EEEB4 S31A0010B7ABDF000CAFFE000C4E0F0002FF030033D20E000EAFFF9F S31A0010B7C00002FF03001EAE03001EAD02001EAC01001EAB00002A S31A0010B7D516AF040023FFFF00397FA90004AB6F000E1BF8003689 S31A0010B7EAD1C9000E0BF80030D1F2000E1BFD0036D1DA000E0B76 S31A0010B7FFFD0030D1F9000E1BFF0036D1E2000E1BFE0036D1DD0C S31A0010B8140033D1B0000E1BFB0036D1D4000E0BFB0035D1D70065 S31A0010B8290E1BFA0036D1CE0033D1B0000E0BF40030D1E9000E43 S31A0010B83E0BF50031D1BB000E1BF70036D1C6000E1BF60036D10F S31A0010B853C10033D1B0000E1BF30036D1B8000E0BE50030D1B0CB S31A0010B868000E0BE80035D1B00033D1B3000EA1FF000EA01C00CF S31A0010B87D18AC010018AB000033D1AE000EACBD000EABF800330B S31A0010B892D1AE000EABEF003A7F9F0033D1AE0004ACD5000EAB1C S31A0010B8A7FF0033D1AE000EA08F000EA17F0018AB04000CAFBC1C S31A0010B8BC000EABFF0033D1AE000EA1BD000EA0910018AC0D007B S31A0010B8D10EABFF0033D1AE0004AC6E000EABFF0033D1AE000E4C S31A0010B8E6A1BF000EA03A0018AC010018AB000033D1AE000EA106 S31A0010B8FBBF000EA0FF0018AC0A000CAFCB000E6BFE0033D1AE39 S31A0010B9100004ACA10004ABA20033D1AE000EA1BD000EA091000D S31A0010B92518AC0C0018AB0B0033D1AE0004AC6B0004AB6C00333E S31A0010B93AD1AE000EACFF000EABFF00397FA80023FFFF00397FB9 S31A0010B94FA9000E1BFF0032D1A8000E1CE50034D1A3000E1BFF72 S31A0010B9640032D144000E1CDC0032D1440004AF6F0001BF6E00D4 S31A0010B97901BC6F000E0CEB0030D191000E0CEC0031D183000E47 S31A0010B98E1CFA0036D141000E0CFA0034D141000E0CF80035D1BE S31A0010B9A341000E0CF30034D141000E1CEF0036D1830033D141FD S31A0010B9B8000E1CE60036D169000E0CE60030D188000E1CE80049 S31A0010B9CD36D175000E1CE70036D1810033D141000E1CE50036B0 S31A0010B9E2D153000E1CDC0036D14F0033D141003AD13F0033D127 S31A0010B9F741003ACF6A0001BB6C0001BC6B000EFB800001BF6C6C S31A0010BA0C0001BC6B000EA1BD000EA0910018AB13000E2B8000AD S31A0010BA2118AC140033D15E003ACF0E0001BB6C0001BC6B000E4B S31A0010BA36FB800001BF6C0001BC6B000EA1BD000EA0910018ABA8 S31A0010BA4B15000E2B800018AC160033D15E003ACED50001BB6CC1 S31A0010BA600001BC6B000EFB800001BF6C0001BC6B000EA1BD004A S31A0010BA750EA0910018AB17000E2B800018AC180004AE6B0004D7 S31A0010BA8AAD6C000C1DBF0032D158000C1ECF0036D141000CAF39 S31A0010BA9FDF000EBF7F0001BF6C0001BE6B0033D141003ACF8B22 S31A0010BAB40001BB6C0001BC6B0033D141000EA1FF000EA01C005A S31A0010BAC918AF1E0001BFA60018AF1F0001BFA5000EABFF000EF6 S31A0010BADEAC11000EADEF003A7FA30033D1410004AF6D0032D112 S31A0010BAF3410000FBC000397FA80023FFFF00397FAD0016AFF78A S31A0010BB08000CAFC4000CAFB5000E15FF0032D138000E140000A4 S31A0010BB1D30D014000CAF4B000CAFBC000EABFF000E1BFF00325A S31A0010BB32D130000E1CDF0036D0B7000E0BFF0032D12D000E1CAF S31A0010BB47DF0030D105000E1BFF0032D128000E1CEF0036D0C1BB S31A0010BB5C000E0BFF0032D125000E1CEF0030D112000E1BFF002A S31A0010BB7132D120000E1CF50036D0D1000E0BFF0032D11D000E4A S31A0010BB861CF50030D117000E1BFF0032D118000E1CF60036D002 S31A0010BB9BD60033D014000E1BFF0032D113000E1CF40036D0CB65 S31A0010BBB00033D014000E1BFF0032D10E000E1CEB0036D0B90046 S31A0010BBC50E0BFF0032D10B000E1CEB0030D014000E1BFF0032AC S31A0010BBDAD106000E1CEC0036D0BB0033D014000E1BFF0032D150 S31A0010BBEF01000E1CBF0036D05F000E0BFF0032D0FE000E1CBFDB S31A0010BC040030D0EC000E1BFF0032D0F9000E1CDD0036D07E007B S31A0010BC190E0BFF0032D0F6000E1CDD0035D09F000E1BFF0032EB S31A0010BC2ED0F1000E1CDB0036D043000E1BFF0032D0ED000E1C9B S31A0010BC43D20036D05F0033D014000E1BFF0032D0E8000E1C7FCD S31A0010BC580036D06E000E0BFF0032D0E5000E1C7F0030D0DF00C6 S31A0010BC6D0E1BFF0032D0E0000E1CBE0036D0190033D014000E76 S31A0010BC821BFF0032D0DB000E1C7E0036D05F000E1BFF0032D069 S31A0010BC97D7000E1C7D0036D0570033D014000EA1FF000EA01C18 S31A0010BCAC0018AF00000EBFFB0002CF00000EA1FF000EA01C0095 S31A0010BCC118AF00000EBFF70002CF000033D014000EAFBF000267 S31A0010BCD6FF00000EAFF70002FF01000EACFD000EABFF000EAD64 S31A0010BCEBFF000EAEA2003AFDBB0033D014000EA1FF000EA01C50 S31A0010BD000018AF01000EBFDF0002CF010033D014003AFAC100C6 S31A0010BD1533D014003AFAB60033D014000EABF9003A7F9F0002DF S31A0010BD2AFB020002FC03000E1B000032D0A1000E1C000032D0F8 S31A0010BD3FA1000EAFF80002FF02000EAFBD0002FF03000CAF6FD8 S31A0010BD54000ECFFD0002FF01000D5F7F0002FF00000EACFF0043 S31A0010BD690EABFF000EADF9000EAEFE003A7FEF003AD390003311 S31A0010BD7ED017000EA1BD000EA0910018A515000E25800018A4C7 S31A0010BD9316003ACF0E000E2B80000C15BF0032D017000C14CFB7 S31A0010BDA80032D017000EA1BF000EA0BD0018AB02000E2BFB0085 S31A0010BDBD0E1BFF0032D0800018AF020002FF04000EBFFB000219 S31A0010BDD2FF04000CAF6E000ECEFB000D5F7D000EAFBF0002FFDD S31A0010BDE700000EAFBB0002FF01000EACFE000EABFF003AFDBB55 S31A0010BDFC0000EEDF0033D017003A7FE90002FB050002FC06008D S31A0010BE1102FD070002FE08000CAF6E000ECEFA000D5F7D000E02 S31A0010BE26AFBD0002FF00000EAF820002FF01000EACFB000EABD5 S31A0010BE3BFF003AFDBB0033D017000EA0BF000EA17F000EAFFD7C S31A0010BE500002CF00000EABFF000EAC1C000EADEF003A7FA30062 S31A0010BE650EA1BF000EA0FF0018AF080001BFA20018AF09000195 S31A0010BE7ABFA10033D017000EA0BF000EA17F000EAFFD0002CFFD S31A0010BE8F00000EABFF000EAC1C000EADEF0033D04A000EA3FF53 S31A0010BEA4000EA21C001AAB00000E2BEF000E1BFF0036D0170075 S31A0010BEB90EA0BF000EA17F000EAFFC0002CF00000CAF3B000C37 S31A0010BECEAF2C000EADF7003A7FA4000EA1FE000EA0D8000EAF6F S31A0010BEE3FF0002CF260001B46F0033D017000EA1FF000EA01C88 S31A0010BEF80018AB01000E2BFE000E1BFF0032D0170018AB3F00E1 S31A0010BF0D0EEBFB000CAFB8000EA9FF00196B3F000E2BFE000CE6 S31A0010BF22AFBE000EADFF0018AB3F000E2BFE000CAFBC000EAB64 S31A0010BF37FF000CCCEE000CDBDD0018AB3F000EEBBF000E2BFE65 S31A0010BF4C000CAFBC000EABFF000CCCEE000CDBDD000C19DF000D S31A0010BF6132D01C000C18EF0032D01C000CCCCC000CDBBB000D13 S31A0010BF761FCF0002CF3E0018AF01000EBFBF0002CF010033D07A S31A0010BF8B17000EAF000002CF3E0033D017003ACCC20033FFFF95 S31A0010BFA0000EACFE000EABFF0033D012000EACFF000EABFF0080 S31A0010BFB516AF0900397FAC0023FFFF00397FAD0016AFF8000CE0 S31A0010BFCAAFC4000CAFB5000EA1FF000EA01C0018AF000002FF29 S31A0010BFDF05000EA1BD000EA076000EA3FF000EA21C0018AB085B S31A0010BFF4001A8B100018AC09001A8C11000E8BCA0002FB010088 S31A0010C0090E8C310002FC020018AB08001A8B100018AC09001ADA S31A0010C01E8C11000D1F6F0002FF07000D5F7F0002FF06001EA007 S31A0010C03307001EA106000E8B590002CB02000E8C0D0002CC03DD S31A0010C048000EAFFE0002FF00000CAF5B000CAF4C000EADBE007B S31A0010C05D0EAE13003ACFA6000E1CFF0036CFDE000EA3FF000E70 S31A0010C072A21C001EAF05000E2F200002DF000033CFA9000EAF6D S31A0010C087FB0002FF00000CAF5B000CAF4C001EAE07001EAD06D1 S31A0010C09C003ACFA6000E1CFF0036CFCF000EA1FF000EA01C0055 S31A0010C0B11EAF05000E2F600002CF000033CFA9001EAB05000E9D S31A0010C0C62BDF000E1BFF0032CFAC000EAFFD0002FF00000CAFFA S31A0010C0DB5B000CAF4C000EADBE000EAE0F003ACFA6000E1CFFBC S31A0010C0F00036CFBC000EA3FF000EA21C001EAF05000E2F600079 S31A0010C10502DF000033CFA9000E15F00032CFB1000E14FF00326B S31A0010C11ACFB1001EAB05000E2BBF000E1BFF0032CFB1003ACCD4 S31A0010C12FC2003A7FFB0033CFA9000CAF5B000CAF4C003AD13F5D S31A0010C144000E1CFF0032CFA9000CAF5B000CAF4C003AD1AC0029 S31A0010C15916AF0800397FAC0023FFFF000CAFE0000CAFD1001E24 S31A0010C16EAE00000EADFF00041DC00036CF9E0001BD6D0033CF8D S31A0010C1838E0004AF6D0032CF9600181B020032CF9600181C0349 S31A0010C1980032CF960001BE6D0033CF8E00041E6D0032CF8E000B