Part Number: TPS62827
Sir
We are planning to make the TPS62827 on by enable pin only (VIN power up before EN high, EN is not sourced from VIN but from additional I/O power)
As mentioned in the datasheet, “Do not leave enable pin floating”
We intended to connect a pull-down resistor about 100kohm to EN to avoid floating in any situations.
Does it make any sense to connect a pull-down resistor?
Or what is your suggestion? If the EN floating is not allowed.
Ben
