We are using the TI devices. Kindly confirm the attached devices are discontinued by TI.
Pravin Dhutekar
email-Pravin.dhutekar@philips.com
Mobile- +91 7387000455
Pravin Dhutekar
Hi Pravin,
I do not have a clear date for when we will have the newer version of this material. The current plan is to keep producing the older version until we can switch over to the new.
Hi Pravin,
These devices are all active. I am not seeing any plans to discontinue at this time.
Can you please check the attached notice? In notice, it is mentioned about discontinuation of the devices with the LTB date. This notice is issued from TI only.451210186161_TI (1).pdf
Hi Pravin,
My understand is that the LTB date is not longer valid. I am double checking to be sure as from what I can see is that eventually we will be moving these to a modern process.
Hi, we have received the PCN retraction notice. Attached notice for ref. Would like to close the case now as my issue is resolved now. Thank you for your help and support.TXII-L-A0020566415-1.pdf