S31A0010C1AD181B000032CF8F00181C010032CF8F000EADFE000026 S31A0010C1C2FF6D000CAFDC000EABFF0023FFFF0016AFFF000EFAAA S31A0010C1D7DF000CAFFB0002FB00000E2A20000EFADF0032CF87E4 S31A0010C1EC000EA1BE000EA0320018AE00000EADFF000EA1BE00EE S31A0010C2010EA0310018AC00000EABFF000CCCEE000CDBDD000E1F S31A0010C216A1BD000EA0910018AB19000E2B800018AC1A000C1DC4 S31A0010C22BBF0032CF71000C1ECF0036CF70000EBD7F001EAB0036 S31A0010C240000CBABA000CAFDB000CAFEC0016AF010023FFFF002F S31A0010C255397FA90016AFFD000EAEFF000EADFF000EA0FF000E6B S31A0010C26AA1BF000EFADF000CAFFB0002FB02000E2A20000EFA4D S31A0010C27FDF0032CF61000EA880000EA9FC0010AC01000EABFFF5 S31A0010C294000CCCEE000CDBDD000DBF88000DFF99000EF97F0076 S31A0010C2A936CF5C0002FD000002FE01000EABBD000EAC4C000E7F S31A0010C2BEAEBF000EADFF003ACE69000CAFCE000CAFBD0002FDBD S31A0010C2D3000002FE01000EABBF000EACFF000EAEF1000EADFFA7 S31A0010C2E8003ACE69000CAFCE000CAFBD0002FD000002FE0100B9 S31A0010C2FD0EABBD000EAC90000EAEFD000EADFF003ACE69000C66 S31A0010C312AFCE000CAFBD0002FD000002FE01000EABBD000EACDB S31A0010C3278E000EAEFD000EADFF003ACE69000CAFCE000CAFBD78 S31A0010C33C0002FD000002FE01000EABBD000EAC84000EAEFE0068 S31A0010C3510EADFF003ACE69000CAFCE000CAFBD0002FD00000294 S31A0010C366FE01000EABBD000EAC83000EAEFE000EADFF003ACE7E S31A0010C37B69000CAFCE000CAFBD0002FD000002FE01000EABBDB7 S31A0010C390000EAC7E000EAEFD000EADFF003ACE69000CAFCE00DD S31A0010C3A50CAFBD001EAB02000CBABA000CAFDB000CAFEC001657 S31A0010C3BAAF0300397FA80023FFFF0016AFFF000EA2FF000EA301 S31A0010C3CFFF000EFADF000CAFFB0002FB00000E2A20000EFADF6B S31A0010C3E40032CF08000EA1BF000EA03A000CAF3D000CAF2E00EE S31A0010C3F910AC01000EABFF000CCC22000CDB33000D1FEE000D69 S31A0010C40E5FDD000E1DFF0032CEF8000E1E220034CF01000EA1A4 S31A0010C423BF000EA091000EAEFF000EADFF0010AC01000EABFF06 S31A0010C438000CCC22000CDB33000D1FEE000D5FDD000E1DFF0038 S31A0010C44D32CEEA000E1EFE0034CEF3000EA1BF000EA08F000E02 S31A0010C462AEFF000EADFF0010AC01000EABFF000CCC22000CDBF2 S31A0010C47733000D1FEE000D5FDD000E1DFF0032CEDC000E1EFED4 S31A0010C48C0034CEE5001EAB00000CBABA000CAF3B000CAF2C0078 S31A0010C4A116AF010023FFFF00397FA90016AFFD000EFADF000C73 S31A0010C4B6AFFB0002FB02000E2A20000EFADF0032CED0003ACF9A S31A0010C4CB6A000CAFCE000CAFBD0002FD000002FE01000EABBF63 S31A0010C4E0000EACBD000EAEFD000EADFF003ACE69000CAFCE004D S31A0010C4F50CAFBD0002FD000002FE01000EABBF000EACBB000EA9 S31A0010C50AAEFE000EADFF003ACE69000CAFCE000CAFBD0002FD2F S31A0010C51F000002FE01000EABBF000EACBA000EAEFD000EADFF91 S31A0010C534003ACE69000CAFCE000CAFBD0002FD000002FE01006A S31A0010C5490EABBF000EACB8000EAEFD000EADFF003ACE69000CED S31A0010C55EAFCE000CAFBD0002FD000002FE01000EABBF000EAC8B S31A0010C573B6000EAEFD000EADFF003ACE69000CAFCE000CAFBD02 S31A0010C5880002FD000002FE01000EABBF000EACB4000EAEFD00E9 S31A0010C59D0EADFF003ACE69000CAFCE000CAFBD0002FD00000246 S31A0010C5B2FE01000EABBD000EACFB000EAEF0000EADFF003ACEC6 S31A0010C5C769000CAFCE000CAFBD0002FD000002FE01000EABBC6A S31A0010C5DC000EACFF000EAE7F000EADFF003ACE69000CAFCE008C S31A0010C5F10CAFBD0002FD000002FE01000EABBD000EAC7A000EEF S31A0010C606AEFD000EADFF003ACE69000CAFCE000CAFBD0002FD33 S31A0010C61B000002FE01000EABBD000EAC6E000EAEFD000EADFFE2 S31A0010C630003ACE69000CAFCE000CAFBD001EAB02000CBABA0022 S31A0010C6450CAFDB000CAFEC0016AF0300397FA80023FFFF000C38 S31A0010C65AAFC0000CAFB1001EA201001EA300000CBEDF0036CEAB S31A0010C66F5B000DBFEE000DFFDD0010AC01000EABFF000C4C22B3 S31A0010C684000C5B33000CBEDF0032CE63000CAF3B000CAF2C0008 S31A0010C69923FFFF00397FA90016AFFE0016AF010000FE68003ACB S31A0010C6AED390003A7FF9000EA0EF000EA17F000EAF550002CF9E S31A0010C6C3060004AFFF000EBFFE0001BFFF000EAFD40002FF0078 S31A0010C6D8000EAFF90002FF01000EABD3000EACCF000EADD400DB S31A0010C6ED0EAE89003A7FFA0033CE4B0016AF0200397FA8002394 S31A0010C702FFFF00397FAD0016AFF70002FB06000EAFFE0002FF2E S31A0010C71707000EA1FF000EA01C0018A100000EE1F70002F108DE S31A0010C72C000EF1FE0002FF080004AB69000E1BAB0036CDC1002C S31A0010C7410E0BAB0030CE26000E0BBF0031CDC9000E1BC1003626 S31A0010C756CE20000E1BC00036CE1D0033CD26000E0BA00034CDE0 S31A0010C76B94000E1B9F0036CD8C000E1B9E0032CD26001EAF08F7 S31A0010C7800036CD260033CD72003A7FF4000EA5FE000EA4D8000B S31A0010C7951EAF060002EF01000EABFE000EACD6000EADDF003A99 S31A0010C7AA7FB2001EAF080032CE0F001CAF23000E1FFE0032CD37 S31A0010C7BFF0001CAB01000E0BFE0035CDF6000E0BFC0034CE076A S31A0010C7D4000E1BFB0036CDFD0033CDF6001DBB01000EEBDF006F S31A0010C7E90CAFFC000ECC4C0002FC03000EDBBD0002FB02000E94 S31A0010C7FEAFDF0002FF050033CDD6000EAFBD0002FF02000EAF6C S31A0010C813FB0002FF03000EAFF30002FF050033CDD6000EAFFFB3 S31A0010C8280002FF020002FF03000EAFFF0002FF050033CDD60046 S31A0010C83D1CAF230032CDE8003AD3560002FB020002FC03000296 S31A0010C852FD040002FE050033CDD6001CAF23000E1FFD0032CDC8 S31A0010C867DE000EABFE000EACD6003ACC98000EABF7003ACCEE3F S31A0010C87C0002EC220033CD1D001CAF010002FF02001CAF0000CA S31A0010C89102FF03001CAB23000E2BE0000D1FBF0002FF05001E66 S31A0010C8A6AE03001EAD02001EAF050002FF00000EABFE000EACA5 S31A0010C8BBD6003A7FE0000EABDF003ACCEE000EA1FE000EA0D824 S31A0010C8D00002CC220033CD1D001EAF080036CD26000EA1FE0085 S31A0010C8E50EA0D80018AF01000E1FFB0034CD260033CD72001EFB S31A0010C8FAAF080032CDBA000EA1FE000EA0D80018AF23000E1F59 S31A0010C90FFE0032CD26000EA1FE000EA0D80018AF010032CD26BA S31A0010C924000EABEB003ACCEE001E1C060032CD72000EA5BE002E S31A0010C9390EA40B003A7FF4000EABFE000EACD6000EADEB003A42 S31A0010C94ECCE2000CAF5B000CAF4C000EADEF003ACCA5000E1C74 S31A0010C963FF0036CDA3000EA4FF000EA5FF000CAF5B000CAF4C84 S31A0010C978000EADFE000EAED6003A7FDF000CAF5B000CAF4C0094 S31A0010C98D0EADFE000EAED6003A7FDF000EABFE000EACD6000E47 S31A0010C9A2ADEB003ACCE20033CD1D001EAF080036CD26000EA120 S31A0010C9B7FE000EA0D80019BB01000E1BFC0034CD260033CD723E S31A0010C9CC000EABDF003ACCEE001E1C060032CD72001EAF08002E S31A0010C9E132CD81000EA5FE000EA4D8001CAF23000E1FFE003225 S31A0010C9F6CD48000EA1FE000EA0D80018AB01000E0BFC0030CDF8 S31A0010CA0B77000E0BFD0031CD6F000E1BFE0036CD740033CD72F6 S31A0010CA20000E1BFB0036CD5D0033CD72001EAF080036CD6F00AE S31A0010CA350EAFFF0002FF070033CD1D000EA1FE000EA0D80019A9 S31A0010CA4ABB01000EEBDF000CAFFC000ECC4C0002FC03000EDB66 S31A0010CA5FBD0002FB02000CAF64000EC4FD000D5F75000EAFDF85 S31A0010CA740002EF03003A7FF4001CAC03000EABFF0033CD3E0035 S31A0010CA890EAFBD0002FF02000EAFFB0002FF03000CAF64000E1C S31A0010CA9EC4FD000D5F75000EAFF30002EF03003A7FF4001CACB2 S31A0010CAB303000EABFF001EAF020002FF00001EAF030002FF01FB S31A0010CAC8000EADFE000EAED6003AFDBB003AEF2C0033CD1D0094 S31A0010CADD1CAF230032CD36003AD3560002FB020002FC030002A6 S31A0010CAF2FD040002FE05003A7FF4001EAC05000EABFF001EAF12 S31A0010CB07020002FF00001EAF030002FF01000EADFE000EAED6E3 S31A0010CB1C003AFDBB0033CD1D003A7FF4001CAF010002FF020063 S31A0010CB311CAF000002FF03001CAD23000E2DE0000D1FDD0002F8 S31A0010CB46FD05001EAC03001EAB020002FD00000EADFE000EAEB6 S31A0010CB5BD6003A7FE00033CD1D003A7FF40004AC69000EABFFA5 S31A0010CB70000CAFC0000EC016000CAFB1000ED1FF001EAF06001E S31A0010CB8502CF00001EAC07000EABFF0016AF0900397FAC0023D6 S31A0010CB9AFFFF000CAFC0000CAFB100044D69000E2D01000CAFDA