Other Parts Discussed in Thread: BQ77307, BQ76907
Hello, I'm designing a battery protection and I'm having trouble understanding the back to back FET configuration of figure 8-1 of the datasheet in bq77207. As I understand, DOUT and COUT are active high that control two NMOS, when a fault is detected the turn on and put the gate of the PMOS to 0, which turns them on. Knowing that, in the normal mode of operation as the voltage of the PMOS vg=vs they would be turned off and wont be able to charge or discharge. I would like to mantain the high side protector FETs if possible.
Am I missing something to understand this application? How can I configure this to work as intended?
