Other Parts Discussed in Thread: TPS22996,
The TPS22996EVM is missing pull-down resistors on the ON1 and ON2 inputs on the TPS22996 device. Once enabled with one of the DIP switches (SW1 or SW2) the given output will stay ON even when the DIP switch is turned completely off. A high value pull down resistor will solve this issue. Even the datasheet states that the ON inputs must no be left floating.
