We are using the BQ35100 in EOS mode, and according to the document https://www.ti.com/lit/an/sluaal7/sluaal7.pdf, we are following the procedure:
- Wake up the gauge before any major discharge using the GE pin.
- Send the GAUGE_START command.
- Send the GAUGE_STOP command after the major discharge.
- Wait for the G_DONE bit to be set to one.
- Read the scaled resistance and measured impedance from the gauge.
- Save the scaled resistance and measured impedance to a data memory device.
- Put the gauge back to sleep using the GE pin.
However, when checking the resistance and impedance registers, both are zeroed, and we noticed that the AccumulatedCapacity register is changing. Is this correct?
We also observed a delay in the response for the I2C write commands. Is this normal?
