Can I get the material and CTE for TPS7H5001-SP so I can perform and IPC-D-279 analysis on my satellite circuit board?
Hey Philip,
Most parts have quality and packaging information located here in the buy table:
What information do you need outside of this in order to help with your analysis?
Daniel
Daniel,
I just need the bulk material and its coefficient of thermal expansion. I do not see that in the tables you pointed me too. Have I missed it?
Hey Philip,
In this section the entire material list for the device, the percentage of each part of the device it is, as well as the CAS number is listed in a table under "material content".
So it really depends on exactly what you are looking for.
If you want an approximate CTE for the entire device we can help figure that out.
If you want to look at each individual part you can estimate it using the material list.
What does your analysis look like?
Daniel
