I have a pretty basic doubt. Suppose the input to the bq25798 charger ic is absent(Battery only mode). Assuming the battery is charged, does the battery output its voltage to the Sys pin or the Pmid pin to the desired output system/load?Also, what is the difference between battery only mode and backup supply mode?
Thank You!
