Hi expert,
Customer used LMR38020 and report there are some solder empty issue for thermal PAD due to the small 0.25mm height from the pin leg.
Would you please provide any advice to improve the assembly?
Allan
Hi expert,
Allan
Hi Allan,
Can you clarify the issue a bit more? Is the customer not able to solder the thermal pad?
Richard
Hello Ryan,
Apologies for the delay, someone will respond in 24 hours, as its a public holiday today in the USA. Thanks.
David.
Hi Ryan,
I'm afraid it is not entirely clear to me, since the LMR38020 should not require any different reflow profile than what is usually used for conventionally packaged parts. TI recommends a minimum solder joint area of 50% of the package thermal area. The performance improvement from there is usually negligible. Please see section 3 of this app note: https://www.ti.com/lit/an/slma002h/slma002h.pdf?ts=1725402766242&ref_url=https%253A%252F%252Fwww.google.com%252F
Richard