S31A0010CBAFDC000EABFF000CCC00000CDB110018AC010018AB006F S31A0010CBC40023FFFF00397FAD000CAFC4000CAFB50004AB6800BA S31A0010CBD93ACCF8000E1CFF0036CD040004AC6A0033CCFB000CE3 S31A0010CBEEAF5E000EADFF0001BE6A0004AB69000E2BFE000CAF22 S31A0010CC034C000E1BFF0036CCFB000CAFEC000EABFF00397FACD2 S31A0010CC180023FFFF000CAFBD000EACFF0004AB69000E2B01004D S31A0010CC2D0C1BDF0032CCF00004AC69000E2CFE000EABFF0023BC S31A0010CC42FFFF000EACFF000EA1FE000EA0D60033CCE90010CC1B S31A0010CC5701000DBFBB000E1B000032CCEA000D8FCB000CAFBC3B S31A0010CC6C000EABFF0023FFFF000374FF000375FF000379FF005C S31A0010CC810CAFC2000CAFB3000CAFD9000CAF9C000EABFF000CEE S31A0010CC96CC24000CDB35000E19FE0034CCC8000DBF99000E09FE S31A0010CCABFF0034CCC8001AAB00000CAF9E000EADFF000CCE20C5 S31A0010CCC0000CDD310018AF0000035F010002CB00000EC9010060 S31A0010CCD50E09FF0030CCD3000CAF5B000CAF4C0016A90100165C S31A0010CCEAA5010016A4010023FFFF00397FAD000E2A20000EFAD8 S31A0010CCFFDF0032CCC1000E2A5C000EA4FF000EA57F001CAB919D S31A0010CD14000E2BC70002EB91000EAFFE0002EF60003AFE3500FD S31A0010CD290EAFFF0002EF40000EAFFF0002EF30000EAFFF000257 S31A0010CD3EEF90003EBFFF003EBFFF003EBFFF003EBFFF003EBF5E S31A0010CD53FF003EBFFF003EBFFF003EBFFF00397FAC0023FFFF3D S31A0010CD68000CAFC0000CAFB1000EACFE0033CC9D0010AB0100A9 S31A0010CD7D36CC9D000EACFF0033CC9A000DBFDD000E1D00003294 S31A0010CD92CCA1000EABFF0023FFFF00397FAD0016AFFF000CAF4C S31A0010CDA7C4000CAFB5000EA0FF000CAF0B000ECBF30002F000FC S31A0010CDBC003A7FE2000CAFBE000EADFF00036E0100036C01009C S31A0010CDD11EA000000D1F00000E10FC0034CC930016AF010039A1 S31A0010CDE67FAC0023FFFF000CAFD0000CAFC1000E1EFF0036CCA2 S31A0010CDFB7B000E0EFF0034CC77000CAFBF0018BF010002CF01DC S31A0010CE10000D8FBB00182F000002CF000033CC750018BB000041 S31A0010CE2502CB000023FFFF00397FA9000CAFC8000CAFB9000C90 S31A0010CE3AAFE0000CAFD1001EAD02000CB01F0036CC54000EFDA9 S31A0010CE4F7F000CAFFB000E1BFF0036CC62000EABFF001809001E S31A0010CE640032CC64001818010030CC5C0033CC5D000EABFF00A4 S31A0010CE791809000032CC5E001818010035CC5C000EABFE000EBE S31A0010CE8EACFF000C1BCF0036CC57000E2DFE000CAFDC000CAFF4 S31A0010CEA3CB0018AC020033CC52000CAFDB000CAF8C003ACC4F50 S31A0010CEB800397FA80023FFFF000CAFBD000CAFCE0004AC6700B6 S31A0010CECD0EABFF000CAFC0000EC090000CAFB1000ED1FE00045C S31A0010CEE2AF67000E1FF70030CC34000E1DFF0036CC36000E1E2D S31A0010CEF7FF0036CC3600191F000002CF0000181E000031CC3865 S31A0010CF0C000EAFFF0002CF00000EACFE0033CC33000EAC0000C9 S31A0010CF2133CC33000EAFFF0002CF00000EACFF0023FFFF003913 S31A0010CF367FAD0016AFFC000EA1BF000EA0AE0018AC6E0018AB24 S31A0010CF4B6D0018AE6F000EADFF000EAFF10002FF00000EAFEF04 S31A0010CF600002FF01003A7FBE000CAFCE000CAFBD000EA1FE007F S31A0010CF750EA0870018CE010018DD00000EA1BE000EA037001816 S31A0010CF8AAB04000E2BFD000E1BFF0036CC15000EA3BF000EA238 S31A0010CF9FAE001ACE4E001ADD4D000EABFE000EAC51003AC2F889 S31A0010CFB40002FB020002FC03000EA1FF000EA01C0018AE07000D S31A0010CFC918AD06000EAFFF0002FF00003AC49E0004AED1000492 S31A0010CFDEADD2000EAFFC0002FF00000EAF170002FF01003A7F60 S31A0010CFF3BE000CAFC4000CAFB5000EA3BF000EA2AE000CAF31AC S31A0010D008000CAF20001AAC5D0018CC5F001AAB5C0018DB5E004A S31A0010D01D0CCC44000CDB55000EA3FF000EA21C001AAE07001A2B S31A0010D032AD06001EAC03001EAB02003AC4D0000EF57F0032CB3B S31A0010D047DB000CB45F0036CBDB000EA1BF000EA0AE00183C4189 S31A0010D05C00187B400002F5000002F401000EAEFF000EADFB0077 S31A0010D0713A7FBE000CAFCE000CAFBD000EFD7F0036CBD9000EAA S31A0010D086AEFF000EADFF0033CBD1000EAEFF000EADFF000EA125 S31A0010D09BBF000EA0AE00180D6D0032CBD400181E6E0034CBD178 S31A0010D0B00018AE6E0018AD6D000EABFE000EACFE003A7FA60021 S31A0010D0C516AF0400397FAC0023FFFF00397FAD0016AFF50002D1 S31A0010D0DAFB020002FC030002FD040002FE05000EAFFE0002FF69 S31A0010D0EF06003AC2D0000E1CFF0036CB33000EA1FE000EA05438 S31A0010D104000CAF02000CAF13001B1F020002CF02001AAF02009B S31A0010D1190E1FFE0032CBB2000EAFEF0002DF01000EAFD80002EC S31A0010D12EDF000033CBA9000EA1BF000EA0AE000EA3FE000EA227 S31A0010D14354001AAF0200181F130035CBA9000EAFFF0002DF0210 S31A0010D158000EA1FE000EA0540018A8010018A900000EAF1700A7 S31A0010D16D037FFF000EAFFC00037FFF000CAF9D000CAF8E003902 S31A0010D1827FD80016AF020002FD090002FE0A0002FD070002FE4C S31A0010D19708001EA203001EA302001AAE01001AAD00001EAF047E S31A0010D1AC0002FF00001EAF050002FF01000CAF9B000CAF8C00E6 S31A0010D1C13A7FBE000EA1FE000EA0540002CB000002CC01000E73 S31A0010D1D6AF1700037FFF000EAFFC00037FFF000CAFCE000CAF69 S31A0010D1EBBD00397FD80016AF02000CAFDB000CAFEC001EA20305 S31A0010D200001EA302001AAF00000EFF7F0036CB74000CAF1B00A0 S31A0010D2150CAF0C000EADFC003A7FB2000EAFFF0002FF0600330F S31A0010D22ACB33000EA1BF000EA0AE0018A411000EA5FF000C1D69 S31A0010D23F5F0032CB6D000C1E4F0034CB61000EA1BE000EA037D0 S31A0010D2540018AB01000E2BBF000E1BFF0036CB39001EAF0900BB S31A0010D26902FF00001EAF0A0002FF010033CB510018A412000E95 S31A0010D27EA5FF000C1B5F0032CB5C000C1C4F0031CB33000EA1AD S31A0010D293BE000EA0370018AB01000E2BBF000E1BFF0036CB39AF S31A0010D2A8001EAF070002FF00001EAF080002FF01000CAF5B0099 S31A0010D2BD0CAF4C001EAE05001EAD04003A7FBE001EA003001E49 S31A0010D2D2A1020002CB000002CC01000CAF5B000CAF4C000EAE19 S31A0010D2E717000EADFC00397FDD000EA3FE000EA2540002DD0027 S31A0010D2FC0002DE01000EA1FF000EA01C0018AF01000EBFFB001E S31A0010D31102CF010033CB37000EAFFF0002FF06000EABFE000E62 S31A0010D326AC54000EADFC003A7FB2001EAC06000EABFF0016AF6D S31A0010D33B0B00397FAC0023FFFF00397FAD0016AFCE0002FB0C36 S31A0010D3500002FC0D0002FD0E0002FE0F000EAFFF0002FF1000BE S31A0010D3650EAFFE0002FF11000EAFFF0002FF220002FF230002CB S31A0010D37AFF240002FF250002FD260002FE27000EAFFF0002FF36 S31A0010D38F280002FF29000EAFFF0002FF2C0002FF2D000EA1BF9C S31A0010D3A4000EA0AE0018AC44000EABFF000EA1BF000EA0BD0069 S31A0010D3B918AE010018AD00003A7FB60002FB1A0002FC1B00021C S31A0010D3CEFB1C0002FC1D001EA20D001EA30C001AAF000002FF9E S31A0010D3E318001AAF010002FF19000EA1FE000EA087001EAC0F68 S31A0010D3F8001EAB0E00180B1D0032CAFD00181C1E0031CAFA00B3 S31A0010D40D02CB1D0002CC1E001EA00D001EA10C0018AC090018A3 S31A0010D422AB08001EAF0E0002FF00001EAF0F0002FF01000CAFB7 S31A0010D4376F000ECFF70002FF03000D5F7F0002FF02000EAFFFD9 S31A0010D44C0002FF04000EAFFF0002FF05001EAF370002FF0600E3 S31A0010D4611EAF380002FF07001EAE19001EAD18003AC532001E7C S31A0010D476AB36000E2BF7000E1BFF0036CADB000EAFFF0002FFBA S31A0010D48B0A0002FF0B000CAF64000EC4F7000D5F75000EA3BF27 S31A0010D4A0000EA2AE000CAF31000CAF20001AAC5D0018CC5F00D6 S31A0010D4B51AAB5C0018DB5E001CCC03001CDB020002EB02000205 S31A0010D4CAEC030002FB200002FC21000CAF5B000CAF4C001EAE23 S31A0010D4DF0D001EAD0C003AC7F70002FB120002FC13000E1B7F7E S31A0010D4F40032CABF000E1CFE0036C8C1001EA20D001EA30C00D1 S31A0010D5091AAC01001AAB00001A0B020032CAB8001A1C03003126 S31A0010D51EC8C1000CAF5B000CAF4C001EAE13001EAD12003AC581 S31A0010D533460002FB160002FC17001EA00D001EA10C00180B06A0 S31A0010D5480032CAAB00181C070034C8C1000CAF6F000ECFF7001B S31A0010D55D02FF2F000D5F7F0002FF2E001F1F100002FF10001EDC S31A0010D572AF19001ECF1B0002FF1F001EAF18001EDF1A0002FFA1 S31A0010D5871E001EAC1F001EAB1E001EA20D001EA30C001A0B02CA S31A0010D59C0032CA96001A1C030034CA91001AAF020002FF1E0020 