We have a Solar Charger design which will charge 4S NiMH batteries. The maximum charge rate will be around 0.14C, but often due to light conditions this will be lower. At these charge rates we will struggle to identify a negative delta V or a delta Temp condition when charging is complete, so I've designed a cut off threshold which will break the current path for battery charging when a specific battery voltage is reached. Will this method of charge termination satisfy the current taper charge termination indication of the BQ34Z100-R2? Is there any risk that when the current drops due to low light conditions we could get a false positive of the charge termination indication?
Matt
