Can you confirm if we can connect the NC pins 8,9 of LMG2100R044 to PGND? Will it cause any issue to the operation? We have some constraint from a layout perspective.
These pins are designed to be left floating, and are used for board level reliability. Can you help share/explain more about the layout constraint you have?
In the meantime, I will check what affects you may see if NC pins are connected to ground, likely it would cause a BLR concern.
Zach