S31A0010D5B11AAF030002FF1F001EAF1F001E3F190002FF1B001EC7 S31A0010D5C6AF1E001E7F180002FF1A001EAC1B001EAB1A001EAE09 S31A0010D5DB13001EAD12003AC0830002FB2A0002FC2B000EA1FFBA S31A0010D5F0000EA0470018AF150036CA780018AF150036CA680083 S31A0010D6050EA1BE000EA0370018AB03000E2BBF000E1BFF00368C S31A0010D61ACA68001EAC21001EAB20001EAE13001EAD12003AFEEB S31A0010D62F2C000CAFCE000CAFBD001EAF2A0002FF00001EAF2BB3 S31A0010D6440002FF01001EAC27001EAB26003AFE100002FB0E0086 S31A0010D65902FC0F001EA00D001EA10C0018AC090018AB08001E4D S31A0010D66EAF0E0002FF00001EAF0F0002FF01000CAF6F000ECFEE S31A0010D683F70002FF03000D5F7F0002FF02000EAFFF0002FF04D2 S31A0010D698000EAFFF0002FF05001EAF370002FF06001EAF380095 S31A0010D6AD02FF07001EAE1F001EAD1E003AC532001EAB36000E38 S31A0010D6C22BF7000E1BFF0036CA06000EA3BF000EA2AE001AAC59 S31A0010D6D746001AAB45000CCCCC000CDBBB001EAE29001EAD28AA S31A0010D6EC000C1DBF0032CA41000C1ECF0031CA06000CAFEC004D S31A0010D7011ECC2B000CAFDB001EDB2A000CAFCD000CAFBC000E22 S31A0010D716AFFF00397FD2000CAFE0000CAFD1000CAFC8000CAF4B S31A0010D72BB9000E887F001AAD46001AAC45000EAFFF00397FD2A7 S31A0010D74000037EFF00037DFF00037CFF00037BFF000CAF9B006E S31A0010D7550CAF8C000CAF1D000CAF0E00397FD50016AF04003A31 S31A0010D76A7FC5000EAFFF00037FFF000EAFFF00037FFF000EAF19 S31A0010D77FFF00037FFF000EAF7E00037FFF000E8C7F00397FD49E S31A0010D7940016AF04000CAFE0000CAFD1000CAFC8000CAFB90083 S31A0010D7A91EA22F001EA32E001AAD03001AAC02000EAFFE0039F1 S31A0010D7BE7FD2000370FF000371FF000378FF000379FF00397F5D S31A0010D7D3D90016AF0400397FD10002DD020002DE03000EA1BFCE S31A0010D7E8000EA0AE000CAF02000CAF130018AC5D001ACC5F00C9 S31A0010D7FD18AB5C001ADB5E001EA02F001EA12E0018CC030002CC S31A0010D812CC030018DB020002CB02000CAF1B000CAF0C001EAEEF S31A0010D8270D001EAD0C003AC7F70002FB140002FC15001EAC2FDD S31A0010D83C001EAB2E001EAE15001EAD14003AC546000CAFC40046 S31A0010D8510CAFB5000EA3BF000EA2AE000CAF31000CAF20001A8D S31A0010D866AC410018CC43001AAB400018DB42000C05BF0032C97E S31A0010D87BDF000C14CF0031C9B6000EA1BE000EA0370018AB02ED S31A0010D890000E2BDF000E1BFF0036C9B6000CAF4F001E3F1700FA S31A0010D8A502FF31000CAF5F001E7F160002FF30001EAF1C00023D S31A0010D8BAFF00001EAF1D0002FF01001EAC2D001EAB2C001EAEA0 S31A0010D8CF1B001EAD1A003A7FBE001EA231001EA330000C03BF07 S31A0010D8E40032C9C4000C12CF0034C9B6001EAF1C0002FF0000D0 S31A0010D8F91EAF1D0002FF01001EAC2D001EAB2C001EAE1B001E27 S31A0010D90EAD1A003A7FBE000CAFC4001EC417000CAFB5001ED5D5 S31A0010D92316000CAF4F001E3F170002FF2D000CAF5F001E7F164A S31A0010D9380002FF2C001EAF1A0002FF1C001EAF1B0002FF1D008D S31A0010D94D1EAC15001EAB14000E1B7F0032C9A6000E1CFE00364C S31A0010D962C98A001E1417000CAFFC001EAB16000C7B5B000EFB7D S31A0010D9777F0036C99E000D9FCC000DCFBB000E0BF80032C99BB3 S31A0010D98C000E1C000030C991000EECEF00037FFF000EEBEF006A S31A0010D9A10CBFCB0016AC01001E0B160032C992001E1C170034B1 S31A0010D9B6C98E000EACFE000EABFF0033C98C000EACFF000EAB85 S31A0010D9CBFF000E1CFF0036C950001EAF110036C950001EAE1BA6 S31A0010D9E0001EAD1A000E0DFF0032C983000E1EFE0034C9500028 S31A0010D9F50D0FD1000D4FE00002F11A0002F01B001EA20D001ED9 S31A0010DA0AA30C001AA803001E3819001AA902001E791800037027 S31A0010DA1FFF000371FF000CAF9D000CAF8E00397FD80016AF0272 S31A0010DA34001EAC10000CAFCB000E6BFE000CCECC000CDDBB00A6 S31A0010DA490E0BFF0032C96A000E1CD80034CAA5000EABFE001EBB S31A0010DA5EAF10000E0FD80030C963001EAB10000E4BD7000CAFC9 S31A0010DA73BC000E6BFE00037CFF00037BFF000CAF9D000CAF8EB9 S31A0010DA8800397FD80016AF02001E1D1A0032C955001E1E1B0020 S31A0010DA9D32C955001F1E1B001F5D1A0002FD1A0002FE1B000EDE S31A0010DAB2AFFF0002FF110033CAA5001EAF29001ECF2B0002FFD8 S31A0010DAC729001EAF28001EDF2A0002FF28001EAC15001EAB140A S31A0010DADC000E1B7F0032C944000E1CFE0036C8CA001EA00D007D S31A0010DAF11EA10C001805060032C93F001814070034C8F3001FA1 S31A0010DB060B16001F4C17000D0F5D000D4F4E000CCECC000CDD9F S31A0010DB1BBB001EAE1B001EAD1A00397FDC001ECE250002FE258E S31A0010DB30001EDD240002FD24001EDC230002FC23001EDB22002F S31A0010DB4502FB22001EA21F001EA31E001803020032C928001880 S31A0010DB5A12030031C914001EAF0E0002FF26001EAF0F0002FF9E S31A0010DB6F270002F3180002F219001EAF140002FF12001EAF1574 S31A0010DB840002FF130002F5160002F417001EA02F001EA12E006E S31A0010DB9918AF020002FF200018AF030002FF210033CAA5001ECB S31A0010DBAEA20D001EA30C001AAF03001A3F010002DF03001AAFFD S31A0010DBC302001A7F000002DF02000EA1BD000EA0760018AE174C S31A0010DBD8000EADFF000EAC17000EABFC00397FDD000CAFDC00B6 S31A0010DBED0E6CFE000CAFCB00037EFF00037DFF00037CFF00038F S31A0010DC027BFF001EAE29001EAD28001EAC27001EAB2600397FFD S31A0010DC17D60016AF04001EA00D001EA10C0002CD040002CE0505 S31A0010DC2C0033C8B9001EA20D001EA30C001AAC07001E3C170041 S31A0010DC411AAB06001E7B16001E34170002F401001E7516000233 S31A0010DC56F500001EAE1B001EAD1A003A7FBE0002FB1A0002FC56 S31A0010DC6B1B001ECC19001EDB18001EA00D001EA10C00183C0174 S31A0010DC800002CC0300187B000002CB02001EAC170018CC07007A S31A0010DC951EAB160018DB06000D0FBB000D4FCC001EAE1B001E88 S31A0010DCAAAD1A00397FDC001ECE250002FE25001EDD240002FDA0 S31A0010DCBF24001EDC230002FC23001EDB220002FB220033C90C96 S31A0010DCD4001EA20D001EA30C001EAF19001A3F010002DF030067 S31A0010DCE91EAF18001A7F000002DF020033C90C001EA00D001EBE S31A0010DCFEA10C000EAFFF0002CF040002CF05000EAFFF0002CF5A S31A0010DD13020002CF030016AF3200397FAC0023FFFF00397FAD2E S31A0010DD280016AFE8000CAFB9000CAFCB000CAFDC0002FE0D0085 S31A0010DD3D0EA5BF000EA4BD001CAF000002FF12001CAF0100022E S31A0010DD52FF130000FE62000EA1BF000EA0AE0018CC410002FC47 S31A0010DD670A0018DB400002FB09000EA1FF000EA01C0018AB0112 S31A0010DD7C000EEBDF000E2BFE000CAFBC000CAF9B003AE9190064 S31A0010DD9102FB070002FC08000EAFFE0002FF0B000EAF51000286 S31A0010DDA6FF0C000CAF5B000CAF4C003AC0D70002FB050002FC59 S31A0010DDBB06000EA5FE000EA487001CAF000002FF03001CAF01B2 S31A0010DDD00002FF04000EA1FF000EA01C0018AE070018AD060013 S31A0010DDE51EAF0D0002FF00001EAF1C0002FF01001EAF1D000261 S31A0010DDFAFF02000CAF6C000ECCFC000D5F7B003ACB2E003AC1EB S31A0010DE0F61000CAFCE000CAFBD001EAB0D000E2BF7000E1BFF58 S31A0010DE240032C86C001EAF05001EBF060032C86C001CAF170070 S31A0010DE390EFF7F0032C7FA001CAF17001CBF180036C7FA000073 S31A0010DE4EFF59001EAB0D000E2BF7000E1BFF0036C86200040DB2 S31A0010DE635D0032C86400041E5C0034C8620000FE590004AF599A S31A0010DE780036C83500041E5C000CAFFC0004AB5D000C7BDB00A9 S31A0010DE8D1EAE13001EAD1200397FDC000EEDFB000EECFB000C23 S31A0010DEA2BFDE000E6BFB000CBFCD000CAFBC000E6BFD0002FBC2 S31A0010DEB7140002FC150002FD160002FE17001EAF160002FF0EFB S31A0010DECC001EAF170002FF0F000EA1BF000EA0AE0018A841006C S31A0010DEE118A940000EA1BD000EA0760018AE17000EADFF000EE0 S31A0010DEF6AC17000EABFC00397FDD0002FD000002FE01001EAC2A S31A0010DF0B17001EAB16000CAF9D000CAF8E003A7FBE0002FB10D0 S31A0010DF200002FC110033C82D001EAF050002FF0E001EAF0600EB S31A0010DF3502FF0F001EAF070002FF10001EAF080002FF11000ED7 S31A0010DF4AABBF000EACBD003AC0D70002FB050002FC06000EA541 S31A0010DF5FFE000EA487001CAF000002FF03001CAF010002FF04C0 S31A0010DF74000EAFFF0002FF070002FF08000EA1FF000EA01C003D S31A0010DF8918AE070018AD06001EAF0D0002FF00000EAFFC00023F S31A0010DF9EFF01000EAF170002FF02000CAF6C000ECCFC000D5F18 