Other Parts Discussed in Thread: USB2ANY
will every time it required enabling output using i2c after power off or just once??? registers retain their state or not after power off??
Hi Muhammad,
Every time after power off, all the I2C registers will be reset. So it requires enable again.
Mulin
Thanks... will USB2ANY device compulsory for this IC to program...or i can use any microcontroller for I2C communication?
Hi Muhammad,
You can use USB2ANY to control this IC EVM for debug. You can download GUI from ti.com. https://dev.ti.com/gallery/info/TPS55289/TPS55289 . But in a system level, a MCU is needed.
Mulin
