LMR38015: LMR38015FS5QDRRRQ1 - Datasheet error
Part Number: LMR38015
Hello
I've designed a PCB according to the datasheet for the LMR38015FS5QDRRRQ1 part.
There is however a mistake in the datasheet, section that describes the resistor values for the desired voltage output.
The value of the resistor for 3.3V out should be around 43k. The value in the datasheet is for 5V out.
See attached picture.
I was lucky that this mistake did not burn but MCU when powered up :).