S31A0010DFB37B003ACB2E001EAC06001CCC14001EAB05001CDB13F1 S31A0010DFC8000CAFCE001CCE01000CAFBD001CDD00000EFD7F00BF S31A0010DFDD36C802000EABFF000EAC0E000EAEFF000EADFF0033F1 S31A0010DFF2C800000EABFF000EAC0E003AFB06001EAE11001EADD9 S31A0010E00710001EAC0F001EAB0E003AC1570016AF1800397FAC9B S31A0010E01C0023FFFF00397FAD0016AFF4000CAFC2000CAFB300AF S31A0010E0310CAFE4000CAFD5000EAFFE0002FF03000EAF7F000298 S31A0010E046FF02001CAF04000EFF7F0036C700000EA1FF000EA0FA S31A0010E05B1C0018AB01000E2BF7000E1BFF0036C7050018AB3469 S31A0010E070000E2B7F000E1BFF0032C705001AAF02000EFF7F0050 S31A0010E08532C718001AAF02001ABF030036C718001AAE01001AC0 S31A0010E09AAD00000CAFDC000E6CFE000CAFCB000EECFD000CAF67 S31A0010E0AFFB000EEDFD000CAFFC000CBBDB000EEEFD000CAFFD49 S31A0010E0C4000CBCEC000EAEFF000EAFFE00397FCD000CAFE000E7 S31A0010E0D90CAFD1000CAFC8000CAFB9001AAD03001AAC02000EF9 S31A0010E0EEAFFE00397FD200037EFF00037DFF00037CFF00037BD5 S31A0010E103FF000CAF9B000CAF8C000CAF1D000CAF0E00397FD527 S31A0010E1180016AF040002FB040002FC050002FD060002FE070003 S31A0010E12D1CAC05001CAB04001AAE03001AAD0200397FDC000EF9 S31A0010E142AFFE00397FCD000CAFE0000CAFD1000CAFC8000CAF1B S31A0010E157B9001AAC01001AAB00001AAE01001AAD0000397FDC34 S31A0010E16C000EAFFE00397FCD00037EFF00037DFF00037CFF00CB S31A0010E181037BFF000CAF9B000CAF8C000CAF1D000CAF0E00397F S31A0010E1967FD50016AF040002FB080002FC090002FD0A0002FE2C S31A0010E1AB0B000EA1BD000EA0760018AE17000EADFF000EAC1746 S31A0010E1C0000EABFC00397FDD000CAFDC000CAFED000EAFFE00F0 S31A0010E1D5397FD2000EAFFF00037FFF000EAFFF00037FFF000E0D S31A0010E1EAAFFF00037FFF000EAF7C00037FFF00397FD90016AFCB S31A0010E1FF04000EAFFF00037FFF000EAFFF00037FFF000EAFFFBB S31A0010E21400037FFF000EAF8800037FFF00397FD90016AF04003E S31A0010E2291EAF0B00037FFF001EAF0B00037FFF001EAF0B00033D S31A0010E23E7FFF001EAF0B00037FFF00397FD90016AF040002FB87 S31A0010E253080002FC090002FD0A0002FE0B000CAFBF0036C75AAC S31A0010E268000EFC7F0036C75A000E1B7E0032C75B000E1C7F0007 S31A0010E27D32C75B000E1DFF0032C75B000E1EFF0036C6FD003050 S31A0010E292C6FD000EAFFF00037FFF000EAFFF00037FFF000EAF67 S31A0010E2A7FF00037FFF000EAF7E00037FFF001EAE0F001EAD0E5C S31A0010E2BC001EAC0D001EAB0C00397FD40016AF04003A7FC300BA S31A0010E2D10EAFFF00037FFF000EAFFF00037FFF000EAFFF0003E9 S31A0010E2E67FFF000EAF7E00037FFF000E8C7F00397FD40016AF69 S31A0010E2FB04001EAF0700037FFF001EAF0700037FFF001EAF0776 S31A0010E31000037FFF001EAF0700037FFF00397FD90016AF0400B2 S31A0010E32502FB040002FC050002FD060002FE07000CAFBF00360D S31A0010E33AC725000EFC7F0032C725000E1B700032C726000E1C43 S31A0010E34F800032C726000E1D010032C726000E1EFF0036C6FD95 S31A0010E3640030C6FD001EAE05000E8E7F001EAD04001EA9060013 S31A0010E3791EA807000CAFDB000CAFEC000CAF9D000CAF8E003995 S31A0010E38E7FD10002FD020002FE030033C6FD000EA1BD000EA000 S31A0010E3A3760018AE17000EADFF000EAC17000EABFC00397FDD27 S31A0010E3B8000CAFDB000CAFEC001CAE05001CAD04001AAF000098 S31A0010E3CD02FF00001AAF010002FF01003A7FBE0002FB020002E0 S31A0010E3E2FC030033C6FD001CAF040002FF02001CAF050002FF78 S31A0010E3F7030033C6FD000EAFFF0002FF020002FF03001EAC0372 S31A0010E40C001EAB020016AF0C00397FAC0023FFFF00397FAD005F S31A0010E42116AFEC000EA1BE000EA05C000EA3BF000EA2BD001AB1 S31A0010E436AF030002FF12001AAF040002FF130018AF060001BF88 S31A0010E44B5F0018AF070001BF5E000EACFF000EABFF000EAE59D5 S31A0010E460000EADF4003AC077000CAFC4000CAFB5000EACFF00C9 S31A0010E4750EABBF000EAE59000EADF4003AC0770002FB000002D0 S31A0010E48AFC010002F5020002F403001EAC13001EAB12000EAE04 S31A0010E49F59000EADF4003AC03D0002FB0E0002FC0F000CAF6FD1 S31A0010E4B4000ECFF10002FF0D000D5F7F0002FF0C000EAFFF00AD S31A0010E4C902FF040002FF05000EA1BF000EA0BD0018AE01001865 S31A0010E4DEAD00000D9FCC000E5BBF00397FDC000ECDDF000D5F0C S31A0010E4F3CC000D5FBB000EEDFB000EECFB000CBFDE000E6BFB03 S31A0010E508000CBFCD000CAFBC000E6BFD0002FD060002FE070057 S31A0010E51D0EA3BD000EA276001AAF100002FF08001AAF11000281 S31A0010E532FF09001AAC11001AAB10000EAFEF0002FF01000EAF9F S31A0010E547D80002FF00000EAEEF000EADF1003A7FBE0002FB08FD S31A0010E55C0002FC09000EA1BF000EA0AE0018AF410018CF57007D S31A0010E57102FF0B0018AF400018DF560002FF0A000EA5FF000E54 S31A0010E586A41C001CAF34000EBF7F0002EF34000EAFF70002FF85 S31A0010E59B00000EAFFC0002FF01000EAF170002FF02000CAF6C9C S31A0010E5B0000ECCFB000D5F7B000EAE59000EADF4003ACB2E008D S31A0010E5C51CAF34000E2F800002EF34001EAC07001EAB06000E9C S31A0010E5DAA1BD000EA0760018AE0D0018AD0C003A7FBA0002FB80 S31A0010E5EF100002FC11001CAC2D001CAB2C000EA3BD000EA27666 S31A0010E604001AAE12000EADFF000EAFFF0002FF00000EAF9B0042 S31A0010E61902FF01003A7FBE001EAE11001EAD10000C0DBF00329B S31A0010E62EC672000C1ECF0031C667000EA1BE000EA0370018AB1D S31A0010E64302000E2BBF000E1BFF0036C667000EABFF000EAC01B4 S31A0010E658000EADEF003A7FA4000EABFE000EACF0001EAE110052 S31A0010E66D1EAD10003AFB060000FF610016AF1400397FAC0023AC S31A0010E682FFFF00397FAB000EA1BF000EA0BD0018AC02000E2C33 S31A0010E697FC000E8CFD000D9FFB000CBBCB000CAFB5000EE5FD2C S31A0010E6AC003AC0FA000E1CFF0036C650000EA5FF000CAF5C0011 S31A0010E6C10EABFF00397FAA0023FFFF00397FAD0016AFF90002CE S31A0010E6D6FB020002FC030002FD040002FE05001EA20D001EAC7C S31A0010E6EB0C001EAB0B000CBCBF0032C63F000EACFE000EABFFF6 S31A0010E7000002FB0B0002FC0C000EA1BF000EA0AE001812530095 S31A0010E71530C6200033C623000CAF2C000EABFF000CCCCC000C58 S31A0010E72ADBBB000CAFC4001EC403000CAFB5001ED502001CAC9D S31A0010E73F01001CAB00001EAF0B0002FF00001EAF0C0002FF0133 S31A0010E754001EAE05001EAD040002F206003A7FBE0002EB00009C S31A0010E76902EC01001EA206000DBF22000E12000032C638001F73 S31A0010E77E8C05001F8B04000CAFBC000EECFD000EABFF0016AF46 S31A0010E7930700397FAC0023FFFF00397FAD0016AFF80002FB02AE S31A0010E7A80002FC030002FD040002FE05001EAE0D001EAD0C008D S31A0010E7BD0CBEDF0032C60C000EAEFE000EADFF0002FD0C000203 S31A0010E7D2FE0D001EAC05001EAB04003ACBCB0002FC06001EACD7 S31A0010E7E70E000EABFF000CCCCC000CDBBB000CAFC0001EC0039F S31A0010E7FC000CAFB1001ED102001EA205001EA304001AAF000042 S31A0010E81102CF00001AAF010002CF010033C5E2001EAC0E000EAF S31A0010E826ABFF000CCCCC000CDBBB000CAFC4001EC403000CAFB8 S31A0010E83BB5001ED502001CAC01001CAB00001EA005001EA104F2 S31A0010E8500018AE010018AD00001EAF0C0002FF00001EAF0D005D S31A0010E86502FF01003A7FBE0002EB000002EC01001F1F0E0002E5 S31A0010E87AFF0E000E1FF10034C5F7001EAC06000EABFF0016AF0B S31A0010E88F0800397FAC0023FFFF00397FA90016AFFE0002FB01AF S31A0010E8A4003AC2B4000CAFC0000CAFB10018AF00001E1F0100AD S31A0010E8B936C5BE0018AF01000E1FAA0032C5BE0018AF00000E52 S31A0010E8CE1FAA0036C5C70018AF00000E1FFA0032C5BE000D1FC5 S31A0010E8E36E000D5F7D000EAFFF0002FF00000EABFE000CAFDCA8 S31A0010E8F8000CAFED000EAEE7003AFD1F0016AF0200397FA8002D S31A0010E90D23FFFF00397FAD0016AFFC000CAFC4000CAFB5003A6F S31A0010E922C2D0000E1CFF0032C5A7000EAFAA0002EF00000EAF5C S31A0010E937AA0002EF01003AC2B40002FB000002FC01000EACDFD4 S31A0010E94C000EABFF000CAF5D000CAF4E003AFDBB0033C5760067 S31A0010E9610EAFE70002FF03000EAFE70002FF02003AC2B4000C80 S31A0010E976AFC0000CAFB10018AF01000E1FAA0032C59A000EAFAE S31A0010E98BE50002FF020033C598000EAFE50002FF03003AFBB25C S31A0010E9A0001EAB02003AFD04000CAF4E000ECEFD000D5F5D009B