Part Number: BQ25672
I am using the BQ25672 IC and programming the registers for series configurations like 1S, 2S, 3S, or 4S. I set the registers, but I want to lock them permanently. Even after a power loss, it should retain the configured values.
For example, by default, the IC reads a 1S battery configuration. Through programming, I set it to a 2S configuration. After a reset or if I unplug and plug it back in, it should retain the 2S configuration until I change it again.
Thank you
