In my design after power up the Vdd voltage keeps fluctuating between 8.1V and 21V and MOSFET never starts switching. What could be causing this behavior and what is the best approach to fix this?
Hi IgorR
Thank you for reaching out.
The IC is most likely restarting because it has encountered a fault.
Please refer the following debug guides which might be helpful with the debug process.
Harish