S31A0010E9B50EAFFD0002FF00000EABE1000CAFDC000CAFED001E85 S31A0010E9CAAE02003AFD1F000EAFFF0002EF00000EAFAA0002EF17 S31A0010E9DF01000EAFFF0002FF00000EABFD000CAF5C000CAF4D7A S31A0010E9F4001EAE02003AFD1F000EAFFF0002EF01000EAFFF006A S31A0010EA0902FF00000EABFD000CAF5C000CAF4D001EAE03003A03 S31A0010EA1EFD1F003AFBAB0016AF0400397FAC0023FFFF00397FCB S31A0010EA33AD000CAFC4000CAFB5000EA1BF000EA0BD0018AE0677 S31A0010EA480018AD05000EABFF000EAC66003AC546000CAF5D00A4 S31A0010EA5D0CAF4E00397FDC00397FAC0023FFFF00397FA90016F5 S31A0010EA72AFF8000EA1FE000EA0870018AE010018AD00000EA1B5 S31A0010EA87FF000EA01C0018AF060002FF000018AF070002FF01FD S31A0010EA9C000EAFFF0002FF02000EAF660002FF03000EAFFE00AE S31A0010EAB102FF04000EAFFE0002FF050004AFD20002FF060004E4 S31A0010EAC6AFD10002FF07000EABFE000EAC51003AC5320016AFE5 S31A0010EADB0800397FA80023FFFF00397FAD0016AFFE000CAFC4E0 S31A0010EAF0000CAFB5001CAC03001CAB02000EAFFF0002FF010039 S31A0010EB050EAFFB0002FF00003A7FBE001CCC01001CDB00000EC7 S31A0010EB1AFB7F0036C535000EACFF000EABFF0016AF0200397F36 S31A0010EB2FAC0023FFFF000374FF00397FA90016AFFC001EA40B89 S31A0010EB44003AC2F80002FB020002FC03001EAE08001EAD07000C S31A0010EB593AC4D0001EA00A001EA1090002CB000002CC01000E89 S31A0010EB6EAFFF0002FF00001EAC03001EAB02001EAE08001EAD96 S31A0010EB8307003AC49E001EA20A001EA3090002DB020002DC0370 S31A0010EB98000EAFFC0002FF00000EAF170002FF01001EAE0E00E8 S31A0010EBAD1EAD0D003A7FBE001EA00A001EA1090002CB0200028D S31A0010EBC2CC03000E14FF0036C502000EA1BF000EA0AE001EA2B1 S31A0010EBD70A001EA309001AAF030018CF5F0002DF03001AAF027E S31A0010EBEC0018DF5E0002DF02001EAF0C0036C4F6000EA1BF008F S31A0010EC010EA0AE001EA20A001EA309001AAF030018CF5D0002E6 S31A0010EC16DF03001AAF020018DF5C0002DF020016AF0400397F6F S31A0010EC2BA80016A4010023FFFF00397FAD0016AFF80002FB0417 S31A0010EC400002FC05000CAFE4000CAFD5001EAF0C0001BF5F007F S31A0010EC551EAF0D0001BF5E000EACFF000EABFF003AC0770002B8 S31A0010EC6AFB060002FC07000EACFF000EABBF000CAF5D000CAF75 S31A0010EC7F4E003AC0770002FB000002FC01001EAF060002FF02D9 S31A0010EC94001EAF070002FF03001EAC05001EAB04000CAF5D00C9 S31A0010ECA90CAF4E003AC03D0016AF0800397FAC0023FFFF003975 S31A0010ECBE7FAD0016AFFA0002FB000002FC010002FD020002FE43 S31A0010ECD303000CAF7B000CAF6C003AC0B5000EABFF000CCCC4B3 S31A0010ECE8000CDBB5000CAF4C000ECC38000CAF5B000EDBBF008E S31A0010ECFD1EAE01001EAD00003AC0CB0002FB040002FC05000C7F S31A0010ED12AF4C000ECCE8000CAF5B000EDBBE001EAE01001EADC4 S31A0010ED2700003AC0CB001EAE03000ECEAB001EAD02000EDD0AE4 S31A0010ED3C00397FDC000ECDBF000D5FCC000D5FBB000EEDFD0027 S31A0010ED510EECFD000CBFDE000E6BFD000CBFCD000CAFBC000E64 S31A0010ED666BFD000CAFEC001ECC05000CAFDB001EDB040016AF2C S31A0010ED7B0600397FAC0023FFFF00397FAB0016AFF80002FB00C5 S31A0010ED900002FC010002FD020002FE03001EAB0B000EAFFF00C5 S31A0010EDA502FF060002FF07000E1BFF0036C48C000EA1BF000E0A S31A0010EDBAA0AE0018AF5D0002FF070018AF5C0002FF06000CAFCF S31A0010EDCF7B000CAF6C003AC22F000CAFC50032C47D0004AF6046 S31A0010EDE40036C47D003AC2C1000CAFC0000CAFB10018AF04001E S31A0010EDF902FF040018AF050002FF050033C46F003AC2C1000CE9 S31A0010EE0EAF5E000EADFF000CCEEE000CDDDD000ECEFD000D5F3F S31A0010EE23DD000CCECC000CDDBB001EAE01001EAD00003AC245C4 S31A0010EE380002FB040002FC05001EAC03001EAB02003AC2B10066 S31A0010EE4D0CAF5E000EADFF000CCEEE000CDDDD000CCECC000C87 S31A0010EE62DDBB001EAE01001EAD00003AC245000CAFCE000CAFD0 S31A0010EE77BD001EAC03001EAB02003AC431000CAFE0000CAFD1C5 S31A0010EE8C000CAFC8000CAFB9001EAD05001EAC04000EAFFE000B S31A0010EEA1397FD2000370FF000371FF000378FF000379FF0039A9 S31A0010EEB67FD90016AF0400397FCF001EA007001EA106000CAF44 S31A0010EECB18000E68FE000CAF89000CC0E0000CD1D1000CD8C846 S31A0010EEE0000CD9B9000E09FF0032C43F000E18FF0032C43F00C4 S31A0010EEF50E11800032C43F000E10000034C43B000EAC00000E05 S31A0010EF0AAB800033C434000EF97F0032C436000CAF1B000CAF43 S31A0010EF1F0C0033C434000EACFF000EABFF0016AF0800397FAAF0 S31A0010EF340023FFFF00397FA9000ECCA5000EDB0B00397FDC0029 S31A0010EF490EAFFE00397FCD000EAFFF00037FFF000EAFFF000361 S31A0010EF5E7FFF000EAFFF00037FFF000EAF8E00037FFF00397F49 S31A0010EF73D90016AF04003A7FC500397FA80023FFFF00397FA971 S31A0010EF880016AFFE0002FD000002FE01000EAEFF000EADFB002A S31A0010EF9D3A7FBE0016AF0200397FA80023FFFF00397FAD00160F S31A0010EFB2AFF1000CAFC4000CAFB5003AC2A7000EABBF000EACD0 S31A0010EFC7BD000EADFE000EAE4D003AC0E90002FB0D0002FC0EA7 S31A0010EFDC000EAFFE0002FF0B000EAF4D0002FF0C000EAFFF0070 S31A0010EFF102FF030002FF04000EA1BF000EA0BD0018AF0000024A S31A0010F006FF050018AF010002FF06000EA1BF000EA0AE0018C466 S31A0010F01B410002F40A0018D5400002F509003AE7E0000CAFCBD5 S31A0010F030000EA5FF000EA41C001CAC01000EECDF000E2CFE005B S31A0010F0453AE9190002FB070002FC08001CAE07001CAD06000EAC S31A0010F05AAFF70002FF000004AFD20002FF010004AFD10002FFD8 S31A0010F06F02000CAF6C000ECCFC000D5F7B003ACB2E001EAF058B S31A0010F0840001BF5B001EAF060001BF5A001EA20C001EA30B00C1 S31A0010F09904AE5A0004AD5B000CAFDC000E6CFE000CAFCB000E91 S31A0010F0AEECBF000CAFFB000EEDBF000CAFFC000CBBDB000EEEC7 S31A0010F0C3BF000CAFFD000CBCEC000EAEFF000EA5BF000EA4BD5B S31A0010F0D8001CA001001CA100000CAF18000E68FE000CAF890008 S31A0010F0ED0370FF000371FF000378FF000379FF00397FD600167A S31A0010F102AF04001ACE010001BE5C001ADD000001BD5D000EA16A S31A0010F117BD000EA0760018A8010018A9000018AE17000EADFFD3 S31A0010F12C000EAC17000EABFC00397FDD0002FD000002FE01009D S31A0010F1411EAC0E001EAB0D000CAF9D000CAF8E003A7FBE000ECF S31A0010F156A1FE000EA0870002CB150002CC16001EAF0D0002CF49 S31A0010F16B13001EAF0E0002CF140016AF0F00397FAC0023FFFF4D S31A0010F18000397FAD000EA5FF000EA41C000EA3BF000EA2AE00B1 S31A0010F1951CA009001CA108001A01400032C395001A1041003045 S31A0010F1AAC37D000EA1FF000EA047000EAFFE0002CF14001CA0FB S31A0010F1BF09001CA108001A01400032C38B001A10410030C37DA1 S31A0010F1D4000EA1FE000EA0870018AF17000EFF7F0032C37D0052 S31A0010F1E918AF170018BF180036C37D000EACFF000EABFF000C3B S31A0010F1FEAFCE000CAFBD003AC15700397FAC0023FFFF00397F62 S31A0010F213A9000E1BF80030C35E000CAFBE000EADFF000CAFFCCB S31A0010F228000CAFFB000EECBF000CAFFB000EEDBF000CAFFC0025 S31A0010F23D0CBBDB000EEEBF000CAFFD000CBCEC000EAEFF000E14 S31A0010F252AFF600037FFF000EAFFF00037FFF000EAFFF00037FF0 S31A0010F267FF000EAFFF00037FFF00397FD60016AF04000CAFDB53 S31A0010F27C000CAFEC0033C33A000CAFBC000EABFF000ECC060081 S31A0010F2910DFFBB000CAFCE000CAFBD000CAFDC000E6CFE000C6F S31A0010F2A6AFCB000EECBF000CAFFB000EEDBF000CAFFC000CBB1C S31A0010F2BBDB000EEEBF000CAFFD000CBCEC000EAEFF000CCEEEA3 S31A0010F2D0000CDDDD000CDCCC000CDBBB000EAFC000037FFF00F9 S31A0010F2E50EAFFF00037FFF000EAFFF00037FFF000EAFFF0003C5 S31A0010F2FA7FFF00397FD60016AF04000CAFDB000CAFEC000ECCFD S31A0010F30F38000EDBCE00397FA80023FFFF00397FA9000CBCBF7B S31A0010F3240032C333000EA9FF0033C2FC000E0BC00032C33000F1 S31A0010F3390E1C000034C32D000EA9F10033C2FC000E0BCE0032A9 S31A0010F34EC32A000E1C390030C324000EAEF6000EADFF00397F09 S31A0010F363DC000EA9FF0033C304000ECCC6000EDB31000EAEC0BD S31A0010F378000EADFF00397FDC000CAFE0000CAFD1000CAFC80072 S31A0010F38D0CAFB9000D0F9B000D4F8C000D4F1D000D4F0E000E51 S31A0010F3A26BFB000CAFBE000E6BFD000CAFBC000CAFBD000EEB03 S31A0010F3B7FD000CAFBE000EADFF000EACFF000EABFF000CCE00B0 