TPS61288:
Part Number: TPS61288
Other Parts Discussed in Thread: TPS55289
1. Can I tie EN pin of TPS61288 to VIN pin (with a 10k current limiting resistor) to enable the IC using the battery? I am planning to use a lithium battery with a voltage range of 2.9 V to 4.2 V.
2. I have seen in other applications the EN pin is connected to VCC pin. How does that work because I am assuming you need to activate EN first to get an output at VCC?
