Gauge team,
Our customer is working with BQ34Z100 in a battery pack. The fuel gauge pulls the clock line low indefinitely and the only way to get it to release is a power cycle of the gauge.
The clock is running at 100kHz.
First, can you confirm if this gauge implements clock stretching? I don't see it in the datasheet, while it is mentioned in the datasheet of other gauges. Like here:
Second, do you know why the gauge might be holding the clock low? Have you seen this before?
Note, I believe they built these packs with BQ34Z100, not BQ34Z100-R2. I'm not sure if this is a factor.
Darren
