Other Parts Discussed in Thread: LM3644, LM36010, TPS92201, LM3645
Hi Sir,
In the Torch or Flash mode, is the LM3553 support the long time turn-on function?
Hi Henry,
Our expert will give you reply later.
Hi Henry,
Our expert is out of office. He will reply to you later.
BR, Gracie
Hi Henry,
Sorry for the delayed reply! Torch mode can support long time turn on. Flash mode would have a duration of time.
Could you please share your end equiment application and run rate? I may recommend a latest suitsable solution for you.
Thank you!
John.
Hi Sir,
The customer changed the product spec, if there have the LED driver torch mode can support up 1A(1-ch supported 1A, or 2-ch each supported 0.5A) and use I2C to adjust the torch current, please advise.
Application: Biometric product
Run Rate: 20Ku/Yr
Hi Henry,
Sorry, we do not have such large current device supporting I2C. If the customer accept other brightness control method such as PWM input, I would recommend TPS92201.
Thanks!
John.
Hi Henry,
I have another recommendation to you. It is LM3645, RTMed next month. 4-ch flash, 360mA torch per-channel. I think customer could shunt 4 channels together to use.
Thanks!
John.