S31A0010F3CC000CDD11000CDC88000CDB99000D0F9B000D4F8C008D S31A0010F3E10D4F1D000D4F0E000EA9F8000EEDFB000EECFB000C78 S31A0010F3F6BFDE000E6BFB000CBFCD000CAFBC000E6BFD000CC981 S31A0010F40BE9000CAF9C000EABFF00397FA80023FFFF00397FA9FC S31A0010F420000CAFC2000CAFB3000EA1BF000EA0BD000CAFDC0066 S31A0010F4350E6CFE000CAFCB000EECBF000CAFFB000EEDBF000C79 S31A0010F44AAFFC000CBBDB000EEEBF000CAFFD000CBCEC000EAE67 S31A0010F45FFF0018AF0000037FFF0018A0010016A101000CAF18F7 S31A0010F474000E68FE000CAF89000370FF000371FF000378FF0056 S31A0010F4890379FF00397FD60016AF04000CAFEC001ACC01000CEC S31A0010F49EAFDB001ADB00000EFB7F0036C2D2000EACFF000EAB00 S31A0010F4B3FF00397FA80023FFFF00397FA9003AC2B4000CAFC022 S31A0010F4C8000CAFB1000EACFF000EABFF0018AF01000E1FAA009D S31A0010F4DD32C2C50018AF000032C2C3000EACFE000EABFF003924 S31A0010F4F27FA80023FFFF00397FA9003AC2B4000CAFC0000CAF60 S31A0010F507B10018AF01000E1FAA0036C2B8000EC0BF000D5F11CF S31A0010F51C000CAF1B000CAF0C00397FA80023FFFF000EABBC0031 S31A0010F5310EACFF0023FFFF000E0BF40032C2AE000E1C59003073 S31A0010F546C2AA000EABBE000EAC7A0033C2A8000EABBE000EACB5 S31A0010F55B980023FFFF00397FAD0016AFF80004AFA3000E1FFD2A S31A0010F5700032C29E0004ABBF000E2BFB000E1BFF0036C292008A S31A0010F5850EA1BE000EA0370018AB02000E2B7F000E1BFF00362E S31A0010F59AC292000EA1FF000EA01C0018AB34000E2BFD000E1B24 S31A0010F5AFFF0032C260000EA1BF000EA0BD000EA3BE000EA25C8A S31A0010F5C40018AF030002FF040018AF040002FF05000EA1FF00CE S31A0010F5D90EA01C0018A4070018A506001AAF060001BF5F001AAF S31A0010F5EEAF070001BF5E000EACFF000EABFF000CAF5D000CAFDA S31A0010F6034E003AC0770002FB060002FC07000EACFF000EABBFE4 S31A0010F618000CAF5D000CAF4E003AC0770002FB000002FC010039 S31A0010F62D1EAF060002FF02001EAF070002FF03001EAC05001E17 S31A0010F642AB04000CAF5D000CAF4E003AC03D000EA1FE000EA03B S31A0010F6574D0002CB000002CC01000EA3FF000EA21C000CAF3137 S31A0010F66C000CAF200018AF34000EBFFD0002DF34000EA3FE000F S31A0010F6810EA24D000EA1FF000EA01C0018AF060002DF02001821 S31A0010F696AF070002DF030016AF0800397FAC0023FFFF000D9FB1 S31A0010F6ABEE000E5DBF00397FDC000ECDDF000D5FCC000D5FBB6F S31A0010F6C0000EEDFB000EECFB000CBFDE000E6BFB000CBFCD007F S31A0010F6D50CAFBC000E6BFD000CAFDB000CAFEC0023FFFF000CB3 S31A0010F6EAAFC0000CAFB10018AC0300183C010018AB0200187BA6 S31A0010F6FF0000397FDC000ECDDF000D5FCC000D5FBB000EEDFB3D S31A0010F714000EECFB000CBFDE000E6BFB000CBFCD000CAFBC00A9 S31A0010F7290E6BFD000CAFEC0018CC01000CAFDB0018DB00002307 S31A0010F73EFFFF00397FAD000CAFC4000CAFB5000EA0FF000EA1F2 S31A0010F753FF000EA8FF000EA9FF001CAF00001CBF010032C22363 S31A0010F768000EA3FF0033C1DA001CAC01001CAB00000E0BC0008F S31A0010F77D32C21E000E1C000034C21B000EA3F10033C1DA001C88 S31A0010F792AC01001CAB00000E0BCE0032C216000E1C390030C292 S31A0010F7A70C000EAEF6000EADFF00397FDC000CAFE0000CAFD104 S31A0010F7BC000CAFC8000CAFB9000EA3FF0033C1E6001CAC0100D8 S31A0010F7D10ECCC6001CAB00000EDB31000EAEC0000EADFF00391D S31A0010F7E67FDC000CAFE0000CAFD1000CAFC8000CAFB9000D0F63 S31A0010F7FB9B000D4F8C000D4F1D000D4F0E000E6BFB000CAFBE90 S31A0010F810000E6BFD000CAFBC000CAFBD000EEBFD000CAFBE00F9 S31A0010F8250EADFF000EACFF000EABFF000CCE00000CDD11000CAD S31A0010F83ADC88000CDB99000D0F9B000D4F8C000D4F1D000D4F4B S31A0010F84F0E000CAFE0000CAFD1000CAFC8000CAFB9000EA3F8B9 S31A0010F864000D0F9B000D4F8C000D4F1D000D4F0E000EEDF70005 S31A0010F8790EECF7000CBFDE000E6BF7000CBFCD000CAFBC000E3D S31A0010F88E6BFD000CC3E3000CAF1B000E2BC0000CAF0C0002EBB2 S31A0010F8A3000002EC01000CAF3C000EABFF00397FAC0023FFFF17 S31A0010F8B800397FA90016AFFE000EA3FF000EA21C000EA1FE00D8 S31A0010F8CD0EA087001AA81D00183818001AA91C00187917000EFF S31A0010F8E2F97F0032C1C3000CB89F0032C1C0000EACFF000EAB45 S31A0010F8F7FF0033C1B3001AAC19001A3C23001AAB18001A7B2254 S31A0010F90C000C48CC000C59BB000EA1BE000EA0370018AE0A006E S31A0010F92118AD090002F9000002F801003A7FBE0016AF02003980 S31A0010F9367FA80023FFFF00397FA90016AFFE000EA1FE000EA0DF S31A0010F94B870018A8180018A917000EF97F0032C198000CB89FE6 S31A0010F9600036C198000EA1FF000EA01C000CAF8C00183C2300B7 S31A0010F9750CAF9B00187B22000EA1BE000EA0370018AE0A001822 S31A0010F98AAD090002F9000002F801003A7FBE0033C196000EACEB S31A0010F99FFF000EABFF0016AF0200397FA80023FFFF00397FADD9 S31A0010F9B40016AFFC000EA1FE000EA0870018AF170002FF0000A6 S31A0010F9C918AF180002FF01000EA5FF000EA41C001EAC01001EC9 S31A0010F9DEAB00001C0B1C0032C184001C1C1D0034C17F001CAF05 S31A0010F9F31C0002FF00001CAF1D0002FF01001EAC01001C3C239C S31A0010FA08001EAB00001C7B22003A7FC00002FB020002FC0300D8 S31A0010FA1D1CAC1D001C3C19001CAB1C001C7B18003A7FC0001E3F S31A0010FA32AE03001EAD02000C0DBF0032C16E000C1ECF0030C108 S31A0010FA4768001CAC1D001C3C19001CAB1C001C7B180033C164EC S31A0010FA5C001EAC01001C3C23001EAB00001C7B220016AF0400EE S31A0010FA71397FAC0023FFFF00397FA9000EA1FE000EA08700188A S31A0010FA86AE010018AD00000EABFE000EAC51003AC2F800397F73 S31A0010FA9BA80023FFFF00397FA90016AFFA0002FB020002FC0357 S31A0010FAB00002FD040002FE05000EA3BF000EA2AE001EAF030085 S31A0010FAC51A3F4E0002FF03001EAF02001A7F4D0002FF02001E95 S31A0010FADAAC05001A3C50001EAB04001A7B4F0002FB040002FCFA S31A0010FAEF05000EA1FE000EA087001EAF020002CF17001EAF037E S31A0010FB040002CF180002CB190002CC1A0004AF590032C12800F8 S31A0010FB1918AC140018CC010018AB130018DB00001ECC0300024C S31A0010FB2EFC03001EDB020002FB020018AC160018CC030018AB2F S31A0010FB43150018DB02001ECC050002FC05001EDB040002FB049D S31A0010FB580033C1100004A85A001A384E0004A95B001A794D00F0 S31A0010FB6D02F9020002F803000EA1BD000EA0760018A201001810 S31A0010FB82A3000018AE17000EADFF000EAC17000EABFC00397FE0 S31A0010FB97DD0002FD000002FE01000CAF9B000CAF8C000CAF3DD1 S31A0010FBAC000CAF2E003A7FBE0002FB040002FC05001EAF0200FB S31A0010FBC10EFF7F0036C107000EAFFF0002FF020002FF03000EBE S31A0010FBD6AFFF0002FF040002FF05000EABFF000EAC00001EAE0D S31A0010FBEB03001EAD02003AFB060004AF93000E1FFE0036C0FD80 S31A0010FC000000FD930000FF920016AF0600397FA80023FFFF006C S31A0010FC15397FAB000EA5FE003AC2B4000CAFC0000CAFB1001801 S31A0010FC2AAF01000E1FAA0032C0ED00198C00000D9FFB000CBB36 S31A0010FC3FCB000CAFB5000EE5FD000CAF5C000EABFF00397FAA3E S31A0010FC540023FFFF00397FA9000CAFE2000CAFD3000EA1FE002B S31A0010FC690EA0510018AE01001A3E010018AD00001A7D00000CE9 S31A0010FC7EAFC0000CAFB10018AC010018AB00000D9FEE000E5DF3 S31A0010FC93BF003AC25500397FA80023FFFF00397FA9000CAFC0D9 S31A0010FCA8000CAFB1000EA3FE000EA2510018AC010018AB00008D S31A0010FCBD1AAE01001AAD00003AC25500397FA80023FFFF000CAE S31A0010FCD2AFC0000CAFB10018AC0300183C010018AB0200187BB8 S31A0010FCE70000397FDC000ECDDF000D5FCC000D5FBB000EEDFB4F S31A0010FCFC000EECFB000CBFDE000E6BFB000CBFCD000CAFBC00BC S31A0010FD110E6BFD000CAFEC0018CC01000CAFDB0018DB00002319 S31A0010FD26FFFF00397FA9000CAFC2000CAFB3000EA0FF000EA10C S31A0010FD3BFF000EA8FF000EA9FF001AAF00001ABF010032C0A9F5 S31A0010FD50000EADFF0033C08C001AAC01001AAB00000E0BC000EA S31A0010FD6532C0A4000E1C000034C0A1000EADD80033C08C001AF2 S31A0010FD7AAC01001AAB00000EAED8000EADFF00397FDC000CAF4F S31A0010FD8FE0000CAFD1000CAFC8000CAFB9000D0F9B000D4F8C47 S31A0010FDA4000D4F1D000D4F0E000EEDF7000EECF7000CBFDE00C5 S31A0010FDB90E6BF7000CBFCD000CAFBC000E6BFD000CAFED000C76 