Other Parts Discussed in Thread: BQ79656-Q1, BQ79758-Q1, , BQ76952, BQ76940
I am trying to design a BMS with active cell balancing. TI team suggested BQ79656-Q1 (16S, 4th gen, does not require NDA for evaluation) or BQ79758-Q1 (18S, 5th gen, requires NDA for evaluation). After going through the data sheet it seemed little confusing on how to connect the charge and discharge MOSFETS using BQ79656-Q1. Is it possible to integrate BQ76200 high FET driver with BQ79656-Q1 and a microcontroller? If not how would I connect charge and discharge MOSFETS in the design that uses BQ79656-Q1?
I look forward to hearing from you.
Many thanks and Kind regards,
Criton
