BQ27Z561: BQStudio support
Part Number: BQ27Z561
When updating a golden file created with Battery Management Studio as software for a product,
there is an issue where the battery remaining charge display and the actual battery voltage do not match.
Are you having similar problems?
Will this be improved by repeatedly charging and discharging the battery?
When a new battery is attached to a product, will the correct remaining charge display be output from the beginning?
For example, is there anything else I need to do, such as unplugging and replugging the battery once, or repeatedly charging and discharging it?
Are there any tasks that must be done after writing the software?
Thanks and regards
kugimoto
