What does the part or output voltage do when AVSN is open?
We have 3x120A, 1x40A running at full power with no issues. AVSP and AVSN connect to FPGA on-die sense points. We have 100 Ohm from AVSP to VOUT in case the FPGA is not populated or AVSP is open due to a bad BGA solder joint.
However, we don't have 100 Ohms from AVSN to ground. What happens when AVSP is tied to VOUT but AVSN is floating open?
Thanks.
