Other Parts Discussed in Thread: TPSM843620
TPSM843620 EVM Board, looks like meet OCP while turn on with Full load=6A, it causes Output Voltage raise in two step, please advise.
Can you share a waveform or image that shows the concern?
This appears to be an eload test equipment issue.
The load is 8A when the output voltage is 0.4V, causing the device into overcurrent.
Use constant resistance mode on eload, a power resistor or a different eload.
