Part Number: TPSF12C1QEVM
Hi Team,
How to connect AEF IC GND for a 2-pin AC inlet(no earth GND) application?
Charles
Hi Team,
Charles
The following is an example of 3-pin AC inlet with no earth GND application. You can follow the same for 2-pin AC inlet(no earth GND) application
Best Regards
Hi Naresh,
In my customer's application, they connect Y-cap to AC/DC secondary side GND(also the GND for PSU Vout), so could I connect AEF IC's GND to PSU Vout GND?
Charles
Yes Charles, you can connect them together - If you also have common chassis, IC ground and PSU Vout GND can be connected to the common chassis.
Thanks and Regards,
Naresh
