TPS61299: current consumption
Part Number: TPS61299
I have some doubts regarding the consumption of the TPS61299
I have assembled the circuit below on the bench.
From what I understand, the TPS61299xA has a Force pass through mode, where it practically works like a switch.
Measuring the consumption of this circuit with the enable pin set to LOW, I reached 300uA, is this as expected?
If I use the TPS61299x, which has True disconnection operation mode , will I have the same consumption or can I expect something around 95nA?
