Hello expert,
Kindly ask two questions about 92682 channel configuration:
1. When only use one channel, it is explained in the datasheet that the other channel should be disabled, but how should we deal with the related pins, all keep floating or pull certain pins up/down, pls clarify.
2. If both channels are used, when there is some issue occurs in one channel, will it influence the work of the other channel? Or we need to judge according to fault type?
Thanks!
Daniel Wang
