TPS7B86-Q1: Need the detailed spec for TPS7B86-Q1 DDA D version.
Part Number: TPS7B86-Q1
HI Team,
We are considering the DDA package for TPS7B86-Q1, and we find it have the B version and D version, and we only find its pin out are different. For the detailed spec, they are still have any different? Could you please share a compared sheet about them to us? Thanks in advance.
Kunyue
  • Hey Kunyue,
    Both B and D version of TPS7B86-Q1 supports PG and PG delay functionality. As you mentioned, the only difference is the pin-out between both. Apart from that both devices will behave similarly in terms of the electrical performance.
    Due to very minor changes in the pinouts, the load regulation performance of B version is slightly changed compared to the D and that is captured in the EC table. Apart from this both B and D version are same only.
    Depending up-on the customer requirement, please go ahead with the required pinout. Both devices will behave same electrically.
    Rohit Phogat
