Part Number: TPSF12C1
Dear e2e Support,
You will find below a customer case I'm not able to reproduce on my side, so I guess the issue comes from PC or windows settings (note that the macro are enabled).
Could you help to investigate on what happen?
Every change I do on the file, even rewriting into a yellow filed with the same value, I obtain a flat “loop gain and stability” graph and a strange effect on “AEF impedance” graph.
If I change “grid side Y2 capacitance” from 2,2nF to 0,1nF I get a message saying “It is not possible to draw negatives or zero values in logarithmic plots” (italian translation from the above screen shot)
Could this issue be caused by the localization settings? (need to change “.” decimal with “,”).
Maybe some macro crash for this?