S31A0010FDCEAF1B000E2BC0000CAF0C0002DB000002DC01000CAF09 S31A0010FDE3DC000EABFF00397FA80023FFFF00397FA90016AFFEBC S31A0010FDF8000D9FEF0002FF01000DCFDF0002FF00000EAEEF00DC S31A0010FE0D0EADF1003A7FBE0016AF0200397FA80023FFFF003926 S31A0010FE227FAD0016AFF8000CAFC4000CAFB50002FD060002FED8 S31A0010FE3707003AC4D00002FB020002FC03000EAFFE0002FF000F S31A0010FE4C000CAF5B000CAF4C001EAE07001EAD06003AC49E002E S31A0010FE6102FB040002FC050004AE5E0004AD5F000EAFFF000294 S31A0010FE76FF01000EAFFB0002FF00003A7FBE001ECC03001EDB4B S31A0010FE8B02000EFB7F0036C058000EACFF000EABFF000CAFCE7A S31A0010FEA0000CAFBD0004AF5F000EFF7F0032C0420004AF5F00DB S31A0010FEB504BF5E0036C042000CAFEC001E3C03000CAFDB001E11 S31A0010FECA7B02000EA1BE000EA01F00180B0A0032C04700181CBC S31A0010FEDF0B0034C042001EAE030018CE0B001EAD020018DD0A2B S31A0010FEF4000CAFDB000CAFEC0016AF0800397FAC0023FFFF0054 S31A0010FF09397FA90016AFFA001E0B0A0032C038001E1C0B0035D6 S31A0010FF1EC034000EACFF000EABFF0033C01E001E0B080032C01F S31A0010FF3331001E1C090030C02D000EACFF000EABBF0033C01ED0 S31A0010FF480000FF60000EAFFF0002FF01000EAFBF0002FF0000F4 S31A0010FF5D02FB020002FC030002FD040002FE05000EABC0000EEA S31A0010FF72AC77000EAEFF000EADFF003A7FBB0000FE600016AF35 S31A0010FF870600397FA80023FFFF00397FA9003AC2B4000CAFC03C S31A0010FF9C000CAFB10018AF01000E1FAA0032C012000EC0BF009E S31A0010FFB10D5F11000CAF1B000CAF0C00397FA80023FFFF003F4B S31A0010FFC6FFFF003FFFFF003FFFFF003FFFFF003FFFFF003FFFE0 S31A0010FFDBFF003FFFFF003FFFFF003FFFFF003FFFFF003FFFFFCB S3150010FFF0003FFFFF003FFFFF003FFFFF003FFFFFF7 S70500100000EA
  • Hello Adrian,
    I compared the srec files and I still might see that it is an issue with corruption of the srec file. I will need to do more testing. Can you send me the unseal and full access keys for the device. If you want, you can send me a friend request and send them to me privately.
    Adrian
  • Hi Adrian:
    Per your request we have shared with you the unseal and full access keys several days ago, and have been waiting for your updates w.r.t your internal testing which you mentioned would be finished yesterday. However till now we are still waiting for the testing result to be shared with you.
    Would you please give us some updates whether the testing are making any progress or not.
    Our whole program has been delayed significantly due to this ongoing issue,  we'd sincerely appreciate if you can help us find out the root cause so we know the direction on how to solve it.
  • Hello Yichong,
    Yes, I have finished testing and discussed with members on my team and have determined that the unusually update to the Ra table is most likely caused by the Qmax value not being updated frequently. If Qmax does not update within a certain amount of cycles then it cause this sort of behavior. To know why Qmax was not updating, we would need a historical log file throughout the lifetime of the battery.
    Adrian
  • Hi  Adrian:
    we can't get the exact log data for the failure sample, but we can run some cycles in our side , please tell me how many data you need if this is Ok for you, thanks!
  • Hi  Adrian:
           may I know how the Qmax update affect to the Ra- table update?
  • Hello Yichong,
    Yes, run a test with 10 cycles, and make sure to log every register from the gauge. Qmax updates should also occur when the Ra table updates. So if Qmax is not updating, then resistance values will start to update irregular as it is not being compensated for the decreasing Qmax value. If possible can record the entire Ra table after each cycle.
    Adrian
  • HI  Adrian, I've sent you the data few days ago , have you checked checked it or when do you think we can get the respond ?
    Thank you for your patience. There was a lot of data to look over. In this test Qmax does not update after a full discharge because the battery needs to have a proper relaxation after discharge. There is a short rest period between discharge and the next charge. If this was the same behavior that was experienced in the end equipment then this would explain why the Ra table update irregularly.
    Regards.
    Adrian
  • Hi Adrian, thanks for your feedback, I've sent you another data that cycling with enough relax time but the Qmax still not update, please kindly look into the data and help to find out why it perform like that.
  • Hello yichong,
    I checked the data and the OCVTAKEN bit gets set after the discharge so there should be Qmax updates. You did not record the Qmax so I can not verify if it updates or not (it could also possible update to the same value). However, I can see that Full Charge Capacity updates during the test.
    Adrian
  • Hi Adrian, yes I also see the FCC updated during the cycle,  and I'm curious in what condition the Qmax may update to same value?
  • Hello Yichong,
    It is very highly unlikely that Qmax will be the same as FCC. These values represent 2 different things. Qmax is a theoretical (ideal) capacity of the battery. If the battery you were using did not have any internal resistance then the Qmax value represents how much charge is available. We know this is not the case in the real world and batteries has an internal impedance. This causes there to be a IR drop in the battery. Thus, you will never truly discharge the entire Qmax value. This is where Full Charge Capacity value comes in. FCC is the practical capacity of the battery taking into count many factors including internal impedance and the load current.
    Adrian
  • Hi  Adrian, thanks for explaination,
    still not clear why it seems like the update condition was achieve but the Qmax still not update, in the failure samples it seems the Qmax doesn't update but the FCC update irregularly , so just want to know why Qmax not update is the reason affect the Ra-table but not FCC?
    in addition:
    1、you mentioned that Qmax not update may cause the irregularly update of Ra-table, but we have test for more than 20 cycles still cannot  reproduce it, could you advise how many cycles may detect it?
    2、
    3、we've few failure samples on hands, can send to you for analysis is it can help you , please kindly advice, thanks!
  • Hello Yichong,
    Ra-table table uses the Qmax value in it calculations for updating the Ra resistance values.
    1. I do not know how many cycles it will take for this to replicate. It could be on the order of hundreds or thousands of cycles. To partial answer that, approximately how many cycles was the devices in service before the issue was reported?
    3. Regarding sending in samples for our analysis, you can contact your local FAE to learn about this process.
    Adrian
  • Hi  Adrian,
    appreciate for your feedback, but could you please how the Qmax update will affect the update of Ra table?
    in addition, do you have idea how to reproduce the failure?
  • Hello Yichong,
    Please read section 2.4 of this document: https://www.ti.com/lit/an/slua364b/slua364b.pdf
    Adrian
