How will this device behave if VIN is at 0V and ON is at 3V?
Hi Andrew,
If the ON is high, the FET will remain on and Vout = Vin which will be 0V in this case.
Arush
Hi Andrew,
When EN is low, the FET will remain off. output side QOD resistor will also be present to pull down the VOUT if there is any.
When EN is high, the FET will turn on. Outside QOD will also be removed and Vout = Vin.
Arush
