I have looked at the following pages but could not understand them.
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1282592/tps923655-regarding-the-spec-of-ovp/4881804?tisearch=e2e-sitesearch&keymatch=TPS923655%252520duty#4881804
Could you please tell me about the following?
1.It is stated that in pre-charge mode, a low constant current output value is controlled by a low duty ratio, and in CC mode, a high constant current output value is controlled by a high duty ratio.
What is the reference value that serves as the boundary between low and high?
2.How can Vcc_th be determined for CC/CV Charging Mode?
3.Can you please tell me how the capacity of Cvin should be determined?
4.The recommended values for the loop compensation circuit are listed, but are these values for Vin=12V and Iout=1A in the circuit example?
If so, could you please tell me the formulas for calculating Rcomp and Ccomp?
Ryu.
